查看: 1639|回复: 3
谁能帮我翻译CRACK
发表于 2007-9-9 09:57 | 显示全部楼层 |阅读模式
1.Use the Keygen.exe to generate your PTC HOST_ID license file;
% [4 V; c/ d3 y7 y, O9 o. X* x6 @2.Install the PTC License Server with your PTC HOST_ID license file which you got from Step 1;
  V. l% j" _& x3 W$ m9 R3.Install Pro/ENGINEER, and select Single Server license type as the Pro/ENGINEER license;1 y- @* O7 ?1 l$ T7 m. a
  then fill "your computer name" as the HOSTNAME in the BLANK before the port "7788".
9 k. @, }# ^! |5 Z, o/ D: W  ) G: a( H- L/ l7 |4 g; A
  *If you click the Setup Option" VERICUT (R) for Pro/ENGINEER" when you install Pro/ENGINEER and wanna the VERICUT as the
& v; l1 e7 V. h5 \  *embedded software for pro/e, you should also do the following two steps for the embedded VERICUT:
* i4 X: e$ M* p+ F5 {  *    A. Copy the patched CGtech.dll into the installed directory \proeWildfire 3.0\i486_nt\obj to replace the original one.$ w/ `+ w& j& d. A
  *    B. Find the following file in the installed directory \proeWildfire 3.0\bin\proev.bat and open it with an Editor software,
7 o$ R% e6 m; `( b+ _+ B  *       search9 g: u( f& x: x9 M1 v6 ~7 V" t  P
  *          Vericut %argstr%$ x* u5 b0 C9 ]5 B" M3 [/ V
  *       and replace it with the following string:
8 c5 v, M6 t7 _; m4 ^  *          Vericut %argstr% PTC_KEY=0
) c- z; K9 [( r0 P  *       then save the file. the purpose of the step B. is to forbid the VERICUT to use the PTC lic as its lic.Actually, CGtech3 ^6 q; J# B  |; i( U* }+ O" i; |
  *       no longer supports its VERICUT as an embedded software for pro/e and no longer uses PTC lic.FYI, See the CGtech official
) p/ H1 L! h% I9 M, O+ o& @  *       website said:% p% P' M( ~% |+ n4 l1 w% x4 p- n+ U
  *            http://www.cgtech.com/ptc_update/index.htm
6 d+ s- {- P$ N3 M0 o           + O' w, i" z6 s, q) g0 [' `+ l0 S
4.Install Pro/Mechanica(Structural and Thermal Simulation) like Step 3." {- ]8 @6 g. s1 ~0 b
5.Install PTC Distributed Services.this step will automatically get the lic from the lic server installed at step 2.
' r* Y) N3 w5 f! _) K& W6.That is all and enjoy it!
9 \7 `' c3 O; B4 w1 E0 y2 a' Y
4 f8 `; L2 ?" Z! RTEAM ZWT /2006
发表于 2007-9-9 11:15 | 显示全部楼层
这是ProE3.0的安装说明,你只到网上搜就可能找到你想要的了!!
发表于 2007-9-26 06:44 | 显示全部楼层
发表于 2017-2-13 20:38 | 显示全部楼层
这是PROE里面的许可证文件。不能删除哦。
GMT+8, 2025-5-26 10:38 , Processed in 0.204988 second(s), 26 queries .
