在做uf5947的时候,第一个参数是矩阵,是不是只能通过uf5943,uf5945获得啊,如果我自己定义一个矩阵给它,不行吗?7 Z2 R) x- g! [, p, h
4 K, K% D, G0 T v1 p1 c1 j3 j8 k, \, k
4 e: L6 e- p. b, |- _
以下是我的程序:
, t3 E* q1 U+ a3 T) j9 _2 A( h4 f: r7 r' V/ W$ `" B& `' U; J
int irc = 0;
0 u: U/ E: s- `9 B( K5 e/ o7 j( ^! t char *message = "Select Object";9 ?* i# I1 w. S* ?2 y( u% h
UF_UI_selection_options_t opts;+ K7 L+ M$ k* w1 b
UF_UI_mask_t mask;; { R3 z9 Q/ o
tag_t object, view;
6 M" `0 N u; x o" _0 d- P: M7 W/ i" ] double cursor[3];
/ P5 W, O4 N- {1 ~ int response;: N4 W" Z0 ~9 O" |8 _: N. U
+ q( V' y6 Q9 i
2 m5 q- g" ], M: k7 E5 |. W! s
opts.other_options = 0;
# a' x* e- z3 q9 _ X% e1 e8 N opts.reserved = NULL;, Q/ M9 t# F# \! I
opts.num_mask_triples = 1;2 m9 o0 I- W4 Z! }1 Z% z
opts.mask_triples = &mask;
4 g9 q) C( i& ^6 \, V opts.mask_triples->object_type = UF_solid_type;8 ?0 M$ O) V0 T) m# W/ c! K8 ~
opts.mask_triples->object_subtype = UF_solid_body_subtype ;
V5 p+ c- u( g1 q' G' f# O/ ~ opts.mask_triples->solid_type = UF_UI_SEL_FEATURE_BODY;: s. o! ?4 k1 O: V: c
opts.scope = UF_UI_SEL_SCOPE_WORK_PART;
5 @& Y* b# y# @( W b irc = UF_UI_select_single(message,&opts,&response,+ e( c; s0 D* c; @5 c0 K
&object,cursor,&view);1 O+ \8 M/ |' F6 _2 G
UF_DISP_set_highlight(object, 0);7 P3 K, t/ o; S6 F% \& K6 }% P- r
& U5 y1 r# I- z+ i! w; g6 c
+ z6 m8 V+ V, t/ l8 ? B* f$ M
, z% x3 N. q5 y( m- c4 v `$ O const double rp1 [ 16 ]={1.0,0.0,0.0,0.0,0.0,0.98,0.353,-1.446,0.0,-0.35,0.90,2.00,-9.00,-9.00,-9.00,-9.00};
, c$ x+ b& ?4 _0 S [ const int n_objects=1 ;
5 L$ y- Z7 K8 s w3 I8 r# ^ const int move_or_copy=2;
/ W: G! v1 B5 |* m const int dest_layer=0 ;
4 L7 t8 v% {+ J: e2 G const int trace_curves=2 ;" C& W' @/ c( W* P" o* E
tag_t copies;
; F& C2 r, h2 E) \ H tag_t trace_curve_group;
0 x; m V- K M1 f8 d2 T& D6 T int status;
8 d$ f5 D+ x( k1 _0 \" }" k% `: R! A- ]9 }" A# }* l4 Q1 a& C
uf5947(rp1,&object,&n_objects,&move_or_copy,&dest_layer,&trace_curves,&copies,&trace_curve_group,&status);
7 l7 b( X& M, r9 n: V% k6 |' O7 l4 o% ~8 N
5 D0 L, K- i/ n4 X, [! M# y6 _
, n6 u4 f5 J! q+ O* _ c* D+ N" C# L) v) Z
; ~+ b( m2 G9 j% Y编译是对的,但是没显示,status的值是4,也就是Shear Matrix With Non-shearable,请各位帮帮忙?
. J0 I0 O# M+ [) ` f7 v0 u! o/ I( G( n2 h
