#include
- o, j: _! ~. H6 O1 i, R#include 6 9 Y: C1 [ x. j8 L
#include / h0 E" e/ A2 B/ j" e1 P3 C1 K
#define NUMBER_POINTS 5
* }1 g& G- {) `+ s( M( i$ P#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
; A9 ^$ k+ B) T4 ]6 M. h6 |static int report( char *file, int line, char *call, int irc)
, a5 s, ^5 j0 i' ?2 q* Y{
) L2 d) b- T6 R/ ` if (irc)
( e1 ~8 r, m% F$ x { 8 Q% f) l1 |, C5 S. I$ O# @
char messg[133]; 4 n& b! ^9 h1 H$ q$ j3 o8 e
printf("%s, line %d: %sn", file, line, call); # D( H7 ?7 }9 S) |6 U
(UF_get_fail_message(irc, messg)) ?
1 ~; C" S6 h, y) m: y9 t printf(" returned a %dn", irc) :
$ y' L) H4 ]+ ]/ u) h+ h printf(" returned error %d: %sn", irc, messg);/ 7 P& B* ^1 b/ N5 N3 W
} 7 m' @+ ~, Y7 B9 J0 S/ s+ @( Y
return(irc); + |" [* ~ Y9 U! n2 n1 ]
, m k; b$ u$ W$ J$ }1 U/ Gstatic void do_ugopen_api(void) " ^0 s# x; `; m% u
1 h) `2 o2 w1 h1 J+ k3 c: _1 Y/* B-spline parameters */ 2 {, j2 s0 T a4 ^- t' ~3 B
int degree = 3; & v- l: J3 I5 [' Z. y
int periodicity = 0;
4 l" g- u6 V; @& q0 }4 @, h" Z Y, Vint num_points = NUMBER_POINTS; - P- F) s U$ R( \" c
/* Point/slope curve attribute array */ 8 c/ _; z# y3 Y& f
UF_CURVE_pt_slope_crvatr_t point_data[NUMBER_POINTS] =
}; J7 `. ^3 W0 T. D {
& L, e' U: ^1 ]" F { {-0.0539, 0.0511, 0.0000},
7 `8 y2 d4 j" ]3 ?8 Q UF_CURVE_SLOPE_AUTO, {-0.3597, 0.9639, 0.0000},
/ a2 ]* i9 V$ y, K# s5 { UF_CURVE_CRVATR_NONE, {0.0000, 0.0000, 0.0000} ) + m5 o5 A8 P) E( y& B, v- ?
0 F" ^3 N2 _: }7 M& b6 } { {-0.4801, 0.8428, 0.0000}, ' i' G @: P2 C4 \& L! Y
UF_CURVE_SLOPE_NONE, {0.0000, 0.0000, 0.0000},
6 e- K" @# w- U. K' ~ V UF_CURVE_CRVATR_NONE, {0.0000, 0.0000, 0.0000} * l d& O* V k
}, ( k$ t- l! S- N/ l3 D) |3 }
{ {2.0000, 0.9000, 3.5956}, 2 V, X/ s( c. l, U* L: ~4 w/ v( {
UF_CURVE_SLOPE_NONE, {0.0000, 0.0000, 0.0000}, * P! A# h) p/ U# c# _, {
UF_CURVE_CRVATR_NONE, {0.0000, 0.0000, 0.0000} 7 ]5 r1 |6 b9 @% [) i& j
}," , ^9 d6 B- ~+ T3 x8 `4 v* B
{ {2.3456, 1.3456, 3.7890}, : y7 P7 R; d, \: T# }
UF_CURVE_SLOPE_DIR, {0.5000, 1.0000, 0.5000},
+ e- Q5 E6 @4 n& W9 ^ UF_CURVE_CRVATR_VEC, {1.0000, -1.0000, 1.0000}
( ~& P: B7 ?8 L' A5 a }, { {3.1000, 2.4567, 3.3214},
, U3 r. F% h6 f6 \% X UF_CURVE_SLOPE_VEC, {1.0000, -2.0000, 1.0000},
$ _+ o& b" `1 o ~ T! P+ s UF_CURVE_CRVATR_VEC, {-1.0000, -1.0000, -1.0000} }
( g9 S- u$ d' w! [7 F( N. ` }; 8 M' {# J q* C# j5 t8 b) F# [
5 C5 ?1 f1 n- n2 f6 Z9 b8 R: _
/* Arrays of user's defining point data */
4 v5 b) _6 c8 Q) ]6 ]: G. Edouble parameters[NUMBER_POINTS] = {0.00, 0.89, 1.73, 2.23, 2.85};
7 @, }9 w) U: T+ c, N8 C6 e" xint i, save_def_data = 1; 7 Z8 m9 S x; ^" {
tag_t spline_tag; / A% v1 R) o. p8 \' R' `+ q
; y$ m a" c8 X
/* Create B-spline curve */ 6 Z* i! j# Q3 }! o/ D) s
UF_CALL(UF_CURVE_create_spline_thru_pts(degree, % h+ b) D4 m) |
periodicity, ' O( }" O, `/ D8 B! j5 H$ l% o
num_points, + J% Q" ]9 d* M5 x1 a. Y% x* [9 F
point_data, ) a. s0 R+ p$ G% Y$ ~/ @
parameters,
3 b( E: w/ t% ^! u+ M" b save_def_data,
8 c6 }' B; H* z! o0 q6 O &spline_tag)); 6 f2 [1 w6 @. R8 A, Z4 P4 J1 e0 O
; a* m r- F) l6 V/*ARGSUSED*/ n8 r. _" ]1 |$ ^0 t J
void ufusr(char *param, int *retcode, int paramLen) " S1 I& @, u+ n
: `% M: ]' y) ]2 ] if (!UF_CALL(UF_initialize()))
1 ?; q2 K& Z* U+ o$ N; o' c { 0 X A6 \$ k- }
do_UGopen_api();
6 P) u; p) j# G* @; P UF_CALL(UF_terminate());
- H, }0 z# J" b2 U }
' E t) e' z2 z$ Y}
5 K& g" x' u2 L; nint ufusr_ask_unload(void)
5 A* [+ [5 W$ j- S- ?/ {+ P{
4 h6 B0 Q1 q+ h0 W( B( j1 K: d return (UF_UNLOAD_IMMEDIATELY);
0 Y+ J5 j8 r- b2 S& P3 @. A2 C S}
, h! e- [' ? _3 N4 K7 N请问程序中的红色的那段程序是不是表示斜率?后面的数字表示什么?1 L5 G" ?, {: @7 {
