查看: 4479|回复: 8
[分享] 让每个人都成为定制程序单的高手!
发表于 2011-1-12 10:37 | 显示全部楼层 |阅读模式
在定制程序单时,最麻烦的就是一些参数的英文缩写!现在全部公开:4 u, K# P0 m1 ]. k; K8 Y! @- O9 z' }
Typical Header Variables
: W" l# v( m. E/ l+ C) C- e9 Y
[/tr]
Variable
. n& G- l: n/ B! @/ b: m! \2 j: _! n3 p
Use
1 T- j* h/ x: J  P/ l
||PART_NAME||
6 v0 k' i* A- ~8 v! R6 p
Name file name (ELT file)
1 N+ R$ I( C* X4 m* U; W# m& R
||XML_DOC_PATH||
" ^7 K8 S" Q/ C7 j4 [
Path (ELT file)
& E" z/ w" Z. i/ D% N& K2 _, B
||XML_REP_PROG_NUMBER||
$ f( M- C* H" J$ F
program number
0 K& u$ x" a: N
||XML_REP_PROG_COMMENT||
1 V! h; q- H% ]' v) J1 K. c1 A1 d; C
program comment
% @5 `1 t7 K9 L+ M
||DATE_SDD||
! P& J' f/ M1 {% L# b* h
Date - Day
7 b# Z6 c+ y; s/ _
||DATE_SMM||
4 z) ]3 p$ Z  C* B( L7 k5 v
Date- Month
' J, v5 r4 h. ]* k, b1 C% S
||DATE_SYY||
4 t: O: t9 g0 |) p4 F* b
Date - Year
3 P3 h- q  @9 Z5 j6 F- G7 t! \
||PART_NAME||
: n: U4 j/ ?3 \2 t6 ^
User Name
+ L( Z. r1 U8 s/ Q8 E
+ `/ l$ p8 U( v4 _
$ m5 ^, S% m8 Q& p% `; n4 [
Typical Body Variables
  q! y- F( d" P
[/tr]
Variable
5 H1 F& y% v7 ^6 C5 w
Use
8 u/ J: h# Y6 W
||TP_NAME||
# A1 y) d5 m# c
TP Name
1 B6 S8 |) L* y0 D6 P) C
||TP_COMMENT||
: F# z; {: p/ s
TP Comment
9 |% S( l' I. T0 T8 G" g- s
||PROC_NAME||
! a+ @# c# B; x3 h  j! g7 E' B/ a7 b
Procedure Name (short)
% ]# J( p/ q& v+ _
||PROC_LONGNAME||
* ^. u, L+ E. ]$ K; b
Procedure Name (long)
& N* X& u, {( Y& N$ l3 i7 ^/ {; _
||PROC_UCSNAME||
  A  U1 ^6 V- O8 J6 i
Procedure -BKS
/ k1 h: w  O$ {  y
||PROC_COMMENT||
9 G+ D2 `+ L6 d) {
Procedure Comment
8 s) o0 H& s( X2 p1 H
||XML_CLEAR_PLANE||
' h0 B& |8 x/ l
Clearance Plane
) c8 A* T) `' Z0 ]
||SPIN_SPEED||
* l- A9 D/ h2 l& \+ r- I- `
Spindle Speed
6 L6 N6 R) N9 }, A
||MCH_FEED||
! r% h& e+ S. c- a7 ~) F: D, J# Z
Machine Feed
. f+ B; L# D$ V' c
||XML_SURF_OFF||
% v+ R# u6 g1 m( @, B
Surface Offset (general)
3 A' ]- X" h# y/ Q8 C; s
||XML_SURF_TOL||
7 E+ I% a- s  H. g
Surface Tolerance
3 a/ H! s$ L/ O6 d6 A- v9 r
||XML_H_STEP||
) d5 ]$ E/ ?  L$ S  `; Q
Horizontal Step
6 O$ m( G; f! |' q2 U
||XML_V_STEP||
. \4 m/ X+ Q6 F) I8 v! @2 |9 w
Vertical Step(general)
3 Y$ B4 Z2 E9 C5 |# E- k2 ]
||XML_ELECTRODE||
* Z1 p6 J# s, C% g8 m# x
Electrode Machining (Yes/No)
; l: H1 B  v2 }& R: f/ T
||XML_ELEC_SPARK_3D_GAP||
- N7 O  g/ ]8 R2 @. p7 F
Spark Gap + 3D Orbit
; Y) E6 I3 F' a; D. i. s: ]/ w; E
||XML_ELEC_PLAN_GAP||
9 N" O3 i/ O$ }% Q2 [
Orbit Planar Gap
7 |9 k3 p9 y% f; l
||CYC_PECK||
" d+ o" z4 ^7 F4 A' G0 t
Drill Cycle Peck
$ f8 U* }9 e9 ?/ k0 A. I& u
||CYC_DWELL||
; h8 M/ ~& k% V( V4 `8 G, ~
Drill Cycle Dwell
, M( E( I2 J' N: s8 j% _2 U7 |
||CYCLE_1...12||
' x! c$ @  n( y% }: [
Drill Cycle
' z5 d, ]9 M: b- D2 M6 z" s6 y
||TOOL_NAME||
' M- b2 W2 \2 M2 N$ i
Tool Name
+ K% L$ j( ]" F
||TOOL_CMNT||
' o! \6 H4 W# w0 Y9 Q/ W
Tool Comment
- B9 ~" Q* F( p: z3 R+ {/ K; P- g+ H
||E_TOL_TYPE||
& y( A% L# l& I# r) }) d* N0 ^2 I
Tool Type (see below)
0 j: M% B3 L+ s
||DIAMETER_||
$ D! X0 _, o3 G/ z
Tool Diameter
' R: T6 ]  F* _4 H/ |, A2 [$ S
||TOOL_RAD||
7 X* G% O7 }9 i1 Q' ?- j1 K1 _
Tool Radius
! V5 r  H4 t( E
||TOOL_NUM||
/ }. s& K5 w( v: a9 n
Magazine Number
: x  t. p( l7 q2 i  @4 b
||TEETH_NUM||
3 x, q' ~% L# E/ c' x; Z! e( G
Number of Teeth
2 D) W2 u0 C3 I- `( S
||CLEAR_LENG||
- w! D) A6 Z) z( R# |0 S- P
Clear Length
, ?0 N! Q# b8 {  X6 B, a
||CUT_LENGTH||
, M+ f8 U- B/ X/ o. L6 @1 v9 I8 b
Cutting Length
4 V& V- Q* S$ t9 d, x9 k& |
||XML_MIN_CLEAR_LEN||
, L" s) H- ^( [; r5 n+ I6 q
Minimum Clear Length
& D2 p+ u( g1 j: j& ]0 D
||TOOL_TOTAL_LENGTH||
# y5 O" f: N; W
Total Tool Length
  V# v% T/ D( K, E: T4 M* ^+ k
||CON_ANG||
$ m/ P) G5 E) {8 K  V/ c5 w
Tool Conic Angle
/ x( ?5 _' F! |" D
||TOOL_ANGLE||
, `. Q) k" L# `4 T% D5 C. M
Tool Tip Angle
/ N+ t0 P9 O. h1 m; s8 v+ {
||SHANK_CON||
. ^0 C: R$ C7 c7 L- o8 f9 K7 v& Y
Spindle Conic height
+ P) E$ p. d5 M8 g& i
||SHANK_TOT||
% z7 k# o/ j, F
Shank Total height.
" j6 i) k3 m- I! u* i& ]* c2 Y$ k
||SHANK_BOT||
" X# d0 S& W1 r
Shank Bottom radius
. o6 w& M" E( V( Y) L+ d; B5 h9 O" d
||SHANK_TOP||
" J$ D) a9 y% w, R) y! T& i! Q1 ?4 F
Shank Top radius
+ k1 E1 e- ^# l. n# D1 i
||HOLD_CON01||
( w& Z5 {( @; i$ k. |# o
Holder Conic height (holders 1 to 10)
2 w+ s# s5 h, P* l. W3 o
||HOLD_TOT01||
+ b; R+ \* M# \  e/ S4 f
Holder Total height (holders 1 to 10)
7 v( F; [1 ?8 s' j: M: }! w
||HOLD_TOP01||
; z( z$ f3 P& y9 b$ [; [
Holder Top radius (holders 1 to 10)
: J$ u) d) b* _' v! S# |
||HOLD_BOT01||
  F7 W+ m' O) x9 v
Holder Bottom radius (holders 1 to 10)
5 s5 G- U# `  o6 \  I
||X_MAX||
0 k- i4 j4 ~% E, v5 Z
Maximum X
) k& s' h$ N0 k; E( ^
||X_MIN||
9 ]6 S/ i- o* ]) l; b2 z
Minimum X
7 _3 e3 _  G+ V5 A' _' I+ ]
||Y_MAX||
+ }* P; j. E3 s/ O" N8 o5 c
Maximum Y
& s3 a* J6 h& G: U
||Y_MIN||
- C& `: x) @8 ?6 `$ l: w
Minimum Y
9 z% W. \( T6 k% d. @+ q9 s. Z# W
||Z_MAX||
  O" K+ r" c* V
Maximum Z
2 ]6 I- p# n' O4 N1 [
||Z_MIN||
' F9 N. Z' v) x# F
Minimum Z
2 s% M1 `) A! z7 F
||AIR_TIME||
5 V7 c& b' t" i2 B
Rapid Motion Time
0 F5 V" [6 x& e2 H0 R5 p8 y
||FEED_TIME||
6 P  D1 v1 O; C! O8 U
Cutting Motion Time
4 T! f7 \1 @5 G3 Z$ T
||TOTAL_TIME||
* |. Q5 {( T3 x9 Q' c9 X4 U, k
Air Feed Time
7 z7 x, T5 Y$ J: o* j: \6 P4 |) r
1 E4 _  J9 ~9 X: D- e) H$ hNotes: The variables displayed in red give the totals for the entire file when used in the Trailer.& R, d' U( u: e6 _1 o) p* D3 N' w
E_TOL_TYPE values: 0 – Ball cutter& V" ?* n+ u! j, {
' @; T) [) m* n$ z8 z1 A
1 – Bull nose cutter& t7 }$ z1 V8 _4 K' p) x' n% G
2 – Flat cutter
: C. d/ T2 N; A9 C3 j% @- V$ ^3 – Drill
" a3 o% Q# u, |' M( B* X7 P, P4 – Reamer0 a0 z$ @4 W# s3 \9 n% X3 S
5 – Tap
# [8 v/ j' S$ R) ~7 L) u; b( C6 – Center drill
. {6 \% V; [$ ~( K7 – Lollypop cutter
' b  j+ T/ N( M. w( L8 – Slot mill (full radius)
1 k0 I& E: e( U8 a, P4 d9 Y4 g9 – Slot mill (sharp corner)/ C( a2 U/ ?  ?$ y9 {2 ~- s
10 – Slot mill (corner radius)
  S+ {4 Z: V, G' J9 ^11 – Dove mill (full radius)
$ A5 Y( w2 [6 X) r3 E12 – Dove mill (sharp corner)
) L6 J5 R+ ?  Q13 – Dove mill (corner radius)$ {. p8 E0 d8 A; D
14 – Counter sink
& M9 _0 h( w( |( N! n3 ^
. n$ S9 z) C  Z( ?7 y# I
4 U/ N$ W* n# f9 h. f
Typical Trailer Variables
8 [1 c3 J# S% l" Z( V0 R* d- K1 L; R
[/tr]
Variable
( U2 Y: H- A" C' v3 G
Use
3 @0 |3 I3 `0 T+ T
||PROC_CNT||
# y) C) C) y. v, K4 \* r
Number of procedures (with Auto-Drill also number of tools and orientation changes
" ~4 H- \. l+ K- I- Y4 L
||TOOL_CNT||
4 R& y" y' e2 o8 A
Number of Tools
; q9 O( Z. t( h7 k0 L
See also Body Variables marked in red
发表于 2011-1-12 16:19 | 显示全部楼层
看不懂啊
3 W- R' l8 Y. [: }( c  不知道用在那的啊
发表于 2011-1-18 19:48 | 显示全部楼层
看天书,头晕
发表于 2011-1-26 17:00 | 显示全部楼层
什么意思?不懂
发表于 2011-4-4 12:54 | 显示全部楼层
5 |6 z# }( B& [& {- X: {: n6 V
shi 是什么编码··不懂
发表于 2011-4-16 17:28 | 显示全部楼层
搞的什么灰机
发表于 2011-4-16 18:03 | 显示全部楼层
没见过也没有听过,能说说这些怎么用吗?
发表于 2021-1-2 11:43 | 显示全部楼层
看天书,头晕
发表于 2021-1-4 08:01 | 显示全部楼层
這是用在EXCEL 的程式單變量
GMT+8, 2025-6-7 05:34 , Processed in 0.150073 second(s), 25 queries .
