我们的机床ucp800,有对刀仪,所以A轴轴限我设的是-25到115.
" K M2 R7 R! r1 ]! J e8 i1 v% p6 {' Z3 {$ Z
BEGIN PGM s MM
! c2 ?9 r! Y& wBLK FORM 0.1 Z X-300. Y-300. Z-20.9 O" }+ n* Z' ?6 Q" w
BLK FORM 0.2 X300. Y300. Z0.0
3 }. ~- _$ N6 n5 k0 G( M. }- g4 lCYCL DEF 19.0 WORKING PLANE) p V5 A- j- d* D E
CYCL DEF 19.1 A0.0 C0.0
6 d& D' M6 j8 U: c" qCYCL DEF 7.0 DATUM SHIFT
& F2 m+ z' `6 @& U( a; R8 uCYCL DEF 7.1 X0.0
% _! m9 e1 Q, L: Y& xCYCL DEF 7.2 Y0.0
0 I5 _' |9 s1 A6 E1 y/ {CYCL DEF 7.3 Z0.0, B3 g% Q6 s8 X3 k/ S/ M
CYCL DEF 32.0 TOLERANCE
; J. }3 d! J. G4 ]+ y- x2 eCYCL DEF 32.1 T0.005
8 E7 Y. [: S0 Z: ?' A7 JCYCL DEF 32.2 TA0.05; I5 Z5 l0 E3 E: J
M129
# _1 j+ z, G7 U1 ]$ n9 }& WM117) J/ A( M" q' t' E" |' Q2 a/ b& T
M115
$ \5 Q# J6 M* U& ^: eM126
. @% L7 |% y5 v, x9 HM140 MB MAX+ L( F' m, \/ ^6 m
TOOL CALL 0 Z S3000
7 ~9 E) ]$ \! m6 b4 Z5 F$ A;*(Tool_Number:T0)8 ^' E) E3 s n" K
;*(Tool_Name12)' O4 ]5 c' \- g. T4 }4 S
;*(Tool_Dia:12.00 MM)
0 D, F: `* g% ~3 X9 @; nCYCL DEF 19.0 WORKING PLANE
& b0 l3 n- T! YCYCL DEF 19.1 A85.784 C97.701
/ w1 j2 E6 ]" |6 w. |! V: |8 NL X-33.759 Y38.302 A85.784 C97.701 FMAX M13
, O" }) H" E% y, |) R9 o4 ~L Z55.175 FMAX0 ?* x% z+ c3 Y0 J! f3 q
L Z41.688 FMAX
: ]# o, E- _8 F/ O3 w) FL Z41.188 F1200.% ~6 b$ e; v6 o1 U) H9 K
L X-32.043 Y38.672
* i; f M, l9 Y6 A0 GCR X-28.338 Y42.029 R5. DR+ F840.
# y5 w! m$ F1 l6 P. yL X-27.986 Y43.122 F1200.' g+ K; L$ G, x7 i( K3 n9 g, K
CR X-24.598 Y46.451 R6.239 DR-; _% g3 n2 j# U) L: Q9 K
CR X-21.528 Y50.397 R5. DR+ F840.* m+ j& i- V* ]1 Z
L X-21.271 Y52.258 F1200.
+ N5 w \+ t5 f1 s0 P, Q6 A% b) sL Z41.688
. [$ \; \) b) D0 c- \L Z47.175 FMAX$ j. P( Y7 l- k/ s* I+ n- o8 C) B
L X-33.759 Y37.569 FMAX
5 w: G" G6 d! ^9 u: e. b9 T& ]$ R( n5 n& JL Z41.439 FMAX
/ o+ q+ L( l0 _* m# IL Z40.939; B( ^: N7 _ @" k
L X-31.66 Y38.277
" O* _3 [$ Z3 i# `; Y6 E1 ?( U UCR X-28.355 Y42.029 R5. DR+ F840.$ R4 L/ }- n7 b$ d
CR X-24.598 Y46.588 R6.268 DR- F1200.
A: O; Q) C* ~CR X-21.547 Y50.55 R5. DR+ F840.
* n- _! B) B6 r; w4 U7 [L X-21.297 Y52.427 F1200.
9 \* n$ N0 W$ U' q" UL Z41.439
. |, z$ l8 U' w0 H& ^% v, AL Z43.188 FMAX$ X0 E, P' r1 l$ |1 B
L X-33.76 Y38.203 FMAX6 M! _! e8 t/ w
L Z41.189 FMAX
* N' C/ c3 H2 [* O, `L Z40.689$ b8 L5 y' ]# l6 I
L X-31.576
- R* A) v2 Q6 L9 m- o" _$ \CR X-28.357 Y42.029 R5. DR+ F840., u, J; r4 m8 z b& x- u
CR X-24.598 Y46.717 R6.265 DR- F1200., S" o; c" v4 @2 c* ]) C; l3 c/ O: E3 s
CR X-21.563 Y50.69 R5. DR+ F840.: n# U8 C- x9 _, m7 h
L X-21.326 Y52.521 F1200.
& _. y% ?4 H, [# tL Z41.189
5 K6 P. u1 E5 |% j0 P, e6 Q4 YL Z42.939 FMAX9 B2 w: R1 R7 ^. s) k4 x
L X-33.76 Y38.191 FMAX) `8 _9 q6 F! O! }: t3 `2 ?
L Z40.94 FMAX$ R4 ?; E7 t" |+ U
L Z40.44; z, n1 {1 T$ T1 E& x
L X-31.562 Y38.19) K3 N" q5 a6 G' z
CR X-28.358 Y42.029 R5. DR+ F840.% p. [7 X( a ?) N5 d& `
CR X-24.598 Y46.772 R6.331 DR- F1200.
' T7 q8 z% [- T8 e. GCR X-21.592 Y50.768 R5. DR+ F840.
2 {8 P8 i2 H/ B; o \; n1 }L X-21.377 Y52.534 F1200.# Q( i' x1 h$ Z e5 X
L Z40.94
4 k$ v ]: J$ O( `5 @L Z42.689 FMAX
0 G* `9 v# |8 r9 E& dL X-33.76 Y38.182 FMAX
! B( i4 q2 H/ I" @* h, T7 ~3 h+ FL Z40.691 FMAX
$ B6 j$ E! i. p' d, F; H9 XL Z40.191* n) Z) Z5 b* @9 ]+ G
L X-31.551 Y38.1819 ^2 n3 \5 O) j0 o+ r! l/ F
. D1 t& O- M( I3 f) JCR X-24.598 Y46.815 R6.383 DR- F1200./ l0 H+ v {/ ]
CR X-21.615 Y50.827 R5. DR+ F840.
0 f( a8 @) r4 i5 a6 I& u* E! yL X-21.414 Y52.554 F1200.
; ^+ x2 S3 z9 eL Z40.691! m! r2 @3 Z5 |! Z: ^
L Z42.44 FMAX
5 G5 M: b5 y9 y" e5 x+ N$ sL X-33.76 Y38.234 FMAX
3 `- \9 }- m0 d1 tL Z40.442 FMAX/ E3 R+ g0 @, g( N
L Z39.942+ E- p5 A" k; W9 Y( m$ c
L X-31.6114 G+ N7 ^5 Z( B6 J
CR X-28.356 Y42.029 R5. DR+ F840.
) O. K: P' F& }# o# |) Z& \CR X-26.584 Y45.493 R6.856 DR- F1200.
' t" X% _, ?* H& eCR X-24.598 Y46.848 R6.383 DR-( S8 L' @4 Q( A+ p+ |1 u6 @6 ^8 ?
CR X-21.621 Y50.865 R5. DR+ F840.+ K' w! [4 p: Y% G1 L9 x! f
L X-21.426 Y52.572 F1200.
* k' m* C0 i; \L Z40.4420 W% m- x# y3 e( t9 K5 n) |1 L+ p
L Z42.191 FMAX
/ K2 I, A# a' S7 @L X-33.76 Y38.234 FMAX* e: D5 B! O$ N) W3 B/ B3 O6 N# _
L Z40.193 FMAX1 h+ N$ O7 L0 u0 I) j, N5 c
L Z39.6930 g( u$ K# M& P* @$ q U( T2 x6 g& a
L X-31.611: c8 u- |/ h6 t
CR X-28.356 Y42.029 R5. DR+ F840.) ?& o. w. B2 L( E
CR X-26.584 Y45.493 R6.857 DR- F1200.8 U* W0 I+ [! b1 N
CR X-24.598 Y46.865 R6.308 DR-
$ G$ M8 L7 Q4 rCR X-21.633 Y50.891 R5. DR+ F840.
+ a4 h9 d K, v' o/ l$ F& YL X-21.443 Y52.59 F1200.: L( h/ ^' q- j2 I2 u
L Z40.193
3 q. `7 L/ ~6 Q8 J) Y5 b% f9 @L Z41.942 FMAX
( O4 q5 ~& O" M# Y/ F: L3 h* AL X-33.76 Y38.188 FMAX) Y. F; e9 u( `2 ?6 E
L Z39.944 FMAX
8 S8 a% [: a% l+ [8 H/ ]L Z39.444; M5 O2 U0 @3 I8 t9 W0 Q- g
L X-31.559
; p- C3 O% r5 D( k5 G r/ B9 M# A5 bCR X-28.358 Y42.029 R5. DR+ F840.+ Q5 V7 m. L: z0 Q
CR X-24.598 Y46.854 R6.489 DR- F1200.& d; I6 G6 K1 x1 W7 b* _
CR X-21.656 Y50.897 R5. DR+ F840.& y/ |5 k2 u; Y6 i8 m" a; J
L X-21.475 Y52.607 F1200.
4 c( ]' y d" x8 `" h" M' n# kL Z39.944: t2 Y( x( \" A+ p& w- X8 P
L Z41.693 FMAX) w' w G( ^4 P' ]" m" M
4 u1 Q2 A- j. LL Z39.694 FMAX
* ?6 O6 V# v, Q- H4 a8 ZL Z39.194
0 ^& y+ R. A6 ^' XL X-31.561 Y38.19
+ O1 z4 G- `/ c e$ z# `8 SCR X-28.358 Y42.029 R5. DR+ F840.
2 V, T0 ?: U* X" m1 c" v2 w3 |CR X-24.598 Y46.865 R6.518 DR- F1200.7 W$ _. O3 B* l+ e
CR X-21.667 Y50.915 R5. DR+ F840.
$ Z: v% G; m5 F+ P" |9 SL X-21.491 Y52.624 F1200.
1 q2 k6 n, V9 }+ S$ n) g0 A' AL Z39.694
( C# w+ }4 ]" Y. S0 j* IL Z41.444 FMAX( _$ M0 b, Z0 F9 u/ Q7 b# K
L X-33.76 Y38.195 FMAX" m% N& c( S$ A& |7 Z
L Z39.445 FMAX: N6 j7 x; ^7 Y- D2 F2 P$ @3 c
L Z38.945
4 p: O& k' j" j4 O: |) O2 n6 Z! ^; i; ], yL X-31.566 Y38.194
( k: z. \4 ?& Y5 [CR X-28.358 Y42.029 R5. DR+ F840.3 m# [" N7 U7 ]7 @4 F' \, q6 _
CR X-24.598 Y46.872 R6.55 DR- F1200.
$ H/ U4 \# X7 U; n, YCR X-21.679 Y50.931 R5. DR+ F840.: `$ ]. ]1 Z1 w" E( r, i" {
L X-21.507 Y52.644 F1200.% k; P; ^9 K K5 ~
L Z39.445( x" i! g. ?7 S& X2 m
L Z41.194 FMAX+ ?7 v8 q+ p6 {$ q
L X-33.76 Y38.201 FMAX# M4 v4 d6 e" s( G5 o! v5 y
L Z39.196 FMAX, B$ C* ~$ t" u4 g7 `5 O3 z
L Z38.696% ]7 M! }9 P p" S/ o$ F/ I% R9 Y
L X-31.573 Y38.2
+ a2 U, \+ n8 l1 N w3 h* s+ k! {CR X-28.358 Y42.029 R5. DR+ F840.6 T( [2 f+ c7 n5 g
CR X-24.598 Y46.878 R6.586 DR- F1200.
: v9 g" `3 n, [CR X-21.691 Y50.946 R5. DR+ F840.
( |- m2 R# n+ d2 U5 Y" YL X-21.525 Y52.661 F1200.
4 S; W2 ]: C6 d6 V& T9 n* G6 O0 NL Z39.196" j! J& z& O8 }0 J2 S! e+ s
L Z40.945 FMAX
8 w" R% q2 d! c: ML X-33.76 Y38.208 FMAX
6 i! u ^! b8 U' a6 o- h- uL Z38.947 FMAX
0 r. A2 f0 Q0 f& K5 BL Z38.447) \- t: m' f6 k2 k$ a1 |/ B; N
L X-31.581 Y38.2075 m( _* R( g1 v6 t2 e: T; r- l# H
CR X-28.357 Y42.029 R5. DR+ F840./ T: y" A' F: i K
CR X-24.598 Y46.883 R6.625 DR- F1200.
8 c5 B: A0 q/ |: B% d- nCR X-21.705 Y50.961 R5. DR+ F840.
5 ^! c( X# G, X/ F' `L X-21.543 Y52.683 F1200.
& I2 Y/ y4 d! r/ M- \L Z38.947: n/ x$ S- P. r7 L: W+ c j
L Z40.696 FMAX$ ?; m" q% m3 Z1 E0 E: W% e
L X-33.76 Y38.215 FMAX6 R0 p, J' _. O& k- T6 X4 X p
L Z38.698 FMAX2 Z6 {* S( M+ i0 a
L Z38.1986 F8 [5 b S2 _* K0 @/ O) c) a( S
L X-31.589 Y38.214
8 N8 r) Q5 ~7 ?CR X-28.357 Y42.029 R5. DR+ F840.
$ _/ c1 D- _4 J, z* g9 ?CR X-24.598 Y46.889 R6.663 DR- F1200. x' ~3 s9 C; [& k f
CR X-21.718 Y50.976 R5. DR+ F840.
' J: u0 }7 C0 ^0 T6 ML X-21.562 Y52.701 F1200.8 S' H$ w3 I" X/ A5 `9 C! W
L Z38.698
( @; D3 b. F5 T0 i4 ~L Z40.447 FMAX. y- {6 `5 j; o( k4 R% z
L X-33.76 Y38.224 FMAX
' R$ L$ `2 W- W; \- m9 ?! ]L Z38.449 FMAX- {7 D1 R9 v3 _6 Z9 T( L: w
L Z37.949
* P5 b9 Q/ P# z2 x" qL X-31.601' ]. C5 @; H4 `% ~" _
CR X-28.357 Y42.029 R5. DR+ F840.8 b8 W) {; X. ^( V
CR X-24.598 Y46.892 R6.71 DR- F1200.+ ^$ m& `, r8 e+ ]' \
CR X-21.733 Y50.99 R5. DR+ F840.0 @/ C( @% Z8 w& d
L X-21.583 Y52.723 F1200.: @2 q+ Y9 E! D$ i4 m) A; O1 I: V
L Z38.449
% o# e- o/ e7 e" J( t, IL Z40.198 FMAX, w- C, d& x+ t' t
( Q" I9 |) Q+ c V7 }4 [7 a8 I7 o+ @L Z38.199 FMAX7 i8 n a V( ^; T0 M" ]. ]
L Z37.699
8 g" I9 Z9 z W% t$ t0 hL X-31.612
/ k( c6 h/ x" ]CR X-28.357 Y42.029 R5. DR+ F840.0 i" D3 _% Z% A0 m
CR X-26.584 Y45.493 R6.858 DR- F1200.6 F8 \! B" ] Y+ G( \7 F
CR X-24.598 Y46.89 R6.935 DR-
. o1 k' R$ s: F! j, e E" ECR X-21.733 Y50.987 R5. DR+ F840.8 h( r) W' I8 _3 p h& ?/ \
L X-21.581 Y52.736 F1200.5 Z* C4 O7 Z; |- w5 b
L Z38.199: W$ A1 j+ }3 O# h: \) n! A9 ~/ m
L Z39.949 FMAX( f, L" ~6 R0 i2 [
% ?2 R. T7 @7 l+ |L Z37.95 FMAX" U0 b: }% i+ W% Z
L Z37.45/ [9 [; r/ V( M1 f
L X-31.612
7 z6 S5 a, B- ACR X-28.357 Y42.029 R5. DR+ F840.
* ?/ V# Z# j6 ]9 LCR X-26.585 Y45.493 R6.859 DR- F1200.
& s: K6 }9 S/ F! @1 kCR X-24.598 Y46.892 R7.025 DR-. }: r9 Z ^6 d5 K) m. k; Y* `
CR X-21.745 Y50.998 R5. DR+ F840.
2 k8 i: |( `2 e* H0 QL X-21.597 Y52.76 F1200.6 q2 o* j) u6 i* ^( C
L Z37.95
: }: l- c* a$ x( B6 F# JL Z39.699 FMAX. [& U' U/ e4 e! w* s
L X-33.76 Y38.221 FMAX
6 \+ I( Y0 [9 E+ B: J( S8 ~L Z37.701 FMAX
8 p, q2 n0 A6 d/ z; W; R4 o, HL Z37.201/ G: X# h( a9 r
L X-31.596- W A1 K$ v" _* j+ s3 p
3 i4 s5 @$ B8 @3 O+ A; n% nL X-28.341 Y42.113 F1200.* v8 m6 u5 t8 y8 S2 z& ^1 Z
CR X-25.532 Y46.347 R6.541 DR-
( v% y& \1 u9 q p( OCR X-24.598 Y46.885 R8.582 DR-5 D% h7 u/ p& l, ^7 j# Z
CR X-21.83 Y51.049 R5. DR+ F840.
6 ], m4 P/ F( |/ RL X-21.72 Y52.778 F1200.
% Z* n1 r l, R2 r3 E0 Q, }L Z37.701
; y8 o! x8 v U( S- r, `- u5 h% T6 tL Z39.45 FMAX
% \& ^+ d8 {5 W9 |! d, b; YL X-33.76 Y38.221 FMAX# a, d& p7 m$ b1 J5 c& \
L Z37.452 FMAX
1 A# G# I$ J9 p0 E0 `: G) s8 uL Z36.9529 r1 A( H6 _8 f6 U, J+ a
L X-31.596
1 B9 J0 K3 p* gCR X-28.357 Y42.029 R5. DR+ F840.8 F' _5 w/ v0 m- ], m0 F: l) T
L X-28.34 Y42.12 F1200.
$ Q) _& k. A9 ], }CR X-25.559 Y46.328 R6.529 DR-
/ P# V6 m6 E6 N2 k# W# RCR X-24.598 Y46.887 R8.844 DR-
* l- g, X, {( ECR X-21.847 Y51.062 R5. DR+ F840.
. a; ~- B5 R7 U( ZL X-21.744 Y52.797 F1200.4 O% Q& s: v- `/ Q# R; ^
L Z37.452
' v6 c! e5 h! }& B6 f y4 N) RL Z39.201 FMAX7 G3 o8 I+ L- m" C* w& g
/ Q, J7 O* t; q9 f0 e- ]# s% yL Z37.203 FMAX
8 R! b3 R% E9 R* L6 x2 {; O4 ~L Z36.703
2 p3 v' R% c8 i2 r6 Y' ZL X-31.596, V+ T7 O2 o' O
: {7 D6 M) N$ r5 d/ r" e- oL X-28.341 Y42.111 F1200.
1 L5 V" Q5 D& ]* R4 B& OCR X-25.549 Y46.333 R6.54 DR-# m6 {# G. _1 P, k& Q
CR X-24.598 Y46.888 R8.988 DR-: x W! t5 N8 \1 g' e3 J: x1 W
CR X-21.856 Y51.069 R5. DR+ F840.. X# Y2 x3 x: y; T- a A- q
L X-21.756 Y52.815 F1200.
/ G. W/ _. E) EL Z37.203/ O$ o1 m! V% v
L Z38.952 FMAX, T5 e/ J4 m! H& Z* v2 T+ T+ \
! V/ m1 }! R0 G5 p5 JL Z36.954 FMAX: G$ C5 P$ L9 b0 R9 b! ~
L Z36.454
+ Q$ `/ D% W; N% _! I8 b8 [: jL X-31.596( L D: m5 R( b# I7 r
CR X-28.357 Y42.029 R5. DR+ F840.* G }! L. D3 ]& B/ e' w& ?' A
L X-28.341 Y42.116 F1200.
7 a' E6 F+ J( P2 n. h" LCR X-25.564 Y46.323 R6.531 DR-
% w( c5 m# Q' \CR X-24.598 Y46.889 R9.142 DR-4 g' s+ N% o7 _4 ?5 a! q
CR X-21.865 Y51.076 R5. DR+ F840.
2 I' [0 z! O" [7 ?L X-21.769 Y52.821 F1200.
( d" C* w) D' C, h2 H5 }L Z36.9540 K+ u! H, g! C- t5 `) F3 [: l2 d. R
L Z38.703 FMAX
9 p+ h' Q* i" D- j1 EL X-33.76 Y38.221 FMAX
5 [$ _4 U6 @% P: V# t$ w/ W) y/ QL Z36.704 FMAX5 q e4 M7 C3 x+ j3 j1 }! I4 [
L Z36.204
" A$ R3 [) @9 O7 z3 ~L X-31.5961 F1 A. ], T" T [
3 N/ O6 ^9 Z) y DL X-28.34 Y42.121 F1200.9 m; s9 n* r: {
CR X-25.576 Y46.314 R6.523 DR-
5 Q( _2 r5 Y: o7 `CR X-24.598 Y46.89 R9.299 DR-
: C/ d3 ?5 V9 l! M: bCR X-21.874 Y51.082 R5. DR+ F840.! J" [2 m! [8 G
L X-21.78 Y52.852 F1200.+ b5 u: }2 ]) X: L+ G. b
L Z36.7043 @6 U0 X& \3 h, w
L Z38.454 FMAX9 ~9 ^8 [7 f* o; u1 c/ O0 f b8 j
8 U5 h( u2 I0 ]8 \8 T. x$ x tL Z36.455 FMAX5 S% P @0 |$ b u, q0 ^3 F6 M
L Z35.955; y0 u0 ?1 I. a# O6 g
L X-31.596
: |- c! F0 ~* }) H2 mCR X-28.357 Y42.029 R5. DR+ F840.- Q) `. k! q/ m
L X-28.339 Y42.125 F1200.
, M& q6 s! U; ?6 ~CR X-25.588 Y46.306 R6.515 DR-# p( \9 Q9 B+ }$ y
CR X-24.598 Y46.891 R9.46 DR-3 ^" \/ H- h' N9 @1 f0 r
CR X-21.883 Y51.089 R5. DR+ F840.
0 F7 I8 f2 b5 oL X-21.792 Y52.87 F1200.5 G2 O% ^8 B, z$ m5 i1 M0 ~
L Z36.455
' ?# w2 T, h! T) }. V3 I- xL Z38.204 FMAX6 i9 c# Y0 g( O% W/ R% M4 y
L X-33.76 Y38.221 FMAX/ s% {, M* w2 x
L Z36.206 FMAX) ^6 I6 r, K8 Y; C) v
L Z35.706% z( w4 D5 ]4 ~' `, p' L
L X-31.596
/ O9 ^! o( b; {, N; g3 _CR X-28.357 Y42.029 R5. DR+ F840.
$ {$ c) o3 {7 V+ C# l: yL X-28.338 Y42.13 F1200.% y* V. p, o6 B/ D4 w9 z3 Q. o
CR X-25.598 Y46.298 R6.508 DR-7 R5 z: }0 [3 a, |. y
CR X-24.598 Y46.892 R9.626 DR-
h2 l8 W0 A- i& |& a7 X7 _CR X-21.892 Y51.096 R5. DR+ F840.; [5 @5 G- T1 v- a( L3 T
L X-21.804 Y52.894 F1200.+ x/ x: G$ v$ R- l7 [: w9 I
L Z36.2063 h; U: Q/ R$ p8 M4 D8 W0 U" }
L Z37.955 FMAX* w# h; H" Z1 W0 m
L X-33.76 Y38.227 FMAX5 h% x" i; F0 ]9 X' ^* E
L Z35.957 FMAX, n% x" s8 E. _1 G" z0 l
L Z35.457) ~1 O3 E" _& m
L X-31.6032 j7 [2 I4 a2 k. b8 ^7 y
( u x- v! ]* U( }3 ]CR X-26.22 Y45.839 R6.778 DR- F1200.
: Q$ T% P/ I0 j+ E0 tCR X-24.598 Y46.893 R9.798 DR-5 n. M% w" {- O
CR X-21.9 Y51.102 R5. DR+ F840.$ S3 b. u( ]+ d4 H$ `: F
L X-21.817 Y52.913 F1200.9 J: Y. ~/ F: `
L Z35.957* {% j4 I6 h1 v- k' e v9 B
L Z37.706 FMAX" m! g, N& s+ W7 X$ h) u
L X-33.76 Y38.227 FMAX9 L0 k2 D0 d: M/ F' r, l& R3 W8 s
L Z35.708 FMAX9 l: Z/ x' X! D- h0 e, ]
L Z35.208
0 L0 A3 ^' {& Y% ML X-31.603) O1 o, A7 C( r6 c5 L( \- K
CR X-28.357 Y42.029 R5. DR+ F840." Y: _ i) r% `/ n# ]0 E; z
+ h: G3 b6 T8 f: E9 [CR X-24.598 Y46.894 R9.976 DR-9 u3 k1 w9 S4 e. u
CR X-21.909 Y51.109 R5. DR+ F840.
, V8 a% I" Q2 Y5 f8 P, X% CL X-21.829 Y52.933 F1200.) b" N3 {; E: O& A
L Z35.708! m# g6 H" P/ f1 j
L Z37.457 FMAX
( b: N3 Q( [- i- q* e4 ~L X-33.76 Y38.227 FMAX
! `% s7 h' _ w) zL Z35.459 FMAX
( u q% `- T# D* \L Z34.9596 ]9 ~( w5 e% E8 u
L X-31.6048 t5 w) ^9 A( U) @
CR X-28.357 Y42.029 R5. DR+ F840.% I7 _3 W; n! Y- x9 P: D. y6 p
CR X-26.22 Y45.84 R6.778 DR- F1200.# e! b6 i+ R% a& U: x
CR X-24.598 Y46.894 R10.159 DR-% f9 O+ o7 f" ?
CR X-21.918 Y51.116 R5. DR+ F840.
* V8 S7 j( n3 @+ y( ]: K8 ?$ NL X-21.841 Y52.95 F1200.
2 W) m: G% b. n9 eL Z35.4597 D" D; L: W5 G0 V4 [6 D2 j; T: C! v0 F
L Z37.208 FMAX
# O$ a: S+ |; U2 |/ EL X-33.76 Y38.227 FMAX
+ O! ~! z% n( y. f2 M$ u, EL Z35.209 FMAX
2 q9 K7 Y' V, v8 `) Q+ z2 x* xL Z34.7091 c+ Q8 Z1 C9 U+ P; _
L X-31.604
9 d7 S( @0 ~$ G+ _' H% u8 T) lCR X-28.357 Y42.029 R5. DR+ F840.
4 [" U* t+ ~, m9 n7 X" PCR X-26.22 Y45.84 R6.778 DR- F1200.
1 Z* H* U8 v! v' UCR X-24.598 Y46.895 R10.34 DR-
# s$ h2 o) o( f7 o* k" ]CR X-21.927 Y51.122 R5. DR+ F840.9 [7 O8 j9 r0 ~
L X-21.854 Y52.949 F1200.
1 a) b& [& s0 P. HL Z35.209( B* U: u8 p3 G) i3 r
L Z36.959 FMAX3 G0 W) U( l. U% y3 U
L X-33.76 Y38.227 FMAX: Z8 l+ I7 R" R9 ]1 S+ J7 }
L Z34.96 FMAX
) P' g7 k6 j3 H6 {# U8 p- h( C! T7 aL Z34.46
+ V4 e+ _: S+ FL X-31.604, x% @0 z, Z& r+ ^' O
! ^2 @ g9 n. m. u& B$ ]# t" f/ ], R* qCR X-26.22 Y45.84 R6.779 DR- F1200.4 _# ~, h5 O) a2 P" _7 c
CR X-24.598 Y46.896 R10.545 DR-
* p3 A9 P U8 ~3 n& n- ?+ RCR X-21.936 Y51.129 R5. DR+ F840.
2 c* `" a* Y* O, [/ y0 k9 XL X-21.866 Y52.984 F1200.% u! x2 C, m o# E
L Z34.96
1 u$ a9 u% w/ ^9 ]1 `, ^+ FL Z36.709 FMAX
" q2 L" C- Q0 g r# q4 bL X-33.761 Y38.227 FMAX
2 O% e1 M, v% F' BL Z34.711 FMAX
+ x* `$ w$ t1 D# H6 e" QL Z34.211
0 D- u4 }, W' ~9 `) J* ~4 j) JL X-31.604% i# \, f; W) b; n7 f
CR X-28.357 Y42.029 R5. DR+ F840.! ^0 m$ s% ~2 L8 H+ q2 u0 ~/ e* ~
( m( _" y& n$ \! W+ ICR X-24.598 Y46.897 R10.748 DR-+ N/ t, g7 W7 ~) ]& Q
CR X-21.945 Y51.135 R5. DR+ F840.+ z. r% `' j% b6 s( _5 V! E( f6 f
L X-21.878 Y53.011 F1200.
; L% U% m1 q7 D1 r% {& ~$ c2 pL Z34.711
8 [. H* u2 n+ v5 ML Z36.46 FMAX
6 O* @9 E% \) b1 s! d" k9 B; aL X-33.761 Y38.227 FMAX# B3 N6 A, R9 J, U
L Z34.462 FMAX
$ H* _- e5 g2 Z; M) M" L& K" FL Z33.962
* K( n$ Z* ?" `L X-31.604: c& C5 y9 K9 o5 z, X* H
CR X-28.357 Y42.029 R5. DR+ F840.. s6 a9 g2 k0 _5 c/ f/ E+ N, v. B
CR X-26.22 Y45.84 R6.779 DR- F1200.2 g' ?2 G$ |% n# A& R
CR X-24.598 Y46.898 R10.958 DR-% n7 A, b4 Q- @' g- Y2 A8 X
CR X-21.954 Y51.142 R5. DR+ F840.
* q9 h: p- R8 h W0 f/ iL X-21.89 Y53.044 F1200.9 @: I G! s' c+ y. z$ ?! J+ h; Y) V
L Z34.462/ j" g" u0 ^$ f b' L6 T8 G
L Z36.211 FMAX' e) o4 G$ g8 S; i- Q2 b6 D
; p2 i, z$ J; W4 r* t2 oL Z34.213 FMAX/ E, ^' v! U( d- {* u+ h- S
L Z33.713
* K. m" g# ?) H4 q! u! v2 F* gL X-31.604
. w5 N5 K* `# z/ @& OCR X-28.357 Y42.029 R5. DR+ F840. O+ s* Y, Y# u W3 ?% P% \
CR X-26.22 Y45.84 R6.779 DR- F1200.7 c& o. o5 r2 b
CR X-24.598 Y46.899 R11.176 DR-
/ R! C! ~ M/ N, s8 B! u, R3 ~CR X-21.963 Y51.148 R5. DR+ F840.
5 `8 l& z' _6 ~7 @1 CL X-21.902 Y53.078 F1200.$ q/ M$ m6 D; X6 N0 ^% ~0 E& l
L Z34.2130 r/ g, p* E9 O% R8 e, q" R9 }+ Y7 W
L Z35.962 FMAX
5 Q( Q" N) h5 sL X-33.761 Y38.227 FMAX4 @/ P5 q( t. s8 Q0 r$ W
L Z33.964 FMAX/ T# I6 v" N" ^; T/ N
L Z33.464
" n8 i8 f9 t- Y# J( g. eL X-31.6046 |" b4 T" T0 z& {5 _
CR X-28.357 Y42.029 R5. DR+ F840.% V& y2 I* F3 Z1 @& {! {
CR X-26.22 Y45.84 R6.78 DR- F1200.7 Y a4 m" G+ v: H$ h
CR X-24.598 Y46.9 R11.402 DR-! B% C( B ]6 B+ g$ i: @3 h0 [
CR X-21.971 Y51.154 R5. DR+ F840.0 q- d/ Z% ]1 Y
L X-21.913 Y53.144 F1200.6 C6 U/ w( Q9 j0 t% @
L Z33.9643 g) p' ^2 P& b
L Z35.713 FMAX3 A6 y6 U3 K, C2 k# t; `
L X-33.761 Y38.227 FMAX( A. e- e, }" o2 ?2 s
L Z33.714 FMAX- z8 h4 v4 Q m9 o% R; r% X
L Z33.214- W6 d( Y9 z3 J0 \8 j y' p
L X-31.604, p) ]* Y% r7 c& L. p; I2 r) {4 D
CR X-28.357 Y42.029 R5. DR+ F840.6 D& ^4 R4 W( ]5 [2 k
CR X-26.22 Y45.84 R6.78 DR- F1200.) C' j: F9 }6 s
CR X-24.598 Y46.901 R11.636 DR-
' _+ k$ F( |. g. g- j" V9 oCR X-21.98 Y51.161 R5. DR+ F840.
+ K x$ X& T0 p/ k$ g2 LL X-21.923 Y53.251 F1200.
" d$ J. ~" s3 C' G2 TL Z33.714
0 G s: @/ S$ ~, l; `& hL Z35.464 FMAX
2 ]' r% Q( r8 J T2 {5 J, A- @L X-33.761 Y38.227 FMAX
4 v4 e- q. n0 w# F7 M. ML Z33.465 FMAX. N j# [( h' w' Z: ]8 j+ S
L Z32.965
2 y. d; q' L# v- @' E' w; JL X-31.604( t4 L8 c/ Q/ }: B- }- u8 i) E
CR X-28.357 Y42.029 R5. DR+ F840.# F% g1 h: y: B; T" l( k
CR X-26.22 Y45.84 R6.78 DR- F1200.8 A: }: ?2 p4 y! V0 q2 p! z
CR X-24.598 Y46.902 R11.879 DR-
% [1 s4 j. o. _* r* x+ F4 ?# NCR X-21.989 Y51.167 R5. DR+ F840.
2 w# q+ l9 r0 W9 ^9 aL X-21.934 Y53.333 F1200.
. I. `3 {& _8 q$ {0 WL Z33.465( s9 h |$ }6 X S! D9 g% a
L Z35.214 FMAX8 a# C9 h# q; ?8 h& b! `
! r: J) [8 W9 g2 n5 P/ XL Z33.216 FMAX
! g$ E) X" r2 C. S% `/ Y3 }* U- _L Z32.716
: ^% a' S( Y! F% i9 QL X-31.604
$ a6 t: Z4 k f. I7 S) SCR X-28.357 Y42.029 R5. DR+ F840.
) S% C3 I( ^, qCR X-26.22 Y45.84 R6.78 DR- F1200.5 w) q) e' N* `# D! ~! c; E* A
CR X-24.598 Y46.903 R12.132 DR-
4 n% A6 R0 E+ g- |CR X-21.998 Y51.173 R5. DR+ F840.# c% T; g- Y; ~9 f$ S- |
L X-21.944 Y53.471 F1200.
8 X& S! o3 z. L8 x3 X" @( t7 ^L Z33.216
1 P2 o- A' y6 u' qL Z34.965 FMAX1 H/ u' s: h7 o
7 s) M& _4 }4 A( {: fL Z32.967 FMAX: Z" ~# f6 N- n! ^- W2 Z3 a, U1 P6 o0 c
L Z32.4672 I1 ^* Q% s8 C8 A5 h5 y& z4 T
L X-31.604
" T# S0 S* n: n7 `* \CR X-28.357 Y42.029 R5. DR+ F840.
! q2 W* g9 m/ {5 A. y4 K# R! cCR X-26.22 Y45.84 R6.781 DR- F1200.
& g# r7 T7 {2 g+ [CR X-24.598 Y46.904 R12.395 DR-
# {, w3 W2 X6 I( [ L7 \CR X-22.007 Y51.18 R5. DR+ F840.
1 G0 t" W$ ` ^1 @% RL X-21.955 Y53.616 F1200.
. C8 Q$ l4 A8 ]! u3 l7 P" TL Z32.967' O0 x. P* B! k" K0 i- s* `
L Z34.716 FMAX$ A3 e8 \, k9 y$ T
L X-33.761 Y38.227 FMAX! S3 O5 D+ ^' W* m! N" e
L Z32.718 FMAX
+ e4 R; B4 ] L* b! y$ tL Z32.218
% |$ w/ a+ ?* v; Z0 TL X-31.604
1 G- E" z0 |6 V4 y7 DCR X-28.357 Y42.029 R5. DR+ F840.% _8 B- `* i# v& E. k! q h4 o
' |* N- N. }, k' f4 sCR X-24.598 Y46.905 R12.669 DR-, I3 p4 J) \" f! o" c" C+ h- V
CR X-22.015 Y51.186 R5. DR+ F840.6 j) ]; L7 Z n2 z6 h
L X-21.965 Y53.793 F1200.
0 J0 L4 q1 {* }+ Q- F- P8 ^! D5 ]* DL Z32.718
* B/ I4 L) g! l& PL Z34.467 FMAX9 n0 x1 ~3 ~# x* D' U& K U
1 u' j- g- g8 Y. g( nL Z32.469 FMAX
; l, U! I# Y HL Z31.969+ j3 f' n/ k& k& q0 a
L X-31.604& g) \& T; n- z7 {
CR X-28.357 Y42.029 R5. DR+ F840.' W* h! B$ D5 H( q3 t
CR X-26.22 Y45.84 R6.781 DR- F1200.. p: u5 w' ^5 ~! J O$ U
CR X-24.598 Y46.906 R12.954 DR-$ K! ~% `+ B2 S! v4 H! Z. @5 c
CR X-22.024 Y51.192 R5. DR+ F840.
$ B( B( k5 D! l' I4 jL X-21.975 Y54.037 F1200.
4 ?8 C( E. c& B7 |& N" j, l6 Q3 W- |L Z32.469, c$ I- }& Y5 K8 u. R
L Z34.218 FMAX2 s# }( p+ k0 N: N
L X-33.761 Y38.242 FMAX
1 n7 M( d& `& o) _ C+ \$ hL Z32.219 FMAX5 h ~' d0 b' [" ^, T& N" }+ g+ t
L Z31.7191 ]6 _( ~3 r: j/ p: A
L X-31.604 Y38.2277 l$ p9 r# f8 Y8 H4 ~8 e' |
2 Z7 F3 @8 d; f& W: t: \" eCR X-26.22 Y45.84 R6.781 DR- F1200.
' A& @/ P, O% M+ {! Z2 `CR X-24.598 Y46.906 R13.251 DR-
# f. X6 A2 v9 Z8 j3 x# SCR X-22.033 Y51.198 R5. DR+ F840.% |2 A' I4 f3 w e m0 b+ U
L X-21.986 Y54.297 F1200.
& g! l" ]4 E9 w2 cL Z32.219
4 d, `6 w$ s+ ~- c- ^L Z33.969 FMAX- i6 D5 e* T y/ ]
L X-33.761 Y38.26 FMAX
! w1 d. y8 m- o, `9 S0 hL Z31.97 FMAX
* X) L4 _8 H6 a/ ]& ^3 K, gL Z31.47
' m+ M/ v1 {6 {4 u8 o9 N, k/ sL X-31.604 Y38.227
8 v" ?* k6 D5 ?! }3 T( [7 c3 J. [CR X-28.357 Y42.029 R5. DR+ F840.# e. }: _; [% W9 P
CR X-26.22 Y45.84 R6.782 DR- F1200. d7 k: _4 j1 H! t" U
CR X-24.598 Y46.907 R13.56 DR-1 ]- J6 W3 I+ g
CR X-22.042 Y51.204 R5. DR+ F840.( D" D+ y7 X$ d5 _6 L; q
L X-21.998 Y54.554 F1200.( k" ^5 f$ p0 W: _8 V8 B) t7 F
L Z31.97! R: l v! f S# e1 @
L Z33.719 FMAX
, u9 `6 O& }1 ~7 I# b! Q% \L X-33.761 Y38.279 FMAX5 Q* A, V l0 J; U- C" U8 ^
L Z31.721 FMAX
8 u, V/ y& r, _% j6 h+ }1 YL Z31.221
4 L& g/ K" E+ x( H' O+ }1 KL X-31.604 Y38.227
# m, H0 n1 o0 O9 }0 M$ gCR X-28.357 Y42.029 R5. DR+ F840./ Q( u2 k/ w4 k' S; C
CR X-26.22 Y45.84 R6.782 DR- F1200.4 L0 z$ o4 J' x% \
CR X-24.598 Y46.908 R13.72 DR-
A0 j2 G3 D' ~; ]5 e6 a2 YCR X-22.046 Y51.207 R5. DR+ F840.7 P- F2 i. |. B4 k! a& E
L X-22.002 Y54.811 F1200.+ @+ r! L$ Y& ?1 U* w2 j
L Z31.721
) `' w) N. R2 h3 t, nL Z33.47 FMAX
+ f0 c7 Z& p! B+ cL X-33.761 Y38.297 FMAX s2 \- ]; `" J5 b7 B
L Z31.472 FMAX
6 `. a; `. V- K/ HL Z30.972
- g* a# R( E6 A2 R0 C }L X-31.604 Y38.227
% b: H; I0 F4 aCR X-28.357 Y42.029 R5. DR+ F840.4 [# W4 d# ?" L( r: o2 B
7 @( ^, D- \8 _5 vCR X-24.598 Y46.912 R12.318 DR-
/ y- L1 S7 v K. ], v8 jCR X-22.018 Y51.194 R5. DR+ F840.6 ]; c& t" i$ E% l3 H( C
L X-21.945 Y55.072 F1200.) l0 j: x) @; [1 @- e
L Z31.472
% e! z& e0 X" y7 iL Z33.221 FMAX# I* {8 C$ H w
L X-33.761 Y38.315 FMAX0 r2 l! u0 N* O) l, N
L Z31.223 FMAX
6 Y; e+ C: {& _! _4 HL Z30.723
7 Z6 X8 {/ j/ c- N/ K, X' s9 zL X-31.604 Y38.227' g/ T4 S$ J2 U0 ^0 Z& o
CR X-28.357 Y42.029 R5. DR+ F840.2 J6 k+ o( k! l0 G7 M- G7 C
; M1 o& r9 ~+ b& {CR X-24.598 Y46.91 R12.744 DR-9 K( J- Z& r2 a& K: C8 t
CR X-22.027 Y51.198 R5. DR+ F840. v6 s0 Q8 g: ^. g
L X-21.958 Y55.329 F1200.3 p2 ?2 l& a' }0 j9 ~
L Z31.223
1 L# w$ t4 H5 B, h- \3 k6 l; f1 SL Z32.972 FMAX5 H |1 t+ s: A, x
L X-33.761 Y38.334 FMAX
! ]3 {* J1 d. P" t9 r/ @L Z30.974 FMAX6 ]% x( `$ u# E8 q4 B
L Z30.474. q p( N. N$ o* y U, b
L X-31.604 Y38.227/ ?. Z) Z2 U' w3 ?; l3 G! ]
9 t' i/ z$ E5 R; T7 WCR X-26.22 Y45.84 R6.783 DR- F1200.
7 _) Y' s0 [$ ~7 M5 J% p7 OCR X-24.598 Y46.909 R13.135 DR- y7 b* L! B# D1 Z. S
CR X-22.035 Y51.202 R5. DR+ F840.! K( S$ y; C @; @" i3 p- U
L X-21.97 Y55.58 F1200.
! O$ ` {9 A4 ~0 }+ [% D! kL Z30.9744 F) A% b0 z% V
L Z32.723 FMAX
9 ~& r; j4 w* W( h# x$ z0 _L X-33.761 Y38.352 FMAX
3 { N+ ?$ V% H1 `( y3 b1 [% IL Z30.724 FMAX
* `4 j; U; f& T4 tL Z30.2246 k3 M; i) q7 d7 A3 }* T
L X-31.604 Y38.227
) w: F |$ s$ R7 R5 KCR X-28.357 Y42.029 R5. DR+ F840.
' U0 |7 e( l! i uCR X-26.22 Y45.84 R6.783 DR- F1200.' [8 A+ i( {! C
CR X-24.598 Y46.908 R13.571 DR-
" g7 Q9 z9 g' c2 v2 s" [* dCR X-22.043 Y51.206 R5. DR+ F840.
( X; }/ A. e, u' D O( XL X-21.983 Y55.84 F1200.
0 V$ p2 u- {/ }8 O, }L Z30.724% L+ T% N, I4 x9 \2 ^! U" @3 K) l
L Z32.474 FMAX7 R2 [7 P' M% q# H6 e ]
L X-33.761 Y38.37 FMAX V [5 |; B, _8 M- I5 ?
L Z30.475 FMAX& B/ g" F: x1 W9 C; J$ }2 s
L Z29.975( j$ j" W% k' d: t. F
L X-31.604 Y38.227$ N: V4 {& {; W4 t" i
CR X-28.357 Y42.029 R5. DR+ F840.& i6 ]4 X8 V! H- @6 a; J
CR X-26.22 Y45.841 R6.783 DR- F1200.
0 `" _( h) T ?, X, g: |CR X-24.598 Y46.908 R14. DR-8 R; J9 [, t% Z, S& D
CR X-22.051 Y51.21 R5. DR+ F840.
; t$ x8 {0 q$ T' t& L" ~L X-23.221 Y55.843 F1200.
& S, \* |% |0 Y( l, X2 GL Z30.475+ I% p. J$ L: f' M6 d
L Z32.224 FMAX
* x/ @' s' |7 {5 u8 YL X-33.761 Y38.389 FMAX, Z7 K$ j- y1 Q: e: n/ z: v1 ]
L Z30.226 FMAX
$ `0 t3 V! S1 {3 V, M! cL Z29.726
, G, W) N/ i$ {+ H+ VL X-31.604 Y38.227
( U! `# _! d) G& B9 \' MCR X-28.357 Y42.029 R5. DR+ F840.
1 K, `" l0 V' M/ X8 lCR X-26.22 Y45.841 R6.783 DR- F1200.
: r0 |$ \9 I! `0 q! ~7 u% T/ rCR X-24.598 Y46.908 R13.777 DR-
! f, i6 w" W( V& H( OCR X-22.047 Y51.208 R5. DR+ F840.
0 B: b3 B9 r& g l9 B/ T9 JL X-24.353 Y55.757 F1200.
7 }3 j6 M ^6 A+ u( t% FL Z30.226$ W* x2 C. j3 r
L Z31.975 FMAX2 B8 D& X1 v( e( H' G3 `; t3 {5 K
L X-33.761 Y38.407 FMAX
3 U0 H8 a0 p( Q7 v2 x1 n" YL Z29.977 FMAX O% C( A# ?7 E- A
L Z29.477, d4 {- r r( O+ Z6 _$ @
L X-31.604 Y38.227
+ s0 k% u ^2 oCR X-28.357 Y42.029 R5. DR+ F840.% Y/ G; y8 i x/ ?) ]+ k& e) P
CR X-26.22 Y45.841 R6.784 DR- F1200.$ W4 D5 ?: r4 ^/ g+ Y1 F
CR X-24.598 Y46.908 R13.787 DR-
' G( s1 ~; T; o$ OCR X-22.047 Y51.208 R5. DR+ F840.7 z' {- p; S* z" V }4 @1 }3 y
L X-25.931 Y55.305 F1200.! a! F2 H& {" A
L Z29.9778 e% v" @* w8 E" F# q1 R
L Z31.726 FMAX
8 `; A( D8 u' r7 r9 z$ W8 pL X-33.761 Y38.426 FMAX
/ s: K" z% q; x! {5 e% V+ }9 bL Z29.728 FMAX) K' j y$ i- D! f9 |1 s7 @
L Z29.228
) V3 H! g" l3 V3 V1 GL X-31.604 Y38.2273 c2 V: L2 e, O6 X
CR X-28.357 Y42.029 R5. DR+ F840.! m4 M& s d4 S( j8 F- A
CR X-26.22 Y45.841 R6.784 DR- F1200. S0 e0 j; v5 s
CR X-24.598 Y46.908 R13.796 DR-
9 B* J0 R- v7 aCR X-22.047 Y51.208 R5. DR+ F840.
: O6 j: z. _8 I" f& CL X-27.397 Y54.621 F1200.
* K; \; f9 z5 H, `" N/ RL Z29.7288 ?& f A' h& z, O, N
L Z31.477 FMAX. d9 s: l+ M# ~' V. o
L X-33.761 Y38.444 FMAX
, O4 {0 h+ }8 `# t5 K# L+ oL Z29.479 FMAX
. r- |! o9 W4 M+ OL Z28.9794 \" [" g0 D% x( ]. t: g7 R" F, d
L X-31.604 Y38.227( O& A5 [; s8 A3 |% J$ ^
CR X-28.357 Y42.029 R5. DR+ F840.4 b* Y( x4 c* _% {4 U
CR X-26.22 Y45.841 R6.784 DR- F1200.1 [) a9 E p/ J
CR X-24.598 Y46.908 R13.806 DR-( M( w4 Q+ C- l6 R
CR X-22.048 Y51.209 R5. DR+ F840.' M% R; ?/ i; M" c# s/ f
L X-28.735 Y53.667 F1200.$ W! p e7 u9 i$ N5 j
L Z29.479
+ g, b% v- o/ u' y. F2 SL Z31.228 FMAX5 |, i$ \+ [5 {% T+ |5 i$ k8 F
L X-33.761 Y38.462 FMAX, Z" ?! l( { T+ p% N- c: u6 m, e
L Z29.229 FMAX+ `5 J0 u: `8 f! K
L Z28.729- {% y1 V7 \( a* t0 e }' F
L X-31.604 Y38.227) Q+ _, a" A1 O, `
CR X-28.357 Y42.029 R5. DR+ F840. \* K2 a( F( C; l: ~- l# E- F
4 o! |1 y `1 i% cCR X-24.598 Y46.905 R15.312 DR-
6 L+ U% X' ?% W" z" [# Z8 w' yCR X-22.072 Y51.22 R5. DR+ F840.' f% E" z' g- ]0 }" L
L X-29.884 Y52.552 F1200./ b7 J a8 c+ j+ j" k: t5 F1 Y
L Z29.229 G k- s) \2 L* i8 C% Q
L Z32.975 FMAX
. e/ M8 g* O* a$ r" R" @9 O3 lL X-27.026 Y60.687 FMAX! s7 F9 p# y. \% T: s" z
L Z30.226 FMAX
7 C) R, d4 V1 y/ r B& B$ e; ML Z29.726
2 }! w6 t$ O" F( c5 K# U' Q3 `L X-24.725 Y64.446
2 N% l d3 i: u- Q9 k* o0 k8 wCR X-23.99 Y67.056 R5. DR+ F840.
`* L _$ c8 J# D& G9 ^CR X-24.597 Y69.444 R5. DR+
( A8 U& C% D8 n: TL X-25.696 Y71.465 F1200.
; F( r) }. ]$ Y6 v# ^6 d0 }/ ECR X-26.392 Y73.534 R6.334 DR-
J: y/ e( R: t4 nCR X-26.558 Y75.725 R14.517 DR- U+ L8 y, }) E! `- l
CR X-26.456 Y77.448 R14.517 DR-; L% v( V9 }& r# c+ F7 `+ h7 J2 H' q5 T4 R
CR X-24.285 Y81.543 R6.432 DR-
m8 R e# t; k- P( Q8 j4 G; F' kCR X-22.562 Y85.319 R5. DR+ F840.1 @# K t, X/ \, w) P
CR X-22.653 Y86.269 R5. DR+& @5 L+ I3 m$ a4 n+ k! w: N/ X
L X-23.058 Y88.361 F1200.
: T; b9 t1 g3 j+ `0 S( X% d& NL Z30.226
" Z$ C8 H8 \9 W5 fL Z32.224 FMAX
8 p+ q3 Y1 q/ C3 R/ jL X-27.022 Y57.313 FMAX$ x! f. x2 r4 `) p5 t6 j- o' R
L Z29.977 FMAX+ m. N/ [& ~0 Y' `2 r
L Z29.4774 ]6 N* p% j! {1 @
L X-24.725 Y61.066
4 @7 h8 W2 N' ^) BCR X-23.99 Y63.676 R5. DR+ F840.
0 S2 B5 l3 q9 m; i) u4 p rCR X-24.597 Y66.064 R5. DR+
* K$ E) E9 i' q+ q, gL X-25.704 Y68.101 F1200.) W! ^: Y T( h: |7 E* P& k0 K
CR X-26.492 Y70.86 R6.573 DR-
; m& v: K$ U# }, BCR X-26.604 Y74.75 R67.278 DR-# f- J9 T5 w# Y# x
CR X-26.54 Y77.687 R67.278 DR-1 Z! [7 A4 [4 P% e- V
CR X-24.522 Y82.078 R6.529 DR-
/ j" t* M3 N, K- h0 ~9 E/ ACR X-22.969 Y85.699 R5. DR+ F840.( i+ \' ?# ~% l
CR X-23.109 Y86.875 R5. DR+) a7 u& D- \3 c7 m
L X-23.512 Y88.54 F1200.
1 c2 k: x* o& I% e4 u/ ]* }$ {L Z29.977$ v. p- \2 i9 B1 C) L
L Z32.224 FMAX/ ], k) @# F& b- D: p6 W
L X-28.074 Y55.866 FMAX
+ Y0 n% w- q: b! e' KL Z29.728 FMAX1 |9 a' n; ~6 R- S& s3 y
L Z29.228& [9 I% r$ x; z8 o7 Y0 ]7 M
L X-24.725 Y57.686
4 \/ t5 l0 e: E( Z' ^) ICR X-23.99 Y60.296 R5. DR+ F840.. t P$ P' u, [: ^* z+ `
CR X-24.597 Y62.684 R5. DR+1 H0 Z: a C' y, P9 q, ~, g
L X-25.691 Y64.696 F1200.
7 Y7 q5 N i' g% @" dCR X-26.531 Y68.148 R7.857 DR-
: `) |1 S$ R+ n; S5 J7 JCR X-26.619 Y72.915 R128.964 DR-) x+ Y9 a0 x+ U; Y& b% b8 R$ }
CR X-26.597 Y75.303 R128.964 DR-
2 M- k1 j9 n- {, Q0 w$ IL X-26.587 Y76.4953 [$ {6 f- G4 L/ D- V; f. s' W+ ?
CR X-26.433 Y78.857 R21.054 DR-
( b H0 ^& X# R9 h5 Q$ ~" T8 |8 V5 QCR X-24.773 Y82.398 R6.27 DR-# ?( l9 o# z* @" I
CR X-23.412 Y85.826 R5. DR+ F840.
# P) ?$ D/ _1 h4 O5 ]7 b$ q' A, j' kCR X-23.623 Y87.264 R5. DR+! C6 f1 D. c6 L5 I
L X-24.058 Y88.714 F1200./ [2 x% t( w& O: E, \
L Z29.728& |! E" b' B2 G# [+ |/ A
L Z31.975 FMAX( t. K9 a6 ?9 J; L
L X-28.735 Y53.667 FMAX6 d% O! q, O( ?4 @9 g9 ]
L Z29.479 FMAX8 d: M w. t: x" }4 s, R( Q7 y& d4 s
L Z28.979
7 i5 D2 }" K& g8 R8 u' w' JL X-24.726 Y54.306! b, ]# S) y& v0 o- t$ _
CR X-23.99 Y56.916 R5. DR+ F840.
" X# x$ a( O9 M% hCR X-24.598 Y59.305 R5. DR+9 v7 a- |7 c: n' o
L X-25.692 Y61.318 F1200.
, s' i: Q5 B2 x3 H; A; y3 rCR X-26.526 Y64.57 R7.833 DR-" \, m5 Q& z5 A
CR X-26.642 Y71.378 R200.934 DR-) G+ u) {* p# B2 q3 t/ k0 j( k; L5 Y
CR X-26.542 Y77.687 R200.934 DR-( {6 W8 V' b4 A( a$ R; d: W1 n
CR X-26.342 Y79.667 R11.443 DR-: S# `, q O% ?( A1 o8 M' P0 |& u
CR X-24.957 Y82.567 R6.318 DR-' H: U; F) s) q% n( N
CR X-23.774 Y85.797 R5. DR+ F840.
& x l+ V& x0 t' Y* SCR X-24.068 Y87.487 R5. DR+
+ N: s T; L# B; \7 D/ h }6 fL X-24.574 Y88.896 F1200.
6 v6 B) N. W+ Z7 { f: sL Z29.479
- o1 w3 n# c; h3 YL Z31.975 FMAX; m" _8 c4 i7 \ n
L X-29.884 Y52.552 FMAX& G% a! I2 Q6 p! T
L Z29.229 FMAX* ?, p5 j; S1 S% d* w6 ]. R/ A
L Z28.729+ q- k# _ g4 k. {
L X-24.726 Y50.926
/ ` |1 ^( c6 X. V: ~ u0 S' bCR X-23.99 Y53.536 R5. DR+ F840. p, s2 ~) r M6 n) @ H
CR X-24.598 Y55.925 R5. DR+" @- i& T. H3 i) A, O
L X-25.686 Y57.927 F1200.
8 v, j* a1 S0 K+ }CR X-26.507 Y60.993 R7.288 DR-8 R% ]# ?+ _5 H' A% y: d" ^
L X-26.597 Y63.379
8 H- t! d3 y+ u/ rL Y75.303
" a4 K9 \; ]* B! S" `+ F+ tL X-26.587 Y76.495+ h3 w! B& s- d. [% ^' r; d
CR X-26.341 Y79.812 R24.767 DR-
9 W" g: ~/ W6 Z# d, b/ mCR X-25.138 Y82.697 R6.217 DR-% K, f* I0 G( n8 b! P
CR X-24.121 Y85.72 R5. DR+ F840.6 f+ o" t, u* Q& G+ ?
CR X-24.512 Y87.657 R5. DR+( P8 \$ S& u# j
L X-25.088 Y89.027 F1200.- ^2 V+ f7 C7 W/ V: E0 v
L Z29.2291 e" D1 C/ C$ k% x; V+ O
L Z30.979 FMAX: {! V+ O0 R- Y2 Y, G. q& @4 }- _& O
L X-33.761 Y38.481 FMAX5 V. R5 R9 Y5 {) ^0 D0 E
L Z28.98 FMAX
) ~! O! C2 e/ d6 X7 Q$ Y1 j1 \) xL Z28.48- B" ^0 H9 ^* K3 T5 n
L X-31.604 Y38.227
5 ]& A# P% l6 |4 S3 _CR X-28.357 Y42.029 R5. DR+ F840.# c! h3 \0 [& \. \; [# s
CR X-26.22 Y45.841 R6.785 DR- F1200.& G [, Q4 _0 }! A7 x! r2 C- X2 ~: e5 R
CR X-24.598 Y46.904 R15.63 DR-8 X4 i! b; C, K
CR X-23.337 Y49.062 R2.5 DR+ F840." x$ S8 R9 E, N
L X-30.747 Y51.432 F1200.
% b4 D- I" @2 z) l( Z5 uL Z28.98
8 L3 j. o5 P5 }/ BL Z30.729 FMAX% o% C ^) E. D
L X-31.372 Y50.077 FMAX
* m4 A4 B `* ^$ E7 s; y o# @L Z28.98 FMAX
# F& _3 L4 _2 Z" ^L Z28.48* |2 G+ ?, I1 P* B/ d( Z
L X-24.726 Y47.546
5 N" q5 }0 N" ?( N5 {! N% }CR X-23.991 Y50.157 R5. DR+ F840.
3 |; o( v% {7 i: QCR X-24.598 Y52.545 R5. DR+# o- O' z; @# @0 b N4 x' ~' f
L X-25.688 Y54.551 F1200.& N5 y9 T- K0 {& T0 T/ E6 ?/ y* {
CR X-26.491 Y57.416 R7.273 DR-
- H9 q$ N* k+ m2 u# c: eL X-26.592 Y59.801# o1 d' S$ l( K# Q1 z, N
L X-26.597 Y75.303 B# A4 Z& i B8 s
L X-26.587 Y76.495
1 m7 z8 g: ~$ l) v5 C) I% t. G5 `, GCR X-26.36 Y79.879 R34.744 DR-
4 x0 \" p `- t# }7 j' ?. Q% iCR X-25.257 Y82.767 R6.273 DR-
) Q' z% s/ z XCR X-24.344 Y85.647 R5. DR+ F840.! M) g: _' R1 p8 B( t9 }
CR X-24.806 Y87.746 R5. DR+3 M: K- f) W7 \9 b" w
L X-25.433 Y89.101 F1200. O/ N4 |, g% [8 c$ g0 q
L Z28.98+ u) a2 c9 | k: \' |* r
L Z30.729 FMAX L9 B1 W& F/ \( j' f7 v$ `
L X-33.761 Y38.499 FMAX" P; E/ w/ H" @+ r0 Y
L Z28.731 FMAX
' ~' \" r- E( P# PL Z28.231
! ?! W) {$ z: [3 z. ]5 [# ^L X-31.604 Y38.227
8 I6 P* g4 ~: s: rCR X-28.357 Y42.029 R5. DR+ F840.
6 {* f/ S' V8 A2 X0 j1 n1 pCR X-26.823 Y45.226 R6.785 DR-" ]9 J$ b* x" y. e6 V+ {" j; j
CR X-25.368 Y49.143 R6. DR+ F588.& Y8 a" [7 P5 c: [% y
CR X-25.882 Y51.572 R6. DR+
# N" ]0 O3 o y, o6 mCR X-26.471 Y53.838 R7.21 DR- F840./ L' z, `3 O* W& e
CR X-26.588 Y56.224 R32.939 DR-
7 _$ [+ a8 \5 E$ M4 O9 W$ dL X-26.593 Y58.082
4 V/ c" r* C' n; s9 g% P/ z; \L X-26.597 Y59.802 F1200.
$ ~, q; T% j! ]3 |- ]% H5 L9 AL Y75.3033 j6 ]: A' ?( ^, @% L. Y
CR X-26.599 Y75.647 R37.459 DR-: {" Z8 s( a" m4 `1 E
CR X-26.337 Y80.07 R37.459 DR-$ J2 o0 b/ s% \3 b& T
CR X-25.367 Y82.822 R6.289 DR-; @7 g' @0 \/ D' }
CR X-24.568 Y85.533 R5. DR+ F840.' i1 G) v9 k5 I. f; b- v
CR X-25.12 Y87.816 R5. DR+
3 Y, @% y1 p( `: }1 [L X-25.803 Y89.145 F1200.$ V5 l" a$ N$ |
L Z28.731
B( _2 h8 e! g, U" ]( s. mL Z30.48 FMAX
9 }* ^' O! S% B6 }( I: e) fL X-33.761 Y38.517 FMAX$ V. V5 F R% Y/ i* w; k
L Z28.482 FMAX
( z9 D' n( X8 \# R5 J9 F/ h' L% ML Z27.982
" z- q! B8 x' I5 WL X-31.69 Y38.312" a) g& ], q- F5 t
CR X-28.346 Y42.029 R5. DR+ F840.$ u* ], m& V+ u# g
CR X-28.058 Y43.123 R11.733 DR-5 G' T! E: s. n/ a
CR X-27.247 Y44.669 R6.801 DR-
S% s7 B Q$ Q( ZCR X-26.161 Y48.112 R6. DR+ F588.
8 e! B! C+ U: B' |, m9 _CR X-26.31 Y49.443 R6. DR+$ A6 {; P$ F! V) M4 p" U+ o1 ^
CR X-26.443 Y50.261 R6.546 DR- F840.2 ^' N$ l" b: o; ^
CR X-26.584 Y52.647 R21.026 DR-
) s' A( Z2 r5 p8 F @$ ~L X-26.598 Y53.84
/ p: H7 e% K% H/ N: S& s( I+ cL Y56.026; t5 ]: Y# U( j$ b& l O
L X-26.597 Y75.303 F1200.
" \# C# m% L; r7 TL X-26.587 Y76.4954 x4 Q# H, _* J- _/ N& I9 a
CR X-26.337 Y80.07 R34.746 DR-% K1 C5 y4 d9 b( v7 ?
CR X-25.86 Y82.047 R9.181 DR-( i5 Z! C+ u5 R. v
CR X-25.455 Y82.861 R6.222 DR-# y$ T5 ~* A6 n+ Q9 n7 J4 R
CR X-24.757 Y85.409 R5. DR+ F840.$ c( I% @% y! s" ]+ |
CR X-25.399 Y87.86 R5. DR+
# q: _( B+ n. D. r1 }L X-26.128 Y89.156 F1200.- M0 @3 q0 c8 l0 A1 t- C0 y0 |
L Z28.482
- f# F9 ?! R* r3 [7 WL Z30.231 FMAX$ L$ t; O/ h" t
L X-33.761 Y38.536 FMAX
; b4 h& g3 k0 ~L Z28.233 FMAX
9 \2 O' V7 f& Z$ v5 y* R1 [L Z27.733
p5 e6 s7 C- s1 iL X-31.613 Y38.234 @2 S" n2 v* V: R4 }
2 N3 V/ s8 q& ^( k0 \) k/ J9 ~. V( T- ?CR X-27.426 Y44.411 R6.868 DR-
) s: K3 O9 j! A" E+ f2 u, O; T; ECR X-26.512 Y47.594 R6. DR+ F588.
: B0 u D- M, f2 K- xCR X-26.525 Y47.987 R6. DR+5 @( J: h0 q" {8 U! Z( h4 H' y' p: J
CR X-26.597 Y50.188 R33.373 DR- F840.
( _ U$ ?2 R0 H/ l) S* JL Y54.585
& y( V( C% B( Y3 TL Y75.303 F1200.4 X @% _0 v' l J3 F$ @! ]
L X-26.587 Y76.4956 g- d: T0 R# m p7 G
CR X-26.176 Y81.005 R26.787 DR-" E; \9 L$ H$ V' Y N
CR X-25.515 Y82.884 R6.154 DR-3 d: y: U0 w/ }. f4 c4 w% v
CR X-24.901 Y85.284 R5. DR+ F840.% p$ c7 ?3 h0 P* G
CR X-25.63 Y87.883 R5. DR+; J2 v- X/ g8 e! t; E2 @ H
L X-26.398 Y89.147 F1200.
: Y$ _- Z" {9 IL Z28.233
+ Z. P9 I# Z. H7 P/ S- nL Z29.982 FMAX5 a" N+ K) c5 d# [! v
L X-33.762 Y38.554 FMAX) [7 X; x! R, X# n+ z
L Z27.984 FMAX
8 `) U$ y" [/ X4 u- x5 E8 r" ML Z27.484. M7 i3 p# B7 A$ p0 [4 ^" t
L X-31.613 Y38.234
0 h0 B& m, w% L# |CR X-28.357 Y42.029 R5. DR+ F840.3 c# e( ]: G) p R
CR X-27.47 Y44.339 R6.868 DR-8 s W3 K" v% P3 Y' y( u
CR X-26.595 Y47.46 R6. DR+ F588.
8 E$ I1 ?6 i: w! `8 c1 yL Y47.482 _( {/ g1 y! s+ O
L X-26.597 Y47.878 F840.
9 Z3 v- n3 i$ ?L Y54.082
4 l) v* u, Z3 g2 v! OL Y75.996 F1200.
+ H, N( E$ k: m8 ?+ p& BCR X-26.171 Y81.099 R30.72 DR-' N5 Q( N' n5 h# F+ p/ \" q
CR X-25.571 Y82.904 R6.193 DR-
" C3 W/ `$ a! N7 h% rCR X-25.017 Y85.191 R5. DR+ F840.
- s0 _3 V2 A& fCR X-25.813 Y87.898 R5. DR+( Q. k1 w+ e! R, O7 v
L X-26.616 Y89.146 F1200.# ]: w' F8 B- E( R
L Z27.984' c# _* _, s) U0 Y! t6 U/ A% y
L Z29.733 FMAX2 } _ Q/ I1 j& U z$ f& q: D$ m
L X-33.762 Y38.572 FMAX
f! O6 G$ q/ W4 ?; kL Z27.734 FMAX
7 V% r8 B2 |& n) P) W a7 o6 `L Z27.234
4 W4 T' B2 L- G/ W2 L9 i! t& X+ U8 U) yL X-31.621 Y38.241
% [1 ^" B4 }5 SCR X-28.357 Y42.029 R5. DR+ F840.$ G* D+ s# @8 _3 J, q+ J& I$ D
CR X-27.467 Y44.347 R6.971 DR-" Q9 z5 B2 _; q0 P: R
CR X-26.597 Y47.455 R6. DR+ F588.
. g, \' _, ^9 A' z& M7 X7 r. xL Y54.055 F840.. j9 R9 Z: t' I u4 q
L Y76.108 F1200.
: r# Y' p1 {9 Q9 A s6 {CR X-26.15 Y81.225 R29.45 DR-
0 M! T! N& y" o6 Q7 o' QCR X-25.602 Y82.914 R6.408 DR-
( [3 {4 t+ w5 H3 NCR X-25.098 Y85.101 R5. DR+ F840.( L t5 k- l& C- v4 Y. p. F( G
CR X-25.956 Y87.902 R5. DR+
7 P4 k1 `5 `8 O9 ]L X-26.8 Y89.15 F1200.: Z. n* w* P3 b; ?; _" I- e6 C
L Z27.734 M S) k5 W3 c) d( l
L Z29.484 FMAX, ~( u9 } b: {+ V' T6 `) I* t4 [
L X-33.762 Y38.591 FMAX
; k9 K1 h/ I9 C$ LL Z27.485 FMAX- Q/ j# f9 G1 I
L Z26.985
# j% g4 }6 D3 ]' {L X-31.621 Y38.242
+ Q; h/ k7 D' {' {( E2 P- BCR X-28.357 Y42.029 R5. DR+ F840.# [/ k V% \8 _. H5 A
8 v- n' f, _4 d) i. nCR X-26.597 Y47.455 R6. DR+ F588.
+ r, p) }: O1 lL Y54.055 F840.( Z9 S8 Q/ N& Z6 e
L Y76.025 F1200.
/ S* Y( i/ m* Q& I" l$ `CR X-26.158 Y81.175 R30.423 DR-
* v4 H5 y' l! _7 T7 xCR X-25.643 Y82.884 R7.278 DR-! u( Z8 p# p% J' \
L X-25.626 Y82.9223 x, h/ G4 e% `6 O5 x) G. E
CR X-25.186 Y84.973 R5. DR+ F840.
$ U) |9 S) c% S5 T! TCR X-26.13 Y87.896 R5. DR+7 ~* J* p9 M1 `( O. p& W- M( g8 {
L X-26.998 Y89.101 F1200.8 B8 S, ~7 a9 x4 d8 ^6 I6 J% C
L Z27.485' B: T2 b" J+ `* C# z2 j9 r
L Z29.234 FMAX
0 T# y# Z' D V b6 rL X-33.765 Y38.609 FMAX: R+ T G' O# @1 u, r$ L% Y
L Z27.236 FMAX
) s. F2 _: ^& S6 CL Z26.736
( ^& S9 X7 B7 ]4 QL X-31.621 Y38.242
( x; O7 e1 u+ d" z* m2 y6 }CR X-28.357 Y42.029 R5. DR+ F840.8 i/ B# N1 ]7 L3 v6 x
CR X-27.467 Y44.347 R6.972 DR-
6 w/ \0 m4 I" s+ gCR X-26.597 Y47.455 R6. DR+ F588.
- q" N: Q. W+ P1 }: eL Y54.055 F840.. H& a; s8 O1 c+ R9 ~6 t* b
L Y75.937 F1200.% t8 a/ w2 m" j; U6 B* ^9 C. @
CR X-26.125 Y81.372 R31.474 DR-
5 {( _1 s1 C0 N# DCR X-25.649 Y82.929 R6.647 DR-
+ t- _/ d0 |" I# L( y7 W' H8 ACR X-25.217 Y84.963 R5. DR+ F840.
' D. d6 Y2 X- R" @" I9 Q/ \$ iCR X-26.172 Y87.902 R5. DR+
1 S7 D* x( W! y- [8 V3 {- tL X-27.069 Y89.137 F1200.& ]- ]8 G3 V$ U, z
L Z27.2369 |6 R( ?: ^+ a! t0 G3 j# \1 R
L Z28.985 FMAX9 u/ h: ^) d2 J" {, n. [
L X-33.821 Y38.628 FMAX& ?4 C$ w( D2 k5 R
L Z26.987 FMAX
* v9 {2 p4 y+ gL Z26.487) ]1 |9 b4 l9 {$ `3 K( h& Z
L X-31.621 Y38.2425 T% S! R( r6 Q
CR X-28.357 Y42.029 R5. DR+ F840.) B) V+ S G" }# `
CR X-27.466 Y44.347 R6.972 DR-
8 y9 C, I6 j$ p; w% \+ wCR X-26.597 Y47.454 R6. DR+ F588." ?9 {) |! ]+ w
L Y54.054 F840.
+ R4 d3 K( l0 h# T. |L Y75.303 F1200.
w) |8 M* r" V5 W0 ACR X-26.599 Y75.668 R37.098 DR-
- R/ R8 _' u4 i. F/ iCR X-26.337 Y80.07 R37.098 DR-
; x+ O" d% C( [ A% x; w( LCR X-25.856 Y82.385 R13.304 DR-. J8 n) q1 E& H3 `2 g$ r V2 [
CR X-25.661 Y82.932 R6.217 DR-5 R) Q7 r, M: I; C
CR X-25.291 Y84.822 R5. DR+ F840.
* ^- R+ s) h& [( rCR X-26.34 Y87.886 R5. DR+. X$ }2 E4 g- e( s
L X-27.25 Y89.061 F1200.* B2 l6 H$ _; q4 t( l Y1 W
L Z26.987
2 f, y) ]' J5 c1 SL Z28.736 FMAX6 H [+ n* A6 r L
L X-34.344 Y38.646 FMAX* ~! i9 v; k3 w2 \* ^! O7 M( u3 q" i
L Z26.738 FMAX
3 d$ F5 l, F' p6 J7 dL Z26.2386 y( j, [ a O3 o6 V5 v9 B4 E6 @
L X-31.621 Y38.242: G- A0 s5 d5 }4 g4 y
* w0 I1 n" a7 e1 Q. i: ]7 XCR X-27.467 Y44.347 R6.972 DR-
5 X. h- a. C7 l! BCR X-26.597 Y47.455 R6. DR+ F588.
0 ?# d0 S6 C$ s) k) TL Y54.055 F840.) Z9 D; T7 {; }8 U8 A7 V' U
L Y75.303 F1200. u- x% E% X' g; e- M+ S. [
CR X-26.599 Y75.668 R37.097 DR-
+ y7 _9 r1 o5 Z, RCR X-26.337 Y80.07 R37.097 DR-
$ c7 d0 h* w9 a+ ]- | ICR X-25.836 Y82.449 R13.304 DR-3 n& h# V4 K; ?
CR X-25.669 Y82.934 R6.246 DR-
' O; B: E* b! c- g# ]CR X-25.324 Y84.759 R5. DR+ F840.
/ a+ z8 h, r# ^CR X-26.416 Y87.878 R5. DR+$ l- {. G, S$ q. X* \3 i
L X-27.346 Y89.042 F1200.! K( g! e2 T" q& z7 Y/ w- y" w$ v0 A
L Z26.7385 } H+ D; z1 S7 l3 K) M4 X* ]
L Z28.487 FMAX
4 \& D7 @; l; \6 U0 N6 _! RL X-34.789 Y38.664 FMAX) M( Y) H5 u( b/ f( i% ?1 X
L Z26.489 FMAX, ?7 W' ^0 E9 n5 |- Y
L Z25.989
" Y( C4 {7 ~9 ?L X-31.621 Y38.242
* J! S$ }9 f# k8 |4 tCR X-28.357 Y42.029 R5. DR+ F840.! B% q, P$ T# t5 j) f
CR X-27.467 Y44.347 R6.973 DR-1 e' T N" _1 u, I. I, [
CR X-26.597 Y47.454 R6. DR+ F588.+ o! I. g' o( @) A/ W
L Y54.054 F840.. ^9 u* i- b# ^! J5 u% t2 x
L Y75.303 F1200.
: @; Z" V w0 w$ hCR X-26.599 Y75.668 R37.095 DR-6 v% ?- U Y! ~- B7 o7 a3 X H& M
CR X-26.337 Y80.07 R37.095 DR-
- s2 E" N4 a7 b3 ^CR X-25.836 Y82.449 R13.305 DR-2 @ _6 F% I! F5 z
CR X-25.672 Y82.935 R6.251 DR-0 B/ d+ \9 A) k: J9 [
CR X-25.341 Y84.726 R5. DR+ F840.7 b4 [; n/ E4 d( d" G
CR X-26.456 Y87.874 R5. DR+, P: L8 U) x+ P" B3 K5 w+ l4 a
L X-27.394 Y89.031 F1200.
6 z. ?" I1 `" \* GL Z26.489
d. {' Y; z& JL Z28.238 FMAX
2 a) w) D% I6 e7 Z, ?L X-35.181 Y38.671 FMAX
& _) }9 S8 Z% I3 R9 h7 w, s$ ?L Z26.239 FMAX8 ]9 }4 Z: x7 |7 j0 U, k
L Z25.739
) T' @; k# F, R- X5 k- Y. {! \$ uL X-31.621 Y38.2422 O& B: S* X- _, m& _
9 F0 t- _4 i# }6 ?1 eCR X-27.467 Y44.347 R6.973 DR-5 W9 `1 z) v/ f* g, |6 \
CR X-26.597 Y47.454 R6. DR+ F588.: h+ ^3 L$ V1 Y b+ C& @
L Y54.054 F840.
& F* n! Z' w, ]' U; ZL Y75.303 F1200.
0 o1 b3 \/ _ ]- @6 z+ v( l% zCR X-26.599 Y75.669 R37.093 DR-% X& A1 L8 S, }0 t2 B% j6 V
CR X-26.299 Y80.378 R37.093 DR-
& z# T, I3 ?% E$ r5 G: B6 zCR X-25.652 Y82.93 R10.902 DR-
6 Q: |' Y# b' O# r" x8 W0 h9 QCR X-25.315 Y84.735 R5. DR+ F840.
& i% a; ^) d5 x/ |( _0 dCR X-26.42 Y87.87 R5. DR+& w$ i# N' Z/ ~' F* Y( v! E Q" w3 ~
L X-27.381 Y89.064 F1200.! f3 i! L* W8 l% z# f2 n9 d: F
L Z26.239, O* U: y! Y9 w$ l
L Z27.989 FMAX# V7 h, B7 }1 o3 A8 _
L X-35.523 Y38.676 FMAX
4 f$ j: N/ _+ ^2 M6 r3 F0 c( s9 }3 ZL Z25.99 FMAX2 W8 W. \( b( \# V1 [: k4 E' L, Z
L Z25.49
/ R* M' C0 i) Y+ J$ \% OL X-31.621 Y38.242$ \2 p, M b0 T: y/ f
CR X-28.357 Y42.029 R5. DR+ F840.9 O. K; M$ Y3 r( k4 f. D2 r" w
. p; U F7 C7 `" h: S" S* {CR X-26.598 Y47.454 R6. DR+ F588.4 p4 j, U& z* ~8 _6 w& i8 ^: d
L Y54.054 F840.
* q3 j7 T4 F/ K9 h7 FL Y75.303 F1200.; U7 C" K1 \9 u) ^8 \* [
CR X-26.599 Y75.669 R37.091 DR-' ?% {' p* x/ ^6 s. R& l W0 T
CR X-26.299 Y80.378 R37.091 DR-
- w8 ?) V4 z* j+ m, k1 ?CR X-25.652 Y82.93 R10.902 DR-
' v/ G4 r; g3 B1 D5 f) LCR X-25.315 Y84.735 R5. DR+ F840.% v' R9 t7 p# ~, f3 G2 l
CR X-26.42 Y87.87 R5. DR+* o2 a1 n5 L7 f) }% G/ l, j$ k7 U
L X-27.391 Y89.075 F1200.! ~( Z( \5 R, @" q6 \% P
L Z25.99( r9 U- d3 X& ^! c! t0 `% u
L Z27.739 FMAX, w+ m( B4 w% }
L X-35.865 Y38.659 FMAX3 I; E* Z, t3 X2 x
L Z25.741 FMAX6 B' P8 q7 g1 E9 r5 V
L Z25.241
, p* p6 @, \& Z0 d0 L jL X-31.621 Y38.242
) w. I& |7 h' b2 {( Y: q: qCR X-28.357 Y42.029 R5. DR+ F840.# N; d' }% j* F" M- x6 p% z$ R' Q
CR X-27.467 Y44.347 R6.974 DR-7 }+ N* r3 z/ j9 \9 ^1 C& o6 n) S
CR X-26.598 Y47.454 R6. DR+ F588.7 X# E, _, |( c( m
L Y54.054 F840.
! W c7 z* |# g8 _8 uL Y75.978 F1200.
2 H2 ?" _, q1 w6 N0 x8 d% l6 wCR X-26.134 Y81.316 R30.974 DR-
9 I- l d6 M( D2 b/ @, ICR X-25.667 Y82.934 R7.833 DR-
7 W# ^" j. @2 z0 t8 p0 ]CR X-25.294 Y84.828 R5. DR+ F840.
K6 L$ }% A6 H' rCR X-26.34 Y87.889 R5. DR+. p( ^/ i0 R/ E1 U
L X-27.321 Y89.156 F1200.3 O. j1 w! D1 l: _7 |* {
L Z25.741
( W& a' B7 W* L: wL Z27.49 FMAX
! N$ \# y q0 O: v9 w& s- xL X-36.178 Y38.637 FMAX/ y- Z1 b7 X- U# W3 |
L Z25.492 FMAX
# L; k4 s3 j( o2 _% ^L Z24.992, x) r3 p1 }8 f* f' v
L X-31.621 Y38.242
" U) v4 e) D" |3 ~9 P* P3 S' }CR X-28.357 Y42.029 R5. DR+ F840.
: i# x$ }: o: ]. o& q: Z& ~CR X-27.467 Y44.347 R6.974 DR-% z) H# L# Y% l" x& }1 k6 E- l% Z
% _/ E9 L1 u, q5 l3 e8 BL Y54.054 F840.
& f7 B5 w) I! w9 D s, i( D3 GL Y75.303 F1200.8 X$ v. a$ t' s
CR X-26.599 Y75.67 R37.088 DR-
9 b- c+ N6 @3 s. m1 B% NCR X-26.299 Y80.378 R37.088 DR-6 m5 \) R8 Q9 {8 r) [
CR X-25.652 Y82.93 R10.902 DR-4 N0 `+ ]' j5 |$ m( L1 y
. }! [) x/ K ?+ V. _: I7 E% oCR X-26.421 Y87.87 R5. DR+' s e( g0 d9 u& k
L X-27.4 Y89.087 F1200.
" t+ y9 |5 [/ A5 s9 _" @L Z25.492/ g- e# N" o; ]: x! g+ b) ?! u0 _
L Z27.241 FMAX
/ Z" g* o# j0 I! G0 S9 t" UL X-34.983 Y54.187 FMAX
$ T b( l# ]" A* s# U- X+ zL Z25.243 FMAX
5 P7 j' x, o/ vL Z24.7435 o$ D! t( n L( v" o" d7 r
L X-32.762 Y51.772
& f& b' x* |9 y- Q6 N mCR X-31.443 Y48.388 R5. DR- F840.7 D' u, r4 [+ |
CR X-31.673 Y46.892 R5. DR-1 o" Q6 f- I9 U7 p- a4 z
CR X-32.032 Y46.003 R6. DR-: ]4 L2 A" S3 b$ e
CR X-32.548 Y44.812 R11.775 DR+ F1200.3 U/ w; c/ `# L4 T5 S: q
L X-32.602 Y44.62 F840. h, I0 I9 A+ o0 `2 b/ K2 R
CR X-32.696 Y43.822 R6.062 DR+ F588., r: _+ `+ ?& E3 d2 V
L X-32.698 Y43.7365 ]% C- Y0 I# \( K) m
CR X-31.035 Y42.056 R1.68 DR+3 s3 i- a2 y, ^
L X-29.973 Y42.045 F1200.; Y" q7 |( \) X2 h
L X-29.952 F588.* R# n7 A/ I' N
CR X-27.955 Y43.382 R2.16 DR+* e7 e: V4 f, s8 l1 S1 e# Q
CR X-27.467 Y44.347 R6.975 DR- F1200.
9 g% G4 `" M" W" R! q2 H7 n( e0 zCR X-26.598 Y47.454 R6. DR+ F588.( R( N' I: | J4 v
L Y54.054 F840.
7 K' x: t: A3 g3 EL Y75.303 F1200.
! e% _4 S7 W5 |0 Y! rCR X-26.599 Y75.67 R37.086 DR-7 T; a" W C% P
CR X-26.299 Y80.379 R37.086 DR-& t% @1 H- i5 Z1 O
) P2 g7 _# H* F) t1 Z" w* O& d( R6 [CR X-25.315 Y84.735 R5. DR+ F840.
. C# C7 L( ?3 P) {% ?( O2 v* dCR X-26.421 Y87.87 R5. DR+6 `2 ^; G3 T7 \5 p$ L$ X* I
L X-27.401 Y89.088 F1200.. q1 d- f ^# t% G- o* [, ^
L Z25.243+ y3 _' i3 ] R! @+ a. a
L Z26.992 FMAX- ]" e2 r1 ]; _, w4 `6 Y8 T, m( z
L X-35.321 Y54.124 FMAX# k$ K2 j% |" w) r+ V4 d
L Z24.994 FMAX3 x, j& g! k% a7 H: _; s
L Z24.494" c2 T0 u* k1 n
L X-33.199 Y52.344
8 z! d$ R& h- e4 w+ n q6 Z+ z/ oCR X-31.413 Y48.514 R5. DR- F840.
- D) t2 \) p1 { T2 r5 _CR X-31.489 Y47.646 R5. DR-1 S& w6 e2 M0 `+ ~ \. P
# e) z7 g% t$ w+ iCR X-32.947 Y43.507 R11.775 DR+ F1200.
! c) ]5 _$ W) n1 Q# iCR X-32.979 Y43.237 R1.142 DR+ F840.
- b% M4 ~: ?: r- u% l4 uL X-32.977 Y43.168
% e4 \: H. ~+ ]- a- UCR X-32.958 Y42.929 R6.132 DR+ F588.
0 E* \0 N7 @1 X. z: t g, zCR X-32.012 Y42.066 R.96 DR+
' r- ~/ F6 ]1 |- B M, d7 r; h! UL X-29.117 Y42.037 F1200.
- L- Q- A5 t M% R# {- EL X-29.108 F588.+ s* u! @7 m5 z# I& _* s
CR X-28.188 Y42.722 R.96 DR+. S+ f2 y3 U/ u* X) ^( g
CR X-27.467 Y44.347 R6.975 DR- F1200.- m! O/ Q4 j. Y1 d! X/ ?( W7 R
) Q5 L! ~( r$ I* M& }( @# NL Y54.054 F840.' q' y" L5 d( j$ m$ l3 y; L0 l
L Y75.303 F1200.
& ^# W' R9 ], DCR X-26.599 Y75.67 R37.084 DR-
3 n! F; `: v8 I/ ?CR X-26.299 Y80.379 R37.084 DR-
0 t) Z6 i( J1 V) ^7 OCR X-25.652 Y82.93 R10.902 DR-
: h+ { s* S/ j. r* N( O- lCR X-25.315 Y84.735 R5. DR+ F840.
7 g' Y: S3 Z# ]3 ~* ^CR X-26.421 Y87.87 R5. DR+
0 `. z, _2 A1 k2 J( WL X-27.401 Y89.088 F1200.
' a3 B2 \8 L* j u& G- ZL Z24.994& a* u7 A! r# d( P; D8 t5 E
L Z26.743 FMAX
/ B8 i6 Z& e2 SL X-35.677 Y54.129 FMAX7 F1 Q3 S, G# c! F/ v7 O
L Z24.744 FMAX1 ]6 K0 G: P, K$ {0 H
L Z24.244
9 W1 `+ r- m& K+ F% Y( QL X-33.672 Y52.825+ K( b1 T8 m% l1 V3 G/ [
CR X-31.399 Y48.634 R5. DR- F840.; i% X/ v" ]7 R% s8 f! q
CR X-31.406 Y48.368 R5. DR-
* `# ~' T! K# m# gCR X-32.032 Y46.003 R6. DR-' F/ k, }" f- h: ]$ m% _: m: K
CR X-33.073 Y42.925 R11.775 DR+ F1200.
% E+ n+ u9 y$ ]1 S& x9 qCR X-33.137 Y42.472 R4.8 DR++ m1 P$ I' S' k- a
CR X-36.025 Y38.391 R5. DR- F840.6 v' V# f V, h& n/ Z9 k2 P, S; X
L X-37.092 Y38.706 F1200.
5 z, ~5 g G) z/ B. lL Z24.744( u, f# t3 [4 T, k) J" A
L Z26.494 FMAX8 l/ l; i6 v; G( i
L X-34.507 Y84.916 FMAX
$ L2 O$ W& {+ i' I& W1 e: d- Z. d0 n1 RL Z24.744 FMAX
, Q0 i' D' d; o3 N5 { eL Z24.244
. b6 y1 y" N/ T" bL X-33.312 Y84.071
* S( {8 N" H5 o7 `1 Q2 DCR X-31.2 Y79.989 R5. DR- F840.$ N2 t2 W# v, y* ~) ~, y
CR X-31.221 Y79.529 R5. DR-
4 [6 `- ?5 H* S. u% ACR X-31.399 Y75.67 R41.883 DR+ F1200.
. _8 c5 o/ y# i: gCR X-31.398 Y75.28 R41.883 DR+
% t. |! m0 s3 V8 D; SL Y70.257+ `( C8 Z6 e! u$ @! v* V9 I
CR X-33.898 Y65.927 R5. DR- F840., N" x! }" X7 N9 g
L X-36.149 Y64.627 F1200.8 b; N2 {0 x3 i
L Z24.744
: B# F) z \# V$ i: qL Z26.494 FMAX
5 c: V: X) P* K* K. IL X-37.092 Y38.706 FMAX7 t" c# n* f+ O
L Z24.744 FMAX
! ]6 p1 J5 t. R" Z- V1 q* hL Z24.244
8 {* j7 Z1 e, i4 [) x/ YL X-31.621 Y38.242/ R6 v) f6 R% h/ M4 v( ?- Q+ r$ b- _
# w5 ]6 F8 g+ r* P, HCR X-27.467 Y44.347 R6.975 DR- ~2 `( r4 t5 g( v
CR X-26.598 Y47.454 R6. DR+ F588.5 b d3 v3 y2 p4 p5 _
L Y54.054 F840.
, n' P5 {/ y6 ^L Y75.303 F1200.
/ Y L0 M3 e- l1 f g- H0 U" R# ZCR X-26.599 Y75.67 R37.083 DR-) |1 C3 N5 x) o
CR X-26.299 Y80.379 R37.083 DR-
4 n J* h9 t0 B. F l" L% Z9 Y6 ZCR X-25.652 Y82.93 R10.902 DR-; p! s1 P1 I1 X& i
0 D- A9 q' t) h8 cCR X-26.421 Y87.87 R5. DR+
" e, K# S& S& G8 pL X-27.402 Y89.088 F1200.+ c' d# E; D( r
L Z24.744 u" o6 s4 y2 o6 [9 x8 e
L Z26.494 FMAX
( ?% J* |0 m) ZL X-36.078 Y54.522 FMAX3 Y: A7 k( D Z$ u& R) x) w
L Z24.495 FMAX
1 d( V' c5 m3 k9 h p! rL Z23.995
; W5 n4 ~& @$ Z. m% z+ Z' `/ \L X-33.898 Y53.264
. E9 j6 Q6 B3 `- x* M8 ECR X-31.398 Y48.934 R5. DR- F840.1 U' R. o$ k6 n5 a- s
L Y48.683 F1200.6 F+ ^2 g A) x7 Q s+ S9 B7 @
CR X-32.032 Y46.003 R6. DR- F840.
( f% ^- e' x" P& T/ a7 S: KCR X-33.073 Y42.925 R11.776 DR+ F1200.4 p/ `/ w% | w4 H" J8 B8 p* J
CR X-33.157 Y42.077 R4.8 DR+ z# S1 h' ]3 F) C9 G8 K3 R$ h
CR X-35.7 Y37.772 R5. DR- F840.' }+ ?% C4 V* x7 P9 `
L X-37.524 Y38.748 F1200." [! s: T( t0 s
L Z24.4958 T ?0 H* D- L5 B% K% R5 S
L Z26.244 FMAX
" r9 c+ f; X5 X3 i6 q" sL X-33.604 Y86.895 FMAX) q& _6 j$ Q2 @7 Z/ |1 [, X
L Z24.495 FMAX
2 M& c/ r d: M. m3 LL Z23.995
7 _& t- N. {" }8 t& L9 bL X-32.753 Y86.199
, t3 B) x% C# \1 ^' d8 w, iCR X-30.917 Y82.328 R5. DR- F840.
8 H" ?4 D4 i$ f: l2 D8 [( q- HCR X-30.983 Y81.523 R5. DR-
, Q# c. m# p( {) H9 u. ?7 bCR X-31.06 Y80.988 R15.702 DR+ F1200. p1 H- Z/ O; ~5 x- s
CR X-31.399 Y75.671 R41.881 DR+
- ] O& A3 H* e6 K# a2 r% {CR X-31.398 Y75.28 R41.881 DR+
/ ^1 G( _1 k. ]7 D/ WL Y61.742
0 J9 t1 N3 G# C9 D" ?CR X-33.898 Y57.412 R5. DR- F840.4 Z& c) B6 { x0 o1 K* u- w# P
L X-36.149 Y56.112 F1200.
# D- L* b& w8 y2 N6 s( `$ lL Z24.4954 W6 [+ N+ u% O$ a
L Z26.244 FMAX
8 i" z- R% R0 u5 wL X-37.524 Y38.748 FMAX
# o) B0 ]+ P4 b5 g" q" X2 LL Z24.495 FMAX
" L5 A& z* O9 }L Z23.995
5 V' n; N* e7 p- G2 p* nL X-31.621 Y38.242
5 x2 u3 x$ I" r8 T- ?# x* kCR X-28.357 Y42.029 R5. DR+ F840.5 k, X' A V. ?
CR X-27.467 Y44.347 R6.976 DR-. Z) m9 \' b- c- V {0 {3 \
CR X-26.598 Y47.454 R6. DR+ F588.' L' x3 h! N y7 Q R; f8 [
L Y54.054 F840.% X$ I* {$ ]7 r" U
L Y75.303 F1200.
9 O- T% Y3 Z" G2 o! m+ W% }CR X-26.599 Y75.671 R37.081 DR-
, X; l" b( X _# Y! yCR X-26.299 Y80.379 R37.081 DR-
6 m1 b! j( \- y _CR X-25.653 Y82.93 R10.902 DR-
0 {0 p- ~# j1 y: }1 kCR X-25.315 Y84.735 R5. DR+ F840.4 z1 P2 Y; J8 f. k. [
% G6 `& P; D( H: A. b$ tL X-27.402 Y89.088 F1200.
) O! e# O! N. U0 gL Z24.495
. T6 ^$ t9 w/ Y0 R. v3 YL Z26.244 FMAX
1 A' D e8 _* c9 ^L X-36.545 Y55.53 FMAX
& \; V# a2 Y: gL Z24.246 FMAX9 ?( W( z: j$ I" s' s
L Z23.746/ }# e$ b( z& A; V
L X-33.898 Y54.002
4 Y' n& m: z# X: rCR X-31.398 Y49.671 R5. DR- F840.
6 u/ L+ v z; FL Y48.683 F1200.: f- X* l y! r' e
, n$ S7 Y2 R7 ~) B" X: pCR X-33.073 Y42.925 R11.776 DR+ F1200.5 S" b1 ]0 o9 R- B, |
% {, Q- M$ A1 d6 }0 K5 t8 p7 t2 A) bCR X-35.7 Y37.772 R5. DR- F840./ X. }/ F0 d% r4 Z6 j4 l) x
L X-37.981 Y38.806 F1200.
$ F' E j: A6 w6 U B5 D8 V# s( c5 \L Z24.246
+ R4 A/ X$ l+ Y# r* T% A* O3 cL Z25.995 FMAX
3 m* Z7 x' \4 |+ U! \ EL X-32.559 Y88.493 FMAX
0 X- |9 N5 A8 h3 H4 HL Z24.246 FMAX
9 A7 y3 s. m8 @* \6 H- [: OL Z23.746$ Y) t, {+ k' d" A/ H
L X-31.949 Y87.883: r2 x2 F; v2 W2 R( C0 N$ R9 \6 ]
CR X-30.484 Y84.347 R5. DR- F840.
4 [1 k! z6 |- W, }! qCR X-30.654 Y83.054 R5. DR- Q; Z" i6 D9 Z! R
CR X-31.061 Y80.988 R15.702 DR+ F1200.+ H& b. z: |; _
CR X-31.399 Y75.671 R41.879 DR+
" U7 z" n( Z8 i" M7 wCR X-31.398 Y75.28 R41.879 DR+
- \. W% q7 s$ M( M; [4 cL Y52.2941 ? X+ f; A$ t }0 o
CR X-33.898 Y47.964 R5. DR- F840.( q/ ]8 S% T, d0 e7 A
L X-38.996 Y45.02 F1200.( p; d9 O5 b, i6 q8 S# ?
L Z24.246; g/ _ N _# `, y
L Z25.995 FMAX. w' j, m7 s/ G
L X-37.981 Y38.806 FMAX3 q$ k: L( l! D6 }
L Z24.246 FMAX: W; @: L }8 q: u5 y( x
L Z23.7461 f7 f, Q# A, z" ~" ~1 _( X
L X-31.622 Y38.242
0 V$ K+ u3 H# ]. C6 c& c+ L; F' \/ f5 SCR X-28.357 Y42.029 R5. DR+ F840.
+ j1 `- J T3 {' y1 ECR X-27.467 Y44.347 R6.976 DR-
. \ ^: B. {8 V3 ~/ R3 k! p# jCR X-26.598 Y47.454 R6. DR+ F588.
$ T) `4 {1 a% i: d6 qL Y54.054 F840.
" h( {$ F2 ~% g) U6 q9 }. r! k9 ]L Y75.303 F1200.1 V' H7 v6 k4 m
CR X-26.599 Y75.671 R37.079 DR-; Z7 g% [+ ?6 T# y
CR X-26.299 Y80.379 R37.079 DR-
# F6 w* B! |. L. W& B0 B" eCR X-25.653 Y82.93 R10.902 DR-
9 t, j/ }# V; H0 `5 b" m5 n4 X0 CCR X-25.315 Y84.735 R5. DR+ F840.+ |( ^* Y$ d' l! y# o" E9 N4 X
' y' {& l) e5 k3 ^. f# sL X-27.402 Y89.088 F1200.8 b/ e6 j, o' r& Z- N
L Z24.246$ f6 t! W' L% I3 p9 m
L Z25.995 FMAX
9 Y0 Q5 C8 X% yL X-32.78 Y88.713 FMAX
1 N6 M7 h; r6 p& _8 oL Z23.997 FMAX
3 O* K* a' m( y! ]' PL Z23.497
/ E2 E! d. I ^8 t" T: |2 YL X-31.949 Y87.883
( _; K" |# A4 FCR X-30.484 Y84.347 R5. DR- F840.
+ v2 c; E' f3 S$ c/ a2 oCR X-30.654 Y83.054 R5. DR-
! m: ?1 n* L- [& Z+ ` FCR X-31.061 Y80.988 R15.702 DR+ F1200.& w3 o! u2 L9 }0 _# ~/ k
CR X-31.4 Y75.671 R41.877 DR+
# H3 n5 _% u' V- sCR X-31.398 Y75.279 R41.877 DR+1 {1 w. d3 q2 w* ]+ k+ P* g
L Y48.683- }& e8 A9 B1 x. P% J4 d
3 l: O6 b8 N9 I% Z# dCR X-32.744 Y44.237 R11.776 DR+ F1200.
2 c f2 R' ~" zCR X-32.821 Y43.737 R1.68 DR+ F840.
1 q0 i7 p) o8 C% ]CR X-31.158 Y42.057 R1.68 DR+
: r; T/ T0 }, @3 _6 d4 rL X-30.134 Y42.047
% |6 j. k( ~; U- u/ l" DL X-30.11 F588.) B! x9 j G" O& c; \; b, {1 Y8 T. C! Z
CR X-27.908 Y43.494 R2.4 DR+
# m' P& x7 [% Q1 pCR X-27.467 Y44.347 R6.976 DR- F1200.0 G3 m, J9 g3 `: s
J5 n" Y6 ? t. h3 UL Y54.054 F840.
* K9 Z, n8 C$ S4 Y: oL Y75.303 F1200.8 h7 o5 l" }3 C5 _
CR X-26.6 Y75.671 R37.077 DR-
2 l1 }, d- H2 r7 h5 ?& JCR X-26.299 Y80.379 R37.077 DR-
2 b6 C$ E* [0 L# ~% N% dCR X-25.653 Y82.93 R10.902 DR-, T- ]. g9 Y3 X# ^- ^" T- f
CR X-25.316 Y84.735 R5. DR+ F840.! z3 a( s( E9 Y3 q8 g; y- |
CR X-26.421 Y87.87 R5. DR+. p& J4 Y$ i2 p
. H. P; d# l0 u% b: e" [ G$ QL Z23.997
4 m0 v& A2 v; I! k; s2 q/ g& |L Z25.746 FMAX) E3 Q3 g& l, m
L X-33.033 Y88.966 FMAX
# `& C/ o Z& c. s; VL Z23.748 FMAX
9 ^# k- H, g% s. L9 L* ^# SL Z23.248
# v3 t) B% y: F' w4 J& rL X-31.949 Y87.883& ^+ c# @- L* Y& \
2 ]/ W1 P' F4 s8 Q- XCR X-30.654 Y83.054 R5. DR-9 d: l( Y* U" Q. B9 |! D2 y6 t
CR X-31.061 Y80.988 R15.702 DR+ F1200.- N$ S+ }+ J. u2 ^) v
CR X-31.4 Y75.671 R41.876 DR+
5 b! D( w, x A" d8 d( z8 LCR X-31.398 Y75.279 R41.876 DR+
% l# p+ C& k7 |8 p! LL Y48.683
$ v" U, b- y1 x) y5 \' @CR X-32.032 Y46.003 R6. DR- F840./ L2 u) q! u: _- L+ A9 G
CR X-32.744 Y44.237 R11.777 DR+ F1200.) N/ {; B v9 q$ G
CR X-32.821 Y43.737 R1.68 DR+ F840.: K1 c5 m; k) D; }5 Y- {6 ^4 N# o
+ c: w- c8 Y& S* b* DL X-30.133 Y42.047; z I# Z: }; Y
L X-30.11 F588.
( a; t n+ o$ ?3 J. Z0 DCR X-27.908 Y43.494 R2.4 DR+
' _# V8 J' S: ], @CR X-27.467 Y44.347 R6.977 DR- F1200.
" N6 {3 D# j' S E0 O* t5 ]" WCR X-26.598 Y47.454 R6. DR+ F588.
4 F- Q, L+ y, N9 T4 lL Y54.054 F840.$ t( {$ o/ f% B7 `
L Y75.303 F1200.
: J& m. a: o) sCR X-26.6 Y75.671 R37.076 DR-
" W& O8 v! I6 N/ V% cCR X-26.299 Y80.379 R37.076 DR-
- q! b" Y& U+ ~0 sCR X-25.653 Y82.93 R10.902 DR-
( B3 O, V# F: P1 J6 s* A3 ]5 VCR X-25.316 Y84.735 R5. DR+ F840.
G( x" U& p; }1 o* l0 k+ jCR X-26.421 Y87.87 R5. DR+
5 x7 K9 _ N( Z4 Y; L* ^0 qL X-27.402 Y89.088 F1200.
8 Z' O6 W( y5 bL Z23.748
: }. m; d; a: D; ?L Z25.497 FMAX
! q! w$ z6 Y- \3 w" H1 mL X-33.146 Y89.079 FMAX6 L" v& M3 p1 g/ i; ?% f
L Z23.499 FMAX/ A$ s& [, `" Q- f: C. p; n- Z' [
L Z22.999
K$ m5 n# ^ SL X-31.95 Y87.883
. }( Q: q. p1 F4 y5 V3 x. tCR X-30.484 Y84.347 R5. DR- F840.
' O6 ]: ?8 b$ |" ZCR X-30.654 Y83.054 R5. DR-( ?3 M' v& y p$ d" S6 v
CR X-31.061 Y80.989 R15.702 DR+ F1200.
, n) {0 }3 |8 b$ `6 QCR X-31.4 Y75.672 R41.874 DR+& T1 |* q8 t; G9 G
CR X-31.398 Y75.279 R41.874 DR+( w1 k3 z$ M" D7 l) v0 U! k
L Y48.6831 a/ b# }2 Q. A3 L* j9 n6 ~ J# ]
* i. V8 M4 M6 X/ _( zCR X-32.744 Y44.237 R11.777 DR+ F1200. E8 d" K6 I" @1 n) C
; q7 Q# G" o8 C% RCR X-31.158 Y42.057 R1.68 DR+
( y2 U" P$ [5 [! a5 T; A) v1 sL X-30.133 Y42.047
# f" V9 y0 w& ?" C4 uL X-30.11 F588.. _0 l) y& e5 a% S6 x" N$ p
) M% [( y2 Y# C6 N, m& oCR X-27.467 Y44.347 R6.977 DR- F1200.
2 E' p% F m* hCR X-26.598 Y47.454 R6. DR+ F588.
0 r4 H/ W0 g& G5 PL Y54.054 F840.
& `2 e) K/ G, c8 u& A8 pL Y75.303 F1200.
) J& S5 C9 X! i+ l6 f$ c# OCR X-26.6 Y75.672 R37.074 DR-0 C" Q6 ^+ u. I
CR X-26.299 Y80.379 R37.074 DR-
/ ^# t6 G+ x( o% u9 H) e) @CR X-25.653 Y82.93 R10.902 DR-+ [9 `, U- _3 ?1 I, C
CR X-25.316 Y84.735 R5. DR+ F840.+ Z: w/ x% {2 s
. ^: X0 b9 m" P& kL X-27.402 Y89.088 F1200.
) ?& g( f" T, S" a1 L) [L Z23.499
/ a! P' K' i$ ~! @! ]L Z25.248 FMAX5 d3 s/ t1 t, h8 D; C' z0 g0 {
9 p! k/ s; i! x' }- p* W jL Z23.249 FMAX
0 g8 c1 E" O$ u' y6 ~6 s3 Z% ML Z22.749
, ^' s, A. ?, |( Y4 ZL X-31.95 Y87.883
( p+ _. k# N) ]8 \' ^' {5 T& |' bCR X-30.484 Y84.347 R5. DR- F840.# j1 | J/ Y& Y2 V7 N
- F w) t0 s) A) @; fCR X-31.061 Y80.989 R15.702 DR+ F1200.
- x7 P! i: P) `6 y% BCR X-31.4 Y75.672 R41.872 DR+
; T; {! B4 O) |' {' \CR X-31.398 Y75.279 R41.872 DR+
$ F8 o* [+ i+ h9 zL Y48.683
- P/ ^2 Z' k z, f9 J( H$ ECR X-32.032 Y46.003 R6. DR- F840.
& O) _) E* h) _4 |- BCR X-32.744 Y44.237 R11.777 DR+ F1200.
: O- h- q5 `" r8 ?: O9 P3 p7 \CR X-32.821 Y43.737 R1.68 DR+ F840.4 Q" w( _( J, l, ~' {/ m
CR X-31.158 Y42.057 R1.68 DR+9 b1 |4 D0 h4 q
L X-30.134 Y42.047+ Q4 F- T9 _9 ?3 V/ \
L X-30.11 F588.
1 Z6 k8 D5 u4 D, T6 ECR X-27.908 Y43.494 R2.4 DR+& r7 _5 S* j% H, M& y0 t3 n0 B
/ O3 \9 |! W5 _! ?1 Y& \$ ?CR X-26.598 Y47.454 R6. DR+ F588.9 A! y2 t- B( L; Y# `0 M
L Y54.054 F840.# d& G8 g6 H& ^# @" W
L Y75.303 F1200.
2 @% C# `$ A* w4 vCR X-26.6 Y75.672 R37.072 DR-
2 [( D6 U/ ~9 V6 m. n$ j% E" ]CR X-26.299 Y80.379 R37.072 DR-6 B: u4 A7 R- @3 A5 J0 a' A
$ r$ N( z6 m) P9 i% x6 ?CR X-25.316 Y84.735 R5. DR+ F840.5 C' @6 m/ z! u6 }9 y
CR X-26.421 Y87.87 R5. DR+0 T o4 N. W/ P" e8 H+ B
L X-27.402 Y89.088 F1200.$ f3 q% i2 J8 W; r2 [
L Z23.249# d2 {0 x* T. l2 ^- Q
L Z24.999 FMAX! h2 e! E+ I6 Y( E
8 l H& R- a) ^) `6 \L Z23. FMAX5 g% S7 P, d9 h9 O) j, X7 d. \
L Z22.5
- U4 S- o' v' @8 U% B5 P9 E8 Q7 RL X-31.95 Y87.8838 P0 a: Z$ D" `* Y& r H# p, w
/ W7 x3 m; k% r" ]1 r; A+ V0 RCR X-30.654 Y83.054 R5. DR-
' t3 j1 J3 }. e4 s/ t' _CR X-31.061 Y80.989 R15.702 DR+ F1200.5 a0 ?' R* K9 f; F5 O) ]
CR X-31.4 Y75.672 R41.87 DR+
( F8 F$ `6 c) T$ v/ I8 @# SCR X-31.398 Y75.279 R41.87 DR+; z: Z3 d% e: e
L Y48.683% ]+ I; V# H, k+ T% s( ^3 P
: E; Q- x% T% q7 MCR X-32.744 Y44.237 R11.778 DR+ F1200.( ~7 F* x+ ?# q% }
CR X-32.821 Y43.737 R1.68 DR+ F840.2 k7 n, H& H9 q3 B7 e
CR X-31.158 Y42.057 R1.68 DR+/ H0 ^8 J& }- {. ]$ Q/ p$ C
L X-30.133 Y42.047# K1 X" w: W+ w
L X-30.11 F588.7 m" D( _" m+ e
9 L% e' u6 E. wCR X-27.467 Y44.347 R6.978 DR- F1200. I+ Z3 ?: c% B8 {0 @; ]- e9 B
% @! |4 e, X; B+ H) kL Y54.054 F840.
4 q- X* d1 \1 Z: bL Y75.303 F1200.
" Q6 p! X# G; ?CR X-26.6 Y75.672 R37.07 DR-
+ r+ ^8 U- ?# H0 J" Z' g* RCR X-26.3 Y80.379 R37.07 DR-/ q8 P1 U/ w5 O
1 [& s# L" k1 d5 U5 u0 vCR X-25.316 Y84.735 R5. DR+ F840.
: t& S, q3 r) u1 sCR X-26.421 Y87.87 R5. DR+
. n9 ^' X- V! `5 {" yL X-27.402 Y89.088 F1200.
. h1 z4 ~# V1 U# N/ M5 C8 o( P0 rL Z23.! _6 `" ~6 O2 y$ J/ @# o3 ]
L Z24.749 FMAX
~ ] b2 q" e# hL X-41.97 Y39.42 FMAX( q `- V. H( Q: N/ w
L Z22.751 FMAX: t+ V. L4 g9 }; Q
L Z22.251
1 P* u: {% {% g @L X-41.01 Y39.777: n7 J% Q2 N1 U# V+ Y$ a
CR X-37.823 Y43.63 R5. DR+ F840.* j3 V) B* b4 V f
L X-37.788 Y43.822 F1200.! j0 Z* B# r4 o, u) c* w
CR X-36.861 Y46.967 R16.578 DR-
/ `, k7 t1 F3 v5 q/ q3 r7 \CR X-36.493 Y48.849 R5. DR+ F840.
" t0 f |, j) T* _1 l0 xCR X-37.547 Y51.919 R5. DR+, ]8 @' ~/ }3 s. V/ n
L X-40.027 Y55.107 F1200.2 W) b0 G3 O6 E! f! \# w6 k h8 u# I) Y
L Z22.751: w8 O4 B, |0 M+ ~1 s- J
L Z24.5 FMAX
' T* i. Y, G7 T6 ~L X-33.146 Y89.079 FMAX
* I! P* x& L7 d! f, f! OL Z22.751 FMAX
& F# z/ G6 K3 E& yL Z22.2512 Q {1 i0 [! B* i
L X-31.95 Y87.883
( P4 R/ ?" c$ oCR X-30.484 Y84.347 R5. DR- F840.) [3 r! U a' Z3 t) p7 `. }
" ~' A6 F: p; y4 X- W! PCR X-31.061 Y80.989 R15.701 DR+ F1200.% z" [4 _# Z+ `) a# L
CR X-31.4 Y75.672 R41.869 DR+
( y" E0 z5 O P& dCR X-31.398 Y75.279 R41.869 DR+ H) h3 [& i1 | ~
L Y48.683+ W9 a6 B& a+ l1 v/ t4 d3 R/ ~
0 u1 ^7 y2 W) M+ L/ F5 W3 VCR X-32.744 Y44.237 R11.778 DR+ F1200.5 ]$ ]. D; D3 ~: r- o k3 p
CR X-32.821 Y43.737 R1.68 DR+ F840.0 r$ h; t) v" m1 F
' U7 w+ n1 U9 V+ @6 B+ l( Y- R8 tL X-30.134 Y42.047
@5 }7 b0 A) u6 z* ZL X-30.11 F588.
' D2 ~! X. r; m) ^$ ?6 ^4 u, ]: ~CR X-27.908 Y43.494 R2.4 DR+* E8 @ H3 i& d2 l, F
/ v: w4 ^- [$ n) d, ~, gCR X-26.598 Y47.454 R6. DR+ F588.
- f" d7 V+ V0 dL Y54.054 F840.
0 M" h+ C- P3 ]' [2 }; AL Y75.303 F1200.3 g/ C% a% }" y1 \3 A, w! }8 p
CR X-26.6 Y75.672 R37.069 DR-' f# z6 i9 M3 `: F' G' M4 ]
CR X-26.3 Y80.379 R37.069 DR-% M( q2 P9 i( X. m% C6 s8 q; v
CR X-25.653 Y82.93 R10.901 DR-
4 |$ a( g9 C, x. b7 _& d7 ^CR X-25.316 Y84.735 R5. DR+ F840.
5 W! Z# ` v' `- rCR X-26.421 Y87.87 R5. DR+0 U4 Y' G7 `8 }' z9 ^
L X-27.402 Y89.088 F1200. l) N% k8 ]0 i0 o4 l6 U
L Z22.751+ e& N9 D( w( e! A3 w
L Z24.5 FMAX+ w' s2 I; i; s5 A0 [
L X-42.928 Y39.008 FMAX
5 y2 {, ]" T6 F* O) r* w2 TL Z22.502 FMAX! l+ J' I4 W2 s5 {& |& L2 w
L Z22.0022 v+ i' P1 M: z) X, O
L X-40.5 Y37.82
" b5 ^, A Y7 h. n; pCR X-37.957 Y42.125 R5. DR+ F840.7 `# X5 l& `6 x: n9 B
CR X-37.788 Y43.822 R9.6 DR- F1200.
0 s9 W. x, n/ gCR X-36.697 Y47.356 R16.578 DR-
0 ?) t# n) A) d aCR X-36.198 Y49.745 R6. DR+ F840.
) {8 d+ k, r. N% iL Y49.913 F1200.
. G, k$ F9 q' Z& d% O8 I7 Q7 [& ECR X-38.698 Y54.243 R5. DR+ F840.5 ~5 ^# P' F$ P
L X-41.178 Y55.675 F1200.: M+ n# |. g: V* T: v8 l
L Z22.502+ `+ d% t9 U# X' N* o! M: U
L Z24.251 FMAX- L8 S' K8 m( ` g8 W& o
L X-41.919 Y50.04 FMAX
5 F- A. p9 f0 Q1 aL Z22.502 FMAX
" O% h+ I& d4 F9 W. [4 Z, eL Z22.0024 M+ \' z0 M+ Z; d) B% [. @
L X-38.698 Y51.899
' V1 A" L Q1 x% XCR X-36.198 Y56.23 R5. DR+ F840.4 u# s h0 {+ B c0 `+ l e
L Y75.258 F1200.
2 m+ y) D$ [2 S: R& [: @CR X-36.2 Y75.673 R46.667 DR-
% s" P; l8 f+ _4 s2 V. C7 _CR X-35.9 Y80.954 R46.667 DR-
, g$ p' a% \% b; KCR X-33.515 Y83.082 R2.4 DR- F840.
* a l o' o' aL X-33.492
* u3 w; C( g4 @; _L X-32.955 Y83.077
) `* R6 d6 Y! n3 c( G3 T3 ^CR X-31.055 Y81.157 R1.92 DR- F588.' a2 A. }$ h4 u$ I$ Q! o
CR X-31.07 Y80.917 R1.92 DR-
# O2 i n$ Z$ \CR X-31.4 Y75.673 R41.867 DR+ F1200.
' l3 c9 z; ]. s' U F! D9 UCR X-31.398 Y75.279 R41.867 DR+
; g @% w+ X, i/ j. o% [L Y48.6831 E/ j. S2 T; Q$ } |
CR X-32.032 Y46.003 R6. DR- F840.( _( r" D/ L/ p. ]3 |# f' c) G
CR X-32.744 Y44.237 R11.778 DR+ F1200.( {3 _, Y( N1 N. e# R
CR X-32.821 Y43.737 R1.68 DR+ F840.* p0 q$ @8 a4 y( D/ v z r; B6 J
CR X-31.158 Y42.057 R1.68 DR+1 ^0 _2 B7 |9 @/ D- H6 B
L X-30.134 Y42.047
, ^" f: ~0 `; QL X-30.11 F588.
9 Z% ]9 \" h- ^, J( m( RCR X-27.908 Y43.494 R2.4 DR+
& R Z. P% v! W/ s& g+ J" C$ t. e5 NCR X-27.467 Y44.347 R6.978 DR- F1200.
9 O9 Z+ j% Q! h: j* U! UCR X-26.598 Y47.454 R6. DR+ F588.
/ S% b1 G( I* l; {3 t$ V( O, _L Y54.054 F840.) z' ]' i! k5 X" h- U
L Y75.303 F1200.
, L2 A+ g( a9 J+ UCR X-26.6 Y75.673 R37.067 DR- ?, A! E% G9 n) P. w3 |
CR X-26.3 Y80.379 R37.067 DR-
! @' P; i/ S3 S5 lCR X-25.653 Y82.93 R10.901 DR-
8 Y+ P. b8 x0 H6 v. j: j$ I! V. k+ ~CR X-25.316 Y84.735 R5. DR+ F840.
" j' C$ O' l& kCR X-26.421 Y87.87 R5. DR+
* `- u' S3 u1 a8 {9 M; a q: W' _: nL X-27.402 Y89.088 F1200.
9 A9 f1 w6 K: u9 Y( ?L Z22.5029 d8 w0 `/ e: P" J
L Z24.251 FMAX
" Y: W+ b: {0 q6 J1 Y/ vL X-44.428 Y38.971 FMAX0 H4 z i1 ^, E+ o k ^% Q5 |( k+ A
L Z22.253 FMAX) O% j5 j) e; W0 V+ O( H6 L
L Z21.753
; J4 F4 \0 v8 c2 O- v; HL X-40.5 Y37.82
0 M( B+ R; m) v) k! SCR X-37.957 Y42.125 R5. DR+ F840.9 b# M) Z5 W) ]; U4 e, M" g
% }) q/ [% U) u5 {6 yCR X-36.697 Y47.356 R16.579 DR-) U" q* ?: {) d3 e
CR X-36.198 Y49.745 R6. DR+ F840.. s* O8 c9 M, J
L Y75.257 F1200.
1 @# Q* J# `$ @& PCR X-36.2 Y75.673 R46.665 DR-* R: X* a2 O: I, H! X
CR X-35.9 Y80.954 R46.665 DR- ~0 V& a: ~4 x2 y6 u* Q
2 `5 p p7 s7 \$ ]2 v" W& t9 ~L X-33.492+ m5 x! \: [* q; i# u! G8 E
L X-32.955 Y83.077) @+ Z; d& W. U! u+ h4 M
9 c1 o. a5 |. d* i8 \8 r7 c4 QCR X-31.07 Y80.917 R1.92 DR-
$ v0 `% ^. o2 l7 _9 ?5 LCR X-31.4 Y75.673 R41.865 DR+ F1200.+ `3 E8 u9 T/ Y& G
CR X-31.398 Y75.279 R41.865 DR+# f8 W: ?* v' o/ Z9 D7 S
L Y48.682
9 p* f9 B/ E* I- B8 uCR X-32.032 Y46.003 R6. DR- F840.! u% f3 S3 K8 C4 w: c# U" F, z+ M1 p- [
CR X-32.744 Y44.237 R11.779 DR+ F1200.
+ a( o- ^# I' C' Z/ ?- b$ }CR X-32.821 Y43.737 R1.68 DR+ F840.4 v j, l1 o9 g \/ G9 I( C
CR X-31.158 Y42.057 R1.68 DR+- j9 n: f5 A( M% |. N7 o
L X-30.134 Y42.0479 L$ G% Q& o _9 q
L X-30.11 F588.
7 v% h4 q6 m- z7 K4 T+ E& ECR X-27.908 Y43.494 R2.4 DR+
7 j+ Q7 z1 v* ~$ K z; BCR X-27.467 Y44.347 R6.979 DR- F1200.
5 Y; T- v. a" hCR X-26.598 Y47.454 R6. DR+ F588.$ c5 s# |# n( ^! K6 `- Y2 j& Q$ |
L Y54.054 F840.
$ w2 V/ i: v0 ML Y75.303 F1200.8 b, D7 j0 Y0 e% i
CR X-26.6 Y75.673 R37.065 DR-
* s0 y. e; Q' E2 _# c! u+ nCR X-26.3 Y80.379 R37.065 DR-
; A6 ^( F1 F( a) |' \CR X-25.653 Y82.93 R10.901 DR-
2 m& U# r5 W% z2 l' MCR X-25.316 Y84.735 R5. DR+ F840.
! b `! z: @5 j6 z8 Y# bCR X-26.422 Y87.87 R5. DR+
# W1 j% L }) cL X-27.402 Y89.088 F1200.
0 _2 d& a% y& f2 ?' |1 y& G% T6 IL Z22.253
5 s" ^8 t# n. J8 W) q/ UL Z24.002 FMAX* |% \; m/ O# k. d, y. P' X) N8 _
L X-79.676 Y49.101 FMAX
* A; A5 q4 @ j7 l2 l- KL Z22.004 FMAX6 T5 D" ]. ?$ S( X' u, _+ [" h8 W
L Z21.504$ H1 l. h9 n' o; V" r1 a" n
L X-78.476 Y49.4680 K' W; k6 L& s. i9 z" ?
CR X-75.064 Y53.122 R5. DR+ F840.# Z4 G; A4 L; g2 Y$ L+ ]
CR X-74.598 Y54.987 R54.979 DR- F1200.! f0 o. r# t& q" u
L Y72.646
% W/ B& q# v4 x8 n, u2 w6 r+ `CR X-74.213 Y73.949 R2.4 DR- F840.
9 v$ S3 g# c8 e' L% s) p$ NCR X-71.429 Y77.378 R20.5 DR- F650.5 w- a6 x" L: u& u% j& F+ x
CR X-70.753 Y77.655 R.96 DR- F588.6 o- k8 y: L, N. {2 G! @
CR X-69.793 Y76.695 R.96 DR- l# @. G$ c5 f3 L1 O
L Y76.6846 B4 X* j& q/ m# |6 i* u& o
CR X-69.8 Y75.673 R80.263 DR+ F1200.
7 Z" K7 w; v' ?) UCR X-69.798 Y75.128 R80.263 DR+
4 s% X8 R, D! V9 }" J' [1 lL Y54.339
n Q; X5 ^5 P; wCR X-70.797 Y50.097 R50.179 DR+
+ _0 M. ]" r$ H9 jCR X-70.941 Y49.303 R43.2 DR+7 R5 I3 M* F0 T5 u6 T
CR X-70.975 Y48.899 R2.4 DR+ F840.9 M- ^# @" p4 T2 ?8 s4 s
CR X-70.11 Y47.055 R2.4 DR+
4 r% `$ d* r, g) V! _1 dCR X-69.701 Y46.723 R20.5 DR+ F650.* P3 Z+ M- K" j6 L, T2 j" y/ N
CR X-68.686 Y45.972 R20.529 DR+
) e. W" W4 X3 S, MCR X-67.866 Y45.716 R1.44 DR+ F588.
2 l% ^9 }5 l1 {. L5 ], ZCR X-66.438 Y46.97 R1.44 DR+
8 R, L V# r7 Q7 k( n# k2 `- VCR X-66.082 Y49.2 R38.4 DR- F1200.3 J5 `$ b, f2 k( }! s
CR X-64.998 Y53.658 R45.379 DR-
) g/ f4 ~- ^* ?5 h0 Q( b% pL Y57.083
" e0 l; k2 K! K# J' n, iCR X-64.518 Y57.563 R.48 DR- F840.
$ k7 U3 |5 a U4 J6 H7 P& WCR X-64.127 Y57.362 R.48 DR-
5 |1 P/ Z8 N- J3 ?: q4 OCR X-61.495 Y54.933 R8.759 DR+
. K# }! M2 I( K- x/ wCR X-60.328 Y52.874 R2.4 DR- F588.
6 i, f4 s% l* m/ [- JCR X-60.425 Y52.196 R2.4 DR-
: j/ Z6 g* M! d6 N/ fCR X-61.366 Y48.304 R40.579 DR+ F1200.! @+ p5 }* O5 A3 F- q5 Y) R5 J
CR X-61.817 Y45.098 R33.6 DR+
4 S1 S# O* {) [% e WCR X-61.827 Y44.879 R2.4 DR+ F588., X- Z7 W% E& b3 v+ V% D
CR X-59.749 Y42.501 R2.4 DR+
' V# c c, T+ c, `. A: jCR X-59.47 Y42.465 R20.529 DR+ F650.
8 J3 A9 i. f+ B7 WCR X-59.21 Y42.449 R2.16 DR+ F588./ a7 ~! x: ^4 n, l3 ?, w( a2 }& L
CR X-57.057 Y44.429 R2.16 DR+6 c1 P: ^ b5 ?2 Z1 J
CR X-56.651 Y47.408 R28.8 DR- F1200.
! ~- D/ ]4 e r/ E9 |0 cCR X-55.398 Y52.177 R35.779 DR-
7 M( k9 C( i- l# l$ l1 FCR X-53.862 Y54.27 R2.4 DR- F840.
9 h+ I) y" E5 j! T9 j. \- ~4 j$ FCR X-52.095 Y55.19 R8.759 DR+7 f% R1 T; J+ z+ Y$ C
CR X-51.558 Y55.354 R.96 DR- F588.
l- ?0 R; h9 e6 s% OCR X-50.598 Y54.395 R.96 DR-
N' r) K! V7 L' `L Y51.358 F1200.
4 ^; r! o, \6 q; BCR X-51.935 Y46.511 R30.979 DR+" ]% {( O: c$ `* j
CR X-52.356 Y42.268 R24. DR+8 O* C' q' }7 i9 X$ @
CR X-54.899 Y37.963 R5. DR- F840.
9 R4 S" o. u' {8 I5 L' D$ T# aL X-57.798 Y36.327 F1200.8 d8 `1 d! O& b1 B
L Z22.004
# k- d/ \4 ~, Y4 J) a# y( jL Z23.753 FMAX" K* Z. D3 f8 }
L X-60.692 Y61.77 FMAX# i/ |$ e! T* Q5 U" D& J- D" \
L Z22.004 FMAX, X2 C7 V8 F0 [( M% Q
L Z21.504
3 K; _0 ]$ d$ ?+ T, eL X-67.498 Y60.746
: S! G. h2 S* ]8 p# {$ [( f2 NCR X-64.998 Y65.076 R5. DR+ F840.9 P3 Q& l$ `1 l. Q6 t0 E
L Y75.145 F1200.7 R. b; {) ]+ d5 Q0 r- `
CR X-65. Y75.673 R75.463 DR-
8 t& q4 \ p( R: G8 P3 QCR X-64.863 Y80.214 R75.463 DR-
; E* K1 d( Q O9 L4 u8 O; J: sCR X-63.192 Y82.358 R2.4 DR- F840.0 G6 a6 Q0 X P" x: ?+ r3 |# G
CR X-62.097 Y82.671 R20.56 DR- F650.0 F( B: [$ d4 J7 c# m9 `
CR X-61.68 Y82.723 R1.68 DR- F588.2 A4 i0 r0 Z* H1 w, ~0 b) T( k- i' s
CR X-60. Y81.043 R1.68 DR-7 Z. D: g% g# X
L X-60.005 Y80.919
2 o2 q0 N4 e+ i6 G: v% ^CR X-60.2 Y75.673 R70.663 DR+ F1200.9 c& I! I; C8 r' a
CR X-60.198 Y75.162 R70.663 DR+
* z* s1 @" d1 Q) {L Y71.183
: ?6 G m6 W6 C! j% I5 dCR X-58.518 Y69.503 R1.68 DR+ F588.* z5 ~$ |6 @4 t& ~
CR X-58.268 Y69.521 R1.68 DR+
, N+ h, \, ^4 L1 |) QCR X-57.441 Y69.606 R8.694 DR- F840.% h2 \6 _: }& V: z# F# H
CR X-55.398 Y71.762 R2.16 DR+ F588.6 ~/ e/ i6 W" D# S3 K
L Y75.179 F1200.& N1 Z) J% o: A8 l. i# ]$ t
CR X-55.4 Y75.673 R65.863 DR-: m) ^7 K$ ? S2 ~3 H
CR X-55.178 Y81.071 R65.863 DR-
4 m: ~4 {8 l% [CR X-52.786 Y83.274 R2.4 DR- F588.3 j P1 U8 o# Z2 U8 e& x
L X-52.7622 L9 T7 ?: \5 ~
L X-52.503 Y83.271 F840.: N4 G* l1 t7 [+ _8 |) o3 V
CR X-50.365 Y81.111 R2.16 DR- F588., H( q; N2 Z4 g8 D7 z& T
L X-50.373 Y80.926% Y7 `* z, ^3 W8 j. N; ? f
CR X-50.6 Y75.673 R61.063 DR+ F1200.
8 n$ I; @! a* [& n" V! d# B3 h/ z% HCR X-50.598 Y75.198 R61.063 DR+
y! }" Q: Q8 d7 [L Y66.837/ I6 N }' l+ G8 G2 o& a
CR X-53.098 Y62.507 R5. DR- F840.+ n5 u) j, [- Y' X# E6 B
L X-53.527 Y62.259 F1200.
2 M6 y, s4 S! U8 C9 ]2 X9 ^L Z22.004. J: ^/ P9 |& M0 n* C
L Z23.753 FMAX
4 @1 Q# z. ?: _! ?/ k) i9 J, nL X-53.008 Y36.274 FMAX
1 O' W: |/ l8 U: V- YL Z22.004 FMAX% W+ Q/ n" l6 G, m0 I3 J5 j
L Z21.5045 y# n: T8 J$ h0 K' m2 d5 l
L X-50.099 Y37.915
- {* |8 z# X0 w: vCR X-47.556 Y42.22 R5. DR+ F840.: V! B! h& Z' E" p) M e
CR X-47.219 Y45.615 R19.2 DR- F1200.
$ E( @2 v7 m" X2 g Y- Q/ Y4 I% C4 TCR X-45.88 Y50.266 R26.179 DR-6 r x( L3 _! [/ C
CR X-45.798 Y50.698 R1.2 DR+ F840.
8 C1 B# y1 v4 y) p& i/ s' s XL Y75.217 F1200.
: X2 r- d/ ^1 }* D: p/ m; zCR X-45.8 Y75.673 R56.263 DR-
! G, L2 ^8 d+ P; A4 LCR X-45.546 Y81.006 R56.263 DR-4 c# ^! o$ ]* }$ y i
CR X-43.157 Y83.178 R2.4 DR- F840.
% N7 K& T, B# v. u- C% F& N# R5 q% a+ ?L X-43.134) H& o- K1 ~' B1 B2 M# @
L X-42.608 Y83.173
g7 L4 H) K6 P( a LCR X-40.707 Y81.253 R1.92 DR- F588.
/ t5 m ~. c" `CR X-40.718 Y81.053 R1.92 DR-
- ?2 H6 M4 X" oCR X-41. Y75.673 R51.463 DR+ F1200.
+ y# Y/ H6 }/ D( C: ^CR X-40.998 Y75.237 R51.463 DR+. G# ?/ n1 |% H* i
L Y50.6958 W2 M( T3 W) _. k6 C+ b4 r2 i
CR X-41.409 Y48.52 R6. DR- F840.
5 ?5 S% b" \ a. o+ q* R3 P3 ECR X-42.504 Y44.718 R21.379 DR+ F1200., L+ s6 V' d9 Z1 ?1 f
CR X-42.563 Y44.385 R14.4 DR+! N- E: ?7 {, ?6 a* L! Y- a
CR X-42.589 Y44.072 R1.92 DR+ F840.8 b9 ?' G+ P& F8 N7 ^( y3 m
CR X-40.688 Y42.152 R1.92 DR+
- i; ^' q$ X- f4 D, R8 O; mL X-40.115 Y42.146
4 X7 I7 t; [8 q1 W7 YL X-40.092 F588.4 U$ g& [$ x7 Z* S& E) q( `' [- w
CR X-37.741 Y44.062 R2.4 DR+, |# ^5 _- z, D- q r) h* q
CR X-36.697 Y47.356 R16.579 DR- F1200.% [3 B$ x. e- X. z3 L; F) R2 l
+ }3 X: X0 \& k$ m4 w# L. zL Y75.257 F1200.
5 p# z F. x) A2 `2 w" v6 l" pCR X-36.2 Y75.673 R46.663 DR-
" M5 J3 T0 }. [' q% {, x1 Z; J4 e; r" \CR X-35.9 Y80.954 R46.663 DR-
7 O* W- E' T( v5 p& ]& hCR X-33.515 Y83.082 R2.4 DR- F840.
6 R9 }* ?$ K: s8 WL X-33.492
2 y/ ]+ x2 p$ P/ i( qL X-32.955 Y83.077
2 r5 B1 {! {+ Q# \1 q) MCR X-31.055 Y81.157 R1.92 DR- F588.9 s A# K4 ^$ h0 a+ l; b' s
1 O+ E! z* m a) nCR X-31.4 Y75.673 R41.863 DR+ F1200.
( S. [; g* s3 f: \4 BCR X-31.398 Y75.279 R41.863 DR+
, M {0 _% U9 { `7 O C# UL Y48.682
( |5 u+ F* U; X% fCR X-32.032 Y46.003 R6. DR- F840.( X; M+ c2 z% G
% C8 F3 n) Q" c* m" {2 nCR X-32.821 Y43.737 R1.68 DR+ F840.3 C0 ?) p5 M _: W- `6 N2 X
CR X-31.158 Y42.057 R1.68 DR+" u. L. C! B1 j
L X-30.134 Y42.0475 ~0 I* r$ ~% D: h
L X-30.11 F588.9 B0 X5 y$ d! R9 u) C$ b. ?
CR X-27.908 Y43.494 R2.4 DR+ U! [: @. z* T% y! R3 P, Q! g
CR X-27.467 Y44.347 R6.979 DR- F1200.- q6 X4 g( v! v
CR X-26.598 Y47.453 R6. DR+ F588.3 q1 a! Y& g1 E3 L1 H: u
L Y54.053 F840.: N: ?8 M' M& A' p% P. b
L Y75.303 F1200.
( b! b; u" U" w/ Y0 h N5 OCR X-26.6 Y75.673 R37.063 DR-# ]$ Z: B# G; E: d
CR X-26.3 Y80.38 R37.063 DR-
3 G/ [8 B: A( f3 q: x4 KCR X-25.653 Y82.93 R10.901 DR-
/ ?4 f8 D0 z8 H: b! P, O, `CR X-25.316 Y84.735 R5. DR+ F840.# e* q6 _- y5 s1 b! ?
CR X-26.422 Y87.871 R5. DR+. D% R X& v: H- U/ C
' F8 ?2 n7 L( i0 OL Z22.004
% l+ n# n( H$ r5 QL Z55.175 FMAX
" B2 v3 @: G: J: j8 gCYCL DEF 19.0 WORKING PLANE
! A, _' l, O3 tCYCL DEF 19.1 A0.0 C0.0
+ `+ I7 d! H; G; N) ^M140 MB MAX
& M: v3 s- }5 }CYCL DEF 7.0 DATUM SHIFT0 l1 a+ ~9 ?1 v
CYCL DEF 7.1 X0.0
! C# L; A" K, ~2 [" B& }9 X! RCYCL DEF 7.2 Y0.0
: f" J& r4 T( z7 F( r) k. rCYCL DEF 7.3 Z0.0- V0 ?# `2 B; O, V
CYCL DEF 32.0 TOLERANCE
% F' R' K$ H/ M* w, H/ O$ ^CYCL DEF 32.1; ~* t; y' `' Q# b; w
CYCL DEF 32.2
+ u% u/ H. G! }9 W7 M# ]$ }$ E5 ^9 W- dM5, R, u+ ]# b" e* N+ `% a
M95 ]! {5 P, x: ]! m Z6 l m0 W$ w z
M30
6 U2 Y4 Q. B" w: [, b;*(Total Machine Time:4.54 Min)& O/ Y3 {: r! |+ D, p
END PGM s MM |
