查看: 4541|回复: 8
NX7.5.2.5 破解方法_求翻译
发表于 2010-12-28 21:28 | 显示全部楼层 |阅读模式
不好意思,我外文太差劲,如果硬着头皮装  ,装错了不好找原因,重新装,又是几天几夜的功夫!
. p- B" L: ?8 n2 L5 R' ^6 P/ S      敬请朋友们帮忙!谢谢!
0 M. v, J5 P5 f具体破解方法:
( Z' D; F" C: J9 I    It's Update only! To install it you need NX7.5 32bit to be " _( Q, P4 c: I# ]. Q
    already preinstalled!% r& }; C0 u" z( v# Z* {5 t+ a+ ^
    (1).Install NX7.5 Licensing.If you have already got ugS License 4 G5 |$ E) a0 z: \' d2 X2 x
    Server running go to (3);. Q$ u0 [0 K, {5 P# k! j! I2 `; N
    (2).When asked for license point to UGs4.lic supplied;
( R' w- k: a! I& k' v1 U    (3).Go to "Program Files\UGS\UGSLicensing\" and run lmtools.exe;+ E6 K4 V0 h8 R% B6 f9 w! S+ J. V
    (4).Select "Configuration using Services";/ J& p; c( E! G6 T9 U( e) `7 I
    (5).Select "UGS License Server (ugslmd)" in the list of servers;
; a( T$ B+ J6 I+ L- @: T( L0 c    (6).Select "Start/Stop/Reread" tab;
0 ]7 L* v/ A; L2 s1 V- h( E    (7).Select "Force Server Shutdown";) {* Q1 Q/ H: \7 D9 o0 I
    (8).Press "Stop Server";1 X5 A% b; c! x1 F
    (9).Replace "Program Files\UGS\UGSLicensing\ugslmd.exe" with one/ ^' \5 V! |4 {8 w
    from folder UGSLicensing;
, ], T% o; ]& r- |. E- {( X    (10).Replace "Program Files\UGS\UGSLicensing\ugs4.lic" with one
6 e4 k$ B/ t. d' f    from folder UGSLicensing;% M4 F0 M( x& p, j7 N
    (11).Press "Start Server";1 B/ j" L, N6 D. T& Y# J* S% J1 t
    (12).Install NX 7.5.2.5 32bit Update;
3 {. M  l& j* a4 l3 b$ ^    (13).Replace NX 7.5 files with those in folder UGS. Keep in mind
7 i" J0 A* I! w! R! V: P4 ^    paths;
发表于 2010-12-29 11:31 | 显示全部楼层
下个英汉互译的软件!!!
发表于 2010-12-29 21:16 | 显示全部楼层
(1)。安装NX7.5 Licensing.If你已经掌握了UGS公司授权7 W: t9 W! I" {' ?$ Y' v
    服务器上运行去(3);
9 T$ G7 q* C$ h3 b9 b0 E, u    (2)当点要求ugs4.lic牌照供应。
, D9 B0 }: {" m: |6 e$ p2 S% ?8 ?    (3)进入“程序文件\ UGS公司\ UGSLicensing\“运行lmtools.exe中。
# K1 V: r) i( [' T% L: l& M7 f    。(4)选择“配置使用服务“;
9 V# M! m" Z9 r, F; Y9 ^    (5)选择“UGS公司授权伺服器(ugslmd)“在服务器列表。
% c7 G- b% B5 g/ J; \; k+ ^* Q; Z    。(6)选择“开始/停止/重读“标签;5 Y; Z& {! C' ?$ F$ f
    。(7)选择“强制服务器关机“;3 p3 w+ ]" M% ^
    。(8)按“停止服务器“;
( ?% q0 M7 }/ |; v4 q    (9)。更换“程序文件\ UGS公司\ UGSLicensing\ ugslmd.exe“一6 M9 `! ^; S5 g4 `, \
    从文件夹UGSLicensing;; U7 j' I/ P5 U& o/ }7 `
    (10)。更换“程序文件\ UGS公司\ UGSLicensing\ ugs4.lic“一* T# B/ ]9 }4 X& Q2 u1 z/ y
    从文件夹UGSLicensing;
! q# `" l2 O1 ~+ F/ Z% g- I    。(11)按“启动服务器“;
2 f/ u* n% S9 s    。(12)安装NX的7.5.2.532bit的更新;- u$ b- z$ s2 I# o) e. s
    (13)。更换NX的7.5与UGS公司在这些文件夹。记住
# f3 u% a' _$ l4 L    路径;! P: P: z" S4 \- M" S
  j. c" e$ f% \. H4 x
呃,翻译软件,呵呵凑活看吧!
 楼主| 发表于 2010-12-29 22:28 | 显示全部楼层
非常感谢zhangzhaoo!
 楼主| 发表于 2010-12-29 23:53 | 显示全部楼层
仅供参考! B1 k$ J) Q2 @& s9 z& G/ f
(1)运行 lmtools.exe;
! \' b# S1 u1 I" }& p: ?4 U4 J3 L(2). 点击Servic/License file,选择"Configuration using Services"选项卡  V- |6 W8 }3 n# c
(3).从列表中选择 "UGS License Server (ugslmd)" ;
1 ?' N. c) N  \% c# y(4).点击"Start/Stop/Reread"选项卡;
3 q% s# F0 I$ p/ M3 x$ s5 C5 r1 c(5).选中 "Force Server Shutdown"选项;
; h: F* ~$ ?" i5 T; r. z7 P(6). 单击 "Stop Server"按钮;9 O0 a; Z2 m3 ?# X! N5 P
(7).替换 "Program Files\UGS\UGSLicensing\ugslmd.exe",9 V$ l- t& V( z+ F" W9 Q) V. B4 h7 }9 m
(8).替换 "Program Files\UGS\UGSLicensing\ugs4.lic"   + J3 |, t2 u+ X! o. s' S
(9).单击 "Start Server"按钮;- {; t( v2 N6 F+ G+ w
(10).安装NX 7.5.2.5 32bit 升级包;! r& {, p5 t# i8 V/ O4 h3 v
(11).用破解文件替换NX 7.5的对应文件。
发表于 2011-1-12 23:21 | 显示全部楼层
It's Update only! To install it you need NX7.5 32bit to be# j- N3 i9 M9 \# G) l9 G, m$ T
) \9 h8 r: R; ?  E. ]; u此更新仅针对已经安装NX7.5 32bit(位)的用户/ H4 D/ j* I6 j" t+ Z: C4 q
    (1).Install NX7.5 Licensing.If you have already got UGS License3 z3 I1 V( H- C1 A& {: }
: n* k4 Q' o' V5 X" f7 s(1)安装NX7.5许可licensing。如果你已经安装许可,请直接跳至第三步. g; u, m, T" N4 W
    (2).When asked for license point to ugs4.lic supplied;
6 ~) J7 ~$ @9 n(2)当询问许可时 选择至已经准备好的ugs4.lic
) o0 B" L" z; W    (3).Go to "Program Files\UGS\UGSLicensing\" and run lmtools.exe;
9 D4 U( ^/ V4 N6 g9 h2 ~(3)进入"Program Files\UGS\UGSLicensing\"启动  lmtools.exe
, \. x8 a. g& E    (4).Select "Configuration using Services";
  g% T" m& w% |. `9 e5 O9 h# A2 a# e(4)选择"Configuration using Services"
( [* I+ ]4 @  @4 {3 S( h8 G5 @% q    (5).Select "UGS License Server (ugslmd)" in the list of servers;8 l. w( D8 S% S  p1 F+ F6 i
(5)选择列表中的 "UGS License Server (ugslmd)" # T' o( H5 Y! [/ ?8 C
# o. |  ?. t+ R3 r1 ?(6)选择 "Start/Stop/Reread" 选项条& ^0 k+ b2 h: C$ D0 {
5 S( m: |5 R; Q# e/ `% B4 o(7)点选"Force Server Shutdown"% G% {: R9 |* u& N+ r+ V
    (8).Press "Stop Server";1 A! Y" e% K6 ?/ I) V3 q$ b
(8)按下"Stop Server", Z# A1 s- @  A" c
$ ?- l) L$ R# C4 h. {    from folder UGSLicensing;
+ Z0 I* g* t3 K, K% s(9)把文件夹 UGSLicensing中破解文件替换至 "Program Files\UGS\UGSLicensing\ugslmd.exe"
, u9 ~. Z% A& M9 _- R; g# o  O    (10).Replace "Program Files\UGS\UGSLicensing\ugs4.lic" with one, U; e) V! [- F* q
6 _3 g0 ]7 T/ u5 c9 Q* L" i(10)文件夹 UGSLicensing中替换 "Program Files\UGS\UGSLicensing\ugs4.lic"5 L& e3 l# _; _7 F, ~: W
: v9 E7 y0 o( t(11)按下"Start Server"
- A; r9 c% \" D4 }    (12).Install NX 7.5.2.5 32bit Update;& q. z1 ]/ |% q8 J6 e- e
(12)安装NX  7.5.2.5 32bit Update
+ X& ?& d# t" K( c+ s    (13).Replace NX 7.5 files with those in folder UGS. Keep in mind- h2 z2 `4 Q, H* c0 F( m
(13)注意要替换这些文件至文件夹UGS
* Z- {8 d0 m+ C# U; w4 f    paths;
 楼主| 发表于 2011-1-13 18:53 | 显示全部楼层
朋友,谢谢了!
发表于 2011-1-22 15:31 | 显示全部楼层
谁破解了,截几个图来看看,菜鸟的看不懂呀,只会看图呀
发表于 2012-10-31 22:30 | 显示全部楼层
想要64位的* k& k" A1 @3 _, h3 O
GMT+8, 2025-7-8 18:39 , Processed in 0.144527 second(s), 25 queries .
