1. 只进行单位转换,保证实际长度一致.(When you just want to convert the Unit but keep the same length.) . `0 v- y+ U y7 l5 z* @& ]
a. Start->Program->Unigraphics V1x.0->ug Command Prompt ) D2 y* G* z6 {) r, _
b. Cd d:\UGs150(eds140)\ugii
) ^- D4 L* N$ d' F0 {c. Ug_convert_part 杋n (-mm) name.prt 5 v4 C; w: b8 C) H
2. 进行单位转换,保证数值一致,实际长度放大或缩小.(When you make a mistake unit, So you want to convert the Unit but hope keep the same parameter value. )
- r. |$ o7 o+ H) v" b( c" B& ja. 启动 UG, 打开UG part 文件,进入Modeling.
4 G, G5 H) j. E7 g1 tb. Toolbox->Expression->export 产生 name.exp 文件. % R: d6 t6 v: N: `2 J
a. Start->Program->Unigraphics V1x.0->UG Command Prompt 7 \, K( L6 q9 @; ~, q
b. Cd d:\ugs150(eds140)\ugii
% H8 X3 z6 r: |& l' qc. Ug_convert_part 杋n (-mm) name.prt 4 ?; _3 F4 a9 t5 H6 B' g
d. Close UG part 文件, 重新打开 UG part 文件。进入Modeling. N9 L/ ]# z# ]) { O8 x
Toolbox->Expression->Import with option(Replace Existing) |
评分
查看全部评分
