楼主 |
发表于 2011-10-24 08:46
显示全部楼层
循环命令
5 Y" b4 ]( R, ^, @b = 曲面 box,) p5 c# N( k- y7 q0 S7 U, D
t = 以平面修剪实体,! K! w: h8 A& T
a = 通过一点一视图面修剪实体,& }2 D, t% j0 F* m2 e
s = 以平面分割实体,; J1 u, v+ a$ ]3 R/ S& v
o = offset,
6 I* @, a9 h% |* {0 x. gr = replace,
& n _; z+ t/ w- @e = 拉 伸,
: z' l, m" K; [: m$ ?. P0 E/ j# _+ qc = 基 准 台.
- Y7 Z) R. H9 B循环命令的顺序(可以增加和减少命令)& E( Y, k6 E2 k
cycle_order:6 S& b) e* o, x5 j) _+ |2 w
b,a,t,o,r,e,c,EOF% W# E$ Q5 j( }* g. K% Y
. K& l, N4 `/ S: w; \5 H6 ]# @
基准台的xy单边宽度预留量
3 l: c* v! q4 u, O- bbase_x_and_y_wide_offset:0 O X7 G3 Z0 I" W6 n
4,EOF
2 f- |5 M+ V Q, y5 I ~0 L4 M* n' {. A6 W5 q: O
多个铜公排成条的y方向的规格 ( y )$ G, ]. [1 M0 Y( ~ s7 B
pw_elec_material:: h; a- N! p5 N, H: k4 y. y/ O
20,25,30,40,50,60,70,100,EOF
! J% g+ _; G( K9 w9 w1 o3 ~9 ]$ @8 C9 v+ h
开料长度的预留量 ( x 预设值 )- I( t f6 _# r* Y, G& {
kl_x_stock:+ S H3 _" e; q# X
2,EOF" U' W* J8 y$ f* m
4 e7 N8 g8 W, {: B' B; Y2 X, d
开料宽度的预留量 ( y 预设值 )
' o9 j% Q' p. [; W( m2 ?( Hkl_y_stock: Y$ t7 W5 a4 ]9 V3 R' T1 W2 H/ L
2,EOF
& Y" q; J; ~9 r
2 s) e$ ?: K0 ?! A5 }' D% \! Y开料高度的预留量 ( z 预设值 )
8 b1 n. I8 @+ Fkl_z_stock:; e3 b% F* ^: N6 P' M- f; r
10,EOF
. C* r" A: @- R/ U* P% q- w4 }5 |. t# }
开料的宽与高的规格( y and z 要按料的从小到大的顺序排列,y方向每一种规格的料占一行 )3 Y! d7 _3 ^2 Q! ^; o0 }
kl_yz_material:! u# Y: y- b& a8 X, \' E
19x25,19x31,19x38,19x50,19x70,19x100,; q+ g" v) ^% ]5 X+ o. P; g( W
25x25,25X31,25x38,25x50,25x70,25x100,5 y5 e( o3 t! ~, f6 L3 P
31x25,31x31,31x38,31x50,31x70,31x100,8 i3 ?/ Z2 n/ E' H7 t8 i b6 l
38x25,38X31,38x38,38x50,38x70,38x100,( O @, P" f A6 v3 [. } x
50x25,50X31,50x38,50x50,50x70,50x100, D% w- m+ y& [7 W9 _# d- C
70x25,70X31,70x38,70x50,70x70,70x100,
: t& W# T0 R5 n100x25,100X31,100x38,100x50,100x70,100x100,EOF6 j; p$ v( Q9 n4 K' j
5 D& o0 Q5 z$ ^' j电极粗公的默认火花位
, w- o$ Y0 d7 L9 Z$ ]' |elec_rough_space:: q% k# h) T8 V; j
-0.2,EOF; r7 o" t1 I* }8 l! `0 L* b0 O* I1 u
电极精公的默认火花位4 v2 P; z, g/ S8 v- y
elec_finish_space:, ]" K$ _( N/ M) S& X
-0.07,EOF
7 f2 q2 Z1 t2 o* N0 \' n
0 {9 N# |: I8 z! W5 J+ v* J( K电极粗公的默认数量
8 k3 C' N/ q+ c" A) eelec_rough_number:% `& |: e) R! c: L* ^ Y b5 R
1,EOF
' \$ Z& Q5 k4 C" i电极精公的默认数量
5 g) v. ^) R3 W) t6 Celec_finish_number:
" n8 g( J5 t! }8 O. x1,EOF
; `8 o% m+ m" ^+ @# j" @; S: K8 A9 ]( m1 j; ?. K2 z7 i
后处理的默认目录5 j" h1 g- \& d! v# r
post_folder:
& T2 S: h4 {6 tD:\,EOF
$ E9 ]/ m& I5 W0 s }9 c
3 T5 b( A# i. b) e s- Y7 a8 h: H2 n9 N' J! H1 l
后处理的机种( 共提供5种机种,如果你要添加或修改这些机种名称的话,你也要添加或修改后处理4 X$ D% M, r1 r' F2 s7 ]
模板文件“template_post.dat”中对应的机种名称。
9 ~. S: T, e. |" ]& B$ S6 t( J 目前只提供非自动换刀的自由选项,如果你们公司需要自动换刀的自由选项,请联系我们!)
- _1 F) [0 h8 z/ g, d# W0 M2 ppost_category_1:
0 w7 q: s8 i8 Y6 o西门子_ju,EOF9 F d! P9 D, N$ v+ H
post_category_2:/ Q! ?$ h# ]3 L( y
法兰克_ju,EOF: Q5 j% n# [# m3 D- O @
post_category_3:7 S6 [0 O1 Z( w6 Z; p
三菱_ju,EOF
+ L- ]: j- {& _post_category_4:9 R) x; R# V( H( u$ d* U
空的,EOF5 f$ |. R2 c# m6 c6 ]: k' O
post_category_5:$ V3 g, M2 _# A( Z" O2 U
空的,EOF
4 N' F- _( M0 M& H; h. H, u: ?5 r s3 D/ D: d9 X: Z
: Y* G# R* I, g% T
默认的后处理机种 ( 如:上面的机种2对应的是“法兰克_ju”,你在这个参数中输入2的话,2 a* p+ O7 f3 T' x/ u8 B9 X
在后处理对话菜单中默认的就是“法兰克_ju”机种了。)
1 L' t; G* A+ Fpost_category_default:
8 Y& k' G- E! r3 S2,EOF8 |/ Q4 c; D. q' t* e% \
% F/ K9 K& a; ^
################################################, V' J6 Q+ U& t: I# P6 d8 r
实体自动著色的数据
8 l, }3 N7 ]+ i0 [7 }0 n+ CR圆角的颜色
4 L# d# }% S4 R' Z$ tr_color:
$ L0 x; \. X2 [% R7 G150,EOF
3 u. ^; _+ {# [# U0度面的颜色
* q E& j$ P9 r' n' Mangle_0_color:
0 ~, P$ ?& b) s/ p6 \175,EOF$ [/ b% t0 m( k( E) {" Z% i
大于0度而于10度面的颜色9 Y7 ?" f9 Q/ n* G1 `6 w& Z. ?
angle_10_color: A6 r: x+ X4 Z- D
128,EOF
+ S2 {' T& [) l& k大于或等于10度而小于25度面的颜色2 ?3 n, e& A! Z2 l0 X
angle_25_color:5 d9 f r2 I! s* u4 l- D& Q
109,EOF( R! Z, s. \/ n' D
大于或等于25度而小于45度面的颜色
; h# L! L6 z) M+ Q# _angle_45_color:+ O) q- ~. z" L; r& n! x
75,EOF
7 C' M5 ~" M+ H* y大于或等于45度而小于65度面的颜色
1 ]* B8 L* S. @* v5 O6 L% T2 ^' n9 qangle_65_color:
, x7 u2 `+ s+ T) ^) d$ Q55,EOF* Q/ _/ B# J3 D! H) I9 S% B
大于或等于65度而小于80度面的颜色2 T: J. s$ m# x: U( W$ b9 r, a6 M3 ]3 e2 r
angle_80_color:
+ z/ \5 K% j( U/ s& ~3 f20,EOF
, \2 s1 R; W* t6 S0 G9 z大于或等于80度而小于小于90度面的颜色/ J$ }5 w# X u" ^
angle_90_color:8 x. [! Y/ |( f# c. j( l
117,EOF
" S. S. v9 Y' n J* m+ R7 R垂直面(90度面)的颜色4 w3 u* l3 H8 ~
qz_color:
6 k. f( a9 l3 s: J2 H1,EOF2 a, {* n2 B- ~3 V3 G
倒扣面的颜色7 {8 F# M: _5 X# p
fs_color:
* p6 k$ P+ d. x; d7 H! k. {3 w6,EOF
7 a: } H- V# L! j#########
- k3 R8 E. x+ k! Z+ D手动设定曲面颜色的数据
# I) D* @6 Z) Mset_face_color_menu_1:
. `0 j8 h' J$ h+ s$ X第1种颜色--红色,EOF
% Z2 ~$ H* E+ u) K' y8 Y$ Bface_color_1:
3 c) c9 c Y! Y* D. x: b9 s9 y186,EOF
. i+ F$ `! m5 Z0 W' Z$ Eset_face_color_menu_2:
- g5 ?+ ?) y9 ^) u. V第2种颜色--白色,EOF0 O: w' g. h" }5 V! @" s) g
face_color_2:9 F! z. ^! z. }. j! p; c0 p4 J2 }. X
1,EOF
6 Y3 c+ k" E) C# u2 ]) @* J, mset_face_color_menu_3:
( e/ [; @ z: u) h9 m) W c5 s第3种颜色--蓝色,EOF, g$ ?& E7 l" `6 Y
face_color_3:
p: T" g t2 m7 l( i211,EOF# w5 H# B/ f K
set_face_color_menu_4:! m) x( I; y% i* |% A/ N+ r' G+ a _4 _
第4种颜色--红铜色,EOF
! T. b# B' W" q0 u3 @+ uface_color_4:
: T% a0 ~1 U7 F; I9 I114,EOF9 `7 p1 L! T5 G1 N, C
set_face_color_menu_5:
$ a) q: @& D' V: V第5种颜色--紫红色,EOF
, e! J6 @ a8 L f1 Cface_color_5:
" I u0 \' R- ^181,EOF
! L2 [ o/ c3 |. o' E4 xset_face_color_menu_6:' e4 H. ]$ V2 j+ O
第6种颜色--淡白色,EOF
. T6 Q1 F3 c9 g* X1 m9 I# uface_color_6:4 L' ^6 { Z$ g" O1 j$ L
38,EOF
+ X# n1 J- e, J4 Jset_face_color_menu_7:
$ E7 d F# u8 q' Z5 V第7种颜色--淡黄色,EOF
# T3 B! s9 _* ~7 Mface_color_7:1 E4 W2 |/ t; J3 L
125,EOF8 s/ g4 `& W, `1 \$ G8 o
, k: b C- U" x0 u* ~5 _/ n
) C- N1 G# _2 y5 E3 n0 U9 t2 ~' ^+ B. x9 A8 ?- q2 u2 @5 F7 ]
$ \; U; m% `3 e0 d################################################
, v- d7 Z' n# i8 _3 o
0 \) a4 D" T9 z% ?% e以下是大众化图纸的参数定义
4 f' t6 [& V8 g! ~5 _! i$ r9 @
, w, N) _# a- p4 n################################################6 i0 H# w" n% \1 X& {! e4 q
一些取舍值的设定(即要与不要)
, N0 s" y$ S4 U& j& V6 ]
! D& r; f* K! ^- m( c模仁上视图原点标注y轴的0位尺寸( 0 = 不要, 1 = 要 )8 T9 K* S. i6 f) m( ?
mr_top_view_ori_dim_y_0:
6 y2 p9 m7 f2 E3 X3 M+ P5 X5 G1,EOF
+ R5 v& P$ B. h! E- N* K, d( P1 Y) }: ~0 Y
模仁上视图原点标注y轴的EDM点尺寸( 0 = 不要, 1 = 要 )
7 A/ }+ X/ S5 Y$ ?7 W F( Gmr_top_view_ori_dim_y_edm:
, U7 j* O A5 |; a+ l0,EOF
: P4 k2 y$ I( ^/ Z ]: Z C
/ n; V% B0 o5 K/ P8 m; B模仁上视图原点标注y轴的最小尺寸( 0 = 不要, 1 = 要 )" c+ H/ L/ ^* K# h
mr_top_view_ori_dim_y_min:
2 I& C1 I6 `0 p6 ?0 P1,EOF
* _' e: w( j2 d" o" K
7 z7 P) O/ A0 z+ m) q# p, L模仁上视图原点标注y轴的最大尺寸( 0 = 不要, 1 = 要 )& t9 G1 F) p8 M% {% D" J+ U
mr_top_view_ori_dim_y_max:* e* l7 g* }% Z: j
1,EOF% p$ E P8 J6 H) r
" Y" @- z& C( B. G
模仁上视图原点标注x轴的0位尺寸( 0 = 不要, 1 = 要 )+ m% `5 M& S0 B( {% E I, s
mr_top_view_ori_dim_x_0:
3 H: k g, k6 v% B: P ^2 f8 ?1,EOF
& V1 i B- n" Q* b( R
& l' g K3 E* p! N/ z s' x* G9 l# S模仁上视图原点标注x轴的EDM点尺寸( 0 = 不要, 1 = 要 )
1 r& b+ \+ l) y! r% E! lmr_top_view_ori_dim_x_edm:% }9 k, ^4 z: ~# m
0,EOF
4 N5 s( O$ I: @5 B. Z# S1 B! y
( ]. N, ?2 m; t {模仁上视图原点标注x轴的最小尺寸( 0 = 不要, 1 = 要 )( y5 w2 f2 F% g
mr_top_view_ori_dim_x_min:
/ j1 l; [# {1 F# t) [8 r$ |1,EOF3 r% m" G. t' r& o( Q
: Y* o9 R% l( _" v' k# N模仁上视图原点标注x轴的最大尺寸( 0 = 不要, 1 = 要 )' |* d6 g$ S2 G. S' V0 c
mr_top_view_ori_dim_x_max:
% R* Z5 w' _+ a; [/ \9 C7 K1,EOF
% x6 ?' U) Z, D. h8 i
2 c [9 P& _5 B5 k5 V, v* z" [! \% ]( q6 h. |8 `. E& J
+ {' Y6 h2 Z3 ^$ J4 Y `( D模仁前视图原点标注y轴的0位尺寸( 0 = 不要, 1 = 要 )
* _3 L4 ]( V4 z ]+ {8 t$ A, ymr_front_view_ori_dim_y_0:1 c: C6 ? ?- H3 W
1,EOF+ R: L/ m# }1 v
% T2 l! o& e# B& t
模仁前视图原点标注y轴的EDM点尺寸( 0 = 不要, 1 = 要 )1 u( ]+ e6 X3 M2 m
mr_front_view_ori_dim_y_edm:
6 H! S% ^9 Z& U* q1 y2 q0,EOF+ i* f2 l) c/ C* h3 N# s' J- r
" c3 @7 U" o- f* f8 @/ @4 l
模仁前视图原点标注y轴的最小尺寸( 0 = 不要, 1 = 要 )
' E, R# Y( Y6 l7 \1 d$ @( Xmr_front_view_ori_dim_y_min:
^3 I& e1 |1 h2 ^5 y1,EOF$ O2 X/ b6 J" B* l) t/ d. R; m* C5 w& O+ I
8 O* v" {$ ?2 l/ P/ R. v
模仁前视图原点标注y轴的最大尺寸( 0 = 不要, 1 = 要 )
7 z8 `7 W. _- emr_front_view_ori_dim_y_max:
9 o5 j6 e, P6 _& _$ q; p1,EOF
( Q, m/ R. h7 P I
# e L1 C/ l+ ^% }1 J* Y模仁的等角视图( 0 = 不要, 1 = 要 )0 Y9 Y) H' I4 \6 l8 V1 U
mr_isometric_view:
: n d0 _. V2 Y, O8 w& G1,EOF$ `! t3 T! J7 l) P" D
3 [# H1 Q# I# j9 o8 \8 | Q, u
图档路径的注释( 0 = 不要, 1 = 要 )0 ?/ e' b+ J+ s. Z% |" ^9 S
part_path_true:' G) X6 w2 T- g; W
1,EOF! k, v2 B" \# L$ i0 F. U8 [2 U. o
$ [9 d; ^: z$ q
1 M3 c3 ~/ U) O7 ?$ l9 C! s#########################
1 C" n9 Y8 O7 o1 Q5 s4 @# ?3 n4 K& X) @* E8 I% ~% @$ ^
图纸的摆放( 0 = 横向, 1 = 竖向 )
4 O/ p8 R l8 {! O9 v/ nedm_sheet_orientation:
Q/ M. x- d7 d0 ~5 Q X7 Q+ O: _0,EOF( }% x. x: N; Z: Q$ D6 E
' Q* t+ P0 t, l$ x模仁的上视图和前视图的边框,长度和宽度( X and y )
& e+ O4 w) n, ~6 R- mmr_top_and_front_view_bound_x:
/ D+ q) l: _8 O* L+ o120,EOF/ T) c4 |- c+ k
mr_top_and_front_view_bound_y:( c2 l- }+ D/ M: y
120,EOF
" e$ b# }8 c0 f% Z; W, a% d0 a& `- L/ M. F5 _4 ]) j
模仁的上视图和前视图的放置点,x值和y值( X and y 上中点 )
+ N0 v' y: X# c( E5 x- K8 J5 B6 bmr_top_and_front_view_point_x:% C6 l! o5 D* Q* q; E$ e9 t9 O9 z
81,EOF
3 e$ B& b f) g! i" o* Rmr_top_and_front_view_point_y:9 O; k( z! ]+ S8 O5 l1 I6 H. P
185,EOF, G" B$ T# g4 G$ b7 ^3 z+ n
% f6 i$ R; J; P: {9 }5 J* K) c模仁的上视图和前视图之间的空隔" e- }6 T% X" t* ~: b+ s
mr_top_and_front_view_space:3 l. y7 x7 p" w+ o; y2 x2 O( Y. W
30,EOF3 D S( |9 E. i# `
( l$ ]/ A# _* {- E: N6 Y- P
模仁的等角视图的边框,长度和宽度( X and y )
# i; W5 d9 w+ u0 |; E$ Ymr_iso_view_bound_x:5 z" @, K% _: ^& z) ^- g
110,EOF
* m4 A! h9 s9 ^. Smr_iso_view_bound_y:4 V7 {% a4 v' {9 Z6 ~# Q
80,EOF# \5 H% O. @, }5 P4 W
9 h3 [# _" a& U/ \& ]0 \( }- R模仁的等角视图的放置点,x值和y值( X and y )! J& w$ G% K* @8 t7 C! t( ]" ]! Y3 ?
mr_iso_view_point_x:9 [+ x M1 _! j" a( o/ `
228.5,EOF( ~9 G: S4 G+ K& {( K
mr_iso_view_point_y:( t( ~% W2 B) [1 f. N
78.5,EOF
( V ~* ]9 Q) g9 z2 ]* v1 I. w, ~9 v( I; O: ^
电极的上视图和前视图的边框,长度和宽度( X and y )
3 d. ^( |8 f& }- b) }, C) Lelec_top_and_front_view_bound_x:
6 n5 @) j0 V0 {' m60,EOF: l2 }) x+ N$ M
elec_top_and_front_view_bound_y:
6 Q% \- ^. }) M+ T, J0 C) m) X1 F60,EOF
8 a8 F3 \5 c( h. t1 V
3 o; J' I3 o, n& Z! { J电极的上视图和前视图的放置点,x值和y值( X and y )+ t0 T1 c" Q% |* M6 t: g# | P
elec_top_and_front_view_point_x:5 b* K8 Z, @/ _1 i. g% G# [0 }' H: Y3 Y
203,EOF
* J# q$ h5 p" b' n* I( G* Xelec_top_and_front_view_point_y:0 G, e' w) O. e& Q
165,EOF" b- z5 P F7 G( w% [6 h J
! y* ~% V/ U) N, \
电极的上视图和前视图之间的空隔
3 N- d/ y9 h6 ~1 Pelec_top_and_front_view_space:
0 w; c# u7 x M3 h9 _- T' k6,EOF/ D- l7 B% W- G% W3 Q/ R* C z
; B+ g9 A& k, Q+ o. R* n7 n
电极的等角视图的边框,长度和宽度( X and y )' |4 }! @9 P5 L) X+ m0 w7 L
elec_iso_view_bound_x:
# _; m+ b v0 m3 y6 j( {6 F45,EOF$ _# b6 e! q3 N- p; V) c' q, [
elec_iso_view_bound_y:
' I) }- e. s% N9 B1 F80,EOF
) D0 u3 I9 \/ l' m! ?
) B+ C) R2 k" C4 H& f$ Z电极的等角视图的放置点,x值和y值( X and y )
3 S+ _7 P8 @3 C6 G y7 j2 w/ I$ \elec_iso_view_point_x:, E2 W' F- h" R
271,EOF4 u0 w- }- T( ~9 \/ l* y
elec_iso_view_point_y:# y& n7 z3 E5 m1 p, d! Z& u
165,EOF
7 x- O, \4 y, ~: Z8 v2 s
! @6 ~0 A9 E8 S2 Z+ A5 F& g3 G% D( |##########################################+ E. d3 _# a2 l* I
4 o3 {0 ^+ W, y% J
模具编号注释的放置点,X值和y值( x and y )
( [; [% m1 h4 }) V: omold_no_note_point_x:
4 g; t( ^# L" K$ e* M1 s1 h! e# V215,EOF
' _- ?2 Z3 Q- a! Hmold_no_note_point_y:+ n% z+ q4 p* Q' b, S* |) [- p
32.5,EOF' B: p- n1 ?1 f/ p1 q: T
2 }5 Y5 o) ?! k% N* k8 T3 {+ j4 H工件编号注释的放置点,X值和y值( x and y )2 u( b- |6 X5 L2 J
part_no_note_point_x:
: Z, \- _9 F3 [, `4 o215,EOF1 v' q% K6 \9 o. ^( e0 G; }
part_no_note_point_y:
0 Z: @! w( w! u9 [25.5,EOF) \: D# _! C% _( p8 q# n i8 S
7 [) e3 p; a/ f工件类型注释的放置点,X值和y值( x and y )
# }) C8 z7 M0 x1 e* r" \0 x) Upart_type_note_point_x:4 i# u: X. G* B( P
265,EOF
n8 I$ p; c, o* apart_type_note_point_y:
1 }1 E& D/ T% F25.5,EOF" y- O8 ]# _3 h; ?% _* }, l
* ]( v0 k* c( x4 Q+ k) Q" J. D6 V$ ?/ q制图时间注释的放置点,X值和y值( x and y )7 V$ j9 y9 x9 ^
time_note_point_x:5 L% Z: t6 C9 ]
215,EOF+ O) X7 @3 ? {6 {. j P9 u# w7 j
time_note_point_y:7 ?5 G1 S. P7 H; G! W) B4 e
4.5,EOF
1 q1 Y& A8 {+ f8 ?
- q7 S: S. G8 r" e客户注释的放置点,X值和y值( x and y )
$ r: \+ l8 B3 y9 a$ C5 J5 R/ ]; mclient_note_point_x:
$ ` V7 Z9 e9 i+ O4 o2 D: I; t265,EOF
) l. l% n8 X. Q4 d, k9 g3 cclient_note_point_y:
1 j- j; S [2 k, l32.5,EOF5 L3 `/ @1 K* C2 ?6 l: t+ S
###########################################; y$ T7 f! z3 h
铜公编号注释的放置点,X值和y值( x and y )
2 E; H# i3 j, |1 v! ]9 W1 W5 nelec_no_note_point_x:9 _# I+ t8 A) n4 Q' [
35,EOF1 I- j' ?% A4 h' ^
elec_no_note_point_y:
; Y8 d& k0 S" d0 u18.5,EOF% R, r4 _) ~" Z. A
2 Z- N& A5 }: \4 Z2 {+ q6 }0 W% h铜公粗公火花位注释的放置点,X值和y值( x and y )
9 V3 `0 f/ I Nelec_r_space_note_point_x:4 ?; G3 R9 n4 V3 c
30,EOF
6 Z) i/ ~* y, o1 o' C: u' y& z& B# X3 Nelec_r_space_note_point_y:0 Z' G" W5 N7 }! x
11.5,EOF0 [8 @( E. Q' v3 |) C! y3 L0 v3 W
* f' E3 e, \9 k! O. {
铜公精公火花位注释的放置点,X值和y值( x and y )
! q) v7 \ `8 d. ?' _' j6 U ]elec_f_space_note_point_x:# h5 w V- d2 z3 K
30,EOF% y0 k% Q" A3 T" H. ~
elec_f_space_note_point_y:$ N+ E6 M$ T; `, l% { k! L5 L+ m
4.5,EOF3 s, U& F$ u! a" C" \
6 x' a. F9 k! g: p, g铜公粗公数量注释的放置点,X值和y值( x and y )
' P& B$ V( T! {+ i f6 o$ I2 U9 yelec_r_count_note_point_x:
0 [1 i% n0 P: p. [4 S) m; v2 [68,EOF
. K* [* b( M* P( D0 f, Kelec_r_count_note_point_y:% J% N: _" _: P" Y; ^/ J
11.5,EOF' W+ r* a( D& r9 M% w8 R* b3 `$ ^
1 X$ D8 `' r3 S- k+ c9 B- Y" M
铜公精公数量注释的放置点,X值和y值( x and y )
+ C. O7 F9 E% _1 l; {elec_f_count_note_point_x:5 y6 R; i Y v( N3 b. k
68,EOF
# g" s& S5 O0 Z ~elec_f_count_note_point_y:# b4 O; S4 I' U/ e' c8 }5 q, [9 Y$ R
4.5,EOF
# u* H6 n! o1 `6 L2 L4 _0 E6 B
0 {$ I$ M! ]- w$ ~ R特粗与特精公起始注释的放置点,X值和y值( x and y )
+ F" j/ O( I3 y+ j3 B K" n st_elec_note_point_x:4 ]3 w, r$ @: E7 Y, l& v+ B' E
21,EOF H( y: t0 H$ m/ ] {$ y6 x
t_elec_note_point_y:
( o, L0 U4 V. z) K30,EOF
( z/ E1 T% ?7 m0 i. ^# z6 F0 @0 N: G; W- p7 J& Y$ n5 u6 y
图档路径注释的放置点,X值和y值( x and y 左中点 )( W4 A- `" E. f& Q* `* T+ C
part_path_note_point_x:" L* O" N- ~: g Z/ q! O5 Z! k
72,EOF
) h. X$ \. ~* W% cpart_path_note_point_y:4 @1 r, {6 n7 _* _" S
18.5,EOF
" Q T* P0 g- ]) _5 {2 e
/ |" R& p. n( [# X& K备注的放置点,X值和y值( x and y 左中点 )
7 z( K( C/ w/ \note_point_x:
: u& d3 W" P# a102,EOF6 j# n: C' p6 t4 @
note_point_y:
4 f# M4 e2 F; m5 A. v: Q4.5,EOF3 P; R( t! x( a) W) F
2 z2 O5 \8 ~( G, ]% b+ ]9 |图纸页码的放置点,X值和y值( x and y )6 O6 Z4 }3 l% r4 R- s
page_note_point_x:
0 ]) T* ?2 b2 A6 _: U5 w* k273,EOF. \' {" ^# j5 P& K- n9 A# _
page_note_point_y:* u5 j! w3 k# Z- p1 ?3 D
201,EOF
: ], Z* e/ ]/ C& |7 \7 @/ c W6 S: `- _
共用铜公说明注释放置点,X值和y值( x and y )
9 c. M; n# O0 u8 Z7 @ e- sshare_elec_note_point_x:5 ]8 I7 x5 F* O, ~ L9 X: V) p7 n
43,EOF/ g7 R) m8 x6 \) r9 t4 D% ~
share_elec_note_point_y:
+ ~7 o2 B( g# H( t27,EOF
7 J$ {0 P/ {* r$ x9 T' I/ @' E1 Z" x3 I9 U4 t
" j/ [% ?: G7 J9 m#############################################################
7 q' ?; L7 v1 p- K+ o& f R7 d- w; z2 V1 b" W6 g
CAM 部份, H p; P9 B/ v' d+ d* Z9 e7 h4 Q" P
1 C9 v* k$ s( ~- ~! p: V8 d4 u& B#############################################################, D" o( P( b9 F7 p2 D- X8 Z
- A: ~& b( O2 Y4 R" ^; N
铜公开粗(第一把刀)时是否要平行粗光大于0而小于65度的面( 0 = 不要, 1 = 要 )* G# B. v6 O. G. } B# n
cam_elec_roug_fix:
! @! K Q, S& ?, c% V1,EOF
4 r s8 \# d+ ~( y
) N) t) a, W7 a; }3 y. D$ w5 H# D平行精加工的10度以下的步进距离
" W$ R3 B0 m4 b$ q- x N% zfix_p_local_dis_10:
' u; F! o0 z( F- ~% u0.12,EOF
% D! U5 r+ g% I" i0 g( e( z8 h平行精加工的10到25度的步进距离% ^6 m/ b3 T X4 o7 X9 g
fix_p_local_dis_25:( |( x W- g; S2 M7 }; i- y
0.1,EOF
$ Y, {4 j5 K) y0 e% \. w3 D: S+ y平行精加工的25到45度的步进距离# f! E5 u* ^3 s$ @7 k- j3 Y. _& Q
fix_p_local_dis_45:6 p- b L' C: y0 n* g) a
0.06,EOF
( S1 r) S6 @# F/ F) G. E1 S- C! [% \1 X. K7 b C
9 i$ @, T Q, m
等高精加工的45到65度的下刀量
/ ~! P6 Y+ M# `! D) x3 m5 nzlevel_local_depth_65:0 J; i/ @+ P! X6 z/ K, L
0.03,EOF
+ P) I1 i/ O P2 C& o# q7 V Y. f等高精加工的65到80度的下刀量
2 l, |0 ` e* v- azlevel_local_depth_80:
$ ~! _- ~, _, n! @3 Q# j3 w0.06,EOF8 W8 }! z8 D9 H+ D0 V: r% g; p
等高精加工的80到小于90度的下刀量
8 H. m2 e V+ u% Fzlevel_local_depth_89:
3 B" O/ l- D1 u1 Y: K& {7 N0.12,EOF& }6 }& E7 H: W+ J
! y' s0 Z; u4 O! F: ]1 \
end |
