查看: 2609|回复: 21
机床报警 上传程序 请高手看看 那里的问题
发表于 2011-2-19 20:42 | 显示全部楼层 |阅读模式
一运行就报警 广州数控系统' v$ r$ y6 H8 x3 d/ t3 Q+ {
, J2 p. H( X7 G4 q& k1 x3 |%* [# H& @0 a& h( {% [  ^
O01231 k: \* b9 ^9 C9 o
G40 G17 G49 G809 u. b: d8 Z3 L: N% H: O; ]) C
(Tool_Name10 Tool_No:2  Planar Milling )
0 k6 S1 z" `! I, x  tT02 M06
& }: R; ?- ~. F4 ]! ]G00 G90 G54 X-.465 Y25.504 S1600 M03
( I' Q0 h+ g& s& \6 I% c& ~$ Z& nG43 Z100. H02 M08
2 k0 w. C! h+ K; S- u5 dZ6.02
9 Z4 T. L& p3 N$ D( |0 wG41 G01 Y18.504 F500. D52
( Z$ d. K* y+ W' }; n# Q# UG02 X0.0 Y18.51 I.465 J-18.504
; r4 L% j& a9 ?0 V: cX5.254 Y17.749 I0.0 J-18.510 h& s1 p, |# l9 H' M( Y7 p
X10.31 Y10.979 I-2.004 J-6.77
) i3 r3 u- U& I- PG01 Y-10.979+ Q( b/ E9 l- @, u$ t
G02 X5.254 Y-17.749 I-7.06 J0.0
& ~/ ?! b# g9 X7 D* e1 DX0.0 Y-18.51 I-5.254 J17.749, V6 A, n7 j6 o( @2 Z
X-5.254 Y-17.749 I0.0 J18.51
( W5 B0 R" O% KX-10.31 Y-10.979 I2.004 J6.771 y# _6 d( s0 V/ B; y; G/ N
G01 Y10.9795 n, ^9 K/ ]! C. X8 ]* l0 y
G02 X-5.254 Y17.749 I7.06 J0.06 u' o$ x' M0 v0 }
X-.465 Y18.504 I5.254 J-17.749; i3 ~8 j$ ?. G. L' t
% d$ i/ Z( U+ |X.535 Y18.502 I0.0 J-18.51" X% X& @) \/ v& ~: f5 K/ z& Y
G40, j4 X7 E' J( g3 w
G01 Y20.502
/ L6 x* [# r: I& ?X-.415 Y19.505# S5 k- ~3 G1 P! t" f1 h
G41 Y16.505
+ c/ H/ j2 q" m6 p) C5 bG02 X0.0 Y16.51 I.415 J-16.505' d8 d/ b, J/ g
X4.686 Y15.831 I0.0 J-16.51# `- ^- c; Y$ K+ _% J
X8.31 Y10.979 I-1.436 J-4.852. `/ _' G" I6 v# G" y
G01 Y-10.979! J% ~1 T# ?- D% Y: Q8 \% \
G02 X4.686 Y-15.831 I-5.06 J0.0- K% c' p* \# \: ]8 A: u+ H6 ?
X0.0 Y-16.51 I-4.686 J15.831& b2 W3 x/ M* i
X-4.686 Y-15.831 I0.0 J16.51
7 H6 z+ r% U+ I0 w0 F. GX-8.31 Y-10.979 I1.436 J4.852; j* @$ V  N+ Y2 q" e( p
G01 Y10.979
; P) A1 X6 I! |/ ?% B+ z0 |5 h; |" QG02 X-4.686 Y15.831 I5.06 J0.0
; d/ D* c- Q. c: o4 j9 {X-.415 Y16.505 I4.686 J-15.831
6 Z+ R9 b2 A( b5 ~+ jX0.0 Y16.51 I.415 J-16.505; Y. a5 A4 I  Q
X.585 Y16.5 I0.0 J-16.514 G6 l2 e' ~% f' ?
G40& U! y" x% ^6 x4 L* a- g% p
G01 Y18.55 Z1 \0 ^% v, @2 i0 k8 l# ]9 `
X-.413 Y19.445
( R' l$ [8 u$ e7 J' ]& @4 I, VG41 Y16.445 # O! t0 |+ @5 B2 ~6 M
G02 X0.0 Y16.45 I.413 J-16.4452 }( w% ?. d; k2 j' Y7 _6 U. A1 _
X4.669 Y15.773 I0.0 J-16.459 v4 E% ?1 ?& E' V! m) H9 T" @, N6 o
X8.25 Y10.979 I-1.419 J-4.794. K, j$ X% p: E5 i6 T
G01 Y-10.9794 q6 Z/ i( U; d7 R
G02 X4.669 Y-15.773 I-5. J0.09 V3 y0 l! v0 x6 U/ C& k& V* A
X0.0 Y-16.45 I-4.669 J15.773  V' [! ~8 m$ }1 H% m0 \
X-4.669 Y-15.773 I0.0 J16.45: O2 z! E$ @" H( v" \/ s$ T; g
X-8.25 Y-10.979 I1.419 J4.794" ?+ O7 q" _9 |2 C! R
G01 Y10.979' ^' x6 Y& H4 w- }
G02 X-4.669 Y15.773 I5. J0.0
- @: Q5 }5 J7 T2 f& MX-.413 Y16.445 I4.669 J-15.773; n8 C' @( Q9 [4 l: G  F4 I# g0 b- ?
; U7 Z3 K1 S* ^9 g" |# tX.586 Y16.44 I0.0 J-16.45
8 B5 t& e& x$ n3 ?" ^6 w9 uG40/ j4 r) e6 i) E1 P/ v
G01 Y18.44
' v0 O  T( I, eG00 Z100.
* S1 C9 W! ?6 RM057 Y6 E5 |# t+ {; a) J
M09
+ U- J5 T- D* {# M+ s* ^" H, g6 tG91 G28 Y0.0
! r# e: z- P8 _9 vM30
( R0 O# o9 w- d- y, f* x$ H%
发表于 2011-2-19 20:51 | 显示全部楼层
好像是D52报警吧
 楼主| 发表于 2011-2-19 20:58 | 显示全部楼层
不是的 以前一直用 都没问题 广数系统 没有半径补偿这一行 长度补偿和半径补偿在一个行里 上级规定1-50用来写长度补偿 50-100写半径补偿
发表于 2011-2-19 21:11 | 显示全部楼层
O0123去掉就OK了
发表于 2011-2-19 22:27 | 显示全部楼层
后面的G41之后没有D
 楼主| 发表于 2011-2-19 22:51 | 显示全部楼层
刚刚上网看了下资料貌似和建立G41的进刀角度有关
" k* o, U" q* l7 D$ h这样建立G41就不行
/ b% l  `! h. i3 y& s1 x# w  p 2.jpg
- x& U9 n: U- z/ a) h像这样进刀方向和切削方向角度大于90度 进刀的长度大于刀半径才可以 不知道是不是 没有上机试过
 楼主| 发表于 2011-2-19 22:53 | 显示全部楼层
希望高手能详细讲解下 G41  谢谢
 楼主| 发表于 2011-2-19 23:04 | 显示全部楼层
怎么都是围观的人多 回帖的少了 都发表下意见把 错的也没事 帮忙顶下贴也好 论坛关于G41 G42补偿的帖子太少了 大部分都做模具的用不到 做外协 零件的用的多 但资料少 而且不易懂
 楼主| 发表于 2011-2-19 23:16 | 显示全部楼层
睡前再顶一下 明天礼拜天休息 起来看看
发表于 2011-2-20 09:38 | 显示全部楼层
圆弧过切吧 下刀位置离远点
GMT+8, 2024-11-19 02:29 , Processed in 0.054332 second(s), 27 queries .
