int CHANGE_action_act_cb ( int dialog_id,
3 L) ]4 W8 T1 e void * client_data,( h% ?: R9 ]+ F7 A8 o, Y
UF_STYLER_item_value_type_p_t callback_data)7 n# [& ? F! O H T
{' i* w }0 G) N/ P$ k1 C
/* Make sure User Function is available. */ 5 q3 O+ Y c$ `2 D# C
if ( UF_initialize() != 0)
6 i3 O% {7 V7 c% A return ( UF_UI_CB_CONTINUE_DIALOG );; O4 v1 E. e+ d$ Y( z
% R( V% [! y- [9 X
/* ---- Enter your callback code here ----- */$ X, C m2 z. p5 a/ M" o5 v# F
static void do_ugopen_api(void): q# F( ?' V0 x7 \
{ char dir[100];2 w. o, O/ i/ ]! Z7 i" y! r
char *grip_exe=
$ ]% c% I$ \7 r1 K "E:\\UG_para_design\\tiqu.grx";+ i) `$ f4 X: Y i
int status;
R9 z5 v) m* ?4 P! } int grip_arg_count=5;$ m2 k n% X: A) \) W5 Y+ K# O
UF_args_t grip_arg_list[5];1 H" i6 j3 L6 ]/ O* X- H! x
grip_arg_list[0].type=UF_TYPE_CHAR;
- V2 {6 K/ K1 g' t3 k( z/ d( a/ x grip_arg_list[0].length=0;
( G- |7 F3 w, l3 ]- | grip_arg_list[0].address=dir;
. w# W, _! d2 `/ J, d, P0 e5 @+ J4 ]) w9 ]7 i- _4 E4 c( e( ]/ T
status=UF_call_grip(grip_exe,grip_arg_count,grip_arg_list);( k% u% g: D# ^4 A+ z9 v4 D
}2 A; R! L2 ~8 f- G1 v
do_ugopen_api();; `( u3 i+ h7 x6 @/ B4 g2 D
UF_terminate ();6 _" o- k# N6 D/ V
" F" z- [6 t' U# ?
/* Callback acknowledged, do not terminate dialog */
5 l4 [4 g; \2 K6 w0 c' W8 N return (UF_UI_CB_CONTINUE_DIALOG);
|7 d5 A; p7 X9 ~- M x$ R' T; g 5 h/ r4 H' O! U G
/* or Callback acknowledged, terminate dialog. */% q8 e6 d) B2 C( \7 q5 _
/* return ( UF_UI_CB_EXIT_DIALOG ); */
! p. S$ b- K8 q8 o; Z$ }4 M% _1 t4 `9 Y
}) p6 w8 D$ ^) y. }$ U' _+ a
这是我编的一段程序,调用里面的GRIP程序,高手指点,帮忙修改一下 |
