#include <stdio.h>
' S& Z6 J; @7 e2 |4 b/ S
! F3 U/ I1 X- p, Q# x& [. u#include <uf.h>: r" \2 b% p6 [) k9 ~8 }
% E7 K2 R C- q
#include <uf_ui.h>& F8 K/ t& O$ V2 ]( I
8 o7 a0 G) n0 _; L" w% y1 m$ |#include <uf_disp.h>
& R0 H0 ^" O( w- v/ k; m0 m6 o! U+ W8 M
#include<uf_modl.h>
/ Z' q- _' t$ B; P& L
+ e3 @8 S" N5 P. {#include<uf_layer.h>0 ^2 J: |, R9 O+ _+ ]# a |0 l
2 n9 t3 W/ C$ j7 v3 X, J
#include<uf_assem.h>
! i* k3 |5 t; w4 ^- I" {+ Y
) ^( _/ v" s" |6 P0 c5 R9 }#include<uf_obj.h> C; P" q) M! K/ ~0 t; y& V9 p% x
) j# n( O* _* |* r o ^1 b& \
#include<uf_part.h>/ L4 w1 ^: b! Z% {3 Y4 B
2 |6 i0 ~5 a) ^' `: F$ T Z* K: b
#include<iostream>
3 X5 U) K. }" ]# X0 [, ?4 Y) u. R Q4 g; f
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
4 S- K! g# u. d+ ]& a0 g" r# Q6 o* m% y$ Z+ v$ |: B- S1 a! F
static int report( char *file, int line, char *call, int irc)
* @: X6 n- {3 ?; G. A
" ]8 l) n. b+ K; \2 F/ Y9 Q{: P+ ^6 B8 U6 l
5 E2 d- F: @$ ^, _4 X; X if (irc)
; V. A( ?; _4 S+ x( y
9 c' C( n* B; p# I {
( O" W* l4 P% m6 v. f, ~ V
0 h4 E+ u" Y; l, _/ p9 g2 q( Z char messg[133];4 Y3 O d' [7 V! V$ }( B
+ K! z: n6 b: l" k% K0 u printf("%s, line %d: %s\n", file, line, call);
/ t( k- [) _; ^% @. U" }' h9 S8 J+ i$ ]' t4 `" m) O# u
(UF_get_fail_message(irc, messg)) ?
8 B' O2 `/ X0 \8 s: ?6 J2 V+ r( ~0 y( l. q |6 o, v4 o* r+ X6 y
printf(" returned a %d\n", irc) :
8 j6 e u2 h& R3 g4 s) l
3 z B- W, a6 ?" l printf(" returned error %d: %s\n", irc, messg);
$ D, m* \! e6 @( ?1 q- G( t% s m3 U& H5 u
}" T# L9 \! R6 H& l
" [# M t. R/ k% E! @
return(irc);
9 ]2 P0 k4 a3 L. ?; x+ T' U- H! ~# x5 [
9 z2 a T1 u# j( H4 a' p" |* V/ f* `1 j% ]6 b
static void do_ugopen_api(void)
8 G/ Q9 H+ [. f! U) \
7 A: K" o1 m' f0 E; A g% [3 W) [{
; N) a: N: O0 P; ]' Z% m' z7 e& x" ~- a% p' I6 {
UF_FEATURE_SIGN sign = UF_NULLSIGN;7 u8 c7 O4 D0 n; g+ [, N0 L
. b1 g$ B% D, r2 e2 k0 L6 X' ^ tag_t target = NULL_TAG;/ D5 {4 ?! g" B( v. Y& ^/ s
7 |' B; N% ]; A" ?) Q
double origin [] = {0.0,0.0,0.0};
8 T! q6 q6 x% Q1 k& k% I q, F. I! N3 j- Z1 x: k% e
char* height = "100";6 d* e7 d3 n$ r5 a" o0 o" p( b
! o% g/ V0 k# r) G
char* cyl_diam = "80";
s4 Y: E$ T$ G+ x" J. l3 i4 v# ~% U6 X2 g Y
double cyl_direction [] = {0.0,0.0,1.0};
' Y# [' p: V" ]( F* U2 h* f1 y9 y. B; {/ i
tag_t cyl_feat_tag = NULL_TAG;, r5 H; j: T7 k- D
: @2 v' g/ g8 r7 C2 [: A7 p/ [
UF_MODL_create_cylinder(sign,target,origin,height,cyl_diam,cyl_direction,&cyl_feat_tag);
& |9 s! i9 [/ ], A! X& Q
1 Q- V3 L/ P8 N double value;
1 B6 _1 a3 [( l7 ~9 C1 E7 _# c9 r+ `) _! v) h. k
tag_t target1;
& d* u9 O# i$ h$ l) Z& f
5 _* }8 x; @3 @, P UF_MODL_create_exp_tag(height,&target1);//Creates a parameter expression, based upon the input string.
3 v! ~+ k4 q" c1 G/ i% u/ f; w- L% ^2 a l+ i
UF_MODL_ask_exp_tag_value(target1,&value);//Asks the value of an expression tag.8 F5 X+ S0 F; h2 z9 ~/ F
- _" Q1 A* O- }6 I: H# l ~$ Q
double location[3]={0.0,0.0,0.0} ;# F0 J! g9 x' e8 |) i# n7 i
4 L" Q5 H! w: a# ^ C
double direction [] = {0.0,0.0,1.0};
. Z+ u% X0 @8 y0 R s6 w8 `
* @5 _9 T8 J6 V( D3 w tag_t obj=null_tag;
' w& V/ C: S1 n- Z( n# R6 M" P; O" c: c0 u
char *diam="30";( F u9 u' h4 P- R: S1 u
$ ^* k0 Q, E, b1 o4 ?4 V char *angle="0";
. N& r1 y `- v
9 ?: ]9 }6 [9 ]; |! z E/ u4 n3 U tag_t bottom,top;
) i% |- D& |1 ~' Y# S1 z9 @1 i; i8 ?
tag_t feature_obj_id ;
' n$ K: n! {. K9 K0 E' P2 v& w% J/ `2 q/ F) {* D. e; G3 L
uf_list_p_t face_list;
8 u$ j* J* _0 V# M9 m0 n, `( }% v1 F! J. S1 c
UF_MODL_create_list(&face_list);//Retrieves an object from a linked list of objects7 J- u( @9 H, ]7 n3 D! l( j
4 b4 Y0 M/ h8 F/ k9 \8 O1 ?$ `
UF_MODL_ask_feat_faces(cyl_feat_tag,&face_list);1 F" n/ w6 `$ D6 s, v
, Y @3 s: B# N, ^0 f1 d int count=0;
$ I, _, y8 h$ O, m! O# H3 C# U8 S5 g: [
UF_MODL_ask_list_count(face_list,&count);//Retrieves the count from a linked list of objects
* s6 d, p- P; Y h
/ F4 |9 K3 w5 r# U2 P. H+ d) z2 F0 sfor(int i=0;i<count;i++)+ \. g% v `2 c5 y( o6 H1 D
{$ q0 Y, }5 G8 T{
* W( Q( O4 W: }* l9 `! t. `! j7 M0 ^1 E# T! R4 Y2 A
UF_MODL_ask_list_item(face_list,i,&obj);5 b# M8 p. u# \# v, F5 S* d' a
0 n! K d$ \1 q/ V int type;
7 y4 C4 J/ Z. O0 d) C+ e# x( j3 M7 B2 v: j r# a4 h5 p" {0 \8 D4 p/ Z3 n
double point [3] ;
1 Y8 J3 t _* q" }% I1 g, r6 [& y* v9 J2 \0 I( y$ A X! b' k, }
double dir [3] ;& p& m/ K0 Q; [! X6 Q5 q+ d/ J
, w Y# `# c& M* C0 `. M% v( }0 @% }6 ^
double box [6] ;
" T9 Z/ p4 l7 }9 e1 P8 u2 q# |/ L e8 Y6 Z; T7 B
double radius;" y' N% G# V" Q) B! @1 t; P* z9 e
9 p4 w, q4 M9 Y! I: |
double rad_data;, ?0 ^" o( V/ ]' s% ~" x/ W
5 O0 i* b, h1 B int norm_dir ;
% C* F2 O0 A2 H# Q6 L) b; ^5 w/ E! E! R
UF_MODL_ask_face_data(obj,&type,point,dir,box,&radius,&rad_data,&norm_dir);//Queries the data associated with a face
# n j) p* T1 [8 K5 T( G
& w7 B. @7 e; d if(type==22)//“22”代表有界平面8 z% t' V4 |% g, n% B- ~
X8 y+ Q h+ X O" m/ L0 y
- Y0 ?$ ~& m$ H! e: w* Z1 V7 x z: X
if(fabs(point[2]-origin[2])<0.0005)6 m0 Z7 j, I0 F. @! h9 K
' z( T0 r0 O8 L5 _, |* @
1 B' h. z* p9 K3 M: h
2 X% P) z' w3 O( i bottom=obj;
. J5 h( m! n9 R! f* y" Y2 [. _2 W
* Z2 B' \, l# l8 s1 T }8 T* I) W. g) o3 {3 e
- } A: ]& U+ i5 T5 `
if(fabs(point[2]-value)<0.0001)
) t8 D. |6 B( D& d4 d U+ p! H F$ {6 @
- d! I# t% w7 R! i# W2 g% _/ n; ]; K& p& a
UF_MODL_ask_feat_location(obj,location);
' g% T1 k. H O
7 D8 u% H/ n5 B top=obj;
8 [2 `) F9 D2 z0 u; }6 f
4 x! G; e- w t }
, r, |8 ~ K/ R& l3 `: W" b% f" {9 u$ @
2 o3 @7 U& _* l
# Y9 V, K0 A, w9 N, [: F$ _}
" l A* N2 e5 Q9 X8 T1 ]3 M s# m6 c2 e! K2 t3 R D! m& `
UF_MODL_create_simple_hole(location,direction,diam,height,angle,top,bottom,&feature_obj_id); w8 B7 {2 t" ^5 I$ S/ q0 Q
# _+ a$ j9 y7 ]& z0 W* v
UF_MODL_ask_feat_faces(feature_obj_id,&face_list);; e1 v6 |* f! ~# d# V
/ c' s7 W$ V$ F! WUF_MODL_ask_list_count(face_list,&count);" P0 ~; L) n% i$ ^+ I
" z1 o) W" q$ }' E0 v! g0 mfor(int i=0;i<count;i++)
0 j, E2 R8 J* M( q c T; l3 T `+ v5 H* T6 o
{% f$ E+ x8 O- k0 J+ X" L0 r3 E
2 B4 B B0 G/ H9 Z5 J UF_MODL_ask_list_item(face_list,i,&obj);//Retrieves an object from a linked list of objects
9 O) ~8 z( N" j" ]- R
9 b/ Z1 _5 Y6 C, G% o int typel;
6 @) S4 s9 n5 [# Z+ s4 M0 Q3 P+ r+ h; r8 z8 G ?) O' B4 ^: F
UF_MODL_ask_face_type(obj,&typel);' e; T8 o; n. f6 c' d
! q. o8 A4 X- E0 |
//倒圆角1 v0 i/ t( _4 R) `
; Q, h. g4 F* F) p- w) _ if(typel== UF_MODL_CYLINDRICAL_FACE )
# X) d1 m9 l3 ~7 `, a" m6 _3 H' Y- g7 v
2 }4 x: ?8 } @: }% w( K
# \; j/ x2 r9 [( w, Q7 E. b uf_list_p_t facesl;
+ X+ |' `$ G5 ?( y- {
) G' O" q( H0 N8 s$ u( w UF_MODL_create_list(&facesl);
% S% D" A2 o* L9 J
8 l6 I, E$ E$ c! W. e1 ` UF_MODL_ask_shared_edges(top,obj,&facesl);# e) a7 a% x5 B* a2 A% a" h
) N3 E' y8 z% ?4 s const char * radius="3";
: G4 D3 ]2 |9 U: P# c
: p' F3 v) h( _: p' x7 I int smooth_overflow=0;
7 N$ M) A/ O5 e6 r8 L) j1 Y: [- ?) k- D9 f1 b& L) F9 W
int cliff_overflow=0;
& c- [5 g4 ~+ c: ]5 ^- S% ]
9 V5 t- v% {$ D5 R7 c* E int notch_overflow=0;, T7 S5 }8 Q( M+ z+ r
7 w2 J1 q% H; V$ r9 }: l& [) L
double vrb_tool=3;
+ e1 r# E% l- [4 G4 ?; H: [: D# }- }+ z) i6 b' O
tag_t feature_obj_idl;% H, S8 K `& p" r$ p0 o: G) n
+ [4 K- B4 i" J d3 }0 B- V UF_MODL_create_blend(radius, facesl, smooth_overflow, cliff_overflow, notch_overflow, vrb_tool, &feature_obj_id );4 X; B) s0 B) G0 K
o, q8 X c4 L2 q: e, t! {7 e- W5 K5 E5 j }
+ x1 g. O9 ]- N, _' W' i
7 |$ o$ Q8 P3 s% y& Y }
# S, ~; I9 d" e
8 ^2 W5 A+ |7 b1 p}
) Z; {2 S7 E3 w2 R! p! m
6 ^! [' t6 N8 g7 t7 }3 Q' ovoid ufusr(char *param, int *retcode, int param_len)( B% ]$ G7 h2 G
* c" n2 H2 j n/ z' m{
3 q& Q& s& ~, b. Z' h+ w& i( E) N$ T* x0 J0 D* \) x
if (!UF_CALL(UF_initialize()))$ s% l( V' Q9 }) @1 ?7 J/ N
- u" n- L$ ^. m2 Q; K" @0 M5 M {
. |+ Q' E# u Q
* ?& Q' A% X$ k$ r& ? do_ugopen_api();
0 v+ e6 k; s) r S! S" L( N O$ t& b
UF_CALL(UF_terminate());$ G1 v$ H7 j3 d' ^' U! o; w
6 |+ `/ U% S' Y( C3 w% a }6 s+ {, R8 V: {6 g+ k/ Q0 `
- {/ L0 x. M: F' v- V( ]& ?
7 J( A3 R+ @0 F" ]9 d3 A* A7 }
/ _; }) W( k: sint ufusr_ask_unload(void)9 @7 b2 i; p! ]% q# h; w B8 _+ m
* J3 R) w7 t8 v y{
' a' S2 ]9 `, Y2 C9 J' j. i! |* C1 c7 f5 I+ A1 q
return (UF_UNLOAD_IMMEDIATELY);
+ A, B) d: r, I6 t( j9 u2 u6 o8 a% \$ k) @, O
