查看: 33515|回复: 26
NX-7.5.5补丁已出(960MB)
发表于 2011-12-19 20:22 | 显示全部楼层 |阅读模式
 楼主| 发表于 2011-12-19 20:27 | 显示全部楼层
PR ## ~0 {8 v7 K  s% Z# d& V
Description: y: d% l8 {7 u8 b3 f! P; Z- \
% y7 Y" m, I  c) y. g
1312632
4 E1 B9 n" X2 u2 r5 y6 Y3 ~ Part Family giving error in when updating
  c4 m* j& k4 ^$ y
. b9 V: y+ Q. G3 N9 ~% L8 S1467471
( x  c% }) W' J; I Wire-edm operation loses information when copied2 Y& u6 X' m" s) \
; E' b# x  h; u/ E: B$ ^1540505
- e  H2 @% o* w9 y5 S Non associative PMI geometric symbol
: I; a, A' B0 J; H
1 a( A2 V" {! \9 Y! b1607725
9 i" X' k6 Q0 N CAM: Drill to model depth creates endless toolpath in certain conditions
4 y$ s7 u) n8 I. A% @ " i9 Y3 g+ B2 P3 N) c
1612522
& b4 R6 F* Z9 D% _+ p9 P  g6 j CAD: Unable to mate components tangent in both directions4 R/ b0 U) h, W2 r3 D
% R3 k+ W/ E9 U: D% u" h1629164
* ^) t. Y6 f1 ` Contour_Profile gives unrecognized Tool motions in NX 5.0.2.2$ w6 N$ ~" Q  d; M& E9 Z  B
* j) o1 u* Q+ ^
1639992
; P3 c# `2 v5 o: r* }/ F8 R Planar mill gouges the part
6 [2 T. p0 O+ Y6 e* Y6 y5 |: X  z* } 5 [8 y: @, d5 m$ e2 W  O. t8 A
1656674$ |3 e( M4 v4 Z2 [% ^0 D  [* X  Q7 K
Engage motion positions tool below top face of part- [9 p2 `9 K- S* q
2 X2 @% x3 |1 x; d- v5 A
1663585) b# {; I, _5 t; c
Error by retrieving Countersink tool from Inclass into NX2 i3 i; s; E  [8 s0 w
2 y/ {: F9 b( E8 w( H+ |4 s3 x1665752
1 x1 K$ x. R, Y; C, M* p) l. e Gouges in operation
5 _6 o. O5 {5 E8 R1 i
  E) S, B% s0 N, X( o$ }* M1673953  @( Q8 {4 B0 {) r& g7 R
Unable to update linked body to correct value ...! `) ?  C# g& Y6 p7 L
2 Y3 M% f0 }' }( G
1674888" {- d5 u7 ^0 d) U% @+ D' k
Error in MillUser operation -> No MOM MSYS Event while posting 9 G# G! z$ \2 R4 `% j
, O6 M' f. m8 Y( Z! h" v  w
16791383 D. H: @9 U+ N% `; Q& V
Delete All References does not remove all Inter Part Expressions0 d/ L7 @+ J/ [4 W; ?
: l2 G. c4 i; M& r) v3 W
16795014 {' w$ Z4 R0 I4 y; L
CSYS associated with a UDF could not be moved to another Layer' f. M7 J/ V) t' N6 a
: W  E6 |4 M2 g( o! W8 v1683882/ ^6 ^  D: M9 X# Y
Rename an expression does not update linked expressions
& G/ g, h- v0 S7 X1 Q: {" H
" l( y- O0 v- }  @8 f6 T! b1695488
+ x" v4 |) F  ?( _: M+ k Thread display shows a gap on chamfer edge of the hole
  {3 v1 J' t/ \. ]4 \
: o) T8 ?% ]5 n/ V1695607: W& n, u' k  l4 U& \! Z* ^9 L
Unpredictable behaviour of RecurDyn Solver' B; L( k, N# }8 u* ?, Q; z6 f
% j0 N! r5 S: o3 O9 H1701098
2 b$ }: v$ E0 z op flagged as edited if feed in cycle is change but not if Feeds and Speeds...
  h' E+ V( W* p ' P# a8 m- k/ p7 V9 {
1704497
& x' f% P( X4 O/ _ Trouble with ProE transfer
9 C6 o# F. v$ B
. H8 u6 W( O- i+ a1708339
: J3 I" w8 t1 X. B, V2 x" x1 S2 @ Contour profile operation have steps in the path when multi depth is used6 {' w4 g. w. w& T
- d1 p9 O) Y' x+ v) a5 V/ k8 j
1715569
1 k6 C7 q# Z/ m" Y. M/ s: T NX 6: Unwrap divided conical face, not correct& c; m' C4 e6 q
% N$ T0 A) }* R$ z$ g+ t
1724926
. b$ ^' j3 |" d1 |6 l7 T2 R Cavity Milling gouges the Part on several Cut-Levels if 'Body' is selected 2 s! V) E& h$ r/ `) I4 t# a
& w& _: \1 W" z7 {
1737296
2 L! v' a  R! j% C; ^ WEDMIE_MAV with Lead Out Point on NX 6.0.3 64bit
/ P5 H- {- v. v' }/ e) {+ a6 \ - B4 f/ ]* q- s0 x, _- _8 [' P
1737665, [6 d6 [2 E9 s7 g
Cloning assembly is deleting IPE rather than linking to the new cloned comp name. W/ r, Z$ L" Q) O$ K
& D6 w% H. c9 i# ]! F% T+ F0 ~- F, ]11738136
5 {, h% X6 N1 Y0 Y2 O: l4 g* v; t Variable position Mating Conditions fail to convert to NX 6 assembly constraints& ?) I4 C' o+ r# }# Y
, Y/ r# E/ w# _& |! {9 u; y0 I- A1741002
$ w" N5 Z2 Q, M6 z$ ` Missing Arrows on Dimension after DXF Export   t& a/ |- U8 B* f4 U! `
% R* ]$ T* B9 h! r/ ]1744109
1 p6 a0 m6 z' W9 m6 w6 B! x CAM: PR - Resulting IPW is different when Turing and Milling Operations changed7 p6 y9 R, i1 V) F$ h
# B4 Q7 _1 F$ L, l; V1744336# I2 O" y6 V7 \" Z3 q
Motion - Constraint: point looses contact to curve
' k; X' g9 V4 H" ^ + ~0 p, g& M5 ^" u- L6 n( J( Q
17472384 Z9 R0 n7 G' W& r
Regression missing warning for too big size on text# P! E% B8 ^1 I! w" A+ ~
' ^; b5 c# @$ M- L+ N1 D7 E/ _
17474147 H2 z' X% d; r( c( L' k3 T
Section Line Preferences is changed when opening file in 64bit
$ _6 v) I; t# R
2 {" o' m; J3 T- b0 ?1751698
+ J& f5 V0 Y& }3 I( \ CAM: PR - UDE's not shown in syncmanager-window
1 g+ u5 _6 s8 C0 r! @. ~
% _/ w3 U5 {) J* Q3 c& _1752179
; @  q5 `8 V& M4 {0 m, L Center lines are wrong translated through 2D exchange to DWG4 D" O8 p: v: x/ Y% n; U: b$ h4 D
. _# ^2 Q; i8 P, Z5 B0 ~4 R5 O1752547
; V, [  X3 y4 f/ f$ ? In Cavity Milling the Tool Gauge the Part  i8 @+ u: s: I/ ]! r3 L3 n% `' M
3 d3 B  i; w8 x* w
1753484" `6 [, z/ Y/ L! x
Does not update unless Point to Point operation is generated again
0 }7 e4 V8 G+ n) ~( J $ F, f1 V; B# q5 Z  ^1 r$ n' l
1757300
! l% z( U+ d5 g Wrong display when drill and turning operation in the same program
' d  C/ J! }+ i! T7 X
- ~5 t. q0 Z- L, G1 U1757485! l+ ^3 R; H- M$ q+ z
Plate preparation returns an internal error when plate has a hole in it+ `9 U1 N# h% {) m* a2 x
, c& Z& s! R; M
1762026* ]  O7 m8 `2 U9 ~4 L; i! |
Clocking of electrical boots using angle constraint result in positional problem/ }! d2 Y0 n1 G/ l4 X2 x3 C( Q1 q
. V5 z# \$ R+ [6 ^: v' p; W
1762128; Z( a9 w6 I( _! f! ]# b
NC:Modeler error: non fatal run-time error9 c- y& l" e$ v# L" k* j( M! D
8 h/ B' d3 f6 U" p" Z% T
1763715+ V% l+ W# T5 q, P7 O$ }
NX 6 64bit Error: Unite - Part Family Template
* o/ ~+ ]* o; ]. }" K# o& p
8 B( V" Q9 B: @- S4 Z1765154- ?/ k7 q: E7 q* j! y
Object dependency information is unavailable on linked bodies
; j# T+ g- G5 M0 Z, b' g
# i( G2 S% c2 k$ D1765852$ l4 A: Z4 ]; }2 p9 c, w' z! B
Problem with selecting datum CSYS by name
8 M# e, {  {: i6 O / a! F' ?% k% a5 L6 I
17692624 `( w  {( h  G3 l- ^+ A4 m4 A
Cannot control item type for custom region components
3 @) m, e0 Q4 z( ~; d3 H1 s& |
# T- X) ^; F- `, W7 S17741544 Z" @! l% O/ [' f
Problems with using Motion Simulation
( b2 h% w5 {$ ~$ ?, S$ O3 P
! u5 q6 I- C: [; E1775319
9 q* ?) a, L. C* t: I1 H2 B Open Feature is created without partition mark* Q7 x9 Q9 I. ]  @( |) ~
3 W) u5 d$ E, D& M1775635. N; f4 @7 _* O9 y8 W! I0 H9 i5 N
Feedrate does not update unless Point to Point operation is generated again
3 N; C1 D/ t3 B: G  P( y
; u- l) g  h/ f' L1778249
" W3 x2 F4 |$ B5 @  y0 f' g Change in Point to Point need to Re-Generate the Operation1 p9 P% G# O  ~6 |3 h. n
2 R& S$ C+ a: ]8 o1778496& k% g* K5 ~' q+ k
Feedrate parameter drill cycle doesn't change in regenerate needed2 L+ b: s1 V' j- [0 G
% F% p6 J& O( K& K+ M  t1779519* q2 n1 ?0 J6 R  [8 F$ ?1 u
CAM: PR - Cavity Mill leaves Material on the Blank and cut it at a deeper Level7 d# Y8 s" }* J1 D3 u! ~2 F% x
+ @2 w, {! y5 Y" ?1779934
$ K8 d- T+ L+ L% s  u4 p Cannot select pattern control point with UF_UI_point_construct
4 H8 t8 X6 r; Z& M; X- R% [   {( b; I% i* g! ?5 n% U
1780699( o  a+ l2 Y( v+ B
Centerlines not properly translated to
) r& B; u8 e5 |$ B5 k7 { ; u+ R6 n1 _: @6 }
1781526$ Z% K, y0 t9 P4 S3 X! [, m
2D Centerlines change to Continuous after translation to DWG
+ x& k& X5 s& X! M% f, G- L  @   m( l/ ^- d+ P" E, u# a3 g
1781628
5 j! I+ O) B) |* E4 a' Y; A NX Ship: Update of Geometric Modification thought Distribution# T  t9 Q! `0 Z, `% N( Q$ g
' ~% F) m6 s" b5 i( Q- F# W
17817565 f. e- F3 ~% ^' r2 T. ?4 e; ?+ n
Replace Part Fails - connection broken, extra constraints created
9 |) U8 @/ t. {* L4 M ! i; W: B% c/ V9 V* a6 d
1782839
; {9 z1 f, O+ s6 V: N% T NX 6 with TCEng -> preference for section line won't be saved
% m. I- Q1 j" Y6 e) ]3 X, n# a - S& u' z' H8 ]0 f' M& H
1783529
& n9 d& h% E( v: ~ After modification of the multi body part, distribution failed" y: J( i! {) ]3 A( z1 i+ `) S
3 P, |5 _2 B( o6 Z, d0 D1783812
& g2 P- p( w, G' ~ COMMAND: Update $ _1 l, C; q5 I0 R6 u4 R
! a# x5 R9 f$ |! V3 {: ~1 T* B9 C( \
1785808+ f0 i/ r* E: m* T
CAM: PR - Verify show wrong 2D-Workpiece by using Tool-Assembly: ~, g$ T' U0 J! x* i
/ u) U$ J- c* ^8 y; v6 v
1786838! O; [, r7 Q3 B* }
NX Ship - Feature Migration from NX 5 to NX 7.5
5 [4 I0 _% h; G, c: r$ M 6 z4 \2 H) x9 |0 l1 d; V
1789752
! {2 m9 f) _2 h6 u' j! N6 j, O Keep Selected Flips the Start and End, and the Guide Offset Direction
. K' c9 W0 y$ Q' N* @  t6 J, W $ m: n6 P9 `6 l" _" U# D3 _
1789755" V4 L, C1 D5 l. C* {
Keep Selected Selects All Sketch Curves instead of those only intended
+ {' B8 I5 o+ O& G1 ]! S. a! O
* A* ?! d1 |  \# Y/ g6 |) g17897922 B: Y' x$ C# n- y
Different behaviour when filling attributes, Exhaustive vs Suggestive # Z; G* a. q1 n; H4 i* J2 ^/ y+ ]
6 o% U7 h) \7 Y
1790500
& }: O% k4 m4 o; d7 g1 |0 y Translated NX drafting file in to the DWG the center lines are missing" U* {- K7 ]% p: S  H, w' a, D
8 w- c- p1 W9 I6 W! z* C
1790909
. \! I  F# d& C Copy_paste nested component group in ANT changes name to "Match any of..."
" i6 I6 Z: ~4 p* Z$ b
7 v! k/ V& l) q% n0 ^: ]) [' E17925277 J, O) Z: C# t" C) B! `
Not able to sync formboard) A4 F8 ]0 b2 Y9 l0 j
) x+ z! \6 y( L8 r9 \
1792636
* N- b* }5 u3 E& F# ~! T UGTO2D: blanked objects are visible in 2D part& X; [* a: \* `/ c, [9 r& ]
$ Z: w, q, E* B4 y1 ?9 g9 V1794299- D) T7 T" H- p" Y  E7 w. D7 g7 L
CAM: Machine Simulation shows wrong tool with duplicate Tool No( h- l1 L* Z: a5 W3 ?4 q4 k1 e0 _
8 G/ a6 l8 o9 z9 V$ T  Z) i, V1794809
' l/ @0 F2 U9 P  F NX Gauge the Part in Cavity Milling with tolerant machining turn on# f$ T; B, G  i6 R) |
6 o* ]& y& R/ G9 M0 B1795673
2 L  P3 M; ]* L! a+ g CAM: Calculation time for 5 axis toolpath is to high compare to competition) V* f5 q0 U1 W: D/ t( s" ?/ C3 H1 _
8 u  R6 J$ _1 K. j( c0 s1797021
, b9 N( o  |* [5 M* j Specification loses connectivity to assembly after import) y! j/ ~, k1 |* w/ r) z, W- o
& `! \. k4 s: |- ^- y1799134
) m8 K3 {# j1 A: C# x% L: f  W, M Variable Contour -> Contour Profile Multiple Passes tool collides with part' D" F  l# T6 D8 N0 R# \
# b8 e( z. s  [4 D. R1 H7 X1799480# g7 i0 k( F2 {$ S" T- t
NX truncates custom database attribute from 512 to 208 chars+ t8 ^, P$ E( b/ j
4 f+ T0 o# ^: m0 B6 y
18077287 F% z# U  Y7 O6 p, r
Problems with Verification when the Tool Display is an Assembly
" B1 l- N' s9 u" S8 l0 i6 M - Z+ h+ r0 H6 L7 H; M7 S
1809670
$ ^( H8 s% t8 r; A+ b" Z# A NX 7.5 Marking Line on
" g1 R- {$ z: T) Y
6 S" n" O- u0 f1810000
7 v( L: s  `8 `$ ]  p& g Internal Error when opening assembly with promotions and out of date structure
8 z$ j- t, |! x4 U/ s, P) o$ j3 [
6 |  u$ D4 ?* }3 I1810921
4 P! @7 g$ D8 ?5 L Probing - depth method 3D cylinder & midpoint - not working. p* O1 ]+ o/ K; q7 p* d
2 [; ^% P) G7 k  d) G( h
18116000 i/ ]0 x1 D, q0 u7 _  n
Add component to Part Families crashes NX session
& j1 [2 r) g/ l4 M6 U! k : d* ], A( [# v7 g) e) |
1812455/ H  R$ i$ I! p8 `. a* w) ~' J
CAD: Ribbon Builder, wrong Distance Tolerance and Angle Tolerance
" H% r+ |& Q$ q& S0 u/ {, o9 n$ k
, [) S; x: A; b, e. M( _1 y1812805
4 }( f3 t5 B/ L4 K- Q  z3 P Assembly drawings take long time "updating assembly" and "updating objects"! n2 J! P! i5 ~3 P% O1 t: L# m9 n( O
: L+ P! T5 R* G2 j, u8 R& c1812815; T4 y  F1 D" P' D
BETA 7.5.2.5a - Missing PMI tessellation on NX version 7.5.2.5a
  z5 ]4 N: U) P' {+ R ' d7 u& O, K9 w  k& L
18155639 {( e" x$ ~9 R) N' {/ l/ Q! v+ K, C
Dimension will be reached incorrectly after loading drawing
& H( n7 _5 O: c7 e! a/ @
$ j3 m; n) r# m1816267
* q# s5 X( u8 u0 @ Non cutting motion gouges part geometry with extend and trim corner control
3 f" ]+ H, ?3 @9 N$ C' M- ]8 }) B ; o2 j- W5 T2 e& N) g8 N4 q# J
1818129% d( }* b5 H5 r/ v- j' ^# H( o1 W- k
NX Structure does not update Teamcenter when using custom item types
1 y" J" W- e. i! i
$ t1 T% R' |1 Z4 o# o% d* ^# f1818551- Y% ]4 _: c9 k! |
CAD: Custom Symbols (Reuse Lib) in NX 7.5 reports loading before and after insert
: b( M/ G; M4 n/ D  q- N$ L& h
% H7 V0 c/ B( H3 x1 `2 @1820494
! e$ z. ]/ Z/ k4 u- F Save As New Revision to not allow manual input and change of revision value+ V4 V9 p6 P) o' D3 m) d4 t2 A
- U# t0 z% t5 [5 ~; p5 U, h
1820612+ ~) Y# i; n, Z. j( y
Unable to save after adding additional fixture to the Machine Setup- W  Q% Q2 c" X( i& L' p
7 S# W8 v, N7 f
1821503
3 R  c; ?5 a/ _ Change in Point To Point need to Re-Generate the Operation( f* l5 R) \6 p4 _; L( i
9 Y9 R) Y* L0 r4 Z
1822109
/ `2 o8 _) D2 L/ S( x" z1 p% |! C7 G PRO: UIStyler and remove comp from list in 5 ]' R# \% l9 X) C
  t1 f; L4 o" X5 c1822212
6 R, S2 ?8 y: j0 S: V) n* E( |4 z Not getting correct motion with of .010mm but is correct with .001mm
* J/ W2 h4 |6 z ; U5 }' R3 D7 R. A9 J7 I2 I7 H
18222473 r+ A& c5 Y: q2 s$ v( h
CAM: PR - Create Feature Process with multiple Features does not work( P6 u- s% [7 @7 H/ P
% {% y- s: e. L" g5 U1822539( O& o/ z0 C. I
Export changes position of GD&T Symbols
% j7 r* a! p2 L! o7 \ & ~+ a6 u  j+ M2 }! t! m1 a; d: s8 k, O
1823301
! o+ q+ C: L! e  \2 D5 X% X Internal memory access error saving file (and also with Part Cleanup)( w9 r# A# Z+ V1 k  T5 j. l" [% a
8 E$ L$ l. v1 q1 L/ C" l8 F18242241 l% n- }( w5 N! q$ Y
IPE are different in NX 4 as they are in NX 7.5
5 U+ k; L, P: Y& H: V# a/ h1 }
# d: G5 Z; E" ^; f$ ]  U# A1824463( {# E3 u! F, o5 V) L3 C
WELD: Changing point no for a group of welds modifies included Fixed Weld attribute) g9 H% T# ]6 ]  J
+ D" q8 I) j: E, E% i3 E1824553
4 H! v4 U  U# {+ C5 n CAM: PR - Changing instance Array lets been flagged as "not valid"
; P1 e" `9 Q3 V/ Z) C1 U/ n. H  s $ i2 l: m& o) v+ u8 o5 Z* p& t
1824652
3 h3 _' p6 _% B+ E- h$ z; [( e No such expression
+ w: V# y$ s, ?9 b+ {+ ^
* y! B, w5 z# A8 Z4 }+ |' Z18246558 J4 _; p$ `  x$ L8 E1 ?
Some IPE fail to update
' u( g3 g/ u3 o5 B, J 7 l6 {; f8 t4 z/ ]6 G
1826157  b1 r# ?  w. _4 l
ug_extract_body fails with ug_udfs on re-order " k2 o% S: e# l0 G: j0 H' i" ]& m1 j% c
* K( M% Q. Z: N; l0 A  S) h( S8 T7 P* n/ M- U1826780
+ m0 d! J; _% y# l1 n  K6 H Holder Angle from loaded Tool is incorrect
5 g+ I& ?; V" ~! j$ s0 B$ @6 z1 V 1 A, z( S! A  T" p
1826841
& B4 |* k7 w* z, O' p: W; V Without Section Line option is not acting like a session option 1 G6 z! t% |0 H2 s
' h4 D- [% |  ?
1826901( j4 j$ ?- I: r- M2 {7 U8 ~
CAD:- NX 7 5, move component, no ability to set the "snap increment" value
! j- q; w8 B9 s' X2 I- F- y9 ~- f 4 `( ]' U6 d# e9 {1 V. P8 h  \
1828554' f8 \) c5 f- ]1 [3 M# [% c
The specified expression variable doesn't exist error when opening assembly% l7 ^6 Q" V% V' f8 W* {
1 p$ K3 D; c& t" p) L! F
1831412* i2 ?3 @. u+ Q' t+ M
A deleted or invalid class id was used (580039) to make top the work or display
- B7 l# b6 u. l9 X$ Q" c' Z, u+ g
8 F9 i; P0 D0 W6 t' E9 @3 E1831542
: @& N. @; i% C4 q4 s6 @ CAM: PR- Simulation returns a Collision (Tool - IPW) but does not shown this
1 N2 H4 ~+ s. H) w1 }9 @
- ^, W6 i  V6 B+ K1831580
; b& Z+ A: ]3 l Shell expansion result has bad areas; V- g2 u; A7 b1 p6 P
8 ^8 t" `( e' z) X- Y
1832583) ]) v" p+ _/ V
Descriptive Part Name is displayed incorrectly if Item Name is set in Russian8 _9 M- t+ w5 i  w+ s2 P
6 w( p1 I& u2 Z  L$ c: J1832737
6 n' o2 ~2 ^& a6 f An Invalid Tag was passed to the tag module 3 |% q  p: B) T$ W
$ ]% M6 R7 O+ I" ]7 P& i9 k: a( E1832858
& G# V6 t. p! l) g8 w8 R Copy Electrode fails with internal error when not saving file with2 V5 q8 G, l  r' o/ M+ K" C( P
8 B9 v* w9 H/ v3 d; e! @9 B
18333006 y8 E+ C9 B3 I9 R% Z' S
Formboard is not created if all wires aren't routed
* z/ F$ \1 E: E% y# ?8 Z$ C9 D3 C 0 i5 U& z8 W, |) b. \/ p* h0 j
1833579* b% J" n2 H- ]6 K$ r, r9 u
Machine Code Simulation Reporting false collision between Tool Holder and IPW
% r6 g2 c- P8 W   y6 a& P  d- M  ~
1833821- Q; ?0 ]# j! |
NX Speed; very slow performance in general
+ `4 ^; R, z& F" m6 J2 s
, [) c: n& V; Y- O& P1833824
5 Y$ _6 {' k" V- t" ]6 F Missing splines after ugto2d
: `# q! L% ~& S" K1 g5 \
' L4 w6 `" ~' E1835314" A/ v6 {- _5 X! w, g. Y- e
Missing preview-path on transform_copy_instance
( O& L* t- g& w4 Y2 j9 _" v # x" Y2 g  ^( j& h
1835846/ G' A; Y4 d. T2 z0 \0 e
Missing marking lines in NX 7.5.2 MP21 ]6 P" N4 D8 \9 R
2 f0 t$ n4 p# e" o" ?) b: X0 Z' G1836366
4 F% q5 @2 F4 \9 i 'The string entered for a database attribute is too long' error is incorrect
' _5 G0 M4 r; n* j) C! l- Y5 t 2 U* q! c, P9 ^- T* q  A
18370397 q" I( y" o8 w: ^& n( s  x
General Fault Exception in Export
7 l5 @: p8 N/ c" N! W! U4 r# S% c. x
: `: ~, g) n6 R3 Z& ]1 z1837276
2 s1 g+ T7 m9 j& H- x1 s 2D Exchange doesn't translate 2D centerlines correctly
& X7 F) W; T" s& A, k
+ J5 w6 n( Q1 p. S, n1837387! n$ P" `* o' I4 x  k
Simulation does not stop by Part collision with Check ON
. v* \5 u& j7 t 6 O0 Q+ q8 ?/ M5 s& A; t6 }/ t  J
1838038" U. L% F9 P" o9 z. [- q+ _
CAM: PR - update - Milling - Turning does not work correct( P: J5 |  y6 C
* l. j+ u3 Q' A" [9 f7 A
1838447
* ~. V) U- c/ h, G/ a PRO: Empty when fails
% r! d9 T1 M* a# }* O
& j1 g" L1 {1 }- J1838488
% S1 M# R5 y/ f: z' @; y2 u; M 2DExchange: Drafting Feature Control Frames
' ?" w" m% W% g9 e( {4 }# r
; Z, C9 e! v  I. c; {! p" N6 n1839536
9 L, {( }( J. w: `/ |- R) ~ CAD:- Deformable part ignores the center constraints after edit# ?7 _  b* g* `  J# f. R3 k1 p
4 l+ ^- {" F2 z& ~; h% |1841392
- p( m6 c. f# j5 T  h* q  E  p# t Problems 2D centerlines while exporting
2 s3 }+ l2 w; H: @
+ V: }, e3 |% s' W/ J0 I1842127
" ]9 G- r9 [) x1 \ Scrap Offset Face creates gaps in section curves% {% ]2 A& q2 g# d# W
# o) `% p* @1 U" g( X8 O
1842132! l7 C! G) h% L
SURFACE CONTOURING collision check adds unnecessary moves# r0 r# \  M+ J, [4 l" b+ }/ y
; L0 ^& m0 P% C  m1842139! u% `# d+ U2 y% U
With Passes Add Delay Code for Grooving Operation$ @! p% f) C6 D; F; u  Q/ Q) D2 n
. A- k0 G; x( D0 t# S2 W# ^; ]
1842898
% C( i6 f# k. \6 F DWG: 2D Centerline becomes Continuos after . to dwg
1 X  Z. C* w# J# t
9 V" p. p* g2 x, R0 s. x- }1843011# N# ^5 n" D+ r
CAM: Cannot switch Optimize Regions Face Milling operation
0 t: p) c& ^& u3 w5 \% Z
8 G3 |( o8 W8 b* s+ x1843297
5 `2 W  F0 P! e8 f8 }: ] Feature Selection Toggles in Find Feature are not working
- s- ~+ r4 e" l% ~7 [
( r! k! B0 n, L% {) q18433328 @; I- [1 b2 d' v* B, l
Customer: simulation files in TC and native have different naming syntax
$ S/ @3 X$ w; H- ^6 X. V' g" Z$ ?
) Q4 J' Y1 M, |) r5 e' z8 c1843769
3 E' g' l; o3 P; J) f% I; G6 d UDF cannot be positioned with KF 3D True
3 M% m3 p0 s0 z8 m! E, I
# f/ Q9 i$ b( _18440020 j- J) a: a, ]7 u
Insert Blend Raises : "Incorrect Object Type" when Selected and Edge5 {* n4 |% F5 z
( `; S  ~. @- @1 C
1844122
+ ~- Z8 H. j) n7 j; X" h/ y+ C Couldn't open in NX after upgrading to Teamcenter8.3" C0 Q; |" n6 F( A6 ~8 R- @
5 n4 e; ~5 O9 U& P, S
1844332
( a7 i9 ?/ b+ X% g, X8 p0 {2 Y& D% d CAD: Touch and align Constraints didn't update after moving the component+ O, P- |% P. g" c, a# K
* ]! P5 N0 M3 c3 i! D
1845255
% H0 x# R/ N' D Zlevel Custom Depth Common Distance does not set Range depths
% R9 |" v4 v; \2 P 1 r: `  a7 l# I2 L6 n2 v/ e
1845415
, J. Y% I& J: X$ J" A" ~1 k Error update upper draw die from NX to NX 7.5# F. k/ x" Q* R* w1 ]% j3 l
3 g+ V4 n& F; ]; I4 ~& |: x/ }
1845507
# ?8 ]* A  u) V# u# a# L5 F View update 10-15 minutes to Section Edge Curves, 10 seconds to extracted edges
" I; v- V0 D) J3 Y$ n: S$ M
8 r7 j: `# C) B+ b4 R( h$ q6 k18456446 R: }' f3 `6 m4 |4 y, W% ^
Draw bead feature: reverse placement face direction
( _) v2 m$ ?, Q1 n4 {
, b, q# r/ \6 G9 D2 C1845739
7 d: z+ L; v& k& e Trim Post feature doesn't trim solid body with sheet metal body
4 F. ]9 S( n4 z$ e7 ^/ s , B. Q' m$ H' _: X% Y' \4 ~+ w; J
1845815
0 o( ?- |0 R, `& h7 v: ?2 a* f CAM: PR - NX does not realize different between internal and Settings0 z& I" R- o3 X  Q7 \
% j* |$ P0 X7 b" p+ a- U, @! ]! a; B
18459260 M3 Q0 i2 r4 c
Unknown curve type error while opening drawing 9 z/ p  a2 [2 F: D
: t7 W1 v5 C' Q9 k( }' T* M  R1846247! f2 e' E: j4 E4 i* M
CAM - NX crashes after change displayed part on close
% z. L' U& k; ^5 r   A; B. E  B- M* N
18463478 J1 u1 H/ o- h& Y  m- u
Check-Mate: Cannot set NX status message after custom heal option
- b3 M2 K1 d; h ! ~0 w8 ]. U1 u9 }
1846418
. e5 a: V: d7 T3 a  p. \. ] Import assembly to TC fails when part family member exists and logfile is used
8 I0 l% a9 D: E7 W& P
& c7 }: C! W1 M' v+ ~. _18465491 W! g% n8 I+ H9 V; n
Apostrophe is not considered as special characters for solution name9 Q) O( [; c; R- h# B& ]4 e
6 s) U* w9 k& _. d% a+ k: w18466464 K. W$ @. w) ?) g. g, @# q" N
Parts not loaded when Multiple Revision6 S7 C; N7 p* \4 {/ B3 w: q
  K, A: J* @8 k4 ~! d4 S
1846822# T$ D/ t, E6 s; v0 O
KF class fails to add the UDF to the active Feature Group
( K+ O, Q9 o( Y9 }% W- e, _: G% r 9 `, ^9 k; n6 d; x- e7 b1 q0 K! }! I
1846857
3 {- b1 h* E+ T) n" g' u7 g CAD: Electrode Drawing not updating attributes with long project name
) U4 Q  k  }9 a; |2 c! f) Z # o) F2 m, T" l1 r
1847249. d4 H; J& I# I9 y, V
In turning, with Flip and Reorient Tool, the toolpath is bad6 V: q3 e) ?# P- c9 s7 S- q8 U
! w1 B: W5 I4 T2 W; \
1847289+ Z5 X/ m8 b  L+ U# ~6 a9 F$ T0 H
Spline loses port associativity in deformable clamp + G0 P; Y& Q2 E7 p
, M% z, H% I" ?  I% j" W1847333( Q) s8 ]% P, E- ~& M1 k4 I
Missing for a Non Cutting Moves when IPW is Active, z5 [( y; B& w2 P& w# x/ W! M
2 Q! a3 D; u. f/ h9 n5 M18473385 V( B- C9 [( t/ A" b/ N! F; ?2 g
MP Russian text based Expression Formula is not readable ( O3 R! }3 o7 y5 m! f
1 d. C! T/ k7 }3 o; e% `0 y  T( V4 l
1847397& V; v. S9 T2 ~' E3 B8 B
Invalid or unsuitable OM object to delete array (corrupt, instances)
5 V$ _+ v0 E' I( V3 h/ y9 X8 f
3 ^6 G3 i- B6 k# l5 ?, z1847478$ u. P% x; z9 Z* W7 E' G
C++ error when creating a new detail view 7 @$ E. G+ E3 R* `. \; @
0 ?8 M" z% [1 d) Z" x18476059 _) t, H9 v- W: q* M
Missing_wrong support of CSYS when replacing components
1 L1 c9 ]4 q9 t- `( s . j( {6 s/ h8 b/ X. G6 l6 t0 G
1847612- F: q; o) h" |' t6 ?/ I
PRO: cannot redefine link to assembly for  & ~2 d2 @: s1 x4 T: I
& p" a" E. B2 ?1847761
$ j+ Q( O* |% h* x Orient branch does not work in case of a loop& h4 e* m  g4 g' \$ q
2 [( R4 u8 U! \5 u1 N6 h) t18484105 U- U1 L' a& X* B# X
Orient branch gives unexpected results ) R6 ^2 X4 g% R- A
' s& P* ]7 z  G5 W1848411$ Z2 Y7 s. k& i9 A* J
Can't open specific files since NX 7.5 6 \, V3 e- x! {6 g& A' X4 f' z
0 |6 `& H2 i1 J' M" \4 S+ T3 Z
1848413$ e/ w( `; c2 n/ d. d
Flip component gives incorrect results in NX 7.5.3 mp1 + T: L2 O0 K8 a6 J/ j; U0 V
* t6 ^6 C1 _+ ~) A' F
1848415+ v# f7 N# N2 F
MP - Update results show callout attribute discrepancies
# w- U6 Z. {6 c5 U& Q  u! X
+ l; F; _+ j& ?5 z  r- L1848491# ?, o6 B; _# i; Z1 Z
3D in-process stock causes rapid engage & d9 {: ~, y  [' {6 ?5 G& \6 i
1 x; |- H! o4 k5 {' n; R2 \$ j
18486665 l" R% r% t% b4 u  W* _  l) f
Move part with disconnect part flag on does not work (regression < NX 5) ! o' a  P4 D& P* F
1 ]/ k8 l7 Q; r) _3 U% t; ~
1848668
7 b: q5 Y: O. P0 k Formboard creation option thickest _ longest does not work 2 j8 j+ j8 w0 @/ U, d5 Z* c
$ D' W5 a. ^9 ^$ s9 I
1848696
5 E2 B7 K1 Y; C1 x; K2 p The filter setting in Operation Navigator does not work in NX 7.5
6 {- k+ ~: x' h0 E/ W  Y* n ( k9 C8 P4 S6 \7 d& `% N/ ~5 h
1848798
' h0 v0 p9 S* w) J5 N2 s( ? NX hangs when creating formboard
' R9 V! B) e9 Q 1 C! s4 X3 j7 n0 T& E: i2 _
1848825/ r+ h# F, F9 U. P$ R
Formboard not able to update (missing segment) ( q: c* k0 b" B: D
2 l+ C3 r0 L; B$ |1849064- y& @' ^( }4 L( T- b* I
MPrilling tools not correctly retrieving Feed from Machining Data Library ( t. m+ l4 W4 ~
( r, B9 n4 Z: N5 T: F
1849065
5 f- ]$ x9 H3 {' C Electrical routing path lengths change when assembly constraints are converted. _( N. X: f, ^: Z5 H8 o6 C  v
3 E" J0 x% s) K) X. x3 f18491555 V' {& N* j  y
CAD: Components were added to an assembly
) z, e. C* d/ W   J; S) V' H9 I+ c! X& Q% }- h
1849176" r$ V# t& R0 K! A, K' x, O
Teach Mode;Tool display is incorrect when using a drilling tool 7 M9 q3 `' T  x; p/ }& w
; a/ i  F1 Z# u( D" H# U
1849330
) m& K8 }& n! B" r: G' b3 ?, @ Analyze Formability - One Step mesh does not work within NXManager , G% Q, i4 y9 R& c$ L
9 A! @/ p& Y" l# r+ m6 ^+ n! L1849428
* D: N" L3 Y% f5 W9 X/ i Mirrored Cavity Mill operation has closed area helical engage after mirror " I7 B- S! p: a6 v& {& r+ z9 g
+ d( i7 d: U) A# a18494577 u, ~6 g6 o7 ]9 D$ ]) i* @' N
Warning "Invalid part tag" and inability to open a sub assembly in "Assembly
8 [" m6 [$ a  s7 v7 e+ |6 G
! B3 t" r, w* [0 h4 Z4 c* `. n1849470
7 u5 Z6 k( S- U' g% S2 J Wrong component if an assembly exported with >Add Part & z" r4 d7 I- ^# z! C' A$ g) ^
9 U8 H: @6 J3 t* z, |" ]
1849618. o& n% i% t7 X% V
Null tag not allowed opening NX6 part in NX 7.5 : q6 S$ t. V0 Z  R1 u2 x. b
1 K& K& y( {% b: E1849708# P, ^) n5 R( l0 j
Routing plug in for "cut elbow name" with TC fails
. {7 p  r1 s. R* J" d' q7 `
* h( P, I! V( J$ v/ _1849743
$ `$ r: j4 c! ]+ q: [6 t. e ui_comp_integer are no longer shown / T# s9 {8 T% [8 q$ c/ ^
1 }9 t( v: G$ q. D! v' W) D3 I
1849802
& k! {+ Q( f% K# s! h/ Y+ L3 f MP - Electrode Design: Wrong attributes for rotation angle in copied electrodes $ ]7 b. {1 k! e( t2 j/ T& o
1 M* q* a3 H# g1849830: m4 Z! s( e: P2 U# I4 V
Unable to delete a saved WCS
" q1 i6 l: s% q4 y, {2 b: e0 ~
8 D) ?0 ]% q9 f/ H! j1 n- h% y0 o18498414 _# P+ S- }6 {5 h
KF: fails with German chars in sheet name 1 @# h3 D) V' [0 i/ |! I) L7 j! W
) ]+ c: ~) v+ N9 H. C2 C
1849993( _" Q4 F( J: q1 `
Electrode Design doesn't initialize project correctly working in managed mode
) n9 j0 T. w5 f) t 5 i' v3 z1 l6 \
1850714
, n% Q2 i  u5 j9 r4 d6 k9 o Surface Finish Symbol ISO 2002 Standard
: N6 E: ?, e- U* |
5 G) n% R6 d3 p. o6 N$ B: K) Q% L1850797
6 l+ h" x8 ]6 |3 Q' S Hole table - wrong depth of hole ) A0 j. u4 q$ a, a
3 ?4 N3 ^* u! G+ j1 G! M+ g9 D. I$ W
1850896
7 k$ }. p+ C0 B7 V/ i. E( Z( d Fatal error running analysis with 'thresh'...
) A7 w9 [  x0 w: Z# J " s; L) E, I( |- `; d; K( s4 f1 `
1850987
0 e3 H% g& _, p3 H7 e6 B: B Place part does not work in native environment , x5 e4 E: |8 P: j8 Z) J* w
, e3 X7 @! M7 r4 \# Y3 a; h1851060: [) v# u# M$ O  \- \+ A) @4 h4 {
CAM: PR - Generation from Operation will not flagged correctly in ONT 4 ^, r+ `9 V2 r0 i" i* J! e1 j
) z* \  s$ W0 _7 N7 [: P1851343
8 w$ u' f/ R' r; F; p. |. @  m* Z Attribute change from NX 7.5 gives error
% j; o5 B! v6 K. B- K7 [3 R   f& H6 w6 X3 R% D; O2 }
1851497( r8 X4 f3 b- z8 [! i( ]) n
Face ID is missing after wave linking
$ }: G4 V; H0 _$ u7 I # g/ I/ C1 r+ k! T5 {! ]4 N2 P
1851555
8 @* r3 z: ]6 p: A1 i5 L- ~% Z$ \! H ugtopv -> no error message when Input data in TC do not exists
& o2 @9 {' H4 w9 ]
- c! T. l# z# ~! h4 x2 l2 E1851607
, u6 D0 ]8 ]' h2 h# C- x Force Save All does not create correct wave relation in Teamcenter 1 ?- c" s: s. u. F9 Z' H" \
1 s# [7 w5 _% \& I! }# a1851610) v8 H/ R# E9 ]# I, C- @
Save-As assembly, containing wave references, creates wrong wave relations
; l6 G5 x* ^# z" Q & l1 O7 K$ |- G
1851706
+ q6 b: h- v( S  P. l& C$ } Hole Table ignores depth of hole when crossing another hole ! U2 v( Y* u1 w& W) C  V
1 e6 Y% V! r) [4 ~  y+ ~1851847
- l. |$ g& \8 S8 [- b While revising, all the solver files are automatically imported
, e. w( Q$ d+ Y% p$ r9 B7 Q  v: B
& v5 l! r+ h! C( l2 I0 {3 o# i1851881  u* d* c7 m5 q  c& B) g
Mark - team - . . lost in .sim file
  j- `' {) H  u
, N! w# d$ r' K1851886' Z6 W3 p0 p' \0 l& S
Item balloons not migrated correctly via NX 7.5.2
1 \1 C. N( A7 b3 T $ f9 U5 q/ W" k9 W1 _# ?
1851948
0 ~- B  |! p5 M7 d  z/ R% X Mark - team - scenario where cannot report . node info. in .... % n/ i8 Z/ R: E$ `0 r1 G( b
  ^8 |1 N$ ?$ E3 D- a6 D: V7 k
1852030. s6 @- y$ J8 W
No Inverse generated for all profiles of a : D0433_0770318_0
+ q* ^. V. M, Y
; N+ t  T! z3 N" @4 l1852107
$ B; i9 f0 i6 D) e5 M Pressing STOP during Parallel process causes internal error and loss of work
: M& j- t) `% u1 c$ d ) R. n! C0 P- l, k3 J/ R& e/ Q, ^
18521675 \: v  z" s0 [* c) L3 X$ p, j
Open Assembly in NX 7.5 causes "Memory Access Violation" 4 K2 V$ x, d6 C  F% t* F
9 T; C6 C6 F9 P* Q1 m! U( T" g
1852433
% N; H( Y2 x$ ?  W8 q3 S7 y Issue with filtering by feature attributes
; C0 W# O$ F8 \1 _! ~2 K7 ]
2 r/ c3 E4 t5 H9 c8 O# L# A1852476
' C& S: U" q( t* z6 U9 r7 B2 O/ z2 b Assemblies fail to load with partial loading enabled
1 y8 K7 J. T) I9 `: b1 ?/ G0 v1 s 6 I8 g) y+ w( X2 ^! ^
1852526
# j0 t% F# M; F+ J  H CAD: Update error on linked body feature 0 ~9 l* {  K( K  \% h! R! H" s! Z
9 q& n" W; }; h1852531/ x) e3 ]2 D: k( g+ S# B2 n( i, V
.sim file does not reflect changes to . using assembly arrangement
3 S. L0 \) A& ?7 Q / [8 \, s' v* |+ {$ u  i
1852562
$ N7 P, W8 t. k3 ]9 L Custom_Symbol-Installation.bat fails for a space in the JRE path ' B2 X$ z3 P9 H6 b
, M' f" b8 y8 O9 _$ A/ D$ V; V/ e1852690' B7 N* R; U; X& B9 l4 k
OPEL: NX Export Assembly fails on replica Items with (name only) references ( [. ~4 F! Y2 z# Z& y9 Q( K0 ^
& n/ y$ `! R! |5 K; Y5 d1852970
, q% r" f7 J. }2 u0 c/ T Orient wcs offset in context of assembly   m5 |3 s/ V" H0 C4 _$ h. \
9 Y. H2 t/ Q1 K; c3 N* @1853040
7 L0 d) \, ]& T4 o% M Bridge curve from Conic to tangent to Conic  n+ q( |4 b% I! }& r% |
$ h" ?7 P* l1 c
1853428* u6 b2 O* w  O- s" X/ J
Significant Performance problems when Generating NC Programs
$ r3 c* [5 Y2 j  A  `/ L' G8 a ( S; B: M6 J% g, l4 Q# s
1853611
9 Q9 v& L2 j. x7 `% M NX 7.5 preferences for storing posts and divers results in files not found 7 O. y$ i9 [8 z% Z$ i  h( F
& W. L% i* X  W4 |4 u5 w1853680
9 g6 D+ a/ u4 _: x7 ~& B CAM tools remain in ANT and prevent NX file from saving % p% y$ e* N1 a
9 W& G) r+ X' ?/ J, }4 |; N" Y$ y
18537006 j# Y& ^7 V2 p& u2 U. P: a  j0 D
NX Check-Mate Result XSL on Web does not work: href3D"(null)"
! s6 ^4 r& K% I( _
2 g8 E- I+ H! s$ d! h+ A* J1853799
: S. s1 |- N, I  G Internal error when converting mating conditions to assembly constraints
0 T! d' D( j  D7 m2 ~/ O 6 f( l6 F% B* U, _  |1 {
1853830
  `) S- j6 k" } Machine Code Simulation Reporting false collision between Tool Holder and IPW
5 Q1 q8 k0 L0 R8 ?  Q6 W3 z
% V! i) _3 a. r7 p$ ~1 [1853986' x/ v" _- j% X& L0 Y$ g4 A
Name would clash with a part already known about in this session" ^5 W) f& S: L6 x/ `: B. M
* A7 c" q7 k3 Y2 U" l3 e" M
18540698 e$ _$ x% E2 f. o9 n( G
HF - Trim post does not work with a simple profile with spikes 9 ~( |; a7 j* o! G
! {1 D/ z& S  |1 Q2 X6 L7 R1854222
( \  C. Z0 q8 b6 E Standard Parts activates invisible layer 99
3 T9 _. X' t# n+ h ' |% r( j/ }2 w* o9 T8 j7 N! T
1854257
& ^. \/ G- D: i5 P9 n, j. f& ^ CAD: Feature playback failed in NX 7.5. (windows 64-bit problem)
0 ~8 M2 \! }6 {  J7 U* d. T( |
8 L9 E+ D3 R% R7 ^( t1 \1854260! @  m" @* |$ ~# \( M+ {
2D Exchange exports "Limits and Fits" tolerances not correctly " D; o% I& ~* g" F6 f
  O, z. H2 O$ e1854537+ t% U  W/ T4 z  P* q2 j
MB3-Object-Transform-Instance does not copy Attributes --- "Transform-Copy" does
  \  @) I/ D, P1 y2 W - j& m& K/ }, }; l6 o
1854570
' G% k2 i( X6 Q Cannot not use Tracking point with flipped tool; f) U' b% c' g
5 U# \& X& O) [; _- x/ e
1854671# q, w) P0 z; b( Z" R% ~( o9 K9 U
CAM: PR - Sync Editor in NX 7.5.4.4 is not usable as in NX 5
8 z% N2 w; ^) w) |7 E# P 2 K% _0 T% T3 m( B4 p& D! B
1854814
8 d7 O  m. z4 E  `3 A" r Mandatory Attribute with suggested do not change to green ticks when enter
2 ]4 ?" E, k/ l* Y8 C. Q 8 n9 Y+ r% K) Y2 d& G0 I% S+ |9 r
1854815
' d9 K' \- \5 `2 H% l, q: t7 m Font is different between a suggestive and exhaustive
  E+ V& p& g) H' ]; Z/ j8 Q+ B + p0 s2 y, n% i/ r/ }4 K9 |
1854836
3 l+ X# @+ l( R1 [7 c Selecting Attribute from' M; c+ P( E' Y9 \
8 ^" _! m7 K7 W4 b. h1854839 $ |4 x3 v3 `) Z4 Z2 j& Q1 E1 N1 M& {
Selecting values from in attributes does not work correctly
7 t7 b1 s1 a# U& H+ U7 o, n 8 H& p" f9 p) }6 z5 t" z: \
1854840
: r  T3 |, i+ `& v KF: Diameter symbol is not assigned with & P4 z  F# V! R! L
% }0 _5 t2 l1 i( f18549208 H+ k, y) V! |
David Whitehead - Siemens - format of value incorrect...
" O4 m3 [# v: U, V. T" {
- J4 R' \! H/ b& t! m$ I- d18550093 D2 c5 x8 U) B- ?) v
The incomplete Operation in is shown with a Green Check Mark
  B0 ~% U6 D) I  V % S9 C- @/ {% @/ D/ v% c4 k: l
1855093' u4 L8 Q% N$ W& E/ w
CAM - Cut Angle Vector Bug
7 k- p) x. h% Q6 H& | 8 U* ?: n1 \1 G6 I; r/ e
1855113( A3 \6 O! D+ K- o( T
Move component failed with internal error8 I; S* ]8 u# B2 J3 u7 U' n' O* D
  i( C2 K# s) i5 b1 z1855356
3 t0 x  L2 K1 Q8 o% v Feature update does not work anymore
* t2 `; A2 a9 e4 ?) G, r
, r. l8 w5 f2 Y+ g3 a; ^/ b9 ?7 u1855410
0 A9 M% X) `8 g. b! K ENG_CAM: Supfolders after Postprocessing are not deleted after closing NX4 i2 K  Q8 m8 H2 p; Q- A
) q; A& h) h# w4 b
1855501' U1 b) b$ ^. |4 {
Journal replay fails with runtime error... 6 ]% j  C: u3 S' T! G0 ]4 d
, s8 |, j1 S+ A1855729
. j3 A( O+ L8 V Cavity Mill; Clearance Plane based on a Sphere damaged Workpiece 1 h  S9 V6 L: `. w
, T$ m0 Y* B- k/ @4 p
1855789  ]7 d5 M8 F2 P& j) q$ r5 k
Parallel Generate not checking completing correctly NX 7.5.3.3MP2 Hot Fix
% k8 M  g0 u; |" L( g
3 A5 h" e! A: R1856000
  E% \* R" w& S: z! P1 Y Engage - Linear or Relative to Cut doesn't work properly. Move is in wrong direction6 Q" n9 X* Z" u, H0 y" n, B2 z8 [' \
1 W. _# T4 E7 D3 q
18561607 r* v! ^1 h2 p( R1 `+ D
Lines are missing from the view
' m. p8 E1 p" a9 \( O9 @) U5 t
/ ~- c& P* O9 X* _: w  p1856377
3 Z) v4 ]! }! ^( h0 [/ d6 F( ^ 'Start from Center' option does not remain toggled on after generating operation/ u7 k7 }; B2 I' t2 r2 F
/ p4 s6 ^! l0 T1 g" j3 q& r* z1856382$ W2 y# U5 F; U& [  V% J" [. Z; v; `$ T
NX crash deleting component with partial loading off (stack overflow) / d% ^1 P$ f9 Z& d) {8 a0 e/ E
5 s( Z) C, j4 a% j. i
1856422
0 [: v% Y( K0 p7 E8 a Copy form element does not work in V7.5.2.5+ V% W! r' ^+ s8 y! n) R
+ ]; U: t' A# k+ N) z1856470' e0 Y/ {/ m% d/ m7 u8 A2 L
Memory access violation on delete of a drawing sheet ( {6 w8 [+ [$ W- c, q' @: J) O# B
' `9 _6 f8 @% h, r2 F' g9 F9 C
1856536
) h4 W# n' L# o  U$ a Components moved after using Convert Mating Condition 8 \" y- v. \: k2 _' I
5 [% X+ Y4 p/ `9 e* x: V- R0 a1856576
2 V/ t1 W5 Z# w Wrong Position of Subassembly after converting Mating Conditions
3 e2 A* y! _- n7 N
/ J+ b  N* }6 M7 x9 |1 l  d1856603% c% m7 \6 a4 k. n
Coping Operation out of Optimized Group does not work for Geometry . ~" o" K1 W. v6 x6 ~4 P
- H& X9 E& d% ~6 C: @! l: y* h: D3 y1856624  o  B* G+ e# [- W
NX freezes  when selecting curves 7 K* D* X" ]( `& o& N& H: I
" X. H7 W9 A7 x/ J; t; \) s) {
1856642
' |! Z+ R' t* \ NX 7.5.4 - Teamcenter - - MB1 on tool -> 11
8 q1 ?3 g5 l6 q3 R1 E 7 k; n2 \& g- T( E2 @" ~3 p
1856823
4 B7 s# @' T# |  |5 N' V" `" T5 D KF UI: Extended Text Entry not opening in NX 7.5.4( x" z! d: ~5 b! [1 d# w1 [
' O9 f6 ?4 \* v, t) q4 |+ j
18568421 f/ l6 X: C+ y% a
Getting incorrect output for drilling cycle in NX 7.5.4. NX 7.5.3 was correct
: R/ g: \7 J+ ?' z 3 E; g! g& g3 X3 m9 }
1856886
/ l8 t$ b; l6 M1 G. b: @* l$ D MP: Fails to generate Contour operations via . In NX 6 it does; |: _5 Y5 k* h0 u
* j7 N# s! s4 S+ j# Z
1856999* b# r) j, q. j6 @, U+ m$ C6 I
Move ID-Symbol, Annotation cannot be associated to a view 8 T" }' |. Z9 J
+ j7 @2 k4 x8 \, u! q8 B9 f18577804 Y  ~$ o! R$ v0 V
SM_free_in_area when generating CAM Face Milling Operation MAC-OS  , E/ z' Z5 O/ E
( `/ r2 c' v- l! R1857871
+ t, b& k, a, [ CSE - Fanuc controller parser error " Parse error after reading 'B+'" # Z6 O  V! m) q3 f- }& @: _
& O; j6 L7 J; i( I4 H
18579844 S. W) H) ~5 }  y
Assembly cannot been open fully because NX session terminates
; f% f8 @% f7 f/ r9 {) f. \ 7 h, ^! a( s8 A( k& e. u
1857990
- z8 Y5 \% F( a/ Q MP Attempt to set the tag of an object to a value already in use, and not for a
( F1 [* ~% C9 _. G' b5 l ; O8 R9 C; C9 h) c; Q) j$ v
1857995/ _, N3 K. W8 A
PR1849659: Section Line Preference changes
/ L% `# o" ^- n  T. v( J" i
4 O1 a9 `- r; @0 [* o4 Y  p1858034
5 |3 g; N) d) d% a. M+ l NX 7.5 Refile - Error: 1020001 - File not found, {4 i3 l4 l& j& `8 v' `
; |2 z, }7 o( o8 B1858058. w  @" f; N( w3 N5 U' g! Y  o
MP - Wrong MarkingLineAttributes multiple (same) profiles on OS and cutting side
! d! x  C# \( f. M+ ]& d" P
$ i7 \( X- L9 H1858236
  g$ a9 W/ L. N7 I Snap distance not remembered 7 u# j$ A. U) V
0 C, g( J* T6 p6 b( L+ G( F5 g
1858244
+ |& j8 X3 i) I# Y* r' [ File->Export->2D Exchange... DWG3D(wrong H7) - File->Export->DXF_DWG3Dcorrect / a4 A) a0 S6 P' ~: r% D
  ~7 R% Y+ B  B8 i# g1858280
; t6 G* R3 W( Q; I6 N Part Specific issue: corrupt lightweight representation
! f" E& O; p4 i
& ~: p* y" K6 [" M' ~+ N* x1858336
3 D6 N. T+ W2 t1 o/ a7 T5 \ Parallel Generate doesn't Work with Teamcenter
. n$ `7 d- u2 i7 n2 ?8 [1 R! h & ^- L$ h/ e( C$ I' N: |0 A2 K
1858347/ g( ?7 P0 `' D+ ~1 N; q% [
XML output arcs incorrectly , ?, v8 A4 @6 l4 U1 H! {
9 i& `1 J# t0 Z' N4 a. O
1858451
$ U# w! O: p& v) ]9 R4 G Error Message when Simulate Helix Motion for Controller - r/ J7 }: K* T: t, ~
8 R' J3 T, A6 L' a5 x" x' V% ^
1858462
, R6 t: u6 I! j1 r: j6 W Taper Angle greater than 90 degrees fails to update in NX 7.5
0 q! B% ?3 e% ~, R" y' q& O( z/ c5 O
2 H/ E  E0 n- G$ H! U0 g1858688
1 |+ ~  P8 L1 r- g Motion links solved with Recurdyn come out of the joint during animation ! j" j* H2 t9 p4 t
* s: w$ n! w  a/ ^
1858717( s' R& i, x; b# I6 w* {0 v
PR: NX2ANSYS: KEYOPT(12) issue: Contact type bonded not translated
/ q" Q' B) v1 b: t5 r : E- a. W1 b$ O" i( Q9 C0 C! D! D* a) ^
18587858 C! G& X5 O5 m! V
NX 7.5 to JT wrong positioned component after translation
& c- f5 _! V& O0 T5 m4 L' p   Y3 |7 b, u* ]" Y
1858873
. `9 i! f/ J( o0 q, U9 \* s! P Step drill material removal incorrect in 3d verification - sees only step 1
  N" {1 \( g6 y0 r6 P- ]
9 k- O) M. d' H9 m/ O18589238 J( I" Q) V4 R
Special characters are changed during CGM export
; a: P" K- A+ G. w $ u0 ]1 V/ w# s: |' T# d2 Y6 [  R/ T
1859010* o5 l0 m: v- i6 T+ l, d/ L/ b
Scrap Designing shows then changes Sketch Annotation character size
# |. z1 B1 H* }3 C+ a
8 @: r2 Q: r! H: Z9 h$ e# ]1859039
4 j7 B. V* W7 H+ P9 n PLANAR MILL- engage using Ramp on Shape when set to Arc
0 U: X! H- `$ } 4 G1 f: ?! T! d8 h: F
1859095
9 Z2 ?) D& T" Z& L  J: N Motion simulation works not correctly with RecurDyn solver
  `2 t& f# r5 J5 ~3 M
8 V6 O; O- _% W: j8 A1859168
, z& ]" C5 {8 M. b  i PDW - cannot create a user defined Punch in Teamcenter Environment
# Z/ g) _, L/ {5 N+ K9 h3 K* ~7 R+ f ' }+ j/ U- O. S, A; l3 b* T. C% N; s- a
18592308 o) Y' ~8 w: L& V' z( h
String Expression does not change after editing spreadsheet( O- r3 r1 Y4 a# l) r
4 L! E& u; l* Y- O: Y* ]1 Y1859253+ v4 N" D/ J# Z- ?
Plate Preparation layer from Single parts changes to layer 1 after modifications
8 Y; n+ q6 p4 Z/ R/ S( H ! e9 x$ b. x: \: f* W
1859265
* z% j" X! w5 G4 i" e1 A Assembly Constraints: Touch Align, no reverse when connecting spheres 9 m# R, q7 t, N% p0 R  \3 z
) [+ l# C) g% i2 {$ Q4 Q
1859281$ O/ V9 t/ C: b9 L" v& b+ [. i
ID-Symbols flips after view style is changed to extracted edges
; e! `! j, o5 B7 \- E2 H- m1 @/ y 2 D7 [, L( d3 P8 n  j
1859309
* ^; ^8 A6 T3 a& A8 R  S; b8 U9 d Part family spreadsheet edit Error: Failed to set Excel running
7 T5 }& y- m; l4 M: F, {* Z 1 v! d( h/ N1 Y9 b" Z0 V, K
1859402
/ u- S% m9 y) N. v9 C2 o6 m MP - Electrode Checking does not show interference like assembly methods 3 m' `, U7 G' ^0 L1 ~4 s
& H: @5 q( n+ R1 I1 N
1859408
, _/ d7 f8 F0 L+ H/ k% Z  _& S7 S After Copy Electrode, Name Rule in Part Name Management changes
9 z" ^  F! q# b8 n# ]
; e- v6 p! F; x* t4 L1859435
" f  v8 Q# r+ S Has wrong stock size caused by missing Z_LENGTH expression
5 @3 |( O2 k% |% u  ^! _ ( f  M4 Y! U: s; |+ d$ Q* `
1859464, V% d# r: u, u% m! Y+ |- d
TRA: 'Re-specify file' for SolidEdge ASM fails with internal error
) C: A: n1 O& c
. C. N' ?1 E4 n* v% U. s. j1 e1859535
3 o  G% q2 b% h2 {( A9 c( e CAM: Selecting an operation from Unused Items causes NX to terminate
( g  j3 Q$ w8 h& k
+ S& G% O+ c& m; f1859539
, ]- A* i" h+ u6 k% v! W( P5 O& q# z' i MP:Cavity Mill operation with a results in internal error 8 Q' G8 V$ @! `/ ?
, Q( Z, M# L6 L( K) c
1859548) b! Y# w/ W! \; Z' N5 H2 @
Tool Path Verify does not work with custom End of Path Event
  ]/ \, b: L% W, g' l0 k
3 k/ o' O# D4 N$ N  @1859648" B5 ?, P* U8 n6 J4 n) r
Update components ends in internal error (2168657) # C0 y7 c- N. X2 c+ `0 K, n6 ^
# g" T+ s: V1 @/ z3 X
1859664. j6 m" x! e0 {/ A0 o
PR1849659: Section Line Preference changes 3 s  c3 C" v1 q8 p- H, c$ j
" Y& j1 v2 V+ b) O# {1859695
7 e3 n, c; a8 N3 K: S Part cleanup takes too much time to complete on a model * ?% d- `. h5 s" i
( r% E; e% B; Q
1859735: P/ B# ^  _- R3 u* |1 [
Switching then opening a component cause an internal error - d  ~8 [+ a6 o# G0 o* X( j$ w
/ A: Z" J- e  }2 H2 g& W1859807 ' g$ t3 |6 O$ D% s
Attempt to save a bad pointer, save aborted (580134)
* ^/ V* J  F8 z  b: C( t" K: q
( x* p5 \: k' t& ~& C1859815  f. K) l" `" f8 S; D
Unable to select attribute value at the top of the LOV 6 |+ I& L# q1 ?5 ^  n
$ ^, s' {: o& d' [. ?4 I) x$ ]18600965 r# g2 N8 `4 ?1 J+ W2 k
UF_MFM_ask_selected_fea_list reports 0 selected features in NX 7.5.4 # @" e" N8 `8 @0 \$ ^) F$ W: m2 ^
- z; a' g# V2 p4 d8 N: E& G9 e, r1860167: h0 k5 J  `% i2 w4 P7 A
BomView always checked out! + ~% z3 E9 d! a  p3 y& S- g
: s; k: O$ ]" w4 b) \/ u3 [4 |1860271
/ p# i$ g5 D8 T: z6 G' j PR1849659: Section Line Preference changes   I' L4 R+ u+ T& Z* u
6 T0 l7 F& h( m# D2 v% p
1860408
. n7 f2 g3 x! j+ S% V$ n Preview Motion does not move all component when machine is loaded in Mfg 9 l& o3 V" _; {) {0 e
# h) }' c3 t5 G$ K/ ^
1860631/ H6 ?& t! ^0 T  [5 G7 W
Tim Loyd - siemens @ rolls royce - nodes not on geometry after fem, merge face
( j6 L/ p1 S1 X& j" G; E
) N) N4 Q7 v$ X" U" X18606391 @0 E9 W3 Q0 }9 O
Synchronous engineering application user problems (eighth package)
+ _, c; x1 L- \0 D! k) I0 n" H 8 l( S6 C, i1 w- N0 n& [
1860695
) T' }* C1 u$ k' n ISO tolerance symbol fails to show correct on 2Dexchange export + q9 B7 X" y( \6 U( a' ?
2 F9 R' P8 n& A  [
1860839
7 o' t! [0 ^2 F1 O( u6 P' l  p' ~2 b Face Measurement slows down NX Session " x1 D" N$ @3 W5 Y: ~1 g  |
( s* p1 ]) ]1 z2 u; q6 ]) ]# {
1860863
; |$ C7 F! d9 D9 T4 b- h, _) F5 s( e7 A Memory access violation when opening NX file! A1 m8 n2 x" }7 _+ V, w7 X
1 r! E6 R+ E; Q( b: l18608931 L6 w1 |4 }; J' V: y
Detail view label shows wrong scale factor : N# K1 R" z! y$ m$ M
% v! z8 t- N, C: [  c' [1860910/ k9 R- J) V% V' J% B# Y) @* S
Perf issue Showing main assembly after Show_Hiding Constraints (comp filtering) 5 N7 f3 Z9 R: m1 L7 `
6 J, E5 V3 z6 z2 j5 u1860972" F& C) n: A7 v/ ^2 S% p
Checked out BVRs after parts are closed from NXM
+ d) b$ O$ {* y4 l& `2 `
% P7 d% E+ Y# y" Y1861202
0 K1 b5 O9 ^4 P4 s MP: Check-Mate "Report Member names" does not work as expected
  }5 y4 D6 o1 x5 l# p8 f
- [4 U7 A# E/ J1861224
6 ?" U6 r' F7 H, ~% F ShowHide AssyComps cause More option in ANT to go (comp filtering) 9 o* S( t2 L6 w% d/ \; m7 D* \" j2 r
6 D1 `% N/ q8 M  k7 I' a- e0 j1861588& }& e- _# h/ J
CAM: Undetected Collision in ISV in INTERNAL and in EXTERNAL mode & Z5 I% X4 u) I  C' h+ _% a
7 j; ~* g5 ^  Y$ V
18616835 u: u$ p% G6 p2 T
Relation IM N_UG_UDF is not being created during save in NX 7.5
4 q5 C* k9 _( `& a$ m
# }5 ]1 U& J6 n+ _1861756$ ~; j6 I) v# w& x  {
Specifying temperature pre-load always reverts to last-specified .OP2 file. z- J' n- S: q0 D
0 Y9 x& n1 E: l: K. F! q
1861843
; ~1 x; v; ^3 |9 r- a Assemblies with position overrides lose position after migrating constraints ! l; U, P$ ?6 a& N- x9 W, f( r0 f
: o8 d4 c! A; a1862113
+ S$ I/ t5 K! G2 J. d3 O CAM: Undetected ISV clearance violation between Tool and Fixture
/ N7 ?4 z1 g. `. G2 a" m, y4 q
% {* z  g! p* P, ?- N) z0 ]1862206
0 U- K& D) s) g+ o9 | NXOpen returns different tags for extrude_sketch curves in NX 7.5 part
- S2 z0 o9 J+ o/ k) m6 [" T5 |
: i- V- }! U3 D5 ^1862245
  _  ]8 M' a; r& |' G$ K+ S( U Point names not available in .fem... * R3 G* G2 v% |; p/ q! @0 v
/ ~4 d. j6 |* {, {1862248; q! c; N: P1 A/ Z
Routing Destination Characteristics not working at different assembly levels . H9 V! H1 }( \; Z' x" I! a  \
8 {; A0 m0 s" h+ p1862263- e' L) G" g4 ^2 M  T; d+ Z; r
Declan Nolan - queens univ. belfast - point 'attribute' not correct in .fem file4 J* U9 l/ d  t
* d$ U% i; N/ |6 s
18623403 ~# r  X' f1 |2 B: L
CAM Templates have very large file size   D2 @, `6 N& u7 u% Y/ ^
6 A3 p4 y8 w+ J% Z  W5 C1862383% m$ J- O: C2 I) o. q" a+ C! k3 k
No 5axis post event as of NX 7.5.3 with equal coordinates but different vectors & _7 W! k; y2 ^' q' J" |, S
* |8 m1 o1 _$ v: j1 y- m$ W% D* F* ~1862402
1 u. i. y* x0 Z) w8 _/ O4 _ Replace component does not make component visible: i* e/ h7 K" u0 e
0 O. v2 S! [4 d! [- @: P; @1862550
" c& M% A1 D9 y3 f7 q% f3 Y% X. U Unable to open part in NX - internal error
' a" ?: i8 M9 D+ Q0 }6 F, `
$ d  Z: y" O) J$ o9 K# b1862589) _6 i) C" I1 Q9 }/ o
Formboard flip component does not work in NX 7.5.3 MP3 & r! u" M0 l- ]$ M8 S
3 A$ P  k  n, @4 D7 ^
1862669. K0 D5 C7 x; O4 c
Tim lLoyd - Rolls-Royce - 'frozen data error during volume meshing' with NX 7.5.4/ x$ j: U7 P3 H$ W3 n
( V0 T5 m5 Q& |! r/ ^
1862877" Z' i$ S" b4 ]5 g& @, Z
Feature Mapping does not change orientation
- x' O; Y& ~) P. j9 Z ' `: J. m% U' E
1862933
/ P: t: q: t' q  d2 |+ f6 p CAMR-CSE is not able to parse "match" command in S840D controller within NX 7.57 A/ Z6 F! I. O* A2 k: ~& `' [. j
) d, m. D( w' }0 O18630877 Z" A/ q/ z6 w
Move ID-Symbol 3D> Annotation cannot be associated to a view
: ?( O4 K% @& F! k 5 q4 F  [% ^7 e6 w' j! |) F- z
1863113+ ~# k- Z! e% z: Y* G  s1 P9 w/ _
Inconsequent string length for company specific attribute
- D7 ]( o  D8 U2 [3 ^9 M$ j6 ]1 q
. I1 h! B* N8 Q! q" t2 l18634267 `* t% S. ]; c
PRO: Cannot change Reference Sets after opening part by UF_PART_open)
  ]3 _1 q5 W! T
. B/ I6 C% c, B( I0 d. H3 X+ d1863650- E* y' J! t# _, e0 K/ O! W0 k
Memory Access Violation after edit with rollback
# `5 G" s6 c3 m- \3 r5 F; X3 d % ]! F9 D9 s6 {9 |# m
1863686. J9 Z2 |* B% p) D6 J# L! T
   Flip component gives incorrect results: W; D1 Q, R0 Y: N( }
; X7 B  k$ s/ H3 R) Y1863714
  h* ^) K" J4 U& X% q! w/ `$ P' {+ W Connectors fail to orient or flip following formboard update
( E# Q1 [" ~" ?; A3 x: ~& F
. l; z6 `; I- b8 Y2 }' X18638901 O& o# \% N" a7 e1 U$ P/ [5 |
Overstock missing following replace boot
0 o/ X) C. v. S  d: v5 {
' s/ [$ W# ]! `8 u6 p) w1864108* V) y. s  O$ E
Some assemblies cannot be opened ( n* c3 Y, A( l! z
6 n& i1 F: _! d2 }2 [1864116$ q+ U( l- s* S% z2 ~& A7 y
MP: Leaders  lost associativity after update drawing, fine in NX 7.5.2
) m0 g* N. G: j6 T9 y' B 7 {/ z; n: M; d1 q; T
18643690 @7 K# E! `1 i
Inconsistent display of Tangent Magnitude value in Bridge Curve command
* u; q/ N" V( G+ a4 ?# } / d7 L4 z0 }2 N: C4 c7 d: g
1864554. x( X4 y0 }( j6 b
UGMANAGER: NX UDF dataset remains checked out in Teamcenter 4 H8 \" V) I% y; x& F
$ n% ]" b" I9 N- x- z& K
1864744" O/ X! A) }. n! ~$ V" R  _  l
Colliding parts are not highlighted (64 and 32bit)4 e+ S: n( ?9 H. P
: s; m- r4 I! z9 [$ e0 l1864919' N8 v  E& r5 i; Z4 [) d. y
CAD: Delete outdated sketch constraint fails with 'invalid solid object tag' 3 S) y/ g4 M4 J/ L
. |/ x& d: L5 I# s0 |% X) `0 ?1865191. G+ T5 F4 X; w/ R2 ^
Place Part not created at port location - but absolute Csys instead
# s8 ?) H4 t# I5 p! {) A
+ h$ X. H0 @, h9 P& F% {% O+ Y1865245+ s2 O+ O/ q! F( R2 i1 {& b  _
Making a feature array and it is not possible by using a existing parameter
9 T( z3 U7 w* B+ }, C; T
# ?0 f3 r" A3 ^; T1865330. Q: z1 M/ ~! J
CAD: Internal Error while adding component with remembered constraints 5 n4 E% S% ?, L3 k
) A, g/ M! J: B# e/ N/ H
1865409
1 |# i1 L& Z2 E5 h Unable to move an annotation, NX comes to a halt
0 T: p( k4 s" ~2 j 3 q  w  Z( j7 V; B& s4 i6 R2 K0 n9 I
1865440) p6 Q( D; M9 J$ O
CAM: PR - Parallel Generate does not work in managed Mode (PR-1858336) 4 d! `; j- U7 ]; ^
$ g1 n& W0 b% K- f( p# j9 i1865519, p/ k# i2 m% M3 g& W/ K$ v, b6 Y
VAI-Issue-046: 2DCenterline was converted to nothing ) s& ?! T" d. l
2 r. Z9 ]5 A$ c* I1866102" o0 N3 v2 C1 ]/ A0 x) K
Detailed thread function not working correctly in NX 7.5.4 $ n* j1 M! \' {8 v9 w; L
  M; q* y9 K* P$ z5 p1866167; J6 Y* a' M& [+ r5 T. T$ x
NX crashed after selection of edges for Moldwizard Edge Patch8 i4 a  ~1 Z3 V+ Q! l
) w' y6 Q( f% S. J( ?1866538# v& b) s/ f: l( w. f
CAD:- DRW Detailed view label shows always 1:1 regardless on the entered scale 2 b: ]5 o) r9 l' Z6 S
9 h& E9 X8 }  p5 d1 @7 v
1866560
; W- Q5 H3 B1 ^( w& A7 R% ?: H NX 7.5.4.x performance problem to create Pockets in MW environment * W, ]+ n: O; N0 }; e8 t
6 ]& R; R. B3 e- Z( C
1867206
9 X$ C% q% Z. F6 Z CAM: PR - "lanar_Mill" Template with Tool Axis "normal to Floor Face" stalls NX2 s, _' \3 J" v( Y! z
# t! |0 J' A* X# e
1867342, p* _4 ?8 D* K) h1 w9 x* ~; x
Loss of trimpoint associatiity when OK is pressed in a Trim Plane Point dialog
+ S4 C5 X2 x: z- W
/ P% C5 u: a. Q7 H, q: G0 z. j9 x+ g1 [1867348
/ V; F- x  W9 F; M. k/ ]8 U- [) h/ }% S Losing NX Lathe Trim points rectangular offsets upgrading NX 6 to NX 7.5
* B1 j* I% U$ s/ X# j% u( U  H0 S 4 K! O( S, Q* f5 S
2068590 - L. k. a/ e! u% r
Inconsistent display of "STEP" setting. {& i7 T2 y' H. `$ d
* a' u. F% z' U% G/ `2068849  M) J1 M& Y+ o; H; V( u0 m
Every time the path is different% e& u$ s4 O2 o
( n) @, d: a# c# `
20834548 w8 @# z9 M4 n9 `
Location of component doesn't change by setting Angle Expression to 180 degree
: U% x3 ~; E8 u6 |* F' F
1 X( n: E4 v* p0 c6 Y2100966. o; R$ f: k1 b
Bridgestone: Surface Contour produces tool path with spikes
& d5 }8 U+ J3 H; \' O" {- z: l 9 A2 [: F' H2 _! L
2103268
: m) [6 g/ f1 u  x5 @ It isn't possible to renew "Mating Conditions" correctly
7 q  N; ]" a0 `; B, I3 u
; s; [4 \% P: D- P3 E- L6 O. x, l8 v6 L2105722, H, k( W" Q% z3 j( |, T# O- N7 u
Annotation associated to dimension in expanded view is lost when view is copied1 s2 `2 k$ p0 D  u4 W
" i1 a# d* `# g  \0 K* E; c/ y2109967) e2 {8 L* M1 R* S$ q6 n
CSW:About "Modified components" after the "Update Structure"8 J" _3 f! [) d; u- B) d+ E2 A9 ^& {
2 i' v- W$ {( t; I
2115689, h- }: ~% }. |  t" }3 O
Scale and Aspect Ratio in Feature Control Frame do not work   d( H; K9 \* Z3 z" K4 z. x
- b5 M. W& g# I& ?0 i0 m8 d7 ?2116582+ X  N6 X% E2 x) R+ g$ L7 f
CTEST: Feature Control Frame is set to "Non-Assoociative", it synchronizes
. q) o. @9 ?' o3 ~
' B) b4 h3 Q1 i; t: W) `4 u: h2118657
7 R' p, w7 x! L7 a* w8 X# @* A) r9 F Cavity mill gouges parts when tool axis is not parallel to ZM
" n2 ~: B3 W/ @& i& v% C: k
0 f, R) S( V  q& u5 w2122850$ q: s# S8 B( n1 [* E3 \% |, \
i-TEST: "Associative" attaches though it makes to "Non associative"0 u6 ^/ ?0 T- k6 s. X+ X# o
* _; F8 t2 t/ ^3 L2124319# _) [. v/ F% A$ ]
AFU file cannot be imported into TcEng from native" L2 K2 h4 p8 b3 ^) N/ Q  O$ k
  r/ r* {& c& ^. a: b2125614
! V9 e/ Z) z" O& Z0 v+ H Centerlines not exporting to dwg " m2 l- S# c# K+ C! r. ]# g
) r# D& u( Q5 j; p% }1 A
2127459
, V  [. n: f) u" c Editing a Pole of a sheet by moving will Hide the sheet edited
( y2 s) w! w0 J$ m1 f: B7 U, [+ v- P * s- e: ?- i9 A! R9 a2 o; g* ?
21275927 i- S/ V. n$ t9 S! q( ~
CAM: Gouge check is not correct. K' m6 }% v/ b6 ~4 ?0 S0 x9 u5 a
% }. h3 H8 G; Y. D7 L2129442% {! _- x, c  K7 e+ R6 ?
UF_MODL_model_compare_2 Error: Incorrect object for this operation & p* O6 |  V  X3 k1 c% M" B  D
3 F; z4 e- j5 f% V5 u
2135915
0 s# e1 Y/ e; k6 f4 T Unable to display the replica component in ANT, if it was deleted in MyNavigator
& W3 r) \- j; s  t( {
- G( h; K( n" n) A0 r9 Y* D! T2136968
  d4 `# ^9 l1 P) H& e- I Helical engage move violates part stock value in face milling area # m! {) Z2 i. \1 G  Z+ g, ]& G" [
4 R4 g& }/ i1 y4 v
2140442
" Y# y! A/ a' M/ M( C+ t The drawing changes when the view was updated, A+ D; ?' Z% C. Z. ~
$ K) H: E4 r& e7 O! u2140444) G5 r- W% w( W+ |
The drawing changes, when the view was updated in NX 7 .5 4 e+ b% {- [3 g' \
3 i" \; Q2 m+ V2 P! H
2141351# C& w9 ^/ z: y# B8 g4 C" G
Custom symbol moved after update views 5 ^7 h: X: i6 z5 t6 [0 w& B$ o
6 v8 r1 ^" [. Z2 l$ N) Z
2141906
4 G# [4 J9 j: t: u9 N% z/ z' e  c7 H# y Take too long time to create parts in NX manager2 J6 k% z1 c4 A
2 G  `. s: x8 W- y8 C0 p& j2145061" |* G3 O( v% H. C5 B" N" @9 S
The threshold of ESE and EKE is output by the index such as 1e-5
; K2 o; r' e  t  A& e , H8 I2 v4 I3 {2 o
21452439 J% n1 `; O( @# d
CPJ The Inferred value is incorrect0 N2 L$ A( t2 f( P# o* u) r# w
7 c7 A. a8 U& P% {) c
2145872
+ G+ s/ B, R3 ^+ k, D( c5 z About the error of [custom symbol]   v. Z- x: ^- u* y. r0 `1 k5 S! [. I
5 K  K! l4 |& S2 N) f; c0 u
2148866
# H, a5 @% h# d" H) V CPJ-VUP: UAF_UAD Failure(NX 7.5.1 ip3) - NX 6  SB Drawn Cutout fails update NX 7.5
) _+ {5 a5 ^  W
% z2 Q! X, L' ~8 a. _2149653
- C5 j- R9 X9 \5 e# e$ C2 k Gouging - VARIABLE CONTOUR operation
8 b% }6 h5 k& w 5 @8 U% I+ m2 l0 N% I5 l: |
2150014, C, d5 C6 I, e9 ?
Problem in tep translator
3 k) D' L% E3 f  w
: @" W9 I* ^2 E1 c# w+ {2150025; B2 u) j3 s3 t
Color information is lost in step translator
) ~% b+ I! L1 G0 z: V
" M6 j! \1 f# ^* @# b( k2150659
) B5 S* C% K. P! L0 a* q; U The color of the face does not pass 5 S" R- X: P1 L! J/ t/ J9 B. Z
0 {" d# R7 P* z) k
21508422 {/ ?* B/ y* I
Center Mark is not displayed as Center Point  G: U' P8 x- R. E( ~" N& F+ ?
, u+ N; ~! {% w1 A2152210
: U* H5 B, ~8 a; l2 m Nocore finish pass overlap problem + I+ Q! V+ i* g6 U
' m. h: i4 u- P& y; U1 y2153118
% `& b, Q7 d1 q8 q2 R' {/ G) q* n. K Wire EDM; In Path Events is toggled on when template operation is created ( \. K& w) K8 D# B' n5 n- C; Q4 S
9 K- I5 x; C9 b, m7 s% D
2153349
7 w+ \  y; y5 r7 t CPJ: Copy cannot be performed when there are 2 bytes in an Arrangement 3 a0 c/ f8 c9 _3 ]
! y' L! {! f/ @2 u! \2 L
2153468
6 q6 A# p" e4 [6 m" `+ f$ [ CPJ: Cannot move note" @( d2 h& d7 Z* @: m. d
8 X, F% [/ |# T: ]! D3 f# Z/ D2154637' ~$ S5 l) k& W; M9 D, `8 C5 A
CPJ: Internal error occurs by Show_Hide on assembly constraints in NX 7.0.1.
1 l7 j. F, g( V6 _& g4 b5 C , n7 y  F0 s$ T3 g% h
2154968
" E% m( [5 a+ P7 B PS24.00.172 - Add the Edge Blend and the body volume3D0 9 U/ u0 j* }8 u  b6 w3 h; K
5 q2 a( _$ z) U: {6 E
2156694
; L- o, \! Y$ V! \ CPJ-VUP: UAF_UAD Failure(NX7.5.2 ip4) - Flange is failed to update
: N* V' B! F* c: Z$ _ $ x6 b! r( Y6 D, ]+ _
2156748* L: B3 f' n# K+ v4 t: R' k5 Z
Dotted conehead font is not correct when analyzing minimum radius ( `, q) G+ D) `1 i
# R0 n- E6 `7 V% M
2158037
6 F2 `! ^; g0 q4 Z: ~ Variable Stock values are changing when re-entering custom stock dialog
# H1 p& Q0 Y% l7 k6 \
/ M, G6 y' N: J* n9 Y5 F2158765* t3 p$ t  q5 ^
Stock of "Thickest" is not defined as a Main Run + ^: w2 s( C7 h$ z5 j
- q' Y5 O1 ]( @/ [2 E; B2158767
* p$ s8 {: f$ p" m( I3 y+ Z. K Main Run is not reversed definitely
8 I+ e  s1 J  {/ _' E : W* i: ?4 D. ?7 F
2158772& }- j1 u& i# H
Length of "Electrical Connection Navigator" is not updated
- ~& e+ a- M! ` 1 C' S" x* z. y4 v9 G6 I
21587893 \  X+ Y. a9 k9 B
Part moves when I change a segment
8 Z( h0 J7 `4 x/ m8 z
2 i6 x7 ?' f0 P/ }2 l3 L2158830
# z3 B/ P6 \% Y& Y! a Preview toggle is not honored when Shaping Segment in formboard
4 R. v8 z9 i, G6 n+ a$ t ! C: b# x- p/ k6 r
2159003, o. K1 p4 e3 i7 n/ k
UF_DRF_ask_ im_info returns unexpected arc angles
6 @; g# U: o8 V( }& h1 O0 h
& ^( D3 I( g) J0 L$ l4 K! a4 ~8 r2159325
& h4 Q& o4 S; ^  ` HNS-TWS1: Cannot use "Move Part" on a part which has "Stock Offset Point"
; o0 n6 ?* J! O' G3 `; V
% N7 Y. U) b; K2159532
! O; C6 N/ `) s. ~* R Make Work View cannot be done by "NX 7.5 Viewer"
9 s3 }7 c; Z7 u6 m* B- F; `" B2 q% ?
6 V+ O/ Y# g& r; Y6 L. m2159632
& O0 k  w" j$ } Not getting smoothing fillets on all passes. NX 5 was correct
1 E" ~8 ?4 O. v! {, o3 I 0 r; n9 V8 Q- D+ E" d  m& Z3 C
2160120% `5 m6 i$ O  b! Z& q% N/ [
I cannot input value to "OPSKIP" in Post Builder 7.5.1
  ?- d" I9 K- B
8 m" j7 d" W) A0 }7 b2160169
9 d7 U! w) _3 C" m) [ A ribbon builder's result is different by NX3 and NX 5 ' r8 G3 z" B4 n& a  S2 |- a, H$ [4 }
8 \0 f& z7 c( R: t. a, d  Y' ^2160443# _3 q5 b) j( D! o! R
NC: Cannot specify stub side settings for each leader
% F1 x1 P- ]# H$ X/ c2 h- O
2 ^3 n/ j0 {: l8 N. `! W2160693/ a6 M0 U% d# b( X, t* [. p, i: p
The font of 2d center line changes after export to DWG
; S* `5 A% k: a4 u# Y5 ~  {
9 p: a: R, F7 I$ b4 c  v2160813
3 Y% {  u7 S& i2 X; j shape line not output by the PLOT output
- Y( x! _' I" x! K
6 a9 K; O8 O( d% O5 [4 C2160887  L/ x/ k3 a5 S# q7 o  L
HNS-TWS1:3-Dimensional Built-in Path make a connector not aligned to a formboard
+ a6 q$ U: G" h1 B/ S! f* @
0 v. L3 g& m/ l8 S2160888, R/ T! C5 f1 ^) e# W; @! P( ~
HNS-TWS1:3-
8 k! \! G) w7 u7 j! C$ W4 Z
/ T* t, Q9 E+ n2 f* U3 O0 {2160899. z; p* N6 R/ m4 E1 f# l
HNS-TWS1:Internal error happens using Transform Path
6 P! t0 V! R. x1 G" ]' Q
( A7 V% q) w8 h/ {2160900
3 D) f3 [4 p0 ?, l. r* U* r HNS-TWS1:Internal error happens when we edit Spline Path in Space Reservation
$ ?- J* D6 I0 z  |2 n* ?
0 a, H! j) T% b' ~2160904
6 D/ e6 Q# p" h3 x+ Q0 \ HNS-TWS1:Inconsistent behavior of rectangular stock on line Vs spline segments
- z4 `" C& J7 }  r. v( |! u6 ^- z
6 z( q: p& N& |# K2161059
/ C2 Y0 q5 N/ Y5 t% b' Q. E/ d MP: Using Variable Streamline Interpolate Axis with multiple cross curves
  j9 g% r3 x& @% _5 Z. i1 C2 r7 y ; Z' U( [% u3 U& _# ]+ n
2161176
3 j- {" `. ?  ?% _- a9 A- @ HNS-TWS1: Eiting a fold angle (extension vector), an internal error occurs
& L, @' t* M, i* b 1 k5 l. a  u( T2 \1 {  G3 h% r$ F: c8 T
2161180
9 b! [! L% P9 E1 g5 ^ HNS-TWS1:Error message is displayed when specify to Main Run of Formboard Layout
8 n* A0 v) @. z% ?3 x/ R 7 D' S6 m3 g. `- ?' U1 `
2161182
9 L8 g0 I% [2 }, S1 O) ~ HNS-TWS1: Electrical Connection Navigator "Length" column does not update % T& Z- i" |- I+ D
# ?: U' T7 s0 t
2161184
) g  B  ?, l& s9 n' L/ y% l6 L9 S HNS-TWS1: In drafting, can not select a single segment for Orient Branch
9 s7 _, o; G2 K* n( C. \6 Z9 h
0 t, i5 ^3 {7 _( j8 c+ v8 F2161322
0 w; c0 s4 x, h1 S5 K1 W% ^; h7 L WEDM Tab Thread Point not inherited in Cutoff when more than one boundary used ! \* m" F" L; T, \5 C1 r
$ {0 D1 m; n+ [: k2161351
6 H* ~. \, k$ | View of Threaded Hole
% D5 o5 s1 E/ M0 G2 b9 ^1 Q' x' F
$ T; ?, M6 ^2 p: Q2 V21618782 h& @; e' T& L4 W7 W
Updated feedrates for drilling operation are not shown in toolpath listing , Z5 N4 A$ A$ E# f6 ]
& h& Y) X) p: ?6 h! I" A2161984
- U' D! }% e2 A  I Incorrect object for this operation during Move Component . s$ q8 z/ G$ ~! h
% f  U# Z  |+ z* O! q- w9 C0 \
2162447
+ B+ A0 _6 d" _8 z% o. v- _* N$ k Problem that "2D Centerline" cannot convert DXF
1 Y4 `4 f3 S5 s5 k0 t  d+ r' T
0 c5 F6 @, u. S2162972
, e. B+ w8 n, M! E3 s- }, x ISO_Simplified thread symbol with full thread display incorrect 6 G" J- I. G( K( \
. k4 n8 ?' S$ \, B  G, P1 a
2163099
% W8 ^1 q% m# M" S! G& C DoUpdate does not populate the ErrorList with information
. q4 U+ y( m+ Q
, M3 j2 P3 }+ m7 D7 m; u2163933
# o; m* z6 E2 T2 x2 G5 A Japanese note attribute value is garbled
" D# ^! ?0 x0 U& e2 `9 T# l
% B# }8 W, i! v9 z5 G+ H3 {$ u2163980' d6 p! F" U$ d" x# ?. _
When "Deform Component" is exported to JT, it doesn't become correct position
8 ?' k0 A! g' |3 c0 }  U
- a; Y" Y8 j+ B2164078
1 ?$ W  u( X; s5 @2 @ The preview does not function in "Shape Segment" when the Angle is changed
0 ]" r' x( ~9 L4 }4 c( ~8 S8 R( n5 r ' Y7 e1 s, c7 I. k2 V8 i( i+ r+ @
2164263
4 @3 g! B4 H5 ], T8 `8 ?( r An internal error occurs by "Edit array parameters" of "Edit component array"8 l& J: g3 v" p
1 s- s6 W$ a! D, F21642837 W; j- h! O# T* p9 B% \& G: P
The position of arrow of leader in custom symbols shifts& A5 p( x* N8 H. S0 Z. i( f
6 d  d: }* }  r% s: N7 ~2164304+ X& l8 Y4 W. f, h2 K3 ?
HNS-TWS2 : ANT does not remain displayed when creating a New FMBD $ L( ^- ~/ v0 D& t
  W+ }; B% W3 Z; f  T5 x
2164466! h6 M8 K1 W- l! I6 `: T. T  y" Y
HNS-TWS2: Not able to select path if view style Extracted edges: Associative 3 M$ I! u! G$ ~1 ^0 C. ]3 Q
: ?) [( ?' m2 X: v
2164765
! E6 v+ e$ q! e9 J" m+ ^ When Enable Multiple Revisions, Copy Component As of a linked body is broken , w+ K( x; X; X# u1 \/ a
6 H- ?. i# _! C0 \/ [21652776 G; U5 C  @) R, P$ O
[CAD]Cannot = create association between PMI symbols with dragging " G2 ]( Z& E9 \7 p, O
1 l6 a; V; D" O- H* p2165341
4 p2 j% G( U% ~ Unable to mimic "lain with Aligned Arrow" leader type 2 ?! }) V& X$ [) B1 w0 ~! d7 u$ F
! `1 y% z) ~) {, h
21653619 O' K' x) Z" u$ i4 i
Material cannot be set using NXOpen.Preferences > PartSheetmetal class , P' t( \/ h. I( P% d
8 g/ {5 V. s; A$ v/ z
2166082
$ d8 ?, y! _+ M+ U7 t1 m NC: iTest: Body edge does not appear in a drawing view0 s4 L& Z5 _! d# H# x
/ ^4 x; n8 z9 x7 j
2166303
/ X2 v' M7 a* T: U2 }9 ]. O! W Incorrect display of Blank boundary. Internal error occurs when op is generated 9 X% X- D1 D, ~3 M0 [: ~, I; ]
& F8 r& E) a! Y9 E5 k$ ?1 C8 L21664370 B) X! J" B: `' W" E! Q8 a; A. Z
Routing characteristics is deleted when picking from existing stock inf
+ v5 _$ X) d9 y1 B( p7 i9 a
9 s+ J  [& d3 r. R" X2166495
  a+ W" z0 W$ b  z0 H About a view border
, V' Y  b0 [8 t
% H3 ?2 u* Q( Z9 L/ g" ]8 _4 n2166775$ g, q+ k( a! u, l
Anti-aliasing not correct with SSAO
/ r) ^! F4 I/ V6 G, f
8 ?( H" C! L  q2166778
1 ?2 ~$ {( J, T Some abnormality with SSAO(Ambient Shadows)
* D$ C# h4 C7 B9 Z8 y ; P2 l0 P; q) {6 f4 T. Z
2166930% N. N5 a& d9 ^
i-Test Drawing changes are not displayed when updated + }5 j; Z9 H+ |; O9 |
2 v( n) R2 S- Q$ l- A" L1 ?% b2 F2167211
/ u5 ~9 W5 T. V# l1 {& g When executing "art Cleanup", some objects disappear
8 j  D$ C7 F5 d# r- e( z ( n& |) \# H. u1 x% e; _! ~1 y
2167305, U0 q- a( \: m
A Japanese attribute is garbled in Structure Manager
/ U6 b* `5 F  ?2 [
- p2 d" I4 {9 A- Q4 V- x1 k8 [2167349
, T/ G# d+ H' W2 @7 d. b) w Return the error "invalid file name" when loading a sub Assembly- g3 o( V2 h$ d, ~2 x. a
" K! e: H1 A. ^1 {2167588
) c$ i  J% v0 U( w( p WEDM - Geometry NCM Cutcom Register set in template does not stay set when used & @! b5 X4 c8 F, t1 f8 C' y
3 X4 ]/ }: m: K& w2167598
' M% k" ?) {. F  [+ U- Q5 I- n2 c+ d Disable_deactivate Flatten Assembly" option when importing IGES file in managed
0 x% [" \. w. {
. |$ j' j: ~" Q3 A4 Z. o21676783 b0 w) p" f* t+ W; D; E
The feature name "boss" in PNT display as "##" in Chinese version
9 d2 C  b4 b0 k6 X7 Q) ?9 R
+ b4 V3 }  M& s$ j* ~2167759; [5 f- a2 [4 T8 o0 I7 x! V
Cannot relate plane of Addendum Section and section of Panel Body ' A- G5 E0 V& `  V# j
" q( e7 J1 N3 Y( _; r) N7 j3 V2 z. T% ?2168241
1 ]) `  C. ^* `; q+ L% y* M0 y Z-level fails to develop correct scallop when using Flat mill or Bull Nose mill ! D& Y! O; N" {4 z
0 p3 }) k% j/ S: L2168397
) P5 |& A4 `& N4 c' _7 p4 M CAM: The path of a circular arc is generated with the edge of CAVITY
' f8 x! X, v$ P
7 |, e4 O; J- G' e8 o4 f21684373 ~9 K4 H! m$ D/ ?0 O) d/ L  E
Stocks sweeps overlap (self intersect) after removing part
8 D, s9 G' \% h. D/ ^' k1 L* {0 M
' P1 }2 h: _8 M; C0 i1 J0 w9 [' x21684694 S) b; _) B0 `  x4 B$ K* Y
[ CMM] "Failed to import data from multi-CAD part file" error occur7 l# j( S" m) }$ }% Y7 Z# k
) q) m0 E: G+ B; u
21684912 |+ E) n& q' L4 Z& V2 {8 ]4 p) ~
Datum feature alignment using "osition Relative to View" isn't working in NX 7.5  ~; k/ d+ n5 w! T" U' r, |- U" h
  }% }3 w. N' V2 V- v$ y) v4 ]
2168641; u  t( z( H* r  W" p1 V, D! d
Cannot correctly reflect the value of the attribute
, M8 O. `5 m7 P) l' O 0 d# m, A& m( I' o
2168657# I; z/ j9 c8 K( O7 R
Updating starts from unrelated feature when executing 'Make Current Feature' - T* H: Z# F  n0 @8 |/ _
0 H8 U  G/ p' D$ Q
2168658
  L$ `7 x4 d1 K( Y9 p When the prtfile is opened, updating starts
; F  L* K9 P4 C, J# U# Q   Q8 Z5 Z/ _8 ]" v6 u$ d) s' F
2168775
5 Z+ u$ M$ h: x5 R/ H# s CPJ : Null tag not allowed, after using Update Structure/ \/ W) J) W' X/ N8 Z! J% F2 p
7 s) ~, `+ j1 j* V
21690899 _* p2 E; V: v5 W; y+ W+ N! j* g
The centerline shortens when DXF is converted
7 c2 P5 |. l$ I" |, G' S
' ]3 J+ S, U% s7 [$ l0 P9 T4 l4 C2169323
& o$ |7 y0 d' ]: v9 ^; ^" m Importing Pro_E assembly into NX, assembly structure is changed
7 \1 z0 O7 Q- @+ W+ ^
4 f8 J! B; u8 B2169404+ p7 Z. r- s5 X* _5 z/ v' D2 l
About impor of a DXF file ; Z+ G6 ]; |- D
) c) p" y( c1 r( [% T6 T
2169498
$ G% S; F. j$ a2 e  [ Followup to PR2137843 about deleting views in Adv Sim and going back to Modeling: p1 v8 H, B* l
0 m1 e% j, e3 k& x) V
2169513# `9 m% m3 J- X1 P
Routing objects can't be moved after converting mating conditions- M1 e+ |/ m. m* X
2 ?  ?) f0 _' U1 p. y
21696763 k* B6 \2 ?) X
CSW : Creating Clone Assembly components are not found
" t, {6 n( A& ?0 o 8 r+ e0 k2 D9 Q* k" M5 y
2169722
3 J  d( z: a+ M8 c+ I; F! O  Z4 X+ P Turning off the clearance result does not hide components from graphic window
/ k% B; s6 o2 _0 |) v  m
7 z% M2 ^+ d# L2169742/ N2 i' I4 u! C. \
Why do grounded joints move on RecurDyn solver
( w( V+ t1 I: A' |
) `- @- N3 ?& U' G5 s: H5 r2169785
. w1 t* ~! K5 P0 a# L% N+ o- j Failure to open the part file in NX 7.5.3 MP1
6 g/ ~" ~  x; I/ o! G9 B
' n' G, i( [+ R3 W$ _% ?' K( i0 ?( d2169788# ~2 B& Q. r6 u9 `3 O
Unable to add deformable part family parts if created in NX 7.5
3 f( ]" K8 L; |# Q- O. z2 z6 B 5 ~1 O' S) q& k. r  E9 D, h
2169889
6 N' b: I3 T, N* G7 E    Underline added to PMI note is not underlined when exported via JT
& o4 x( n' Y5 l' A' y; z# U. U
( W  Q' v4 l4 F; W) m1 J2169892
9 V# f) f! ?) I/ M% x% K& _ Leader arrow is missing when exporting PMI label with horizontal leader to JT 1 O. ^$ D- \3 J# P, m" o
/ u3 ~7 a8 Q9 @0 i2 \, e' e  O- d2169894
) T6 [9 @8 d: z; r% p If and Else statement is not working correctly
0 r5 I% j' x; I: h9 x( f2 [  o
7 J" _4 q. e$ b. [6 z  e2169920
5 w( {. s( v  K, ~ Specific process in an external NXOpen program yields extra decimals in PDF
: S+ t4 P9 N: e5 o; N# i/ {+ I6 Q
/ N& M, V/ I! d* C3 `, I' e3 g# E2170296
; [$ C$ s  k+ p, }0 Z/ p Unable to edit Routing Mechanical of NX 5 in NX 7.5
  [  W0 i4 e4 T  O  {8 J
  K. R* g+ ]+ }4 O9 Z& a7 C7 a6 g2170320
, V* k, T, B1 ^7 Z2 u CPJ: An internal error comes out3 S. B) v1 \# F. J
$ J. ^9 [& _' e  p2170338
* d' I- _1 M, b4 D( ? Unable to open NX 5 parts in NX 7.5 but works fine in NX 5 and NX 6 + }4 E, ^  }/ M1 A, C! J2 R# r5 s! f
( w% d) w5 J! {2 ?
2170339
: C3 c" U1 Q2 G4 r& i0 a; R" E CAM: If Multi Blade is created and a file is closed, NX will freeze
" s' F! Z+ M6 M
) a( Z8 }, W& _21703931 L8 J/ H) J6 N. x# z# }7 g  r
The order of nodes in the part navigator changes each time : ^+ m& n) F8 ^$ P+ C$ y, v4 j& v
% m* X8 [  U4 ^$ H- r& l
2170422
% ]. I$ v" ^! ~1 L Background color for sim files 3 @& [) ~) J: u) d3 o' _7 X
& _, i( s4 u6 l; R" M2170503; P3 H4 x7 k' K
Copied models are not replaced
5 ~8 u, B; Z! O7 B  H( P3 _8 O! ^
8 |- ], y; Z; O; Q+ z" N21705154 c: \( V) a. e7 y% R
Green color of face at master part is not reflected to polygon body  t, c; ]: _( b
( w7 A2 l( J4 ~21705219 e* j& q8 u( U
UF_CGM_export_cgm raises memory access violation when using NULL options
/ B* x4 f0 v6 N# f; g( k * J9 X! z9 }: h
2170759$ H7 u. Q. T, D7 x% G
ugmanager_clone export fails due to unused components - works with dryrun
( `, Y8 X0 ^) u9 N. [1 q5 Y. W3 X( h
; V  x" k  Q( R/ |5 m2170766" G" l/ U1 a5 X) u3 k# E
Cannot convert mating conditions to assembly constraints $ O5 D/ }8 q' `) c3 P  w1 H
6 h! ^- J1 m3 A/ P0 D2170782
6 b1 _0 H8 g/ A( L" F When assign Stock that has different materials, just one material is assigned ' G2 J5 B; f1 |$ h
2 A6 `2 J3 u2 p: V" I7 m
2170787
6 n6 ?5 O# B" l9 F. U0 { Error occurs after copy_paste and undo_redo 8 ]; b) i. R! C8 d! e. x' O
9 Y: z8 Q7 U- y. T9 t% b$ }2170793
8 X; F+ U: f4 d3 Z0 m$ A& I Flip Formboard Component is causing Formboard Layout is distorted2 s- B4 F" \  }' ^
2 |- Q" t0 S2 |: g+ Y
2170901
+ j! @4 B- B, O7 s/ u Automatic alignment is different between NX 5 and NX 7.5
8 R! O: A; c$ i$ U - k2 E2 z5 N# |6 U
2170958
% m; I. P- T* L/ e& Z2 v Cannot move the arrow of Detail view label when Stub Length is zero
% r( O1 ?! {4 d- c1 I' L $ ?/ c+ E* |7 U) {- F
2170962! a; b* a5 {) n. [- K
Failed to open part and get error: A tag was passed belonging to an object that . e3 U0 Q9 {% T' b
. `' E  m" A0 V. j! [7 o6 ]2171078
  D7 j- C" j1 G! T$ O Stocks are overlapped after moving and removing part+ ?/ r/ E6 w: N. x
1 j8 Z  L7 O9 O
2171116
6 Q7 ^3 l% T( Q/ F$ [+ n2 i! o Assembly always opens modified
2 ^+ d! R  x% j+ v2 b# ]8 c5 o 5 l# v" J9 P7 `! G$ y- w
2171174
6 }8 ]& r2 _9 N6 E [Translator] The leader line and underline of text label are unmatched
5 T7 n5 {5 @/ R4 S: M& g , m) H: b8 q- B# ^: g; ^! W
2171193
4 T* ^+ H3 @* c8 g( E8 j4 M CPJ: Internal Error using Transform Path. 6 C9 A1 R3 m( V2 `* k: Z
- r& F4 R9 Z  S" M2171246* ?1 R+ m( h1 k8 X- X
ERROR: Stack overflow; opening file locks NX and NX must be killed
( @+ ~& R% w' O  p7 Y9 ] / y  `" s- Q+ b0 Q) B7 k( W9 E
2171326
. |" `% c4 C) j/ \' L CPJ: File cannot be saved after deleting a WAVE feature   \2 ~+ V4 q. u# A9 i
. W$ A4 m1 @( `% S21713715 m' P& m0 M7 x3 T1 ~  N
Display of "Completed checking out datasets for parts" to the "Read Only" part % m! }: t, _- n! F) V; t, N
) K8 M+ \5 z& B; y3 q
2171450! z' k/ l8 C& a
Faces are missing depending on Product data location / e2 q2 ]4 {8 w. {2 J2 P1 K
/ w( B/ B- L; Y, b9 z
2171496
1 J7 l9 A6 V5 \& t9 U* O! r9 b" y No constraints created after converting mating conditions ! j+ w1 C! O  h0 l3 W
/ ^: V1 o- T$ U7 }4 Z* J& J# Y2171520( |; K/ U" {* r" l
About the method of installing Custom Symbol Library in the NX7.5_TC8.3 environment$ w5 Y: H- S2 M4 E  [
) |- g' q) B! T' f3 A
2171532: D7 }8 w- q6 w2 X
Double deck blank becomes single deck after delete an electro head # Y' B/ J  }7 x5 \
" `" ]0 B/ y0 b9 N% w* C8 Z
21715547 T; g/ y' A0 \1 b
CreateInstantiatedUdf() fails in history free mode
& m" E# H+ U7 t4 e& O6 ] . _1 t  K+ k& t' v
2171557
+ M6 l* P! E. K' @! a9 _* p Internal Error occurred when close all parts after Export
8 i$ _0 O% t; x& a; p0 O
6 W" D1 B+ @4 e( k/ Z. {9 t$ e+ u; }/ {2171559
" _$ g  Q6 v% B6 ] Error occurs on feature selection from PNT after program finishes
. o: S1 U& x+ w( D9 G: X4 S6 X9 B" {
( l( R0 i: H% w# {2171708
* u# a' c' I# Z7 K9 h; _6 m! A( y! T% ] Process is looped when selecting closed section of a component - NX hangs - D+ X' b7 h3 b7 P+ F
' I' t* l1 O# s) X( a5 [& x* M5 _2171835
6 m: n+ f5 K; M5 X. v) G' J/ k Can not execute Custom_Symbol-Installation.bat on Tc2007.2.2
+ \9 s/ l2 z% m" L' u. ^
2 r5 @* x4 Y2 s9 S. y1 D" P2171911
8 z5 D! v! Z& Y; e) M8 r. Z Engage_Retract feedrate ignored (output as RAPID) if IPW option 'Use 3D' is used0 X7 U$ \* p+ C0 U8 d
% T! Z2 b- M: C2 P
2171924
7 r: T) D3 y$ g; X7 L Problem : A  part of text does not display
( t" o) ^# m0 D3 f, f* J' Y " R2 Y1 }6 q7 \7 R) r9 D
2172017+ G* D! x; `7 c# u
CPJ : CreateInstantiatedUdf() in history free mode
$ f9 I5 x' Q* \/ u( S# f! B% A( S4 I) h
8 ?2 ?% Q5 C2 _( g2172036
4 }% m+ K, X; @ Render-sets  is not reflected in a section-view when a background is turned OFF* W7 s% d- O5 j4 v. y( d& {3 N9 R
  D8 o  h9 s% V4 g2 _8 T" T21720910 L* _; z: Y  s
mom_nxt_pos not outputting correct value in NX 7.5.3 but is in NX 7.5.2
# F! T# `+ \. n4 ^+ Y 5 m" S5 {; v' T7 p
21721017 J* M3 T; `4 F6 D9 @3 Z/ n. t
File from NX 5 opened with NX 7.5 is "Out-Of-Date"
4 i/ `* s; ?" q; a1 Y, B, d . O' E1 v/ h6 [2 i  d( I( l5 v
2172232
  J, i1 `9 x8 O! S* t0 y5 g- c( L% i Can not export the part out Teamcenter & j- ^) Y7 H( R, P
- |+ w; W4 \9 ?/ O" U5 R2172260
5 ~& N' J2 I2 T. O& i. S Selecting PMI does not highlight associated face
, _# M# \, i6 z+ X* U# g 0 c: C$ m+ Y5 m
2172278% s+ q6 g4 Z6 N) T
It is not overwritten even if it allows overwrite by [2D exchange]$ k! q+ V" t1 z! e) }: \) X
1 z0 l3 ~& J  H7 D
21723024 S4 H, D. D; v1 i2 S# I
CPJ : Cannot select a solid body by name with UF_UI_SEL_FEATURE_SOLID_BODY 0 s) Q7 [0 Q8 X: H
' B8 [% h4 h' e9 w2172328
3 h& }5 Z8 z- [/ l% Q UF_SF_modl_body_ask_body(). only works if polygon body is displayed part
( v3 ]$ y0 k9 d5 h2 ` * p' W4 `4 u' J! |# k
21723477 e3 V8 [- S7 c7 r# M. ]
CPJ : Teamcenter gets "nx_access_tcclass" error for unsupported license feature5 ^4 `' Z( e% p. m4 z" W* v# F
' S; P' u8 C/ q- ?5 Y1 j, i  E& k
2172378
2 a1 y0 q% m! `9 J( e  T The selection step of [block] command is a problem
. \+ {% X7 c  \2 y% c( g + O0 |/ R7 ~$ e9 o5 L* k) T3 G( U
2172473
) }: w- B: q3 L/ C In ISV, about the display of time
, j% F( Q2 C: n& P3 w
  Y  P3 S$ a" W) g- ^  E) e' z2172584
" f( ]% W/ x% j' f$ G7 I' D1 r When expand the reused lib folder in TC, response has slowed than NX 7& ^' @: Y* Z6 R2 F/ n6 H! K
, p; o" S) {4 X( ~" a$ D9 r
2172585
, {/ X7 C3 U& q' c% h+ U) R4 c, L CPJ: Ordinate Dimension UNDO Mark not created
- R: W+ k& g4 S0 f
5 ]3 e: X2 G$ z/ o$ L5 t  b  _2172623' N4 m; l. w  c& ~9 l
CPJ: Surface Finish Symbol Leader Style changes to "NONE"
( h  e" @1 N5 O$ l3 b6 H2 B  k& S
( m) `4 v2 u; w' g2172679
! |5 O1 m; F" D Gear model does not update correctly after editing the Gear parameters ; Q# |2 I1 l. u* e, R
& }* B* D; p- ]
21726965 S6 J' O8 K3 S7 X( y8 O' O- R$ d
When "Apply" button is pressed,the description area on a dialog is extended
8 h) K% d# i# g; X$ t" c0 a' ^ ' z  [3 d6 n% z* y3 f: U/ n4 h$ }
2172825
6 i3 L  A. @+ @2 Q) a AlternateID was displayed to ItemRevision that not attached Identifer & @7 M8 R2 Z2 p8 ^+ `
9 x$ v+ e1 b, Q* g4 \2172987
5 |) P; F* d) P8 W1 S/ R The display of "Out-of-Date" changes by used "Assembly Load Options" - Z" ^2 A; t. c: F
4 d) f% {* ~' Z6 S2 k
21730456 P( u3 ~- H+ ?+ V* |
CPJ-VUP: UAF_UAD Failure(NX8.0 ip24): Unite failed at feature playback 1 E. @# M% N% `1 j
( Q  {% \5 T7 I$ U3 u
2173046# `, N4 W! b1 o# v
ProE to NX Translate not working
3 k* u  `* i& y) q1 t. W) { % A* _+ A1 T8 O. x
2173063- C# m- z3 n6 [+ f! D: Q0 R, |
PS24.00.175 - CPJ-VUP: UAF_UAD Failure(NX8.0 ip21) - Edge Blend
3 f2 a' |0 A) z' N* z5 Y & R6 }/ r* v* Z5 Z# }  [
2173077' I' U4 k- j& f' \
CPJ-VUP: UAF_UAD Failure(NX8.0 ip21): SB Hem Flamge failed to update 3 [- Z; r4 z7 G6 k! |
+ D9 X( {5 W4 ]- ^
21731919 w3 ^$ I# t8 X
MP -Execution of Convert Mating Conditions causes the corruption of RCP for Bend
9 {+ z$ `' o; e) ?% `
  A8 p' J, V, K! G$ }2173223# K0 a+ @. F/ E& G, b. {4 `7 f$ x. M
Modeler error: non-manifold body or boundary; file fails to open # Q9 m; Z( I! l, U
+ A- S) g0 r* G3 X2 p1 x2173326
" n8 _1 y7 M9 M5 B Pad, Pocket, Groove and Slot features not in menu in Chinese environment
- K( G- |7 G2 F. o
6 d% j; J" Q3 m% C# z2173475
; e4 P# Y7 d+ g8 d ug_setAttrValue() can not set 2byte integer attribute value
7 F+ L7 w8 z" f. K+ N+ X
7 i( D" c0 u8 Q9 S! A2173515
* a9 r( j# Z, Q Relativity of PMI can't be exported to JT 9 p+ Y; X; V1 j+ Q
7 W  M+ I, Y+ |1 K
2173520
  s6 B$ @- E' j' m' o5 O$ c) x8 R6 D4 | Create point An attempt was made to free an object that had already been freed / x" U4 Q9 l) F, i& \, Q/ J
! \- O2 C9 Y* b: _4 p3 R
2173581
" _( k# W! D- ?' i: r1 M Non-master part does not import as a non-master
: J. v/ U+ `* b" B* u 3 D7 p8 ^: d; @7 ?
2173625- P8 r/ K* d! i- g1 D* o
CPJ: Inferred Constraints and Dimensions is not effective
- x; @& l! y0 i/ _+ e6 |! l * f4 A. M) z3 @5 V3 Z. f4 y9 c
21736306 Y  n5 F; c' [
If using direct transfer option, collision occured in Rest Milling
& K$ J) u. @0 {1 p. D" w/ g: [
6 N2 N/ D5 x5 v' Z2173683$ P9 _! `6 P1 f0 L
The "Define Custom Symbol" dialog crashes $ g/ V! h* T) M5 e! N1 z4 R( W
5 v2 t: j( l2 d$ K' `5 f# ~! l/ e2173831
4 J0 |6 P5 ^# ~9 s  ~ The error occurs when the image is registered by the PNG format
7 w" H" g( c$ p% K; H 8 X/ u6 [8 {* P8 x  r
2173887
' t; k. Y' e) _1 k8 l Routing: Cannot determine type of stock for specify item. Dialog will not launch# {$ q, P# ~4 d7 V+ `
9 f5 t0 `* a' b( @7 L
2174203
% }: g& s& w7 ?1 B) ^ Saved CSYS T_MCS_1 is deleted after using UF_PARAM_set_tag_value
9 x8 Q$ D2 J. `, _3 y  `1 |) b
5 v3 u& Q, m( e. B2174295' Z- X1 P/ x8 E0 J+ x* A- u8 Q
Import Simulation Entities moves results to different solution 4 S* d! _6 h* d0 p' ?( J4 W3 e
# r4 @7 o0 T& _2174315
# \* g3 r1 t  b. v What replaces deprecated CgfxMattexBuilder.TextureSpaceType property
5 }! {1 j$ D5 R% r9 T# { ( }7 Z; _5 C. A& i$ V7 r8 p1 J* O
2174372
  a: g8 P% ?( [3 a At the time of Update Session, an error is given
" V' g7 e8 b" g; s3 z+ Z
3 |" r0 a3 U) d8 o" O2174566! l' N8 v  p2 w2 o' F7 R
CPJ: Drawing fails to update completely on 1st attemp, works on 2nd
8 _2 I+ I' F& G- D7 u( R 0 w* o/ g% P9 [; P9 @
2174591
0 p; j4 `+ C3 ?& f  u$ R Assembly broken with invalid LOV value in note type (backport Tc Err mapping)
1 `( I* }0 c0 }7 l* x. W
+ _9 K& J. Q4 K  |2174603
0 L9 T; J; L. K- R+ t Unable to populate property (attribute) values from expression   }( p9 j, U$ z& B! G1 A/ j
0 U1 e; h7 r1 U6 V; h. W
2174656
1 [" J6 U* D; q4 w4 |/ G4 U Generating rough groove operation with "multiple" depth terminates NX
# X# Y; |1 V2 G
4 }! `0 V/ {7 b0 D; ^$ S" J0 p2174661. f* L( A. y) E) M. q
CPJ-VUP: UAF_UAD Failure(NX8.0 ip21): Chamfer is failed to update 7 \# A$ q, x2 E% }9 K. J- p
2 i, ?7 D" @, ^, ]/ C; w2174745
. l# g& |2 p6 Z* ]+ ^3 {: s CPJ : The edges in component are not selectable with Curve Collector block
! ^- X* v8 X! G % o- e( b0 Y* }- b0 G& |0 R$ r
2174746
1 p8 k& t% a9 _, D8 `9 `7 Y Flat Solid result in additional facet body and solid body in model reference set
. L, \3 H  J) W : u1 I, K9 S. z* U" H  j
2175004* @/ k* h" E$ [+ K2 g, Q7 ~) R
Updating Simulation message remains on "Status line"
. j2 n! C& F, l4 b3 j% c
; {) ], ?# A/ p% t4 r; a2175056. L: E# Y6 i7 y
Guide Frame of Stacking PMI isn't displayed in creation when Display in all view- m4 X% \' F. h" X; V
1 ^) @) n4 A$ V
2175082
' u$ x) J" g  E Teamcenter is terminated when setting TC_Allow_Longer_ID_Name3Dfalse # z5 |* j! K2 r6 K& H# ?& b4 r' j
% f- W. w" O# z' w& W; z
2175221* x- f6 |* R, s
It takes too much time to place library parts from Add Reusable Component
. @0 w6 T& O( W% W: u: K- l7 A
$ k# N" `5 l/ V) A/ T+ s- N; |2175264( I3 H1 T0 s, m$ J
Associated intersection point flips to opposite side NX 7.5.4 & NX 8% ]' O" y! |/ p0 u
& ]3 y1 a( ~% a% W4 p, d
21753235 |2 x4 S; j4 B
[URG]part family is added from the reuse library,the sub-assembly is checked out; e/ g0 w( [4 B
/ {  G. p, z* D9 B21753289 R$ I' F$ ^' v$ q  w# k0 V
The direction of the "leader" does not change automatically
7 V0 u1 J! P: t: K- c; R2 d
* X( ^5 B5 n2 v9 p* Y2175340
% O) |- b) ]8 m4 V) i Edt Sketch with Rollback causes session hang due to Continuous Auto Dimensioning
2 a; |9 r/ a0 G, o8 U. B1 r & ]0 \7 C' t. C. K) ^+ }2 m
2175473
5 g- X1 K0 e2 C: a# ~2 D Alternate solution - one of two identical constraints is reported invalid ! T! ?+ |7 t; l  w8 x
5 p- H) I) n. }4 ^) G
2175667; G/ a; X5 P" }/ c2 ?' g2 g* u. w) o
Cavity Mill; operation status set to regenerate after generating the operation
" B. S- X% g. x  m ! `+ D- L, v+ t+ N6 |
2175951
; Q1 B0 ]/ b3 a3 M" @/ M CAM: MKE does not start in a Japanese environment9 N9 R, X$ P0 r9 l
2 x+ m# K; z4 l- `4 U! T
2176078
- |& H+ U* @) r: O8 D# H: K8 h UF_MODL_ask_feat_faces() performance regression
  K" x" s7 o1 u& j6 X. D( h
# ?1 O) o' V0 j/ H21761438 w8 i: `% u9 M1 S
SST: Internal Error opening assembly in Tc# y0 y! ^5 a+ A$ O/ G
4 Z4 @2 i2 B1 [" F4 r; O2176182
5 a. T; y6 D) Y+ n8 t& s& G: {& }1 c, ] Recovery error if an assembly is opened % D. \% ?; F; ^
, }& B. p2 @- _; ?5 s; d% ]6 S8 h& g1 G
2176228$ B" l, F6 P" ?. a. n
Creating stress graph across iteration results internal error in Japanese GUI
. }7 M+ j9 K9 w; _: X) X
4 X  w3 S6 s4 l$ W" v: {6 U: `2 v2176248
2 x% K: N) H4 {# R; |4 i Unwrap Curv changes after an update in NX 7.5
& M$ L2 Z/ z7 J 7 K& a% a& C3 g7 q) m1 I
21762509 q% k8 O! m- O5 ?+ M* C7 u
Unable to edit the color of instanced geometry. {  @5 E+ X6 J9 p1 f' e8 Q
: k" P6 B) s) K21762546 a( m) X; ~+ r; O
The error that doesn't occur in the former version happens when PlayBack 4   \2 D* m8 I$ N" p5 A
% `' [6 k& Z! \  o* @
2176377
: P. ?2 ~6 P+ \) n UAD:After up dating the drawing, symbol moves  Y* L' q0 O& w4 z
9 t6 j7 A4 I8 g7 F2 M' l
21764502 u! g5 u5 i( O$ B8 T* _! a
URG: Parallel generate fails in TC 2007.2.2.1 ) _1 T/ O; o9 R. o
/ x! Q& n2 f, p& ^2 R- _2176453
3 I- |3 F1 r0 o4 Z& G UAD:After up dating the drawing, the length of sketch line is changed 0 Z  ?/ c0 b) y5 A! e+ ]
! T4 }! c0 L9 C2 ]- ~2176533$ U4 u: z( J) v! R
SST: Lightweight Facet will not be displayed on NX 7.5.3 ! \) \1 a1 ?+ a1 L$ V
# t% t  b& o" ]% ^" }6 w- I, E+ a5 }8 Y2176536
6 T7 _- ?9 j: F  }' Z; k0 R) l The text in  the cell of "Tabular Note" in DXF is not imported - `+ ?* h  j9 g9 H2 ~6 v5 {
" {( a! E7 S- C
2176549+ W+ j* K& k2 f! ~" A4 X" X5 T5 g9 P
SST:when FMS_HOME is not defined,ugmanager_refile deletes UG data set
2 r, ?2 ~, H( P$ g' d
$ c$ J3 C4 J3 W: ~) a2176608
1 [! X. f0 s1 u2 ]) s/ L/ O2 ^1 W7 A Template part dialog is appearing for some components when assembly loading
* [# N# W0 |; v0 _% M " u- C( g: W, [/ C5 L
2176738
; w/ _/ h. T5 ] A path is not displayed in a lightweight at open time
/ H* M8 `/ L/ Q( l4 z- X# e+ r% @
) |# Z$ `* S- J# s- V5 P; c2176764
2 ?+ N) T) }1 T* O Mesh density value in "Spot Weld" is not displayed correctly 6 M% {% f, h5 z2 v. Z  C. s3 g! N
2 H, M4 E0 V+ V% R9 @2176898
2 S* u- s. }2 u1 t1 ^- j The display of sketch color became the dark color 3 T# [9 |$ g9 b# s
- ^! `) k& x+ J9 E4 @! @
2176965
: O( ~% w6 H6 N7 q% O; @ Background color defined in prt file is not inherited to sim file
- f' S, p( J3 G* {2 X7 x. W$ u & j5 \0 @8 g3 @+ I8 O# v
2177117: B8 L% j7 J; \- [' P
PMI dimension is not shown in the correct direction9 f( V% `) u8 s  g# Q8 h# ?
# f2 T1 r2 a6 y1 \2177157
. I5 L: l( b. B4 F+ J2 L After insert UDF using the API, we can't use Active FeatureGroup
8 M9 d1 p9 B1 p/ X1 X- N # _6 D" c0 i6 e0 Z" i  f4 H! t
2177158% Z/ u* G3 ]& i: C3 ]$ w: ~
When we insert UDF using the API, the UDF is not added into Active Feature Group, y/ ~3 p0 O5 i3 ~( Y( R- j
% p( }  R8 I3 h  B/ S4 ]
21772150 `$ |$ r% Q  V9 ]+ E
An internal  error is raised by cutting plane of streamlines 3 R$ ^5 n" f( F4 t1 L
5 e. J. s! A) ~4 {+ {
2177221- j' p$ h) U! R0 U8 z( Q
FSF is not calculated correctly when Life Criteria is Max Share Strain Life + i& K0 J. q8 g( C3 P/ z1 M
# ^6 n3 Z2 K9 V1 `) }# V1 S
2177223* H) f; z3 [( a8 M: u
UGII_CAM_GC_USE_HYBRID is retaining some curves used for tool in FACE_MILL
$ I1 h! e1 G! |+ R! R/ X
/ k) I, c1 s6 V( n; N2177364
$ k- G! \( w) K5 Y CAM:The message of THREAD_MILL operation is garbled
; i( _! ?4 s3 d0 ~; T ; D2 I8 c2 {1 N2 q$ ~% j! ]
2177427* [. O6 y9 P$ H7 c2 A- F" A
There was a problem when running command "Delete Routing Objects" on a new part " ~- w% M; e  k8 }( k, O$ \4 B
7 b; w/ a% B1 V( W# c0 L5 W
21774486 k' H4 i# K- W
Delete Rout ng Object raises an "incorrect object" error
; z0 N" `. Y0 g; _& d! W+ i, `
, k, U+ s, Z4 K21775726 {% I0 m6 L1 g# C; e: a
UF_FBM_GEOM_create() returns error code 11
% J( X& l5 r/ q! b* g; }
* [/ U' q7 q3 Q9 @3 j1 Q2177645( P: G! k+ ^1 F0 x) e' D3 ^
.89595 can't be rounded by rule 3 P- {3 c" y& {4 X, U0 G' g
( w, ^! `4 n: K8 @4 J
21777639 k- S+ D. @9 z5 a
Cannot open assembly with Internal Error & b) |; g3 n% ]6 H% r. s1 h+ p6 L
% [. \$ j2 x+ o6 C! G2177795, ^6 @% l) e; J& q. W
NX crashes while opening assembly
2 e' {1 f4 u: S9 z- [
$ Z0 F) i) u6 n& i, q: J5 J, X9 Q2177838
1 m/ L- L: j/ i' ~$ n* P  Q Cannot open assembly in NX 753 with open error 0 O$ V; }; m! t1 [1 K$ z
0 D3 D, ^+ d' W. d/ u. a2177899, ]% A2 A) u2 M, p7 U
Issue#06: Cannot open drawing file & Assembly 9 g. ?$ m! W% I. {' L
4 _) S3 Y) q0 S- }" E
2177906- ^7 A7 d" v5 {6 B
Cannot open assembly with IE
  P/ L* o9 e) o# P8 r7 X ! J0 V+ S) ~; ^% \
2177914
8 Y  E4 l/ t' C2 o+ O Issue#8: Cannot open part file with Modeler Error 1 |+ h: i& m1 \7 F1 w6 r5 y
: K1 Y+ z) ?, ^9 `9 @, X5 _2177994; J7 f# M6 x+ v- O* x7 i
SST: O_S ERROR: signal 11 when loading assembly file , b2 D+ l% d- P' h
* ?' n' |4 z. @  z4 ~2178088
& O8 [3 V: _2 W- V+ L  b NX 7.5.4 - evcrvu.c: Unknown curve type opening NX 4 assembly * c3 d: C' Z. i6 g5 b5 H: K) e4 j3 o
6 _; O  q* o, _! |21786229 Y7 r( O4 S. t9 H: i& X6 Z% W9 S
SST #21: 2D Drawing File Open Fail with Internal error + s! v8 C& @5 z; u; a6 ]( |' W
% Y, j7 ]1 U" L- J/ \2178922
5 R3 O- a; |: A SST #26: 2D Drawing File Open Fail with Internal error ! d5 c. S5 A( |# W
" w- G; ]( h, C1 N% Y
2178932
" Y& }$ j9 v0 U  Y9 { SST #28 Cannot change the window of Top Assembly file 5 w) S, p5 J* }# E, o# [/ X: Z
8 w5 H0 G& E! C$ m6 J
21790354 Q0 q; i0 Q9 P! N1 R' @" n
X-Form Proportional movement not working during edit with rollback
, m! M# b/ k0 H' G' p7 n* K7 b+ |
3 M. B9 \3 a, {- ^! m/ f& k+ m2179192
3 B! f0 N0 N  W: n9 _) H Thread Milling error display message is unreadable in Japanese language
% R4 _) ^7 J0 c
/ e; K, g0 y4 s" r% p21792021 n6 ^) P, X4 @0 {& m% Q( X
The color of FACE changed when it was made the Lightweight display is not re) R3 W* _& _3 Y' D4 Q. ~
' v$ \1 Q1 E# ^/ z4 y
4086825
& u/ T( r' O8 L: A5 @) r" V. ?" l2 M Update Structure from Weight Management can leave invalid components selected ; `" d6 I* C' b3 W2 I9 f5 {8 a
# y4 H7 ^0 l: M4 a9 H4758411
, }: P! N$ l' @; C+ |" e Warning message from assembly weight analysis even though the operation succeeds
7 u7 J& F4 `# r6 c% ]# ^) Z
- w- B. N1 o$ U8 d7 E4843093
9 a6 f6 W! v, \. \( @( L# i Generate listing file does not set value to "on" in .tcl file   K5 O  ~# s$ M$ k+ Q" s  Q, m8 M
5 f/ o4 J0 c4 |2 Q9 l4918801
% b' l6 M- `% Z% J% W' R Part Navigator UI issue - in Details window: highlight exp, move cursor,then MB3
' @: T  i; s, ^ ! s. }* b+ a) y# Y
4929740
+ T" r; ^4 U; w. z, v/ ]4 J3 O Floor looping issues. Scalloped flanges; m5 [' h% E9 P
, @. q! h$ n0 w1 n* p* |! j4946503
2 r0 A( n6 J2 i1 L Multiple passes on floor toolpath is very bad6 K  n: w5 m1 o  A/ @0 k
% A7 z* q; H! m* T, x2 E5086570
6 r5 z" K4 `; Q. p Part Navigator ignoring edit exp. environment variable 5 ]$ {" G' S! n( Y% F" }3 Z
7 [& m2 G/ Y6 z0 A
51165116 s5 T, }, w$ c$ c; {
Machine tool not loaded in ISV Simulation if no license is available
; ~$ b4 D/ @; Z8 A + {8 `3 G0 K5 U3 j# a2 \
5161514/ P$ x+ e9 S  d3 Z/ e9 O" m1 D6 l4 v
Reposition ammated component causes other components to disappear2 P' S" `) v& X' |+ F2 ^$ D
  n3 W& r& C6 K% W* V) x4 F8 E
5213590. J3 V7 }/ ]) @) C3 I) G, Q/ u: Y
Filter renamed to Match any of... + r+ P# b+ A" V+ u
: L2 t" B  Z+ d; s2 {, ?# M5 y" F
53390267 N2 m4 j, @! ]6 O' x0 |
PS_24.0.152:NX crashes on Face Blend preview (in pskernel.dll) ) K$ b/ F9 P+ o6 ^2 P6 H
0 t$ r9 j% {3 E. _7 n. x* {! r
5358426! b, j/ ]  ^) D! |$ q
UG Crashes during the generation of a Zlevel_Profile operation on Faceted Body
3 E3 B) ?$ N( P4 `2 z% x# H 3 f; a" C1 O* A- P+ v# w- B) Y
5396446
0 Z3 K3 L7 }# w1 h update_delete error on rpo'ing a feature on piece part in context of assy * }1 P4 O' _' {1 M% g
+ ?2 y4 x# F6 o0 c! @
5410639
* l1 F; \& }1 D7 I8 r Names of 'Match Any Of' Assembly Filters not maintained when reopened 5 p8 ]) `! l: k
0 r1 W* m5 A8 t! C
5593266  v* K, E$ p7 Q  a) T; @8 y
Wave Geometry linker creates incorrect curves in mixed-unit assembly ; I0 y1 a( s( z4 U
0 \' o4 k* Y! {2 A( V* o5649782
# P, F$ ?' L1 t) [6 R- T. \ UF_UDE_set_string(ude_obj,"user_defined_text","this is my text") - not working% X. ~; ], L+ h4 [* ?! i
; M0 X* A8 m! m  f  O  _6 ^
5652234, N2 e. g8 u: a/ `' ^
Facemill undercut gouges during engage_retract
5 Y6 b/ |' r1 l$ \* T# c- v
/ v! m4 P, c3 A' h" Q" D+ ?5681628; |7 v: z+ s9 V' R: p1 n, f5 L
TcE: I am running into problems when I try to Import in an NX4 SIM : V8 y1 }: B, `
) @; d2 G- {$ K. p5763863) m" i; C3 ^, `1 A9 c+ {" D
Angular Dimension receives Error Recovery if selected on Dim-Extension of curve
/ b8 z0 r  a* A8 ]& F8 g6 t
: Y/ N8 Q! [8 h3 M/ v5 t5798136, N, V9 e9 k' T* z. n2 V! O2 `& O8 F- a
Export Assembly not functioning like NX 3.0.28 k6 j( s# ]2 _+ f8 u
9 D' H# D2 x8 C& u& i: ^: d$ q  Z5823348; m/ L0 S. Q$ |/ x
Move component while doing clearance analysis causes graphics not to show + N) D* a- b1 {5 h2 @7 s. m
$ L! {3 A8 w% k
58281018 H8 l: V: g8 S" D" h6 z1 }; y  x. F
Deformable Part fails when an MC constraint is changed from Mate to Align 7 ^6 g( I0 ?$ x* c! m4 Y
& r5 D! C  V6 y* K4 h( ]5839434" L1 h% S3 o( F
DRF60612: Flow for shifting focus across controls is not correct
# U: d; E6 y7 i+ u" U 8 L6 E4 A+ g: G! J) F0 g
5840253
1 s! L$ W1 W9 K: O4 ~; J Clone fails to update all Wave Links in NX 5.0.2.2
, V/ t( Z8 j) g; j# i , H" n6 ^$ G1 N+ @4 q: W& x
58455399 B" g+ }& x- ?3 q1 R9 R0 k
CONTOUR PROFILE- erratic tool path movement at first two levels of cut 8 f; ?  ^; d$ Z& f
* l" w8 o2 O5 o/ ^9 o5 q
5849857
* p2 e2 Y! Y2 {3 h9 `. v, g Assembly constraints with conical faces causes other constraints to fail
7 u: f/ f9 W/ a6 [
+ [0 {5 f/ a- p  W, q4 r5 R& X5861249$ w7 b! s, [$ ?! W" C+ U1 j
Getting redundant motion on some edges with multiple passes , Z$ w/ ?' q# a
: \6 t; J# }" e* b
5868639
. h4 S9 k0 l4 m( k Planar Profile causes internal error $ c9 `5 w' m) |: [* ~# N
/ \+ [0 T9 F+ X5 U' ?* f) ?
58818053 M, R! K% s( N  x& A5 A& ~
NC: Om_world_check failure after editing Trim and Extend feature
- Z1 C% ]4 J; s8 {$ k7 Y
# k+ d+ L  P  O3 H5884776
' T9 V* f3 T4 I) d6 {3 Y8 s Machine control sub-ops are not getting saved when you OK the TPE UI ( ^& I. t; f5 _7 ^9 _' u
8 E# E7 A/ q  b% b. ~
5888901# {, ^3 X) E* U- g, q; W9 s
TPE is not disabled when RMB'ing on program group, o) ?( M7 k: {7 Y0 D$ s6 L9 o
; \( u9 z% ?+ k! E5893838: R; e* b- |/ S! h
Fixed at time stamp does not populate the features list
* B2 b+ r1 u  ?. I
$ R) u- m9 I# w: k5902952) W- m. z6 G: Z: w1 o8 R' T/ Q5 i
Feed rate values in drilling ops do not stick without generating
; K: ~8 T5 c& ?1 d$ J8 k% l& a9 w) M+ B
/ W2 V5 a2 F! U, i4 l4 t8 a& n2 w4 ^: o6 L5911960+ T& z6 |( g9 D
PTP- change IPM to IPR does not update unless operation is regenereated & L( j, v, |7 \  E& t% w
" b1 g9 m+ C# J+ h3 J; B5914231
; _6 ^6 `( [3 n* z mini-proj: for linked face, the list of features does not include all faces 2 |3 l% q( r' F, J/ c& J1 u
( G* \, _8 b% J5920074
* l9 y% c5 U8 l- d/ E  n/ @ WireEDM doesnot remember control points if I reselect geometry ( g) j4 p" u$ v. S* k# D0 H  H; v
: G( d( ]5 s$ i8 Z. i: \5935468) X3 ^$ l" E- i4 F
TCM recorded in NX 5.0.1 does not run in NX 5.0.2& h5 U5 u9 w2 ^" c/ b: K$ K( `
1 L, D, D9 m% H2 W5 N: b5941903
/ f  u( Z0 G3 p2 q8 N Point to point: Modeler error: directions are coplanar ; ]1 r  M9 o8 R+ i8 A; x" Z' X$ g2 R
* u+ B& G' o' {7 O! T' U- w
5944353
( W6 q$ @$ L8 ?$ L0 J2 P0 ~ SLED-Fixed at current timestamp list box is not getting populated " A- o$ \. u" j
: Z. t9 _3 }# H
59475332 U6 k  }4 i) f
Import --> Part: A tag was passed belonging to an object that could not be found0 _) S0 t, a( z8 _: n" H, t" \. O
! d) C! d' w  G  g, B6 M5964655
* M& X: K7 T4 P* ` Linked feature not restore its body after feature modified it suppressed
6 N5 r' [: `6 {: W( c ( F: ]; [) A! J
5973030  K$ K7 }8 Q3 Y0 ]& a9 ?, Q' v
CAM: PR - Mill User Defined Tool Gouge-Check 5 V) h" S' f. C( |" L
# S* F, [# V& z. r) \4 p5 R; j
5981825% ]5 K; c7 X4 {* y! U, q2 s
JA_FCF_with Symbol as Leader object - k3 P' q2 ^8 u7 y  K" v3 Q9 ~
7 x0 d: w0 M9 c+ a5991020: H0 k) `  M$ w! Y) \: P* [) {
Opening part from TCN which was imported as CAE model part type fails ! ]* J, z3 `0 n& H4 ]& X7 h" i
7 \3 O- D3 l& s; q- ~) N5991033
; n! h6 G8 ?" M, X7 h/ T1 C: {- z Error while opening an item which is imported with CAE Model part type 4 b( X7 g) J* ?* c% C0 L+ a
! g: O6 @  |# n1 H: o5996641
: `: D* `0 N/ S) B3 }6 g: O FindObject: JA_FCF_Assertion Error_changes loc when dim as terminating object 8 D0 A5 u, T: W! y; M
* m4 M2 v- Z# w- r3 e7 Y
5996660% \) @1 C- |4 ?9 Z+ \( ^6 C( U. U2 o
FindObject: Regression_JA_FCF_lable as terminating object 3 f; X9 s3 v$ \( \. n* H; j
/ A! H+ ]. ]0 ~& N5998542
6 y0 Z. c9 F, x0 M' Z Exception Error Save As Assy Drawing with Parts List_Tab Notes ( K, Y7 v  ~* h
: P% V6 m$ |' D2 y( u: a6 N+ ?& B
6005712
7 h6 @4 M5 R' l+ U* \1 G- Q Time and length are not updated in the ONT after running TPE ) v$ o2 n6 @7 l' L0 D
% T( L  N* b" m) u
60062537 u; X5 V7 [8 Z+ K2 k3 ~8 @$ p$ D( Q
MG Testing: Assertion observed Can not duplicate - o, o/ z$ K! B( O+ v% O" w
$ c8 c2 ^2 e* G9 L' p9 @7 U/ N60111714 J* Y" n( D3 ^( L. r
Inherited constraint assertions Replacing Component (geometry_positioner)
% }8 a) N* ^1 Q7 K% y
3 ~0 S: y' }$ G6011917
9 R7 v" S! t( u( n  `- } Cloning two WAVE linked assys requires adding them in specific order to dialog
! P( b% G* T3 E' k; k$ B
/ t$ c' X" l8 m2 b! l8 S60127211 s2 p$ R) e7 J% _! ]4 @
CAVITY MILL- leaving an island on every other depth of cut
8 H$ I2 k: R, A" f0 j 6 ^9 k" O5 X1 [6 [' f) f3 ]+ N
6021295
# U! {) J4 X2 N& d NC: trim ext end has wrong brief ) t5 G9 n) C( h
) |' u3 {# v0 R- S( J1 o( q60279211 M) A; ~5 v: ~  A  |
Circular blend curve fails on feature replay ( U9 P* F& i* Y$ ^9 K' c" z
& h) P5 Y% v# U/ I; c! b- u7 U! F, K60347043 _" R5 P) K, D4 {! y$ x- E
Adding Part  family member raises the status: "no bounding box"
! V+ i4 h! P5 i( g1 n  o
: [% ?  W5 _$ O2 M9 Y8 o6041842+ ?, ~# e( T% Q4 }
Text memory leak
$ d- b0 L2 p: ]! i- r: l( `' z 7 d' E5 e% X8 i# c8 ^
6046148
# Y& @$ {5 u6 S$ \! ? NX 6.0.2.4 - Move Def. Point and Move Pole hide surface in assembly
# N! P. V6 s/ X) w* q / r/ x; j* ]1 t, \0 E7 E$ p) A2 H
60479156 q( D5 R' @& e' g# A* A
Preview success while OK fail 4 j! d9 o- X8 ]
5 B/ Y) h* l- l7 d. r5 m6057801- o5 |4 j8 T9 A# X; g) R
OM check world failed after removing override
" R$ T% s3 s* x; @1 ~8 v3 M) o
! A6 d3 d  z4 \3 w( P5 x60814312 q; U1 A+ `+ N% N' d) M
VASX PROFILING- intol_outol setting changes engage to come from floor
' E) Y* h+ p6 t/ R) Y5 x* [" B# X* i ; p" {  ^+ o2 F4 |1 I6 G& W
6081634! q" q0 c6 H9 [+ _1 s
PMI to geometry association doesn't work for promoted bodies ' |, f2 b: W' s' \6 g
1 Y: o" q, I  P: [
6082398' y- W& l; ~: e, Z
FCF_picks a different location when lable as leader object in drafting
+ I" U$ v. }8 P! F" s. G6 T' i - \8 w% b* Y3 t5 G; j
6105061  n$ K4 q! Q! X: A% H( ]
Incorrect THREADED_SIMPLE_HOLES identified9 S0 t- u( E/ o* k
. j7 k2 e) b7 e61149966 ~, \, U+ b; f* T& ]& |5 Z
Facemill non-cutting moves gouge part
4 m8 I' E* Q- q% j% a& q ' i$ B, @- J2 {  i/ f4 l5 J1 ^( [8 }
6119793
! H; v! b) K! d Trochoidal in_out both fail with slanted tool axis in PM
4 h1 B+ ^. v: y+ k, e0 U9 |. M2 m
7 S! Z$ x( X* X; C2 {6123640
, |- L9 R2 ~5 e4 C* ^5 t! M PMI label is retained when inheriting & placing the view 8 u/ t$ H7 i! B0 \; H1 e
1 @8 F( Z3 F  o5 V) u. s* h
6127544
% z% @" N0 G5 @( x/ V Journal Issue: Terminating object for PMI Datum Target is incorrect while replay
' V% K9 v( A- X+ C / b% w/ `, ?7 X+ G3 Y' K) }, Q4 \
6136926
2 S; k) M; H2 u3 b% q4 M$ w$ E No override geometry available after deleting source component
4 R& _$ G* F9 y& A8 }1 Q1 L/ U
, p2 K' D, C; R2 q4 D6140448( {. ^: \9 F. e) F
Specific Note_Inconsistent behavior when doing Undo & Redo 1 a4 A4 t+ V$ Q, K  P
. s! s2 b: Y5 K2 [) S) t6144785
& s4 j* u) M; M Error while exporting surface finish symbol_custom symbol
& |" ^3 w; _) X2 c 2 e, M6 `# }+ ]. M# v- `, Z+ [: P
61449842 f$ V1 N9 k2 T1 k$ X7 H9 n0 ]
Cavity mill;leaving uncut region at levels 8 B; t# N3 `3 d( o" I) c6 o0 }6 l2 R
/ z7 y# Y, ]# v, W$ ^/ X/ h: {
6146414+ ]: V0 V2 g% P% x. F  d
Ops marked out of date after replay only $ A: W, p& \0 s; g* e, h
8 R5 v2 ^0 P3 Q6 ]& G' Q  e6147924
4 n  M) N/ p# u  x0 d8 l Overstock behaves differently depending on what tool was used to delete an elbow) g1 N' t5 o( t  k) V
  S; m$ R% m+ R/ M1 A+ }6149263: W) F/ z+ \' C0 M
Copy and paste operation or tool looses all but string attributes
+ i7 N% r- d$ M4 L
: E0 y" D( ]( u61505408 a! h6 _, J# {- F
Symbols are not scaling as expected
9 V4 u9 C' J* P0 m $ Q! `2 T6 Z* u1 Z  \- A9 F
61537893 ]  E4 @: q5 k4 R" L; Z6 N/ N
Can't select a user of a subgroup when using the transfer ownership
9 h" r$ g  ]' @& ~2 ?) _
7 H4 K+ e) q( `2 K  |- u2 y6155516$ _% V7 n: ]9 {: ?. x/ ]2 t, \8 I
Not getting toolpath for all the holes in a face
: j( g: g% L; X1 h/ U9 c 3 K* j; Q5 v+ A" ]
6163143  Q) O3 x0 ~4 w$ [( O3 d8 F
When reassociate PMI note, it rotated 90 degrees
0 ^; g; x. v3 p 4 f  ]* Z1 M  R, H
6163390# n8 Y( r8 U4 {: a
Annotation gets associated during edit though non-associative option is selected
  l$ e4 B; C% G# C/ q, U
* U$ f4 ~, E$ I" b/ C0 w" E2 q+ g9 }6165761
+ G/ i! J5 V% v; f' i/ |' b) l( c. z) w4 m PMI & ModelViews are not exported to JT when we set UGII_TMP_DIR variable to '.'$ e5 \0 }5 J( Q) P- z8 f
+ @0 l  L# s: p+ B4 [$ t  A
6171881
& H" R$ D9 @  g9 \' S SLED_7006 Face Milling lost some cutting area, in comparsion with FM_Area 4 s7 O# M9 Z+ a- F/ C$ P
6 {( R8 @2 K/ D/ M
6178357! k2 O- m9 d; a% }0 H
Refresh issue wtih PN when hidden sketch is selected for skecth option box 0 \7 @7 g; N  [! {- Y: f
7 m7 `, }) u. s& P3 s6178441
+ H0 Q# e$ H) u! \( c Feature remains highlighted in Pn after Find Object is used $ F( t+ T4 t$ l4 F% w
! B% X* b) Y6 ^0 {3 D6185157
/ C) E% `: g# e* b" @& Q LWEnvVar Edge blend not displayed correctly& Z+ ^1 R7 Y  z; M: M
  J8 G: I. [1 G; i+ y- @' g
 楼主| 发表于 2011-12-19 20:28 | 显示全部楼层
6187668
- r: h: l0 ]: z/ O2 X LWEnvVAR:Re resentation column in ANT stays blank, doent show anything 8 u5 q4 |: u: |$ \
6 Q# c4 Y5 Q$ ?+ `$ F% \) A& r
6187676
; N3 k7 s% |/ ~0 N) L5 f LWEnvVar;RegenerateWork" require to display comp after Edit Deformation operatn6 Q# g  I9 Y0 r; g1 K% ]7 K9 O
2 m, a# d6 m. L9 ]) M; A6187708
8 T7 m- I, p& c" }/ K LWEnvVAR:Severe development error followed by an internal err while saving assy ' @6 J$ Y; [3 l/ C" ~
4 Q7 K# I4 E) J
6187771
" g. C) j2 E* q LWEnvVAR:Assertion failed error while deleting features from part navigator! ]# r# u1 ^1 w3 N. H
) G' I! j- G' j8 q: F4 [+ t2 v6188516
% C+ `) v+ N! \8 E' y5 g6 n Getting large arcs (cutting air) when using negative stk and tight intol_outol
- P' C$ V! b; o: _; s+ d
4 E5 O! f6 S. I8 X! g61907600 C! A$ u1 ~% c* L4 N3 S: b
After editing feedrates from toolbar - updated feedrates do not gets posted out   a$ A* \! H* C
! b# p- T, G# a. w6197074( K3 a; a' m. @  Q9 t' X# Q: V
Datum Target leaders not acting correctly
7 p2 c; r4 W6 K8 Q: {
6 |( f& X1 f0 u6203185& b5 R! y' H9 E/ ~- G2 W
NC: DFS are retained after redo ,when FCF is Selected as Terminating object ) n6 V* W$ F( x: P
: A% O2 X6 B$ Q! D2 W6203598
5 s. f  q5 u# ~* i Text memory leak on close all parts after open by proximity 8 v7 c- {$ s2 M) V4 C$ Y
, R8 \' P+ |5 f62038012 V* O6 _/ N! k) |+ a0 y9 v7 K
Move Pole surface should not be hidden in Assembly context 5 a- q+ y1 J! z0 j" |
. z- z; C$ `) M  w- C6210480
$ D0 I0 R3 K" _; q4 f# S! k9 C) m7 i  T! p TUndo_redo Operation is moving the leader attachment point 8 m5 R& l1 D+ i5 A3 ^: a2 T
; c. J3 s7 B5 g) a! P62133480 L' t6 m0 ]/ i# W7 ]
Unable to change feedrate in Tool Path Editor when output contact date is on 6 ]/ s8 `0 n* ~
7 r5 C  R) g8 Y( E& R) F4 `6 S# S6219955; K2 q" q8 @8 `$ M
When instance feature used as tool on changing number of instances SI is lost 4 e1 \% t2 {4 X9 P( _% R3 i
. I! v7 ~- \) `( o! i
6221717
2 o: R) D' }) S( s& ]6 k Unable to identify representation of loaded components $ D3 ~- D4 H( Z& c( B
9 y: c' w. d$ Y# u( x& ?0 y
6223732
8 F& ~6 L6 \1 }; A, u- V6 c# y Cavity milltool overcuts with follow periphery cut; FASC; gets no motion ' {; q9 ~3 \& r
% L6 o  D& `; [0 M. b1 v6 E2 y. Q
6223921
/ ?* i8 B, t3 I6 | PMI is inherited onto drawing upside down
4 w' {- s1 g" p5 }, s$ }
! ?  `7 T- y3 \& q- Z62255693 k% o( h. I, a  n; s
Vertical dimension text is rotated 180 from NX ( y3 X3 B5 c  u/ B
6 Y" j1 M. `6 d6228432
6 i. a' X0 A2 @  K6 J Cannot create an acute angular dimension to 3D Centerlines
) ?4 t8 B$ }! O. l: r5 O+ V& i
4 V+ m0 `3 X/ P6 L; [0 P. ^. [6228440$ H6 ~4 o8 ~2 J; W1 f
Assertion after going to associated objects
  z. |7 {  a9 R# a5 M+ X( x. ~( t& t , b& B' y, L6 G
6230086
; d( y- @, N& x# R& {3 u Check error occurs when undo the Define Deformable Part
) n) d. R; v5 [; u, [
% L: _& a& W& x# m1 M; I4 f62301821 E' S/ b  ?0 |& V6 {! \" a% S
Few display related problem with the combination of LW and promotions 7 ]' k2 U8 G2 _, x. y* y3 q
4 e* a& n7 \, @% M$ \6230951
) t( H# F* P$ ?0 y4 T* A Representation column showing nothing for subassem having promotion $ @' H, Y/ r4 x# R# g  g0 S' q& s2 f
# t, f# r6 R4 m6231780
: z& e8 K' R  d& z. p; g& E& A- Z Group hide toggle works _unhide toggle does not work in PN) n  b1 c- }) ]2 h/ o: w8 H$ a
. G$ |3 X) Z7 H  o9 T$ z/ m! D
6232559
$ v2 p# ?' ]2 L Poor performance for color & attribute recognition; G  z3 m% |5 R1 R1 x9 p; {
" k$ n* I2 S6 A: `7 B* ?2 t/ U2 M62410240 a2 a( B/ @$ v$ M. s
Memory leak while change Application after Open by Proximity 9 i! H5 |, f3 Y0 n; ?
8 W+ @6 E( P7 B2 m62443043 m7 k5 I! i/ t# z% U; D
Problem with own role-file 1 y7 p  |3 T% F+ }
2 |0 k' |8 O& A% T2 I
6244378; h/ [( r4 i) k/ }
Advanced Wave : Wrong results for linked Edge in mixed units assembly . Z- L& }; V5 s& Z% O& H
) I( T! t% _9 @' f0 V* u2 ]; ~: }
6244560
- I/ k) ~0 b+ N6 K2 \6 [- ] Assertion failed occurs after paste Hole / ?" R) `# O# o, b! k
6 |/ C; |2 O. s; g6246069
( v9 V, E  d7 _2 J No length on wrapped overstock on Overstock on Fittings 7 @/ l4 `6 s* i0 G, t
5 ]9 L7 A* U3 Q* M9 Q3 i9 V6248693
; f% l( K$ E) u Assertion failed occurs after undo the associativity manager 0 f! O7 W$ b' H
4 P# S; k; e0 X* e7 l
6248968  B4 Z" f/ [, w! H0 s1 [
xform with fall-off and single point doesnt allow dragging of single point
$ v$ e, u7 q* e3 G
4 j. m' }" x% G0 C6253091- {( B  c' q5 `4 [" _
Assertion error while editing Linked Body
% v, r. N& U3 e  u  ~ 1 w% g0 V3 ?" n; [0 p
6253416
; ?: K6 _/ Q2 Y8 l( H' f Unknown Overstock_Stock Transitions
$ F4 v1 S$ w3 d. {6 w3 T% a   T8 t+ g5 p+ V. \7 |
6255086
0 \* N3 G. s: S, l  P# t; x Component Groups: Drag and drop "Match any of..." CompGroup loses name
$ r3 i( q. F1 G7 }2 H  b* N9 N5 I
) Z0 y+ S/ E2 G! I, f+ ~" ?6256653
/ Y& Y! {! r4 |# Z# }2 j, K Getting Assertion Failure while Zooming the sketch " S. u) z% m! u
" O9 h) t# d( w: ]3 S62567919 L* E7 k: y$ a/ _3 _) r5 w
A connector direction is not aligned against connected path ' ?9 K7 T# \3 C+ d3 J  y
5 U- \( e2 q9 f0 N
6256880
) V3 I2 F( N3 d# v! m0 V, | Drafting objects are not visible in Shaded View if centerline is selected * ^+ t6 a. P3 p9 d( J
+ e+ r( M) S4 ?& o- L
6257493
0 e* N/ ]( e4 s8 h: M! Y Keep Selected Guide Curve & f( H6 J. x8 V
2 X+ V. q! d5 f5 m6259430
+ T+ |& ~/ u2 R6 I# J+ z3 O6 c% M Assertion removing VCP after converting mating conditions (valid refObj) * O; x. X# z$ y5 E& X
: h* p8 @/ u& n: C, [, Z6262232( |/ @8 e( d; P7 I
Edit Associativity is available in context on PMI FD * v% w" ]- q7 ], ^: S' _) X- E
5 q  k6 c* j3 g# x# ]+ j% \
6263444
; [9 u( ^3 a2 Q# v$ K Assertion failed while edit WAVE Geometry Linker! q+ Y  c% V0 {; t: g! b# l  D. Q. P
/ l: ^: U0 a& ~! [. u6264156
& }# ~, m5 {* p. k; [ NX 7.5.0.27 -TCM Apply to All toggle doesn't work for current constraints
1 p( U0 f$ [0 h  s ' P+ k* F4 o! `* S3 E, M* _3 t
6265251
( m, l, ?& Q. q( @ Modeling ugn x75_27 Autotest Failures: EXCEPTION: O_S ERROR: signal 11 in line' P; |, `) ^5 |6 R
9 c; i6 j+ Y" Y2 w6 K. ]6265964
/ e) q2 F6 y* X0 d# D* v Report on Immediate Children expands children and grandchildren & [: C( L" R5 |6 f
1 Z' l; j9 c9 ?$ _6 G6266621
. h4 K" C0 j3 e/ H No undo marker generated after generate on workpiece
/ G3 u; m. r6 z- g$ z  x  l3 I 3 H8 N0 m. X5 s- ^
6270846
1 o& ?$ }& T% I6 i( I extracted edges causes pictorial section line to display incorrectly + ]8 \/ h4 z7 w" P9 l
) b* F% T, F+ a  u, ]" k
6271853# h9 h% h4 k, r" e
Label chamfer deleted while using Offset option in Move face - h# n6 w% J3 t, I" L
6 N. E3 W. M9 i8 C( n+ h1 z6277494
1 V& N0 A7 R" [: p FCF attached to the other PMIs gets detached after inheriting them on to drawing
. P  u, f2 e$ G! o7 a! F% v9 J, q" z6 ?
) @! y) @3 }7 _7 c. P- j6280274
; ^' o  g* h' s7 Q) D2 \  W, S Wrong behavior of dimension while doing edit associativity 9 l  A; e; @( s: i  @. C. J/ e
1 d+ {2 D6 K' Y9 U
6282444% c  e* N4 m! s
Create with Section Line 'is always unset in 64 bit Windows 3 B$ d- ?6 i: L
$ x8 i/ A( j& q2 _6283544
0 Q# c7 S* g; ^% }" o! X NC: Check assertion failed and internal error occurs while simple clearancecheck
& y, S( t: e- K! C6 R! V" G
! t. H- c8 J5 I6283718: |& Y! B: l* R: J9 _& Q
Refile inconsistency between native and managed mode with -regen_lw_use_def # u2 O' H3 f% D; o: o$ j" ]
9 Z* `, [; D4 {% B6 t% B6 k, r, m8 }6283719
9 E2 {1 J2 u+ ^ NX crashes in CAM autotest check world when model already open
4 F/ w/ d& c# D: Q4 b
! K& Z. {: e" i9 K4 k9 L9 r6284182) d. G4 }) i+ A! A/ t( d6 Y2 j
Paste DDAO should not paste other feature % h' M4 w6 y9 N5 C4 _" j8 H* R7 K* c" t
5 B9 [7 ]" \, S/ g  f. h6285474
' v+ |1 I# W( N8 t% t Cannot select Pattern Points Using Move Object -> Point to Point option
( X, Y3 I9 ~% R* g& b  \; r: }. D ) q9 ]5 S. ?1 F+ M
6288301
8 i: _# l1 z; Z/ i4 H2 o! ~ DRF20702_Assertion error by selecting Templates selected thru palettes
9 e8 i1 C$ {0 {0 |) r # A( E$ I3 ^; `7 r' G; ?
6290281
- ^& R" X0 R1 b( B3 w, { PS24.00.156 - NX 7.5 UAF Testing - Part fails to update in NX 7.5 % d: G+ ~( n, N
) }+ W6 L" E3 F2 \62903790 i5 Q) E6 I% |: a- A# ]  f
Assertion fails when rotate model during creating studio surface in assy context" r+ [( x2 f6 {" j0 ~
% m. }  {+ x9 d3 c. E& i! e9 x
62904813 `% y5 y/ h9 U6 A- g6 K& j4 }
C++ autotest replay fail % u, Q% S' C" C- C- s; g
5 b  }  {* v) B62912492 b* `* B; B6 _- {) C
NC: Internal error while creating fcf with leader as flag using dfa file (KF) ) @! I. k' j& |) L7 h- c& \2 |
* \! Y9 y; z# P! M) j. k! r
62912889 v2 R: h3 l# A* `: [" F& N  A
Error during update while creating fcf with leader as datum using dfa file # E! P2 ]4 Q8 Q4 o& o
* T1 d! d4 l  t; F. a5 o
6293757( n. U$ o: M' g
Surface is hidden after perform move define point on the surface in assy context* b  l! x$ {# o( u
+ Z5 w! a$ V/ x4 C2 m, L, A
6294023
6 D9 U4 Q! a8 y5 K% q1 |* s. p) c  @7 \1 } Modeling ugn x75_29 Autotest Failures:Nodes differ : original value mdl_pointset_9 G% F% Y9 ~; j4 X
3 ?5 b  w% g" t% c/ h! F62940304 i/ y9 w; l* V- q* L
Modeling ugn x75_29 Autotest Failures:Nodes differ : original value EndOption.Tan; S. |  r# `1 b
/ z# d4 o  S! j; `( R  Y& h6294084# q, S' U1 y# a) ^9 c& a, m
Modeling ugn x75_29 Autotest Failures:Nodes differ : original value StartOption.T$ H; ]' j) M8 ]: i9 U1 W6 i& ^
" U& ^3 W' I2 ?+ p
6296249
1 V5 l7 Q3 v. p& {5 O0 s Usability Issues with Edit Part_Stock Characteristics
( _( p6 J( S# {+ H! |6 f 7 U2 |' _7 Q$ \* F$ M, V
6296353
" k- @+ M) [, A1 ~5 m; P! K9 g! j9 c NC: NX hangs attempts to scroll when mb3 content is up " R; ~# S  i! n& A0 F
0 m6 \# \9 ~6 [0 f$ b6304527! {% J! I8 B1 r! m  n
Error selecting_deselecting component while in Clearance Properties dialog   Y, G$ V+ V7 ?, k. k; z7 b  m7 }
% k6 u% U( q6 s& C- m# {% f1 p63049653 U" g2 P( c! P( d& a9 E
Edit Curve Xform> Method block Planarize tab random flashing 3 p& `% M) Q% u% g
. T3 X& O! B; Y( B6305666+ B  W" J- J2 M* y* Y$ N/ @6 i1 h
Contour profile operation hangs the workstation
% o. y- n4 L5 m/ ^
6 }3 b: M* r5 d( I) ~63060152 h! d5 n" b' P1 q9 V) t8 J
uft_mateconv _motor_drive_unit_asm has regressed in NX 7.5 1 C1 u. L3 k3 t" s8 [0 W
( V* r* e* U, u: M
6306466$ x) ~2 V% ?2 N6 U
DRF30724_Development load on error message by ungrouping ID symbol of closed Par7 N/ c0 o3 D- D6 _8 H1 c  M
4 ^/ D6 B5 b5 T" P. ~
6312092+ m) r% U, a, O9 p  C. ?0 h
Align_Inherit of Match Edge does not work! E. l9 T$ G6 C7 V3 i6 {
1 a  n8 ^. [. E; A% I$ M6312937. j' A  W+ v& I! W6 U, O+ B7 z7 P
No work in progress or feedback when selecting large number of features 2 _. V4 s( F" B7 f
& h6 F6 S4 e/ F: B6313487
& L8 \6 Q3 i2 c& W Internal error occurs when Edit studio surface in Details
! L- S; ]8 `' f0 a8 e! Z + D! F  y0 f/ N
6315163. T7 E( }; u0 k! {& F
Error using Insert->Shipbuilding->Symbol in drafting + `4 ^8 j/ A+ b, G( N( ^
1 d  {5 [( F3 g3 b0 a' C# @5 o3 `6316598& j. P( a- G+ z/ }8 `9 v: P
NX 8: Select  template dialog gets displayed for no read access ugmaster
+ M! m7 s1 \7 T' a . W$ Y2 U* D8 W) x
6316689
1 u4 E( j: c, y" m( q Parallel Generate Fails when Multiple Operations have IPW Dependency
  k+ D4 \% B0 s7 e: V& E5 G$ R # [  {$ M1 \8 x9 Y
63168492 L, W9 T6 `) r6 Q% w- A
Parf Family spreadsheet edit - Family object name is invalid & r% n8 F/ E4 H
7 d0 ~: h: g  J8 X+ r
6317929
9 ~. i: _) M- m: E/ t3 U$ B PS_24.0.147:3 Face Blend does not display 8 j# l) g1 ^! J) t' J) s/ {
7 t8 g* y' D4 [
6322066
2 [$ i% W4 x  \0 X Constraint Convert Internal Error with GM assy' d  D  I  Y6 X$ A! }6 T. ]
- F) B- T# _5 y1 x$ z6322243, h: K% x: F% t1 [: i7 Z: @% u
Create Feature Process does not create correct process : a- R+ E' C0 w% m7 T4 c
9 x' ]$ K" u5 V4 f/ P6322678: j; K/ g# H* `: w9 ?$ T; e7 F
NX dumps an exception error into the syslog file while editing the drawing sheet
2 G6 E. N) ^& D/ ?" L/ a & Y3 Q6 c6 h3 y& S1 |" N
63231929 O+ p3 h5 V8 c/ T  L4 U$ v+ f
POSTBUILDER-not getting linearization of A axis with Zero pivot distance ' q! d! S& w9 [6 o" G) g6 y6 l
: d/ C; Z' y  I+ Q  i3 d+ |
6328684; p0 [0 [( x, L6 _0 q* G
Cut Sheet annotation comes out wrong by default
/ p. C- l) W! T5 ~
7 L; l+ n3 X/ I8 j  E6330430
1 e' ?( e* c( @9 M/ P, }( Q Can not create Stock Fold Shape with reverse directions
, n2 ?2 F5 K5 C, Q
! ]6 u7 h+ r, z* D; y; H6330436# e; E5 M! T% Y9 O  O* |
Can not create stock between folded stocks
/ f: N5 i" ]1 \7 y4 W) a0 j, q9 Y) j
- ], _9 A3 g" `' a, o6331158
$ s2 A/ C4 C, V) R3 t! r Assembly constraints are not created during Routing Spline path creation & z; G# O3 o! g
; q. l' I7 p7 c4 w9 J6 @4 A- D63318950 ~/ S" S% w$ O- Y$ N' i
Shape Segment performance issue
: v3 V7 ^. H: S5 a5 V  j& U
5 ^0 g+ h8 d: |, G: u6332735
' L0 f$ f2 G# }5 y6 T7 \ Filler stock adoption from a reuse library inactiviate the Romoving Option & C/ S& K9 D' ?# k# |# z- O
- f1 x& b6 @" l5 E$ }; Z5 n6333404
5 c4 |% L5 D6 ^% \ Assembly having JT geometry overrides is not able to open , d; t3 x& s* r0 I
5 S! G1 T4 N9 p6335727
- G" D% P5 `% |4 _/ H2 c! u0 _ Rest milling operation is missing cuts at certain depths
. i* D$ r6 K) d# b" B% i
' O  d: c& v/ A& M- a0 R" ]/ d% x6339431
7 U9 q$ j2 i, @$ W2 ]7 k! W SLED 7.5.1.1 EXCEPTION: line 450 Drawing_DrawingSheetBuilder.cxx / i( |  j( r4 B- {! U0 q, F
8 A  A; D! p9 O  N+ m. L6339674- f0 r3 S3 }) A) [0 K) B
SLED: Parsolid error from constraints code & _4 @& K8 h2 I+ F% }0 ~
3 i3 A  |+ S0 |  `+ ~+ s8 o- Z0 T6339726. b' Y9 c  [9 y7 Q3 b
Not all faces added to identified features ; ^! ?# a8 d3 @7 C. ^
, y0 A( J9 A$ d$ d$ g63410068 V: \" ~3 U/ b' S
SLED: Unfreed TEXT_p_t / v* _- ]- |( `- E
! V( h$ M% ]! P' c: t1 A63418244 p) u' p6 J9 |9 ]( t' ~
Cannot apply space reservation on some segments2 q: j4 j- C9 _1 _5 |
" m2 m. D4 K0 U; O; L& a4 i6 V6344357
6 k& ?* c- r6 ^: ?* a Illegal Tag exception in autotest CamTest_dev_fbm_turning_C_del1f ' N1 D% O6 {! n* j
& R' F! I$ S7 ^% E
6348675* W$ g% F. v3 h3 ]  U( K
NX does not allow to delete the fold segment* v2 c2 R' `0 ?9 ~& i
$ c) L' S3 d3 N( ?$ H
6348721+ m# p, {. X6 {" g: v
Problem while cloning assem when Item Type changed to CAEModel 8 S' z* C& u6 ?
! w- ~/ r9 V; A: f! Y9 z" e( w- f, [6349490" W3 W/ N3 k- h& N8 L8 _
Update Formboard not working as expected
6 X7 G) |3 C8 m; e6 p: _ 8 E1 H5 s+ K- B* W
6350901, [' C4 O$ M  T7 y$ p
UDEs not output in relation to Start Marker- E) @' i: {' s9 [# @' i% ~, K; i
# c5 D; k* v: ^( |63523544 q& d, B* e5 Z& m/ s  R* S) j
In ShapeSegment Radial BendAfter selecting 3 pivot points, the Object gets de-selected; J% k! y' Q9 k( C0 l
* D1 @* V% i, b) R# L- ~
6352372
$ k8 `  M) N& {! j In Shape Segment, Radial Bend moving the Pivot point, the point gets renamed to
8 C* }3 Y( v7 {5 N' p7 j9 H3 \ + a1 R; [& O+ \
6352706
7 E1 ?: O; O( ]7 e( i VCP constraint won't update when low lev constr modified if not displayed part
4 k0 L" z' |% `  u 9 i, Q2 T5 N) y3 [- G! b
63529210 v% |* h: ]- S9 c
Redo not working as expected in form-board > Flip Component . m1 f' o% I; D0 m
% y6 I. |3 x! T5 o$ m6353416, I4 P( ~6 M3 y- I. F5 l7 H
SLED 7.5.1.3 EXCEPTION: Error code 3580006 Drawing_DrawingSheetBuilder.cxx+ g4 H8 X" _$ V- w9 F2 B, Q
5 \) g% O5 g9 a8 k# `7 P. A: J
6355907& X! X+ j( v+ m+ x
Memory Leak while selecting Open By Proximity
9 A. q9 F3 a! ~7 l$ y* E) [# `
3 E" s6 y0 b$ ~# z6 S3 F6356356; M+ q' O" T" d" N# w
Nocore Wire EDM operation has an overlap in the final cut pass
/ j2 _& x$ ~2 q# w: T& H: y; u
, u' v6 X9 Q5 T6 q6357113
. d9 i2 l4 o4 {/ T: s Arrowhead Style changes from filled to closed when changing style
1 ?9 t) q% }! |$ I1 U' G
' a5 H) Z$ R9 u5 S3 D4 T6357157
4 t* R( H8 F4 D  L" \: v+ R* r Assertion Failed when editing Studio Surface and rotate View in Ass context 2 K% Z0 ]" X6 w  n  }
' F+ \, Y% U2 K% p' {6357178
! Q4 B1 x5 }2 ^5 p Thickness Dim:The extension Line is crossing the Dimensions
0 c  N/ m/ b9 ?1 X1 w) s
' L5 t# v* ?- b' A3 `+ E% k) \$ R( C6360422
% L! A2 C- v3 S+ @$ f4 j Problem cleaning up xfer_map during error recovery in ExportUtils::ExportToFile
2 E! M- V- ~3 U  ?7 w& U6 i ! ?& C, q$ a6 j( t+ u
6362230
- z5 H3 y% l  v4 f. J8 ?" a0 X5 E Error when suppress profile_cutout's parent feature- n7 ?" N8 V4 R
( |1 l. O' S: k& Y
63625656 P( y- B4 ^% C! }" B3 C1 T
Internal error defining point with defining vector
) f! E9 h8 l1 C& c8 j" }- J* @9 w! ?
, y6 u" U  H3 s( r7 W  l& q. V& F63629174 x" t/ I* v1 ^) i* Y- ^+ {: H
'Null tag not allowed' when edit plate endcut draft type & m% V! ]& \: J" ]
" y) r5 Y- D# Z9 p. s( C# U6363827
' h- K0 y( U$ |+ O' F$ Z& g The Time Column Does Not Update After Using Tool Path Editor
( k2 F+ w4 }1 \ 6 O& B" ?3 G) {+ G) ^. B* n
6364220
  N* h' h- |2 _; L Internal error when change draft type from Trim to Extend
4 k: k  H: b8 `7 n8 ?- M# a ; [/ N+ E: i) ?3 u. k
6364221) }- S) T6 ^: [* R' X
Endcut trim shape is wrong in plate 1 I- [; n3 p1 F  S5 A& Z
# z: P+ h3 r6 M3 T7 S3 F
6365006) \8 B+ L9 Q6 X- d9 Q5 q6 J
Assertion (text_memiory_leak)fires while closing part opened in context of assy 1 W' `. {0 ~8 p* }8 Q% N+ F2 g
( [* X! C2 [7 S+ M# d9 k
6366207
7 P, ]+ o. z+ N' g; }& f Move component does not retain snap value for next time / v9 f9 h$ [% o; Q
( P0 W' C, {) d4 v
63673038 Q3 Q. U( Y1 B9 G. c' H. w1 v* O
Autotest CamTest_dev_fbm_fr_13_upd10 due to AssyJA_ReplaceComponentBuilder error
( T/ F  [3 h& |) \  H$ Y4 |0 Z# Q
7 l  q, |2 G7 n& d6367847% q3 ^! Q4 ]9 J- a
Feature Conversion: Unable to locate feature type test & L$ ]1 u: q; C
2 D% f9 ^+ Y) a' Z& b6 c6367849: z! R; a9 K! E" }
That have nothing to convert do unnecessary update after Feature Conversion 9 n' z' {$ a1 {0 `/ m
- w( v! \4 o4 D4 j9 u1 s
6367850
6 C. c. h( P- E1 R" R4 I! } Check World failure after invalid section error 0 c& l" P; m, r3 b: Y( O
+ \: Y& `2 ^0 g  Z4 B6367852
! D/ }3 Q7 w% i$ i$ S IE when creating endcut with sketch and taper angle > 0
0 ]9 Y) j- ^* Z8 B ( y' \5 F) q! P- l. v% x& L% r4 h
6367853) l4 W" U4 L( r
Endcut ignores trim option
6 d4 l2 h1 J1 x0 v9 l" u: l
7 ~0 \* ]( p: i$ |' f7 N  O6367854
! z6 D  @7 A$ |+ o# M- |) }5 r Conversion of some brackets failed due to missing expressions ) l7 N- L" H. G3 W( E  N  o
/ l: v" n& }% ^5 j
6367856
" U0 T" {' j  x0 @2 a2 @ Conversion of some profile cutouts fail because boolean is invalid & n  T* M; O) T! v$ Q% p
4 W2 V& q# e2 H6367858
9 ?. f' D% v- d+ ]( A% F( B6 O Conversion of some profile cutouts fail because of wrong attributes
* D; U/ ~8 ?- A( @" Y$ G
4 z7 `. v2 g( _* K6367986: L# o1 V# y  E4 v
Reverse Direction option in Formboard Layout is not functioning properly % g+ h/ L" |: c' e/ n
6 c! r5 V7 \* N- D) G; q63681683 E1 p  ~9 }( A* ]! b1 G/ }
Preferences >Annotation grayed out during Sketch command
( ^1 I* j9 K/ p. i: [4 e, [3 t
0 |1 l; C/ y* w: H6368407
8 ~. d; R- q/ |' y9 @ SLED: Internal error
; Q- D" T/ N0 ^6 }  S5 Y- s 0 H: l% y8 s9 F
6368456
9 W0 C: y0 K# [, ]0 ~. y- W SLED: Error deleting profile
* {# S3 ]$ e& |6 n7 \' m( F
8 K1 V4 N" a! Z# U& W6368842
  w! w; H/ d! l4 I5 D  d NX gives assertion failure while using function update formboard + K7 K% ?3 _, Z
4 y% X9 d" q6 g4 P& j' H5 y63701384 S+ T7 i! C4 Z* |
All PMI's getting retained when picking leader end object as other PMI on REDO & A1 o) m+ w( U8 r( n6 h- ~
; Z1 K, P8 D  G5 Y0 \; E6370264" q0 r- O& U9 }2 m, l% O
PMI bi-directional edit does not work for some of the annotations
! l5 @- _( n7 O2 g; k & L( t) V/ b+ _# I' u# \
6371066
8 R) |( b7 Q' e; ]; @( a, r Sheetmetal Usability_nx751_5.64 Autotest Failures: ASSERTION:: in line 827 of
6 n2 k2 [* _1 B # `5 T8 o# N; [4 }  D" u
6371500& T* U; h# V8 f
Max and min values are shown after turn on inflections
, U2 q- }4 ]0 n . K: B: A2 s7 J8 g& i5 ^& O
6371503  Q6 s3 Z* w. S- i
Reverse Normal does not take effect " `( X! B, n' {, j* K) U7 ~* G) W
3 E" ^  I- ~4 |  R1 b1 v  U
63730852 Q1 K# a, A# Y' H6 c
Cannot change G0_G1 tolerance in studio surface dialog via expression + A6 e, d# b- y& Z# d' m. D1 }
$ X  N4 d% j; \( F& y
63736910 g" {, X+ L8 n/ [( @2 i  `& E
Internal error after deleting Non-Sectioned object in Projected view
. W5 f. j! w; p$ u7 @9 F: N3 E1 O
% q0 W' w* K. N; t3 S* y6374908
$ [7 j: O+ m. }- x6 } Insufficient information on cause Error parsing XML file in CompareTestOutput
; g7 F% F% P3 W) N7 B
7 F. K3 g+ Z% D% b8 B, @3 D6375049
5 H# f  F3 L' N# q TP fails to be displayed when clicking 'show result' in transformations
6 T+ A2 w! H+ |+ D$ k 2 t/ |/ p2 D# u* ~# E
6375798, L, {% j" @% Z6 ?, ^* h. \3 n4 I
Flag leader not showing properly in PMI with the composite FCF
; Y7 N9 {5 q: g" n' ` " ~% Q/ b5 B( G: i/ d2 V& I
6377137* \% {- S' P# G6 o+ H; m
Assertion failed when edit distribution feature after deleting plate 9 S' v+ I! z; h; m
8 t+ q- ]# p  ]" d/ t" ^9 [6377157& i; ?: F+ M& B8 I3 Y
Undo&Redo on a Note throws a Warning message
/ C8 f/ C# J! C. ^  e * ]" g; U! {, Z7 _8 q) M
6377767
3 t2 j2 B% O: M Delete Routing Objects of Stock Fold is cauisng an unknown Update error
7 Z: e2 m+ b# J! I# m2 h5 U
$ L1 T! h4 i. R" v8 ^6377768
  `) _5 z$ X7 ]+ G' v$ p Autotest ugmgr_SAV_t25 failed because part is not getting saved in Newstuff
5 f4 d% `- {  t7 h) _. r; B8 x ! F/ E6 _8 X$ n2 {1 i6 [6 X
6377844  h" y& v( z' A* c9 I, D
Cannot make all connection with single Auto Route
# Z: @6 _# L0 W& t# A
: l# V% |6 N6 n7 e1 q7 J- Q$ H63784091 h! q$ C" B' u" r
Reattach subdivided segment is causing sweep display distorted & n& e% U9 _- J, X  W
$ v* [3 C) F, b+ a
63785237 n6 S' i) d# r2 f: ~: e" m
Rectangular Stock with Stock Folder can not be moved using Transform Path ( s5 i- W& B( o3 [5 I) n4 j& R! [
0 s6 w' P) |# G
6378990' S' ^- `6 ^6 m- S
[2] ugmgr_CLN_It1, test issue with comparing jaformat_xln files
5 p+ |+ A0 z  \  U' _/ Y3 B1 e( Y. h 4 ]' W+ J4 ^; U/ w5 \6 V: |
6379073& ~+ X7 _" @) J
Issues with Open by Proximity dialog memory leaks
" Y$ ]3 C+ I% ? ; x( S5 _, o- j' m. i$ N, Q5 a; Z1 j
63792575 C  L& ?; q" u2 ]
Edit circular stock to rectangular stock and drag handle for width is causing IE6 _  A& `) s( ^4 [, |
  s5 d( c+ k% A9 |9 O6379259
8 y( v  {. X: n- { NC: Internal error with Save As NewItem for an assembly with JT overrirde prompt
" [6 V( @" Z( r/ d
# r  I3 B/ I3 Z6379864
7 m2 s5 K5 q/ ^" E2 z Creating Stock Fold caused to twist the stock
3 a+ {, h) C: t' J5 [9 y* u' d' H   w8 j+ j4 h; T, C2 S
6380593% ^" f/ Q% n3 p( F) g& \
Edit Overstock length or its position continuously, NX session crashed 6 U8 ^' \9 M! c% V: k; D* M( l
% s+ ?2 @8 e& \! i( n& X6381180
4 @: t* ^- g* l [1] UGMGR_sav_t25: nx752.0, Test Part Is Not Created In Newstuff Folder # j, X- ^) k% L9 I
5 i( l2 _/ d- A% h2 M/ ?63819569 M) Z5 @& [4 e# }
Highlight Line AO can't be selected after deletion in assembly mode   \- v/ |& O0 M
( Y; U  E: ?' w# Z5 r" h
6382797* n  L# b* Z1 {8 y- x
Identical Step1Pockets are not grouped together - FBM 6 j! Q* U0 q) `; W% f& J
- Z2 U/ ~2 q  d. ]$ _0 I
6383454
! P' k: N% g) Y* m* @5 h Processing of Flat Pattern of view takes too much time
% h2 U/ K) x  ^
, r& T( e; ~4 |* f: q63834929 u  N/ u6 K1 A; s
AO in assembly mode remains unchanged / I  s  J! N+ I4 N
! O" I. V! S& y7 w, C, Z
6383872, i) Z( E2 J0 @  g
Wrong recognition of Slot_U_Shaped Subtype2 - NX 7 to NX 7.5
2 m, }' V' ?) W9 V& h
  s3 n0 ]/ W9 V5 F# I- o6386086
: h/ m3 v* g/ |5 D/ _" p! ~ Exceed Certification:NX hangs while using Analysis>Curve->Graph & Graph options
/ a' t5 |1 T3 e8 k ; C# V5 R8 j* z! v
6386257
4 S$ K* t+ |+ j# X7 m Leader arrow type does not stick when switching back and forth 2 U+ O! S, Y: ~
5 I" P, K/ x+ {
6386417+ {5 f/ X3 N3 ]6 g* k7 m' R4 R& \: q( \4 z
How to get the new Component after NXOpen.Assemblies > CreateNewComponentBuilder0 F- c" N- S3 D3 f# q# ^, s
; R' H' l' I) [+ s* k% o: s
6388253
+ v0 x7 g2 \! @. T2 L Position of jog is changing while placing it in view
+ h1 }+ E2 q7 ]$ h 1 X  r: o6 w  v% l- m. r3 j3 T! V
6388731
3 t- h. X  I6 `- \ SLED: Makefile_win for NXOpen Java example InterOP contains incorrect whitespace
1 P" j2 F5 E: q# \4 O / o% Q" M+ E1 w7 ~0 L
6389027
9 z1 a; Z  f! x7 [9 k) P0 x Problems generating user defined hole making operations
8 O# N. }) g  N7 @" v9 {
. u! i4 j2 o: O4 k) x% g$ ~' B( R6389654
6 Y1 z% ~9 w7 ]+ D: P# } Internal error occurs when undo EDU with cutting sketch ; l7 h+ \; [8 J
9 ~* \0 K0 A- y! i7 W' |" y63896605 b# K' v# f; ?# Y; u6 n
Internal error occurs when undo EDU of composite curve 2 q) ~/ D5 V0 j) M2 C
" @, _- T( b; p; K
6389670$ i% @3 G  o" z0 K6 ?! ]0 L+ R
ASM80202_Om check error in assb w load option as Component group (loaded cache)
2 n, v; |$ R* N9 [+ J) R ' J' t' Q3 z3 H$ \7 v
6390498
( n" E' C2 o) r) [9 a Origin tool doesn't work correctly for PMI PD commands
, y6 n/ b/ i4 U$ d/ C ) B+ u- Y+ P4 m
6390525
& z# o2 P* a/ G& r Assertion\Attempt to write to freed object selecting Connect when Reuse Library, X' m; I- A" w/ r- x1 i2 E/ ~
4 X4 L9 ^  H; H" e3 _% U6390618
) C' K8 s1 B* [3 K; N7 H SLED 7.5.2.1 EXCEPTION DrawingSheetBuilder::CommitFromData Line 455 4 }! j% ?  P1 O7 P. X
" P7 o, n# _) h
6390620" V5 V! Z3 h9 Y  J  X" z6 F% l: |- o
Undefined parameters inconsistencies in xml output
6 S7 y  }" p( N 5 z9 ~8 `7 o! F5 A3 R" L
6391854
& Y6 A# @! G% e: _, {7 Y8 F8 v Development server error is coming while replaying the auto test file 7 k( M; `9 ^7 U2 u! G: o
! o$ e6 T* o3 X2 @
6393094
$ x: x9 b5 h# a! ^, v- b Setting feedrate on point to point operation will not list correctly 1 L) G! b0 T# C, [+ V8 N
- f) H1 Y3 V" T! j6393233
% A$ o9 Z# u2 B6 g+ H; e NX8ip5_EVAL UDF_Deform definition assigns wrong expnvalues as part of definition
8 |2 i5 i6 q. \+ O( ?! f2 ? / q, R  a: I+ B/ x# |
6393251' g) Q3 V" w& Z1 c' O
NX8ip5_EVAL_Assertion error selecting Deform in PN% I6 x, ~( A- k. a7 R' Q
$ n5 k2 g0 O% \% j) I' Y
6393346
( |) q5 F" j4 e* }$ u9 g& y: { Support cannot be edited if its reference edge in Plate is modified : v7 ^6 D3 W. s% w
6 Q" n: @, U  j/ I: D  S, x' U
6393360! d5 j% }, d7 ~+ V
Giving warning while compiling C++ files of Creating Xhatch with excluding label
* A6 |1 @; ]1 q+ ]
0 j) `3 c  O% Q! @) X6393960
# R" A: Q) B* h Ok button turns grey after reselect profile when creating Collar plate
5 k0 H3 M5 m- Z1 d4 ]+ h; [- K* a! ` - v$ c# ]5 H5 y
6394054
# Q- y+ m- \% _: S% V8 y% q Default Value of String Attributes is not getting set correctly in MFN 9 L& `( I' ?8 q# |, k
0 C% d5 T8 b, E& l% v5 d% b8 A
6394682
5 j% a; |6 ^6 t' x% G' _- Q. Z Internal error when creating "rofile Cutout" with assembly environment
, w8 V+ v( S; r2 m# n' j 2 R4 V5 z) s( @+ e2 y% k# u# ]( k
6394799$ B! c; ^. @8 N- M( ~2 s
Harness display changes when option update formboard is used 9 r/ V6 t6 O( M& i8 }( h
  F' ~8 D( j: b5 C; H6395736. k- Q6 ]) E0 H' Q
Edit String expression in spreadsheet does not update NX expression ; x$ N" e5 h2 W0 \
  o2 S  F# p' N; w* C
6396718! C' d6 k0 m; ^4 P3 l( X
Import of AFMs to TC isn't complete
. Q- L/ E- V  K5 C! V* ~
2 ~3 j0 N- m  Z1 Y9 R4 S63985352 D: Z. f& R( }
Error appears when create cutout in a assembly part; O' h9 [7 a5 ?; C* s% S
( k2 \% g4 I2 v
6400591
0 D" r4 r5 I0 s) \& | [1]Sheetmetal Usability_nx80_6.104 Autotest Failure:Nodes differ : original value
9 Q1 |' X' f( h7 t! ^: @# S9 f
7 V# L% Y- t% x, }4 w  j2 f0 [6401104
: ^' K3 `  E  E2 E  E# I Mirrored features incorrectly identified 4 G' X# A4 q6 Q" i
3 X& V! [9 T9 Z
6401554
% d8 L" ]5 N5 e$ c. E& B Not all feature properties attributes added during feature identification
0 [# I' z9 D7 P0 m: ~ $ W" \' s- _8 B! U) @3 Z' o3 S
6401713- Q- ]1 @* H% b
Silhouette lines clipped in lightweight section view for object not selected " ~! |* j) u' V- K$ [: O% s
. v- c1 t0 X- y7 [# v
6402285* t7 M* J* S0 R3 c$ o) Q% g; j* Z
On adding the dim to ordi'te in PMI the inhe't view does not display the dims correctly% s& J( c7 p  f5 v
6 N2 e/ |  b' g6 K) c0 G) K6402915; c& i* [$ O3 g8 B
No Undo mark created for Rename Stock functionality
+ [' u0 [9 ?7 N. Z' u% E& }
( M: }* _# J  \9 }: l6403572/ k% \% w* b1 ]7 `' l. R
The file does not exist during Feature Identification on IDEAS part % I6 j: ~% o) v* k
5 X- ]5 M$ `$ b: c# ~  H1 b* o6403756! q# L/ y1 s8 n* Q  Q
IP_EVAL_Assert on Over Ride and Load Geometry (geometry_positioner !3D NULL_TAG)
" [) P9 w$ i. c% @, ^0 f8 N( T) x 7 _- g0 @; b; j
6404902
* C6 r8 ]: p3 B0 O Face Milling- 50% Stepover leaves island on face
$ P$ C6 w7 y: d. y5 p2 ]; j
* J: R* _# O" G, @, S6405238
! q# E: ?9 }- J' ~ Threaded hole incorrectly mapped as STEP1POCKET_THREAD $ I5 C1 |/ c+ x5 n6 o2 ]* B- D
. K; ^$ i1 a7 w# t$ U! e6407307; I# H: C7 O9 P4 G7 K" u
Internal Error occurs when we edit the linked composite curve
) M- @% P( D5 O/ s$ a/ b8 p+ } 0 s1 Z0 u* m2 }- z3 P& T' D
6409655
6 @! n  a5 F3 H" O8 m Selection using HD3D allows to select top level assembly as Component to Replace
. P$ F: }6 j) f! t9 O! w  ]# M* _ ' Q/ e% f4 A# O7 f8 f
64101921 ?4 F% [5 p5 ]# M# x
NCM using sphere clearance is weird
6 y  ^5 T% r! A, T1 q 9 Y0 t/ i: R2 i$ Y6 U
6410384
' K  T8 A! K  f& \9 U, O: f Inherited PMI Horizontal Dimension Extension line is not displaying correctly 6 ]7 S. d3 n$ K
' o2 V/ x) w) O) Q" l6410878
, T) l6 q/ t7 K3 C) t/ Z Coordinate note is retained while placing it with quadrant pt as tracking point5 l8 z2 r& q' G0 Z3 |! ]/ J
9 l$ H5 U9 f% f5 u/ |
6410896
1 l" M' |7 z% [. G* v Internal memory access violation occurs when extension of spline is edited ) V4 M  e/ B( L# S, H) n# X2 m
7 _8 x( b8 A+ T- A7 f9 E
6410948
0 K; I7 w4 C7 |& k# s Overstock gets removed when folded rectangular stock is edited
0 s; x. g* S0 o8 |1 f' P
. E# q4 B& h3 U. Q+ T64125440 w: P. e, B, d( g  I! B' ^4 U
ModlUITest_SI_ICS_PR6239126.seq:ModlUITest_SI_ICS_PR6239126.cxx: fails in NX8IP8, X0 Y; ^: x2 R4 M8 B, _
7 H% x5 z; S  s7 S, M. V
6413397& r7 G) b" h. [
[1]Modeling_int ugnx80_8 Autotest Failures:Nodes differ : original value true
# F- M: M" f) _* c5 j: H * M  d% b0 R% X' Q0 G
6413828+ S! G" B& n1 j
TCIN:cannot load assembly - invalid or unsuitable OM object . [1 ?3 {4 H  ~% J0 o3 E% A
$ ?, y* \5 f' P# w5 E
64164677 @, n/ H: ]' _( n
Green check mark turns to Red astrisk after SWAP RCP is checked in shape segment. ^* j& U, `# v: K( ?
3 n2 n9 Q' ?* O6416609
9 o* {- p0 g4 Z0 P. E! \4 R8 b In NX ANT, the revision value in "Descriptive Part Name" is incorrect / h5 D. E( j  q
0 q" W, E3 ^; [& J5 ]6417181
6 T) M( n" E" x6 {! a, M Cannot back to Join Face dialog box after cancel Error Message box 2 G# b6 a# g: P( w/ e
% [" w6 {: q. m! q6417810
  g1 D% I  C0 Y" h1 N5 M: Y7 Z1 d9 c# d Internal error when edit Contour Flange in delay mode
4 }- j! y- E0 ]7 j9 d . B; n% o9 ^5 F% H% b% v
6419193
% R. I- ~9 l  } Toolpath -> Edit -> Move uses large amount of memory
. A" H# E$ n+ F; k( Q 8 y$ b! v  a' B8 k8 P0 ~  R
6419664" v# V) B" h9 U. @: i* l$ M/ u
Getting obj count increase when initialize with mill_contour
3 w- e9 t- E5 i5 K- s0 |0 A# i' X' Y 2 R6 P9 A% v& u, E2 n
6419843
$ Y* O, N6 R' S Camgeom.AskItems .NET CAM Wrapper call returns junk Pointers " p; w, y+ T5 _+ V# ?1 V. y
7 R( p( [$ m/ |2 Q) t) ^/ p6420091% J8 g% L+ n9 A/ q
REVO simulation gets wound up with repeated scans# z1 ~3 i- p) `5 D) M
/ i2 m8 k& c4 g2 j$ p! k
6420235
1 i$ E1 F( ^0 I Flag type leader is not displaying properly when drag the leader 8 O3 p) b/ t+ I- B6 b: _6 s0 }) a6 {
0 m8 P1 y- O$ \, M8 e" l; h. ]* ]) L
64208433 Y) K4 \4 G- Q9 p, f& G
Invalid view option displayed while performing REDO on faceted representation
, F) H3 ], R% W+ @9 ?9 ~
# h) K+ w1 P( J* K9 O6420896
, k5 z' ?! k8 \ Alert message seems inexplicable $ a% b$ N* K, a% ^  J8 ~5 Y; x
$ Y$ H: Y1 a3 I% l# H! J% C
6420925
5 d5 ~" j- m+ e. V  Q6 o Cannot place profile with two piece guide
  ]/ T7 `8 \% }; e" D
3 K0 z& q, T: d+ d8 g' m. q& {! s8 h6422438
2 X- Q" [; K% Z0 z6 z$ ^3 G6 e Not able to parse co-datums correctly 4 C: x% W9 t; M+ P; B& Z# T$ L
) J3 ^, S9 ?7 {% n, r
6422579( W! p; H  W0 G! u' s* P% C
The highlighted entities are different in Formboard with Native NX and TC enviro
7 O0 h; ~& F0 d/ a7 L' a1 z
7 Z4 z- \2 A: v5 G6422597
7 ]8 }; N; D& }' [ Shape segment does not work what the customer is not expected in formboard
' X6 C% L) G8 s8 } . x; n" i6 b" `# o! N% D
6422703% t7 M+ y. i2 }8 R1 H
Stock Offset path is moved which has a constraint3 F9 k2 [! N9 t0 l
% {$ s  }: p4 x; c& O5 E- x
64227313 v& Q, U9 i% ^. J
Error occurs when trying to move a connector by "Move Part" function 0 K9 D  l6 h0 U0 r8 l( B7 t
: q. [1 m# d7 Z
6422762$ q) S& R- O: u9 J4 r
Transform Path & Remove Part does not work with Pre-selection (MB3)
% M) k) I% ?! T" x( B. Z) V) N
( `3 g$ L/ y- c/ D- S1 L6424052
9 Y" F2 t, t' X' w+ W% j" G Error occurred when dragging pivot points of Radial Bend
7 Z. h8 z8 ]& l" X. q3 d( A
, x8 A6 N( \( u6424060
( |0 y  D0 K5 |3 p& B) k' Y Adding filler stock to the spline path removes the hallow $ k. F# A1 [3 _8 j
4 p6 N8 M+ \- _7 Z4 b* M
6424071
( F; S$ U( F0 r5 V: D+ c' ]9 j Internal error while adding Stock Transition : O, ~) d" ?1 I
& H8 Z( W0 U8 T  u
64241636 g4 J& j2 x- K! h& v. k6 ^
Unable to create Fold Stock after deleting assembly constraints 0 o6 @! A' N2 }7 F( `* r
# T6 N7 }: }( M7 G5 x. V. f( y6 q
6424178( h7 \: [3 o+ v) k7 w1 x2 w# e
Internal Error during edit spline path with Rectangle space reservation 1 M4 _# j9 Q3 I
. q# a0 @0 a. I# Q- e
6424185% a6 A; [7 [& [! S
Unable to create path with "Canon not find NX object from Parasolid tag"
6 a: D* O& q, E, k2 K
/ r% l4 G5 O$ G. p6424221
) I/ K3 S8 b/ @; x1 l Internal error on Generate of FBM WEDM nocore operation with finish pass
% o! E, H8 h! `% T* H 4 g! ?# i1 f% T
6424936
  u( u0 h, r7 x6 U* j Drawing and section view will not update
! q" F! b$ I$ z0 i # C" v! ^2 [/ e" W
6425034
+ U9 J3 E* R1 ^: [4 ^ Face finder cannot find correct faces 7 t& |! n' t5 ^6 V; U. l
& B; A& @: Q8 F
6425304  ]& t: w6 ?, A' S; J
Chesen ";Specify From Point" is not correct
1 i( e3 F5 c7 i: F8 U& K 3 Q, L; c; s) e# H
6425349* Y( g- _9 u- j; z$ w$ o- h
Table content with PM text does not updated correctly 0 E/ `$ H+ J/ C, O* C- _
2 m9 j& p6 w7 Z) i6428302, A9 G  k7 p& }0 \9 A
When Stock fold is convert to SAC shows undesired behavior & om check world fails
8 f" y( \$ \% O( v5 V
$ u: h( h4 O2 F# T+ j+ _" l6428423' ?1 l0 O4 d! S; P4 K" Y
LOV does not show in the NX Manager Portal from the Pulldown
" g( r6 j" g8 T6 X+ F( n   Q# a; a( p2 [4 b) U6 s
6428760& Z! U3 A4 W) \' s) N
Simulation error with given part for sim5_sinumerik_in machine ( [; b. F: d7 e# W
2 K6 S* e: q$ |8 ^
6428977; v+ [( p. V0 l1 E
Missing Visual cues when re-stacking PMI objects
* R: N7 T+ x' P! y6 T# f
1 T! L2 H0 E1 ]" [: ]3 p; R# X4 {6 R6430464
* t: B4 t8 N! X1 J  ~; S& ] TC9:SM: Rac hangs when tried to export configured UGNX assembly from SM
4 p. C. }, C% H% H6 u2 P7 ~7 T ) t  H* g% t0 S2 |
6431732
8 k$ b  l  P0 O& |1 i NX gives InternalError on selecting TC CustomSymbol folder having PNG image init
% Y6 M) F  k" ~; W8 _5 c$ {
; X% O/ F8 |( M% T64339580 l9 g3 R0 b% U+ ]3 U5 |
Assembly fails open with partial load OFF _ OK with partial load ON
2 H. h% w8 h/ }, H: g2 L8 g
# o1 y* u$ A) v. i& X6434109
% h* E# A$ a9 o2 b6 ^- o9 q2 A& } Cavity Mill operation incorrect after re-generated in NX 7.5.2.5 2 Z( u: l8 p; V, W0 D2 f9 G
3 D* ^  o" [( @
6435294( u5 g  v+ }9 A7 v, K
JA Autotest: validate toolpath quality get different gouge checking results
, G  C) v6 e2 u& f! {* R& N% u 0 t, P5 q% h/ T: h% h2 a/ `" k
64357247 N% I, N; I  ]8 D+ J
Error while adding finish symbol. error Unknown curve type
( l1 E* a8 v# t, [ 9 s, T4 p) ]. x0 }
6436891
: j& q% C: ]1 {! O; ?: k NC: Save cause internal error with item created by "copy component as"
- O: C. b8 t2 W7 G / y) i7 M$ S# y* w3 x) _9 A
64370906 M& V5 S+ H' b0 H
No Arrowhead on Plain type Leader
8 ~0 A1 d; L, T
9 `6 `* Z! k& W7 S9 Z) k! u6437441
9 s3 _9 [  N4 j# d/ T/ V An error message pops up when editing Linked Mirror Body ; H5 D% |" P& H, L6 k! c, |
8 o; y% M* @- v$ a
64375502 A* q1 t! J4 U0 y3 I2 ~# P" {. P
CAM_FEATURE_ NAME autotest instable
/ D$ s* }, }0 ], i/ n9 r7 C5 X' d
; c) O- M$ Z" _4 C- y1 f, [5 k6437555; e! X  h4 n4 W
Missing marking lines on the flat pattern (straightbrake flange)
( J& v6 ^. I# _& W$ T3 u$ p0 W' Q
% ~5 u1 z7 ~+ r- n2 E( P& x; U4 J64393214 M5 F1 K, @# M, t1 t
Face blend with link body has edit issue
) ], V8 R9 G; M# Z 6 h  j7 w% O" L+ x9 W
64416500 P) q- E! c' Y( P2 I
Custom Symbols in Tc 8.3 have performance problem versus native NX 7.5.2
6 a/ w; o6 c- q+ ]6 [+ m7 s
+ {9 v9 z5 X' v! R6444017
2 S, I2 w5 l0 B) {* H" T2 o7 F- S NC:MILL_TURN - IPW corrupt after milling operation1 j) t( r9 {* l: O1 T0 A
+ Y9 \8 c8 L$ S/ r% o
6445821
7 v( c& F# V* ]$ z! h* k& x' f Internal error while replacing component having component array
' c6 ~3 t8 a% P3 c" l* w8 F 8 K8 j3 E/ X6 N/ U
6446058! g. H9 u+ W* G0 b1 ]
EXP_KF error handling incorrect
0 ~3 m! m/ f  @2 A8 `2 O( `
# `$ q. Q7 a) u" E6446509" f& e3 S! v: J4 B5 b; z$ f
Make Unique breaks interpart expression when assembly contains system delayed 2 [+ t3 |5 u; e
  ~1 Q  a0 m$ H  D
6446798
5 u9 ~% d4 K$ |' b$ S" B Trochoidal Tool Path Causes tool to gouge part 1 F7 h3 i1 o& f  d; O! g
2 U9 ]# G% J: v) |, u' o) T6447335% T4 L8 r; N9 V# p2 C0 K
WAVE update fails on load of component from Cruise Ship assembly * C% `# T8 s) i+ n
% l4 m6 _' S9 k9 G. p
6449353$ ^2 Y  k0 |2 f( `# {7 [
Check world error when undo the deformable feature operation
9 E( ]0 m( X2 Z! B+ u: o! ]
6 D% @" }. \5 N! a$ E+ F# R$ z9 J6449720& N( x9 Y. b) i! O
Large memory leaks creating drawing booklets" q5 c( {  o! M; X6 |4 ^, K, T
* o1 [- t: O9 h: u
6450092! s- E3 r9 ^5 v% O* t
Assertion after when delete all objects ) z) e3 B0 A; M: T" y) l
( r! A2 u3 M3 K- K% H6450194
3 A7 o! f) p0 J The component with spline path does not move . ^" b$ X6 I, l. C
, Q' R- a1 n2 U. d" u+ W64525282 q* U2 r6 o& [- F  [! [+ W
Pre-int : different orientation of SR for spline and linear path 8 U( C! i( e2 F- D
, K  |- a5 s" ]" z& H9 c/ d6454473
& B) Z/ J8 m3 I: w9 r- M' f Internal Error "copy parms are not sorted" attempting load of ship steel parts
! _2 V) A" `% C2 |, Y  h
  I! z0 O6 a1 \% x6454854
. O- ?8 W; ~- B5 Q  o# R Faces don't display in NX 7.5, looks ok in NX 5 , |3 u9 m3 y' T% f7 R' Z
" E5 Z' `: v/ R% m6 Q9 w7 D" ~
6456165
& m+ Y2 ]! E/ B) y SLED__8013 - error removing components from cutter assembly 0 L0 O; q# N- h4 K
/ r7 J/ ~2 F) Z2 T3 I  k  m6456598
* Y  A8 l2 i3 M$ _: N Pasting an operation after one generated with Parallel Generate causes an error
7 I' K" E* K/ a; D
% p; F; A( F  {) j64582856 ]) ^& |$ u3 @8 P3 Q0 j/ d: `
Contour Profile operation hangs during generation1 @+ K8 s9 y) Y- ^% S
9 a' v7 w9 ~- E5 D64585276 K6 B# u/ O: j
Assert copying simulation views ( I, g& N+ Q' ]5 s! a
% ^. C4 _) j. I) O4 h
6459178  A9 r% x) G4 V$ B0 m6 x
Assertion failed when edit wave link with fix at current timestamp
0 r/ E* r0 @  {' m7 N. E; a5 X % |4 C$ I6 j0 l
6459225  s7 e+ C+ r1 [' z1 B& i0 I
ARCH8307isk error on paste special redo & t  L) y# U9 \! Q& C0 M
7 j, T4 H! j% ^
6459479- Z4 M7 p3 r% p2 ~# H
Slow doing a show_hide in NX 7.5.2 to NX 5( W4 c/ t, D# u8 \7 @. }
5 m) ^7 }& c$ G6460351
/ r: x, j: C7 P0 S Assertion after copy_paste and edit linked body1 {% Z, X! K% A1 H: @  J
0 I: a3 z# P, P6460596) g7 a0 L3 P+ R+ \) L- ~4 W- @
Assertion failed after edit Linked Faced(0) 6 T1 E9 h/ N6 z0 s
1 g, ]" P4 s: K8 b8 m6460838" `! Y9 X' b, x6 U/ p: f
ug_cam_askOrderedMcsNamesAndToolAxes returns incorrect names ) v' Y3 X6 a0 O
$ g9 x! ~7 r- c" ~1 G
64610719 d$ s+ c1 I) ]0 G" L& H3 w$ A
When creating _ editing a duct split, the display does a complete refresh
- G6 T/ M3 C7 |0 s& L 0 S7 E( c3 E% u9 G, y/ J. S* q
6461381
6 `7 Y: P9 x% t6 m8 k, v NX 7.5 L10N CERT: Strings in English - Tool Path Editor
$ f* ^; g5 v  m/ d3 ?0 z$ W
9 X& B3 M8 d' ^. m6461555
* y" {& ]) @2 |+ _* z Machining Feature Navigator disappears during reopen of modified part ) _' i% @5 z3 p; [
$ D3 S0 Y! q! j8 `3 C
6462185
4 A. x( m, t# j) v Show Hide does not work when dialog is active for packed node after state change8 ?6 E4 q7 [/ V7 r
6 A9 \" I  Y% i' t+ x
6463544
. y3 h6 B( @) F5 H If surface is divided the Shell Expansion Lines are wrong 8 P7 n( e$ \- W, ~
- S+ \6 ]4 Z, T6 D! v  `: v
64643585 O. m5 b  J8 v( @7 w
Assertion error while selecting segment from sub assembly for create fabrication
! w7 M3 e6 G! R) m
  L9 p8 W. }' A, w6464427
. k/ D' Y- p- M) p6 J; Q  M Missing attributes on straightbrake flange markinglines after platepreparation
- K. A2 E' Z1 i, Y: f . p$ `1 W$ I% Z0 `; D
6464831
' s( O. m- I' ]* @/ j& [- z Excess Material is not correctly ported to XML output
+ H- R% R4 r$ y  B/ r2 j 1 u# U* d) V5 f$ k
6464838
3 e9 ]" a! M2 I* S! l, y Excess material just creates the value
( q; x& ~% p9 q) T
$ a. ?) e2 K, D6465209- f1 h  V/ p- ?
Surface finish symbol with flag type leader doesn't move with parent view . T7 Z0 }5 x$ K* R0 V* J2 x: l
* G3 R# o7 y) _4 y9 N# g6465278
( f# v5 I) w, ]% s! O Internal error occurs while editing points By poles Spline method in Fold path+ w1 `/ Q4 h+ w6 N, H. X( D
' s2 v, R9 P6 T; T/ _6465303
. G: u9 w( S, C( s+ }4 Z  g6 W7 D Error Encountered :NX Routing problem occurs during Parallel Offset Path 1 g$ |3 s- \/ c! n& R" O# S
5 J) k, {, ]$ a! ?0 x6465349
$ \$ G. [" N' z) x/ }4 J Create section line session preferences are reset to default for new parts ( X; a+ l" D5 R2 I
( z* z, ~0 A; F/ H6465970
! O7 N+ T9 z  ?4 s1 L Ship annotation function needs to work -- combination of issues not able to work8 J* L% G+ O: \3 x9 z
! \' U3 D; d% n+ w& h
6465978
8 J. r- Z$ N6 I. S& L Straight brake profile with inner bend radius (not a knuckle NX ship supports)
" [$ e, r3 z" G; `& C4 s9 B
& E' V: m  k3 V2 O$ G6466226" U2 L& o" K7 }  [5 _% V5 C
Sig 11 adding metric flexible harness to inch assembly% t2 T8 n) p) F6 f4 [' k5 `- @  N
) H3 t( M0 W0 |. a9 Q# u( G, [
6466785+ {, t, l- D. ]3 r
PMI not displaying in correct position in Drafting Views, OK in Modeling " C/ U' @1 }7 a- t. i9 k; _
5 C7 W# B9 \: A7 ^4 i; E6467462
% X& T2 z7 u2 S. b9 C2 r, g5 L% [ Ordinate dimensions doesn't retain when you delete parent feature
! J! P! G$ \1 A+ Z. a 6 y( H6 v: s* ~* w* R' o3 p
6468763. |5 }" H0 O: L) L: w: Q( i
JT file can't be created 6 ~& N% g! i+ W2 m  K4 V+ I9 O
0 n; l+ Q8 ~* b/ l; R6468890
+ P5 V3 V+ a. r" U$ F& f5 d- q2 s Usability ugnx80_14.200 Autotest failure: parser unable to parse master XMLfile
* M/ w, J1 K" h0 @" J* y5 H. D 3 s% \3 ^6 H2 N( Z% {% z( N' m
6468931
! [  H; P7 W1 W6 @! @2 y( f OK_Apply remain sensitive even after Deselect all in shape segment -formboard . [% A! S! U0 I$ \3 z
, a- F( G6 z1 C" {5 l  k6468940% I5 x, s1 R" l: x
OK button is not active in point dialog and OM Check failure.
+ j* i, H# f3 e: S 0 ~& B+ ~& G+ Z6 l- b# G, M( C# U& u/ p
6469639
# ^7 G! d0 H) `  S Segment not highlighted_selected when view style is associative in shape segment
2 |2 {* u0 o* W0 H2 i% W ; F/ ^" d6 p7 J
6469859$ m6 `. e% x9 p# p+ U- i3 }
Problem clearing CAE Node and Element selection highlighting " ?% P' p4 |3 l1 D+ h0 A' u1 [9 `) W. y
' x2 F. r9 ~0 v" v# F3 `
64698876 g$ d  A2 _0 |5 P
Heal Path training prior extension lengths # d9 A1 r' V; j5 B1 K
# I2 h2 X5 {( S$ o& o& M6470118  L5 z* j  H7 o9 W+ v# m4 J
Trying to map from Thermal_Flow to Structural, getting license error
' o9 w  S( p$ r* z9 O " a* }+ q7 @8 k, p& j7 f# F
6470418
& J/ n/ f" _9 _* Y# X5 [ A deleted or invalid class id was used editing retained Callout ID
3 J" p% ~6 V4 Q1 e! ?; I6 j $ K" ~2 p2 R6 X+ t! f  l2 n
6471845
' S; R: P( ?! k [1] "uft_import_isuzu" EXCEPTION:580039 Class id 0 is invalid   E9 V1 n6 x  a1 q- a# V
  N! A; ^5 H+ g+ R& D3 a4 O6472387
) ~3 v9 |! p- v Internal error occurs when delete feature 7 o! C: B' A% }- {. V
7 m! j2 B2 n& ~2 J& `64724063 `$ u- N+ m+ S4 N
Annotation origin of angular dimension is changing after undo_redo
/ q9 A) u- Z/ E1 J3 g 6 s4 M0 w- }+ t7 r( N
6472474
( H+ Q* u: Z. ]1 u* a Internal error when distribute a profile use closed curve as guide line
0 q7 _7 f& U7 @% \3 J/ o; B
1 |3 X3 o) W2 p6474663% N. s$ r! y4 T- L$ u
Rough turn; operation fails to find cut region in NX 6.0.5.3 * @$ k. @( z; k3 e/ C, [2 Q/ E+ m
, ~: |8 t) t+ L  E7 t& Y4 g) o; w+ R
6476191
1 q) v- c% U' U+ d+ D Undo doesn't work correctly for Section line preferences . v9 g  L  g* p' S: ^
+ `0 m5 J' m' Q4 p& F; s9 F6476815
5 i) l) t7 x) [ ugtopv crashes with memory access violation
' X- N' [+ U% `0 D* Q  q) L
  O9 k# u& n4 `6 B" I( [4 e6476873* [6 f. p1 z3 K/ a: [  C
NX gives exception error for function pin listing8 g+ R2 M; ~; Z! Q) `( R
/ E/ O0 F4 x2 J8 N
64776995 h- M! z4 Z2 ~) O9 l6 u# C
Non-circular overstock doesn't give correct overstock data
8 f0 j5 h& Y, j7 ^- g. X
2 n& _# L' w% }% o4 c' H6477802; I3 l# l5 ]# x7 H$ p2 ^2 f
Spline Path - Moving second spline point caused 1st end point to move 1 A% Y2 Y  s- ]" L
8 ^2 `- R  W- M2 |64779585 i, p$ X+ ?5 u
With Section View cannot be set as default preference
/ Y/ ]" k4 \: i5 H0 {. C  Z, k& u ; D  [* u$ u) Z( [) x9 c# o
64780431 S6 H5 V8 X+ [# x4 H- }* H% L9 p
Clone operation with replace name does not update wave links
1 {3 L# Q5 r# a! w( W: q% S+ m
9 R6 Y7 M! \" v! x) a" H6478402
: r# ?% u+ O7 P Linked faces created by clearance plane definition shown in simulation ' \- m% r$ r  O) U
- H% `- u' E+ }5 ?( w3 \; h, E
6479161
( ?; L9 [  x' x& B5 @ UG REF SET3DEmpty in PSE gives "Reference set not changed" error on opening assy , E9 S! f5 S5 w( F; g
; g& e3 t* ~& D1 R1 r/ o
6479657
( ?3 B! x9 w/ s( e/ x2 }! c Extra server calls because of extra Item types
0 ~& w$ X! ~( S7 Y3 y: O( D & g! W: B! N8 d( k
6479970$ n) e  T/ M7 p  h* d4 a
[4] Drafting NX 80.15 delta1: Autotest Failure: Drafting auto-tests are failing w
: O  ?- @0 t, Y$ b3 n& I, f& v
3 K6 A4 H2 n. ?' q" W6480452
& B; N7 ]$ z, h Port attributes not showing on part between patch version' F' J1 a: o* C& A' y" L2 u- t9 F2 a
4 m! @+ p7 c6 S/ J3 d
6480568
' P+ X5 T, q. Q8 @$ t2 |) X" T Errors occur while in reference sets randomly
: G% F! q9 u8 Y( v$ r; `5 o9 X
9 ]+ F/ X( y( ^6480734) i" Q4 @8 E0 H) Q% D  f* I
Editing Formboard spline with shape segment displays it in two places on window( f5 E$ O& ?; `3 [+ i# g3 ?- ~
2 m+ ^6 }% s- v2 o* c4 b6481270$ M# A. h$ w# [. n
Canon UAD: Assertion error when starting Check-Mate Update All Drawings
4 k* X2 c& `3 |& Z5 g) P7 Q
" E# N6 f" M) d& P# s6482070! ^7 f5 E: U% m9 k
REGRESSION: View regenerate needed when changing view to AEE
! r; ^0 U% H+ J2 C9 S! f% f" m
& u. w4 s+ H; t/ A* p6482400
5 S9 j5 S" Y& s7 b3 Z The compone t with spline path does not move without fully loading # R/ d# w- G5 I, g  o1 s' h5 w/ P
: P( J, t, M# w& w  q- h
6482451
6 P/ n1 P  q4 w, [5 a/ Z: p 'Assertion failed' occurs when Swap Pivot RCP is toggled off in Shape Segment
0 x% ?; _. L; |; v. }: e " L6 E- A- R. x8 T2 k
6483297( ]0 w6 H3 l) B; j9 j7 e$ g; w
[3]ugmgr_JRC_t autotest are failing due to an exception.in update_internal.c
3 B; n$ R2 K- P. s* R1 K1 N- \ & K# ^7 q; S5 ]! f8 P0 [
6483961
- _0 z  f* l$ g/ I7 G' N9 H Parasolid returns new created edge as its origination
! [% I+ P- Y/ m. u4 F
5 C$ ]+ Y; _. T- {6484236' ~+ e9 ^, H2 C" G% t
Entering CAM with a machine tool model takes far to long
8 m7 z5 `* x0 ]% P0 A ) ?6 q4 @9 s% `: ^. o- P; j
6485002" w' @- t+ O6 M- l# w, a6 T, Q
Regression: Function 'Replace Stock' not working as expected % N' V5 ^& E% m& S6 E  ~8 m
8 H' V! A. S2 X9 A3 s' P, G+ j
64854549 S- R' x: O5 c. _+ x
Analysis curve resizes on edit when created with Suggest Scale Factor
; t' B2 Z# b/ C1 [ , P- ~' ~4 b, M$ X* x
64860279 ^& L) ^4 t+ ]9 o! R3 G
ugtopv fails with error "Can only add components to a component set" $ y4 P1 Q5 H7 @# m6 F! n  @
2 t- M5 ^* ~. [# i% y) l+ I6486032
: z- z2 [9 ^$ D$ S; i; M* ? Autotest ugmgr_MCD_t19 is failing due to an assertion
% L9 h  A  P- Z4 m
% G0 M) z+ G- D) j7 e6486745
! K' L9 V( n0 u& Z- t, A- l Win7: HD3D Info View contents are right-aligned on NX 7.5
4 S7 _- e. `  e3 y $ b7 F3 L4 `% y7 Y
6486986
9 i5 U$ x; \9 M# B2 ^ Study Clearance Violations - multiple Gwif display issues . g: x$ M4 y+ x$ w% u0 Y
! e8 S3 H9 P' E6 o6 a7 S3 U0 g6488453
8 @( U4 D1 R) v8 y Minimum radius check produces way too many temporary displays, hampering display
' t$ W3 g: V6 s) c; j 9 y# A6 K$ }8 i: }& ?" b
6488492
7 Q, i6 @' z3 p/ o/ H+ [$ } NX does not support Labels, Dimensions or Notes % _: s) S4 G% _* m" U
, j* B* P3 x- Y
6488655' @) u9 Y, V  T4 @- \& H
Autotest "uft_modl_m_reorder_feature": Exception 1400007:Failure in TAPER_apply
) q- V* _6 ?! W; K) |
8 ?  S" q' x, v6489756
0 V! d% _" E/ L+ y. y Reopening drawing with section line preference set changes the preference
& r9 O/ [* X% c/ v3 b
% S5 o# i9 l5 ?# s  H6490294
' J  A$ j  p' g0 B8 q NX gives check world error for function route connections
" p# y9 R; r+ F" y/ _
: y* z, a; E8 X. I4 D6490319% z' i) `, d8 }4 V$ i1 N) L( Q
Transform path gives assertion error while selecting sub assembly in NX 7.5.3 / z5 k* [' h6 H0 J
0 L0 y4 B  t4 k" l* O; |6 ?0 p# \2 \
6491972
5 w" F+ Z8 z  P4 I$ C. |; _ SIAO does not update in real time
  Y0 ]% O$ D6 R  B% `, Y
1 n" m6 a7 m( K( ]* g+ @6492135
1 H( p: y: ?) W Not all MoldWizardFeatures show up in the source after Update upon Load
! H+ l2 ^  K9 o6 L" r6 C! N& M
, T- V7 |* r* X4 b+ `" R- I6492317
: F' |" B. K* Z0 D% B- X Redo fails on Relinker but works again after another feature is edited 3 f# n" ~  g! o% e
) [) D5 V- h6 D: H* _3 w6492392
5 h( N: r: k1 O' r0 v Create pocket creates subtract features in wrong file
1 y8 t/ [5 B* U9 E
# j) O/ Z5 s# k% }; M: Z6492904
. T) S& Z& A$ |. o3 J3 Z5 w) [ Assertion failed when Edit with Rollback of Linked Region
& @+ c3 Z/ A# D) k
  M3 X- H/ a- }1 s  H6493088  Y. N5 D- E3 s8 y
NX752MP3_&qu= ot;Error: 940254" while loading an assembly with altreps
% [  P/ W1 j/ h5 i" Z/ A0 }: `, D
& B6 r7 ~4 O, l$ V6493136
5 c1 ]# V2 F& s1 P& z( D Assertion Error occur when we change the current timestamp feature 1 e' e# d' k6 k8 A
& }/ z: r- j' e! r% k. A* X7 Z! \6493757
" @+ J! c* d+ a2 Q5 z  Q; R' K Rotate is lost after bringing up feature browser pop-up twice 1 d' W- M- B0 V) Y* C
/ i# u7 s, W: t1 m' {& [% Z1 g6494353" z2 V. o4 ~5 ]& L& L/ F/ X" q9 q
The broken linked faces fail to relink : a% {+ R. L& d2 Q6 `* U6 e) g: E
  E9 G9 g+ L* l) _8 g6 I  C4 ^6495485
2 H) i% O5 q8 C$ h! N  } The Teamcenter MRL library installs machines away from Native naming convention
5 V0 A1 b5 Q4 z, |8 w0 E
$ z5 R( v5 R9 V7 D/ o6495515+ t# r- a7 S7 ?: w3 _
NC: SMP_ENABLED - Internal Error editing Hidden Lines in View Style * g* T! Y9 T, M; m' V5 V
$ {2 V9 R5 U2 |. Q: z: l0 I( Z, \
6495565
3 w& h) H! t/ E2 a  R1 t Face mill gouge check fail due to TRV called mutiple times (buffer wrong) ! N& @! u& u9 P* b" v! Z) ^3 ^
; C5 P  m4 X$ J; A" V/ q64956577 `/ D5 O. y4 i* e
Number of lights is set to 0 7 d( N+ I% I: H/ K% n
9 |6 W, Q# ^- O9 c6495767
' G# I. y( d* H% h Getting different result while export to 2d
7 h" j; Y& ^# [+ m6 D$ e+ R % V3 [- ~. [7 |2 x; t- c$ Q
6496020
" E4 `$ r- u5 O& i  t7 }" B Performance issues with flat pattern
' g2 {5 `+ S. B
' e. \0 ?9 A" b4 H  o6496644
: Q  S4 K. _; G* X6 v& ]4 C2 X 2Dexchange(dxf) : 2D CenterLine is exported as Solid; d3 C! H2 A: W$ R4 u4 n
/ j2 g9 I! Z5 X
6497966
& p; X  o1 j$ O& H OM World Check failed when edit Divide Face and change input face 8 ]/ x! j, g* d5 e. J
+ D' l+ b" c! }" o, g9 ?6497971- Q& B" J3 p5 m0 D; V, h% L
Feature Dimension is not displayed correctly in Drawing view
. z1 l0 a) @! R , s* ~1 O/ m4 m) E8 G# s6 J
6498396
4 X/ C. I% U6 a3 g# h9 z0 { Second Level Component Groups will be renamed by reopen the assembly 5 E. s2 r3 n* ?8 l( d! W3 [
/ n& ?; _' r; C; Z
6498805
* P4 x& o9 q: o& D6 V+ D Redo fails when manually select a datum plane during relink
6 G5 A* E0 y- I/ u, X4 J/ c" _
% H# o; h3 Y2 z) _. x. O6498847, K/ H9 H5 {$ j9 R! Q
THRESH value in case control entered as integer instead of real
; a5 R  B, a. f5 G/ D8 [4 Y
& U' F5 W: i2 W+ A& u6499125
# u( \' f* \$ T! B Autotest ugmgr_LOD_t5_33 is failing in xml comparison 8 a/ w" ~4 r5 z4 M+ S) I! N
6 F2 ~. ?& A: [9 \  ]3 S0 R3 d
6499647% T6 i4 g) ?: N- m/ l, i
Changing leader type from Flag to Plain causes the arrowhead to change to none , e" j! C0 k9 Q4 ]
' O3 m# a. s3 k) P4 {  C: r3 B
6500253
+ S. [0 H$ e7 V0 O& W. N Dialog memory issue on move object GWIF
- m& [) R1 x2 T) R3 }! L6 i- i 1 k) y% S( y5 p. m$ T# I
6500908: v% P7 J) a) g1 y1 I
NX 7.5 L10N CERT: string shown as garbage - Boss3 ~& I5 C. H. {4 l9 U) J! `# e! ^: R
; j$ {: W8 L  k% V7 K: h
6501031
# ~( M! K% j7 n7 @. q5 v Internal error while editing a failed Offset in face feature
' |; A3 @& N+ y: Z. V1 k- K# t * d; q- R' O/ W5 H) M/ L
6502591
; m" p& F' j* X! X# T% {3 n9 |$ l AutoWrap.pl fails on Win7 machine.  [+ f3 @1 T$ U
) \2 O7 \$ l) U* L7 [8 J1 `
6502680
3 X% p6 O) C- ]& i  X NX 7.5 L10N CERT: strings hardcoded - user defined PMI
( I% C, H4 J# l0 a2 y9 U * b" s$ I3 Z# C1 r
6503521! ~$ z6 R: I& J0 J8 O/ [/ y
Internal Error when create ventilation Hole in assembly
/ y, H- M+ L% `* M; I+ @4 G
* m1 j9 d0 D  A7 D" d& W6 O6503979
' Y& U- @5 t+ r* G' j Cannot solve constraint with assembly cut4 x) Z; \. a9 g+ |9 }; @, A4 g
# {9 i& g# I# e+ Z7 f" g7 P- O65051480 Q4 u  O1 z+ }3 n: u; G
NX 7.5 L10N CERT: String hardcoded - Parts List Section 9 q8 a, {2 O- q1 L5 D
( b. j2 p5 L3 G3 O' v' \7 F3 z& ]
6505288
5 z9 }( n! v: h/ E Line, leader of PMI is broken in translating to JT
9 t8 u& ]* G0 y. t4 D7 l1 p. n3 b5 X
6 a1 O5 O; K0 D( X) C2 B& e. A65057633 `2 n# a2 H5 P! X
Helical Enge crosses centerline 180 degrees out of location ! C- N/ P+ q  L8 {0 _5 W8 w$ w
5 c8 @, v. m7 ~$ n; T7 R
6505767
- A" P- E4 d2 m& d1 V. r0 e Create Formboard : Incorrect Object for this operation
/ f/ ~% r* B- e5 {   z- L* Y& |: O2 Z3 E' O- o# `% C3 \
6506000
- s# d- u4 i5 |5 W Regression from NX 3 - Wrong Toolpath
; X! r: D* j+ H$ H) v/ N
+ x8 o$ u9 J) X& o8 f65061681 x- @& Q% y: V5 H% D# C
Unable to e it the legacy surface finish symbol after Ungroup ! B! c( v. b: O! d" ]
$ C& P9 e: ~9 N  @+ ~6506187
! t7 W0 ?2 }  S3 X. i( D6 Z Regression-PMI-Coordinate Note retained after placing using intersection point % [2 R! f3 y! F2 F
# T! s6 O" C: G0 _" Q
6506507/ b: Z" d) X( f# W9 }; }
Any edit to streamline parameters causes internal edit
6 g( U# N7 o  p1 T* _9 T " Q+ F  H5 S9 F6 a  C; w% y" J
6506945  E, K  x9 [& C8 u
Assertion failed when edit Synchroonize Links
1 K) N* E- h: F9 x5 K' l' e6 Z
1 [+ ?! M8 S& @/ S6506974
9 r" i  B+ m5 ^% m* { After "Orient Branch" and "Undo", constraints are suppressed
8 J0 p3 o9 i7 [' h6 M4 M+ W& M$ O
0 {1 Y: o4 k9 u- A0 Q9 i6507104& i8 l8 ~, T2 j
Wrong error message while replacing top part selected thru HD3D navigator
' n# ?, I6 A! B) ~' T( y) h ' b. Q0 D$ U2 U1 P
6507225+ C, n4 _4 X. O! [" s! [8 }% V
Promotions cannot be loaded_displayed lightweight. REGRESSION # S, ]' Y4 n0 ^% S; Z
7 g! j" H$ \4 `* k6507430
4 s8 b- v' v5 [: b Define Deformable Part not extract all necessary references from Move Object # X5 {- {  F3 N
9 A7 D" }5 N5 u
6507615
$ r/ J) h2 g9 v: ^ Poor performance upon rehighlight of global select list after git popup cancel " n- V; S. Q: c, L0 t" l: Q2 K# z
9 K, x! T2 y! e9 N  ~& h6507720
. X6 e0 C  Y) }7 v' L5 S" B- ~: n Unused items are gone in History Free Mode if the folder isn't closed in history. _0 T. Z' R7 v5 K5 r# O& q
# H' c2 k1 b6 O' Y* Z
6507725$ M. b6 E; Q. J/ L% L1 @4 i
FlatPatternBuilder > GetCommittedObjects does not return the curves
3 C: j1 P% P: Q! a& a7 \1 p
7 I" ~1 r+ j' p; K6507747
* O  |7 b8 q( V( l$ c Edit lineup color ,the addendum surface feature update fail + V8 K8 m/ a1 H# B4 q. G
# |% G0 m% I5 @+ x% {
6507838% I! |& E/ C; u+ g& S  @4 k8 w
Check Word Error after create Die Output Curves
9 `! c7 ^, @, G& B2 [! y
$ B" }8 z3 q9 S( e8 p/ S! ?% J8 f6508220
5 b" r  E  f9 D+ _9 T Snap distance not remembered
3 u, _: l7 O0 E% n3 z) R7 q# }
- l; q" n& Z) r0 x3 X0 h+ q9 o( J- T6508515. i8 }: u9 n& ?
Catia step file doesn't translate properly
6 M% i7 h# V1 ^. U - K: o% b% R+ M; T! n" v8 i& A
65089406 m# t, [, r: T3 P- ?- N5 h- x
FlatPatternVewName does not work on builder for new feature
' m( f  N' l- M 4 J& I+ V7 a1 k4 j+ G" h$ B
6509058: {+ l6 {7 `* G5 b1 B) \2 T' w
Flowcut starting point moves and causes NCM retract to fail
& L1 N, u3 B/ K$ [  t& Q& ~2 Q 9 U0 }1 V; h; z5 i
6509276
) m5 }, U& j7 O' m' g' ? X form falloff inconsistency 1 J  a! @& z  H+ j. g8 v/ ^
) `' z6 n, j2 E. b: \" w3 v% ?0 x6 U% _8 x
6509351" A7 G+ ?3 `# |% r' E  W
Journal Replay cannot work correctly for Datum Pin edit ; @5 m  i: Z. J- r( X* a
5 `, o& ]( z' w8 Q4 T4 j6509458) p) v3 v  N7 i: X& C
Export Assembly cannot be blocked if user does not load the data when exporting
6 |1 y' U1 p5 w6 }: T! b' T
/ {  l, z% E: |5 k# D6509625% }: G- d2 x9 ^& R
Update structure has major performance degradation in NX 6.0.5
) a/ m) c( b& P7 T& i+ I: P1 b
8 L* d; @5 n% H" Z" t) d: i6510147; u: P& Q1 _. v  e! `7 j% l
Datum Locator: Missing JA coverage for Mirror_Translate and From Existing Point
4 ^" g( H! h$ D6 {# F2 t+ I3 l & Q& b0 g; Y$ i0 U+ f. F- M
6510277" J, c" o& _7 J$ o1 U  Y* O
Error: Import assy into TC with naming rule attached say for CAEAnalysis Object 8 i' e% n7 L; ?' F: R" s* C
" m: ?- \$ x6 d
6510886, P' C% b" ?3 Q
NC: Turning off hidden line returns an error/ b, g( D( Y9 n& e/ E
7 u. t0 B/ f/ q' p  m- o
6511121
5 \& l3 u2 f' h Internal error when edit parameters of stamping output, change Springback Compen
) u. v7 T" X; X0 Y) {' g : F2 k0 _$ c; q1 b
6511348
. H5 K' d# x% j7 @3 w) _ FASC cut region start point causes error: An embedded object cannot be deleted: Z$ n. n6 n4 i- _$ e0 D* h
3 r# F7 R6 I- s3 L/ P! L6511495* k& j: s7 @5 J$ t7 }/ H
Edit of Expression causes system to hang % O# i, Q) M0 m" T4 C" H
$ k' o4 P5 w0 u! ], k9 N# N65115706 J" C, z, J; t/ O' R
Switching one occ of component to exact changes all occs to exact 4 e0 a. u- b0 o+ ^
. F5 @7 x; }# \" `2 C3 b* [9 {% Y
6511595( M$ L2 y, t  U( a% `3 n
Var Axis Surface Area operation takes almost 3X longer to generate after 7.5   y' t/ C8 E7 Q( F. p' h
1 H" o  |  ^' A% B- g* t# a9 v! W
6511622' \% C9 e7 X1 i& D: r) I. M/ H* [
Zlevel operation takes over 100X time longer to generate toolpath in 8.0 ip18
/ n. ~& |# \5 n) t1 c4 K2 i2 ] 6 W7 V" U; M( l8 a/ ]$ g; I
6512310
2 A7 \7 s8 W( o* {4 k Creating a foamboard raises "arc length must be greater than zero"
8 N2 N! d% B/ V& h4 G9 e
, r8 q: t1 a! s& r65128488 d- G" L% U0 H8 E9 m2 Q
PLMXML Adapt or Does Not Support Translation to NX 7.5.4
* `3 x( @6 r4 I. x. o/ h
% {* K3 `, h! C5 t3 ^" R6513165
9 J- \3 ?+ p; K6 e, ~+ N Leader attachment point changes it's position when you edit inherited PMI note
3 A0 r8 Q. ?% a: W: l 7 J$ x6 g5 ]6 `) ~% Y# a
6513185  j0 j* ^6 m# R. x" t
Dim created on inherited center mark becomes retained after updating the view 7 [" ?; y. j$ ~2 Y) H9 o1 E+ k6 x
( u8 b+ L* g% t8 V7 @; ]
6513254
) c* S, U8 J7 d0 y Exception error while adding new reference set in Advanced Simulation application% x' a. l. u( p9 z' I5 H3 O
1 o; g; ?4 ]1 O& h6513558
6 x0 Q- D$ T- K; w% D Corrupt part by using "Add Stock" dialog with #UNKNOWN_STOCK as specified stock 8 Z* V0 ?: q6 q5 Q4 m  _/ s
, b! p6 B4 [1 m$ M/ e
65138551 i4 B9 R& @# V  B/ s
Baseline dim created on centermark get retained after editing model 6 G7 `+ A  Y7 v3 p; X
7 X3 ^* }( d8 o3 i* n/ k) S) @6513912. P, W. r: [- ^3 ?- d
Curve analysis does not show properly
& L2 l1 ^4 K8 P0 K% G: F / I5 j( ~- a7 s- m
6514473% {) R" e9 @5 I, o' {
Assertion editing revolve after copy paste  z+ l6 {# E. L" ~& y% e
- O! K" a: Q6 d0 W6 S
6514503% p0 E3 i: C; w- r1 u3 p0 T
No feedrate on engage and retract if IPW option 'Use 3D' is toggled on
: ^3 o" {: l) X5 \  A# E2 }8 w
3 f$ [& ?# i- P+ I! n+ o8 ?6514669
- ?- [, _: j7 ?& O$ T Error display when suppress_unsuppress Marking line 2 `: d2 P" q; ~% K0 T
7 F& l3 k6 ^6 d6514753
/ A  R7 B' K- Z Internal error while reopening assembly from ANT . K. |1 X( ]: p0 U. v9 s  O$ _
: G, W1 |/ m/ O: }6515032, l* r3 l5 ]4 m% a
Altrep component fails to load if the dataset has been renamed in Teamcenter
' y, k# F  n, S  e# x2 H2 V( l
( k5 Q9 n; n' @+ T  A) P/ B6515073
5 t0 w) z1 r9 w! I% [6 G( W+ ~ Ug_clone fas to export assembly
" _4 v" ?) ?0 w9 D' H 3 v% K# s6 h; S! U. r
65151064 J1 ^' v7 r+ i$ g2 X* H0 y. t2 o# x
Thread symbol in sect view is skewed on one side
+ d, ]2 p! d2 W. Q' O! q1 I
, i8 Z2 }8 S& `% t6 T8 J# B) z6515136
: s5 ]4 w8 \- `/ Y7 K/ h User tried to move sync even and NX got corrupted" ^' e- U! S6 a/ X9 s0 [# W. p* B
. U" n+ D; g3 G
6515148
' V* [) x  C6 J# {. G" \6 H. |$ W UG_CLONE export failure
0 W. P- X9 ~: u
$ v7 ?* }7 I" D4 R. ?% N6515237
9 X: r* z  H! [' S1 z* N Two Preferences -> Section Line commands in ug_drafting.men
' J6 x% }! P9 c7 \ 6 s6 V' ~% K9 [* U: Q" \  y
6515301
1 r* l0 U) O* e0 o PMI dimensions text are not scaled correctly with view scale $ t8 V$ ?8 L7 B# f# q3 A
, y* W( @& C# R' c
6515341
( R# b8 M/ Q1 @. n Mandatory Attr not recognized the first time when added to new comp during save   e+ A) ?4 a& C* a% G* `2 g# }- {' }
/ u' T- G. k. ^4 F8 E. Z
6515597. `/ Y: p% a9 \3 ]* J. F& J
Curve drive + interpolated vector - data point move to other locations " K3 ^  f; b0 |% f3 F6 A$ J9 O- S
4 A% ]( z+ Z$ H. J65156276 R3 j( X- F. ^& s4 {/ m5 k
Assertion failed if use Xc direction or other axis in Door opening 5 O& `. c; Z+ i- R( H1 u7 o0 q9 S
) p4 G" y7 h+ L  @. q3 E: e6515671
, }, K* e0 X& U5 r Regressioneader of a retained annotation jumps to different position when you
7 G9 t2 e" x; ~9 x: k: y+ `# ~5 |" l 6 r) D: w9 Y* h& \+ L) a
6515731% N% y# O' @# g. p
Unable to specify inputs in paste dialog to create measure length
! S. X% x$ r* c; p4 `* I4 _
# Z  Z! e; d& \0 I9 u4 Q6515842
; [. q! P; E) i% ]4 f. r) L Note doesn't inherit custom symbol inserted in a note* n/ W+ a( L! G+ J7 D
- A9 A: a/ r# r# i. W  Q1 _5 }6515986
- j& h0 z/ F5 d Export fails to write parts correctly with WAVE associations and Multiple Rev parts0 y. z) V% F% B( s- p0 b
7 S6 w: L) @: W0 h7 C
6516088
+ D6 G* u, g! f6 C0 E( H PS24.00.172 - Edge Fillet visually removing Surface6 j, l: W( z3 i$ M/ b6 k
2 D! J& S8 p; L: @0 Z* h. p65161130 o( E0 s7 i* ^# n$ [: p2 y
GM UAT No PMI data provided on Weld Assistant Datum
8 [. ]3 W6 \$ d' ~8 c 2 {& P* }" @& R; K3 L
6516347
# F' I9 ?, l' h5 e$ z* m" K DIC non-associaitve linked bodies incorrectly showing up in Part Nav body view 7 P$ q4 n, t2 }
: c# G' O* r7 i- Z. u5 M  m
6516571; J- N: e, t9 f% X9 `
Settings locked at higher level message only partially translated
3 P; J8 b7 `, y8 o
  i" V. M% u+ Z" R. i6 a& k) f6516590
; Q. s: t' q) Q, l& E& {6 F Drawing and "Sheet" not translated in the Part Navigator
/ [" A! x4 g5 e) D3 A  l ' C2 k' i# ]5 P3 T, h
6517081* d- p6 q/ a5 \
Memory access violation and Assertion failure creating a motion envelope ; [) I: X& x5 i  \& D% B
! `: L: X/ s9 F. X! j' w2 j
65170976 V, k! `4 c9 M4 D& ~) S
NX8.0.0.19 -Snip Surface giving incorrect result in History Free mode 0 a0 N7 h2 M# j+ h! a
5 p* V' F$ R: d7 `. |" O6 ]
65172042 r: @/ o$ {! F, @0 j; A
List translate error , v  I0 e" l0 f( b2 v
* y5 h! E6 o1 E6517259: ^) ]2 K' d' \8 B3 E. i
[1] Drafting NX80.19: Autotest Failure: Drafting auto-tests are failing with cra
7 T. \  X5 Q' i& B$ k$ Z
- w5 D) t" b( C65173072 p$ F1 |  m! g; s0 |/ H. i$ S
[2] "jat_assy_constraint_parallel_center_fix_touch"EXCEPTION:Constraint-data
' ]+ `! t- U9 @3 b% r2 b" V
7 }- k, u2 I% A5 F/ O65173457 m( a, Z3 S& X% o# K
NX 754-Syste Tes_Assertion error by moving Routing part with Vector method * ]" l, e5 F  G0 g) w
; L3 O5 O5 w$ S5 K' i6517404! c, `( v7 n: V: f0 z4 ~
Tool gouging wall during Variable Axis operation
$ G) r4 t  J# I0 i" S
; U' N1 K. e8 Q' y4 U& u' y7 _; x0 ?6517523  }7 b% ~& O3 I) z. a& \
Newly created methods don't update
4 ]( V6 L0 y+ i+ \ , L; w5 b9 T- R. b$ o- h
65177334 J9 q& E  W0 j3 I# `; j+ Z4 A
Check world  failed after edit count of referenced pattern
' m4 Q- ?( L3 A9 W1 r; V3 u
6 ]4 u9 n0 a( }. x7 r6517956; g+ v- n' r& v# m: L: S
Simplify Path in 3D master and Update Formboard causing unexpected layout change
) Q9 s; E9 C' E
' J: ]' b3 {! Q' ]8 g6 Q( q65179687 G8 G, C  \% b0 @+ a6 g
Bounding Box of embedded symbol is incorrect, results in incorrect looking symbol- V* J# @* z5 S$ t0 \( a- q: b) O
$ y" y' [' n5 D/ {! K0 D9 L1 B6518040
$ q" ?* C( \0 j+ e' [' j& T Regarding the dimensional style 3 j5 y3 E1 f) E% k
) u- }- V5 c% p1 W# T6518090
3 e3 u9 h! J# O# D- \ Assertion while opening an assembly after changing name of altrep dataset 9 W( y9 [9 I& a
8 r1 @2 }8 F# j+ L* A& Q8 q6518144
. x0 N+ L+ M  n7 }& I6 g Weld symbol is not getting inherited properly * W. z+ \& A. k0 b+ v4 i3 F! t$ A
, a1 u9 L1 c: U: _& R( N" i65185094 A4 i, J: Z- \8 N4 ~5 n
New points added to existing Spot Weld cause all existing weld ID to reassign . u1 Y: ~- d. D: z# v  A- s
) P& h/ M+ `! d1 a5 W0 o" x
6518895. d7 y" k* x) w; ~+ V# |7 }
Finish Operation translation error, trim task and pierce task all exist   r! y% u: j4 r/ }
2 J3 @$ j0 Z- \7 G* \9 I% I* E
6519085
2 _! c# |* l2 Q4 O. {8 X1 ^1 D Create wrongly in chinese environment create wrongly, and redo error ; c; G4 f/ m/ J2 f% P" @: p# R
" o- h6 E, W8 z- ^8 V6519354; o4 F) v) E) \3 k; }
Assertion on Convert of Routing Mate Conds "ComposPartOccIsDirectlyFixed(to)"
( K: @6 o. O1 F" G / _) U8 n+ n/ q+ `! V. X) ]0 X2 S
6519368
$ \8 {" ^# x, @8 B; L Tool is gouging in Cavity Mill . [; x7 J) g! t) j+ M0 p
( G. b3 \  x: b) {6519578
' L; m" j( ^) D) v Surface finish symbols do not show leader when components opened fully
) V: e+ w+ i  U8 _$ b- v5 m
/ e  @; _6 [: R1 r3 Y6519632* f0 Z0 l& P/ A4 k  ~
NX BVR remains checked out after closing assembly
8 _7 u: g7 H4 s. ~% H; a# A+ k0 }$ e
4 A8 |# r; r' w  I; D' X* _  b% x7 r6519832
2 N& V8 a& i4 \. h6 [' b Not able to edit FMBD User selection layout for multiple built-in paths comp
& p$ P, ~: u% \: G  e4 a0 E % F* m* `9 z. [/ i7 g! O9 M) B$ ]
6519849
* H9 \% p4 D6 t" w Formboard layout branch - Editing Standard Angles is not working correctly
# D5 z1 O/ Y, V! }. ^1 d 0 V. _9 p2 n/ q: ?9 |2 o
6519906: B3 @' C; k- n
Internal error while launching Optimization Wizard for a part family part
6 W- p8 z7 x+ J $ z* `: L4 j% N  N5 B
6520383
1 B( G6 w  b: b3 { Ribbon Builder tolerances are not using preferences values for defaults , k/ f$ m% t& n4 d, `7 l
% p9 t( [& W- a- E/ ]
6520475
1 K/ ?8 f9 K& W* i SLED_7542: View requires 2nd update
  b  W9 r# o% n: y7 b " q% k. k; W8 V' Q3 _& o1 g/ c
6520525
: |. {3 c3 n0 e% l NX 7.5.4.2 SLED & NX8.0.0.19 - Curve Graph not working in assembly context 3 v' ?3 a8 t5 F' c
/ z: V& @7 v& q% [6520559
- \: X/ h9 G! c9 ~& H$ T; L" n& O General Fault Exception 6 n, E( f# C" F' e2 z
& J$ A. a3 N4 \9 j1 u( X8 J1 d2 k$ A5 C
6520562
* _6 V. O( X! ], n6 G; } O_S ERROR: signal 11 during load_replace component' k$ f+ f! W2 b5 T
- Z- _" c8 F% U5 N8 W6520652% }3 }/ V$ b9 A" a0 ^
Assertion f ailed when Association Piercing Insert
# _+ g+ Q- o' `6 K6 B* X : C. ^. M/ Q8 A9 J7 r" K6 U: E
6520668
- e0 H' C. {  R. y5 H SLED_NX7542 Error while creating angular dimension by selecting thickness dim ; O& {* v- Y! o. ^3 z- s4 z
9 g$ p& K" p1 F+ x& S
6520709
+ t5 C3 N! q& {3 D" c+ g& O Reverse Normal does not take effect within Variable Offset / r" [# a% E8 R( n0 y) |6 V
/ ]5 y* ?' n5 O6 m  |  F65207125 J) Q3 g- q2 Q5 f! [) z+ z; @/ q+ v
[2] Drafting NX754.1_200: Autotest Failure: Drafting auto-tests are failing with
% O8 B( E2 s; w/ M5 E * o4 s. w0 V& r$ ~. |4 v, T' U5 U
65207344 S5 b; G$ ^, }6 c2 p6 T6 L
Check world lower post feature. it will appear assertion failed # T4 T! m  m) b& c- W. ~3 K. F! c
& n& c2 E* ]" ?8 p* M- n7 |' d+ y1 \6520742
9 I" M* |% y& O9 w' E* s6 S% [ NC:Internal error during copy paste if some references are not resolved : n  z* f* W/ B7 X
5 V* M4 m* v/ I+ a
6520765
2 ^3 p0 F: d7 w7 z4 T. N* ]0 S REGRESSION: Inherited PMI annotations have wrong orientation
3 I7 V) ~. H7 @0 W* f 5 o7 w0 H. I, h. `; V
6520786% O5 U6 x: e: @. ?: x9 j* |
SLED_7542:Attribute value is not updated in names part dialog for Force Save All
: Q5 w* H: w% Q$ @+ p 0 W- k9 W( V! {6 a# h' f
6520787
( Q; \- D8 k  h, A0 P, a The "Text Parameters" shows without value in info view for Disabled checker 5 W- i1 E- P4 F% _1 w
3 [0 t5 [% ~7 F4 E
65210733 j- \3 r  K# K3 y5 k
Unite tool selection lets me select same tool body as many times as I wish % a6 ^; S9 k* ^
' e) b9 r" ^( q; S! q) r3 d6521164* f3 ^7 ^- y  \% K) p
Error when trying to delete children. Memory error
* B* {. u5 b1 ~* a7 s & K* I  J* r! j! b: H# K
6521199
) J( B5 ~0 [9 F3 K" Q Facet body disappear on facet body curvature 3 R5 X. k# p7 o$ N4 l
0 m% u. F; H! u3 b# B& V4 V* z65214249 W6 `2 k% l- A0 m
SLED_7542 : Leader end point is changed while editing table leader
6 j2 t9 k# [4 _! [/ ~+ @# J  G
+ r8 p" `3 |) Y5 W- b2 y) F65214782 w- `# F* b+ W" d+ m2 N" O+ K
Autotest playback failed because unable to replace face
& o- T: ]4 i6 V
. j5 Y: J% ?* Y9 i5 i' T; y6521801
7 Q- S( C/ C! e0 A GM - Clip cannot be repositioned following Replace of part 9 |4 v% e8 O# y3 ~3 P
8 L: _" m  H  u3 w8 B65218377 k+ h/ v9 L5 {+ e8 F
UDEs not being output according to Start Marker + B6 R% [  H- I, w2 i
  D, w3 }  C* H7 x5 u* ?. |* \9 @) C. j
6522033
' P# v5 F5 I! g6 t! \. f9 |! @ Xform Falloff error - 2nd selected row of falloff with additional falloff added ! D+ a  U, Z" N; S
2 p- q0 y. j. T% N+ G: |* C
65222821 \8 L* X' F6 L; X4 |8 K
Assertion failed when check world after edit in "Open by Proximity"
+ I+ o: d  |1 m7 @' U / G! f, N+ c! V) e& S* _0 m
6522335+ ^1 L% A# s7 V; ]2 ]
Autotest playback failed because differences found with XML comparison 9 l% L) T( @8 v2 Q( ^. o! D' K
. \  h4 h) S8 }) S( n' v
6522371
" A+ a9 ^" F- ~' Q0 f. t6 |5 O3 K2 R Could not apply stock in detailed style
0 ]2 c4 N' [  ? * X+ J. y) J' }0 e. G% f! D) [
6522649
8 |$ _7 R- k* n/ n' ? Internal Error when doing a Save As after deleting features in template part $ P+ Z' O  `3 k0 i4 Y
  `' N& A% e; E( Z+ J
65232501 k$ h4 m3 ?: ^
Sweeps cant be created during a reroute post conversion - amh29868
5 ?. @5 w+ J3 ?; G" C! W6 }! [4 T( t ! v! g% Q4 E+ P3 d+ ]
6523251. x- X* T8 C( ^! ]4 ?
Assembly Clearance fails to find hard interference between components
- j& n+ F, t* d4 n  F
/ Z% @+ r4 e2 n* J2 }1 R, V6523316. p% E( C9 @; i$ k# s
Assertion when replacing component involving VCP. & w% f8 g1 ^  u7 l' B8 S' p
) w8 a7 x3 N) L- P' a0 ?# r
6523376
! `! ~/ b  i" y( d# x; s Some wires do not re-route post conversion - amh29984
1 V  ?, ^3 T7 q# W/ k
; I# x( S( y* ]$ G+ ]6523674- A. {, N) Q6 J: d
Auto-flex clamp is not inheriting the bundle diameter after placing
- X$ q9 L, X6 z1 Q" G2 p" q! f; C  Y
' O$ {2 q% \/ ^8 O6 M6523688
% w/ Q0 Z1 s! V8 u3 p After formboard generation, most of the constraints are marked as failed ; h7 Q+ D# Z9 ?% d' U3 o/ P7 N" B
: e* @# [& E: v6523697: K# o: y! l8 U. ~9 v9 o$ X
Formboard Update must be run multiple times to resolve discrepancies
5 [3 ~8 X# Y: g3 O4 _/ s
0 O" Z5 _, e. Z) \6523734
8 K& i9 G$ g. D+ }8 C3 e: W3 Y Invalid Arc Length error when creating formboard, W  h+ k5 ~+ p  a
1 u* t* U# r. y( ?
6523748) ~/ R0 u3 @3 k5 |! Z. x
Circular Reference error when performing formboard update ) o0 K, A5 m' T9 ~! N6 b3 F
# a" n! n, A& N
6523895* S" R0 O. Y6 ^4 ]6 `- K9 N! k
View Dependent Edit changes after updating view
# C2 d. {; B2 Q- s6 W- K . s) j. ]' E2 U0 C( N" E/ a/ m' u
6524195
6 L( I* h* T8 ~4 I Assertion failed occurs on Datum Locator
: `$ D0 @9 z+ \6 }
, t' J8 J  A! W5 m9 G3 G" F6524235
1 o, \, q' _/ j' l2 `# X" G" K  w Inherit behavior is not consistent in create and edit of centerpoint option
  c/ \2 k0 o9 O# e% R. x. ^# p   W/ c! t' s. l5 c0 B) @
65243182 Q# Q7 G4 Q' v* F
OM check failed for PMI dimension inheriting on to drawing with update
) I, i5 `! s  u
. p( ]9 ^8 K+ \+ L% N6524361
5 {5 Q( Z& w3 X& j2 P& x8 `/ O: p REGRESSION- PMI dimension is not inherited correctly : w( ~/ |# ]- T7 p$ R" v! v3 [4 u
+ c+ n/ Z1 P% i3 S* Q- g3 a6524385% w; [6 U1 s8 w% U$ {  `3 Y. P: I
Exception error while dragging the DFS in global selection
( G) w1 }+ o7 K0 y+ {. E   N# e5 ]! I( k
65244316 f4 @$ y5 X. R
Inferred dimension do not create expected horizontal dimension between Cen. Mark" c/ b  ~' R+ a6 M5 S
% a. h2 d6 I/ m& ]! i4 k( i" k6524504
: S6 h4 N+ d: Z& J% t NewFlyer: Altreps are not opening since upgrading to NX 6.0.5MP6
) m7 _4 g" R" ?+ Z* \( l4 A
1 T1 L' K+ H+ f* {, _6524574
% N( F, l4 B; ]: ^1 s2 B Invalid annotation plane error inheriting PMI in assembly drawing
# v( p* Y: g# a+ A, s, D 9 t& ~2 W" Y, J0 H
6524677) }7 u3 R4 y1 ]9 U
Moving a view with retained annotations causes leaders to fly away 8 T$ o( B; \- J! H6 v
+ Y! K1 \4 l# B1 L. u65247374 |" m, q2 L1 }" L3 l( c
Pictorial Sec. Line changes turning on Exrtracted Edges $ a- l' j; n% K
/ H; n8 n; j. |: j# Q
6524826
0 E8 z4 v5 ~' X6 e8 ^  T NX 754-BugHu t: Copy PMI dimension will copy the associated PMI centerline % O% J4 {) t; ~. y# z2 ?
" ^( a  W4 ]# D0 z: o% [0 s
6524910! U: [: \4 r! {+ ^! ]
O_S Error deleting a drawing sheet 2 R2 ~0 j- l/ L- S! {( S7 S
" m5 U0 Q- t) q$ t7 D, _! g
6524957$ G7 \0 g6 k8 O4 N
New added blank is not hided in the sheet of electrode drafting
, _! g9 E( ]+ M4 b4 O! i( }
2 F! X* X/ ^% q% y: y65249793 y! H' B% {4 F/ E+ ]0 i
Redo failed message pops up after performing UNDO_REDO for any annotations 1 N6 {5 q- Y' B
$ e  n0 Y5 s# T; x+ ]* I4 _
65250165 R% s. L3 y! t5 g# o) L
Autotest uft_ugmgr_part_control is failing while setting the default folder 8 a* z1 C. A; q; ]
2 s; L" q7 g5 r/ ~5 j* t" U
6525025
  t$ Y) f, y  H Extension line of dimension are not migrated correctly - C) M2 a% ]6 ]: ^" Z( {# @
3 h) A- i3 S* `8 q6525042
6 h# r+ m; k: a$ I Dimensions  location are not migrated correctly
! u3 c/ U* R9 F- l! v/ ?
7 _8 ?7 j% e0 |4 m65250435 T" m8 t3 ?% k0 Y) E; R! n
Angle setting for Custom Symbol is not migrated correctly # ?4 v0 U. _/ h$ ]" L5 K% F
/ c! M4 w; \# D3 B5 [* E; q: ?
6525044
7 w0 Z9 L3 }, X- u Leader setting for Identification Symbol is not migrated correctly
  y" d8 [5 G; @
: V+ T$ b6 ~+ j, z65251657 J: d2 i6 z0 M0 N) m: x
Regression: No translation exists...error when trying to do PMI section view 2 }1 z3 d" O/ q2 i
! F- ~# t! N0 e" g" l8 e6525231
! H" \0 E+ W2 e* v3 \9 a NC: Regression - Issue in TabnotSection cell import spread sheet dialog
9 ?! A& N2 [4 Y6 |$ r2 c# s . S7 P- C' v' e: R- w* N: l* S
6525387
2 \4 n$ ^+ G; G; L" k. Y4 V, I Path updates due to revised model swap modifies entry_exit A_B angles
( w" [# f$ T8 C. m7 u, w & E5 ^5 H$ ^4 l
6525415
+ X3 n0 V5 ], d2 }+ O, r% ?( H Auto Centerline cannot be created on Faceted Rep View
9 f( J2 L! G9 y; t3 l 4 q' O$ S( E, t' ?  h1 {. {
6525555
4 ]; n+ E! w% }9 r9 E6 Y) e Signal 11 when deleting & adding interpolation vectors 6 E: O0 O5 [% ~6 X: h3 q
9 q. }: g) F+ g4 h' m
6525809
4 _5 H  ?" b, d- d2 k Internal error after deleting plane & perform operation on unfolded section view' s) X5 n) X1 e" a7 W
6 J% a( f& ~2 P% m9 G+ b8 X6525895
5 L. c  K6 O" J8 A Internal error occurs on Weld Point 6 |' ~, ~+ j  I) Y6 l3 K
. {9 U/ W5 a# V( r: @$ y5 H# O6525934* ~0 Z& K  I7 I  b+ x9 X& Z
Labels not coming in view in NX 7.5 ' a1 T2 q6 a  G/ A8 |$ P; R
) N2 O& x3 Q4 t4 L6 G# u& ^7 F
65261421 b; ~! O; M/ Z8 L- B# t1 M
Move option in assemblies with point to point re-picks original point ! k! Z. G- |1 t$ i+ B
( }( R' j1 o, c% _' y( i- A
65262666 h0 G' l+ k0 k2 a# Y5 i; B0 Q" f/ @
[1]Modeling ugnx754_2.410 Autotest Failure:Child nodes from master XML file are
) T+ |3 L! s* S' u; A$ ^2 m
( j. t5 f/ e( x6 M8 M65263065 k0 c7 A' u* J5 P0 A3 ?
SLED_nx7542 -- error displaying cutter assembly in TP Verify + i1 ?" ~. @9 z; T
; k2 Q1 @( H% ^# X. Y" Y1 r6526390
' V6 s2 m, `2 s0 z. D  ^ Severe performance degradation loading assemblies in NX 7.5
5 W! ~) S2 h* I/ U3 T5 A6 H0 t7 e  D
* R, C+ I& j) v) H2 M, m6526468
! |3 p  V1 O" \4 D Performance problem loading part in drafting
5 P% G2 O1 y; }" _  I* y 4 g1 c9 ]) K& b1 B
65265789 E* |! w( K' X3 q
After applying "Closed Solid Arrow", folded radius dimension becomes messed up 5 x# T8 {8 Q& D: g, Q
# w+ |" S  ]" ?; Y: A$ E7 _
6526614
  k/ y0 S' Q1 e7 ~4 L: R, r; n PMI FCF behaves weird after editing from drawing' C! R+ }1 M6 K0 N. W
1 f/ r$ O/ l% J3 \* a; I6526688
8 W# }" q; l# y) W8 F Current Issue: [1] Drafting NX80_20.225: Autotest Failure: Drafting auto-tests a
; p" T0 f/ Q+ w8 Z' E  j; P $ E% n; U" F6 \: w/ Z" [& j
65267716 z  u8 O; E+ X. O3 Y
SLED 7.5.4.2 EXCEPTION: Object is of class WireFrame:ine, not ANN_BASE 2 {& {# _+ ^( V/ Q: {
" F$ g5 M; I, `
6526809
) H, z7 j+ c! K" { Layer filter problem pressing the enter key. Internal Error_General Fault
4 V# I. U6 s  q/ a8 D3 W / f# c  e9 D  c. d0 K* z' p
6526962: r* z0 R" h- X8 d, B
Can not create offset csys in afem which refers to csys occ
$ D% H( C0 Y  d# V! g ' i. {: ~0 c- b: o7 A* J
65269834 c& B) i8 Z) T7 k, L  N! ?
[15]Adm ugnx80_20.377 Autotest Failure:NODE ERROR: Cannot find "object" attribute
* O" l7 w+ g5 s9 l  F ; O6 |: U" s1 f; U
6526990
2 I/ v  |1 F/ D7 a# l [13]Adm ugnx80_20.377 Autotest Failure:Nodes differ : original value 16 8 M# J9 c9 S% F% Y+ ]
7 P  D- Z0 t- {+ a6 `
6527133& _4 R' U% K: E' r/ m$ v4 v/ h
Editing A Point Creates A New Point + L. G$ i  u9 {5 l
% A" G& E" A  [2 `' ]" J0 R
6527330
# N3 O, }6 |1 Q8 a3 m6 x Assertions from getMovableObjectForCompData while autotest print assy structure
$ g% ]' z* x% |7 ~  d  ^
" w& O# P7 P+ O7 P7 A; |6527339
) K7 P& b* O9 j2 u+ W Error:Operation Open status in View Manager 1 N. |- c: v3 O, E: D' W
0 |+ b3 G6 h9 c2 K" T) u
6527346
7 U8 i6 Z# D1 G' t3 Q' X3 p Identification symbol when placed inside annotation view not shown properly
7 i, v$ S# }/ C( _
3 M3 e) j6 L0 R* q( S% `6 \6527385
2 S, ]! K7 ^2 D- P! ^7 } Regression:SB Drawn Cutout fails to update during playback
5 i& o2 K2 o1 q% g
' C6 k- V2 j$ U# L- ]65274263 r3 M6 N' y! T4 ~; D; k: l
Datum plane defining objects are not available in edit mode
! H' Q3 P) E9 k3 O  N" e8 h * {% O7 y  u: l$ K( \( u
6527618/ @5 h; Z; A" w& U6 v
illegal tag pointers from check world error after editing parent of pattern
" |) \/ a2 j+ n4 u& w 1 c: c7 h- |' R" s
6527623, n/ i4 F& t" M3 |
[1]Sheetmetal ugnx754_3.169 Autotest Failures:Nodes differ : original value 36.9- U5 z$ j( X  r5 Y
& n1 d" b- B* M. z( N9 S# e6527662# V! X' K2 `3 ^6 T' V, {5 H8 ^2 k
Cannot create a stl file + `0 w% r) S6 }5 z9 _2 L" a
( B0 k1 F( k7 h) f6527665/ _  s" g- {8 }& X4 N
Mating Conditions fail to convert to Assembly Constraints ) n+ ]% x" X& Z
% r, F) O! i3 T7 b6 Q9 f
6527865
( J3 M# Z: U6 B! ?# M4 y [1] Drafting NX 754.2_209: Autotest Failure: Drafting auto-tests are failing with
* ^' e, W# e4 i' Y7 y 3 m: Q6 t, N  q: }1 R
65278742 _$ m& @2 X2 c2 l
4 @( [& V* X" ` * l) R$ l! P  `7 @. u
6527878
) a) @9 z8 W4 T% B/ h0 H0 L Leader is not created correctly in expanded view" D) e4 S8 ?# f  E3 t  ?
6 A) o$ l0 g$ ?2 m( y
6527906
* L2 a$ u* C9 t. C' ] [1] Drafting NX 754.2_209: Autotest Failure: Drafting auto-tests are failing with7 \! G* K9 R; \! j4 ]+ Z
* C$ ~) p  t' x, `8 p: G9 f6527984
6 l; K& i. }, @5 G Annotations with jog position, placed inside view does not display properly
: V: B" L  w! w3 ~( l7 h
8 O# b: ~9 f) U" U0 D( l/ v2 A6527996
! j6 B1 C5 \  v# k4 E% B2 D Internal error while using Paste for Linked Region
+ Z  J3 z' f. i ; I& h) p  h8 F4 v0 c, W, A' T
6528065
* ^+ A3 U4 H5 F1 i Development Severe error comes when Add New Reference Sets in advance simulation- n( J! W: C! {/ a- e) C
/ V0 h$ @/ y. q6528084
' e" I9 D. G1 G! p Deviation Gage NX 7.5 is limited to 3 places, 6 in NX 69 |" Z. Y2 m( y! }2 n
% Y( Z' E) Z- g, p65281199 ^% G* C' l( J: I2 K+ ?. Q9 @/ H% h; Y
REGRESSION: Flag leader not positioned properly
! A; w. u8 x. V0 J5 L! H; a 2 V& r" v7 ?) U+ D: K9 O- U+ m; {
6528140
' F( W9 C" ^& h" b7 s( i. f. D [1]Modeling ugnx754_3 Autotest Failure:Nodes differ : original value 0
, i7 A7 K6 Y/ j* ~ 9 i$ B3 s4 z( |9 }8 {
6528224
: Q4 T6 c: G1 K7 v [1]Modeling int ugnx754_3 Autotest Failures:Nodes differ : original value -2395! w. D) _& h( s, J
# w+ I' x! \  a  m2 a# Z( s
6528358
7 p+ _4 d0 I* z [1] uft_ugmgr_part_control failing to do UF_UGMGR_set_default_folder
+ b# t9 A/ k! i5 }5 M
  C/ o9 Z/ f7 P3 t6528395
5 Q. e9 p% X, ?" m! F9 K$ A  }7 W+ U Labels attached to Section View go Retained after view update
2 q" ?. `" }6 @; W # s/ X, {! c& q
6528537
/ j- T: y0 q1 l3 ` Getting Null Tag not allowed in Copy Paste of Point
8 K$ t2 D3 p0 j; b: [* K * u- h# h2 w& d
6528553
9 s% E' ]/ i  J6 |  F Stone Inpingement tool is not showing obvious stone hits
8 ~1 q$ d- @/ ~+ a9 t% G/ D
: ^  z4 \0 O8 W. H6528604
  M+ |) V; A/ n  V Block feature create always defaults to WCS first selection is second point
9 V) f- `. X6 E& T; V% o) {
. n+ W' T) e9 Z, V1 \8 w- i9 Q6528612
2 p; h) |- r. f- X! U& q" g% P$ w Array Output given by JA_BUILDER_get_committed_objects are not marked as sorted3 C' z" t9 I7 D+ H! O
# j! Y  w& j- q- x2 m6528617
% |' x0 ]4 Z! H2 w Add maximum spacing Key in Buffer $ ?6 C" C9 d3 S) i
9 u* J, s- d7 `3 m% w
6528628
$ H* ?- r9 `  S5 e5 |& A# T Array Output given by JA_BUILDER_get_committed_objects are not marked as sorted
7 ^9 G" R8 K, }& s 6 w4 h( o7 }( a0 Q/ U, L7 Y
6528633
5 V7 v) \- F2 Q; } Automatically thrown out of Move Component dialog on error
% O, @; [( D( U! p- ~ + c1 w# A, l# ?9 x* O# j
6528695
; ~: F3 K. b0 s& z3 v8 H# M Invalid OM object error attempting to define Formboard layout
0 P1 `" p, \2 `8 u4 z+ K 3 ^; k4 L4 a9 f5 M8 e; C1 D
6528706
- z$ {7 v1 C& k" D Formboard update fails with overstock error
/ J7 t* V% C( z4 t. Z# I 8 U8 d' X8 s( d6 ?. z! ]- @7 n
6528729. c% s! F5 \! h' l
Flowcut retract motion is no longer correct$ z5 A/ T) o9 H4 h; `% g
- O. H7 j0 I+ P4 j7 @; e
6528874
2 Z( @9 h) q( {0 l Turning IPW does not update correctly
+ L! \! }5 J) a7 a0 g9 G& A+ L' R
$ ]& n4 b1 i9 n4 `% }6529026+ J5 P7 Q1 V- S
PMI custom symbol induces Fit failure 9 Z  m$ V7 z" @
6 S( q# I" @/ C  b' `
6529054
( j( j0 u0 b6 j, B1 w5 J [2] Drafting NX754.213: Autotest Failure: Drafting auto-tests are failing with
% S- b( ^) [6 p0 K
2 z8 R+ B  ^1 d+ y6529065
# l6 h6 ~0 [! f4 t8 S! ]2 u' \ [3] Drafting NX754.213:Autotest Failurerafting auto-tests are failing with XML0 g, I) X4 g7 Y7 s) P
- I) f/ A; u5 ~- n6 W4 O, s+ i
65290827 Y0 w$ k* X, t
OM check error comes after adding Datum Target in Drafting
; r9 w& t& W; U; T1 m0 E4 ?/ o4 z
. N+ Q* {' R; `! _0 j65291070 r4 S' h" a' X  ?" y8 O6 R3 _
Wrong Trace line is created by Move object feature ) r5 L$ |+ P2 y- [0 V
5 s" h9 A2 Y6 A; `% h1 `- y
6529173! r8 W6 [& B. ]: {5 \
Incorrect result for shape segment as segemnt does not move to the desired angle
- E' I5 p( [  J8 S+ L) _' w + v. ?5 }- s3 r! U9 @$ r! s
65292538 j/ ~0 j# \8 k/ E4 ^$ z
Regression:For Datum plane Grid, Cut&Copy is available but Paste never available' `% g& Z5 G# n
/ A7 Q/ k! W: u) j+ ^; g0 a! C6 X
6529302
2 d1 W" M/ A" r+ N4 p. V" o Associative measure between plane and composite curve incorrect after edit 1 x( c4 r3 I$ ~# J7 R! K
+ O5 C. z8 K# k3 t" g! Q& L- [
6529377
# f  H& A  p: K% v" s* D7 f) ] [2]ugmgr_PFM_t autotest are failing with part not found
& q: j/ r, X$ K1 q' d
  d. l" l0 t6 o6529379
% I* Q' w9 |  b) S$ }2 s8 Q- r1 v) h Problems in PMI note creation using nxopen
9 f8 v) z6 m7 |3 U. \/ h
0 _. @) S  c$ {# h8 U6529384
' c7 y. d$ f) A$ x6 ]+ S2 D! A Internal error when replace parent of sew
, X' [2 {0 y' h3 c/ }% ]8 _ 8 j" U; v  Y$ n9 ]' [
6529472
7 i0 }" Z5 a: o) f# @5 b' V/ K4 S Change from Type from Plain to Flag back to Plain Arrowhead changes to "None"
' F; B% f# C- a$ q# w" s5 m( g
3 }# Y# q) b* F7 [6529732
6 j5 P/ c+ }. I  }" g* a. _ Internal error making linked points at timestamp
. A. L3 z. q; Y* `8 q , E; ?7 b# M- A* }% b! _6 {  m+ Y
6529802
7 ?) _9 x* R7 |, Q% ^% L+ W Assertion and memory leak after File --> Save As --> DXF
2 H6 v, {* p" y: y" _+ X
/ G: ?5 O4 l0 T- o; B" E6529842
  G, \; p2 N1 L6 ]: M" @- c$ I- P Internal hookup error while cloning assembly and cloned part fails to open 4 x1 i# U4 u* O( e
9 R  W. C& g3 j) ]: i
6529847
" J1 ~. f/ r+ Z View label is not correctly displayed for Detail View
! t' w+ j% s5 y" }3 W7 H' ^* M
3 d- x% F! l, q: I6529855
9 N$ D: t- g' y" U$ r TC9:TCIN: ugmgr_JRC_t1++ Unscanned node &7D565000 found after dependent scanning& ?$ P4 B& s6 i  s
3 q) E4 F5 h: G& Z6 [. I6529860+ i# M0 x% R* |1 G
TC9:TCIN: ugmgr_JRC_t2+++ Duplicate update occurs for cm part [24258]
8 ^0 P2 `8 ?7 ~3 {8 p + j  ?1 c+ d3 C, R, Q6 f
65298684 N$ x' L$ c1 A, ~4 ~9 D- d
TC9:TCIN: ugmgr_JRC_t2 odes differ : original value Linked_Feature3D"Linked Face1 G* I% Q; V6 C1 m. u' P% U
0 g7 ]7 i5 Q" R$ f' u$ o6529884
* i6 z3 H! X  P% e" [# i Regression:ComputedSize of InheritedDim changing onCreating PMIdim&Updating view1 S6 N5 d4 t7 X- G; u
8 d1 I' W3 {* o/ [65299800 H6 n. n# X; n/ L. {6 l+ Q- y1 o
Cavity mill causing internal error - P- ]1 }! p' |, x
9 r# N6 H4 p+ w; u
6530384
' i6 N7 }% U8 y- a, n; D- T1 Z) [ SLED: WCS origin created in wrong location
' R; f" @" W* j5 p* K : `; s3 `; r$ w8 Y' v5 W2 m  f6 n( v
6530462
0 D0 v( r8 r: ~; j* _" s1 z' D2 Q7 o [1] "AssemTest_OpenAssembly_isuzu" EXCEPTION: Class id 1 is invalid
- F( G: i4 N2 p0 c5 e; H0 `
4 q/ t6 K, y( l5 L6530474( Y+ R$ N# ^( V7 p% d' I
OM check world error after orient branch 2 T* T/ e2 b0 z5 K
0 B9 B  e" q. \8 l" I4 A  D
6530504
- A4 s- l2 F" s5 C! O Regression:Xhatch(NX6053) disappears after updating the drawing
& S  T0 j& m* p 1 I) R% O. A' o
6530537  E% v0 D5 r8 Y+ x& B
Some clips do not move after conversion - limited to single axis movement # `; d7 g. I* r1 B  R/ S
, o9 {( m- m* n4 l# |6530545* ]7 |% j. p, O- G4 P( ?" I$ m
Attempt to free already free memory in Storage Manager error while selecting m
  U: x. a& l+ M$ m! {7 M
& |9 s- y3 ^% I2 g' S$ x2 i6530554% S% n; J6 E8 G$ Y" N- @
Assertion when changing feature timestamp of linked face
6 l. C5 h+ i  o( Z: h; i
! s3 [6 ?5 N1 m% {$ b+ L65307017 w6 l! U1 @2 v$ Z: x% n
Editing of cutout feature blocked with Error message"Can't extract crv from edge
$ i1 _. ~2 z$ R5 o/ @
+ s' L- ^* |! B% ]  r6530749
+ ~. f8 G, E/ \9 R Selected_deselected arrays given to selection callback have only 1 object & s9 y+ t' k+ q2 a  A: l( C0 |
& f9 v" u" W( [5 i8 X6530765' n8 L) E+ g. z1 ]; }
Instanced or copied threadmill operations lose their position when generated
+ q) [: T+ l! r / I# C  ], D! c5 Q/ t- @4 S& @
6530775
1 d0 G5 }' E. ]7 ^# J Weld Point Regression from 7.5.4 phase 2 to phase 3
4 `' T2 B' C8 n$ v% o, X$ E  x, U 2 x. K% @3 g7 c4 g+ y
6531016
% ]) e4 n' j  Y0 B: y4 q- t: Y! m( f& |1 f Update Formboard gives message "Gaps in string or multiple loops"
; j. X" S& h. O! U0 S+ H% b
% ^8 Q% z, c+ r% i  W6531025# p( @& Z* N, T" E; s
Update formboard error when harness is in different folder than formboard part
0 W: K# [6 N. c% N; E
: a2 o( H( O/ e$ D; ~65310465 J1 J0 x) r6 R& ?5 j
Update formboard operation fails
9 P, n. \+ {  B
0 P0 ?. g" [* s5 r5 p. o6531069& h) W( p$ Z; s' g! R
Radial Bend option in Shape Segment gives incorrect results
; x3 [* O, |) L4 i# U* F( [ + f9 k$ z! n: N9 t% ?* V
6531214# g8 c7 {9 @- g" a0 i7 B7 `
[2] Drafting NX80_20.230: Autotest Failure: Drafting auto-tests are failing with8 H# k* L+ t# I, z- E
* l( \6 w9 X! d
6531229
0 n# p2 ?% A, _  _ [18] Drafting NX80_20.230: Autotest Failure: Drafting auto-tests are failing with
- f1 b) X5 {' K$ j; J% D' ?5 Q % _# g' N$ b3 w' |, M
6531290& P" w8 W3 W" x' K6 n. \0 {* @
[1] "jat_assy_move_p2p_cursor1" EXCEPTION: XML Comparison failed! g9 e# U0 c$ ?0 b
+ a$ M8 I6 h* x* s6531323- J! o" G$ V, e& y7 c( P# ^
[1] "jat_WAVE_CopyPaste_Reuse_Diffpart" EXCEPTION: XML Comparison failed
$ `* {$ R$ H+ f; i3 x' o
7 }( a; o9 e3 P) W6531333
' y2 N" a8 G$ r4 _8 f" |* l2 m [1] "uft_refsets_ja_tests" INTERNAL ERROR:Unexpected number of members in ref 0 V, p! J6 W" S1 n' d
+ B0 y- G3 X  R) C6 z0 U
6531347
& d' R3 k. x- Z* C5 }) w. d7 r When doing the runner,Appear Assertion failed+ D8 R% B4 K5 {
& s% D! X6 H4 x
6531351
; |% X0 j0 n/ |8 {7 z% I+ l  c9 k Curve-Analysis Graph does not take effect in assembly context , c3 a! k( B1 [' p
$ p- c% ^" {! Y/ Q1 B6531356
( S/ ^& n! H+ [4 H0 L6 p3 } SLED_80021 PM with trochoidal pattern gouges into part. 1 }& V3 m: l. o
4 K5 \; i7 J0 D+ g6531443
8 N7 }: I1 W' r" t$ }- r0 p; I 23 autotests are failing due to assertion in mating conversion autotest run
5 n# l! p8 r$ I* G& @) s5 D
1 E% c% m" x- P( g+ C5 v6531540
4 _3 k. ^" x! {0 d9 ?$ U Move Object dynamic mode for translate does not have dialog memory 0 I  j4 R. l9 R  [
: u9 y# y0 `5 t0 B' l3 I- K
65315857 b2 f  d% b4 p% w
Move Layer on PMI entities leaves behind invisible entities on move-from layer * Z. @" g6 H' N, k6 |6 N! B
- l1 y; u$ ?  K
6531752, r, P$ i, S( A& H+ Y. X( a; `
[14]Modeling ugnx80_21.384 Autotest Failures:Nodes differ : original value 97.03! T& g8 r7 l' N' s/ A3 L3 ~/ N; `
& Y7 d' R4 U4 O2 O$ ~4 V6531776
! v5 R, l+ w" c, d$ f% N* | Extrude with draft crashs NX
& n; q& ]9 b  ]3 o6 c2 c $ M# s/ |% s( u4 `, {: u
6531835
/ O* ^8 R$ O/ ` Curve not selectable in Curve Continuity
0 U# c' u& h" J: E; `9 n6 q4 [ 7 ~+ {9 r9 X$ G1 s( x2 D$ W  A
6532019
. L- Z0 V9 I, ]. w& X  `( u7 w Exssertion when edit wave linked face
6 v5 m$ q- ~3 h) m
6 x* w2 r. g. ?3 d5 x" s1 {6532052
2 }* a5 U9 V+ j. \7 G) ] Split duct does'nt get updated when its SR is edited , a* F! a2 z7 u0 h* j
; i1 F' i8 J4 s1 o6532309
* F" M0 U8 d( `. G: a( f9 b& T Retained angular dimension cannot be re-associated to the non-sketch curves
2 H) n9 R- l4 s( \, a6 h ( E) [1 E2 n2 B5 l4 ^5 ~, F* J" e
6532344# {: E4 l! w0 c( a
FeatureProcessBuilder GetTemplate returns wrong values
+ P3 _; b* k- J! F# `' I# g 3 V5 [9 ]% g2 F1 Q9 X7 \6 v
65324410 F6 u3 Y1 ^1 r: F- v* G
Internal Hookup error - Object does not exist selecting Submarine for export
* h  K# B+ f) j% f$ _0 k* Y. c 5 S! f/ [* {$ u3 Z7 m, v
65325879 I% ?$ C( V& d$ g  Q0 @1 D
.NET TrackingBuilder.Get() throws Signal 11 error # l! S2 |4 r# {4 Q
' Q: ?5 c2 Q0 S5 k, N9 D/ ?% q6532726
* }: R0 j$ E! Q1 x4 D' A5 p- H PS24.00.172 - NX7.5.2.5 MP3 Measure Bodies and Advanced Weight Management + G! s# g7 x) ^" h# V+ ~2 _
& b7 C/ }. j- M1 S
65327818 R+ \. b: O8 L" Q1 k8 y
NX 8.0.0.21  Curve Analysis de-selects sketch spline
: ^  `- `- `, y/ y8 n   L, d2 V- ^) L2 t. T
65328259 {/ t, M8 L( n) S6 X. f; O
Wrong value for leader stub start and end point is dumping in XML 1 M& p  U! h% {8 Z- {
3 O5 Q2 ?8 \' \( N  _6532843; X' R& M3 H8 W8 e/ ?4 v
Assertion failed when edit linked face
+ O& g% Y8 E: u
% L1 N3 X3 b9 I' X3 |* T0 F6532945" Q/ u, [( D3 t( O) c, a: l
Wrong position of Face Annotation (CGM) if origin is associated to segment end & C( W9 i/ }1 n1 j1 [( F9 E7 A  g
* U: E, f: o& d6 ^6533184
7 M% Z' E) Q" l6 G9 } Cannot delete a CSYS
; Z0 F1 `0 o2 t* M! e& ? 9 M% O5 L. k1 K" w; s* Y2 v
6533261% j5 N7 [$ d7 R  U# a
Dropping sync marker in wrong place will crash NX7 A( m9 `# N1 I6 N; Z
0 b( S" Z" Z5 _' \  p+ p& @6533307
- H! L8 M8 K: [, D6 ` 1]Modeling ugnx754_3 Autotest Failure:Nodes differ : original value 3814874.1896* R5 q. D% E6 G
7 W+ W0 s* r2 G, D, V+ d, }
6533321% G. t, m; E0 ]8 l0 k5 x
Lines and arcs are not constrained after conversion
3 l5 v4 X2 Q. Z" `1 \ 8 J6 g: [6 m9 e# |8 w
6533343
( m' `# O  D7 Y- M( m5 B3 O* i, Z8 `6 u Routing bends by OD ratio
7 M- P: W6 ^$ W- ?- B  e - Y  A$ \6 V& t8 C6 R/ K; ~3 }
6533406+ t; u; T5 l- s& Y; ~
Routing Stock failing with PK_ERROR_wrong_entity
( h" t7 }; F, H. U. d" e  D9 x ( R3 N; k2 z/ Z  a( T4 ^1 `+ Z  I
6533521/ y+ H$ v7 ]- \/ O: N0 P
Memory access violation when trying to generate
( l) x2 m7 Y5 z& L! X" q , y/ N# g. a; _+ L: \& ]
6533540
5 h1 c% e" K4 V$ [& ~: r Problems Importing Sim Entities in NX_TMG
+ b! H# v' f) w" h2 P* @& g( S( d) b , O) `$ a% {  R! H1 Q  ]
6533625, M( v' H. |$ L1 G6 H3 C) Z: U6 ]
REGRESSION - Part Specific- Crosshatch disappears after edit $ F, ]+ k' D7 _/ k3 [5 Z. `8 ]
7 [  a- @$ X' q( f4 n8 s* ]6533651" F3 q& K' i# n( O6 k( K
Internal error when try to cut_paste custom symbol created with SFS & dimension
( H5 C% Y3 ]' d, i
8 O3 N  `' b* G6533677
4 u/ b% i. b1 W% H1 u0 p Regression:OK & Apply buttons are active on removing CentMark&Exception in syslog
/ J. y, h9 d0 V5 C( q* u0 y" M* _ " w% h, ~" p" D. |; N; c
6533747
* @1 G; R" o9 |5 ? Regression :Move object gives Null tag error in expanded drafting view , D* z' {+ j( T4 \: p* w
6 g  l( y6 _, Y) k' A$ u- R
6533769
: p% F* V/ [, O0 e+ @" O Fonts inside the symbol are not maintained
! J% X, W, N1 ^
) Z' I, o* N' k: r# d3 S- E6 d65337789 R) ~( d! I1 o8 a
Tool query autotest differences between 32bit and 64bit
8 U1 X+ d# t$ O9 `1 Z  X2 r 4 \* O! P6 U7 B4 ]3 B8 K, J
6533781: l0 X1 }6 c/ T9 W' m
[1] Drafting NX80_21.235: Autotest Failure: Drafting auto-tests are failing with7 n) _5 t; ~3 R. _
" s: V5 |$ l* C% P7 q$ M9 G6533981, j: k2 V+ B4 u$ ?
Replace Component error when assy is opened Structure Only
! s" i) O0 [8 [7 e- A& Z
' [( f! y! |4 s. }% y6534229
/ ~# P. m: Q& v3 f! m) n TC_Linux import of a fem created on Windows will give filename errors " {6 m  b$ l  ?* S* f. d1 B! [
4 q: T" f9 w7 O7 _' x/ D' n
65342711 j5 [, y9 @2 M" l2 d% ^
TC - Importing with Auto Translate can produce unusable files
- M/ [1 x& s4 s) O" }   g$ C9 F5 a" k
65343408 H9 S  k: ~& q2 p9 q; h4 v
SLED_80021: error updating the end event in tool path editor
% U8 m1 P: J! @' B! s" i7 ~* O* B& C1 F# }
$ N* E6 b: L, Q0 H6534343, p. s: ]7 H6 _2 \# ?; C
'Preview' option not available when transforming operation
, s' S' N# U. Y4 k2 y% e* f
' a) L% p6 z, D& h1 i( \6534378
6 `# C- H1 W5 F% h4 S) v/ @3 E Lost the alignment of baseline dimension when it is copied
/ a7 Y# |4 J+ h, k( p ! ?& q/ s: `: J4 t) l; N* K* Q
65344404 l, s7 Y5 i8 B
SLEDNX8IP21:+++ Invalid trailer (-101058055) found in block &000007FFFFCBED10
: ]1 g4 W, U# a" Z- k, N / K$ y( U, s1 J9 v1 y; B
6534813
7 B$ o* m& q! {' ? ID moved to a view changes inherits viewscale
# g* E, ~5 N" w/ q* n
3 s+ s% u6 ^2 O) }- Q  H4 F6535041
( b& Z; b1 |: v5 [6 M7 L+ F Strip layout can not update scrap with added overlap_overcut automatically 1 r: _1 ]- a2 C5 n3 M
- A6 M  T5 C" S- k/ J6 Y8 Z: q
6535076
: o/ j# |+ }; W3 q- l9 F. A Cut and paste of unloaded components results in error recovery
0 J; i2 }4 q6 a: m2 n $ r& N6 D, p7 Q9 G
6535149
4 w$ a" {4 s) v. Q" D Refile only specifying one alltrep results in all altreps and UGMaster refiled % Y9 O: {9 X" W/ F/ x
5 N% h# o! r; B+ Q6535168" ?8 s. u( c% E
Sled: Missing face reference when edit profile_plate
5 s  S" v  n$ u
+ v# C& T8 s: a  }; q) B( k6535191
5 s" f5 z6 W6 L! x+ b2 z Check world error after Undo-Redo assign corner" G2 l; Z& {3 [+ H* E
, D, k4 p# H4 ~6 g# T
6535193
8 b9 l' G5 \3 |" i! Z% ? Regression against NX754IP0 Region boundary face gets incorrect display result
* N8 j1 T: x1 v/ v4 x
2 ?  g4 `2 _- h" O  l65352009 \6 D! O, Q* a( K% d
SLED:assertion fails when drag length handle back and forth , Y- J6 Q. A( t0 u! R. ?
+ G$ K& ]5 [, R# ]. \6535222
7 v; d  L# x6 ~  @9 L2 Z SLED_7544:Tag was not found message is displayed while editing the crosshatch
: ^$ P" v4 p% u
) }& d/ T! t; s- V: c- R65352577 e; t; K* |$ z4 d3 K6 C( |
Severe error while editing Bend angle ; y4 A+ [% I8 L3 E% }
  l% D/ Z3 n4 x0 U6 A4 Q/ T4 V2 U
6535331( {& @4 ~! O; n; c
Wrong result: the property of "NUMBER OF SHEETS WELDED" from translated weld poi! v3 b! ?9 a  Z
- X1 F/ p5 `* X4 i0 M7 @. I0 r+ x
6535334$ P& ^% n% y- k' V3 P0 U" ?$ s$ i
Wrong results after dragging the center marks extension lines
2 N4 E7 t  X5 v, d2 p9 n # r" _$ E6 X8 t6 m
6535360
8 S! @# ]3 `) _, X Current Issue:Check world fail & gives IE after converting Filler stock to
1 R4 T' T: S, [( ~2 J
& P8 \8 u. A  @4 x  E6535559( g2 @3 \7 A7 [
[1]Modeling ugnx754_4 Autotest Failures:Nodes differ : original value 0
0 Y  p6 O/ L/ b4 t% F   p+ s6 ?/ a8 [9 n  V9 c/ W8 R' B) x
6535571
% v3 _5 Q! a5 {( }" i) c, L [1]Modeling ugnx754_4 Autotest Failures:+++ OM check world failed - see log file* f0 J* }1 a: E" u2 c5 V
, ]' e) I5 g3 R+ H3 P; l6535753
+ M/ ^, M- A0 O. | SLED7.5.4.4 - Regression Internal Error on View Update - Hidden Line and Thread 0 M2 z% V7 e& ]. V2 u7 f
% h2 y4 ^! r- @! f1 n
6535758
7 f7 M, O: w  W  g+ s3 x$ K Internal error (memory access violation) during Subtract preview
+ W; L# e, t) W$ e0 |" P8 v   S0 I* M! B' g1 H$ X
6535763
) d4 v6 Z# p% c3 q7 a/ Y$ P Xform Proportional leaves some poles unchanged 2 w1 ]' _( L$ E- y+ k0 t
" n+ I4 L* ]8 |. P% Z! G
6535814
, ^, N* |0 o8 n Easy Spot weld layers are changed using Display Weld Csys
$ D; W  z. Z! [% j ) k% O- t1 I+ D" U: V, D
65358421 C) f2 L$ Q6 x9 G) `* c2 U
SLED_80021 -- problem with cutter display in TCMFG
3 Q8 b0 ]  U+ z; ^ * W+ ^7 c. w+ v/ g9 U
6535928; ^2 w0 @" O" L* X
Internal error when drag rectangle to select face and curve
& U, r: T0 ~3 d
0 `7 P5 B" q# e6 c6535936
( M$ I5 o7 i2 x! v" H# G: W NC: Internal error occur while changing hole type from KF
" I: _: b' j' a 3 S+ \$ W& z* x' U! y
6535950
* p; l' a/ [( n* w7 k2 l Show Current Feature failed before expand the feature group ) l2 [6 g) r6 ]
0 ?$ z- I$ L  ^0 w: V- z7 n; Y6535962
' H0 C) t. C, L" g; O3 x Assertion failed occurs in this special part% _# i( o& }3 G8 \/ x8 k/ N
! k0 s% K0 r& S! q+ \  |- [, e65361000 l+ b  c0 k: W0 e
range is out put in advanced clsf even if it is not defined
# m2 s. N" U7 E
# }& P! {$ c& h6536156) F6 a. R/ a. d- C! @' W
[1]Architecture ugnx754_4 Autotest Failure:Nodes differ : original value false , t2 z' j+ j) v2 f/ c
* I/ H4 e5 I- k3 @) X3 m; {. N$ K
6536165+ C% N) d  R! w& U4 q# p( b) D
[1]Architecture ugnx754_4 Autotest Failure:Nodes differ : original value ; j( U; ?' L0 J6 {7 {5 ]
& d2 T% O) t; w7 B6536202
- G8 H" W, k! z" N( W8 T REGRESSION: Distance between Scale and View Label increases after hitting Apply5 ]* F% R: _5 C4 N. o. y
/ E6 s. Y9 b' L9 i# k$ w0 V6536371
# F/ x/ [  B! h5 t( S: b+ l- B Stock Browser does not allow selection of segments with centerline stock " ?3 ]- N. X& g$ r5 i. {9 q3 o
7 H. h% B: c8 Q; ]7 h) i& ^6536721, I; Z) D  i0 a; ~
NX754,4 FPV:no balloon message for icon-hide on the UI of 'group manager' # x; w1 `& t# X2 x2 K* \8 c+ d
+ ~* g/ ?6 O9 j. c' u65367651 G1 m8 ?4 u) C  a1 g4 i0 h
Routing Reuse Search dialog can return zero parts
0 w. s: O, i( Q# E & M4 ]3 \$ S6 s) q' K* w4 v
6536779  f) v& o" \1 _# p2 m! F
Turning holder + insert on layer 2 _3 will give wrong result (no OOTB WCS-MCS)
7 e+ E; I0 w+ t7 k1 x2 _3 ]
0 `! e& I( l8 T4 r* m$ ]5 g6536783" Z6 v) u" _0 X6 \3 N  R
SLED: Assertion failed when delete old distribution feature $ V4 f" y& f& ]9 a" H
$ h8 [3 N% H  j7 h" ]  Z
6536805! |0 n7 o3 A  P$ }/ Q& n9 G
NX 754ip4FPV: Internal error while setting mesh Attribute overrides in this w_f
, c  |6 h7 p, O  w2 k! o# [
* q! @3 k2 B9 O- P% z- a6536813
3 S* {7 e  E* N. O+ n Weld symbol doesn't behave properly for drafting standard with template files ' E" }! f/ A2 D: L* R
2 W6 h$ y+ j( i1 {" b0 Q! Z6536851, \% H4 w2 Y4 ~* ^- M+ g0 z# l
Internal error after cancelling the dialog with delay update ON 9 f. Q2 S) a/ q; k7 ^
5 ?( Q. w# j( ^$ P
65368988 q; e4 ]1 e1 \& ]% m# k1 u4 A
Assertion while Open by proximity + s7 F$ a4 I, |" ^! r2 k: k
5 _% K5 a5 n) j& l
6536961
3 S2 i0 }" [. p4 g# M$ z, a9 A Original body extracted isn't hidden when user gets partial results
2 h7 k9 B) Z" O6 Y. r1 X" F  X
/ k7 z: W/ C1 Q: a- T1 q# j, J3 P6537172( n8 y" M3 `9 i1 J
SLED_7544 -- problem in component part of machine tool
, J6 B, s- x; S$ n
) I% L: z/ N' h/ j3 ]8 Z$ I( i/ z5 s6537451
3 D8 W/ k, k, y0 E2 r OM error, out of memory when doing variable offset5 h+ N+ X6 ~" p$ e
+ M  D. z& R2 u% ^: x4 @6537454
+ b. l; \7 i+ O5 G An unexpected dialog occurs when run Mold CSYS
/ Y; z+ T7 g8 [/ }, c$ q ( L% P/ C* k# F' n& M
6537460* i6 {+ g5 g4 c$ c% H; z5 l9 ?
NXOpen - report shortest tool - coding returns error
6 u1 x  V% M& O0 v7 v. b . x. R/ Y) ]5 n
6537519
0 {  F/ T2 u4 d2 s! w Create linear path after stock fold gives internal error " |9 }8 f. Y3 [5 v& _
/ `" I) b: o( x3 k! N; ^! e" `9 t6537543
& L' q# q1 q4 ]7 `0 |  @$ u0 X Assertion wile inserting view
$ T. W' t6 v. Y/ N . \4 A$ k( g' o/ t
6537545
4 L* h( x  a7 Y9 I! w, w NC: Internal error while Close--> Modified from ANT after replace and ref set % m% G$ _. a1 N$ \0 `  X
1 ^, o5 A: C" g8 Z0 J1 e, O5 L6537553
% l$ g; t$ u* `% u2 Z2 E) x Regarding Merge Cavities,Need to add one option in NX8, "Link Only",
+ B" l" _& b8 W/ v- i3 b0 j  C & N8 F. ]: z; I
6537571
# X% k" D" f- V0 A! i NX hangs after doing MB3 in Material in parts palette on LINUX only & B0 S$ p8 q! R5 a( r. r2 z
, U4 Y5 T' D! s+ C2 C
6537589
: w% V+ I/ y3 z) Q' j' M [2] ugmgr_JRC_t3,t3b autotest are failing due to Nodes are missing in log xml
/ H& L- Z1 `( ]- [! C
' H: o. Q) D# v9 B5 [* f6537604
; Q, k  ^+ e  U4 ?1 D; Z0 `+ z0 n4 i( ? check world the die face feature ,it will appear error
" Y* a9 W4 G3 ^& Z 2 E' [6 [) V! W& N! M
65376623 K6 N0 N  U! q0 h! h8 H" s7 u
Hole Table fails to display when created
4 U% A$ I& ?: G. q* T 1 r: K* ^. q/ I3 j: m  W
6537663
; J* L+ v% M; T! u FPV: Replace Stock gives error "Bad size (-1987996672) for allocation request" 3 C# y" ?1 q# ]
4 @- j+ V# S+ U0 S( e
6537683, r% N$ N7 o* j/ p' ]1 i: n  V$ h; g: h
Internal error while heal path while selecting component instead of port * g0 S% g. W5 t
# Y0 L* \2 N3 p! T, H* d6537705
3 a, W, @+ R" L, `. c/ P Simulation does not display the correct arc motion (no machine) 5 [3 s* `3 j$ l; D
' z  R% c' A* J+ _  M) Z% P  ^3 v
6537744. Z) {) @2 N' R! m
Moving from 7.5.2 to 7.5.3 causes drawing problems
# r; Z0 M6 j) E2 I5 t; F
& _/ G1 N$ e+ R" V( ^. u6 ?# }6537767# ]/ J0 b; r! r0 ]# V% _) d
Autotest ugmgr_ANT_t3 is failing in plmxml comparison
3 j4 o! T8 S$ y* ?2 Q. M+ o. s + |' i" a+ V5 x  U
6537985
6 B* E3 M/ I/ A Assertion regarding icon name associated with KF-feature - M8 z  k5 E  g
1 _5 x$ ~( r$ e: r( Z$ m  `" k65380093 l0 K5 T5 ?. _5 K9 I- }: \1 \
Sync Links does not display old and New Curved Direction Change 4 x+ L: x* L1 x$ q: w7 M. d7 J
) ^# ^" [# O, |1 P$ [  M
65380544 m3 [$ K6 N2 w& c+ {7 B  w5 j" L
If altrep dataset is missing, message not correct in NX
; c& j2 ^& u2 U& U$ N 6 o; X! \7 m3 e
6538175
. s& e; F5 \  L5 t5 |& f" Q REGRESSION: Dimension with limits & fits tolerance given is getting retained - B4 q9 u+ q1 x$ w( f& d. u
4 Q/ X) j. B1 _9 d9 f( n  E+ s6538193
$ I/ X' w2 @2 v; G  a2 }5 w* R Excpetion Error message while manual edit of dimension in PMI modeling ( N) F9 q; A9 I/ k$ L1 ^
) M( b6 ~+ t* E/ Q1 s; P9 @6538210% ^+ N0 Q, G' S# v/ e: z. S
SLED 7.5.4.4 : OM check world failed - Objects have been left logged ; R/ @1 l+ v3 r) F) I
2 K# F, m# m; h65382154 K* L  ]" _" N9 C# b9 v$ n' z
SLED 7.5.4.4: General fault exception at CLNAV_interf_node
# M0 t2 G. L5 p7 O 9 |9 L5 ~7 p1 l% A% V$ K9 e, S  y
6538243+ d7 \5 u8 D5 O; ], ]" l  n) H
Check world failed after edit a failed AFB! @4 q0 A( h% k4 t  H4 J; i
3 a5 s; N. U, W! g$ n* G: v6538245: v1 J  J* L8 t3 Q  _  y2 Y2 g
On moving ordinate Dimensions and performing undo and redo is not working
# K! A2 k6 z& e- D6 O" i* U' C 2 B* w( I1 m# x4 v
65382557 ^% c6 k6 ?' `- f4 v+ z
Assertion while creating motion envelope in sequencing - x0 C+ r( {7 M0 J& f" @8 g, Q
8 s' F4 n8 \; C4 g: J4 N  V6538267
: e* S8 N8 E! ?9 ^8 N/ J Internal error while editing point on curve 6 D0 N* s/ ^8 U# ]& c1 \8 X+ T
4 [6 j' r! s: Z2 g; X# M" h1 B
6538321
% E+ F1 a0 d$ { Text Island Margin option in Fill_Hatch preferences doesn't update correctly 4 e( b7 B. E) z- O# f2 ~
  d+ T0 `* ]- l  i
6538323
0 l  y) l" p1 I6 ?# h/ i# d SLED 7.5.4.4 EXCEPTION Error code 3580012 Drawing_DrawingSheetBuilder.cxx
  P" d* q, s6 o0 |9 k- x 1 a% P9 A2 q3 O  C9 N
6538422  V" [. M+ g! ?: [1 [
[1]Modeling ugnx754_4.430 Autotest Failure:Nodes differ : original value 5
( u4 @3 }" S5 Z: ^$ z
. }7 B3 E2 g; e: A8 r/ g5 B$ d# d4 r6538744
1 L; G/ V$ K/ r& Y1 u; { Adding standard parts in NX 7.5 MW using "point" for location resets the dialog " e3 j' Z: d/ Y& G
/ E/ V' r1 i2 u3 l, a6538884
$ S" l1 s3 ?! M Null tag error converting to history free for Edge Blend with embedded geometry   g8 e' L2 F9 V. m- o( S8 E' {- D, `& ?
2 d% H- X2 F5 ~* k" u
6538893
5 w; E* `, ]/ e, T( M After changing routing Specification an "Internal Error" is raised
% o8 h# h6 y. O; l- o7 Q/ k 1 V, s/ z' w8 j; a
6538905
' e! X3 w( U# b- r Internal Error:Memory access violation occurs in B Pillar Construction % p; P/ k* D1 A+ D' Z& {
: p/ c$ b" T2 e6538910, g/ o2 {& u* @: P
Regression:InternalError on selecting ExpressionRow &closing Expression dialog . x; C. e$ p9 H1 w
$ q( v& g; p6 k' d+ |! T
65389623 p2 X2 S- O' c
Regression: unable to generate curvature graph of two curves at the same time. " g" o3 p8 }% k7 A/ Q
1 ^# S1 x8 j: V5 T. R$ c8 k& ]4 t65389778 o  S+ A& E4 H2 N- e3 N
Regression: Unable to do any operation in NX before exit excel after using graph
/ R3 G" Y; [. C6 p! {; U( ^" h* C/ i
" n, j) C/ G+ i9 C* A$ {6538991
" H" ]0 s  r- [. q! y" _7 ~4 n- ? Assertion fail and alert msg display when rectangular select multiple components 2 D; C( Y( N) C( h. ?
" u) V( W2 X+ a' [
6539034
* E4 v. p0 m' G9 t8 \3 G4 j/ m8 ` Regression:EditViewLabel and select Text above stub,We can see the stub for Note( C2 [- O+ x: s1 s" ]- E7 U' B# T
$ B" A5 k( F* r, X7 [5 d- c6539035
0 ^- x( h: I  T( X, X% Q Memory leak after editing Linked Body 9 }) }! c6 q( T1 t, J. k4 i
: X' w  |1 U4 b' s8 G0 }
65390576 o- Q) c" Z( O9 X- [
Internal error while assigning Alternate ID ! L+ h9 o3 E' \  m! T7 J6 |0 X" r
  [8 A4 m& W+ W% L
6539100
) C4 e6 c5 a) U2 f: t NC: Assertion followed by Exception while changing timestamp of wave linked
  G/ q; O, t# w5 H$ y; U+ o2 ~1 K 5 ]9 T( y1 ?, ~6 C: a8 R: k
6539109" U( c5 x7 U, f( m
Internal error after UNDO;Check world for Parallel offset path
+ I, o6 `. B7 R+ W/ J; K2 o
6 q; n# H' v: `9 |! ^8 M6539138
7 R  j2 ^% j4 q+ W1 X9 K  ~ Change in orientation vector for plate gives missing reference ! Z9 T. x* |+ N$ j' |
) [; K4 k* h- N* a3 p/ ~0 Q4 y
6539323
  k3 I: [7 g3 r1 R) F, D Crash repairing a tool: out and in a pocket
' C1 y4 e4 @4 u$ v% D7 v# c: x
* b0 z3 ]' H+ C( Q0 t6539618$ D8 q" F9 E$ |9 z
Error raise when selecting a library tool in TC managed mode ( \9 w$ ?# j3 C5 ]" ?( W7 P
' F  g- d! n( K, Y, f6539643! n2 m' q/ a5 l2 O, U- X2 v
IE when distribute the trimmed profiles in the part 5 m) [; s6 Q$ j* F( c/ L
2 W, q& j; Y5 F) x. w% n5 a/ k6539701
+ w# j0 \9 M5 @, G- H Global Deformation does not honor approximation tolerances tighter than default3 K2 q' k# s$ Z) I4 j+ K0 \
; q( x; ^* x. b; y3 {5 q
6539707; B% g4 E5 z1 U
Contour Area operation with 'Boundary' drive method gouges into the part badly
. v5 d- ]& ~9 w2 m 5 F7 Q; a9 b" Q- L- |
6539716
9 b3 ?3 R7 ~  W0 R' ?: }% m" L %ui_comp_layer_settings cannot not work on NX 7.5.4 ; c& N! B) i1 k& k% v) n$ r/ R
5 U9 V# D* p3 P+ D
6539722
& h& s6 u" L5 w( N+ { Missing face reference if edit profile and change size
+ Z8 L, l; ?( I. t0 V/ r( g( O ( E+ W. N3 L% e' F. x) X6 t
6539789; u4 D. |% K, f; n- ?
Flowcut toolpath regressed and introduces new gouges in NX80021 ) p: W: G4 Q0 i# x5 ^$ v2 J
# J& N5 a: n. C8 X! d( s" _! U. v6539792" C" U7 w0 K7 Y8 }& `0 i
Internal error while using the functionality copy_paste
1 |, @, N- Z4 V8 c( A: g# C, P- ?
% v2 \' l) B% a. @0 K6539852
3 q0 \* ~! L4 T+ X1 o$ Z NX crash while specify stock in c= reate linear path dialog on Linux platform - J* _; Z) S8 C8 g. Q9 ^% M7 I! l
7 y4 b( _% S: F; v- l
65398745 A( ^# R4 M  Y6 `# t1 w5 |
The standard part ACTION "REFER" not work from NX 7.5 6 m2 t0 |. K' @
. E' m1 T" X5 e& F0 F6 p# g2 t  }6540271
2 @) ?6 y2 B" o8 G  Y' ]+ t* P* v Reset point constructor during import set tag error
6 y  k6 D/ t4 R0 A" b
5 ]$ T( z+ M  \- ^- Z5 r7 F; Z$ u65402974 `6 W) p- i. k, a6 Z9 G
Entering a name with a hyphen in it raises an internal error & ~  K0 t4 w: n3 d
( f* a2 l& r3 V& m5 K8 _% u
6540344
& v) r. s- C, t) E SLED: Internal error while ask datum for information5 l, a7 @% m4 n
! z; j- [; j4 D. M1 N5 q6540433
, g- V. ]$ O5 y  S7 K" s. }+ R+ D Hole mill tool path automatically generated is much large the real hole ( P9 l& O5 l6 F8 C
* }$ ^8 S* O: l3 d# A" J/ L6540479) E. I) [! q& I/ t' {; }1 b
Align to Dimension Line toggle should not be available in Origin block + m" J( t* s# D( ?: s
4 \4 C: a! V! d) b7 Z+ }6 X$ e
6540537
* F" O! Z; D* R. q$ s$ w( O Error while converting rectangular SR with fold to SAC # C! V6 D4 Z5 I1 _5 n
. [# A; V+ H; g6 ]6 K3 a3 |
6540730: T4 O# B" n! D& H7 Q, [; G
Drafting Parallel dim (with measurement direction) getting retained on placing 4 U$ t# B+ t/ n. W
9 T+ H. D' _- x6 J8 U- i' l2 M65410647 `: A8 Z: A3 h- B$ R- E+ g- S
Crash with ISV gouge checker for sim10
" L% x; Y" j7 H. o
. {" T9 [7 h# P# r+ o5 l6541221
& Z+ b0 D0 Q# i Error when new part in NX_Manager mode with Validation gadget active
5 u0 N7 s6 }  I* t7 a2 b
6 O& y: a5 y: M; U8 h7 q6541230# E8 E! s( k, G1 p6 z
Development severe error occurs after re-specify reference face
7 b8 v: c7 I* n7 |5 y# y3 h; m $ }4 z) g+ l" t$ X( B8 M- j
6541357, F8 T# G4 K( F- ?5 n' Y
Internal error if invoking one test node which contains too much information
/ G$ j( l* H6 d! x
. P. a- L+ U) c# T0 Y6541442
4 z' z, E5 d$ n. f# t" f. z Internal error while importing part using ug_import utility
7 f% X9 w6 E# T2 F7 V: D 2 j8 \( \( f' c% I) Q
65415803 X; _& h/ z  Z9 d8 z3 S  ~
Export a step214 file from displayed part that has never been saved fails ' w5 X, E* A# D
  e* f/ Q* D+ ]0 e8 h* @
6541608$ J5 v, C; E. n7 p2 d8 ]
Constraint network not solved during move in Sequencing
! P# y2 w: H4 N( q1 m) J
1 l7 h6 Z! A' l% B' e) f$ U6541658
8 ?3 z. }$ i: z2 z9 E% p& D Formboard creation results in "Formboard geometry not fully connected" error 3 @6 m4 D; e2 A5 Z* ]1 W& l2 B/ S
! B7 N: O1 P8 O( ~% {: G6541829
' |8 t4 s9 K! j! E Export a step203 file from displayed part that has never been saved fails . f6 X9 H5 i, R% }
# C1 ~9 c% I$ L! g- R7 J
6541909
# j9 y% i' m, }$ Q9 [3 e3 l Editing an instance array allows change to hole location via radius value
: `0 \1 s: t. ^  u; O. p / I8 E( w+ n& C
6541928
3 J# H% T+ {+ T$ F: P% F #NAME?4 S. V' j: T% h( x: |- l$ }
- E0 @( u! V# [( @( C9 f3 d" I6541948' U. D6 q" i8 ~7 V* k3 q9 _
Cursor select backface culling in status line does not match identify function . [: v+ h3 x% L- \
3 D8 U' I* D0 z2 B6541961
& D3 W' y: |! F0 g2 c- ]6 {+ B Exiting mouse dynamics mode does return PSCM to global selection modus ; ?; Q8 P9 l: Y% k/ r
, l) l# k6 @  Z
6541972( b# Z" F9 T  y! T
Edit linked region feature, the boundary faces can be wrongly 0
5 U5 q1 f# Q$ o
  t5 o) V8 H. U0 q6542013
7 B+ l/ G9 T& } Traverse Interior Edges and User Tangent Edge Angle can not work 9 p# X. z/ d% E* I. |
: o4 Y/ X, c. K) X/ z% t) N) a
65420276 @0 c: e( ]/ C, z; U5 h- j1 J' p
Regression:Not able to select chain dimensions as a set in Design in Context , P" \$ G  ~' M# @4 e* ~- f
6 d. V; Z8 ~  [+ O6542145
& o* I' j8 V8 f2 A/ A" y; N4 R Regression: Internal Error Occur while Copy & paste the hole in Intrapart
9 u1 h; A; I# f; J( T# y9 g0 v
1 |+ m& H3 n: E; ?' C3 Q4 H6542173
2 F+ ~: c# Q  r+ m1 W FPV7544_Assertion while copy paste & playing motion in Assembly Sequence & @3 [6 c* Y6 k* h+ T$ w
9 z+ h2 z2 ]6 l* i1 Q65422598 l/ B; G4 ~( ~: l% p# b; C
Copy_pasting DirectedParallel dim,pastes dimension without measurement direction
8 o( @* b: F9 ]8 i $ F1 j# ^  E0 i; l
6542480
; y) f+ r. F0 q- g/ Q) X& D Sequence of features on output statement is incorrect
! Y2 ]! u( r" l# |
# ~& i. N% n9 Q$ R& O7 ?6542493
' D, B' g  }% g! T Flip formboard component - wrong results flips surrounding comps 2 c. W" e1 s0 u" G4 l
6 m3 b: q+ S- o7 f7 e6542498
' \; s$ q" n& h6 X7 @$ X( J Non-working "review" button on flip formboard component dialog 9 J8 J- U0 I8 e2 I/ I: C( F) l
1 q# @6 ?- R/ \8 F9 v6542581) v# H' s0 T+ @; i" K2 x( ]6 L  {- _/ y
Inspection crashes after exiting to Gateway and reentering
3 I/ }$ A% H8 M, q5 R0 t . c* x9 `/ x8 q# J4 z# m1 H/ M0 ?
6542706
- P- |! ~# @3 D6 k' v& e Wrong display of weld symbol after changing it's lettering angle
3 x& B" B) K3 l" g5 C: m. I6 k1 R. e
" k8 [* k" L, A6542721
( ^2 k; {6 I/ ~2 o Weld symbol is not getting updated after changing its lettering angle , K% I4 Y0 J# A5 O# |
4 }: h4 p5 u* J# P9 n
6542861
6 H) d& S  R# {6 h Cavity Mill gouges part
& C7 X$ M5 k, \$ ]( j7 O. E% r; E$ i ; e1 ?% b# Y- D( j+ C
6542904
# O$ T  e  N$ l3 b* p. g- p4 f. M% U Internal error opening Standard Part Library interface
  Q* N. r# {9 i1 L: f  g6 K  d & D  \0 f: A2 F5 [
65429682 }: v$ U3 _9 ^5 |  ^2 Z
NX hung _bad performance when use move object
" J' ~% H4 |2 O( W
3 h3 k- {1 l2 Z+ M! c6 A1 x9 _6542974
( Q$ u3 S9 F! }: T& l Mazda suite: Internal error happens when generating an zl profile op 7 R, K: L1 Z# ~7 R5 O8 e2 v" H& Y' r
7 K; _) S4 {) h* u5 N8 Z& H6543015
. y5 p1 W1 k6 j  G5 p7 L# c' ] Regression: "Internal error" & flat pattern fail to create on Linux
/ @1 k, V2 x! l  c$ J0 W; K
- H& i! l: \" g( Z# f$ W6543025
  S6 r  F6 V0 y; v  q REGRESSION:Cannot edit default arrowhead selection for all annotation leader types
( w( F( n) b4 ]! T1 A( y+ Q
* U* V7 `: B$ i1 l/ d65430756 X% J* d7 m2 ?
Unending assertions hovering mouse in UI after "Make Unique" operation
6 R( L' z5 G# Q) s. ~) V
* u6 |/ w& ^! I+ @$ W. o- ?8 \+ m6543346. I( e- A' Y( `& D7 t3 ?
Can not run any translator from GPDL
* [0 H; l2 w6 @: I9 u ! S8 t6 f1 ]* N8 F7 f5 y2 J  {6 X
65436209 V' x- e& h, q' D7 V4 K9 i
FSC-surface toolpath generation regresses more than 50% ! @# W8 J0 p' M) Y, B( i; m
3 ?- B3 |$ E' ]1 [4 n0 ^, d5 d
6543677
# ^) N' L% X; l( c: K7 N There is a error after check world the "develop trim line" feature
7 `$ P$ |- b' J& S 8 ?, P, D5 \3 D6 |6 K) M& L0 D1 D- `
6544012$ H8 G$ S4 v2 U/ [" }6 f
NX Part Saved in Drafting Mode produces no JT solids
  q0 s& R" S' i. ]' I : o) y% I% w, e1 {- _6 L- R$ t
6544131
" @) r( X% B7 y7 V9 [; m C axis values are output as 360 deg instead of 0 deg
" P8 Y+ K" d# n  G
1 e$ G+ r! j( w* A3 o6544419
8 I( Q0 E. p- \/ d7 @9 W In Copy_paste, wrong Original Parent shown of 'offset in face' feature ) Q$ n! x& i7 J+ Q: b
  I9 d2 ^' m3 k/ H  J+ z) s5 Y6544463. n6 V/ B/ ?/ N
Regression: Angular Dimension is not correct 1 f0 A/ r, u' w* A
1 y5 k7 V2 `) R( H' v; k8 k3 I( R+ B6544486
5 A6 Z: k6 a0 v6 M The value of Retained Weld Color cannot be changed in Weld Preferences , y+ B. Q! s8 n7 k( m
9 ^$ T2 B" r6 t) O, C6544503
5 k& g) [8 ~4 f2 j& C5 m; S Incorrect Oect for this operation error in cooling standard part + P/ E! x0 J. j% D: ^# S; n
( t/ {, i* n) l6 W6 n: g' R6544556
- z2 ^* {8 M+ i; e1 j ug_clone to export drawings gives incorrect results
2 Y. u& N/ E$ `9 t1 Q4 K
& O4 [2 k. L5 k6544596
1 g- A+ r4 t( k Internal error: memory access violation
$ ^! t% ~7 W. g% r# B* D, r: q3 S
4 o8 {5 ^" H7 j) _  K* t6544728
' M  B2 z9 T- u$ Y6 ^! y1 F( P$ w Offset Curve dialog does not exit on hitting OK and goes crazy on Finish Sketch 7 ?( e* p/ H3 J
, d+ ]- J; q$ L; e3 x65447333 {! R7 ], C: ?1 m# x
Clone export warningmessage "Input string too long
5 Z, o* A  j' j 4 ^' {/ m% }2 p$ A4 K
6544796
0 X  f- p- ~5 W' R Assertions, exception and access violation in copy component as with multi revs ) U% e$ X  V. _  m7 i" s. _
% j" k2 B- M/ |- ]8 z! a
6544849# O; \$ P) L1 R% _3 Y% ~
Top and bottom display and the identify command
+ f  P7 W* b+ ~: e0 l 2 j5 B# n4 ?9 L# `* M
6544998
- e9 `! t5 w3 X Unable to update section view with a dimension present
4 O, f, t1 M* W8 W3 _: V1 X
( e* ]1 |; s- k0 z; G! J$ c65451358 D& U+ A+ d/ V8 R: y6 A; H
Assertion error occur when click undo in Edit During Update dialog 7 c+ [2 Z3 V8 N$ j+ V
  J8 J& M0 K, I, `1 p( u& i
6545169
+ V/ B0 U2 V$ X) ^5 w, k, ^0 H( r& q; y The UI was for face selection was not the same beofre and after sketching 5 r4 J7 R" T' p  I; ]- @
. v( z+ K7 f  U, y6545225
% X3 e4 z9 r. D; l Keyword will be shown in Check-Mate info view dialog
7 o  j) K% `1 T  ], J 6 _3 |/ H/ r. T8 }* j% O
6545261  o$ \1 Q% I5 ~! m1 G
Internal error when run UAF checker if part has measurement feature with check ! F% C5 ^5 E/ A8 |
. B3 Z& s( V+ A. v# C( K. C
65452706 ^# P  [1 V( f, W
Invalid class id while using General Relinker after including non-broken links3 X  O+ y- ]. G
5 P/ m# Q- s& L2 Y$ U
6545455
7 c9 T1 ~) e0 Y& p) h* T Post-process of control ignores current pcs and creates incorrect DMIS * z" d% r' e# Q8 g6 O4 h
( V/ I, l; B; C2 c
65454781 C! E3 h0 N# K, o: [
NX 5.0.3 files don't open in NX 7.5.3 9 B. J# q/ F, y* j( q- D
% _1 p% B8 {! t6 z
 楼主| 发表于 2011-12-19 20:32 | 显示全部楼层
6545566
, a" L2 y# ~( h" g! c) u+ Y* |1 `* } Can't create validation check form in TcAE8 from NX 7.5.2 : h- w. J+ [9 U; X; m
1 n% n1 m! t# E  }- R0 M6545893
; J* x/ g5 K6 e+ g: ?2 D PMI note cannot be stacked with a dimension associated to PMI 3D centerline
3 D6 j( L4 i, ~8 _ : n7 |  }( L0 B4 Z/ L& o
6545936
) W( \. _% K( ?$ z/ t [2]"jat_constraints_between_two_points" Runtime error
1 g- X7 B3 x: m. @! n/ { 9 E$ Z$ E7 k( Y0 f& ~
6545952! J3 ?0 U; ~3 Q. k9 r6 @
Assertion during constraint conversion: !ComposPartOccIsDirectlyFixed(to)
! v+ F) W. ?3 M  U; b9 h9 f' O & Z' o8 W2 s+ j/ w. v( j; w- Z! m0 j
6546036
. V5 D' {; v: z( G5 {# Q: R" ~7 W- i Linux specific internal error on double clicking the Work node in Part Module ' M8 r: D& l9 u5 t! G
- K! M! u' B! l# i  J0 T
65460561 i1 D7 ]" Z' _
Assertion about missing undo mark on loading office layout assembly - }  V3 V, C/ z6 L' r7 g6 p+ l$ A+ s
4 _6 j' B% }- A2 X5 F6546159
3 h0 F( {) E' ~, C$ p% j Split duct doesn't update correctly in Design-In-Context mode
5 k$ m( L/ B+ h& H6 `- j+ a
* m( j& X1 l% W5 q& W% W$ m6546238
( Q7 l0 q2 r# s% J. m+ H Cavity mill operation has very small cut area
3 n, x+ m1 t2 @ $ H5 k- A, N. M/ \
65464340 z9 c1 w2 }, B7 Q! @) w
[1] ugmgr_CL= N_PR1 A tag was passed belonging to an object that could not be fou) \% v/ V5 i6 I- r: Q* E3 X
  X; I+ i" ^& D6546493& l4 ?& `: u/ k8 @2 `. E2 V+ Y
SLED: Changing Height and Width in Graph Options doesn't affect output
9 }+ A# ~0 O5 C ! {# W5 u* ]; ^8 R- e
6546665
: H3 o# u0 m; _+ U3 C: H+ {2 Z REGRESSION: Dragging the circle from the path of bolt circle centerline gives error
* t/ C0 Q+ V/ g# T* X
+ H0 K# ]6 k: t! S9 v7 \6546717, W- D. ]  Z, g, N3 Y
OM check error comes when selecting solid body in "Section in View"$ m: A* \9 `8 a; D5 ?' I4 H( S
1 T* V6 }6 T3 |. v3 t/ B* ~6546723
0 g- I5 X* K+ j/ k Standard part isn't show, when it's parent is hidden and Position is REPOSITION ) A; g2 y3 B5 g* m0 ?$ U) c* p+ l
1 k$ C+ T  t; N' ?* a2 D
6546736
1 I; f8 }3 }  M- K* c9 M Show Shortcut is displayed and no transition type exists 2 h: ?* b7 a, w8 o. i$ }
. S/ w1 |6 k  h3 z, x
6546755
) I4 [' D. `) r) A' Z An assertion has fired when select die shoe feature 2 O6 @9 [( Y5 D
( I3 y2 Y$ J/ D: `( t' y
6546774
& \# J9 k- G6 g [7] Drafting NX80_23: Autotest Failure: Drafting auto-tests are failing with XML( L9 w3 S; R! @+ G
7 K$ E) K; ~) p; J6546788
9 G( W2 ?! ]9 q2 s Styled Blend: Input Faces Layer Change & J1 ]0 Z! h' B) w. C# S. ]( h2 H
+ X  g4 D5 V1 R7 i6 B0 b/ W
6546918
! h& ^, j$ d* t; w Problem with part cleanup of constraint to promoted geometry ' \+ o+ `4 ~( z) B( u
; {- f' b2 W0 ]" M; d: i4 H6547204
9 w: b9 V7 |# Y* d, ` Cannot Save NX 7.5 Part in GM Teamcenter (checkmate) 6 F  k- F/ b) A2 D2 r5 P
  N* n0 f4 R: L$ Q, O6547295
' X3 I$ C0 p# l7 ]1 u4 r UF_SKET_create_dimensional_constraint creates incorrect dimensions , U7 U: L9 L' E. h8 j
$ N  S+ z4 R. E! L$ V
6547318
) l" N# T& E, K' R3 z2 G) w Adding pax file attribute <Libref> 201<_Libref> dissables template_part_planner; j* c3 ?7 O8 e
# `! f! n/ W8 w6 N! u- H: H9 _
6547321% W9 C$ x0 A2 C4 l: [5 I; q
Problem obtaining interpolated vector using API
, V1 j; ~" k$ j6 P6 l7 x
+ k% u# h6 V  s7 W65473510 r$ R; j; g& o
Cannot migrate ideas assembly
8 W1 d# P2 Q9 U. n& w . X. K2 ?$ K2 Y  _& Y
6547384
' C1 [$ F- t; u) T Unable to insert a UDF , r, ~" n; C9 c/ F) Y' B, T1 i
) s" b8 h4 G. W+ F& a4 k- g" q' I
65474730 u7 |% G) t4 [' C0 x* A! f4 U) l- b7 `
Regression, PDW motion simulation can not define slider
* |+ ^% U# s' i6 }! t: U+ n 0 l# T# D7 h4 s$ O! ^
6547475
5 H* Z& {0 g1 d2 ] FPV80023: Area mill toolpath QUALITY regressed
* j+ q& m, e- L   `2 }9 Z$ ^# h9 j6 K
6547481# \2 O. C$ L- u9 i% T$ I) S
Internal error pops up while opening assembly+ L" l- @5 B: m" N
8 R1 m9 C# j7 F- p! }6547494
  W% w& a7 q6 G8 @6 {" B5 \# ]' @ Create new component isn't show, when it's Layout Part is hidden
; h6 b; l' ~# a: c! V. F+ h! a
  Y: e/ S+ y4 {9 M0 X: p; \/ n# X6547506
, b& u0 |& {: s" ]& ?2 I9 ` Performance regression (71% slower) of area milling operation in NX8 IP23
0 ^" k2 M1 u: Z( f; s
2 ]1 h% ]+ V0 p$ i% W/ d6547534. s& L+ f& Y( S) d2 T
Draw Bead adjacent segment surfaces mismatch% m3 T7 P9 f: V6 V
  o2 _) d) w+ |4 z  y( ~9 H# u
65475395 A4 K, {% f8 D7 \, M1 j: d
[3] Drafting NX80_23.251: Autotest Failure: Drafting auto-tests are failing with
( W- c# A) R7 O, D3 Z 3 e3 T1 r( w) Q9 O$ i+ }
6547626% c; F- p# Y" Q8 j) h0 e9 [% k, h: `
[2]ADM ugnx754_4.444 Autotest Failures:Nodes differ : original value 8
+ H. ~2 v- n% R4 w# t5 E
0 ~5 X6 o! s5 Z; _$ y6547635' g$ a/ d7 {7 M. _3 I2 ^, |; B: x
Easy Measurement Pattern: Wrong result for creating Trim and Surface
5 }! c- m* L5 Z3 o) @  @ 8 A) [. z$ l! ?. u* _0 l' }/ i
6547658
$ @$ m+ S) ^3 y) `  N Unable to create Sheet Metal Hole with Torus body) K9 P+ J9 G7 ]) Z8 F/ j
$ g7 k" |3 [* i2 \; P. [/ ~: k6547789
3 ^$ f2 d: M& O; p [2]Modeling ugnx754_4.444 Autotest Failures:Nodes differ : original value 3
9 y6 S# t. G5 ?
/ t$ O0 D$ s! K1 `' t0 N! V4 w$ J6547862
, S, [7 P- c* ]. W3 o# V8 F Unable to Update a UDF
) w* j6 q6 r2 J  d8 V1 h! D9 b5 Q2 e
- @0 _3 R/ j( [6 k8 Z+ e0 {6548084( ]+ [/ c/ a5 m+ `# j( ]
PMLXML files contains loops but can not locate them in the harness% V  P0 v* f/ L. c
) [5 C; I3 j! ^  n6 _6548196* X( W0 @, Q2 W) e
Broken linked body after suppressing parting / {  x- Q$ W6 d# u4 ]  ]. O9 ^- A
8 G0 K5 x' F' x: u; }
65484172 N- x6 _! ^8 w% x! I, H. c
The solution though active isn't shown as active(blue color) after sim0 @- j) \; C; I7 l: L3 |! p8 m: f
/ j4 T& l+ |! \2 X) s6548475
# K1 P2 ^" s5 m Why doesn't Feed Rate update
4 N. x# ]/ C4 x9 K% h1 z
$ A( r1 X8 O9 ]7 K, k9 e6548485
; [- ~7 G) [; n7 }* E$ X SLED_nx8_ip23: +++ TAG_ask_tag_loaded(replacementOccPart) # F0 L$ l+ O* G
! C" B" b5 o  {8 X& h1 k- Y! T. V
6548492% }9 d  u8 G5 D  e0 s. s# B% J! R3 G1 G
Sketcher degree of freedom arrows are not visible editing an internal sketch $ u" }; _) q% j  m5 y0 C: s
0 O+ O2 f& x- n( `6548497; D3 _1 t3 h- ^+ G
Internal Error occur, when we supress the parent of Trim & extend" I2 ^8 t% i7 G7 y! s( p7 O7 d
# i( @3 \1 o# b+ v3 x1 P: z6 K' T& }
6548555
7 U" _, j& x4 s3 E8 N. [0 ^ Check-mate Mulltiline Text in Note or Group worked NX 6, fails NX 7.5
; L, s+ B4 d& N1 C $ I  J2 t+ [/ h( r
6548771  |/ j. o6 t  \* W5 h
Font of witness line with a gap reverts to solid when printed_plotted 5 ?! X# U/ A$ j8 v9 K
  K) `: [: i" V9 x/ q  }. O4 q6548948
. v0 J+ O3 _( p# C" v3 {3 q. V GRIP N_C program that worked in NX 7.5.2 fails intermittently in NX 7.5.3 0 W; M0 v4 ]3 P# u1 b2 ]& l7 {3 m) X
9 f. I3 Q# L) I8 Z9 l! T6 h& g0 W6548957
5 C3 }2 Y6 ]$ s2 X. @5 W) o% k0 y UDF with measurement reports the wrong values ' a8 [% d, s5 C+ h( o* g3 M
" o. Y7 n2 ?& u" v* d1 g0 K
6549004: A9 W# D2 C, o1 s6 G3 {
Rest Mill g ves user toolpaths where no paths are needed & L8 n* M1 C' {+ }' ?3 J- a
. q, Z8 u6 P. V" ?: N, R( [
6549027" q1 Q9 f! `$ N1 O
Specific cavity mill op takes 2.5X longer to gen TP and uses 5X memory
! G3 O- m$ z% l; o% c# u5 B/ A / v* ]# F; m* x/ X) s
6549031& Z* C% h% w, I' z( {) h
Exception in syslog when there is no current view
- O1 C& E* m; o9 U' R / G# @6 ]! _" r; H; o. b( z- b
65490349 h9 o+ ?4 W5 g  }
Parallel Generate not API supported
/ e+ R5 S+ V; K3 u- ]+ o- `: u0 Q3 U
: N! _, o/ G! T6549077
1 ?3 x2 z  }% t Regression_Getting assertion failure while part file open " x9 N# W7 V; ]3 H. M! l8 Y2 [
7 v$ e1 ~/ u. M9 v0 C+ T4 ]
6549112
' [# r5 q0 }& B0 \4 k: ] Assertion error replacing part in an Assb in TCIN7 B- R5 Y9 L3 p; q. [5 T
0 }) ]3 O9 v5 X3 e+ i3 [
6549126. p5 L0 ^# T: M, [
Assertion F iled error message appeared while replace comp
9 y# E! L: c* s& t9 h- v
- d& }( Z) M9 N8 K) g- }6549159" a+ n* W& T% \$ U
Current Issue: [4] Drafting NX 754.4_228: Autotest Failure: Drafting auto-tests' M% d% }! y( m; j: A0 ?/ [3 {2 j2 s
  D3 g, C2 Z0 T6 n
6549170
% v3 j* J) C) F The whole c mmand of Refresh Curvature Graphs is useless now* R/ z- O% q6 [* p4 Q
- u. k- H6 @% W) }3 D' V9 [) G! T6549200
  I& O3 {' u0 b, e0 \! h: v2 J* A Regression_Inherited PMI attached to Stub of a PMI note gets retained
) s0 e' j5 k, W 5 ]; K- R+ [; v3 Q1 ~0 h4 r( P+ Z
6549392
+ A* @' M" Y/ h9 w( V, F4 V, {4 W' | Parts list Automatically updates after replacing a Component # n( ]3 C% a$ }' o. d9 O2 C! ^
9 m: V% C4 X3 F; e6 E
6549434! X) K: p6 u) y7 s# j2 Z
UDF with measurement reports the wrong values_cannot paste . P5 r& ~* |5 ^  |3 Y
5 Q' x5 g0 E/ F1 C% X2 ]6549488
, W! ?3 x7 F1 Z4 L. ]9 W [1]Modeling ugnx80_23.407 Auotest Failure: +++ Feature Update Failed - Sew(87) S5 N) D  K/ e( t: Y; r
6 K" F) R9 |' _& C! w
65496447 `+ M7 V  j9 [$ R  X5 t% W# W& s
OM check world error for disassociated facet body , q- L+ P- w! e3 t! J; L
1 P6 p, b( X; Z5 T9 h! G! d65496880 z) E$ c* B0 K- e# F/ B6 i
Note is corrupt - cannot delete
" B. r+ K4 `% H( ? ) A5 s" q8 |: `# c
6549737
& m1 d: ]0 |# s' D, y7 I" Z Machine Zero is not displayed on screen when it's focused
3 r* |% s- ?9 _: U
: p0 |9 x- B2 f( K/ D* x' W5 M& \65497549 ~/ W. D1 X+ n3 {
Internal error while adding moldbase with use lightweight representations ( M8 [( N2 ?4 H, x4 P
& X8 l1 W3 K1 h# q. V$ Q
6549845
& W; u' H! U3 s8 [* Z Not able to create Join Curve with path selection on
4 f/ y/ L8 B7 k3 q * e+ I- C0 t$ ~3 o% I# `
6549890
/ H) w2 E- s, ]% b7 f [1] Drafting NX80_23.252: Autotest Failure: Drafting auto-tests are failing with
. {6 b. _6 B/ `, n. h* N/ R
  W0 u# m% X( E% R+ g6549980
' ~8 ?: @2 w' B6 M Bad 3d containment from Gbuff and maybe a regression# U) v2 m1 }# S6 m; N" k
" t" K! F8 [( S& h' x  d65500672 {4 v  n( C1 p  X3 _! q! @
Should NOT allow user to pick built in path to orient as it breaks connection
; L: p/ Y6 q' ?5 W
: _( R0 b7 \/ w6 ~( e6550403: E1 C7 @, c' x8 Y; O' |
Human Modeling software does not work after running custom python application ' b( H  l3 y  Q! ~
# e/ @7 n( T& R, x6550461
8 g3 y" v1 c" x* Y  f  F3 R Invalid address found when insert UDF / R! e0 w$ {& L) q
) O4 ]: H, G" A1 l4 _7 H& g
6550613
, c0 [5 H7 T  e. }( Q& d. q Internal error while applying Force validity to Invalid connection
% {5 C# w+ t3 J9 m 6 }& V' k6 m* g
6550624
) {, H0 ?2 ~& V8 Q Regression:  OM check error after using intersection point( p5 S+ V* u9 T8 D+ x
8 x+ x6 d( T% m  d
6550662
/ d3 r4 i1 P* t( ]& ~6 C% ? Profile placed with Select guide set to single curve gives internal error
$ h5 f8 X" p3 U- w1 ?   v% ~; ?  Y* K8 m. N  ?; M3 z
6550664
6 L# A' T8 L  d: [ Tool changer can't return star probe to rack 8 r: w- R1 l/ B3 S
7 o* L5 E5 x+ q! F" B9 l
6550718" r7 @, g4 g0 B
Layout UI does not have same options as during flattening 1 z5 A1 ^# y& X  L6 y. Z& d  J
0 y. y" U: s  {! j6550731: y9 |$ ~$ s8 V
Function Create Form-board not working as expected
) `( ?6 O2 m+ j) _; \- e3 T* Y  F  s 0 e, s6 j9 y. Q
6550770  c- o, _5 P5 {6 {  t; c  J8 L
Session hangs with 0 for Primary Angle * M, y, A4 r# m& F$ P# w
* t5 m' H  {; J# }+ ^6550892
! g+ J, }: S- k  }  J Part cleanup for assembly constraints is not journalled in NX 7.5.5 - Z6 O7 S; l8 y/ r
+ W, g$ h" N2 M& f5 E" ~
6550994
4 ?+ \3 |# h. `3 q* V3 {+ i Distance format is different than the one in length cell) and degree character ) w5 n/ V$ l0 ~
- Q& E* B+ j. i  ?% k
65509992 n% E' G1 `8 _, t
Start, End label as well as face normal are not shown in new Pofile ! _& h6 ?9 R6 I( q! S$ l6 V
5 P7 W5 q  u5 v. i# G
6551036' K( l" \- o, [
Distribution Pos is changed after adding assembly+ M  P1 _, |" S5 n% e# l
' E& G$ E3 b' N/ n# o1 R1 J6551041. m$ h3 F" H2 J8 V
Suppress and unsuppress profile is not working after distribution & d6 q/ Y4 O+ D4 Y! O4 Z8 Q
, m; H& D0 R9 l; q' Y. U6551059/ ?, A: j" D/ N+ f* A, a! T8 M6 I
Reparent with General Relinker Results in Multiple Source Objects 0 H* [7 _& F$ W! G/ Z2 {
1 i$ h/ e1 f  [+ m# g% V
6551072
% Y! o# J. |% M3 C' }8 k( R Cavity mill operation w_ ZIGC pattern & corner smoothing gives internal error ( M8 h  [( e# J& [; k7 K. }6 |+ W
3 [  n# L5 r+ k) @7 J' N% w/ G
6551076
- v/ {- _$ `* B$ S. M ug_clone fails exporting assy with replica component . i+ w8 n+ l" r/ z8 @  \6 o2 D
. ~3 }0 S. a0 m9 @/ H. I6551103
  v/ f0 c7 \9 T/ ~2 r. U; j General Relinker Internal Error For Linked Point' e- Y& w: J$ C) v
8 ]; [, i4 ]. G7 A8 Q: C' }6551191
$ ~2 H# I% b7 m' S Formboard creation fails # m7 ~7 v& b# _) f5 j% O
2 n1 e. Q, l4 [) d1 n4 o6 U* w6551223
4 B0 a4 }# d; H3 B! F" ]# d* E Cavity Mill, gouges
: A& O6 E( t0 V+ t! [7 G' e ( ]: ]# G; e) q! V, N2 |
6551231
$ A2 d- g; [: Y  D/ |0 ] Appear Wrong Result, Cancel As Patch Surface button in Edge Patch
" ?/ Q  O* X8 [7 X/ G ( W: _6 m" k, B* R
6551240$ M( h" m2 s- \0 G, a
When comb-cavity is Read-only,There can be multiple operations in the Merge Cav
  S5 ?: o1 v+ [
( U# A( v$ T: s; y: o- \6551270) T* x" K: [+ z7 _
Pasted measure will be constant when the original measure becomes dumb 4 a0 |4 e& d+ u$ ?) w! U' ]! Z
% G& b9 y. n* u& b. j2 W
6551279# b, C& [' v1 ]' |7 Q# H9 c) \
Deleting part does not simplify segments back to original
$ S* S# H5 p# H" p  w0 e 0 c9 R% \: g$ }6 x( c- s
6551304
+ ^# n8 ^1 K, b; _) z Can not pick and do drag & drop easily when adjust plates length
" T: ~) w, @  Q+ U   k# E$ m: N- I% U
65513797 a+ W% w3 X% j! y4 j9 i
Flatten is not working if not toggling on create sub-component in distribution % g( a6 F; P3 Y, C1 v" q# s+ F
% \* z0 Z& s, o' r8 q6551398
7 Y2 f1 P9 {4 X5 l ugmgr_SLD_t7_4: Failing due to XML comparison! q) x% Q1 `# L# {' K2 V! Z' m
8 H! n* u3 l) y8 p65514125 S* R6 V& ]8 ?1 v, P6 ~" O
Profile Edit Changes Layer
  f$ y% e4 W/ C8 S; p5 [/ S+ P
& g+ g1 i& p' y8 x( t: a6551438
1 f- N/ n6 i2 | Cannot save distributed profiles
& T) P0 Y/ ]! o+ E9 p2 c
$ l- h; J7 }' G+ Y/ `65514842 ]' B1 C3 S# E5 d1 r
Tracking point fields in grooving operation do not retain user-entered values
$ S8 {0 S6 R3 e
* k/ J. @5 z& a5 z$ l) V65515058 d8 c  [* m' e9 ?5 X3 R
NX gives Assertion error if empty harness is used to create form-board
3 m, t" E# s# p( G% u$ s4 a. s( {  p   ^5 k3 z3 e) Q; ^) n
65515577 g& B% k& c2 T8 K! s" q
MP 2D Exchange fails to export
' B5 o) n8 I5 A5 c! Z* Y& K2 z5 _* f 6 _! r7 M5 ^+ i# t) X
65516056 g! C5 y& B% o
Unable to open large assembly after upgrade to NX 7.5.3mp1 & v( l9 f5 b3 ~, ]
4 n6 O% J+ O& Y# U- s. F
6551864
) |5 |2 G3 X1 a% v/ h Parts not removed after deselecting all Solid Bodies in distribution feature
7 n- i( \( Y/ P$ v 4 V; v2 \) z" \' v! O
65518818 b* J7 M) z$ x7 U
sa_part_id not removed after deleting distribution feature 3 e7 t& g  ?; L" v
  J7 z/ r- I3 O/ \5 p6 l& W8 i! m* U; d6551890
3 i1 P6 q1 ?6 q* i9 D# h Distribution fails with combination of specific feature name and number of profi
/ V9 V: K# ]) `8 Z3 H8 v6 d& ^" }% z
9 L/ d; u5 ^4 Z$ \) a3 f- w6552109
( Z6 y5 f. |  F: t) B Distributed component count incorrect & }, `% d: w5 l5 D
0 D1 ?% a; G+ n) Y6552136
$ \& C  h; Z6 M7 o& x End Cut Cuts Unexpected Volumes $ C7 I3 a+ d5 a) v8 o  N
- \2 {* V8 {5 {- I1 d6552165
9 y5 E7 K  e* ?( I6 E2 z Distribution - DB_PART_DESC shall be empty 1 r3 i, i& a- s
& r2 Z" \4 o  R( B
6552176+ n* X$ S& H$ w, w# t+ N
755(2): MAYA Translators: CaeTest_append_jat: Diff in LOCAL cards
0 N! R0 k5 y' R, g. U; b
# M; H8 ~! i# i5 T) [( c  O6552197
7 E. d3 J+ |* K8 O2 p, b1 V 755(1)re Processing:CaeTest_ssso_group_jat:iff in SimSimulationObject value . G  M. t3 {3 d" H
  V2 r! }: F+ n5 Z2 F# e9 I; ~  @" M
6552215
# U) b+ c6 O3 z# K2 |8 \7 c& X4 ~ Assertion error while replace comp w fix contraint (sameParts)
! u; Y* B( x( [: B
/ s3 B1 W/ C& D  z6552219! Q; t' k& j1 _0 f! M4 ~
755(2)ost Processing:MULT: Header-block does not match 1 M- k1 y% W, H) ~/ w/ Q
: k* z4 F8 j; L$ _65522228 E$ a4 R1 R! u4 K' U+ g/ W
Entry_Exit points not updating when first and last measuring point is modified
+ _& m0 q  s- h0 N# S ) P& Q' h" E" ?. |$ R' U
6552345
' H' b9 t( u; Y2 o) u2 o; H" o Export from Teamcenter or NX fails on top assembly with remote parts-Multi sites& a2 {* s& S& G* m% b# z
( A2 S% G% Y2 @# z8 e+ D/ l6552549+ z% T/ T4 p6 ^# g: A6 }5 {; w
Text block in bad position
9 c4 u  w. R. {( P4 e/ O
/ {# V7 {' m9 V65525827 L. v, d8 H) x* m+ Z; C2 \
RMB Gouge Check causes Check World failure 8 ]( ]- z" b0 d3 i
- |( h$ B7 p( D8 |/ q- _+ R/ y2 j) Y
6552590* {6 m9 ~% e4 U
Can't do linear interpolation on a transient function with small time steps 8 o* r/ a- Z* F: U. ]: _
2 W, K+ g+ j2 Y0 l" O
6552598, ?# q' L/ F9 A$ V* G5 D7 e
Update Formboard shows no problem when segement is deleted
% w7 i( K( |/ U9 P. D" o' x
) p% U/ h2 H3 K) E5 U" q6552683
0 N' F+ A/ ?' `" ~ GM test part: getting Internal Error on zlevel operation
7 F/ D" f: R5 `4 U" K' Z
/ [! E7 R! I; M& y: Z$ y65527638 L# ~/ `  J  o, K" M6 f* d3 j5 {5 t+ @
When Enable Multiple Revisions, Copy Component As of a linked body is broken
: |' Z% d6 B) B! ^5 R, ?. Y2 z
9 y' s% g% q0 l- s6 m6552766
2 _7 ~/ _8 R" O3 l2 {- e# @ Create Cavity and Core - Storage Manager free error + T2 `1 ~# P6 J# Y' ^2 Y9 f
$ f2 ~5 b- c; [3 H/ Y7 z9 j3 }
65529848 u: E0 G5 R5 \1 _$ s- w& G
Helical engage percent tool not working same in NX 75 as NX 4 . f4 q4 }, D* ^  o
) i% n3 H! w# t& T6553180
$ s* t, r# u- {: \: F. n% z# m0 l& M Dragging handle in Text lead to internal error
; [4 ]6 j* I" d# D 2 K  \/ \! m3 A" T
6553197
4 j  g: B: ^( a+ c8 B* j  v Cannot globally select this Curve Analysis object with solid body visible ) P1 D" B9 L2 y
1 h! p; {- F% t( w$ {0 y  p
6553198+ J. g7 W' n8 g1 X
There no ge metry selected for this operation error on unbnd PLN 3 t. S8 W8 C  y/ u
8 I! B+ S2 P% i
6553245
9 F/ G( L+ Z5 J3 f9 j NCM engage and retract are at rapid feed rate6 u7 P5 y. L% ~; C7 }
+ p7 `' _5 g8 J! V4 X6553361
; U! |  m4 q! t) `3 u3 G, H Remove error note related to bad buttons in syslog
0 o7 Z4 H& R3 Q7 v
" O5 r! d# c0 I. O* P6553608
  }. q. z7 }8 g' y6 n8 h% z! ^, r Cannot create Welding Measurement Locator objects using NX Open
* U0 D6 ?% N: V# K6 v7 E. M 6 w$ W7 I% M: X, ^9 i& K& p7 }* E
6553946% ?8 j# o+ V) @* g8 f) }1 }
Infer Vector for creating parting surface causes interanl error
& M" `' A5 ^2 a" ]
1 y- e7 @7 _/ y# w: C( b65540170 `  j: ]; f, {. r$ R) X9 ?: I
NCM move could be shorter when moving to min clear dist $ Q" w8 S" P8 P5 a
# k' V- |8 U7 [4 x/ z6 J
6554059) r! Y/ c' L1 ?6 x
Exclude PMI  classes does not work 1 X  ~1 O' e( S
' R; Z5 F9 |: m. H4 E  E% m! Y6554171
, E- a, {1 M& C! v( V. j3 A [1]"uft_perf_assy_open_fmc_six_wellheads_lw_nx6 "EXCEPTION: General Fault Except
  ^: d$ M* R# s3 E+ V! q/ q( K 9 p' R2 u* ]* V/ b9 X
6554219
1 V, U0 C0 M3 H& a3 \$ g7 L( l Add a cooling fitting in assembly, direction not correct
" N, H; a+ d! U/ L- ?7 u % H0 I2 W! L4 `5 F
6554272$ v5 o* n' x0 \( e0 a$ r! W
Floor no longer defined for PLANAR_MILL operations
" U! H, \/ q# N( f
3 X' @2 P/ Z( ~. I  x& z) ?& T6554380
' O0 f) ]: e2 g* o8 G Replace Mac ine fails with no ug_isv_full license has no message in log file   g" p8 K  L' n( Z( n3 l+ C8 g
5 S. d- U: q6 l6554443
! s1 _, |' t! _, X  U$ R Place part is failing in NX 7.5.4 ' d5 }0 x" P6 W0 p, u
# v( w% u' n, q/ l' S- Z* D
6554652  J4 `$ t. `1 a# \& ~% P3 L
Link to PMI error, There is no surface entity selected
: R) ]8 G$ g4 Z' Y9 s$ P, ]0 y / B, |: d% j6 v0 s. s/ c0 h
6554798& Z+ p2 J2 ]( v6 h+ `
Assembly Navigator not updating constraint status of components
. @2 H: C" S6 I; H( F$ s3 t
/ x& V7 {% d: v+ ?5 S6554820
- G' D4 H5 i$ s" Y6 x, O. K Face Analysis operation in Wireframe Display; t8 F9 F9 A% S8 l
% e9 |; L! h. e1 v6 Q6554822
4 o! U4 B* w) I2 W- l* s7 `# q! [$ j Edge Symmetry : Start side temporary Arrow' `4 k' ?4 W7 \2 I  o) X1 W
* i" [. I; n$ p# ?
6554828, t4 ~  `6 Z: c3 M& b7 q
Minimum Radius of Curvature Label of Curve Analysis
, X9 @0 l2 ~+ U% T2 a1 }/ w/ U 6 }* v: b# }9 g8 q& W
65548811 k9 F- [. P# N9 O# ^
TC9:TCIN: Not able to create Part in managed mode, NX baseline 06210 P4 i( F8 }4 d8 @. x
# m1 T; \. l; a/ H5 d( b9 q6555019
( o( X" M1 b% H& n1 q6 H( j3 Y NX159927 - with env var set, radius can still be edited via expression + P% o6 u  s& n- j, d. w% g
& z2 P! e0 K# f5 O' @+ [6555045
( |  i. n/ T% h" l Regressionetail view label doesn't update correctly for legacy parts
4 f, d( Z6 _5 Z, P9 Q4 q  T 3 N% b& I  G2 A: S7 d% `
6555361
' v* T6 p! Y/ @ NX hangs on follow periphery pattern 6 e, s2 d1 j/ [5 o3 N% k+ O
7 q% @  f* x& U4 Y6555422
% b8 W. Q+ ~) l+ ^  @: u Easy Spot (move) some welds have wong information
: ]0 [  T. c) X6 ? : A/ ~# i: H* i" q" C: P
6555605
/ C  s7 s+ w% |+ t: u Message pops up to indicate there is an issue $ j' O2 S4 s# U3 r$ r; P0 p
2 G# t0 K& o" b9 N6555664
5 r$ o1 g4 P. I' H  d: S3 n2 w Syslog exception during part conversion 3 s3 i$ h- a6 \) m, R  d
) }9 N7 l2 y9 X( j0 o6555712
! [8 ?  W. i4 z+ f! x- |7 m5 V( S Assert nxpos_geom_utils loading Newport News generic ship data: zero length line $ u% ], M3 Q) `  Y
. D" u" v6 M7 Q0 I. W- f5 o6555826
3 x: H# [- h5 m7 I4 e" O Cannot edit imported measurement locator . z+ l( Q7 b( E- z$ N5 N
! S! n! U, B, ]6 {+ v) r
65558373 I( ?/ ?# n  X! J& y' m
Conduit Overstock not offsetting correctly; D% b! _3 l9 b' f$ ^* q' c
$ w  j3 v' u+ ?6 O' {
65558645 ], M% k" R6 c# h! m
SOA error in Assembly Navigator MB3 popup on component opened by another user
; y) Q* Z4 b+ p( M" f
% J8 a/ j! T, Y! E8 M9 u6556102
. F5 O5 G# p7 R4 e Internal error from Redo after General Relinker / s6 N9 f( r2 \/ o" z
' O4 \% V$ w* m7 X6556154
4 u' V, J; I) q7 l9 u/ D EXP_qsort_strings_al functions do not work with qsort8 L% w8 ]! F) `3 {, n
1 k- R. X( l; S  l
6556256
* @4 G" e2 }0 w7 V7 d% f Wrong feature types checked when applying template based create feature process 2 s- ~: q, e& U- s& v. H$ r6 G0 ]
5 B# V9 [" m. J" M/ Y6 L& ^
6556312
% c9 z9 i! w! }. `! ~ Check world error after do PDW functions
* x( j/ B  j9 Z! e4 j$ r$ L
- T: [6 u; _& r6556382
' Q( g  b# Z3 L  M6 C Severe error on launching formboard layout in Routing electrical
; ?0 D2 }, w! F3 s7 s0 K, W
2 S! c0 D! M" z& e6 }0 d6556658. m5 `$ e: B: P; Q' {2 {, F# D0 G
Unable to relink the PILO features in the same session
1 S) B/ ^1 ^( n3 x6 Y( z
5 g: P/ W! t, y( }* Q+ T" @65566785 n, N5 X7 Z% h9 m8 s( _- z% L7 w
REV: Custom Symbol causes NX 75 to hang, works fine in NX 5& d) a4 A' V& B5 j
" M+ k8 K+ R2 R' k. X- @
6556939  W  g1 D7 s; |  R
New added standard parts can not be copied or deleted in insert auxiliary0 S( x# `" T7 m; t  s  E- c* Z
* w. b$ _9 K, ^3 M$ w
6556962
( Y5 c' }; ^2 |. i. ~ Inspection of Dimension Style does not flip & {+ k2 J0 J1 o' j2 c2 i) ?4 \
4 M2 x  m* z& A" m! e; v% |6557272
2 G, `% G: b) C/ ^! H3 ~ Surf area TP seems to leave part early in 754 & 8.0 vs 753 % A- Q) M5 |3 A( C+ A) z; \
! G. l' Y7 G4 c1 Z6 b7 J6557349
0 I/ h5 O$ Y9 Q2 ? [15]ADM ugnx755_0.459 Autotest Failures:Nodes differ : original value 14 7 L6 E' x, O( X2 b  y- w( |, l& r
4 _1 {8 b8 \  i( W
6557633. [* B- [. O+ t+ V* G  ]5 X6 b1 D( G
[1] Drafting NX755.0_235: Autotest Failure: Drafting auto-tests are failing with% T3 D' w& n# F( t$ l* a
+ z9 k/ f. u' b
6557636
, P  K; ]3 t0 B% \$ i* p" Q+ g Initial engage from the wrong direction
- B2 Z; i" Y* D! y. j: F
% g8 [; C8 y' r- j% l6 ?6557668
; C/ P0 r  J5 @( l) l [39] TCIN auto tests failed during save
' |& s8 G0 |) s) @4 k 3 k& k9 ^1 i+ j
6557701
$ G6 A- Z4 N9 @5 U7 k" { File > Import Part fails; An embedded object cannot be deleted in isolation 1 h8 ^  P) Z3 P; c) u% @( f: B
* J6 N* ^( h6 H65577310 {, J8 m9 n# r
Documentation for mqc_askCsysInfo function is wrong
5 I" M* W7 n  \8 u' |8 S
* E& ^" T$ k1 M+ mb6557806
4 b3 U  ^0 F: J7 M% H Increase 1 path lth causes other changes - flips branch,stock attribs, wire lths
1 B4 F" w: V+ g, K7 E& y # W, L2 x7 ^/ O  O$ ~2 A
6557881. R) l; ?' r8 ]5 ~, v5 j
File-save &quot;A deleted or invalid class id was used" error.raised
/ H% w" K8 n) C* [# b' M9 g 5 j3 d$ x9 W, x  E
65580246 m  L) c9 i6 Q$ k( ~
Bead Through Point does not work
/ `6 a, A: u. N6 ^# D* @) o% l8 p . A8 y2 ^" z$ q) _6 p. j) L
6558086+ d# k& K+ G  y0 S, a2 o" F
Replace component in 1 assy replaces all same loaded components in other assys
& e$ a9 J. ^1 z" ^" g
" _* v7 I+ e: Y; p+ r6558222
$ T5 x& i. u& c* V: t: [  ` Section line with section view preference is different using partial loading
$ l! }8 _5 r2 o, E4 a7 E& p( r7 E
9 R1 F/ O! d" o, n# V6558324
! a& `0 e) U5 n7 w+ R" ? Internal error occurs when delete feature
3 Y$ G' c4 m( E( ]5 |( N
" `9 p+ c; ~7 q# C5 D/ F3 @+ p8 |6558383
* T- Q3 R( B3 P: l Can't open assembly due to an Invalid tag error
& z% i# s, }4 \$ O  w2 Z1 i ! V7 D6 M' Z: h1 [# N7 h4 W8 ~
6558605$ }. Y8 Z; o& u
Parallel Generate not working correctly in managed mode ' X2 ^* ^  t% d' {* n' ]' B
) l  S+ {3 f* |
6558818
& j1 I. p" ]1 {, @' w  }* M; Y Need to have LOV dropdown for File -> New in NX. Shows in TC, but not in NX , s" v5 z/ D) _1 |3 G
( n2 j  H1 q7 Q" ^6 T
6558900- u7 k' L1 J2 }% }; B8 l
Can't load posture library of the attached part
- o* x% [0 J% T
% [3 k0 U0 D8 Z+ N% G6 p6558950+ V7 M: B+ B/ L
Surface contour boundary drive method: toolpath gouges into the part  y4 ]9 J0 Q& R' X" q
' e1 Q# {. l, N3 r7 K* W/ v6558974
0 J7 G5 f. d' C$ l% s( K Motion Simulation get error result
- ^% \6 m& M; s ! Z& N4 q$ O: i+ K7 q3 Y
6558989, h3 L  J' p3 b: P; o( N
Assigned discontinuity gets removed when function unify path is used. 5 Y" \  h" `6 Q; A8 v$ S2 u
3 n6 L; H: p' U* r1 I) s' O. M65591084 g' |4 O3 G* f1 c9 ~3 ~
Regressioneader arrow line doesn't display for flag type leader for PMI annota
: g; m% t4 w* w) D7 x4 R* p5 U
% f$ s7 B/ K" |6559114
/ S' R; |$ V3 ] When path is edited after collision avoidance applied then meas points missing 2 \( T) q: h. U& b, ?7 Z
3 {2 q9 ?$ D/ v3 S  ^
6559171  _4 C& k/ d: N6 i! X
OOTB custom command pb_cmd_tool_list.tcl throws error on T-slot cutter & ]9 K7 m: R) g0 Y6 {
2 q4 d; V4 m+ i( x6559302$ R4 m# c1 q0 ~% d2 y- Y8 ~& I
3 b4 L7 r1 n. J2 b+ _ ! g3 {6 I1 v$ R  ]' z) N$ G
6559439  s+ \4 V1 w7 x: x/ R( B9 S! N6 p
Error seen updating a formboard in Fiat workflow rev1: entity cannot be delete7 f( _) {- y$ r) o
! F% x- o0 f, o. I: l
6559446
* {2 R( p& e9 @+ C Cannot export an assembly_part with a linked body to a part with no NX dataset ) F, W/ p) T6 F( ~, K
6 g! O! M$ N4 A; d1 O( D6 `  w
6559646
+ }+ @( W; ~( s3 I. j Cannot create V-groove compound weld
; ?( k" l* q. V: o5 R0 ]5 y
% J# y) y3 _1 `0 E6 a6559704
4 I$ {$ H- e5 o: K6 \ Autotest "RoutTest_Elec_Formboard_canon_PR6423377"Failing due to exception
7 E. i& Z* _# A. u
! Z. \2 P0 x3 ]7 w" ~6559705
+ q8 a- d( ~: j7 l. f- Y Error recovery message while trying to update all
& W  [; `$ _! J3 s7 z
- @6 [- @$ y3 {# ~! S$ ?6559723" [, }3 ]- S2 [+ }
CSE Machine Simulation: DPRNT statement fails with parse error + r1 u" Z4 z* W5 v0 Q0 `
+ |: M0 Z$ h. V4 A" N4 m8 z6 v
6559724* g" C+ Z4 c+ x0 z
Dimension missing gap on centerline
- y' G% C8 K6 l7 f$ t5 v + X. a" j0 ~* B1 \
6559793
* {& V* u/ m  Q; Z! G# Z0 x) C Crash when saving from NX to TC with weld feature publication 5 R% W% U9 q! e8 M( I& N
2 G; V1 S% u6 K7 K5 n1 ]
6559813
6 \0 b1 Y  |/ T/ c8 N4 g# [4 } Incorrect parameter change after edit cut regions * x1 E) c( ]& P9 v  w" @1 ]
) Y8 s4 ?  N8 i
6559841: |% m+ @, A1 a0 }/ [+ X
TEACHMODE- missing "prefer direct motion" missing in NX 75/ g  f, d5 e" o7 q/ n+ {
/ W5 j* U# z8 {" `* H% X/ ]65598998 X, w9 c& y: \' c
MW: problems placing an external symbolic thread on a cylinder / ~! u* l2 M9 ?2 {8 [' |/ o1 T
2 L; P! v/ J& G6559944
6 a* g! V! R0 E1 i! r; G  z4 T Update wrongly finds discrepancies several times after initial formboard - Y7 k0 |. C9 X5 B5 z% \. f$ B
0 }$ `& ]4 D) j8 S# @' V$ l6559983
: @' z) l7 a) `2 A7 W9 \ Flip Formboard component issues: preview button and when we do "work" 7 W5 s5 D+ s& D+ o5 M( P* H
% e7 f' Z% B: v
6560031
% J! ^5 b! J' \% ~" ~/ O$ J! r, e Shape segement, add radial bend, update undoes that bend! 5 Q& p  u& l' e! B
5 I7 E% y2 h5 j0 j  Y* G8 v% X& L
6560039
. u# P8 k# \: z Optimized to Drive tool axis exits NX
2 A+ g8 t2 q. w! r$ B! K9 `
5 g& j) S# m, ^# Q8 A0 v6560040
$ h9 v# u8 R6 y# d, v) _& \& S& z$ p  k' k Old color pette is opened when changing the patch surface color
* ?  a5 V; h3 s4 d4 ]6 r9 O5 ^
) v8 |: I6 w# S+ M2 u2 ^0 G6560052
* m; f. ~  z& z3 V) v  e% L Delete multi-wire cable from conn nav, update formboard fails.. 2 @; S6 Q" Y7 h: e8 ?
3 F. Z% W! l6 ?$ K, F, ~" a5 [2 j65600543 F. ]1 w, m4 `( |" L2 Q" y
The color of a linked body does not change right away
1 I* ?' C. a0 g: l3 f3 K1 j; o, W9 V
6 E# U, L/ K0 o% G6 r' o6560130
4 c2 M8 ]! F' z! ~: q* m! m Error recovery message while trying to update all
( M0 d( t" Q3 l, B 1 D( s# }5 x1 L8 {
6560190- Y( r. d- K, M5 C& n
NX gives assertion error while using function object attribute annotation " d( |; f  U$ `0 j! `2 t
8 ^1 |/ w% [: b9 B9 F0 S+ A6560192: a6 q% x4 t9 T6 i; z& g; P
NX 755.11, afu record isn't same with original 0 d5 h% a5 A  ?' T
& B1 v% m* c. b65602733 S0 \7 B$ v7 P8 i# t, x
Values are shown for newly added symbols for ISO2002, ESKD! z8 E3 W+ u% ?; i6 j2 l( W
( G5 d/ ~8 U  i6560289+ h$ C$ `5 C: ^5 I" @$ n' p" ~
Internal error occurs when edit failed Trim and Extend feature & _5 K  _2 R3 T4 A
9 [4 T7 U6 i4 o. `% C- A
6560328
9 Z- f9 M1 ]- w: k Feature Identification fails on MW part - invalid or unsuitable OM object ! P: G% ]: g+ t. `% J8 v
# Q0 {" k1 M. F6560352  V6 b! M% ]& O4 [$ T
PS_24.0.167: NX hung when delete feature 7 ]% ]# g% `* i! Y
# t6 E( Z! f* R8 e6560388
9 G5 ]1 d' a" L NX will crash when changing a Profile to a Belt , when the Profile is set to Vec
+ E! r2 h; A* l" Y9 S ' h3 z5 |& c% K" V% k; z8 l
6560394/ w* B0 n' J  E& T% i
Profile Cutout is not working
- k( T6 P/ J; b7 q' a, ~ # f& W" ^5 P( v+ j  m
65605177 w' ~; N) H, S; ~
[1]Modeling ugnx755_0 Autotest Failure:Nodes differ : original value 56489.26334
1 Y3 x4 }& {4 X  F  ~4 e0 @ 3 X6 _# G4 J! S% r8 N
6560788
5 t, w' r% [0 j Save-as non-master NX attempts tor translate the item id 9 C3 D  @% G  F; \# c
0 l5 j) q) R: J/ |; H6560813
% n7 K8 D( S; j- X3 m Internal error: invalid solid object tag0 [7 s* y5 W  n
; j. ^2 x" {" m/ A* I9 A. E6560852
' w- \) s! u5 F3 K& _ NC:Internal checker error while save after delete wavelink and redefine const
/ B  {' J; H- Z9 h  N " I: S, \4 u) c* O( d5 F$ ?  w
65608865 ^: X1 I- d' z* A+ z* B
Can't insert intersection curves automatically in Split Face UI
: f& r' M1 o# s2 t$ P. L. l6 n% v
2 C" T' Y9 r+ P0 C8 @  a" Y6560894( W* d& `$ X, B3 `
Not able to place a Belt on a closed Guide 4 N: @' d, A% ?6 s
4 G/ Z% G' t) ]6560899
* S2 b7 D! ~: L8 e4 m: E/ v NX gives OM World Check error after using function Orient Branch.
% e/ V$ A9 A* ?! g9 q6 u) {3 [ - Z6 A, J% W& ]3 s* @6 ^
6560909; r4 ?- u/ [7 A% R) ~. `/ G4 [
Not able to flip profile direction on profile placed with vector and offset Guide7 q; D/ O, H8 _" [9 \
( i/ ]& f6 l2 q3 B" c0 U/ @6560933, K# [9 k3 g% r
An operation was attempted on an invalid OM object during replace
! b2 A4 t1 ]/ t( A( V( m7 o - Z0 i- Y  Z  F! {6 u: O1 x: f
6560975% @5 L* T2 X% I0 s4 B' Q
Marking line result not correct
& f. X$ C8 w4 `# F
1 x: h, B  I1 m1 o- E: h$ X! }65609936 o! n& C! B5 d  e$ H3 k! `6 P
Marking Line angle tolerance is not in degrees
7 r. |5 m; R  R; u7 h. |3 Y3 T
! G4 B8 R; w) y9 L. c2 E6561092! k2 I  b9 r& Q
Cannot distribute steel support as profile - missing attributes
9 M: S7 s( H* `- X- h
0 `- [6 b# T  {+ Z( G& Y! r. x+ C3 S6561267! p7 C1 G) [) }) ]" x; E0 W2 v
UDF with Feedback expressions - Apply does not create new expressions ( y3 ^6 D+ r9 A2 K
( k/ n2 T5 ^! C- c  |65612774 \3 n- S% I+ Z2 V
UDF with Area Measurement does not work in NX 7.5
7 v0 A' N, F4 K  G/ L1 w, { : c! H: g' Q* n. N- x
65612970 ~! [$ y/ k6 J$ U  J2 v
Performance Problem Creating Notes % g* v. {/ C* f+ t* s6 V
4 m: H* e# J. |6561410
4 k) b# K  e! T( l CFF finds incorrect connected parts if sheet body exists with solid body
/ ]0 I: V( l: O * F, L3 ]7 V2 ^; n
6561426
- E- y% S5 [* B General Relinker is flipping curve direction
3 d5 F; R+ P. I. C) g* j1 b2 X$ J6 S
6 e: J7 p0 p& r$ T3 [6561433' ?! I5 k! U" f# E  A9 o4 Z. z
View scale i1:1 but reads 2:2 ; Y& ^+ w* d; Z' N, U% ?
5 e$ M$ T" T( {* r: K) f) \+ X3 \' F6561457
, ?, {; o/ u( g/ l$ L% W% G NX 7.5.5.1 MG - Regression, OM world check fails after editing Swoop
8 m) f+ b% D& c3 u4 U/ g
+ F3 d" C) y$ F7 [5 ?$ @6561480/ i' |4 {# f4 U
Internal error while dragging the group member out of it in PN % T$ H; t" _3 M  E
. Z( q3 ?! I, F) {1 Y/ D9 e8 I
6561501, a8 }5 X6 K: A" ~
Solid body display as a sheet when de-select a region
) Q1 v6 a' Z/ V
2 d7 G/ @# A2 P2 G- L65615289 `; r7 \" r+ W% f& m; i
Cannot flip face normal direction of profile with double sided endcut
0 `6 M9 R" g" b- z
9 W7 V& v! ]1 J/ [5 `7 _6561544: x; [+ B( d  l3 W  j- a  x
Gouge Check reports wrong number of gouge and holder collision
# K& I5 m3 W' q4 D: S- k) c . Y4 V; ]" B4 r* |! j6 M; e
65615608 M) V; R6 |5 v" \1 ]
Marking line and reference line not correct in Plate preperation of straightbrak
3 B. w* u# Z: a  R$ ?$ K3 y
; o2 V; f2 O  @* C65615672 q8 g: {4 U9 }" g- R! N! q7 h% p+ W5 m
Plate Preparation is not taken over the Descriptive part name style ; Z0 ^- D0 y9 d% z6 h4 s) b
  o; u: s) z. a8 \" R5 d
6561570: w% u. k, h2 e! w- J0 T4 ?, Q0 f
Assertion upon expanding a group in the Group Container Folder in PNT
, c  L" N/ D9 x+ N& g : v5 Q  o6 ?, g* \
6561760/ K, W' d! O# F' e
Element copy and translate fails in SC03 FEM
5 E1 H8 N) V. f- h- T
" z- D/ ~( D; R4 B/ W8 f65619712 M8 e1 L. S! v6 `. i
Fiat workflow, Rev2: Update cannot resolve 3 discrepancies rev1-rev2
9 m3 g0 r0 Z' V/ _; s' S
& U4 M+ \; J1 n5 C9 L. o4 V6562047
' f- z+ B" \6 R  n9 |6 r& Z NX 7.5.4.4 no longer do average cut as NX6 or NX4 ; d6 c* E  x% E) u0 K
: P5 M( t/ U0 _* l! |( X5 G
6562050
; L9 ?) V) e4 W$ O Not able to edit Reference Sets
2 @. }$ C% p/ | 5 N* F# G9 h8 k8 F
6562169
4 `' l  B3 M$ \ XMLout on metaform gives mirrored results % m" x4 C! [5 u0 `& [% u- g; J
7 v6 n4 v* `( c- k$ C6 |
6562173
/ E9 R8 S- V& @  r- m: O7 a Shipbuilding drafting Symbols are not working
0 M& c: b, J; _/ }  }" | , |1 E2 \# E- \( g
6562181; u8 q7 r) a4 |" x
THREAD_TAPERED attribute no longer extracted
! i" q! k; f( A$ n ' k+ p+ P; u0 Q1 U  g
6562190
! B2 A/ J" D3 f+ |+ x5 T1 Y Belt is created with angle although there is no angle field in belt
# o7 D  m6 V: |6 C# G: T ( J: X) A' d# W, s$ t" t9 }' ]( D
65621987 _: E7 C/ k+ k2 A; ^# r1 U2 E' H
XMLoutput must give information about NON-Planar parts In Information Window
: C( Z4 ]+ S5 b& E3 _9 C
3 S1 ]( E$ e3 E5 B# \  R65622099 V4 w7 T5 ]0 p4 G5 B8 v% E
Section of  profile changed from plate to profile gave incorrect result
7 }1 o( i  u3 a : E" F, f7 C* l4 F& M* \
6562214
3 `. w2 ]) ?- _4 I& u Checkworld errors after Redefine Constraint (left over COMPOS_movable_object)
4 F% H5 v  n% S
! C: L3 [& ?0 y* n" O! ~+ l" p6562285, p- D/ W( W# I" m7 ]  i  f; r
Section Line preference "with section view" is NOT set on 64bit 2 x, C# m% M8 k
& k* _- G! }! V8 q/ H' |9 q6562340
* I, R2 ~8 v' j) F7 E NXOpen > ModelingView > Orient does not work with the display off ) ~7 Y- Z7 \% T! B' {* s
- G' j  \$ S6 a* C+ Q( ^6 j& ]65625171 H0 E" P  Z0 P* h2 e# q" M
Fully positioned component becomes partially constrained when moving a 2nd comp
' m* |: r  M: z; Y
4 t, |* t1 X  U" s+ Z: z) S65625430 ]/ [, D  k, `" h' g6 W
Routing: arclength must be greater than zero and assert failures ' z& z: Z3 _- Q' O4 L  L. V
9 P/ K8 k1 y$ y+ c' U65625840 Y: N. D/ a, m! H7 t% p0 G
Enhance export_ugdwgimages.exe to also support PDF $ j1 E$ C" c% |# V+ C/ c
6 I2 K' v: O) y3 G8 u; b$ W
6562797) X# c. r2 M$ q9 Y7 g4 P3 B' W
SLED_80025: Error message while deleting the view after update # B6 b$ F/ s! X9 _( K) b) {: {' b2 z
' Z9 Z- M; {( w: n" p
6562802
6 \3 m) m* v- j' ]: A5 l# N Assertion failed occurs when the physics named string between 30 and 35 bytes.
% J; I- {3 C) L6 x0 u
. r1 o9 {" a# A9 ?- s0 v7 R- [6562904; ~" A  a: [) s: q% K
Parts with No DOF needs an explict update for ext change to update ANT Pos. info
8 N2 F3 X# u0 c" Q$ y
" L7 _% S6 K( u& m( F; J* L! M4 {, t: V65629182 p) c! s: o/ K- Y
Autotest "RoutTest_general_path_parallel_offset_path_5" Failing with EXCEPTION
, ?* i5 N- a; c0 P; K  y 3 j! W! ?( I4 a: y+ t
6563250
8 s% v  k; E8 {3 m* B' O Detail thread doesn't go to cylinder end face) d" A" h3 j" A" K7 T# r4 Y, T
: r2 S5 P9 [- `( l2 S: ?
6563361+ B2 Q( I! ?0 M# B7 N9 t, b
Edit -> Object Display does an unnecessary regen for a specific part
% ~5 m. I' j( f2 e6 X# B$ ^4 m' Y 3 p" \7 a$ @7 W& _% L
65633857 ?' Q. b  z2 g' }, S
Internal error (memory access violation) on deleting parent of Trim Extend 6 T  _3 h' X% h
/ w) a6 [9 p( h65634410 @9 [% A0 w4 }1 ]
Incorrect display of I,J,K for 5 axis path in Tool Path Editor
; d# f3 N# i+ g& U$ E3 Q
, x8 b6 j+ @! G  W/ g6563475
5 Q6 A$ H& h7 [+ ^# {$ b& n# c Inconsistent name for Curve Analysis object 8 o8 b8 b/ E  g1 j; |
: R4 T* J6 k" k5 m6563564
( t' F3 E# x! T Assertion raised during export of select objects on modified part 3 U, ~) T0 ]% r% s' r0 H
7 C2 W) s* a% S/ H6 I' p  T0 ?/ g6563587, M6 E/ g2 _; t  T
755(1):MAYA Translators:CaeTest_append_jat:OCAL cards Reversed
- `2 ~! [& Y, Z8 C7 \! @ / m! s! h1 M4 h/ I0 w5 p
6563602
9 @9 r2 T0 x& j+ h7 g, G* R2 t9 s Feature properties disappear during update . }' L0 p. w% ?5 X% {# }
* u7 j7 W. E  R* X$ S: T
6563752
6 L* y4 D: B: i& n, t Fiat test harnesses need to pass conversion automated test 5 c! c+ g+ ~3 P( e) @, o8 I) ~
; o% z/ g) Z/ a7 b# v& G0 D$ s
65639880 i0 w, D- L* e: z; R  d
Element copy and project & element copy and translate fail in SC03 FEM
, _3 q+ E$ [. t" `! m3 r
( d6 I' ?% W( I* z& D* O& P/ o% G- i! \6564134
% J" x. V2 ?) w8 u copying some turning operation produce signal 11
7 \  h+ G9 S9 [4 |+ v! A2 v& a , z1 a" b8 O3 G" h
6564152# @& t  H' a6 e, j$ V  I
Internal error Invalid address found in Storage Manager when undo general relink
2 A+ X: h+ Z4 o . N) e. ]3 s8 ^
6564155
4 N; v2 Z. J# H7 k- T" O. L7 u Internal Error while creating simple hole
% F. Z5 \2 D6 C2 q. g
/ {6 S$ a# k& ]" r+ E65641889 a2 ^0 B( F3 a2 b7 O
Assertion Error while Flip Component with Custome Axis type option
4 }! @; v8 L3 B* @
% @$ l! y3 z0 _4 k" {6564203
6 z5 d/ ?1 G+ q  `. O& ? Internal error when de-select reference edge when edit pole3DON 9 m' |+ i7 }8 Q2 [0 ~) N0 B
, T3 W. l& B! X; `% `6564215
' {' E) M4 O& O& {3 s" S5 i" w3 T Internal error occurs when move an object6 ?$ w6 C; K6 P7 _* V2 u  I' K+ d
* T$ C% i, A2 g9 ~0 ^9 H
6564233
, B) W' |$ F) H3 G9 \' N Autotest failed
& r% b6 {1 }# {
& d7 D+ G6 K4 }0 l6564258
$ d3 m# s8 Y/ ~& d: L4 e9 H Instance geometry bodies face properties are not inheriting to Boolean target9 ]) O( V- \8 H- {. }3 ~) O
+ a% Z, o) E/ p2 _" @% U0 s
6564285
3 B4 l1 `+ l0 }$ L1 t/ k Flat Body displaying in Model refernce set 3 J. |, I5 V# M' h8 N# G
* s3 S3 {$ `( w65642867 J$ _' f6 w1 \9 W. j
Internal error pops up while closing assembly
5 t& D1 ?6 _2 o% J: r. g4 H# b5 Z2 S * L, @8 T1 L4 ]' ~
6564301 8 Q$ l6 u) S( U4 g# u6 P: U/ Z
An not add a plane or sketch to JT file (Facet_Xt-brep reassociation) " G  \$ L. o# `: w9 C/ ], f4 Y# v
. \; i; N) T- K( F! v6564728+ _  ~, u1 P" E6 I2 }
Assemblies performance unacceptable in assemblies with exploded views
! p% x/ r; M0 O- V  J/ i! x5 q" O
9 M( a* |) f* K8 ]6564759( s4 W  f) I/ r( m% C7 ^. I. W
Export Outside Teamcenter: An error was detected while initializing for cloning   v+ A6 n/ c0 d; d! b
2 |0 `8 Z1 C" a1 V) P6564784
! w' J( A$ X& }7 D. G NX refile f ils with Memory Access Violation Error
2 A1 T- C, E6 E4 |, c( v1 q8 z 4 h1 p$ _, z. T. d9 ^* V* \6 g( b
65648344 e& v* g3 j& \  o; P
SLED__80025 -- Bad SubopTreeItem Data error after delete in tool path edit
- G7 l! q8 N' e4 z' C , n0 ~$ K8 g: ~$ w. d( c5 k& m& w
65652612 J7 e- v1 y0 i& ]
Invalid guide string definition error whilst creating formboard drawing * G6 r5 J8 D1 J. A- U. N0 Z+ X
+ U, z- _+ G" L% b0 W
6565280
5 j: h  Y2 B. l+ K- Y$ h5 D Unable to open a part "failed to load part when trying to load object on demand"
7 Z- {$ }/ I3 R8 S0 w
! t) l8 ?  g8 ~# E4 {/ |# \6565588
* F4 B1 z# Y' t. s; B9 N Suppress_Unsuppress a failed delete face feature makes it succeed
3 q, X$ B' D! g* H$ o, C
' y7 C; V# T' B65656032 a% I* K3 g/ t+ m( [5 A
REGRESSION: "View To Model" is not working for curves 4 G6 ]% `4 t4 G" v. q
% h+ W# I) C1 |* c' _
6565611
) B  l- ]$ [- }, V The extracted face cannot change the color
$ p+ Z* @6 d" {
9 I, z7 N, ~" e  X( M1 s6565619% V" s8 `  q+ M& z# J/ X
[5] Drafting NX755.0_241: Autotest Failure: Drafting auto-tests are failing with5 v2 U$ @3 f7 p9 ~) {. R  U9 m
, d  r+ H* N0 u$ N3 v6565645$ [0 e* f5 Z+ F) {8 G  O0 r9 ]
SLED syslog analysis: General Fault Exception when deleting object
7 W8 D9 R) M: x, k; ^/ P) q
1 [) ?8 ?# h" h' h9 `" V/ ]6565655
! L$ v) e' [, G" V% V Can't load hand shape library of the attached part
  E+ V/ o1 P6 M2 I# @ ( Q' I, k- Z( Q0 H
6565689! W7 q9 _& q, M$ ?% W6 z
Autotest RoutTest_general_stock_fold_and_twist_2" failing with Exception
1 |' O$ ^8 C4 r8 n, `% e( `- T
6 ^: ]2 `* t2 Z3 ?6565735
9 {5 b3 Z; V/ C3 f* U9 @7 y; O/ w# ~ Assertion while charging type of Slot to Sheet Metal slot
  E7 p4 p1 \4 ]& j; W
3 }$ [& Q- N) L9 Q/ @9 w. o/ Y  b2 |6565843
5 M' n; T. w' z! S$ d3 H6 M+ G NX8.0.0.25 FPV: I am receiving an error when I attempt to use the Face Repair co
9 ^( T/ j8 |1 Q1 A
- e7 j3 A. @  D4 z7 B9 m/ u; |5 e6565844
) G7 @; R# |& [) p% y Large Assembly Drawings won't open 1 B2 U- o+ f8 G
1 J. m8 \0 m6 j* t# h# S
65658527 C/ m- g& @0 O) N0 o  @# t
[2]ADM ugnx755_1 Autotest Failures:Nodes differ : original value 12 " o; i% |7 W8 l  k- u5 Y" n
4 }8 {" \0 a  u6565860
9 s3 ]) p2 P" L% s7 T+ s3 Z [1]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 20
& @% A" v" q5 d
/ M0 G9 ]! b8 U: y% f) `6565869: v, @6 e3 y2 G8 o/ W2 `
[1]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 3
3 z; ]1 k0 j6 _$ p! D/ c- [
& p: t) y% r8 X5 S' S) w0 o8 ]65658736 {# w4 }$ e$ Q. ^1 @
[1]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 6 0 l9 V- z: j3 ]! C* S% a; ^
+ _5 s, F  |5 \* [2 Y65658789 Q, J: ~! w4 c+ F9 F
[4]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 32
& }( l+ A+ ?+ d6 X: U
/ i* s9 g+ w9 o6 @1 P$ p& e; J6565886
* Z2 k) `  v- E* p% r [1]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 15
$ B* t/ f$ K: x' S4 F9 C + W4 l1 I, s7 ~
6565892; l% ]9 w/ ^0 B6 h6 F
[1]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 12 ; t. q, J/ ?. a: s, d2 }6 X5 }
" O" Q1 r  x# T" _% L2 K' R6565897
- W3 O, _, z# e  Y [1]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 9
' L0 O$ S  }- H! F* e* Z3 K
3 R8 ~2 V. i& x" m5 j$ e65659067 J: Z, l* v  R- M9 U  g6 `' C
  c- y, N+ B. [- b
4 X6 @9 d3 Q, I- {) t; o6565908
! p9 C6 c: B: l6 z+ p [1]Sheetmetal ugnx755_1 Autotest Failures:Nodes differ : original value 8
2 p8 j/ G" r- R1 ~1 N5 c 2 S4 J" I2 J7 E, H( p
65659248 c' L" O5 G$ V7 D
Plane in a c= omponent is not being moved along with move component operation : K! u1 f4 o8 N3 I. o% v' L
; ]0 u  g( E  U2 J. L; C( G1 R
6565985: Y2 L; z: [2 S% ?' c. Y
[1]Modeling ugnx755_1 Autotest Failures:Nodes differ : original value Linked. o4 [: m' P) R" Q4 E" t" a
. }0 A9 X. u; J* D* q
6566044) W; D2 u$ q/ S" Y. p1 \0 _
SLED 8.0.25 EXCEPTION +++ Specified object 37610 is not a PMI object
0 Z3 g5 u/ |9 Q) m( n+ l: h) L0 E
+ q5 q; h4 t/ s6 o3 |2 m3 S2 e6566180+ x) }  S" D) A) B' ], t7 _4 d* F, C
NX abort when Edit display
; O+ m  |; t5 { ) [6 X8 f9 e2 N7 p% S
65663751 q1 r8 i6 c' S% z: s1 d: L7 {8 k
uft_rte_functions failedEXCEPTION: Error code 1525080 in line 2257 - u; v) v! t) l* R$ ~
( z+ b% {0 I* a9 |- T% ]0 L; F6566456; B0 _% e/ [$ Y: P0 _
[4]Modeling ugnx755_1 Autotest Failures:Attempt to perform an operation on an as+ k! N' z( p* E" {6 d2 {' i' G! k. F
& _  Y2 B0 f, b& ]; I4 o+ V. V
6566719
9 o# s7 d8 o' ?5 s1 t Check world fails after edit
# O) t9 \% W. ^9 d7 E2 `
5 c, z: M/ h: n, Q1 e$ v6566950% E. T5 L+ }3 x6 C3 N
755(2):ANSYS solver:CaeTest_solver_export_ans_jat:iffs in solver files 4 @4 g' A3 E5 d0 L* L% C2 y7 q$ \
$ H% F2 L* z, I2 A
6567053
1 ~" F; [! T0 H During moving component, the plane object is not moving ; I4 p' s! s6 G1 H+ {
+ P( x& o+ {4 |: Z6 a, `" i6567068
: V% r* M; d6 c, C# y! d. b Component groups rename when added to another group 5 X3 N) O# a& ~" Q( M
* r) I5 g8 n/ K5 n; {% k2 y4 l
65671415 V( }1 p$ u' n' E( E+ ]6 C  {( o
When placing a section view, only the section line is displayed_created
3 R7 w+ X/ {0 W; E) I ) D% q0 i4 H4 A% c7 n% R5 o
6567161
6 `0 Q" \) K' C' H7 g# f* z sco3 libraries are not signed
  X3 i' a& ?& @, O
6 R; f. t* J- G6567517
( P- d: j0 R8 z Deleting Trimmed Sheet parent result in exception6 C1 h5 J! P1 ~* U; S" z# i5 \3 z& u( W
* x" T- {( C: w  p- S' j! ~
6567734/ I% K* d3 m" j3 F+ S2 s# G
Zlevel corner does not produce expected results
' ?' E0 _( f/ Y6 }1 Y  n9 y1 I   Y, l8 B- N1 p
65681767 Z, F9 h4 ~* H( x- s6 r4 s
Cannot simulate machine tool kits 9 ^9 @0 V) R8 D  s' P5 U1 W; o
! X) Z! }' ^- {( |- W# @* t- Q6 {
65682182 i7 s& g5 p1 I9 r
Strings &quot;metal stack up" in the displayed dialog box is not translated 4 E# l4 p# U' a
/ q, `2 g0 F/ l, `6568337
5 n8 W* q! h" V! h9 g Collision _TOOL__PART (GC) is not supported for ISV with external NC-Code ) l/ J+ J# @0 j3 E8 g
. a% V& d& B  b# Q1 K: _6568344
; O  w3 K* l0 t [1] Drafting NX755.1_243: Autotest Failure: Drafting auto-tests are failing with. O$ i4 L4 N% K; c
3 V4 F2 i5 Q. X( n6568357
1 s' w/ X% K, ^) w% P; ] Appended text of ordinate dimension is not getting displayed after undo_redo % I2 X( u: b! p8 d& A3 v
* @8 r0 M# P% f& [6568805
. s# G) l% F1 r+ n/ V Remaining discrepancies after 1 finddisc_apply - 2nd resolves but constrnts fail& }- L! _" L$ A$ L. u0 F
# k9 {  ]3 s0 \6568865# h) m+ u( _3 v
Probe tool defined with adjust register 1 has h0 output on G43 line. : [( e4 V' ]" L2 ]
& V  y  d% }; p+ x0 G& H- g6568888
2 \! {: I9 G( J: V! _ Exception error is coming while copy pasting of PMI chain,baseline dimensions 3 l* n& g. o4 E
; [  L2 j- @% C. w  N' Y& c9 Y" G( T
6568912. T6 k2 X9 F/ a7 j# r. p
Regression-custom standard part was added in wrong direction in NX 7.5.47 s( V5 p8 h7 G- W9 K
5 M7 `" z. s. |. [9 W% d9 c5 S
65689578 ]2 K3 h& T, `
Incorrect thread operation selected
9 p) f4 Q2 v8 |; P
( b( d  \& L( k) V6 d: v5 O6569020
; w( C; B7 ?+ v) R8 P8 Q View will not update without errors in the log file
, [+ m; t  A% M- v7 s1 S
+ K9 G7 |; n9 D. J' }6569025
* r$ o- ]9 ?5 h# f, y$ I2 V Refresh Teamcenter information has performance issue and inconsistent behavior & e+ S. H/ F8 o, b
. X+ I' J& j% n; r" i6569111$ D( i; P& d: f  h
Getting 'Handle is invalid' when generating a Cavity Mill operation
/ s3 C9 ~$ F' x) D, \1 ?
: n8 _# p8 p/ W/ v: _; R! @65691165 ~# m- w6 G; F% z5 v/ P6 C  S
Unable to delete any features from a specific part file
# y' a+ a/ [( r0 c$ d" [! P7 @' V   G. G; U6 ]! f2 v
65692116 [% F" |5 ~" ~; }% Q  o/ i' `
NX takes a long time to update since upgrading to NX 7.5.4 ' b% }) s' `, @  {4 w4 \$ i
2 p: k* P/ ~1 E! ^6569229
- a, Y3 E+ S; K* M' @* S Assembly fails to open, even with load no structure
2 n3 J/ f$ g7 g# H$ a6 f 3 l. [9 k4 `4 b3 W2 [& |8 b: a% X
6569367
3 l7 B+ v7 ~& n5 \ Wrong feature operation name in CAM Assemblies
" z6 `7 ^/ a2 B 9 |6 I4 G0 d4 I5 u6 C
6569765! S/ t; |( Y+ o$ P, p
copied teach mode op from part to part - throws signal 11 when editing - NX752 OK
% w! L# y# a& X  _" f) p. a " v" r' ^  c0 M: k
6569857% p7 R- u4 G# K4 M" V% G1 K' e
Measurement = points are deleted when generating program from 7.5.2
% y6 J* F3 F4 }6 J
2 Q# y# H& f. F) _4 R" W. Q6570093
0 H. X5 M- I; q$ s* O ugmgr_AOD_t5 : XML comparison failed
  V' O" ^+ _, E
. _4 h* {7 y$ z# k6570213
9 J* A7 u! m( S1 a- { Flip tool around holder and reorient tool produce incorrect results 0 @" v. l* {) t! ?1 g) w
) M- K' E  [$ I) J6 H0 v
6570544/ c0 ?1 X/ h  n
suppress unsuppress Sew parent of Join Face causes errors 4 A6 Z; g' L' o' w
) b. P6 X& l- L6570626
. [$ F. I& p) E+ z5 t Error: Part not loaded in the session - Save As after adding Release Status 1 _) r8 f! I( b4 f$ ]
  r- G6 c6 U$ Q; Q5 |" r9 }1 @
6570629
# F' |! |' r7 w6 R Internal error attempting to open a file
% y. ~+ `2 K, m+ B, V. s' O6 V* L
" T7 p9 }; i' C7 q0 M6570662
' V$ H! X5 [! P7 r, [ Assertion failed occurs after specify the face sets
) g& t1 c1 Y: X8 y2 T) y. c$ H ! K( E, `3 q. c2 H# ?
6570666
' B6 a7 r$ P- ~3 i& [ Show Correlted Point does not work 6 B0 G4 f% X: F& P, J: W3 ?
$ c. W; P; i+ B65706840 I. o$ Q# r: a$ G
Only one SIAO is created when multiple faces are selected.
+ W% \$ d! r* s2 Z/ \( E
9 t+ n9 X/ T) G* h/ l( u6570751* ^" ~8 x( f% q* z' o
Internal error occurs when paste Extrude on side face of solidbody
* d0 h2 P, o& P2 J" Q* B0 d- f : A/ ?$ h+ k# x3 w  ?) Y! T
65707706 S8 B2 b  l9 H5 s
IE occurs while right click Distance Measurement in Dependency pane
% Y2 L, W# ?% L: ] , m9 @3 d9 r+ y& ]$ [  V8 _
6570787
8 \: D- E( O. \ OM world checks failed when Unsuppress Unit
6 m# C' k. `6 N' _ 6 I9 T- f. ~# g0 `( A& i& x
6570798% q' T8 F# E5 D% k/ S" c
Wire EDM Post does not show WIRE_GUIDE UDE in Post Builder 9 E+ `  N, d" ~) k; u) A
2 |# A' n% h' J+ s( Q5 M1 u0 r6570824$ @! [% e' ~1 [  ?0 F: m& Q
3 Axis Mill Post Builder MMPM label under G Codes tab should be MMPR ; Q$ n0 ^  A+ J3 z
+ w* k) i# \- u$ v. @( R
6570826
+ J4 L% Y; S2 Q7 M$ L$ { Selected axis not getting remebered for "ath Locations" in Flip Components
; K# C) K8 g) S' {2 b7 E3 \. d
: l1 l# f9 L. F2 B0 t6570833
6 ]& [3 t, A3 k# I6 I3 [7 V  H: Y cutting on cutting of counter boring tools results in incorrect collisions\ipw
, z7 m& B9 T0 d3 ~. K4 V- x 0 H" w7 P2 g" M7 o
6570930) O, t3 l+ S; a
Unable to always select component nodes in AFEM$ D$ G7 L8 n+ Y+ K* w
9 F0 a7 i3 ~; A4 E/ m
6571161& W, ^1 ~! _, O, @1 {
  Errors between NX 6 files 7.5 7 E& Y- G- J/ Z" c
7 d0 N7 k: y; y& n; ?5 W
6571342. r; R3 A2 [) O. {
Check world addendum surface feature , it will appear error message
+ l! c; ]6 |3 _- Y; y6 u: c 5 v$ T0 B3 O  ]+ z
6571359$ B0 n. t  O# v  d2 b( u2 U0 v+ V, W
Internal error while using File --> export DXF_DWG
$ L4 r9 L: T3 D0 l* t% h! |
0 {, A% h( |5 o/ h1 u! @3 N; m6571510
' I4 B% p3 T+ \, p Some parts being removed from assembly structure
( O9 Q; U" K  t
9 P. c3 r! |# d9 ^; L6 U& M6571512
0 n% p7 o/ C, `2 P( {# o& t2 v [1]ADM ugnx755_1.481 Autotest Failure:Nodes differ : original value 4236.8409806
- C' |3 c' ^* A/ j; ^/ p . p3 A9 f* m( C" Z
6571538$ k  w$ y$ y, ?7 V- x9 a1 H& x# }0 H* B
[9]Sheetmetal ugnx755_1.193 Autotest Failures:Nodes differ : original value 2   p, ~, P$ E4 N! U8 u* v
2 ]& K2 @/ D3 T. Q: V1 \6571542
2 E& t6 J. Q. L1 W [1]Sheetmetal ugnx755_1.193 Autotest Failures:Nodes differ : original value 9
' K' Y/ E+ T  b* {* Q7 ~
9 r3 a9 e* j# j7 A6571845* H2 G  b6 s7 `! E$ J  J- i
Replace a connector, update formboard - was 0, now 1447 failing constraints
1 [" v8 [% [& o/ V, h5 M6 v% a , r; C+ I, z6 B+ M( I
6571871- s* p. w6 X$ f
Getting internal errors after running a grip n_c and creating new program group
! }9 P( s( N; o: r3 l
0 }4 F: n! Q: W" S: O0 Q8 q6571908/ ^2 L1 x& T3 W* z# I" N( C
Generate an operation twice during an edit causes a crash on flush final retract
1 `8 A' {7 b5 B2 l6 A ' r; q( J2 f" J; @6 Q
6571923$ T3 x5 P! K) b, ]/ G# _5 Q
Siemens 840D Post PB_CMD_output_delay 6 l# s3 ~7 p8 Q. o4 k
2 j% S0 |+ j) O( ]. c6571940
! a# H2 ?& }2 ?" L. E  V- B5 z8 c jat_Assembly Constraints_Wave_pr5776088EXCEPTION: Error code 3520033 in line 4
  }2 c& R3 l1 |! L4 A / T; C' ~  _% x# p: o$ |* L
65719895 c2 J6 w0 Z" H5 O4 V' r4 q7 ?
Can not create steel support in NX 7.5
8 h" X+ C; j: F% K0 l   {/ J2 Y$ o0 N  F/ h
65719919 T% t( Y+ x% x3 O* ^! H
Cavity mill issues
4 @) z- p; T; C8 K3 L' Z& ?# ^% ^ 6 u. a4 ^) `  y) Y1 t
6572006( h/ G- G8 j) m1 U9 W
Error set refset to empty with comp filtering on# g7 f/ q" ]2 ^0 C! J- ]. C
3 C% f5 }8 d* V4 T. M6572007+ k2 n7 z# e! P$ b
ugmgr_QRY_t4 Exception c0000005 occurred in unmanaged code : P0 w8 f# N; r
) X* a' O; U4 z  O6 _' [6572072- g* W: {5 s! D; |! C
FIAT : - Autotest "uft_mateconv_20965003" is running approx 4 times slower : o1 X7 b% |: x7 {; _3 ?
" K% c8 ~! f1 ]& a4 L( ]$ O% }* s65721331 T; Z. }( g- W- \7 r4 M. \
Drill operation drills too deep
; O! u' Y; ~0 f5 t % f' r7 d" @) f; B
6572511
0 ]; h# D( Q- H Internal Error when reversing placement face at the same time changing the endcu
; _' s1 _1 Q8 p- _% z ' A; [* m) [! n; T' E  e2 h
6572514% z( c2 _5 {! f5 c1 O5 W
NX 755.24 Build: update Tet mesh with SC03 environment->internal error
. M1 ~$ n0 z3 p' p * G" y) R7 @3 D9 U
6572548
6 W' V3 j/ U4 |# I: t2 _5 | 755(2):Core_TCIN:CaeTest_nx_tcin_jatiffs in AssyFemPart value ' a" x5 L5 Y* d" {2 l! [
& Q: ]6 t/ t$ A( L0 ?. i
65725598 N1 z# U& h  I
NX 755.24 Build:'apply' not work on the SC03 export dialog " S8 w( W9 Z, Z0 Q5 m
* d8 Z  \6 @% D8 q5 d! U
6572575  ~% a/ L1 Y% A: ^' g  h9 Q) e0 t
NX 755.24 Build:with unsurportted 1dconnection, export sc03->internal error ' I! ?- k, }$ O6 S- `
! v5 E2 B; v6 p+ C# F! z65726333 H+ J4 |8 q! d
Error on selecting segment in assembly having SAC overstock
0 r" `/ U; {) F+ v  b4 ~' w' P0 c
* E% k& ]1 J- j# U/ J% D$ \6573073
0 l+ I/ Z. ?7 ?6 ]* h  [( Q  Y NX 755.24 Build:node conflict not reported for afem and export anyway->incorrect 7 \5 M- [, ]* |. ^' f, h4 F+ v& O  U
5 o: ^/ l/ Q% r8 A7 S4 n6573100( c2 }3 |( U$ y/ F6 {1 |
Show Result in tool path transformation fail to display tool path # f5 a3 G* ]* H% U9 x, A$ B& G
# S9 s9 I" P! W
6573105
' X3 `: \6 w( n3 s; E NX stop working when i use the TableKey after enter a big value into Adjustjoint
0 ^2 Q5 x, A! H! t6 ]4 Z; @& m & g& Y! K: H. P% p6 p
6573117& n3 H2 y2 ~. c
IE MAV on creating overstock on non-circular SAC stock . w2 l5 U  R+ k! ^
9 Z# H" U4 W5 N6 U! u
6573120  l3 t4 L+ ], z! K6 h! c: L
Standard Part Error, When operate Set Plane View
3 W$ x; c3 D8 ~3 S- _2 }  U: p" T 8 d" A4 L8 v& N, v/ l* F
6573153! a9 Y6 `9 y* Z
uft_assoc failedEXCEPTION: Test failed with error 677
$ o  ~3 I! N6 A* {  h 0 G3 ?# j7 `! X  }- u
6573356
7 Q1 B/ W& A& X Routing: arclength must be greater than zero
8 d8 R1 Q# @% z# Z1 q+ ^2 P. |1 u , x1 E3 h# N% W: S! [6 b) j
6573361* l4 L* w1 ?  y9 a% W
Alt Rep components failing to load properly in NX 7.5.4. Were OK in NX 7.5.3
: ^$ _5 |2 ~) p) V8 P, t! j3 A
" M6 ^' S; K4 T+ T$ J6573377: g% a( U$ }5 d- G4 r  k2 U6 O% u
No gap inserted between dimension extension line and center mark
5 y# N# B5 j6 P$ W* P
( }5 w& n5 a7 I6573385
) ~& i% R0 ^( u7 ]8 |" a: b 2D Material Removal not displaying correctly in Turning, ]3 {2 C2 S8 a1 [1 c$ k0 L' _
. [5 ^, X" P; O8 G8 b0 G6573392
. I$ T* ~8 X4 h# j/ e- V Mated components in NX4 move when opened in NX 7.54 R* H' q+ X- A/ `, p
6 K, S/ A' b- O
6573411: C% u" W8 D/ i6 @! ?
Reuse library slow
5 t0 W6 U( g- F& B : C; }7 s1 V& p4 h* b
6573482
( J( K( f% q: T/ p7 A  J Cavity Mill; tool machines through Part geometry at levels 8, 9, and 10
- [" m. }& H  ^+ r1 `: y+ T7 |
/ m! w( x- [6 O. d6573539) `4 b. V# Y. j- M  }! I" D
Fiat Rev1 formboard update: 15 components position is failed. 1st time
! v+ H3 I+ R1 l. ~1 [6 s
; B% ^$ ]" K0 p6573544
1 _6 {1 K" z: x2 ?3 x5 K1 ~ Cable data needs Updating immediating after FB creation
2 w0 h' b% G1 @* z + _% x2 `* t9 q0 D
65735647 F( {0 q2 G) B
NX Routing Place Part from Run Nav REFERENCE_ID broken ) @4 ^2 n8 @, h9 t
! P. f' H3 |# w/ a4 `3 S6 \2 t6573579
" m  s$ G3 ^6 z Routing Place Part from Run Nav corrupts the part file
" v  Z) A* i8 L) X
9 V; x. @- G+ L1 S& T/ c1 d7 \$ k6573652
6 Q( u3 ]$ E+ [0 r Internal error occurs when use this User Function dll
5 w3 e7 z* d/ Y8 D! \ ( G1 \6 ~4 x/ j) C
6573750
" `% v6 p2 j: O2 E Internal error after edit feature playback in part
( g4 a2 _+ r2 F
' S7 J. Y8 z5 F& t0 p6573801
- ^9 Z3 q0 v/ z Cannot specify working angle 0 for pocket in MTB
( ~9 _7 J4 O5 b5 _6 Y$ Z' U, P% @
4 I: k& R# h7 F0 [) k  I. ~6574101
0 H0 Z0 a. J/ N! b% l8 m: F Faces are removed_see thru after adding to extrude & N& q- D: j2 Q4 s+ ~) r+ Q
9 e6 u: k5 d; C) k+ [/ Z8 Q6574209
$ L; h1 l3 r4 h/ C/ h7 B [1] ugmgr_LOD_t7 signal 11 when updating facet_jt_body # \, ?  c' H, e# z3 X4 U
6 C7 }4 f4 N1 D2 D6574309
7 c) z1 B8 G9 J% c% A9 p5 k Internal error occur while adding component with remember constraints
7 i/ e7 h; t4 P. w( d
6 }7 @& e( d, w, \6574575
( d1 ~3 h7 S0 P8 V' ^1 C Cannot edit Axis in MTB after select the junction from Graphics Window
( m8 d3 p/ ~0 S; k $ M9 M5 j. p. V( N0 _, K
6574608
: j6 @) `( P! S- y/ X- h: S" Q0 e/ y Constraint conversion autotest for fjj53886 is not passing % ?( a; k6 @3 D  z, O
# n4 t- E; H2 z& l+ p2 u3 U  j65747433 ]8 U2 O% j5 ?7 n8 C
Routing: cannot determine type of stock for specify item. Dialog will not launch
" R* m0 X& R: U/ J6 H% K % K$ \; `/ t" c; X9 u# v! J5 r0 N
6574798% p8 a. T7 \' n' ]' V  @
Search Children in Specify Item gives Internal Error
; L9 J8 M# I* t6 `: I# q2 N
7 }8 M! e& S% p/ s- C1 ~6574905
. a/ D9 F" D; x) w6 ]6 X Point Sub Function don't work for Sevtion Line Creation in Assembly Drawing ) c3 {7 L8 S& [4 A8 `
+ O! r; F. m9 D5 @& s- S& ~. A7 k  _6574938& G9 Z" h* k: o" w- X
Regression in using Part Name Management dialog in NX 7.5.4
0 p5 t; y3 |  C; Z$ f8 G ' q/ w+ t! F( n9 Q' \* _
6575039& ?- f4 {! V/ V  r# o# A  i' a7 ^
Flip comp in formboard, then un-route -leads to Sig-11 assertion ; e7 M( u7 u: A5 J) N
  L; J- ?1 \& x  R  W6575142  f  o9 e7 o4 M+ ^) K' \
Legacy IPE is not case sensitive
5 ^2 Z8 Z$ i3 \ 0 @3 a  |6 B+ F
65752425 ^9 U' \. }# @6 A5 n
NX save-as causes "The requested SOA object property is not loaded" error
% L# W$ k3 M- e  {* G+ e' e& T 8 y- q2 \) ?6 B! j
6575331
( C3 g& Q/ G! _2 K( f Dropped Clips in plmxml outputs , g! g- y+ G- t: R3 m- Y. Z
& E  o  L& G2 |( D
6575332
3 ]/ ~% a0 Z& w. H Dropping nodes from the output of PLMxml
' |+ m7 j$ O  O+ c7 N
2 G/ B. w* {6 c; R: H* ^; ^7 V6575431
( F' S, G, T! h  c4 J. Y1 v Check world die tip feature ,it will appear error9 y; ?1 w8 _/ D! Y/ ?7 H
' z3 ?; `: D5 Z2 ?2 X
6575436
& K5 J" }, D) R5 \; k1 W% Q NX 755.24 Build:to close fem sees an internal error after failing to update mesh
! R) t$ K0 ]  ^3 ~# w+ a5 C
* l5 ^/ W! n7 y: _# _: u65754381 @4 k) `' M7 @9 z9 m! W; L4 ]
Product replace feature is error5 c3 X; V1 ?4 @" _
3 C- O5 k% ]5 H6 d6 U& y
6575445
" S: Z) y: f4 f$ E' m: ~9 h" U NX 755.24 Bu ld: undo of environment change, toolbar not update accordingly
" u# G; i2 G6 O) T9 p
- f7 [2 U- U& e- E. L8 ?4 f  t6575455
$ N/ E2 [* A( T) p9 W SLED_7552 Regression Exception error while dragging the view containing SFS
5 Q3 N% `; x& i4 f( u0 _
$ M5 p5 e/ Q- n/ x" B65754830 a2 d! M0 q. a  C% k$ r
Same inputs get different results
; o% v+ ?; E2 w2 s2 h- p  V
, \  r) o) m$ w3 }4 n; V* f6575512
' E) y7 D+ ?+ z1 d Internal error occurs when Open "Open Function Model" twice in FNT $ M) Q# d4 l' V7 s4 A# O5 W( \
8 e/ C; Q1 J: ?  v/ y) C6575518
+ o4 |+ m& l! ] Mark line feature is gray when right click 'Show',not gray when"Hide"
( w: j; K$ T" V
, m+ c9 j( Q- k" x1 v2 B0 c: m6575530& u7 Z$ Q6 C2 p8 R% O
Adding cooling fittings on channel shown error
7 g% ?  G3 }' ^" R5 R* I: d0 B* _* E6 T/ q
3 @% [" T" @# `$ m% o6575560/ q  d4 Z2 I9 m" L' U1 G
Editing of three bend corner with lost parent gives internal error
- Z& N/ l/ U" M+ \9 Y; H# G
9 P! G1 _$ _) B4 r6575569+ i' f1 I6 h# O5 z- f
Symbol line missing when edit Dis Tol more than 5mm! M2 I* ]2 Z" v* R
0 G. _+ O4 [+ a. ]7 v. _
6575580+ w9 F7 s7 M1 x9 [7 j6 C
Regression NX 754: unable to copy_paste the PMI chain dimension
/ S3 _3 ^, S  f$ M7 H  X
9 @2 j9 D* O# h3 T/ i5 |+ Z6575609
4 j! v% s5 o9 c& ^" | FIAT:- Autotest "route_copy_paste_20" to 25 failing with Exception
( d5 ?4 l7 \8 R6 ~# J' O5 O . s* s, O( O. C  g3 W" ~" X8 P% R' ?
6575623
  h9 u4 U/ u# V! m- `4 | Memory access violation during ceation of instance geometry , [7 B: ?/ T4 i
$ Q  L, p% u7 w1 a6575631
) e5 `7 s9 ?. G1 U Exception is given while editing sketch- RM object had an unsuitable OM class
2 F7 t' k# d0 V: L( o ! C9 E7 K8 W; ?1 m! F$ b+ i
6575675
: X; Q; Y" [! O+ ]$ O SignJar fails to sign a jar even though it has been unloaded
3 {1 h* p9 x# f/ U* F9 }% J
, S$ A. u( s: S1 B6575832
. l( B7 [# I3 c8 z+ Z, o [1] nx85_nx8mr ; ugmgr_JRC_t1_refile ; om_verify error
( m# d' u0 I' M& h  F( J
/ D2 V+ f6 X. {) Z6575902! U. d: D) }  ]* D0 G
Unable to rename the name attribute of the port and terminals of a Multiport ; p, I0 j/ ]- a) P  C' L3 W  B
& K7 r2 V$ |# [$ k) ?4 O6575961, H& W# S  L( ~6 J9 E
Crosshatching is making other views out of date2 J# M! e: p" H/ w
* p/ j4 b$ k8 C8 C; G! j3 X" ~65760905 a3 f$ a2 r/ I) H7 ]
Error recovery: create an expression by constant_angle
7 R6 F7 X5 Y7 r* \- { 2 k0 _' C- F% M9 s6 j
65762487 y, {2 v6 {2 n: G: \- C, M
Opening ISV OOTB samples shows part as "Modified"
8 [& r9 A0 ]% ]% E, @
$ c' _; n& q2 ^" |: S% ^6576380! |# O  v9 d$ I
NX 75 and NX 8 custom symbols performance issue
& Y6 `% d; P; b3 p1 W) O6 k" X  d$ b / p9 H7 \* X) G, p1 [5 {
6576399
& M7 `" M) }2 r, O; s Ugmanager Refile reports a successful creation of a TSO file with remote data
; y) |3 k  x$ Y3 A9 P ! }9 l; Q& S; Z4 g
6576593% F4 z; u/ S4 v2 B$ o
Changing Section Reference Set Issue ; t- K: |5 y6 F% i
- b, t5 P" W$ t8 x9 ~+ J6 B- V6576595
% r. O  E* l/ W4 T1 f% A Profile Cutout Flipping 8 _& K; D, m: P! g  Z3 q5 B" F4 S
, l( V; X8 b+ K0 G
6576596
/ Y* H7 Y+ [/ \* N" Y  W, o Cannot place profile on two faces 3 A. Q- M, o/ P, p0 o
5 H+ h5 F. i: V5 a1 d6576597
; F7 }: E& m% A: U Part Corupon with Profile
, D4 c- b! |0 q
& V! K" I2 }4 v7 U/ B2 O$ w* [6576598; F8 @% f9 ~6 z9 I% h( _" Y+ ]
XML Curvature note incorrect " J( r  J2 L+ v* s
1 X/ S  p1 V; r: v5 j65765996 U0 n0 n& C( o3 M
Creating Multiple Belts Invalid Body
7 z$ W# Z) ~  q: } ( G: E$ o% u4 |7 l
6576600
: b4 M2 {5 }7 K: s. s+ b2 C. c Cutting Side Face Incorrect # H5 S3 C' S, B5 m+ u
/ n7 x3 h. _1 ?8 [* `, [
6576611
% r1 P2 Y! a# j2 b! }- { Minimum radius of curvature always equals to Maximum value
$ l( `5 d# J/ p9 C ' Q8 Z8 M- A( w5 ^4 k
6576629
5 T, `8 b1 D, r# ?9 h- W! u9 h MG:Internal error while Make Unique for sub-assembly with constraints & Z' R9 X& _( J0 O+ W
: R( E; A# K; ~  Z- B  Y- u
6576708' d* S! T: U2 ^( V- M' Q, T+ ]
Marking Lines Incomplete_Missing $ S( S4 u, d5 ^* @# K9 [" l
7 W' S" }& L+ J( _5 U
6576802
# y3 s: D, j4 ~' o6 h& i9 x- {: p; { [1]Modeling ugnx755_2 Autotest Failure:UGXML Fatal Error at file # w0 @! B1 }( g* B! L6 |; U* Q! n
8 g, l! ]: W" `' N65768188 x. Z' k+ Y3 d& i- a
Selection Order Profile Problem 9 A& o$ }, V! ~' B0 x
' o9 E* T" I1 v# F% O3 Z9 @
6576832; _- Y- O7 R& O) \! Y' s8 O
Profile Cutout Invalid Section String Definition- Q/ Y- j) V1 c- c
# U2 I. e, Q0 q- u4 |7 f7 m/ R
6576836
7 {( O4 q' r6 t# c End Cut 300 Failing 5 o: f# _. b+ [9 [" u
5 z& o2 H7 D: @, V% q
6577238
# x+ s+ H9 f# n Assertion followed by unexpected null pointer error after replacing compo.
* z  }! h1 Z) Z7 c& r( a1 ^5 @, O1 S% i ( `3 l7 @3 R: B( M- z  l
6577242
0 ~; ^* Q% ]; e, N) l opposite cutside missing after surpress_unsurpress mark line feature   ]! `' `( J" M( ~( Z# s
7 z7 p& X1 r& c$ M/ y
6577243
+ E+ D/ o5 {6 ]; |$ B; S/ c0 ] Assertion error on updating formboard 1 Q5 n! S8 F- H/ d+ X6 J' K8 {
; N. A2 f: e; T4 }6577249- f% {* Y. E0 u  \$ ]( u+ _
NX gives Assertion while using function update formboard; Y! b! h3 d7 d/ A: B; e
$ z. k  n6 A2 M/ ^6577269: k6 Z9 t& d. a4 C
Endcut Cutter Body Too Narrow to Complete Shape7 D' _) {7 x7 T4 }$ K
" S5 |  [& g8 W- m. s; V6 U! g
6577287
8 t8 X( O  |9 {5 U8 h; f Profile Cutout Not Updating . w7 l2 _7 D; ?* @( b
  S  v8 a$ y4 ~8 p) |% \4 g
6577291
( Q" ~6 Y4 E! R, D( b Profile Vector Direction _ Missing Face Reference
* E5 f! f- N% h4 [& }/ V3 {# t+ H  q
- v! x' q8 H! q7 r1 W  W/ k( G65773023 y0 L% I% c( x/ m
Profile Cutout Boolean Fails
* y9 F: D: r0 T* Y / j, A( E6 A0 R6 h* f
6577310
  @" b1 Y% h+ v& K1 c$ c- { Support Material Attribute 3 e- f0 X3 G3 j, [3 r
* m& }) X4 z5 e  A+ s
6577316
3 [2 w9 s0 U8 \" M ISV Holder Collision check agains IPW does not work if 3D Tools used ! \4 N; {" V0 N
. W, o# _4 d: E
6577331
6 [1 t: g# p9 h, k. b Change of transfer between levels with Standard Drive cut pattern 9 w; n7 s6 _3 N
' O, f2 i, O" e6 @% k& i, x/ }( f
6577502
7 m5 I" K- [- Q; C# {# p7 T PMI associative face highlighting fails for promoted body
' J# S* r% S- {# L' y
9 }( f8 a, k9 C3 p& x' H, U6 i6577631$ C$ G3 @. f9 \. N3 |# e. }- C4 D
PLMXML import not working for CHS created files
5 G# h  S( _8 m' j: t6 Y+ k
  {& P8 w8 P* e/ d+ V( g3 Z65777446 b+ }! P# _7 t* n& H+ o
% w2 ?9 s, M+ R* O) u9 p$ P
0 g- [$ d0 E/ V6577800
" Q) i3 I3 G& N; X) {* W On Machine Probing cannot suppress output of T work in all probing cycles
+ n/ z2 P( D' H; g) |# I
8 ?; W9 b( j3 I9 p6577812: V+ c+ F9 @# \9 {8 o: Z
On Machine Probing, incorrect move for internal cylinder 1 _8 z; N" x! c/ u
+ t8 t4 m( I9 ]& }9 O8 ~6577813& }3 _# F, V. R& j/ i" i
On Machine Probing External Cylinder crashes3 k2 m* T" m; k& M
. U' A; H5 i% k5 J3 B# Y
6577845
% o  W  m0 B  u PYTHONPATH in ugii_env_ug.dat is incorrect
' J& Q! G' U5 s: i! l. S
6 E# z* X1 l" d0 U& k$ t6577881
! Z3 p2 X( p' y. r' } Regression: former face attribute missing when select other face on same plate
! ~  A5 _6 z' S 8 ^( F9 z/ F" ?' X
6577966
0 \# A. y9 A  C. G, o  z Patch_nx754.5 :Autotest "route_copy_paste_20 to 25" are failing with Exception
( n4 T) r: E+ a! X; g
# g. P, k" V3 |  B. ]! x; T" j6578081
- o; _9 Y5 W8 [" Z Fiat NXOpen: Slack Spline Performance problem. NX chg 3 sec; NX 7.53D2 min . p1 |" Y0 W0 ~! `3 q- r
7 K# p5 e4 a8 l1 P' i
6578102
# u* L0 s+ Q; J* f Fiat:: ;Auto Flex Clamp" not working; m  J7 ~. ^5 {- P6 l. V
- d5 `( @$ \" C+ G
6578110! W9 m4 ?8 n, }" q
Once top surface is selected it cannot be turn of, the flashlight won't gray out6 X, t8 p2 Q% X* n  O: ]: I9 K# E
3 D3 u% V+ r9 P+ ]" M& q6578125
% Z* Z8 G( @8 {& k FIat NX Open: Slack Spline min length is not correct
( f1 e3 F& [4 O. d" d3 D% m7 R5 `
; d  M# F* O& Z# ^3 f% l  v' u' ?8 M65781733 u6 @  ^6 [5 o6 M4 \# A
Fiat NXOpen: Fix_Connector only allows 1 pick. Needs multiple. Is a regression( e; C+ L: G5 J! p# `
# K- H% u1 ^# a- J
6578260
' Y7 b) w: y/ }5 P  f0 g- v) \' @ NX crashes out whilst updating formboard 6 K' Q: y! z- ]2 o3 r+ b
' J/ u! t9 r. r' X6578353
" `. `5 B4 t6 i% n$ n; o( a Can't get thread callout in viewer starting with NX 7.5 - m9 \6 i: v6 V/ H5 z) C9 j0 z
) C; |- p" X6 @4 I" ]65785584 Y" U$ D# C0 J$ A" N" ]1 w5 p4 G
Examine Geometry Internal Error
3 V& t! O3 P7 i ' d) {; O0 q# ]% B5 J
6578619  M- i0 V7 h' p5 W2 ]* \0 d
Feature arrow visualization direction random on custom feature types
2 `4 |" X6 \% A ' g4 f9 }* |' W8 R0 n! _- S
6578653
0 a9 p$ a- Q+ R: U! v/ u  O Tpdate feature recognition marks all features as deleted on reoriented component
1 G, s! e+ a/ i6 ?! [; h7 d6 p
8 P0 R% c7 g4 q* n6578660
* W6 m0 p% V5 P4 a) @ NN Ship - 0 facets in subassembly l_w bodies when loaded in context ( p. ?# }0 K' u* i1 I# M' v+ w5 u
5 y: Y) z. ~7 H3 R4 w. {% F, x# i65786859 A/ `( O, l# a. Z9 U
Making changes to the machine_database.dat file  M, ^1 U# `& V8 q
8 L! P0 G* Y: @& d) H
65787143 _1 f2 B/ P& s# K
Variable axis streamline with optimized tool axis returns error " e2 L9 w: P, y6 u! p
" i* H6 |- m2 w- G1 }* M
65789062 j* f8 Y2 T/ X- [% ~3 Q% J3 i- Z
[1] nx755_tc81 ugmgr_EFF_t5 ; jaformat and plmxml results need a look
5 E% h  B3 Y3 [
1 J- M( B: ?0 N1 ?6578939
, a  U1 U; [0 U, S/ r# N [1] nx755_tc= 81 ; ugmgr_SVS_t55 ; signal 11 openig svs'd part - x) H6 F4 F  |- D' t  P0 {' ?  F
$ t& E4 x; T% k
6578945  Q9 x5 q0 }; {4 |
[2] nx755_tc81 ugmgr_SVS_t57,63 ; jaformat xml difs to consider
9 v' a7 G' f( f- s- f! Y 8 Y' j0 b: G) [1 u0 d
65789705 y; w0 y6 G. k; C, ~
IE display when create Profile cutout with two nonplanar profiles in assembly / V9 [$ P5 R- U. t9 ^/ ?' h
7 K4 p3 n7 K) E
6578986
  _1 |# H/ U5 \- t+ x- T Trim task feature error
( h. p3 k1 i! n3 T9 s - q3 z" V( A' ~- P5 ~5 D
65789987 X) l" i, C9 k' [8 w! V! ^
755(1):MAYA Trasnslators:CaeTest_append_jat: LOCAL cards Reversed " ?8 B& W$ J" n' B: N& @
+ Z0 K- j0 `% c: [( |% L+ i5 z
6579003" Q& D: H; G5 M1 W2 i
Internal error during start of verify : f0 x! [3 }, u/ p8 F
  @- J: }3 y- D& f5 @) @
65790473 S9 a, e* P  A: j: T( E
OM check failure when AutoTest is played after a build.
0 r- c$ J, A4 F1 Z1 S, k' t% B
& {1 K# c# w7 v/ }* r6579052
4 B7 ^$ L, \& Z) { Internal error when create profile with limits and offset on nonplanar plate
1 g9 O: J- r! i4 d& E5 f 2 J( q$ ~" R) M# n; }" s
6579059' L1 ]9 _0 R: j
Internal error while deleting registry filters  W1 N5 w: o8 q
6 ?5 U, ~/ o8 u0 p) o) d6579062. L) g) w$ Y2 S9 t* p: Q$ g! F! C
Internal Error while adding proximity component group in session compo groups
* _) s: q5 ^$ W5 X3 x- l
+ b! O- u( v3 x+ y5 C6579066
- J2 H' ]9 v1 U% H1 w Internal error while working with MFN filters
/ \* {+ w& l+ p " `/ J% ]% G7 T. D
6579363% Q4 w, q; E9 l7 T$ k
ugii_env_unx.dat file entry for UGII_JVM_LIBRARY_DIR is wrong
+ V9 s, @. j! A5 N3 Z  g* q! h
* w# G9 S3 x! x! F6579622  w4 [6 P0 y! f' A4 q! ~
Autotest failed on win64
7 \- @# P  q5 R5 T2 d0 { / n# N7 P  q: s) Q' K# Q6 b6 N
6579630; g- T$ U6 B: y; q% w6 _3 P5 R
Heck world error after forming insert module in PDW4 H! Z3 q+ w# V( h; n4 \
4 V4 T( n" _5 T0 l: |( O
6579673
4 _' D+ k; q4 B! M2 b. E NX 755.29:inactive mesh-mixed_order_pyramid is exported also ; @3 S* C* [; s9 e: N& A3 g
: h0 J% I! c8 V& t: F! J" v6579849! {. p: ]9 `# p! G: B7 [' x
Infinite loop upon accessing ANT->MB3 - out of memory - l8 H  Q7 K$ ^- \4 \% S; C
* V$ z6 ]7 y4 p& X
65798806 N: m, p% ~. `
Device not added to tool view
. T6 |! B' I& R) F 1 u6 g" W+ F/ T, f. K7 x
65799213 u( }, g' |7 X
[1]Modeling ugnx755_2.489 Autotest Failure:Nodes differ : original value 0 5 d' N+ _, n  z7 N6 R
( h: \1 E7 X& \- a6580191: n% v' R8 \1 k4 A0 m
Unable to export the part into another part / m( ~# G; {0 i) i
7 J5 z; C  g3 Q6580202
" E" e, x! r, B% d" T [1] nx755 ugmgr_CLN_t5 ; failing with xml dif, name used is different
% v) s1 H# n' `* v& c* ~2 N" P " ]# _) F& W% P
6580245
2 b# K% g" x3 C* S( E+ b8 \0 j Internal error after discard two issues at the same time
% n6 h, P- K$ h' f9 E
- z, T9 H: t' i0 S! q8 z# Q6580345
- i8 S/ L+ o" W4 J: |4 c Autotest "route_elec_spline_path_PR_6044265" failing with XML diff
; e; P+ k4 s& B9 x  S  R4 A, p! f+ s' O $ m- U; h' ]9 e0 s7 D
6580388
& Y; J; z( I; [$ Y7 t ADJUST register is not output in TURRET statement in LATHE_CONTROL op
9 W( t/ Y4 X- C  w" K
) x$ z# r7 L6 D' O" X( s& {6580643( r2 n$ E6 G. d" z
Fails to create view during migration of drawing from Pro_E to NX / V1 X+ S5 u0 g5 E  p5 f; S
/ c& B& _6 l& x) c7 h" g
6580675
3 W+ y( v7 a4 \8 f9 K8 I; N: s9 R [1] Iman_master_form, last_mod_date to 1 for ugmgr_UDF_t1 ( d3 k4 \) j0 |* m  n* g
& a5 S- g& C* j8 p
6580746( `; X; j2 `  i" ]6 c
[13] nx755_tc83 ugmgr_CHO_t5 MAB_ITEMREV_USER_DATA1 added to jaformat.xml
9 R- O7 a: |; C/ h( {& U8 o# u 6 }; f4 R1 H7 x8 u8 D& Q
6580768# H; U" Q! e' Y. @8 s# |. }% W( X. t
After closing assemblies the BOM-view (BVR) won't check in anymore, _* T& x/ \) P( l2 q
8 T9 ]. s) O- F
6580896
9 w; H* j7 R! S* E2 U CamTest_dev_fbm_ootb_1_pf_fw1 fails on count < 1000
; M, f+ J! B# C  ?8 H : W+ q) t+ [# t% M9 d8 M
6580897; ^$ j- p$ p3 J# E
Regression:X hatch_Areafill edited using settings block undo redo shows wrong res
: n$ S$ E3 J; ^/ a, N) {6 C! j- [ . \8 ~# ^) O/ J7 J: L+ f
6581096& `0 h  ~' E/ t9 t7 e; `
Extra constraints are created when promoting built-in path.
% ?* c# d; i  b+ X4 w; r4 m7 O
+ Z9 Y1 l6 J  w# p# L6581207
# C* [- U0 c- T1 k' R/ ~$ w- T4 U Cannot drag_drop copy or export function to afu
/ Y: p* _4 s% [6 j # b; }& I$ f* n5 l% ]( M5 x
6581213
1 b- {% A; x8 @6 Q5 H Crosshatch is not working in NX7.5.4 when Display Sheet is off
9 f' b  j6 r- `7 J 7 W5 u5 h6 Q1 |) E5 f% r# }
6581356
: p& U4 ^* |' m Null Tag err attempting to drag point on path - operation fails ( U* G1 T0 s1 n0 a7 y
1 K( `/ x+ S" y- z  ^$ F0 v4 O
6581466
! M! q8 K) k+ u2 ~% `4 W/ Q- K8 d; ~ Another internal error while working with MFN filters
! @- v9 K; h9 c 6 U  o2 i- K4 x! F
65815196 \+ v' y6 E+ p- |$ X% x
Delete NX Sheet metal flat pattern of pattern face takes too long 6 w0 Q7 r& m6 ?2 a: ]/ b
5 q  n* a  G3 N$ s% e+ d+ S! w( B
6581958
- V- o9 c; i+ b& x) }$ }3 l Crosshatch distorts after edit.
/ r& S( O& b: f+ _0 D9 J9 e
7 ?" w& k/ l8 F' `- U65821698 d. }" D- h) W4 u
REGRESSION:Error after selecting the Label on Parent for "Annotation to exclude"
: z# b1 f5 j. K6 |  k
$ e- I+ m* C# E  |1 w6582225! n2 f: N% b- c' M/ I3 }# L9 _1 B
Suppression of inherited constraints lost during constraint conversion
& y8 y4 u: X3 T6 [- ?
# G. S3 A& F- d8 d) k65822423 y, V& N1 Q3 |: M+ T
Redundant objects created in linked part ) ?7 S; g2 ?5 m1 O+ F  L
& S' p  o4 T# x- w& j
6582304
# h7 u- C) v6 s0 G0 I Replace component does not make component visible0 D4 M6 x6 G2 Y9 A
0 C- y3 c- f7 p% ~# f% k% Y, e65825101 ^: i$ a2 ^. x  r- w
NX 8.5.0.1 - companion Curve Analysis displayed even though curve is deselected * a; K' g3 s# ]" U/ \8 t3 b
* z  f7 E! B7 V, y! q6582616: f2 h* y. J. x$ w5 S
OM check error occurs after edit instance feature in FDB , A7 Y, ^& D  B3 C# I; M
2 p2 }0 s& g2 A9 W% r
6582625
# {( w! g5 i8 ?1 v9 S When select complex closed line in LOOP will show close the program 2 V7 M6 u1 k* V( s5 P% s$ g
* M$ p. Q; S8 _
6582635
7 V4 G3 a# k* l  X6 n5 ^ NC: Internal error while reopening assembly   z. m( U' E' `6 i7 A7 b* U. d
0 S) G1 ~" l- O: e7 R( Z. Q  ^- Z( T6582665
, _7 l3 s" Q4 s, Y4 D9 I3 w. W Internal Error occurs when create a Pocket
4 m4 p4 M1 T: x0 c; w
( L! ]' T0 c; k8 N: W65827079 I* j6 @9 q% r8 S
Wrong error message pops up while cloning file whose .prt is deleted from volume  O2 S( {$ h5 e  g( Z+ f/ P, R8 T
7 X$ E; x, l- v- _# U% `+ o6582742
' M! Y% g7 I$ ]9 e0 N4 W+ m MG: Can not replace component in managed mode, J9 j# O7 V; S- I/ H3 ^* M' q* P6 x
" @* s: `% d6 k* |) T% d: l
6582826" _$ x% y2 a! t7 p; x/ ~( _( @
Inherited Ordinate set name style doesn't change with view scale  b% W3 o/ w% }4 [
6 K% q& F+ K7 {; b3 Y: T
6582832
$ n8 \7 T/ n! Q8 }* d" V Wrong simulation when contact contour is activated1 V) k9 [4 e4 j& H1 B, e
9 X: b( S0 Q& z) E! H3 E6582972
5 k: n, ]" O* u' O6 k% |( B GEOLUS NX Shape Search missing 3-digit prefix in username
* T4 u  Z) g: R5 _) c# E4 L
8 q0 u4 @5 W7 v: s; o3 H! N0 r65830330 x3 F4 t$ I2 Y" T; o5 V
Parting.prt is overwrittenAttempt to free already free memory in Storage Manager6 |3 t7 `+ c. ]/ u) k
: H1 s, e4 B8 f1 ~' D5 ?- h6583074
; z( d4 P* {: [" S0 j1 k1 q GEOLUS: Shape Search - display thumbnails do not appear in preview window
4 N2 Y! T" M* J' k: Q4 t: z( ~ 3 b  [8 T& q0 ~! Q# y; F- b& H1 w
6583149
5 L' Q, C/ M; T$ U; w  k The user can only enter A angles between 0 and 105 degrees
" O6 T2 P% ]8 v* d0 M
) h0 m* \  g, N1 D- `# M65831552 I( w6 k& {( L) J* X5 ]7 ~% L7 c
Create Edge Bend Save ( U3 \/ s' ?4 ]# }9 F, u
7 C- p/ @- i, U0 l9 Q4 z9 S% F6583244
6 p& ~( g* |( b$ O# r4 j) S$ N Copy_Paste of KF adopted operation loses all KF rules 4 `* _; p# [5 f% R. o3 I+ ~
" ~( D6 @; y5 U( V' [6 F( {
6583444
! ^$ \  V4 d0 n Abaqus deck import - failed to import due to invalid model   m/ F' D+ d% {/ ~  c
) g+ V7 q# r& e" Z, {6583613% w1 W' R: \# {) g' I1 }6 S" e
Regression: Initial direction vector display is incorrect + l- H/ ?  `4 Z7 P( i5 [( v
0 m$ n  k+ }9 O' N* {" S( w
6583698( n5 C1 f0 U: c7 f
Error code 580039 when trying to save prt file after deleting an operation
% v6 c5 S% v' x* u$ R, m# |! p- I; d
2 C- v5 }- d$ o) I1 Z9 ~, K65838662 a$ x$ p8 V: R# ^- N) Z% i
Cannot edit old Marking Line feature
; C  ?" E- k  x2 {/ z3 ~( V
/ \1 c$ \" q3 W/ l6584061
: l% k5 {8 o. P- U8 K UDF fails to insert using NX Open API or KF - works interactively
! o: t8 Y8 I* h9 p, }
; X, A  J0 o2 Y- V4 L  s  u3 `5 p6584307
5 U# J9 S% o# Y& p Joints open up during solve
; E# ~7 s8 m# K* @5 E! C+ J   b; Z8 u+ z7 |* Y
6584314
0 L, c' p% k; P& O/ ]3 m! N( z Receive ANSYS Import Error Invalid node id when attempting to import with Import
% ~! l2 v0 Y& J# z: b& O* }
! l" {8 T% O8 Z. a) Z+ |* W6584457( H$ o9 |+ [9 |
Internal error during CAM session with user defined template
/ W' b* _' m9 l  Q4 p; O) g : f( B0 c! a6 O  {- l, L
6584459, w5 L6 Y8 S. z( L' T" L- H
Use filters list not updated in MFN pulldown menu after delete of part filter
! w& b# ]1 @8 r( M  Q & x  \3 ~2 ]- a+ w& a9 |
6584499$ q6 k2 w4 U$ O
The die face could not be trim when generate the second trim task feature
, @/ E( u8 G' n3 s) I$ t , Y: W4 g1 D# h1 @  d! K; l! D
65852971 H5 `( r1 U- l! G: B* F
profile cutout for knuckled profile failed when change its type ! t" s, X7 Z4 W; Q4 @5 o
7 W% x6 b5 K) h* P( o/ v) [' @$ B' r  h. @6585399
  F3 [% R. e. T2 a* [ NC: Wave data doesn't update if using "Associativity Mgr" to Unfreeze
' `) j+ k& d. c. t - }) t+ l! E# \& T" C, J4 O
6585475
* L3 W2 \+ c) u# J  o4 H: H; m/ V Performance = issue: Adding elements to group using label range takes long time * v9 s! L( k( w$ u
( D5 w) x+ H( u2 C- z( L
6585598
" V* ]8 r8 g! E& [5 H9 { [1] nx801 ; ugmgr_STK_t2 ; test allows improper action
, N- V' ~8 o  ?# C0 F
" Y1 W* B0 N) p% d) g! w! i! F; N0 T5 \6585670* \- |! B  N; e9 F& P7 M
Trim task donot function . @9 s  h4 `; b4 ~+ B& q+ [
; X" {7 l: ^4 P
6585690
2 r7 D8 l# K* j! x" q5 k) I Wrong feed to position in drilling operation
. B8 B7 D/ [9 R; J- X2 \( C  D( p ; D3 y  M5 c! I- m' z9 c+ F
6585725
2 n1 \* |" ~1 s! X General fault exception during post processing
& ^# z+ w* w9 Y( @6 Y
; q! f8 e. n; E# E! U6585727& h3 N% s9 O9 x# \
Syslog exception in copy_paste of operation floor plane
" ]' T# r  y8 \/ K7 C
0 _5 r/ p5 [8 b; e* e6585966
. }) c! r7 A& ?8 _ Inquiring CAM Opt filename from preferences through .NET fails
) D* P, B. V, { ( e' b0 e9 U3 S; l3 I0 W
6586329
! s/ P' K3 h# `: o Unnecessary curves remain after processing Develop Trim Line feature( l1 s; T& T6 I9 _/ M
3 T; `2 H2 n9 Z+ ^1 B6586340
1 Z- j% l: j$ p. h Profile cutout position and performance issues& S; W1 M# @7 J
3 X# D: R6 \5 C6 p  _/ ]' |6586342. H7 w/ J8 ?9 [9 ]
The developed trim line is not on the addendum surface
3 y' y  d! @* s, |- M2 ~ / \7 E8 T' k4 ~, T
6586377
  e$ K0 K, `8 X7 e; L Lightweight reps not shown for some Ship Steel parts when loaded in TCIN % @$ O7 q9 \( ~5 U5 I
) y* Y! E3 p7 g& s; }* v6586447
* I! s' h$ j( ^  _7 A Internal error when doing reopen part in NX CMM or NX CAM
- [7 ^; G3 v* Q% w0 J $ A( z; k5 h& J' }
6586494, y. ?( Z  l8 A1 V$ N: K2 t; F' q
Need a way to preserve special formboard components
7 G& q& _: d+ g' G0 m
% O5 P9 p) q1 C65865073 d" |( u: E2 E0 ?8 G
Routing Constraint conversion creates extra constraints in consecutive conversion  S' z) {" @5 C
. @/ V8 K9 p; `8 W" G65865122 p( A8 z* n1 o6 H% j- E
Duplicate sines seen under Route Bcurve after conversion
9 f# j* y1 e7 b! L9 R' ?# n3 `
/ T  S5 Z- ?8 `& ?1 m9 @$ l  z) a6586787% K: ~6 M! T' g7 M5 r! S( d9 V
Part attributes not available when posting if using sync manager $ d# H* b1 a' `3 h& y% W4 ?
' W) `' A8 {$ ~, I7 w6 k1 Y# G6586861
$ \$ w: K4 m$ r Assertion in managed mode while choosing reference set at load time + }( u: Z/ u8 a7 ?
0 E/ _3 f1 P6 u* }/ g4 q0 ]) R# U/ r  C
65869316 Y  t: r. a) E6 }  `* f2 A3 G
Assertion failed occurs when i select component as Copied Object and Play 3 w: {; i" s6 s$ m" s7 [1 q
: a2 Z$ A( @/ o- [6587205, j5 b0 b  M% t! D, I* \3 r
UF_PARAM_CUT_PERC fails to work in Surface Area Drive Method / H8 `$ q5 E3 }& b1 P
3 G, A) J8 Y6 \# Y: i$ V( R2 D
6587414
* X$ x9 A4 t3 B; Y4 P" N' p$ X- V+ g Sismes 840d Mill post - if use engage on drill cycle, no MCALL CYCLE() output
9 g! U9 G" \, K/ T7 o$ p, r- i % B! h9 V& h& u$ q
6587522
- l& X% |7 C( K8 S8 x jat_assy_replace_ngcEXCEPTION: Error code 580098 in line 1232
& `# {+ L9 w) G! \$ [$ [! r% j 8 Y+ ~; b5 i7 S6 i1 ^4 [6 Z5 \
6587578
8 M* h# ^+ T# }; P/ q  |" i; Y Check world error occurs after creating addendum section feature% H0 @9 f& ~4 j5 c
- k) a+ |9 H" O2 M& a) d: C9 U( ]/ G65875843 [4 L$ S7 m1 d* V
Area fill do not function $ k$ S3 T% \0 T1 \: i! u, e
2 V7 D9 g, H: P5 r* z
6587678
( L9 R8 S4 P; |( Q1 |# p/ M( E 755(1):IPart :CaeTest_ms_manfp_complete_jat:OM check world failed
; ^* d6 W* |8 Q! @
0 A: t# S) Z7 c. V4 [6588117
" H4 m$ \/ G3 I0 J+ C6 k Constraining part in 7.5.4 causes constraint failures. Works fine in 7.5.33 Z2 k$ f" i$ S6 j3 {
  s) Z9 X* z" R( @/ v6588177
2 E3 t* |0 M: ^2 y: N: Y. P Use offset face method to create pocket thread, it should be OK without error
( b- ?/ ^' ?: K) Q9 w$ c- H! @
% K& P% Y" E+ B65881884 B: x% C# `+ N4 p/ {9 z9 H
IE display when surpress_unsurpress mark line feature the third time % X, L% M5 `% ]0 W# j: Z" ?
2 W+ j! y5 }" o/ L* j
6588205
+ B7 V2 Y! E& F( z1 E In UI of Predict posture dilog's some text is hidden under values block / j- }- e- @' S" p9 b$ W
: p* S' X, v" I7 K( B8 b65884684 K9 @& m! \4 q. j% o& [9 j/ T- b
No measure distance output in NX 7.5 , y* L: z7 I  h$ P* ?" j/ S
4 s/ y, a  j) a6588481! E7 s* P2 h* p, Z+ W% s
BSH - Altrep child of drawing not loaded if APPUIDs have been repaired
$ l5 J6 r+ m- L% |0 `
0 }. E" Y, p* B- j% j, E1 C0 o6588536
4 U  q/ l  z& } BOM view left checked out when file is closed in NX
- p# {" K4 ]1 A4 g 6 H% f0 M: p& n$ @
6588556; u8 L$ D# ?0 o! \' C$ b
Distribution fails on some non-planar profiles / X" |7 o! g7 u* p8 X6 D
  x: W9 L2 F0 T7 Y3 f
6588564
, R/ r% b3 @* W3 A6 O Mssing face reference during placing a plate using Vector option * ]: _6 F5 H1 c* M5 s
# r& t* x% E' s' v
6588708
  ?7 \  ^% _! I" |/ H- U Join curve returns error An internal reference to object was found
; g; {7 s& F9 c, s' g. { 2 L* m5 [, q7 X. {7 ~) W" L
6588846
! l2 w* a3 z  W Reference ses issue when delete Distribution feature. Q2 \/ Y# M, Y. t7 r
+ t$ H! `6 C& x6588854# l3 f# D% d3 K* G3 j) [, |
IE occurs when edit SM Converted Hole ! D4 J7 T, r* j
- e9 _6 |7 r5 R9 X$ D5 I7 v2 N7 d65888919 C! d5 a" V5 E- G4 h
The performance of Blank Generator can not load "ART_INDEX" " R; N! U* N: z) @5 I
, _) f! Q4 V' f5 Y6589382
/ z4 b. D) J7 g2 r8 g1 \' P 'Parallel Generate' option does not work in Team Center
+ s/ P' J+ L9 R8 j' V6 C% o; F/ k, G 5 S" ?! @4 k4 ^. G) V0 c
6589434' z6 |3 b* V# d! @! u) S
Internal error in reuse browser in NX 7.5.4MP2 OK in NX 7.5.2MP3 revG ! H* r) S1 F' r% _7 A
2 n# o" K* D5 K7 z* P
6589458
/ d9 o, q" C' M% f/ _* B9 A) Q Weld symbols use the latest algorithm version to compute text box 5 `; C; D3 X  C2 p9 {3 y
5 p& D7 ~4 L$ g' n3 B
6589582
# ~+ l4 T9 R4 q8 s AssemTest_cpn_PR6421543EXCEPTION: Error code 580098 in line 1232' d1 w" Y, s9 ?9 X
% m  m  r9 p5 q+ l- v
6589708
5 z& G; L- [6 s0 i* w+ Z; M. W Assertion error is displayed while copying the custom symbol to another sheet ' O6 Q$ r- M, w' q
; L$ I9 l- M$ O9 H5 z6589745
5 K" u5 j  W* D9 Q9 ~9 u( { NX hangs on setting branch angles as Standard Angles : need forced exit
+ ^% I' K8 v( L% Y% V
' v  p; Z& a% U# t6 H: U6590009
( m' n9 d6 H) M8 ~5 X6 U: } Problems rotating AutoflexClamp - fails to remain positioned along path
6 }5 t1 H9 C: X4 p' c$ l: x3 D
  I+ @- z/ H% e5 W65901975 i! _; G: e+ I! N( M+ Y4 @
uft_mateconv_1853799 generates invalid statistics
. v  F' e% }4 u7 Z  E, g. e ' I2 L$ E1 G( q$ q+ Y, O; w
6590210
: n' J& L  l& \/ D8 M7 {, } uft_mateconv_nx6_beta_004839 fails with too many error-notes) D0 U. l! b+ l
8 c2 f0 g0 k, m; H+ |  z( |9 b6590219, O$ t7 D. l. P. |$ E9 x/ [
Cycling first entity of type 136 in RM part hit a stub
* Z' q/ H" M7 I3 s6 h$ }
' p& H+ Z' B  H6590254" K( ~& i$ c- ]" V
Fiat test: update not able to remove all discrepancies from frmbrd   e8 i9 p7 M" t5 p7 N( U. h
, k3 h* c0 ^* \' Y0 N3 b# U/ E6590629
5 ?/ ~3 ~! i* w  n6 L& u7 R Gap between leader and text changes to zero when I change color
$ d  \- i1 v4 [: w - f3 K+ t* T. T1 c
6590696" q! d9 I; ?+ \- f  {
Internal error selecting in PN with Reference set dialog active
! T# {6 I" d2 ]* X6 ~! j- z 2 J) v  B6 Q7 _3 w* p2 _; f+ k
6590739
. o$ U% J  a! m3 d Performance is bad when edit distribution in TC
! Y$ F$ @' ^6 @9 J2 i5 | 1 c1 ]) ^  g! Y7 c/ }6 S
65907580 i4 S2 y- a6 x- S8 H
Could not generate addendum surface with sectional% J4 z) B* h1 _- n7 e1 V4 d& _3 A
/ X# r# U5 ^6 _( ^' k6590811- }! ~4 T$ h$ u
Profile Cutout intersection * n. y1 Q# y- H
" n( r6 F7 K! q
6590850' @. a  f2 t' e5 Y$ W5 P; v
ugmgr_JRC_t1_refileXML comparison failed 3 B, q% B  |- N2 k% K! d
: `5 \2 K% _' f: d/ [( I6590987
: K+ P" S/ S7 Y- Q Linked Datum CSYS creates extra geometry
* m% L* n2 T* ^4 Y- X; a7 ^
) S6 v; O8 ]+ H, h/ p" w6 h6590999
7 N9 J# f: q- E& K- M5 s Moves are dropped in output and not posted
, _1 S' p4 _1 S/ M ! V, m8 O2 H$ n3 W
6591094
6 A0 \, d1 R8 h MP: opening NX 5 file in NX 7.5 raises error "object supplied is of wrong type"
  ?, y, e9 r, b* A6 }9 F/ I
" o  }; z7 c( e5 c, z6591111
( V+ r- |# T- A Wrong result when doing automatic feature processing ) c+ C* T& \& k% ?5 d; r
# K3 q3 Y8 Y( E( U- m6591124
. ^; I6 y4 b( m2 Q. B( T! ~" C Error importing part containing CAM data when import of CAM data is disabled 7 t( {+ ?8 ^  `& h; [' w
2 ^/ Q( [6 }, a7 {+ l, D/ P65914245 c& a7 N$ P  }& q
Excess Material in XML OUTPUT should Truncate String without any decimal 6 E2 D$ C9 w7 T- P
$ F# S1 u/ s' c+ ?; n
6591427
4 b5 W+ q$ D9 X6 s: m Belt fail when Guide strings amount changed and cause redistribution of new part; w/ d9 u# h' W' W1 T& @
$ F4 c8 I, }5 P8 ^; D0 R
6591440" z1 m+ y8 D$ X( I) r3 H  y% x
One issue is profile fails on distance change,second is strange sweep trajectory; P2 c; @6 [5 R: p% I
* D7 {5 p" J$ ?( T+ `
65914450 e; ]' K; s. |
Knuckled Profiles radius bight 9 z( ~+ h$ O. a# l6 Q
( P3 G& W6 d3 _5 h8 ?8 ]
65914505 N$ A/ R; K# P8 Z9 W* p8 P
Double markinglines and text after manufacturing xml out : c2 `; k6 e( I" q% N* h1 R  ?  {
9 i2 L! w. Y2 B8 ~3 U
6591566
% w  I8 P7 z  n Flange Task can't create the right result
: q/ p- H+ V6 k1 J. d: n6 g* ^! ] # v9 U, ]8 m0 q5 s1 T. A8 I+ ^
65917511 T! G9 h6 h+ Z3 ?4 ]  P/ W& x
Thickness Dim. can only be associated to Faces not Edges
  C6 X7 i% I# B* N0 m6 H4 s 0 p8 o; F  j' [
6591801
9 X8 r; d; d! h% _1 @  } Classification Graphics Builder does not handle string expressions correctly 1 [4 U0 Z- u9 j% Q. }
* ]5 `' L: l& `/ F" h
6591808
% {2 A( {) L- E0 v% L Section line setting not honored
8 ~) Y& V$ x4 ?5 x& N% W# J0 o; G
3 V# o2 H0 r$ b! n* a65920142 d/ W/ E( }9 B# ?* ^- A/ v
Internal error memory access violation
( A. H: x, B+ O( A- y: \8 S # D  r7 h: n3 U5 B. F" _  e1 G
6592062
& c- b7 E! Z# ?- q/ P$ [5 t8 ~1 O) l Fiat: connect curve path function fails in 7544mp3' b3 j5 q, t2 L# [; C4 R4 `( z
6 Y( E* a& ?. J
6592184
# b' J- ~: J# G Adaptivity analysis and assembly fems fail 6 c: V1 m3 S9 |4 x4 C% L6 P
5 d6 g9 v# v4 W. n7 r* {! g65922635 S6 g$ r5 g& {. v& q1 a
Expression point to incorrect part, Delete All References leads to error message; n7 @' @, M6 Z' ^, `/ w0 A; _* \
1 K1 Z) `  ]5 x% w6592423
7 G% g4 x9 P2 w: m4 V) Q# C uft_assy_open_jt_Nissan_25560ASSERTION:: in line 4451
$ p  R$ ]6 a4 \8 Y! E& L 2 F7 i6 I6 i! M. k) q, {8 f& K
6592609
2 @, o  H7 D$ H Fiat: performance degradation in move part 7544 relative to 7533
3 M' W' o5 g0 Q" A, ^8 b
' l7 k3 T" I0 a: c& Y6592752
% ], m- B: {& x, n+ `* | Circular reference error when editing a sketch
% b  T4 U, p) r  v7 c. J" }4 A ' U' Q- K+ L" N7 {8 h9 E* R6 o
6592926, e; d" ?& X& k1 J! q
Removing Component via Moldwizard Standard Parts deletes child boolean
- p6 G, G/ [" ~8 g! T4 m 2 p8 @8 J  [; G( P% a
6593156$ ?* H5 u2 @" s8 @8 }: a  h
ugmgr_ANT_t3= "+++ Exception c0000005 occurred in C++ API function
: k' v8 F( U1 K3 @; m5 h 6 l# Q) G3 R0 \9 ^! {
6593228" w1 i; X5 z' |' P3 Z
Crash attempting to convert dangling expressions during part load ( O* V, \/ l9 o3 J
( \% `; o* {7 y5 Y% L% T1 T2 D6593331
6 S$ m8 j, r2 U9 e# C/ U Unable to enable single weld object, biw datum or meas. obj for selection
  r9 F& j4 d' F
. v' I1 k5 G# I! q/ H( Z5 Z6593429
4 F' g3 I1 B9 F( X: ~" c9 M6 y Routing Run Import API - Storage Manager error
1 p9 X) Z5 l! ?! \0 \
( e- ~* X' s, Y; a* |& P6593520" I0 }! p9 }/ U# A. m
Unable to save"file is in use by another process" 1 \! W4 {+ d1 `/ \
7 g! c, o# m- s4 p! u* |8 v* D' W6593658" W" K" C/ Y1 Q- t* ~. r
Want to have a marking line layer for single parts, used to be on same layer 3 g$ F, H; k) U7 D& ?
& B0 A& d' J# o! D0 L" [
6593677& m! V0 U9 j# \& _4 B) C; T6 N
NX 755.51Build:if afem consists of more than 2 sub-afem, only one will be exported
$ X( S# ~" o6 X+ [( N& q ( ^3 g  c2 @& V* I7 R: g
6594016
; E. D2 Y8 C( R Unable to open customer assembly - REGRESSION8 B  W- S4 t- j! `* Y4 @5 F
4 I+ ~+ ~/ v. O/ ^: ^6594155
. U: q, G3 U: D CATIAV5 kit lacks required redistributables to run with Parasolid V24 0 i' c$ n1 f& a- o6 w+ c8 T
& ]1 @: c* I. B- Q3 `) G) w6594812$ q7 i4 J! p- c* Q) }
ONT filter does not work correctly with wildcard; v' {  d0 z# Z+ @
" `; ]$ F: `% O/ j7 {. R6594864& a0 a" v% D+ n" [
Fiat: Autoflex _ Creating a path in context creates extra Stock Offset Port
! L" P# T# _. p   z8 z! K+ t) O! y+ W. `  O4 [
6594919
  m0 A2 v3 l* Y# e+ | performance issue with UFunc calls for PCB " c! X( p, v6 k( [2 B
  J* v2 n" o1 ^, j$ P
65949235 }" ?4 i4 g/ \% z
Fiat: Replace part does not call the Place Part plugin
7 v) e% f2 K$ n' K4 o" G 7 x9 n$ e. M! f1 o# f5 K- ~
6595497
  i5 p! K( L, d# V Internal error after feature tagging on features recognized in same session
: E; p- U: S3 j/ g: Q, f : P2 }# b% k3 `( b1 V: x; u# M8 h, `1 w
6595892
2 \  S* Q+ j# n% r2 F* z) ]) ~1 }3 Q While importing part with 'USER NUMBER', item type is different than default 2 W) |, K6 n# N$ u
$ N/ V; \. p; G" s5 [8 z4 W
65961641 y6 u, ~) S: X! Q
Routing performance issues in part-load and constraint-conversion - ^! Y! L; b2 E: C* p' a! ?. L* C
& k5 U$ l2 ]- I  P6 }
6596443
! o3 }' f5 R! m  b FBM_GEOM creation via .NET throws Memory Access Violation in NX 7.5 - NX 6 OK
: V; O/ c4 x, X0 s  d' E ; \/ z6 M( E& ^; y  g& j
6597035
# V5 `1 v( s" K" ^' U0 U CreateMachiningFeaturesFromTaggedPoints Fails in NX 7.5 - NX 6 OK
% g( d& _! R, r; d0 K% o$ C
+ w1 C& D; |. z5 W6597669) Z% [. [- N5 Z( L/ e
[7] nx75mr ugmgr_SVS_t31,42,54,11 parent_update changed to -1 ' y6 z4 _  L) L# x
$ E' U7 f2 T/ L! ?$ v3 c8 c; P6 A
6598058
4 v# @0 }9 N, z6 o' E, R2 r Unable to change item type upon importing
6 b1 e. ^7 N, ?9 y4 i " n6 [$ J0 i3 R& m, S, V
6598405
$ n' D9 n; i* P& k0 T. X Additional XML output occurs after delete PI & Wave Link to PI
* M7 f6 ^' }. c; J) {' x 7 K: d' Y; W3 E; J% k
6598439
+ ]! g0 N# G9 Y4 d Abaqus deck import - STEPS imported incorrectly
3 o- k9 {3 `2 s' S* E
; i, h  r% |' y& z3 C6598727
! p7 v, n" r6 f6 H8 } The OOTB rules fail when using the feature_machining.dat CAM configuration % o2 J, B6 v  B- N
- ?# ~) K6 f8 ]+ b$ v; Z
6598745
" P6 E$ P. J0 P- u+ Q$ ?: g 'copy component as ' part is always invisible and cannot make work part . F9 `. \: r% ?
) A. P# \% t1 v6 x6599020
0 }2 K, h6 x5 | When adding PTS part to assembly. It leaves the PTS part checked out.
8 ~! R* s3 W5 U) s, d# q
- U0 ?9 U' I8 P$ ]6599091, ~( {2 Q- n6 E  a
NC - NX session hangs when use Autotest Validation Tool 'Where Referenced'" G# S0 a& |' F" [( c+ E2 _* m
/ m# I. f- W$ m2 C3 d( e3 Z5 K5 H65994533 l6 T- [* l3 X; k% V& T- Y! T" U
Generate FBM operation in TC env loads machining knowledge multiple times
0 X* M  E0 \& b1 O2 }  L
2 s; r# T* O# s+ I" `65995178 G: h/ {" _! c* P2 u. N
uft_dicInval id link between different parts: G! O8 w8 a' }0 k0 R9 E4 P, \6 P
+ {9 [/ }; I+ |: X) e& O$ a. h
6600167
1 Y5 r& f' }7 Q! H; N Edit Patch has internal error when starting from Mold Parting Tools" }4 H4 Q; y3 V9 I. P* I2 l
& I& [2 m- y% Q3 {" S, a, e, \6600215
: p; g5 s0 ]) ~  E2 z GM-DOL Assistant Trim Task cause faces missing
/ `$ e/ J; P2 W% G: |6 H% l+ c 0 V! F' L. ?( o
6600230" f4 R! i+ b* a; K/ x) x
OM check err or after copy component
# i* c$ X; a+ l; ]
4 ]3 n! ?' a& m& G* T4 z6600593
1 g! U1 ]% B3 g* H( H Control the creation of trim tasks with the DOL assistant
* B; L  w4 Q5 n6 E. S' P$ ? # U; Q' ^4 g& ?" g" Y% _1 _
6600797
7 D& b! ~# l5 p- w! F$ T [10] ugmgr_SLD_t#_4 ; alt reps not loading_reporting; I1 V& w$ x  `$ v) @6 @7 H& m0 T
3 w" p8 s6 @3 F" k' N  I6601118' t7 ?3 }$ g7 U* T4 D
request to allocate exactly 234567 bytes corrupts persistent SM area
  b7 U% Q: }$ n* C4 E 5 q$ H$ _8 H0 O. \5 L% u
6601507
! K! V! ~" N' _  }+ u Cannot show component created by WAVE copy-component-as
- G: D8 [  I7 O1 I; r+ z' Q. T& r
- V, t+ F5 i& u- [, U( f6605286$ [; f7 T1 C: y; N. [
Midside nodes poorly located on last ply for 3D inflation
4 e; ^# u8 ?0 W
1 M) y- [2 M- P6606518
) w4 S1 E+ `$ ?& e/ q' O! R3 [ Corner smoothing creates arc segment that causes circular endpoint error6 F! \. D3 c0 s& [$ Y/ k" [
  X3 l2 c( h/ Y$ ?6608499. P+ W+ o2 B# x. c3 z: E
Need support for Catia V5 R21 SP1
( V8 ~3 x4 @0 S1 W. j1 K# u% @
' @/ i, P; j& r; O; a/ a
发表于 2011-12-19 20:44 | 显示全部楼层
看看,有哪些更新,谢谢!
发表于 2011-12-19 21:49 | 显示全部楼层
有没有破解呀
头像被屏蔽
发表于 2011-12-20 11:07 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-12-20 13:23 | 显示全部楼层
看看,有哪些更新,谢谢!
发表于 2011-12-20 21:01 | 显示全部楼层
送人玫瑰 手有余香
发表于 2011-12-20 23:58 | 显示全部楼层
我已经用 了,感觉算刀路能快些
GMT+8, 2025-8-24 02:57 , Processed in 0.078076 second(s), 20 queries .
