用下面的代码生成草图,但是只出现各种消息,就是不会出现草图,是怎么回事呢?请给位哦大侠指教!小弟是新手!) |3 r& M# Z7 [2 c/ M6 |1 C
char name[30]="sketch_01";8 ?3 f3 e( }0 u8 k" F N" r7 U
tag_t sketch_id;
8 A, P1 O* c ^ UF_SKET_initialize_sketch ( name,&sketch_id );//初始化/ H* h! R$ w$ A7 u5 a6 I
$ ~8 q, j5 a/ O+ @
int option = 2;//草图位置由坐标系决定
5 _9 X1 u2 E: c! s2 [ double matrix[9];
* G" j4 ?1 O. B' S. H) V tag_t obiect[2];5 t) x' A/ d, @1 M. `
int reference[2];
/ o: w# `+ G1 w1 B int pane_dir = 1;. e4 J$ J/ Q: J7 A1 @. ?5 D7 w
matrix[0] = 1.0;: j7 G; y" u) [# a) c4 }" A* F& A
matrix[1] = 0.0;
- Z1 L4 Z) t1 u& s matrix[2] = 0.0;
9 K) {- ?7 T5 u! p$ F' { matrix[3] = 1.0;) G A' q1 C' c, X5 X
matrix[4] = 0.0;
6 u5 U$ H# \8 @& ]" h" Y) R matrix[5] = 0.0;" w- g; M1 z+ X* f
matrix[6] = 0.0;/ {! Z4 i( {* o- D$ V4 E
matrix[7] = 0.0;
# v( u3 X$ ^8 ? matrix[8] = 0.0;
$ ~& Q; Z9 G8 s% U UF_SKET_create_sketch ( name, option, matrix, obiect,reference, pane_dir, &sketch_id );
/ A% t+ L# O4 @# `3 m# c AfxMessageBox( "新草图创建成功,按 确定 继续" );
0 j% M* {( {* W( @2 ^3 @ tag_t line1;- m( T% V7 J3 q1 g) g
UF_CURVE_line_s line_coords1;
1 Q! n, m( Q/ n5 s line_coords1.start_point[0] = 0.0;
6 t, n' A F% U0 t line_coords1.start_point[1] = 0.0;
5 w* y+ G8 M: C" y/ ? V line_coords1.start_point[2] = 0.0;
+ \$ t! O8 ? T3 c line_coords1.end_point[0] = 10.0;
" N/ r+ g3 v, F! }9 C0 Z; T line_coords1.end_point[1] = 10.0;: p& L' g8 V# Z" a
line_coords1.end_point[2] = 0.0;! ?0 Z! M* Q3 ^4 G1 ?
UF_CURVE_create_line( &line_coords1, &line1 );- j/ x( D& ]6 Y/ U2 g/ c
tag_t line2;( d+ Y9 m, ~, s9 I8 a, ]: X7 W2 H
UF_CURVE_line_s line_coords2;
6 j7 K( W3 r7 h& w- x* j" f# v line_coords2.start_point[0]=15;
2 W1 {) L& [. R line_coords2.start_point[1]=0;3 t; L5 C( y- R6 B% ?
line_coords2.start_point[2]=0;. i, }+ l6 m! T9 t7 e$ H* k' f4 L
line_coords2.end_point[0]=25;
2 B1 i1 A S9 N line_coords2.end_point[1]=10;2 E. Z) o1 w3 i. [& W
line_coords2.end_point[2]=0;0 z, _7 b& A) c. \/ l2 Y2 P3 i
UF_CURVE_create_line(&line_coords2,&line2);- |, z/ u* t$ W4 i4 ?
int count=2;
2 e7 B5 f& D: @0 Z$ x' B tag_t addobject[2];' t! Q/ u6 r+ p3 l+ U7 X
addobject[0]=line1;
$ j$ m2 V0 u9 Z addobject[1]=line2;
1 U% b2 m7 H( X4 E; L+ Y UF_SKET_add_objects(sketch_id,count,addobject);
8 b3 F- n& K C y 7 p3 x- k' l+ [2 H7 J( j
UF_SKET_con_type_t dim_type = UF_SKET_horizontal_dim;//水平尺寸类型7 f8 O6 m; O: |1 i
UF_SKET_dim_object_s dim_object1;
4 X. v/ B) ~) W& L UF_SKET_dim_object_s dim_object2;
3 R. C& S p/ v) U* c# A( Y7 c double dim_origin[3];
% L3 l& g: v. K3 s9 G8 _ tag_t dim_tag;
) ?2 E' k3 q. b% M( m dim_object1.object_tag = line1;4 |7 q& T) A; X, |, \ Q# Z/ ?# \
dim_object1.object_assoc_type = UF_SKET_end_point;! o/ A R& K8 u
dim_object1.object_assoc_mod_value = UF_SKET_first_end_point;, Q! Z- A3 G, p% W7 w" `0 Q/ a- q* J
dim_object2.object_tag = line2;9 l8 k) t, R7 C P1 E
dim_object2.object_assoc_type = UF_SKET_end_point;
% H1 {. p& v9 [ dim_object2.object_assoc_mod_value = UF_SKET_first_end_point;7 U; s0 v; e, |+ a ~5 j1 m
dim_origin[0] = 0.0;
/ {2 B6 B/ U. A) { dim_origin[1] = 20.0;
! A7 v* l0 H4 ~. U) G6 A$ A2 W) M9 d dim_origin[2] = 0.0;
2 t+ u! I6 ~& J5 j UF_SKET_create_dimension ( sketch_id, dim_type, &dim_object1, &dim_object2, dim_origin, &dim_tag );//创建尺寸4 R5 G: g, T* n. H' z, Z; u6 l. h8 q+ x/ a
AfxMessageBox( "尺寸添加成功,按 确定 继续" );+ O$ u6 G/ j% W* i
3 I- @( W8 H; L6 J int num_dim_obj = 2;//1 H2 T9 L8 x# {: u: q
UF_SKET_dim_object_s dim_objs[2];
; O. p- S0 `0 M) |7 @9 F" g4 n0 T tag_t con_tag;
! y1 K" u8 Y& @ dim_type = UF_SKET_parallel_dim;//平行尺寸类型3 o: k( c" E" E8 q$ s- A0 k( Q
dim_objs[0].object_tag = line1;0 l) F5 U) Y/ a% K
dim_objs[0].object_assoc_type = UF_SKET_end_point;6 O: }. y5 W @8 |5 z
dim_objs[0].object_assoc_mod_value = UF_SKET_first_end_point;
/ k) b+ k1 V; |1 _1 I7 j9 @ dim_objs[1].object_tag = line2;
: U! }* }& t5 ~' n% S( C5 e dim_objs[1].object_assoc_type = UF_SKET_end_point;
" Y" @; G' a9 m" A7 Z% p1 W7 ^% E dim_objs[1].object_assoc_mod_value = UF_SKET_first_end_point;
6 v! @3 n1 t8 ?2 ~4 n2 U; f7 N: C dim_origin[0] = -20.0;# {0 p" ^. D5 Y
dim_origin[1] = 0.0;+ L+ L* E5 x `0 n
dim_origin[2] = 0.0;* Q* d7 l2 n. Z, K6 G
UF_SKET_create_dimensional_constraint ( sketch_id, dim_type, num_dim_obj, dim_objs, dim_origin, &con_tag );//创建尺寸约束/ j7 S: A( s$ U* b) r
AfxMessageBox( "尺寸约束添加成功,按 确定 继续" );- y6 \" B( h9 q7 t$ R8 |5 W
- R9 n1 q& [/ }+ k* r y UF_SKET_con_type_t con_type = UF_SKET_parallel;//平行约束类型
' Z) a7 ^) y! x8 {2 B UF_SKET_con_geom_s con_geoms[2];
- N' _8 K$ Q L' k( f E' y, A int num_con_geoms = 2;4 d, [- B3 I8 f9 ^
tag_t geom_con_tag;8 h* {; s" f4 j) Q
con_geoms[0].geom_tag = line1;
; ~ S7 i3 @1 A7 E con_geoms[1].geom_tag = line2;
, G* ~7 R* J9 ?- `* @6 x" i( m UF_SKET_create_geometric_constraint ( sketch_id, con_type, num_con_geoms, con_geoms, &geom_con_tag );//创建几何约束
" I9 K( y" f/ \6 V# k6 }2 m+ Z
% U: `2 A) d- Q. K* G! y# m AfxMessageBox( "几何约束添加成功,按 确定 继续" );
1 S3 x& x" I# d. {% \! j, o; o8 r x2 D# A3 { S+ e0 H1 b
int num_exps;
" }6 k! s, l) F9 W; h! i3 v- Y tag_t *expression_tags;
% F9 K2 `- n# W7 a$ n/ g& J UF_SKET_ask_exps_of_sketch ( sketch_id, &num_exps, &expression_tags );//查询草图中的表达式
- t0 _3 J: C: l9 A
1 J- }3 _) C" }- `% H" _. T int num_cons;
( I5 G9 c. ~& c' G, z8 ? tag_t *con_tags;
) m. X: l: u- f UF_SKET_ask_geo_cons_of_sketch ( sketch_id, &num_cons, &con_tags );//查询草图中的几何约束
/ ? h; e, J, G, G
, S9 Y$ Y$ \0 |' |+ \( |. _. ~ s UF_SKET_update_sketch ( sketch_id );//更新草图
( B3 ?& ?' E8 p' ?1 U( U; m8 Y 3 I9 S( H. U9 ?0 z) L/ o
//UF_SKET_terminate_sketch();//关闭草图+ p; Q* ]3 N" _# B5 S
+ a. ?8 A# v/ I! B
//UF_free( expression_tags );
" r! M8 m& F2 `' R5 V4 ~3 n/ W N // UF_free( con_tags );
1 N/ f- `4 Q4 ]- O //UF_terminate(); |
