查看: 4037|回复: 6
[疑难] 求解can't read "post_object": no such variable
发表于 2011-8-14 19:41 | 显示全部楼层 |阅读模式
用的是ug/POST Builder Version 6.0.0.2版本,英文界面,每次新建完一个后处理程序保存后,再重新打开,进入POST builder 界面后,会弹出# S( k9 Y* P) A9 X2 i
QQ截图未命名.jpg : a! U# I  @8 E
关闭后,任意打开machine tool或program& tool path或N/C  Data Ddfinition等,会弹出对话框
+ I& E: |8 s; l, S' A  H7 j9 V8 Y QQ截图未命名.jpg ; ]1 f7 V' p5 g1 @
打开报错对话框中的DETAIL ,奔出来信息如下:7 Q. j9 s$ t9 g0 ~
can't read "post_object": no such variable. Y) h  [" b+ k: f
8 S' B* C* p  M$ s; i" Q    while executing
0 a% _) h) W6 L"set addr_obj_list $Post:$post_object,add_obj_list)"/ O. l; f" P' Y
    (procedure "B_adr_RetAddressObjList" line 4)
8 I; D  ~6 w  U( ^/ l    invoked from within
$ m- f+ U5 A2 ?% l' _"B_adr_RetAddressObjList addr_obj_list"! i: J& J8 x4 \% I% d* B
    (procedure "B_int_RetAddressObjList" line 3)  A1 Q6 T& t+ l; O8 n5 V, H% w
    invoked from within4 m: D" A& r" ^* ]& D) K: L
"B_int_RetAddressObjList addr_obj_list"% l1 ]# y' g; H. k# K, H: n
    ("0" arm line 3)  q7 ~: ~7 S8 v+ `( Z3 ?
    invoked from within
% r9 P4 P# ?, p+ o5 c" T"switch -exact -- $Book:$book_obj,current_tab)  {6 m* ]! ~9 }  l/ M" `+ T& E
0 { ;# Machine Tool
1 A* {0 O4 @1 o0 [global mom_kin_var
8 Z& u" _) P( ~" f  Y3 T9 j. F6 EPB_int_RetAddressObjList addr_obj_list$ f( c, z: P- l  I8 C9 H- j& C2 n
set addr_name "fourth...", G% S! y1 C  M. c$ j
    (procedure "UI_PB_ValidatePrevBookData" line 11)' T; |& u) |% d6 D& b
    invoked from within# g4 d9 g5 e" G5 x
"UI_PB_ValidatePrevBookData book_obj"
$ ]$ b& W; \* K( o9 |    (procedure "UI_PB_DefTab" line 3)
1 i- J$ f# v8 I2 t    invoked from within
' F$ g9 a2 D( x3 E- Z: w* _) y7 N"UI_PB_DefTab .widget.main.nb  image8 762"
' {: b2 V( |0 Y/ _: e    ("uplevel" body line 1)1 A; f# e2 U9 U% ~& u, ~3 g
    invoked from within
6 h( M1 I' T& o% N3 ~+ k8 m* l"uplevel #0 $data($child,raisecmd)"
7 A  }* o. @6 J5 ^# x2 k3 V! }0 h    (procedure "tixVStack:raise" line 20)
& K' H8 F1 e/ A7 f    invoked from within& l* u+ `1 a, w6 k+ v
"tixVStack:raise .widget.main.nb def"' Y; B8 ]( l2 i# l$ R; m6 b
    invoked from within
- o$ t5 R7 O* h! M7 j2 G- E8 o"tixChainMethod $w raise $child"" t% G% h/ X4 B
    (procedure "tixNoteBook:raise" line 4)
/ [/ a! A2 L- r- D    invoked from within
  \5 o; u) H) H. r' F"tixNoteBook:raise .widget.main.nb def"0 r$ R* g& G+ t( B* U
    invoked from within
: J% S- p% R( X7 A7 s' G1 D"tixCallMethod $w raise $name"
0 s* T) X3 K0 [6 w4 M2 u    (procedure "tixNoteBook:MouseUp" line 15)" I, x: a+ g" d  f0 w+ |. h
    invoked from within5 M2 v; L) {  @1 p9 u6 a
"tixNoteBook:MouseUp .widget.main.nb 427 25"
  T  o; @3 V2 z# _5 g- R6 q0 f/ S, m    (command bound to event)
' d; T% q2 c$ @% H7 {7 z+ A
+ t$ [' D, r" i5 \4 I/ t' t不知是何因?求助各位大侠分析指教。
/ \. n2 e0 n6 Z' ^5 U0 ~- C
( \. `, J+ g4 a( j; a8 y3 J% X+ p- N  N2 b2 D1 E" o7 v" \
6 d) X  M: t6 c& x$ X" O
发表于 2011-8-15 09:37 | 显示全部楼层
打個補丁吧!PB6.0.0有很多問題,最終版是PB6.03......
发表于 2011-8-16 08:30 | 显示全部楼层
我也遇到了这个问题     请高手帮忙
 楼主| 发表于 2011-8-18 23:25 | 显示全部楼层
打了PB6.03补丁,可以使用了,谢谢.
发表于 2011-8-19 13:39 | 显示全部楼层
楼主您好    哪里有这个补丁啊
发表于 2017-1-13 15:08 | 显示全部楼层
lyin180 发表于 2011-8-18 23:25( \, b- L6 R8 V, \8 Y5 W
**** 作者被禁止或删除 内容自动屏蔽 ****
) g3 Q7 D/ w, |0 T这个问题如何解决的,,,拜托了。。。。
4 R; i1 S8 `- x* s
发表于 2017-1-13 15:10 | 显示全部楼层
/ s. D$ S% ?1 a0 T3 ]6 z' a! G9 ~9 V**** 作者被禁止或删除 内容自动屏蔽 ****
/ i; ^3 n' `4 X) g( a& ?# D$ r大神,如何解决的,,具体说下呗
GMT+8, 2025-2-25 15:08 , Processed in 0.061842 second(s), 24 queries .
