楼主 |
发表于 2011-11-15 21:47
显示全部楼层
1 % : character at beginning of file
2 |7 h+ [5 {7 ^8 Z9 y7 c3 G91G28Z0.0 : character at end of file
, J2 i% o+ z ~ SM307 N5 f# q5 H! O) }3 s* X" N
%+ E8 q3 e) q$ |3 O& {8 Y7 K- e% o
0 ( ) : commentary: 0=no,1=yes,2=yes,with block nos# T5 v6 V) `3 R, Z/ S. H( D/ P
0 S : spindle speed command
' {# h9 n m* C1 : output format : 1=mm,2=1/100,3=1/1000- |. d% K: Y! }% R) p
1 : condensed mode: 0=no,1=yes
3 @" `! X' R2 D2 l. J0 500 : maximum block number per file: 0=n/a
% C& B0 I" }9 L: L0 5 : initial block number: 0=no block numbers B1 j8 o& l' e' q8 r
0 1 : incrementation between blocks
, u/ F( U* B+ x, W% A% S0 : start up command1 J7 l& c! Z; Q* q
0 : stop command+ {0 S- O% m6 i3 V: ]. M
1 G00 8000 : fast speed: 1=1st point fast speed,2=feeding/ M4 t2 K) _* ^! W% d) \
1 G01 : feeding speed: 2=code F.. with 1st point only
. L' d; S( i8 P- Y+ P/ o1 : point directed: 0=centre,1=tip
' M4 \1 q5 I6 |8 A* n0 : no of free-format lines, each file (20*75 max) 3 O! z: e- n x: G4 o a
1 : Output file extension: 0='.blc'
+ h# q- K8 k4 a$ A, x$ w) L0 : characters to add at the end of each line: 0=n/a
- v" E. m7 o3 S( K+ y5 y0 : maximum size in characters per file: 0=n/a! a% ^ _) z. u% d( F
0 : maximum distance machined per file: 0=n/a
8 G2 r0 Q& `* _4 b0 : no of lines between blocks: 0=n/a' B) |3 }5 J0 L! N! Y
2 : first point: 0=XYZ,1=Z only;
/ A, D- r6 o7 V7 b0 |0 : transformation to the machine axes: 0=n/a
, G$ ?( }* Q+ p1 u- S6 U5 : no of free-format lines, first file only
* {* w# |& r9 I3 ?2 ~G90G80G40G49G17
" o2 Z2 q3 w8 k5 D! K; IG91G28Z0.06 F; E2 U9 b3 t; w
G91G28X0.0Y0.0
3 e+ @3 g+ ]" ?9 XG90G00G55
7 @( U6 U$ _3 c% o" u! ]6 _( q' CM08
2 ~: [5 ?- Q4 H6 [& Q7 N0 : break the file at each z-level?
% ]9 }; a- i% P: q5 g0 : coordinate mode: 0=absolute,1=incremental+ R' ?7 l4 g1 _& _
0 : speed change rapid -> feed: 1=before, 2=after
0 A/ P2 s1 l$ X* _+ g. E+ Q& z! s5 ?0 : speed change feed -> rapid: " "
/ P7 `1 Z) g9 O8 c1 1 : commentaries required : header,distances
: q4 t. j0 f& t# W0 X Y Z : Axis labels : 0=n/a6 ^* n& k7 d3 H
0 0 1 F : Format of speed commands : 0=n/a9 U, U Z3 |) D" J; M% `
0 : Tool axis rotation : 0=n/a. [0 |+ C4 |6 D- e9 p& ]
0 G40 G41 G42 : Tool correction : 0=n/a9 r! x V3 i. s3 Q2 U. z0 L5 d
0 50 H~e~g~h~i~j~kM13 : supplementary block
e1 b- t m, r ^2 [; Y#44 1 : Change the output file name format1 Y+ O, V% M. I7 d
#52 5 : Add lines at the begining of each toolpath / i% q# G5 @7 Y% }' B, ]
M06T~n
T% W1 H* Y& f$ g8 e% BM08/ d7 | h7 H6 C& `
S~bM03G90& G1 ?1 R. X5 ~. e0 b
G00~h~i- ^: l2 T5 H8 F
G43H~n~j
5 V; a" A% F U1 k! }#56 2 : Add lines at the each toolpath/ B) s& f p7 y( H
G91 G28 Z0.
8 [9 D& B' v* s g; x' NM05
; E% e5 v/ ^1 a$ Y
- i) _1 W5 Z. M; v; W$ W, C @(#)nc.ang 1.3 2/12/93 WORKNC
: `" h Q, c' m$ p
% l, _ I$ G# @& H& I2 h請問要在哪邊改自動待刀跟攻牙?? E9 B4 O* c+ }8 T2 Z
小弟在此誠心請教各位大大!! |
