查看: 2506|回复: 1
[疑难] 有限元分析,,
发表于 2012-2-14 10:01 | 显示全部楼层 |阅读模式
哪错了 按教程走的 没用它的模型5 a( G& \" X3 A  c! s; r% ^
! N" r# P0 \6 E1 x信息列表创建者:     Administrator
* s2 j6 ?- S8 {, a% r: g日期:               2012/2/14 9:58:18" G! C9 ^. ?6 ?# @$ w$ ?
当前工作部件:       D:\fadongji1\huosai 4_sim2.sim* ~. N/ R' d. S( |7 H* V
节点名:             rs2yspeew0ti9fx
, ~' E2 `9 ^1 y/ O, m0 Y0 o  C: u8 |============================================================! n( z! A8 j6 ~  A/ f
! S9 t% M) r) L+ p5 B
( q: z; F9 e+ n8 ]5 Z4 o: j+ l+ i " m4 Y: l( f# c' u# S! I* N
解算方案模型设置检查错误汇总
9 L6 J- `" V2 X& C* G3 l! E, q# |! {
- u+ f3 j6 M' e9 w8 l9 y/ J2 H------------------------------------------------------------& z  x! r- ^% I' ~
; M/ }+ E) ^1 T4 b  N5 E$ E
求解器是 NX NASTRAN
: D5 T8 y- p& N; N; G' b1 {: i/ I, c: y
环境:NX NASTRAN - Structural
0 M, D1 D6 M" E" N  l; e. x  U
  t; O/ L; n! C$ }5 n' [/ t0 F8 T 解算方案是 SESTATIC 101 - Single Constraint
8 d4 U6 \- ^# q; ^  Z: M + y0 @' H7 P, l1 f# J8 w9 t
------------------------------------------------------------9 u" ?3 \! |$ S
; C) S9 \& v3 d( v
2 v1 k0 p" b3 E0 i1 s8 H. R0 f8 {3 n1 s' `
; z8 z) a  p" u' p4 p( U; y* ]; e& {9 u基于网格的错误汇总" Z1 g/ D$ G8 J0 }
-------------------------3 D( Y8 ~+ e8 i" P
* \; Q9 W& n% _6 p7 X9 B9 }
总计:0 个错误和 0 个警告" k2 Z' N# L2 x
' g+ a9 |6 `! A2 q& Y  O- D
0 L4 Y! l7 v4 x( l  J0 }5 M. P基于材料的错误汇总1 [" b" [$ k  I/ o& X0 M
, v! ~. s9 _2 |" V( J1 x
& i8 \- l2 p$ ~! m" M总计:0 个错误和 0 个警告4 z* E3 r8 ~* Z/ b; {( t( Q2 C
& F- s" a/ G* D7 I& P1 G
" t+ X" j2 P+ x' e基于解算方案的错误汇总( E' Z+ }" h$ b' T8 d% l
& B6 l9 d0 w+ f3 v
* D) L" f' e$ ?3 xERROR
' Y  N' ~6 D0 S4 IStep "Subcase - Static Loads 1" requires loads, enforced motion constraints or external - D! h! b4 }3 e  p" ?( v
pre-loads to be applied.  None have been assigned for this step.- J  P, _- `% |! k0 k6 P; g) D
# s+ p( {4 J& R$ i
Iterative Solver Option2 s: e: F/ J/ k" }" C. c2 H
More than 80 percent of the elements in this model are 3D elements.
4 d+ R- Y- Y8 F% eIt is therefore recommended that you turn ON the Element Iterative Solver in the "Edit
! M) c: w1 j, Z% _Solution" dialog.' Y" o. M- _% n- p' b) ?
5 O( o* X& ?. p
总计:1 个错误和 0 个警告
7 H) Z$ S9 d( S5 j
4 U9 b6 s$ O1 K: w& j- K4 C1 _# J  P. a# ^4 H
基于载荷/BC 的错误汇总
! U( W/ T9 {- x  m1 n3 s----------------------------
+ Y& T" K/ z' G! W' q2 R5 X1 M( T8 A7 T" S( U; l5 G
总计:0 个错误和 0 个警告
% c7 _/ H/ R  l' L+ ]; F) [
: Q# s3 L, q( I+ i: g
& W6 h3 v8 x# z& N) _NASTRAN 模型设置检查已完成
发表于 2012-2-21 15:24 | 显示全部楼层
子工况1 没有载荷
GMT+8, 2025-8-10 18:17 , Processed in 0.070879 second(s), 21 queries .
