快速定位平面中心坐标的外挂源代码......
. {1 O+ b3 V/ e1 H9 \/ f2 Q# n" _$ x$ F% ?; ?$ m
很实用,你拿去翻译一下就可以用了........7 X# n/ Q% a7 Q ~( T! j
% w7 n) e2 b$ e/ N0 P, g
. r: W A$ m* V' {$ m==========================
" T% v& J% @. i7 V% z2 D/ H+ G5 C5 F0 C( p1 [3 w( d
entity/fc(3),p(14),cs(4),lll(8) 0 Y4 g: s. ]3 m7 E, d/ H* k
entity/l(2)
" s/ V" w5 N9 a3 | ' Y& r' o7 N# k2 T; N- m$ x
number/norm_pt(3),PI(3),DI(7),dd(7)
+ }8 \# w: G0 ^3 ^* d1 }# Lnumber/mat(12)5 h5 w6 ]3 m7 I6 o
8 [0 }/ D: B/ s. H2 D; e- ~
N20:
+ _0 @& l) _' H$ w0 c5 h# I: U5 D/ ]- _ MASK/71 9 E. W' K5 K+ e, b
IDENT/'选择平面',fc(2),resp
5 X J8 m5 x9 o$ S, W JUMP/pr1:,end:,,resp
5 f- z6 |8 r! J, P- [N30:/ w6 ~6 G/ x5 w3 F% c; P3 \
draw/off $$更新关闭
/ o0 {! C4 q: D# ?; g l(1)=isocrv/fc(2),udir,0.5,toler,0.001
. ]) s- }; |2 y; R8 b l(2)=isocrv/fc(2),vdir,0.5,toler,0.001; K" }* n& [7 X: t7 |
n1=typf(l(1))1 A: j. E- v6 U
n2=typf(l(2))
, @! j) g4 G( t; B delete/l(1),l(2)5 n) r' s' m; b7 s G5 L" i7 H
ifthen/n1==3 and n2==3
( s; A! M* Z8 q4 @ jump/N40:
- I7 D# ?9 ?. O/ G) k. Y else$ D. x+ g+ V' I% A, K& Y9 C4 x- o
jump/pr:
& B/ H" N+ z/ _# S endif 8 G; b' ^: `0 S3 i+ g: ?
( S( D/ a9 t' x* I2 K/ E2 ?N40:
+ r3 p5 G: |! P4 { pI=SPOSF(fc(2),0.5,0.5) $$中心点
, T6 o7 p3 ~. x0 T$ h: X% |: q P(1)=POINT/PI 3 O# D- g" U4 z! I
PI= SPOSF(fc(2),0.7,0.5) $$表面的点
6 C9 |; |6 _; } P(2)=POINT/PI ! b9 m6 c) D$ v* h
PI= SPOSF(fc(2),0.5,0.7) $$表面的点 , d( [# i) f& d
P(3)=POINT/PI ( D( ?+ a. W P4 @) m# y
$$PI= SPOSF(fc(2),0.3,0.5) $$表面的点 + V6 E5 N% e; J# W( y
$$P(5)=POINT/PI : P+ I; O4 P9 x! e
. H, X4 Q3 R+ }6 L* W. O, E4 C di=reldst/p(1),P(2) ( @* i K8 \9 F+ W5 u, ^
dd=reldst/p(1),P(3) ( h: f$ _% T z* b( q, w5 D
ifthen/Dd(7)>DI(7) 8 ]" ^- Q7 z6 m
cs(2) = CSYS/P(1),P(3),P(2) 6 m4 ]+ ?* }7 ?, a( @0 [3 y1 q
; B/ s! m& L! w* H &wcs =cs(2) @) D5 ~9 B: V/ L$ X- G
norm_pt=SNORF(fc(2) ,0.5,0.5)7 I2 c' w* b n# p K/ t
p(5) = POINT/norm_pt
$ C, ]' {7 @- H1 G lll(1)= LINE/p(1),p(5)
2 ?( d5 v: B" g6 G1 \9 F- u% u delete/cs(2) 5 `" }6 C( v4 N ?
cs(2) = CSYS/P(3),lll(1)
, |$ a/ K3 s% M5 w3 z/ ^/ L else
' j5 _9 k( ~% t+ X# R 2 |$ L. o2 e! S+ u+ B
cs(2) = CSYS/P(1),P(2),P(3)
5 e! z/ @+ p( ]) J- G- g7 c &wcs =cs(2) ' H8 h3 o) G G( f8 ~
# u% p, `/ p1 D. H" w p(5) = POINT/norm_pt
% T% m. s. _9 x9 n8 I2 x, {: c lll(1)= LINE/p(1),p(5)
3 c: d2 A! _6 d0 V4 Y delete/cs(2) 7 x7 z/ I& c; Q6 M
cs(2) = CSYS/P(2),lll(1)
; e: X( H. \, y$ |, I endif
" z S: V' p, G' }+ @ O draw/ON $$更新打开% g' \) l5 q- ^5 @' \5 U. p7 e6 v
8 |0 J$ Z7 t6 { a% X; F delete/lll(1),p(1),p(2),p(3),p(5)
, K/ ] c1 F7 b &wcs =cs(2)
8 i8 d+ _: a; g1 X7 b) t- K+ ^( p JUMP/N20:" _* s( O! b* k! u
end:; _3 L2 ?5 ?4 I M9 g ~+ r
halt: ]0 _1 J0 W; w% Y
pr:3 u: z$ n" w8 F$ c
draw/on $$更新打开
3 f( k2 H$ @8 g1 W: O print/' '
) _9 i' V8 p; l' [: \3 w print/' 提示:你选择的不是平面,重新选择平面!'3 K. Y/ l( a( d$ j2 a3 m
pr1:/ J5 j0 J$ j4 y6 Y$ N+ L
+ {- S5 t# R. d. ?0 |1 Y jump/N20: |
