UG打开中文外挂; Q4 E/ y9 y" G3 l7 {
2 g: X# w9 C9 A& D2 u2 y
3 c# _0 i" j }. [使用方法:(本外挂支持UGNX2-NX5所有版本)& D( M. m( G( \- P2 L. y8 |! ?! r6 N
1.将文件解压到C: F; S2 e: W1 p
2.打开UG目录下UGII\menus\custom_dirs.dat,. a0 y; u$ Y) P
用计事本编辑:在最后一行添加C:\UG_CHS,保存,重新启动UG.
* d; s4 L2 X# Q) X h: x重新启动后UG会,产生打开与保存的两个按扭,UG工具条 自定义 里会自动添加ug-chs选项$ \2 a/ h' m+ v$ R
T% p2 M2 L) J9 ?. E9 j
下面是custom_dirs.dat文件 用计事本打开举例:(注意红色部分)2 S6 i3 c/ p4 l' I/ Z$ {6 A
6 q: ?8 u9 N+ B, o, o
# custom_dirs.dat: Directories to search for Unigraphics customizations; k8 R' s1 {0 R+ L! C
#- C* o. K" K; P4 r
# Copyright (c) 1999 Unigraphics Solutions, Incorporated1 b& r. z% v# l) ~2 G
# Unpublished - All rights reserved/ l I* D4 ^) @' b
#- }% q. k5 y7 I: a9 b- L: s
###############################################################################% d/ E9 _/ x H) F) f: F/ [
# 1 x, [6 N3 R3 Q9 |
#2 w- }- ~2 d; _! I
# This file is used to specify directories which will be searched for
. c. G) q; E8 @% _/ [: q8 E5 K# menu files, toolbar files, dialog files or UDO libraries. The directories
+ k5 C8 m5 p$ j. g# added here may or may not exist, to allow the same file to be used at
$ T W( m- u$ S' [1 K2 J6 ]# multiple sites. When Unigraphics starts up, it will check each entry, if
* T: E/ h: M, L. {4 E0 z# the directory does not exist, the line will be discarded as if it was a $ f/ A- ]$ d$ R1 S
# comment. Comments are allowed, and must start with a # in column one.
( I8 H0 m1 A+ @- K# c#
+ Q! t `$ v( }4 \3 r$ p# Directories must be listed one per line, with nothing else on the line. The
: t9 y7 m9 I$ q+ V# directory may include environment variables, by specifying $variable. If 0 D- n- t1 N! P$ r
# a $ is needed in a directory, it may be specified using $$, e.g.
4 T" M* R+ R; Z0 u# /users/my$$ would be the directory /users/my$. The file may be made to 4 ^3 m x" k: i/ H' i/ G6 e7 i2 K0 d
# work on UNX or WNT, on WNT any / characters will be replaced by \.
; q e8 @2 G8 o6 e5 [' L#
7 h2 Y9 [! g- J# A #include construct is supported to include other files, to make it easier
( T# w8 n7 E. ]6 a( Q! X! i) ^( ~# for individual users to customize their runtime environment. Finally the
4 h! _# g$ d/ C! |# location of this file is controlled by the environment variable ) n2 D7 Y- [5 N: \7 r i+ V
# $UGII_CUSTOM_DIRECTORY_FILE which by default points to
: G: A/ h% u' q* i& @4 s6 E# $UGII_DEFAULT_MENU_DIR/custom_dirs.dat
- ?4 a0 Z/ ^' |9 M* K8 |#
; A* w+ E6 }9 L, y! d5 _2 f0 F1 w# Customers should feel free to edit this file.; n) R/ H" J* ?0 i7 p" u% Y
#* O9 P2 A/ |$ L( t: v6 I
#################################################################### m0 q" H+ K% h( C. P! u
#0 e1 U B# i' `, q) L6 o: n1 K
# Customer modifications can follow on here {5 t* R8 T2 O" M% l
$UGII_ROOT_DIR\liang
: q# g ]0 x Y! C7 m7 r5 ?3 q$UGII_BASE_DIR\stdlib
5 q7 } G8 j: s! {C:\UG_CHS( o; N% \' Y4 l Y, ]; k
注意在添加C:\UG_CHS时不要#号在前面,
: H$ N- Q" [4 J- U保存后打开UG后,再打开UG后,把原来UG自带的打开与保存按扭
3 X) ^7 D3 S% @' Z2 c放到自定义的工具栏中,把本外挂的产生的打开与保存按扭保存到工具条中!
; J" z4 M) u8 C5 `5 Y3 o0 ~每次打开中文件夹是选用本外挂的打开与保存按扭----OK |
