查看: 2296|回复: 2
程序贴上去,找人帮我改,谢谢
发表于 2007-9-20 14:18 | 显示全部楼层 |阅读模式
拜求解决方案
entity/ln1,ln2,ln3,ln4,ln5,ln6
8 H! W9 R, F. z0 ~# C/ q" k) Gentity/ps(6) % t3 K1 t' y) O' i# {
entity/cur(6) 0 z; |3 k7 j4 g( \3 L6 q
entity/obj1,obj2,obj3
9 E' O$ X2 d4 n8 n; D4 O/ T) K6 ~entity/pt1,pt2,pt3,pt4,pt5 * ?4 O& @3 k( V$ [" `0 u7 N
entity/pl 0 R6 D' R: R. u. k) w
entity/grp
4 Z" j" {) F" Y  H" t' y0 gl100:
6 E7 ?- z6 I) k$ j' K     pt1=point/-2,0,1
2 r# _9 X% r" R# j. W     pt2=point/-2,0,-1 5 C7 w8 ]2 @# F* J5 N
     pt3=point/1.7,0,0 0 U3 K6 U$ C# {% C- T6 _
     pt4=point/-4,0,0
, V  w  D* i- F, q2 D     ln1=line/pt1,pt3   w$ j% R& f2 ?8 g/ l
     ln2=line/pt2,pt3 ( r" b9 Z1 i2 W+ H" ^* o* C3 d4 _
     ln3=line/pt1,pt2 2 y# f2 U7 |9 {6 m8 |1 X- o
l101:
% J) E0 Q: S4 ]4 w& v3 n# K+ G3 z. D+ k     cur(1)=line/parlel,ln1,zlarge,2
2 ~  ~7 e0 U5 q     cur(2)=line/parlel,ln2,zsmall,2 # G0 V* i$ E' R2 O* X
     cur(3)=line/pt4,parlel,ln3
7 r6 Y6 t8 x( l6 j     cur(4)=fillet/cur(3),cur(1),center,pt1,radius,2
6 V8 B% C. s1 l- ?$ g* ~  ?     cur(5)=fillet/cur(2),cur(3),center,pt2,radius,2 % B5 L2 _; `9 B, n  ]- s& O
     cur(6)=fillet/cur(1),cur(2),center,pt3,radius,2
& g" D6 l) ~1 m1 I9 s& ?9 j     grp=group/cur(1..6)
6 C7 y; J3 k; Y6 k# X! T8 Fl102: ) k3 f3 N) A) a' o1 n9 z6 M
     ps(1)=point/2,-5,0
% v6 f6 h# j, n( h7 s! e     ps(2)=point/2.3,-4,0 % ]4 G. w+ |! D5 r. C! v
     ps(3)=point/2.7,-3,0
2 Q; u# j! y+ [9 K/ T7 }     ps(4)=point/3.0,-2,0 3 G9 x3 F2 ~+ y3 g/ U( c
     ps(5)=point/3.4,-1,0
" M, `4 M2 V* V% }- o: {+ P     ps(6)=point/3.7,0,0 & x/ A- d" V+ d- d9 t5 ~
     obj1=bcurve/ps(1..6),degree,3 ( C- R" q- W* T. |7 l& h3 T, w
l103:
2 y3 m4 j; r% W) z( a     ln4=line/-4,0,0,-4,-5,0 5 ^* {& I- o' b4 x
l104: $ h  U' q6 r' \8 [4 ]2 k
     pt5=point/0,1,0
; l) [, `, A' }5 x5 [( E     ln5=line/pt5,atangl,45
' e& l( p* v& U: ~     pl=plane/perpto,ln5,thru,ps(6) $ E) u4 j6 X7 h! N3 i7 r
l105:
( O+ F( [- ~/ M% F3 q+ j) f     obj2=solext/cur(1..6),height,4,axis,0,1,0 ' @1 D6 v# a; i) Z- |" a: @
     obj3=solcut/obj2,with,pl,cnt,c1,c2 8 t: d( e5 N* ~" Y' q
trm: ! e. s% Y2 h$ n4 }' X9 S5 z
halt ' f' K: q6 _6 E3 f) C4 |; ?' Z
我写的程序,我想通过曲线OBJ1和直线LN4导引曲面GRP,并将OBJ3其中的一部分删去 怎么做啊
4 a; S3 f1 }& L8 u  L3 t
发表于 2007-9-21 09:38 | 显示全部楼层
entity/ln(6),ps(6),cur(6),obj(3),pt(5),pl,grp,TE(10)$ M" L% v/ V5 `( N. j
8 m& l$ k, x% z. E# ?1 L2 G8 s' p7 n: }2 Y  W9 t& c
     pt(1)=point/-2,0,1
3 E( }. T$ f: P# N1 |5 w+ w     pt(2)=point/-2,0,-1 " H3 F# K1 }; L) M8 N" t
     pt(3)=point/1.7,0,0 ! {9 x; s) ~/ _
     pt(4)=point/-4,0,0 & |; [; P1 M; p; X/ l9 [
     ln(1)=line/pt(1),pt(3) - y/ H# E) L& h; U/ x. z
     ln(2)=line/pt(2),pt(3): N6 U# j* a+ Y5 n' `
     ln(3)=line/pt(1),pt(2)
' ~& B0 o! Z9 r* M) T9 v5 y
) S: }, D/ ~1 Q/ z# R3 }) V! i& J
; q( Y" s. y/ W- Y& u+ a: Z, C8 [     cur(1)=line/parlel,ln(1),zlarge,2
1 A3 ^, [# B/ {     cur(2)=line/parlel,ln(2),zsmall,2 " S1 |0 R( h! i3 f
     cur(3)=line/pt(4),parlel,ln(3) 3 [0 h: `; H2 Y
     cur(4)=fillet/cur(3),cur(1),center,pt(1),radius,2
; j2 J  Y) I4 ~9 w8 i     cur(5)=fillet/cur(2),cur(3),center,pt(2),radius,2
$ {) p+ f6 ]0 y. W1 D7 L- a7 V+ _- x     cur(6)=fillet/cur(1),cur(2),center,pt(3),radius,2 - G# K+ ?) S8 c
     grp=group/cur(1..6)
/ y' k' F4 ~* }; {; @4 K% |$ R
9 ?4 L- v  X3 w8 G3 F     ps(1)=point/2,-5,0 3 H1 F+ }; v8 i4 A
     ps(2)=point/2.3,-4,0 6 r1 _  o- n! v& ?5 K  w3 W
1 w2 e+ p, }7 T     ps(4)=point/3.0,-2,0 % n6 ?/ L5 y+ {) k/ l7 V$ W& v$ j. S
     ps(5)=point/3.4,-1,0 7 ?. K5 X! S: V7 a- }5 E1 J  P
     ps(6)=point/3.7,0,0 , o, o) T& V6 L6 c! p# G$ d8 S% f; a
     obj(1)=bcurve/ps(1..6),degree,3
/ z0 U0 r; s8 I" b0 \
! [. E/ _  r7 j  U, | , Q% a0 @, u" e- B
     ln(4)=line/-4,0,0,-4,-5,0 . @$ v0 d- O4 A- J# L
( H, r1 ]0 O) Z7 i) I$ Q0 j& _4 `     pt(5)=point/0,1,0
# o. ~7 t% u% J- }3 Y  I     ln(5)=line/pt(5),atangl,45
( x- W6 z0 {- W' c0 c9 g0 P     pl=plane/perpto,ln(5),thru,ps(6) , {  Q4 U% I/ b( C1 |
. F5 E& `8 R+ H7 t
" b; _9 S$ V8 ~8 f: A
     obj(2)=solext/cur(1..6),height,4,axis,0,1,0 # d5 ~$ _+ d8 {5 ?  T  @! v' G; I3 |
6 u5 R. C& t" B& d5 C3 @$ ]) Y% T
     obj(3)=solcut/obj(2),with,pl,cnt,NUM,c2
+ R2 D' b. B/ ]& E5 v: U; l( i2 F, V/ P
; f2 V: }# t" M$ g  j
    MASK/709 S. l9 r6 }  K, |
l100:
; ]2 F  M6 _5 l/ v( q& f    DO/DOL90:,I,1,NUM, m" |- w9 b1 W" J2 G/ d8 h
        TE(I) = NEXTE/IFEND,L200:- m8 D9 h1 p, y8 K& e# _7 L
    DOL90:
$ D8 X' y; A2 F6 m9 F# rL200:% y  q& S, `5 }1 X1 K4 n; [+ B+ W. H  d
        DELETE/TE(I)
  t( G5 n$ m( o/ h- p$ Y9 a2 C
4 W2 q/ ]4 M3 s; C  Ctrm:
. O3 k1 @( t& b$ k0 Ihalt
评分
参与人数 1流量 +5 技术 +1 G币 +1 收起 理由
xcb + 5 + 1 + 1 技术解答
查看全部评分
 楼主| 发表于 2007-9-21 10:20 | 显示全部楼层
还有一部分要请教
在我的程序中间不是有一个GRP吗??我想通过obj1和ln4导引,通过扫略形成实体,我试过N多次都不成功,不知道试为什么??) p$ |- k8 v3 \( l
还有我想了解一下你,你是做什么工作的,你对UG好像很了解,以后向你多多学习
GMT+8, 2025-8-26 20:52 , Processed in 0.059304 second(s), 29 queries .
