使用方法:(本外挂支持ugNX2-NX5所有版本)' P. s1 K5 e V4 E
1.将文件解压到C:8 n0 S3 P8 a. B+ \9 k% B
2.打开UG目录下UGII\menus\custom_dirs.dat,1 c: p9 Z. ]* z& r. A
用计事本编辑:在最后一行添加C:\UG_CHS,保存,重新启动UG.: V$ X; X, \) o+ j
重新启动后UG会,产生打开与保存的两个按扭,UG工具条 自定义 里会自动添加ug-chs选项8 f! y; B' k* c7 f5 K9 c& Z! p
+ q' T; i( r6 j% s* X
下面是custom_dirs.dat文件 用计事本打开举例:(注意红色部分). T( R: B- g6 Y/ t/ d
. Z; T4 q5 j1 O4 [) ]) |- z# custom_dirs.dat: Directories to search for Unigraphics customizations' p( x+ @0 K" i# S
#. u; Y8 g2 H0 }: r. h
# Copyright (c) 1999 Unigraphics Solutions, Incorporated
R" g4 D9 W: ^9 B5 F# V% h# Unpublished - All rights reserved
! [- z- u" z" a0 }: U- {$ N#
! j% o# E6 `8 O! `8 \: ~###############################################################################/ b% h& U% T& F3 R E9 Y
4 R1 K! J9 K5 b) ~. C#" K9 F) Y1 _) j5 h8 b1 ~ B9 t2 A
# This file is used to specify directories which will be searched for4 s3 C& F1 d7 S. N
# menu files, toolbar files, dialog files or UDO libraries. The directories
9 k1 ]7 J C0 p, G9 N* j+ i# added here may or may not exist, to allow the same file to be used at $ N, A8 ^ {# C7 f
# multiple sites. When Unigraphics starts up, it will check each entry, if
0 s" M6 z# h* `. J& ]# the directory does not exist, the line will be discarded as if it was a
7 e# x/ m+ g+ ?# comment. Comments are allowed, and must start with a # in column one. / H/ L" Z& t( b& N5 R
#. [% V: \ O0 Q5 y, I
# Directories must be listed one per line, with nothing else on the line. The 4 Y% Y) b+ `1 R- \1 l {0 C
# directory may include environment variables, by specifying $variable. If
1 u! N4 F; P- g# a $ is needed in a directory, it may be specified using $$, e.g.
9 e- B# A! t) w3 H# /users/my$$ would be the directory /users/my$. The file may be made to
8 ~# F% @: n: @7 d8 ] T/ o# work on UNX or WNT, on WNT any / characters will be replaced by \. , Y/ {6 F( p; C9 n* m
, ^* I4 i6 y' J; r# A #include construct is supported to include other files, to make it easier 5 ^+ k3 ^2 q& a8 |
# for individual users to customize their runtime environment. Finally the ' m5 w, N# V* g. v1 R
# location of this file is controlled by the environment variable ( B0 i8 q7 L1 W4 n* F6 c, l* k
# $UGII_CUSTOM_DIRECTORY_FILE which by default points to
2 p- E" C; k; n, J f# $UGII_DEFAULT_MENU_DIR/custom_dirs.dat- E% e l- u& s
#$ w# K6 k% S" ~. [' B
# Customers should feel free to edit this file.
3 t3 D0 H2 F& f7 T8 ^, G; u#) e" \$ U) s9 A0 J8 y8 X
####################################################################4 i# t5 r2 h3 L. e; y( T* u- n
#8 a! H( D4 r* h
# Customer modifications can follow on here1 N! [6 V* K4 [* N8 ~- J- g* g
$UGII_ROOT_DIR\liang7 a( [, R6 X0 S, A
$UGII_BASE_DIR\stdlib
4 c* }* l- S0 g5 t$ X2 C4 ZC:\UG_CHS
# @, H8 U5 k8 P( c; F+ Y& ]/ m注意在添加C:\UG_CHS时不要#号在前面,% {+ x$ K7 u$ Z* a
保存后打开UG后,再打开UG后,把原来UG自带的打开与保存按扭
- a% q3 w6 x4 p2 i u! @$ u放到自定义的工具栏中,把本外挂的产生的打开与保存按扭保存到工具条中!' T4 o" J6 r; G) s3 _8 D- c, N
每次打开中文件夹是选用本外挂的打开与保存按扭----OK |
