悬赏88G币未解决
后处理检测问题,,很实用但是自己不会用,,求解,,代码下面有
0 E* y* q/ ~3 [) f+ N$ B2 ^& k/ d) w) u4 X
1.转速检测,包括最大和最小转速5 t3 u3 S0 v5 d% e9 O1 t7 A
if { $mom_spindle_speed == 0.0 } { ' J! G) Q5 Q% K, L
#MOM_output_literal " ( ZERO SPINDLE SPEED PROGRAMMED )"
- w) h( o7 F* U2 w5 t) g1 y#MOM_output_literal " M00 " & R. f7 s* Q+ d6 k- b
set mom_spindle_speed 20. ;# dodge div.by zero in tap
7 z1 T2 l9 T3 ~" Aset errmes "\n\n *** Spindle Speed Not set ***\n*** IN OPERATION $mom_operation_name ***\n\n" ! o; B. i; C; @7 C% r
MOM_abort "$errmes" 3 R2 {# C+ v% I' x
2 E' R- e& v) ^7 e最大转速 ( V: G0 e4 U! ?3 e( V
if { $mom_spindle_speed > 10000 } { 9 v; i0 P9 E) P3 X+ O, Y
set errmes "\n\n *** Spindle Speed Over Max 10000 ***\n*** IN OPERATION $mom_operation_name ***\n\n" " l) c+ g/ B0 O4 Z1 m; q( Q3 _
MOM_abort "$errmes" ; B3 @/ F# S, e9 L
8 b3 Y7 j+ g$ M5 [最小转速! M3 i, N+ J& ^' w' J# n
if { $mom_spindle_speed < 50 } { ( q) o: n0 R/ H: F
set errmes "\n\n *** Spindle Speed Under Min 50 ***\n*** IN OPERATION $mom_operation_name ***\n\n"
6 F2 f. [* W+ r) t# _5 i MOM_abort "$errmes"
. b t6 K; B+ C2 s" c2 m8 A% e* e# l' G5 `2 K& V% h$ K$ f" ~) O
4.刀具号未设置检测等../ ]- x8 A2 l9 b; t; x0 T) z
if { $mom_tool_number == 0.0 } {
5 \! K+ i5 O$ ^8 a$ M8 ~#MOM_output_literal " ( TOOL ZERO PROGRAMMED ) "
7 S2 F2 g& o* K1 T#MOM_output_literal " M00 "
, h* b* W D8 t( Rset errmes "\n\n *** Tool Number Not set ***\n*** IN OPERATION $mom_operation_name ***\n\n"
6 z6 m6 z) m v* p2 d MOM_abort "$errmes" ' y6 R9 q1 @6 c r) ]
3.进给检测" j0 ?+ O9 k; ?. y7 ~0 p8 k7 i
4.钻孔的安全平面检测0 s6 g: } ~# F E4 z
( h q1 b M, a. O) q+ L! {1 F
以下主要是钻孔的一些常用检测功能
& k1 Q9 U9 E4 o9 v# p# R) \global mom_cycle_retract_mode # h$ y% |( M, U
global mom_clearance_plane_usage
. P' @+ W5 J. s( B. G+ {global mom_clearance_plane_status
. z4 d T# |& u1 n6 v) Bglobal mom_operation_name
6 u+ t3 t4 S& ~1 Mglobal mom_cycle_cam
& ^, s+ F/ l1 B0 yset alarm 0
$ l, b, ]' v1 I3 hset em "\n\n OPERATION : $mom_operation_name \n\n "
& d- G- {1 n+ p/ W+ J& iif { $mom_cycle_retract_mode != "AUTO" } {
9 F) Z' U& a5 t: p7 ?, eincr alarm ' F% ]8 @% s' M- x
set tt "\n\n RTCTO Mode not set to AUTO \n\n "
- m& J! t* I1 X/ t! f" h# P set em $em$tt ) i, o+ _7 B. T# U. H5 s1 f( [( S
' @/ _- _, Y5 Y$ c& A* y, J& J; g# nif { $mom_clearance_plane_status != 1 } {
( o6 K+ B' L; M* z: i% b. @incr alarm
u" J, [! K' \. {& _5 ~set tt "\n\n Clearance Plane not Defined and Active \n\n "% p6 f8 A5 q& j2 p7 P% v! I+ G
set em $em$tt
- [; c2 _# r; {+ j/ u" Y }$ j" W: H/ i" W0 N
if { $mom_clearance_plane_usage != 1 } {
+ a# } _$ J9 S+ kincr alarm
* Z. z4 } H% s( w9 B# Aset tt "\n\n Clearance Plane not set to Start and End \n\n "# c, J# B* S+ e
set em $em$tt ' e8 k% p! l) q W% a. v3 M! P
}# F3 \% w8 V% a% V, @
" R: x$ b( w" q7 A1 n
if {[ info exists mom_cycle_cam ]} {
6 I- @+ l9 P2 @) `/ a if { $mom_cycle_cam > 0 } {
9 [/ \) Z2 k- G incr alarm2 U) N Z. p# `/ N3 O* y
set tt "\n\n Illegal CAM setting in canned cycle \n Set Spindle Speed on Feedrate Dialog \n\n "% J5 z% K+ e; x
set em $em$tt
# T1 ?! z( e! N, Z }
4 H. D$ ?' T. C5 w" `3 _! D* Q }
3 [' z7 |5 V5 U# L! g1 z8 pif { $alarm > 0 } { MOM_abort $em }
9 S9 M, b' N7 w0 \: W2 v0 F+ O}3 ^9 V! z2 D9 f0 s+ X
