查看: 10325|回复: 13
[讨论] Block Styler
发表于 2011-3-20 22:07 | 显示全部楼层 |阅读模式
* X' S! n5 x  r7 c6 M8 j$ T! {6 i' I5 M1 \1 ]/ b, \- L( M9 ~
请问有谁有关于Block Styler的开发使用资料或者视频等,还请各位多多帮忙,我刚刚开始接触不怎么懂。感谢好心人发至我的邮箱15052452544@qq.com,已解决我燃眉之急谢谢
发表于 2011-3-21 10:08 | 显示全部楼层
你的邮箱账号不正确吧  发布过去!
0 O' P2 z) k2 x7 Y呵呵
发表于 2011-3-22 12:02 | 显示全部楼层
NX自带的,可以学到点东西了
  1. #include "ColoredBlock.hpp"- H4 r. D* ]" v* y& k% _  R( }
  2. using namespace NXOpen;9 H9 T2 ~; G, R" T
  3. using namespace NXOpen::BlockStyler;
    $ L0 x: A8 G1 _) ^" Z' E
  4. , V" O, i8 t  H& t, E4 S
  5. //------------------------------------------------------------------------------" }9 M2 ^1 Q! ]9 [1 U" \1 e2 U  V
  6. // Initialize static variables! h, }$ g$ I, J/ T
  7. //------------------------------------------------------------------------------4 x3 l: r4 p# V- W
  8. Session *(ColoredBlock::theSession) = NULL;
    7 A2 O' }5 c4 ^8 T7 R4 i* B
  9. UI *(ColoredBlock::theUI) = NULL;
    + a7 v6 `( H0 Z- {
  10. * Y' s& W9 i. `# Z/ W
  11. //------------------------------------------------------------------------------
    4 }! L1 B6 F1 D1 f6 Q6 ?
  12. // Declaration of global variables9 l4 T+ Z2 H9 D' o" M& @: y
  13. //------------------------------------------------------------------------------: b$ @1 G+ k' r) Z$ o
  14. ColoredBlock *theColoredBlock;7 U! {$ N/ G/ }# x- r9 n* |+ B; U
  15. //------------------------------------------------------------------------------6 ~5 F3 ~/ ~& y! t, H
  16. // Constructor for NX Styler class
    7 {% F- b# ~* ~( Y! N
  17. //------------------------------------------------------------------------------
    6 J3 l2 S- |2 e" {& \1 }+ i; G) y
  18. ColoredBlock::ColoredBlock()9 O6 T* m% |( _, S1 }; O
  19. {2 V1 Y; r+ ~) {$ m% X( |) Q
  20.     try2 M' k0 s, D8 ~
  21.     {
    - l' v) H; F' L+ u: U! T2 L: E
  22.         // Initialize the NX Open C++ API environment: j2 O1 b0 _$ |; R& e! K
  23.         theSession = NXOpen::Session::GetSession();$ R4 Z1 b2 o  N; i" r
  24.         ColoredBlock::theUI = UI::GetUI();& G( e. i( M' y# K
  25.         theDialogName = "ColoredBlock.dlx";
    ; r. Q) ~& z! f/ `& L: w) {
  26.         theDialog = ColoredBlock::theUI->CreateDialog(theDialogName.c_str());
    4 [; ^1 C+ R; _
  27.         // Registration of callback functions" J* t  C, l6 S1 @0 h# x- A/ a. r9 W
  28.         theDialog->AddApplyHandler(make_callback(this, &ColoredBlock::apply_cb));7 c2 i. z8 p8 P  S4 J6 x
  29.         theDialog->AddInitializeHandler(make_callback(this, &ColoredBlock::initialize_cb));0 U0 F6 E7 x; T- t1 G+ {2 v
  30.         theDialog->AddDialogShownHandler(make_callback(this, &ColoredBlock::dialogShown_cb));2 d& C5 H5 \& K) [
  31.     }
    5 w/ C" m' G, z
  32.     catch(exception& ex)
    # U) K( ?  ~* a# U' n- G6 O; R: K$ H
  33.     {. }( F3 G  d; T- d6 V
  34.         //---- Enter your exception handling code here -----) `$ J5 I0 }8 Q& t
  35.         throw ex;$ b5 Z; Y+ Q' u: @
  36.     }+ v% q9 {! L: \
  37. }
    , W  p' G0 q3 ~+ H5 e' z
  38. ' T: E$ H4 F& V: D/ G  w
  39. //------------------------------------------------------------------------------
    0 h: |1 K7 V% x
  40. // Destructor for NX Styler class3 H4 I- \/ h. h) ?, ]( r& b# Q
  41. //------------------------------------------------------------------------------
    2 a6 T7 o6 K( e: a5 |
  42. ColoredBlock::~ColoredBlock()
    $ T- t2 q" V3 p
  43. {0 k+ D$ X. S* a3 t4 o
  44.     if (theDialog != NULL)9 ^7 ]8 Z. w" T5 Q0 s8 \6 ^0 z
  45.     {
    ; p- i- A& q! r: O
  46.         delete theDialog;
    2 X2 l( W# O8 ~+ f
  47.         theDialog = NULL;/ T1 _( `6 r/ f" K* N+ o, |( K
  48.     }' m) m0 N: {/ w) `, R2 `  t
  49. }. D2 Q+ m* {* ]1 @& V) f* z
  50. //------------------------------- DIALOG LAUNCHING ---------------------------------
    2 |$ \2 C% J$ r) o2 ]' y
  51. //
    : K  j! ]/ q" Z9 [$ ]' m" r
  52. //    Before invoking this application one needs to open any part/empty part in NX% g/ x3 v" \3 Y/ p
  53. //    because of the behavior of the blocks.8 {9 Z! {; Z$ B
  54. //
    5 f/ d, L. K9 @" y  ^# F
  55. //    Make sure the dlx file is in one of the following locations:# E3 a7 ~: }9 j% P% s+ U' P
  56. //        1.) From where NX session is launched
    # a4 N& B: l, C6 a( u1 u
  57. //        2.) $UGII_USER_DIR/application4 v$ X! x! `  c
  58. //        3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
    * `5 `4 B/ w0 b7 w) P4 ^8 }
  59. //            recommended. This variable is set to a full directory path to a file ) ^( Q4 B% U" h3 Z$ v$ V
  60. //            containing a list of root directories for all custom applications.$ a& l* H1 {1 x" K, e6 J! ]. S' I; c* Q
  61. //            e.g., UGII_CUSTOM_DIRECTORY_FILE=<NX install directory>\ugii\menus\custom_dirs.dat
    7 l- J0 W/ d- d
  62. //8 _9 E; ?" \2 o' r$ S) \
  63. //    You can create the dialog using one of the following way:
    - m6 k, J1 r/ S6 W' Q1 V2 G
  64. //
    0 _, M$ i+ i' d# z; m4 e0 }9 v
  65. //    1. USER EXIT
    & D  h& i" C& F. c2 S
  66. //( f, p& T9 f8 \* p
  67. //        1) Create the Shared Library -- Refer "Block Styler programmer's guide"+ V* X* K9 J% ^" k. i2 b. F/ ]
  68. //        2) Invoke the Shared Library through File->Execute->NX Open menu.
    ! {2 ^& G  g4 o! n% |  y
  69. //
    2 i/ K4 h' u% e# ^  V  Q
  70. //------------------------------------------------------------------------------
      u" j0 ~' A+ J: m
  71. extern "C" DllExport void  ufusr(char *param, int *retcod, int param_len)/ t  S3 x5 f% W1 D  U: L
  72. {
    * Z% p, F; y6 A* K' Q) L, Z
  73.     try
    5 s: ?) d, C+ i: h
  74.     {- S+ x/ i% G& m" E4 ]# G0 z$ U: `
  75.         theColoredBlock = new ColoredBlock();
      Q& a9 Z0 n- z1 U3 m
  76.         // The following method shows the dialog immediately' F- |" s( g  {6 H4 a% |2 Y0 @
  77.         theColoredBlock->Show();# U" k5 M7 R, c# R
  78.     }
    % ^( h' B; z* ^6 o
  79.     catch(exception& ex)( w( a" M7 i4 u* O  {) B
  80.     {5 f+ x( f# y( H6 ?- r* H
  81.         //---- Enter your exception handling code here -----  I8 Y& e' W5 W. l0 F
  82.         ColoredBlock::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());
    % F4 T0 O4 w) A/ W" Q$ [# U! \/ S, Y
  83.     }
    ( l3 s$ r/ n( x5 d
  84.     delete theColoredBlock;
    $ ]2 _4 ]) F8 {5 j1 W; ]. I. E  F
  85. }9 x6 J( a! E. m
  86. ; T* \, m' h. k' e) I
  87. //------------------------------------------------------------------------------$ g5 O5 y! r+ ^- Q. Z1 `" p
  88. // This method specifies how a shared image is unloaded from memory- t9 L0 q4 v, V; p; I6 A: S. W
  89. // within NX. This method gives you the capability to unload an2 [6 Y2 f- O3 f! a
  90. // internal NX Open application or user  exit from NX. Specify any
    ; B* _  T% j+ M# S' j7 A3 [& |
  91. // one of the three constants as a return value to determine the type' @* A+ z( T8 i( G; e; T
  92. // of unload to perform:
    4 _3 T/ v2 ^5 s! u0 q
  93. //
    9 S1 y! w, {; R/ c0 U
  94. //. W; ^& ^* [. \. B3 Z; I  E
  95. //    Immediately : unload the library as soon as the automation program has completed) \9 a2 f# {5 m8 K
  96. //    Explicitly  : unload the library from the "Unload Shared Image" dialog
    % n8 q; y! E1 _7 L* p% E3 y
  97. //    AtTermination : unload the library when the NX session terminates
    ) l/ t  M# m" ?% D+ [
  98. //! Y3 O( M, A" Q2 e0 L% c
  99. //" k3 Y, f' Z1 C# ?8 \( H; F9 m
  100. // NOTE:  A program which associates NX Open applications with the menubar7 a3 p& D  |* G. L5 B! e
  101. // MUST NOT use this option since it will UNLOAD your NX Open application image; m# d! O. D: _
  102. // from the menubar.- \0 z: M0 p( P3 I. ^7 K
  103. //------------------------------------------------------------------------------
    0 `  L* D( F6 O8 ?) x
  104. extern "C" DllExport int ufusr_ask_unload()
    , J6 {- b: {& \% ]) A( B
  105. {5 z" J6 @9 @, H! u! H
  106.     //return (int)Session::LibraryUnloadOptionExplicitly;
    , o8 X& d% _6 y7 J) a0 P8 ~
  107.     return (int)Session::LibraryUnloadOptionImmediately;  D3 v+ W! K# X5 d; @) D
  108.     //return (int)Session::LibraryUnloadOptionAtTermination;
    % ]9 I7 D4 R9 l7 ~& U5 T- {
  109. }
    , t, N, X' m. k$ n* y3 P* B) t$ {
  110. - Z1 h8 D. K+ d0 `( i
  111. //------------------------------------------------------------------------------
    : c' F5 F; {3 Y' U/ y
  112. // Following method cleanup any housekeeping chores that may be needed.
    1 v7 h5 P1 Q0 K, i
  113. // This method is automatically called by NX.
      F; o: N- b' A5 n3 s8 ~
  114. //------------------------------------------------------------------------------6 `" H: }9 Q: q  @
  115. extern "C" DllExport void ufusr_cleanup(void)
    " Q7 A* P, Y8 w$ L8 |
  116. {! @8 D: [: S3 }
  117.     try  h9 [7 E9 \! l; D
  118.     {
    . u( r5 u" w7 _
  119.         //---- Enter your callback code here -----
    & ~  Y* z) T* X9 {) ?
  120.     }
    " g% w; f4 Y( \$ {# Y
  121.     catch(exception& ex)$ d4 s) m( _/ w# z7 y2 X: h
  122.     {
    ; J5 e8 `% G/ H# P% A9 \  W3 H' s, F
  123.         //---- Enter your exception handling code here -----  D7 i9 X3 {1 T2 {" g, z5 [! d
  124.         ColoredBlock::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());1 a' i$ o) _! Z' O
  125.     }
    * F' ]1 i% O; i( c/ k
  126. }/ N! X% X* K% t% J3 `7 n
  127. . X! A/ b8 Z2 M: H8 F- Z8 G6 F
  128. int ColoredBlock::Show()
    2 c$ \3 A/ R8 l6 `" U3 d$ H
  129. {* I. P0 h) K& b' t' i2 ~
  130.     try  M! C4 ?: B+ E) Z
  131.     {
    $ x# d% V3 @0 W% n5 ]) C
  132.         theDialog->Show();1 Z2 t5 o* m; E% [2 K  `8 V% d" l- r
  133.     }* D$ g9 l/ L( J: P, W
  134.     catch(exception& ex)' x5 U) W& f! s. ~3 w: V
  135.     {
    " F7 D3 X& h+ F* Q6 a+ I/ C; X1 f
  136.         //---- Enter your exception handling code here -----$ e& j8 y7 b4 y* J5 B9 B: F4 X9 z
  137.         ColoredBlock::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());
    4 a9 \5 [  ^& M# e; k
  138.     }
    " Z* E" s( w  t6 }2 o7 |8 ^% S
  139.     return 0;
    3 `% Q4 T" i2 [% T! Q/ k
  140. }* L7 V7 n! X+ O9 a' p8 u
  141. 3 ]) n0 s/ I: @; [4 u! ]* N
  142. //------------------------------------------------------------------------------
    3 D- b8 v7 E2 Z- `: ?7 z3 j. J
  143. //---------------------Block Styler Callback Functions--------------------------" x" E% c+ i: |. x& ~7 _" G% u
  144. //------------------------------------------------------------------------------
    # P; H  Y! b* T
  145. 1 u) n4 _$ ]) _
  146. //------------------------------------------------------------------------------
    ) X: `9 Q/ T5 H3 G* u8 z" E
  147. //Callback Name: initialize_cb
    2 a3 v! j# L& ~3 I9 X
  148. //------------------------------------------------------------------------------
    5 E! |% U3 m2 z- r$ e2 S
  149. void ColoredBlock::initialize_cb()
    * l+ p& A5 t' H- g* \3 G
  150. {
    9 E! f4 V1 V) I; T! a) X" _
  151.     try. g4 a  T4 l- W1 o; {" ~3 l
  152.     {. u. g1 K( t. x, R/ T9 ~
  153.         group0 = theDialog->TopBlock()->FindBlock("group0");
    ! k% S- ^6 r) c5 \  [6 z* R
  154.         blockHeight = theDialog->TopBlock()->FindBlock("blockHeight");* O6 ]5 f; ^, l
  155.         blockWidth = theDialog->TopBlock()->FindBlock("blockWidth");
    ' u( x% `- ^7 Z; r0 d/ f
  156.         blockLength = theDialog->TopBlock()->FindBlock("blockLength");) C; ~0 @/ Y8 f
  157.         blockOrigin = theDialog->TopBlock()->FindBlock("blockOrigin");8 u- X1 M; R/ [+ [: z! p
  158.         blockColor = theDialog->TopBlock()->FindBlock("blockColor");
    + O2 @/ Y& P! i0 k# p. j3 I
  159. " u9 a! Y/ n7 J( w
  160.         // Set the upper-limits and lower-limits# `* G& }9 L' d4 E' ~+ Q. e' c
  161.         PropertyList *blockHeightProps = blockHeight->GetProperties();$ _; w( {: c, Q8 g
  162.         blockHeightProps->SetDouble("MaximumValue", 100.0);
    # E+ m7 b. i. A
  163.         blockHeightProps->SetDouble("MinimumValue", 0.001);
    ! ?4 P; r1 Y' G
  164.         delete blockHeightProps;
    % B! k. d2 ?5 C6 x: K
  165.         blockHeightProps = NULL;
    - H- A( _" j0 B7 D2 C# a
  166. / R9 `! B7 ?5 B; Q% G" W/ S4 C% q4 Y
  167.         PropertyList *blockWidthProps = blockWidth->GetProperties();
    ' F" t" H% {, @' |3 k+ E9 Z9 r
  168.         blockWidthProps->SetDouble("MaximumValue", 100.0);6 C- P. j& [# E0 j, j
  169.         blockWidthProps->SetDouble("MinimumValue", 0.001);8 L* Q7 P, [0 K: j7 z9 U/ M4 E' V
  170.         delete blockWidthProps;
    6 b4 w" e- p2 r! ]
  171.         blockWidthProps = NULL;3 W8 m9 n1 b" b; s+ \* C
  172. 7 ?5 g7 K2 m$ C! J& a. u
  173.         PropertyList *blockLengthProps = blockLength->GetProperties();3 ~( m9 S' J2 J0 `" ?/ N) j: U
  174.         blockLengthProps->SetDouble("MaximumValue", 100.0);7 E& I% q7 c" ?0 S9 g
  175.         blockLengthProps->SetDouble("MinimumValue", 0.001);! ^1 Q3 d, A& {" h5 c9 G
  176.         delete blockLengthProps;
    - _+ N5 W$ s' v  e3 n  ?
  177.         blockLengthProps = NULL;
    1 s) S! z; N; A; x8 S: _  s+ Q& o
  178.     }
      b1 x6 d, l& g
  179.     catch(exception& ex)
    / q) z9 a) L, N. L( H
  180.     {# P) ]" x" Y$ K$ o' ?
  181.         //---- Enter your exception handling code here -----
    + R- e! Q- B8 b- I  l; x, u1 f
  182.         ColoredBlock::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());
    + z1 p2 e  R4 [8 ^2 K, d0 `! Z1 y" x
  183.     }7 _+ |0 _0 {7 f7 h! F
  184. }
    ! y' [/ O8 C3 w' T" ?$ [
  185. % X$ }: |* {4 U" S* z- i$ h+ ~
  186. //------------------------------------------------------------------------------
    + \  N5 {& {1 k& `; b# z% a6 P8 M0 H
  187. //Callback Name: dialogShown_cb
    $ n) t+ j& F) E( |! b7 S- p3 i
  188. //This callback is executed just before the dialog launch. Thus any value set
    % ]( d: I1 [! u  V- a! j
  189. //here will take precedence and dialog will be launched showing that value.
    3 Z) S' {2 d+ y+ s4 y+ u& g
  190. //------------------------------------------------------------------------------  ~* s% B' b1 ?% G- G) M
  191. void ColoredBlock::dialogShown_cb()& z0 l# b$ x. O1 |
  192. {
    9 W7 d; A# v- E# w* ]9 a
  193.     try
    * X0 T# a4 J# L) B( E4 ]0 A( E
  194.     {
    3 o) t; h, t& x" O, m
  195.         //---- Enter your callback code here -----
    % ~' X3 I: b: @7 E* l" b
  196.     }* p& q" @4 ?) n7 i  V" v
  197.     catch(exception& ex)$ x+ Y4 y" N: S2 j" [9 Q
  198.     {
    9 h% I5 r9 C  {- b- u
  199.         //---- Enter your exception handling code here -----
    " z- ~/ T  y- P- P' S6 U( A/ g: a
  200.         ColoredBlock::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());- b- G8 R6 j, S0 e. {' m" h9 e
  201.     }
    / C: D2 `% v# I* H$ S
  202. }, a  [# T8 q- r( z- b: i) K
  203. 3 ]. l- ~& G9 ^
  204. //------------------------------------------------------------------------------& k! C  T% U, D& X( p% t
  205. //Callback Name: apply_cb
      i, w4 t) X% v, {0 i8 G
  206. //------------------------------------------------------------------------------# U( G) w1 h' ]9 `$ Y( V  N
  207. int ColoredBlock::apply_cb()
    # t4 c; l7 y9 ^: a+ X: F
  208. {, O; _8 ~+ t, x5 O0 p. F/ ^
  209.     try
    * P! L6 V; C2 ]- I% o, r, b6 K
  210.     {
    ; V6 ]7 {6 F! I* I: Z& g9 F3 v
  211.         Part *workPart(theSession->Parts()->Work());4 P# O+ K- G, e5 R% v6 T
  212. ! Y7 o- C5 Z: y( t
  213.         //Get the values from UI Blocks
    8 ]/ P+ c* v! `
  214.         PropertyList *blockHeightProps = blockHeight->GetProperties();, N7 {5 f" A7 O
  215.         double theHeight = blockHeightProps->GetDouble("Value");
    ) C6 x1 M6 X" }% @7 W( I. j/ z& C1 s! J
  216.         delete blockHeightProps;' S8 y$ J5 @' M% F
  217.         blockHeightProps = NULL;
    ) p# U. H0 l* B1 L& d  c
  218.   j6 z  ~! C  X- ]- K  ?
  219.         // Convert Height in double to std::string
    4 {$ j/ {" ?6 S8 c/ A
  220.         char tmpHeight[32];+ ^/ C8 P$ ]4 d4 q2 d
  221.         sprintf(tmpHeight, "%f", theHeight);
    7 }. R7 R* L+ p! H: s
  222.         std::string convertedHeight(tmpHeight);
    ; j0 H- ~0 O, g! l2 N, u8 C( F
  223. $ r. |" _! F( z$ _/ B- A9 n. y
  224.         PropertyList *blockWidthProps = blockWidth->GetProperties();
    : o, f: [1 r1 q8 W. r0 H/ C2 `9 c
  225.         double theWidth = blockWidthProps->GetDouble("Value");' `; C& r# H* t: _+ I$ Z
  226.         delete blockWidthProps;: l$ _! B; \# g8 \) T. X2 R3 _. C
  227.         blockWidthProps = NULL;. u  R8 Z8 I( f% V2 M9 H
  228. : K4 {( N' [" i/ V+ y% f$ k7 `
  229.         // Convert Width in double to std::string
    & q) f' E" X7 y0 v' E, f
  230.         char tmpWidth[32];
    # |+ K: `& `3 I4 K9 v
  231.         sprintf(tmpWidth, "%f", theWidth);
    6 e. g) L( k7 x% f( M- }
  232.         std::string convertedWidth(tmpWidth);9 c' S/ u' ]$ D" i7 p
  233. / U% K. V! M& X" x8 r; y( u( a
  234.         PropertyList *blockLengthProps = blockLength->GetProperties();! J/ g! _; v! q7 K. c
  235.         double theLength = blockLengthProps->GetDouble("Value");
    2 y% i# B/ A+ |* B1 m
  236.         delete blockLengthProps;
    6 C' W# z9 o3 c! A/ Q
  237.         blockLengthProps = NULL;
    # z5 _6 I4 N+ `+ P, e
  238. ( L* f1 W6 m  X% A+ H; }
  239.         // Convert Length in double to std::string. P# P. C" j( x
  240.         char tmpLength[32];  G5 t4 ~/ q4 n4 Q* |
  241.         sprintf(tmpLength, "%f", theLength);
    $ l  R# w" j! H$ @) V3 v( c! H! D
  242.         std::string convertedLength(tmpLength);
    ) `7 r( F( c* Z' y/ {; A8 E
  243. 9 m- i3 ^: B7 Z. X! ~- j" u: c8 M
  244.         PropertyList *blockOriginProps = blockOrigin->GetProperties();
    , x' L! ~6 J5 P  H6 E' f0 C
  245.         Point3d originPoint = blockOriginProps->GetPoint("Point");! \; [$ v6 ]) O: ]- W4 z: z
  246.         delete blockOriginProps;9 L4 I* f, W/ w8 W
  247.         blockOriginProps = NULL;9 \9 {' s- }! Z( q
  248. 0 V+ _  ~# T5 x4 k* L
  249.         PropertyList *blockColorProps = blockColor->GetProperties();
    " W0 t, s1 }) k# Y
  250.         std::vector<int> color = blockColorProps->GetIntegerVector("Value");
    3 v; G. u0 ?; u; R* E  X" z. I
  251.         delete blockColorProps;9 A5 b6 _9 l3 d6 O% P4 e
  252.         blockColorProps = NULL;
    $ d; e! ]/ {. D' q: T
  253. - z1 b: L3 n! d  q5 U
  254.         //Create the NX block' i4 m# {# e( U& ?. ?
  255.         Features::Feature *nullFeatures_Feature(NULL);
    " m. _" @6 a8 Y4 W5 ^
  256.         Features::BlockFeatureBuilder *blockFeatureBuilder1;  a) t% C5 t! H3 Q3 c
  257.         blockFeatureBuilder1 = workPart->Features()->CreateBlockFeatureBuilder(nullFeatures_Feature);
    6 {& f, [0 Z3 Z4 o1 @8 v3 P! f9 p, u
  258.         Body *nullBody(NULL);
    2 d7 ?) i$ g8 v3 d* u8 u) S) ?1 r
  259.         blockFeatureBuilder1->SetOriginAndLengths(originPoint, convertedHeight, convertedWidth, convertedLength);
    % v/ q3 A( u( v+ t9 T+ P5 w( m
  260.   m4 A& H6 F  \# E% F& q
  261.         blockFeatureBuilder1->SetBooleanOperationAndTarget(Features::Feature::BooleanTypeCreate, nullBody);  f* _. z+ N# E1 ~# n4 h' c6 W
  262. ( K& O5 n8 N7 t6 Z& ~2 Q8 |
  263.         Features::Feature *feature1;
    , Z. G) o; V: J- N( D2 l
  264.         feature1 = blockFeatureBuilder1->CommitFeature();$ w2 d; E7 @" n
  265.         blockFeatureBuilder1->Destroy();
    ' W5 F( o) H0 x) F
  266. 3 i! g6 O* |1 Q- |3 }+ A& D
  267.         // Get the body from Feature4 m6 @( B, a  G& U' R
  268.         Features::BodyFeature* bodyFeat = dynamic_cast<Features::BodyFeature *>(feature1);) f3 F  y6 Z+ O5 G$ v( L' P
  269.         std::vector<NXOpen::Body *> bodies = bodyFeat->GetBodies();# T% c5 Z. p; }$ E. F
  270. 7 m5 B" U5 D. }' T
  271.         // Apply the color to feature body
    . j2 S5 L' l2 u: Y* G) W, J
  272.         DisplayModification *displayModification1;
    + Z" p' f$ @) m; Q) @# l& f
  273.         displayModification1 = theSession->DisplayManager()->NewDisplayModification();
    * _& o" g! Y& b  b& W
  274.         displayModification1->SetApplyToAllFaces(true);( I$ S9 [9 T4 u
  275.         displayModification1->SetNewColor(color[0]);- s9 h5 X9 U1 b3 f3 v
  276. * j0 H3 ]% X8 X0 e
  277.         std::vector<DisplayableObject *> objects1(1);
    . |/ `2 E( e7 D$ j0 ]9 x+ _
  278.         objects1[0] = bodies[0];
    1 U9 {' J3 R: f" R/ t1 u
  279.         displayModification1->Apply(objects1);) Q; X1 I/ J0 K# }4 D, T
  280.         delete displayModification1;
    2 D$ \( i9 d: v) J
  281.     }
    % W2 L7 y/ a" H* N
  282.     catch(exception& ex)
    & a' }! N1 \$ j
  283.     {% A' V- M& T$ K& ~1 ]7 b) W1 P
  284.         //---- Enter your exception handling code here -----
    ) q3 a. \* U" x/ u0 H  [
  285.         ColoredBlock::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox::DialogTypeError, ex.what());# Z& f. E' v. A
  286.     }
    6 B8 P4 `9 c) p, E6 F. _! e
  287.     return 0;6 |1 @# T  }; i1 I
  288. }
    3 Y* l) h$ n  w2 c* ]9 C4 R/ a5 h
复制代码
 楼主| 发表于 2011-3-23 09:35 | 显示全部楼层
回复 2# UG二次开发毕设
' O, L' \3 D6 x( o. }) I8 D' L: v5 B6 U  t6 o0 _
" Y0 q' q# b5 s/ \. Z$ K( G    真是不好意思,当时写的太仓促了,应该是“15052452544@139.com
 楼主| 发表于 2011-3-23 09:37 | 显示全部楼层
回复 3# ghghghghgh # \9 s2 X7 c# K3 _
" `( p; y4 l. K  m! G1 C) G
$ I/ y; y6 m1 ~4 M" D8 P
    收到,谢谢
发表于 2011-7-26 13:15 | 显示全部楼层
楼上兄弟能被资料给我一份么,我只做过UG 对话框,没有做过NX Open Block Style 对话框,现在使用NX Open Block Style 就是在% C+ @7 u9 B. t2 M
25行:       theDialog = ColoredBlock::theUI->CreateDialog(theDialogName.c_str());# ^2 a1 r3 I0 w5 j) V
编译不过,错误信息:error C2059: syntax error : ','        c:\program files (x86)\ugs\nx 6.0\ugopen\nxopen\ui.hxx        1175 |* O: x6 [( A: [0 ]. \
已经郁闷三天了,谢谢了。
发表于 2011-10-16 10:12 | 显示全部楼层
lz资料能不能发给我一份啊?谢谢啦!790896857@qq.com
发表于 2011-10-16 13:54 | 显示全部楼层
我也要份178517495@qq.com
7 C% c+ D# l# x, @9 d( y' d谢谢
发表于 2011-10-27 17:38 | 显示全部楼层
可以给我一份吗?谢谢您啊,呵呵
发表于 2012-10-7 15:55 | 显示全部楼层
高人指点 如何读取  selection0  的selectobjects 属性的内容??
GMT+8, 2025-6-29 00:44 , Processed in 0.210161 second(s), 26 queries .
