查看: 2367|回复: 2
创建链表出错的问题
发表于 2007-11-7 12:10 | 显示全部楼层 |阅读模式
我创建一个链表
+ g( X* O4 t1 C3 Y' {        UF_CALL(UF_MODL_create_list(&loop_list));3 a& s# f( c/ B7 c9 c/ ?# M$ b
然后添加一个tag进去
6 P7 K0 O( ~) k8 n0 R  Q. R( F+ G        UF_CALL(UF_MODL_put_list_item(loop_list, line_tag);
! C+ M3 z, y1 ?5 r" o: h7 c9 g编译就报错& V/ m# q8 b; a9 a
E:\ugOpen\replace\replace.c(99) : fatal error C1057: unexpected end of file in macro expansion2 k" e" P  L% u# Z" C
Error executing cl.exe.- J' `% q+ Y' r( m+ g
0 {0 a7 s* [$ f! @& u- ^5 I
! [+ B: _' F% U# t. B/ J
我的整个函数是这样的:" N5 }* q! R3 D7 l
        UF_CURVE_line_t line_coords;
2 z. _) \6 R4 k' O0 ~' Q% G' p9 H        UF_CURVE_line_t line2_coords;* H8 J4 ]' P9 K' j
" ~) K1 k5 X% x9 `        char *taper_angle = "0.0";# \1 ^& S* I( j" i
        char *limit1[2] = {"1.0", "1.25"};/ g4 u; b  o+ e/ H: L4 O$ m
        double ref_pt[3];  Y, y; B. Z: ~) h0 X; Y$ t
        UF_FEATURE_SIGN create = UF_NULLSIGN;1 z3 x: Q4 v! x. `0 `7 w$ c7 A
        tag_t line_tag,line2_tag,part_tag;7 X  [1 s# W5 S% f5 W1 R" ]
    uf_list_p_t loop_list;$ W$ y9 n  h* V- g5 h. P2 {
    char   *part_name="replace_features";
4 H0 F* w% ^# T9 H" u4 X        int    units= UF_PART_METRIC;
* n$ w/ z' ^- V$ F  P) i1 V$ H9 V% L: }
        line_coords.start_point[0] = 0;* Z  N0 k2 |( c. v6 [, F9 {
        line_coords.start_point[1] = 0;" [4 b5 K* S' Q5 b. n
        line_coords.start_point[2] = 0;
# D! V7 Y% V9 r7 V        line_coords.end_point[0] = 100;" W  D! N$ K) Q+ `
        line_coords.end_point[1] = 100;+ S1 }( W0 s& `/ Y
        line_coords.end_point[2] = 100;2 X7 E, n" T( @- j' F' e) w+ b
        line2_coords.start_point[0] = 0;
+ a5 O8 v  I9 p3 `  c$ O$ ~& S3 n        line2_coords.start_point[1] = 0;9 Y( ^8 y9 q" ?, n
        line2_coords.start_point[2] = 0;
) `6 \/ ]# W7 O        line2_coords.end_point[0] = 100;2 O0 ]$ X7 H( l$ Y% Y
        line2_coords.end_point[1] = 0;7 Z! `" x0 v2 k5 \/ k* c$ x* {1 f6 u
        line2_coords.end_point[2] = 0;* s  p, A; T% r2 v& @5 l( R. h7 G
  c, b8 }/ N( h  K1 N$ z+ X    UF_PART_new(part_name, units, &part_tag);0 a; R( b9 G- I
//创建两条直线,这个测试成功* M6 s# T3 U4 P+ S% Q9 j( b, R
        UF_CALL(UF_CURVE_create_line(&line_coords, &line_tag));. m/ `( |. m" Z! F2 R" K4 T! i
        UF_CALL(UF_CURVE_create_line(&line2_coords, &line2_tag));
* F8 m6 g: Q* J+ ^//下面就是创建链表,为了拉伸用,因为拉伸的第一个变量为链表
2 z* h( j* ]5 b$ V4 _        UF_CALL(UF_MODL_create_list(&loop_list));( h/ o5 O  H6 J: E
        UF_CALL(UF_MODL_put_list_item(loop_list, line_tag);//这句话报错,错误见上面3 v. u/ ~7 {' K2 G3 V+ j5 ^
        UF_CALL(UF_MODL_create_extruded(loop_list, taper_angle, limit1,/ O+ U, _% {3 g* M
                          ref_pt, direction, create, &features));, d: u& k3 D7 N9 Y+ t7 k
        UF_CALL(UF_MODL_delete_list(&loop_list));/ A8 v6 G7 a' I' [- I4 v6 p3 Y* ^' S
0 m  m5 I' J8 b( D, }1 W首先可以肯定不是编译环境的问题,因为我找了一个实例,带有这样的链表,编译无误。请高手指点一下,变量声明地方不对还是什么别的原因呢》?
 楼主| 发表于 2007-11-7 12:10 | 显示全部楼层
我就拉伸一条直线
发表于 2010-11-18 14:44 | 显示全部楼层
我的做法: 编译通过请参考
( d3 e7 S# C9 M8 O" O0 g int    flag, i,res,inx,count,response;
0 _' z+ y: N1 `4 `) T9 ]9 J    tag_p_t objects,ExtrudeObjects;
& J- {$ p! W+ p' x9 |" r        tag_t   lineTag,featureTag, bodyTag,chamfer_tag;/ c* h0 m& R, d
        uf_list_p_t  edgeLst,lineLs,features;  //  --链表变量定义' ]0 Y. ?3 j* k% c5 R0 w
7 b' J& G" E( Y) V
        char title[] = "User Title";. g! x6 I5 }/ O
    char cue[] = "Select Objects";
* E, x/ N7 \  A+ b) i    char *limit1[2] = {"0.0", "3"};   // 开始到结束点=高度/ k5 z! r* D8 g* [: s! ]
        double direction[3] = {0.0,0.0,1.0}; // 沿着Z轴方向拉伸
4 F0 x+ ?9 B; W. |" w* A0 ~2 Z6 K  m5 w) s
    UF_FEATURE_SIGN create = UF_NULLSIGN;2 P" @9 F( g6 u/ N( c. Y: }
    double  ref_pt[3],Hight;4 `& N' Q9 _  Q6 l5 u$ f6 A. H
        char Temp[200]="";, r9 T  G& H0 E/ s
//-----以上变量用不到请自动过滤6 e: q( x1 Y9 }/ ~( A% O3 R
--) F: G. L: I. R/ A! t# h
// 创建第3条直线# a) G5 V1 B  R
                                                 UF_CURVE_create_line(&line3_coords,&line_tag);
, Y! e, A/ r/ I: h                                                 UF_MODL_put_list_item(lineLs, line_tag);/ A# K; k) C, j
                                                 9 A! C9 F2 @6 t- z0 s( W
                                                 // 创建第4条直线
9 E  S. y$ K; _6 U  L                                                 UF_CURVE_create_line(&line4_coords,&line_tag);
1 u8 l& o. Z5 i% P6 I0 _3 t. s                                                 UF_MODL_put_list_item(lineLs, line_tag);                                                 * u& A, U: _2 K4 q) M: s& j# z
! Y' c& I5 I4 v2 `
                                                 //--下面应该是将封闭的4条线拉伸成一个整体
- A5 |4 f8 N" h! U9 E1 a7 |                         UF_MODL_create_extruded(lineLs, "0", limit1,
% Y" _, F; b2 h& i- ?6 g- k                                                  ref_pt, direction, create, &features);4 e* ^! X, ?. b2 @- F
                         UF_MODL_delete_list(&lineLs);
GMT+8, 2025-9-17 04:41 , Processed in 0.052464 second(s), 24 queries .
