查看: 2199|回复: 5
FTP登录失败
发表于 2011-8-22 21:59 | 显示全部楼层 |阅读模式
刚刚买了FTP流量1 v3 o7 c; e1 j  l) s% a3 W. J( `" P
但是为什么总是登录不上呢
+ g, o1 b8 A# h8 u+ H
+ h* J2 Z' x0 @[22:00:00] 正在解析地址 http://ftp.uggd.com0 U5 w9 b& h7 H" k  f1 `
[22:00:00] 解析主机为 61.164.140.41
, G0 U) C1 W0 S* {3 d[22:00:00] 连接到  http://ftp.uggd.com, 端口 21 (#1)5 {! p* n" E4 V$ n' {( F
[22:00:00] 已连接到服务器,正在等待响应...
! z# }8 s$ v6 I$ o. S! R* \[22:00:00] 220---------- Welcome to Pure-FTPd [TLS] ----------
/ C) m3 v0 v. G  h* \[22:00:00] 220-You are user number 1 of 500 allowed.# U2 f6 ~0 n0 y8 V
[22:00:00] 220-Local time is now 21:51. Server port: 21.- v4 v  ~  t) c* \) ]% o1 S
[22:00:00] 220-This is a private system - No anonymous login
) c8 b. O* |+ Q2 u* B2 X) J[22:00:00] 220-IPv6 connections are also welcome on this server.
  N* K' }5 i- K# B8 ^# X[22:00:00] 220 You will be disconnected after 5 minutes of inactivity.
' g9 ?2 l" g3 z5 j[22:00:00] USER hqu8808
8 X  s& u, m  C3 U[22:00:00] 331 User hqu8808 OK. Password required
. _: R6 Z8 t* P, M& S* y5 L[22:00:00] PASS (隐藏)
# t  Q- f4 X: O* M/ _9 g# I[22:00:04] 530 Login authentication failed1 ]9 S$ p7 h+ J# a& t. _2 K. L+ K
[22:00:04] 连接失败 (登录失败)6 p; a& g6 c' U
[22:00:04] 重试        30 秒...2 e2 v/ W! D; w. H* b7 s; ]
[22:00:09] 连接被用户中断
, h1 n. m& i8 _[22:00:09] 正在解析地址 http://ftp.uggd.com' j, F8 Q2 i* ?" j! y5 k. p& ^6 W
[22:00:09] 解析主机为 61.164.140.41
# d" ?3 b3 Z4 ^( q3 Q& b( c7 }% c[22:00:09] 连接到  http://ftp.uggd.com, 端口 21 (#1)* a6 d* F5 z5 g3 f1 R% ~
[22:00:09] 已连接到服务器,正在等待响应...0 C" I% I- ]! D! J! _. P3 f( p$ |* d
[22:00:09] 220---------- Welcome to Pure-FTPd [TLS] ----------% v' R  E; f8 \+ q# d1 s0 x
[22:00:09] 220-You are user number 1 of 500 allowed.# _1 Q8 r- b4 m' a6 p( E0 G0 U
[22:00:09] 220-Local time is now 21:51. Server port: 21.
0 D5 _1 r: w) @% z6 j0 L[22:00:09] 220-This is a private system - No anonymous login* W/ h1 `- K7 J/ @
[22:00:09] 220-IPv6 connections are also welcome on this server.( C. K( h( X& q; H; ]+ P
[22:00:09] 220 You will be disconnected after 5 minutes of inactivity.' }4 A2 A! G1 r; m8 S, s
[22:00:09] USER hqu8808
' `* N# E$ i" v; s& r* x[22:00:09] 331 User hqu8808 OK. Password required2 o0 d4 ]$ ?. ?3 w3 [' X2 b; O
[22:00:09] PASS (隐藏)
9 F- G( Y, H- ^6 ~# m1 r[22:00:15] 530 Login authentication failed
; c5 [% a1 X, u6 [6 p3 A" j[22:00:15] 连接失败 (登录失败)( D# }% Z0 |2 r
[22:00:15] 重试        30 秒...
* M8 D/ r* C$ ^% _' T[22:00:45] 连接到  http://ftp.uggd.com, 端口 21 (#2)( f5 ?& R% G& F3 L# M  O% w; {
[22:00:45] 已连接到服务器,正在等待响应...
  N3 |) o: W1 P3 N[22:00:45] 220---------- Welcome to Pure-FTPd [TLS] ----------2 }4 D0 ~) N6 j' ~
[22:00:45] 220-You are user number 1 of 500 allowed.2 c$ z/ G: A. B+ h! K% z$ y7 v4 }7 S
[22:00:45] 220-Local time is now 21:51. Server port: 21.
1 k2 F; R$ {" U6 A[22:00:45] 220-This is a private system - No anonymous login! J  ^% @$ Y: d* K4 J& j
[22:00:45] 220-IPv6 connections are also welcome on this server.: R. [- b0 L$ s
[22:00:45] 220 You will be disconnected after 5 minutes of inactivity.( j5 d! t8 L2 w. C/ `0 ^
[22:00:45] USER hqu8808
6 e4 C( Z$ r2 H. C2 x& p0 ~0 K[22:00:45] 331 User hqu8808 OK. Password required
& U, S3 A8 j8 _[22:00:45] PASS (隐藏)
; Q, ]9 C& ]* E4 q[22:00:51] 530 Login authentication failed
, [9 i+ {$ X  f[22:00:51] 连接失败 (登录失败)2 G4 r* o$ j1 ~1 R7 R/ V% c
[22:00:51] 重试        30 秒...! S7 m  z" O$ p) c  ?/ B
[22:01:05] 连接被用户中断, s; _5 i( a) e+ B+ g" X. G
1 [& S+ F( n" @0 p) G) p5 Y
" c$ H# w; x1 {) G+ W' n1 B0 b0 I; O
# Z5 t  T$ d( Y. p( a+ p/ _2 S9 h
 楼主| 发表于 2011-8-23 16:50 | 显示全部楼层
没人鸟啊
发表于 2011-8-23 18:11 | 显示全部楼层
有没有设ftp密码?
; h, x1 z2 H5 w+ {6 ]1 g& E! L重新设下ftp密码,然后ftp工具里修改好账号和密码
 楼主| 发表于 2011-8-23 18:16 | 显示全部楼层
movi 发表于 2011-8-23 18:11 - {" M# }4 t$ b; [6 f' F
有没有设ftp密码?
' C& M" Y5 s6 h) D8 N7 _2 t) X重新设下ftp密码,然后ftp工具里修改好账号和密码
( Q' Z! r/ P8 R$ W" X
还是不行的呀
发表于 2011-8-23 18:27 | 显示全部楼层
ftp 地址填 ftp.uggd.com (不要前面http://) 或  61.164.109.98
 楼主| 发表于 2011-8-23 18:30 | 显示全部楼层
movi 发表于 2011-8-23 18:27 1 g/ i( e, J7 H* Q
  y+ P" v9 ]+ X
哈哈 太感谢了啊 搞定了啊!
GMT+8, 2025-2-25 03:40 , Processed in 0.055967 second(s), 21 queries .
