查看: 1572|回复: 1
pro/e装不了
发表于 2007-9-5 20:17 | 显示全部楼层 |阅读模式
我要装的是WILDFIRE 2.0.M150- ~& ]% X& R3 {9 {
安装完 license server后。跳出一个东西来是:) P, o& q, s2 h4 f0 ?+ t0 X# \
   PT C。SETUP消息
. c7 p7 G/ Z0 o          安装期间出现下列警告条件,这些只是信息警告:9 j. A/ H' Z/ I# S' Y; q7 ^6 `
           启动许可证服务器,许可证管理已成功安装,但不能启动。有关详细信息和错误消息请参阅日志文件:: k' }. s) [6 F7 b3 C5 E+ B) v
                             D:\Program Files\flexlm\licensing\ptclmgrd.log) p1 [8 J* F5 ^4 {
6 u4 B8 j3 A  p! ^2 T7 r4 Y7 `下面是日志文件:
+ \9 ?& l# _8 z; u5 m. T
# U; ?0 [$ G3 e: _' I6 A+ j, b/ @" X7 d& S3 M( f! Y) `
19:55:18 (lmgrd) -----------------------------------------------
- q* \4 m5 L4 {9 v. b19:55:18 (lmgrd)   Please Note:0 k/ `& y+ R1 p: `7 _
19:55:18 (lmgrd)
, y/ y' h6 l2 ~+ N1 O( P: |$ \19:55:18 (lmgrd)   This log is intended for debug purposes only.
. Z7 V; W/ x" s8 Q: N* X19:55:18 (lmgrd)   There are many details in licensing policies" E8 t; v, M# C) V! @
19:55:18 (lmgrd)   that are not reported in the information logged
- r( U' |  C4 f19:55:18 (lmgrd)   here, so if you use this log file for any kind
. [+ i% V' I7 L, M19:55:18 (lmgrd)   of usage reporting you will generally produce
# A3 J# ~. y; m3 `: D19:55:18 (lmgrd)   incorrect results.8 s" t5 r6 L6 k  Q9 B
19:55:18 (lmgrd)
" j. X  o5 ^6 D5 F. R" @5 d1 J/ N19:55:18 (lmgrd) -----------------------------------------------
  x9 V0 L5 F2 z; U/ d8 I19:55:18 (lmgrd)
: E2 E# t$ V4 e: N19:55:18 (lmgrd)
! F8 G( Q2 I/ c+ A" B( s+ i4 B19:55:18 (lmgrd) "9dad70a2749f4a6": Not a valid server hostname, exiting.
% k5 O& \) P# r- u, P+ f19:55:18 (lmgrd) Valid server hosts are: "host"
: P- q+ v* }$ |5 I' u19:55:18 (lmgrd) Using license file "D:\Program Files\flexlm\licensing\license.dat
- K, \, s: M) f: F
9 E0 g/ Q" C! t* ]
# n' o7 d7 Q( R' T3 ~; R哪位高手帮我看看。谢谢了。
发表于 2017-2-13 20:51 | 显示全部楼层
首先看看你电脑的网卡是否正常,然后再检查一下你PROE的许可证文件是否损坏。
GMT+8, 2025-5-6 00:01 , Processed in 0.118456 second(s), 21 queries .
