楼主的启动方式怎么和我的满像的呢
! U7 a0 }2 V5 s2 k, P6 l1 w, W4 l8 C0 \7 Q/ B# r! o% q
也晒晒我的启动方式吧.ugnx8.0
4 d3 R; Z: F7 U% ~! n9 ^ M
0 @ W4 v' T5 X; @# q& g: Hcls
$ D; L8 [5 \1 W H% g p8 Crem cd\9 m) O6 L) Y' w$ Z3 r& S$ N7 w
set u=%cd:~0,2%
$ E+ Q5 t8 k A- f; r6 r; jecho %u%: g% b( q0 h3 [) o3 m2 i. @
set UGII_BACKGROUND_URL=file:///d:/my_folder
2 _# u! E6 T' Z" z+ N0 Tset UGII_BACKGROUND_PICTURE=%my_config_dir%\menu\ug8.jpg
; I& F1 N! y5 |9 o% Yset t=D:\Documents\desktop
f/ r1 q, ~" Q" ?" ^rem set UGS_LICENSE_SERVER=28000@yw-PC
$ t8 T) D. o0 e7 i, `set my_config_dir=X:\my_files\nx8.0.cfg
% z4 |* G8 S1 H$ {( M: drem set UGII_GROUP_DIR=%my_config_dir%\guoup0 L% U; J; i& \7 u2 L' H8 T
rem set UGII_KF_USER_CLASS_DIR=%my_config_dir%\
9 g! t9 ]0 V5 q8 Qset my_folder=d:\my_folder$ @# y$ ?6 P. U; s" M
set ugii_base_dir=D:\my_program\NX8.0_X32
9 V* ^ e% G x6 cset ugii_site_dir=D:\ZH_NX_X32+ b4 z& y6 b" i
set ugii_fztooks=%ugii_site_dir%
7 G6 t% l6 ^; @4 i1 zset ugii_vendor_dir=D:\HB_MOULd
6 I- F$ U' F9 l. Oset ugii_hb_mould=%ugii_vendor_dir%0 g d* n! ^& m' C
set ugii_user_dir=D:\TMJ8
" a6 V$ B+ t* U1 a0 J8 Iset ugii_ju_dir=%ugii_user_dir%# D9 \5 D% N* g" o8 k
rem set UGII_LANG=simpl_chinese
% r2 w1 S7 D( {: Crem set UGII_MOUSE_WHEEL=29 u1 g( \! e5 S' |% G- [" G( p
set UGII_CAM_FILE_SEARCH_PATH=.\;%my_config_dir%\mach\;%ugii_base_dir%\mach\;%ugii_base_dir%\mach\resource\
4 j( p4 m* z3 l' W) N6 }% }set ugii_local_user_defaults=%my_config_dir%\menu\user.dpv a3 ?. J. t4 W( v! @
set UGII_LOCAL_USER_DRAFTING_STANDARD_DIR=%my_config_dir%\menu }# }; |5 Z+ m- s- A
set ugii_smp_enable=17 m; o( K' i7 J
rem set UGII_UTF8_MODE=11 x1 ~3 E- c& _/ n) O
set ugii_root_dir=%ugii_base_dir%\ugii
% Q! `' s V$ Q2 H0 ]set ugii_cam_post_output_dir=e:\nc- R' n/ M% s5 ?' ~: p2 g2 T
set ugii_cam_setup_root_dir=e:\nc
. d+ j: I; B s2 L1 k, V) \; Hset UGII_PDF_OUTPUT_DIR=%USERPROFILE%\Desktop
5 ^/ U( I2 Z* V( x8 kset UGII_DEFAULT_ROLE=%my_config_dir%\menu\user.mtx
0 c+ w- e' S+ E- o7 U$ Q- Jset ugii_sdi_server_cfg_dir=%my_config_dir%\nxplot- d5 O" W' Q j# r/ R" N4 y
set UGII_EDITOR=D:\my_program\pspad\PSPad.exe# Q, t; b# p# n. \& G+ ?; d0 ~
set UGII_COUNTRY=prc
8 Q* i8 Z7 {: X& Pset UGII_COUNTRY_TEMPLATES=%my_config_dir%\simpl_chinese+ x U! r* C2 a% [7 `; ^
set GEARWIZARD_DIR=%ugii_base_dir%\localization\prc\GearWizard( b7 c$ L/ d3 P# L1 e
set ATTRIBUTE_TOOL_DIR=%ugii_base_dir%\localization\prc\AttributeTool
( V6 M$ ?9 z; L0 B8 b Bset UGII_CAM_POST_DIR=%my_config_dir%\mach\postprocessor\2 }7 N! G$ N, a; z& O6 H- C+ ~
set UGII_CAM_TEMPLATE_SET_DIR=%my_config_dir%\mach\template_set\
( A6 k3 L$ D9 I: G8 r. kset UGII_CAM_TEMPLATE_PART_METRIC_DIR=%my_config_dir%\mach\metric_ansi\# j: F8 f Z# \
set UGII_CAM_LIBRARY_TEMPLATE_DIR=%my_config_dir%\mach\template_dir\
+ q8 z: t" Q! {2 G7 |; u& {set ugii_cam_use_true_ref_tool=1. N+ W8 W% ^0 ~- m, q4 R
rem set CGTECH_INSTALL=D:\my_program\cgtech70
+ z! o5 f, f; c8 ^7 t' n6 ]0 v7 q! Grem set CGTECH_PRODUCTS=%CGTECH_INSTALL%\windows; {& |1 j- ?$ ^8 k+ f/ m6 U
rem set CGTECH_CLASSES=%CGTECH_INSTALL%\classes/ r: k( |1 o9 k- `9 i
rem set CGTECH_LOCALE=chinese_simplified
5 t5 e: V; D4 F' Lrem set LSERVOPTS=D:\my_program\cgtech70\windows\license\cgtech.lf -s0 n2 |# T5 l* `9 P
rem set UGII_VERICUT=D:\my_program\cgtech70\windows\commands\vericut_chs.bat
4 E( U" G+ R+ W' O7 j* g. ?4 `rem set UGII_CAM_LIBRARY_TOOL_METRIC_DIR=%my_config_dir%\mach\tool\, P; [' k5 h8 y
rem set UGII_FEAT_FAILURE_REPORT_TEMPLATE_FILE=%UGII_ROOT_DIR%\xsl\FeatureFailureReportTemplate.xsl
2 f& {0 l) U2 l! Y& Z5 e) crem set UGII_ONESTEP_ANALYSIS_TEMPLATE_FILE=%UGII_ROOT_DIR%\xsl\OnestepAnalysisTemplate.xsl
) c4 t5 R. |; o) L3 Nset GC_TOOL_DIR=%ugii_base_dir%\localization\prc\gc_tools+ @, ^" f7 U, B o
set UGII_TMP_DIR=d:\ugii_tmp_dir
9 \8 q: B# m+ S; @set PATH=%UGII_ROOT_DIR%;%ugii_base_dir%;2 \ B# u9 W& g$ H
start /d %my_folder% "Title" "%UGII_ROOT_DIR%"\ugraf.exe -nx %*
& w* P+ I3 T! f
" _7 O3 x. _( T% G$ P; H5 ^
) z# {- `7 ?6 A- [+ Q加上,金山快盘.哈哈.走到哪儿用到哪儿 ,
8 q5 |6 Z! X4 ?0 `4 p |
