在ug中设置旋转点经常用到,不过只能查看模型中间想设置旋转点时,只能缩小在空白处点右键才能出现这个选项。
" {! ~' Q- J- j s$ r. a8 z" W% W2 ]7 Q/ h2 a( k) b2 M% d
下面提供2个方式设置快捷键
5 E$ l- P* f8 b( ?) J- M$ G$ P/ r* _0 U3 t! T! B) N6 a( O% W% {; V+ J
方法1:直接给【设置旋转点】增加快捷键,例如:ctrl+q、F9,之类但是不能设置成单个字母 UGII\menus 目录里ug_view_popup.men时存放右键菜单配置信息的文件。 在里面找 BUTTON UG_VIEW_POPUP_SET_ROTATE_POINT项 添加一条ACCELERATOR Ctrl+Q 修改后信息“ BUTTON UG_VIEW_POPUP_SET_ROTATE_POINT LABEL &Set Rotate Point MESSAGE Sets a view rotation point for the view where the point is defined, to perform all subsequent view rotations about this point. BITMAP rotate_about_point.bmp POPUP_LABEL &Set Rotate Point POPUP_MESSAGE Sets a view rotation point for the view where the point is defined, to perform all subsequent view rotations about this point. ACCELERATOR Ctrl+Q ACTIONS STANDARD ” 方法2:直接把【设置旋转点】添加进右键拖拽菜单
6 ~! ~, u, Y% M$ A8 v, {9 ]2 Q' {
# d: z* l- M" _1 V/ K但是按这个方法设置后,在右键菜单中就没有【设置旋转点】这个命令了
4 B4 u1 f$ w* j, ?; Z3 W& |
) I0 c* y9 ]. B( O7 ?' @# R# M/ H8 ^$ i8 K
- f$ q: ]# o# V0 y: P3 o
/ Y4 G6 w8 m1 `/ S6 r3 I打开 D:\Program Files\UGS\NX8.0\UGII\menus\ug_view_popup.men文件 查找“MENU UG_VIEW_POPUP_RENDERING_STYLE” 在下面添加一段如下代码 BUTTON UG_VIEW_POPUP_SET_ROTATE_POINT LABEL &Set Rotate Point TOOLBAR_LABEL Set Rotate Point MESSAGE Renders faces (in the view where the cursor is positioned) with smooth shading and lighting (face edges not displayed). BITMAP rotate_about_point.bmp POPUP_LABEL &Set Rotate Point POPUP_MESSAGE Renders faces (in the view where the cursor is positioned) with smooth shading and lighting (face edges not displayed). POPUP_LOCATION 4 ACTIONS STANDARD " e7 t) U" U6 w6 o3 H. x8 b
7 l+ {$ t: G( @! ]0 F4 G/ {: |
v7 g* E$ E" w- N1 v3 w
# h) v6 k: ~$ U, I
( v# ~* _) u7 f6 N7 d7 X/ j
7 s5 G" r, ?* p% u, K补充内容 (2011-9-28 11:42):
- k; Y4 X! T1 Q4 W$ f' K* i 上面的代码只适合8.0使用
0 @6 O7 e8 h( }. z6 f' ~! B" g1 V1 G/ j. n
7.5的请使用以下代码4 E. s- k% R2 Q3 K9 S- ^9 \, {- g
, T: D6 h% |8 K$ \; h
BUTTON UG_VIEW_POPUP_SET_ROTATE_POINT& D6 z" n1 |( J% U( U" i" s
LABEL &Set Rotate Point* R" e. q- }) Q) r
MESSAGE Renders faces (in the view where the cursor is positioned) with smooth shading and . R1 h- N' R }* ^; @
6 E1 ] W4 x; P; ~+ n6 F& R) V# y补充内容 (2011-9-28 11:43):) K" I9 F; z1 j! ^
7.5的请使用以下代码8 i1 a1 s O! f6 X/ T
% u" e' P9 C) U; Q$ i0 R0 x* _http://bbs.uggd.com/forum.php?mo ... &fromuid=413105 |
