依然是菜鸟求助, n, g' C1 R* j4 D, l2 t
我用UIStyler建立了一个按钮,那如何实现:点击该按钮后可以用鼠标选择一曲线,然后获得它的中点,我的程序如下,但是似乎总是死循环。& Z( a: R5 ~9 M8 H" j
int GP_action_0_act_cb ( int dialog_id,
4 M9 ^* V/ C. x8 N5 K% i7 G1 y void * client_data,
$ r1 _" ?3 A% p' `4 s/ v% M UF_STYLER_item_value_type_p_t callback_data)6 [- `# |- V1 k# \9 E- t5 f
{% |2 \" u* o- y9 I$ o
/* Make sure User Function is available. */
2 t$ d' A9 v5 Y! _% V if ( UF_initialize() != 0) l( e2 p( X3 [1 X2 K, l! C! h: O1 W) M
return ( UF_UI_CB_CONTINUE_DIALOG );
, d# T+ h8 u8 N4 u) Y# d7 U) y8 i) u& q, O: u& P& g1 I
/* ---- Enter your callback code here ----- */
7 J, C5 h) i1 M9 T) p" q. i8 Dchar message[133];( ]2 k9 l! U$ A3 [9 n, j2 ^( ^
message[0]='\0';) D$ ~9 U6 R3 C R
strcpy(message, "请选择一条曲线");
1 O8 C3 ?$ i4 K. x4 vUF_UI_selection_options_t opts;0 q0 q* _% n) R
UF_UI_mask_t mask;
4 | e/ N4 T, G% F( Uint response;$ P' Q) h- J9 B5 V+ m6 m
tag_t object, view;2 j: J4 g m+ Z0 h6 F5 S
double cursor[3];
, X! c. _4 T9 ^* U2 i9 Cint unhighlight=0;
! {% M) a7 E. q# A5 R$ u5 T) q+ u) o% G" k( \9 _
0 q8 i, p% G6 f2 V' n& E! G8 J+ B6 f1 o; o& i5 r: }5 b
UF_initialize();$ u9 f- c- i8 w# h3 ^, b4 ^
opts.other_options=0;
8 W& h, X8 a. H3 T) a- t @opts.reserved=NULL;
& a9 n2 Q- [+ X9 K5 Copts.num_mask_triples=1;
* @2 Q+ F, o, b; [: V# L Qopts.mask_triples=&mask;
* h7 }" E& p% U0 }8 Q8 B2 h y1 C, @
6 k* N/ r+ q5 B0 i- E& Q* Lopts.mask_triples->object_type=UF_spline_type;
2 z) R: b) O* H6 ?. ]$ m) fopts.mask_triples->object_subtype=0;0 n/ A8 P! E9 t3 D6 o. M
opts.mask_triples->solid_type=0;: Q! N; z+ C2 ~( p w$ s; v
7 O6 d- n1 A, v2 s! f1 H0 _4 b, Fopts.scope=UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY;
( b, D# L- C3 f, gdouble port[3];6 e3 Y+ Z5 `, g+ d5 Z, R6 Q# D6 @! {
3 t* v- T' w: P6 c+ {2 W
5 }2 X: [ E1 s2 J3 u+ s$ f% ?. t8 b! Xdo{int irc=UF_UI_select_single(message, &opts, &response, &object, cursor, &view);}# l7 `$ n# G$ U( Y& b% P% N7 B4 _
3 F- T. }. g7 x% r" W
while (!(response==UF_UI_OBJECT_SELECTED));" W0 x7 O8 o2 ^/ [, i0 J
if (response!=UF_UI_OBJECT_SELECTED)8 x2 [8 k! X: c% N: `/ h3 q5 u
3 U( Q# x$ y: w0 p; N/ Yuc1601("No Curve Selected",1);3 B0 V* Y$ O4 V% i0 m- ?' x% @4 n
UF_terminate ();1 r& A+ F6 D" N- w8 Q
return (UF_UI_CB_CONTINUE_DIALOG); S4 m$ A' U* I7 V- L
% D& V8 D+ P: P9 X9 O
7 B6 ^) h* Y6 D8 K
0 r7 T' v; \8 }9 X) [7 rint ret=UF_MODL_ask_curve_props(object,0.5,port,NULL,NULL,NULL,NULL,NULL);
7 [: O: D* {: D0 i G3 _ char message2[133];
' f& s7 b9 p! n& C- b, r message2[0]='\0';
0 _9 _8 Y* V) x0 [9 { sprintf (message2, "曲线中点坐标为:%f,%f,%f",port[0],port[1],port[2]);3 t1 x) C# Z# t/ n4 E1 e
uc1601(message2,1);. `2 _. R5 X; B' i( ^& X
. Z& n" S' }' b- I9 R, }: U- p4 e1 F2 i; I, \7 ]- ^ s
E$ w$ t: T1 `( G/ t" F
UF_terminate ();
8 A+ F. l' Q! A1 Hreturn (UF_UI_CB_CONTINUE_DIALOG); \9 r8 A1 w$ ], B% [3 m7 J; o3 L
