看看这个可以吗?: ]: G3 c* J7 L! ?9 N% ~
列出信息创建者: Administrator: r' B( y) N4 ~; y* B- Q
日期 : 2011-7-16 12:57:00
8 ?6 I% ]/ z9 U2 C当前工作部件 : F:\lianxi\b1.prt6 ]; K2 s) g" \: Z6 g4 z
节点名 : microsof-e8f1586 P R2 R) T( N) a3 M
============================================================. c" l/ S" g; z' P0 e
; POSTPROCESSOR NAME
* Y) v% M5 I. |. W/ A* r! x& a' y; F:\UGPOST\WSS\3+2.TCL )
: k( ~! x* ^8 J q;
1 f5 z% f* t0 g$ Z. C; {BEGIN PGM 100 MM, L4 O$ }% @5 `3 D3 ]5 K
BLK FORM 0.1 Z X-100. Y-100. Z-20.
* O: l* X8 u* V2 z7 r+ s/ EBLK FORM 0.2 X100. Y100. Z0.0' T1 g k R4 n
TOOL CALL 0 Z S0 ;(TOOL name: D3.4 )
, r5 U' O, H& jL M3
7 u9 D- b) q& Z1 B- r0 z' qL M129
9 t9 p. ^/ |5 ^! B; TL M127( G4 ?2 @# O. t U! m5 K
L Z550 R0 F5000 M92
6 u* D0 [) R4 C! }% W1 d! _L X350 R0 F5000 M92( f$ _$ i0 q8 y
L Y300 R0 F5000 M926 ]- K& r! g6 D% [
L C0 A0 R0 F10009 x0 |+ O. c/ f
CYCL DEF 7.0 DATUM SHIFT) R4 y% s+ r: A1 B' \# H m
CYCL DEF 7.1 X+0; I- ?( Q. f$ |" K
CYCL DEF 7.2 Y+0& x1 d; R8 J/ A/ @% Y
CYCL DEF 7.3 Z+07 F4 i# c1 \0 e, }# Q' r% H' k
CYCL DEF 32.0 TOLERANCE( S5 }! R3 z) T* c2 r; }1 Z" g
CYCL DEF 32.1
: M6 y% e, q# c$ V! J3 ]) c2 [) ^CYCL DEF 19.0 WORKING PLANE8 G g" }' m1 S9 ^! u
CYCL DEF 19.1 A+0 C+0' D O' r/ |- Y, y6 d' C2 e
CYCL DEF 32.0 TOLERANCE0 e* `" }# ?, e. Y& n+ D/ i1 b, _
CYCL DEF 32.1 T0.01
( f' T0 R" H: \' ?, _, T3 EL M126
9 M% p" Y0 d1 T, i: W2 n6 u0 w NL M11 M165 a4 e3 A& Q+ ] W6 u4 h p
2 u3 G7 i- y! R g6 ]& ZCYCL DEF 19.1 A19. C90.+ v. k2 l' s1 L7 h8 i$ ?5 S2 I9 A
L A+Q120 C+Q122 R0 F5000
5 F0 t) t6 a% ?3 RL M10 M15
8 X- ^$ T$ d8 q+ TL X0.0 Y-25.394 F MAX7 L6 \3 E+ c& Y5 C5 ]& |5 c
L Z54.25 F MAX
5 c/ z6 ?6 Q$ j# R* D `CYCLE DEF 200 DRILLING Q200=50. Q201=0.0 Q206=250. Q202=0.0 Q210=0.0 Q203=4.25 Q204=50. Q211=0.08 D9 F! X W/ w" ?7 g& D+ V
L X0.0 Y-25.394 F MAX/ k9 t% A/ B0 }* @ X6 i
CYCL CALL
; G+ p5 z- |6 e' g% n/ wL M140 MB MAX4 ], c, f. D7 P! \: {' l1 G, v3 o
L M11 M16
$ g0 K+ p c7 a/ ^/ Q, eCYCL DEF 7.0 DATUM SHIFT
. V8 W( E( P, B& Z" cCYCL DEF 7.1 X+0
, ?8 X+ _( A9 C: v( T2 m( y9 _CYCL DEF 7.2 Y+0
2 K( f: ?/ j7 ^8 o- }CYCL DEF 7.3 Z+07 Z6 P1 e9 ~' z: q
5 W4 p% Y* G* P4 N6 ZCYCL DEF 19.1 A+0 C+02 M" O: P: R8 G4 r! y7 a
3 ^5 `' p: A6 rCYCL DEF 19.15 Y( B4 ^$ g4 ]6 \
4 u$ o. Y0 \( w: H# J! bCYCL DEF 32.16 V% e# [* m$ O/ C9 N' W8 k1 I& @: L
L Z550 R0 F5000 M92
9 {/ s3 ]: l5 D: UL X350 R0 F5000 M921 _4 l! P" U1 c5 p( x( a: z
L Y300 R0 F5000 M92
0 e, B1 i `3 w% I, d, X1 DL A+0 C+0 R0 F2000
) v7 R) I- o* a- T5 jL M1277 B/ g9 s0 |. E4 d* R
L M5* [0 o' h& Y0 h$ o6 T$ U
L M30. [. b' y. U4 t P, L" U
END PGM 100 MM |
