楼主参见这个:, a3 Y: w% b3 @8 L1 Y
( I7 x+ J( y K+ J# AUG7.5破解方法:
( q" \1 x% L- K. x0 X# ^
; z* c' n* f" D& n8 LMAGNiTUDE文件夹内的Install文本文档有说明,可能是英文的问题吧,把很多人挡在门外。英文原稿如下:# z* k/ j2 K) `
8 e/ B j+ K9 P8 o3 r' ~) C& `
2 M; n% Y: e3 \9 K1. Install NX7.5 Licensing.) K% g# c. X, I* t9 [8 C
2. When asked for license point to ugs4.lic supplied.
- E' Z) a, b* R3. Go to "Program Files\UGS\UGSLicensing\" and run lmtools.exe.% c3 X$ d3 x U6 f: ?# G7 ]. Z
4. Select "Configuration using Services"
6 n& ^$ ?0 s- Y( U& N$ P5. Select "UGS License Server (ugslmd)" in the list of servers., |9 k4 o# Z& n5 Q. B$ E8 B4 P ?( A
6. Select "Start/Stop/Reread" tab.
" }7 V2 O' V" a: m+ f7. Select "Force Server Shutdown"
_6 I% a L8 }) ]0 A6 L# t8. Press "Stop Server"9 Y2 O0 Z b2 E$ _, i
9. Replace "Program Files\UGS\UGSLicensing\ugslmd.exe" with one from archive ugslmd4.rar.
3 [8 @# h) H( ], g7 v10.Press "Start Server"+ W! Y8 d% R$ z( T9 N- E+ N# x1 J' |
11.Install NX 7.5" a/ |; N$ B& P( [
12.Replace NX 7.5 files with those in archive nx75_32bit.rar or nx75_64bit.rar. Keep in mind paths.$ O7 t1 V- q2 C" p- F6 m
; A+ b* O: E4 k0 t8 M
中文翻译如下:- M. s+ q$ s9 R$ x; M
' [) q: Y0 h2 N8 A( Z9 ^
1. 安装NX7.5 Licensing.(许可证服务器)0 B2 C2 v5 e7 D, l- r$ _3 l. d
7 y- D) F. Q0 ~3 z( h2. 安装过程中提示要许可文件时,请指向破解包MAGNiTUD内的ugs4.lic文件(这个文件不需要像4.0那样要改什么host主机名称,原样不动就OK)" p, V6 z( P& H# g
, i2 i: M+ a( k A7 ?
3. 跑到安装好的UGSLicensing(路径是“Program Files\UGS\UGSLicensing\”——我的是C盘,很多人喜欢装在D盘的就8 X; O; w1 E s4 A
- f4 ~ Z7 P- [" |去D盘找吧)文件夹内运行lmtools.exe. k6 l1 \. b5 K! q
' r D3 X- ?" |; m, ^4. 在许可证服务器界面里选择"Configuration using Services"& C& w8 L0 y) w! B$ c
5 u" J' L8 O; L5. 选择"UGS License Server (ugslmd)"& m, N6 ] a: t$ ?" @. A
/ |- y& P# V5 Q4 s# `: M
6. 再选择"Start/Stop/Reread" 标签. N8 n0 t% t7 N4 A. ?! h! P
! a- f, s* C8 u6 l7. 将"Force Server Shutdown"选上。(这一步很重要,是要强制性关掉许可证服务器,以便为接下来的替换许可证服务
# E# c3 P/ T2 ?2 Q: j& n' I8 y6 s+ O. C
器的文件作准备)
7 y% u8 y$ |: I) A1 A9 F
( e, J/ N- v: N4 Y( C9 Q+ u% c8. 点击"Stop Server" 停掉服务器.: D8 `! ?/ k |4 C
/ k) C/ ]* ?* G \9. 替换这里——"Program Files\UGS\UGSLicensing\ugslmd.exe"的文件. 用压缩包ugslmd4.rar内的文件替换(当然要先
. r4 i7 @% R6 F7 y& [, n0 o$ ^; Y1 A
解压,ugslmd4.rar压缩包在破解文件夹MAGNiTUDE内,里面有两个,根据自己的系统选用32位或64位的。
; ?% Z. W, j \9 {) C8 R M1 |6 y( s
10. 在到许可证服务器介面那里点击"Start Server",开启服务器。- W; H, Y+ E$ `# h8 ^( Q0 @, [, O
5 l5 ^. @! `; Z9 d2 k$ c11. 做好前期的破解工作后,就可以安装NX7.5了# U5 m* o$ W' a% [/ X
3 n2 A) `) c" P& S. C) m
12. 最后还要替换一些文件。把破解文件夹MAGNiTUDE内的nx75_32bit(或者64bit).rar压缩包解压, 然后根据你的安装路, M$ C3 \+ V9 w8 `: {* }
/ x8 O* \+ H0 I' Z' [
径来替换相应的文件。
0 g$ p+ |: x9 O) C# z6 a/ O, i; Q, }1 E
1 i; F$ R; ^5 p" F4 m希望对你有帮助! |
