查看: 984|回复: 1
[疑难] 求教,二次开发中遇到的问题、、拉伸体,以面分割实体???
发表于 2012-4-20 09:05 | 显示全部楼层 |阅读模式
刚开始学习二次开发,基本是照书上抄下来的拉伸源代码,编译成攻但是不能用,请各位指点下这是那里有问题,要该这样写才能实现拉伸的工能
3 o# J3 |1 T/ }1 G9 o; }& ]# E6 ]: C8 w; \) ^) u( }3 A7 q3 h, a) N
拉伸源代码:
/ K; ]% ]8 N2 T, L  r5 Eentity/cur(100),obj) v; C- Z1 M9 ?( B
l10:. D, K& z0 c  O6 L$ I! S
ident/'pick curves',cur,cnt,num,resp# L/ D& d( n5 W; H: _4 P) R
jump/l10:,trm:,,resp+ l6 X/ \! S5 _
l20:' X0 W2 l: |( a# q
obj=solext/cur(1..num),height,10,axis,1,0,0& Y6 |7 n0 k; ~
trm:0 r; v) }! N1 ]- T# d# t7 @
halt: i: K' ]8 Y  T6 {0 l
% N; }# Q- U) `. L还有,分割也有这样的问题:
+ M8 b4 F: v* ^, z" t* O% G2 hentity/ent1,ent2,cutent(10)& h( \- @9 t1 e6 G7 J6 m
l10:
, ~0 w: T$ c8 J. F- q& hmask/70- n' G' P2 U: F8 h
ident/'选择实体',ent1,resp) h$ O; A& b" C
jump/l10:,trm:,,,resp" r- d. q! f! v- d, V5 V
l20:
/ c" x  B6 ?( p& r2 A& d# Smask/71
1 ^  M6 E9 R5 Z7 C! W" l3 F! }ident/'选面',ent2,resp
! H3 n9 x1 F8 K( o( C' P, K( ajump/l10:,trm:,,,resp
% ?' k, v2 u: u9 P' a' N2 o# el30:
! G* ?% {# j( f. p/ v% ~7 Ycutent=solcut/ent1,with,ent2,cnt,c1,c2, V) O( D; O* y! U8 z* V
print/c1,c2
( A8 Q) _( W$ R  ftrm:) ?& N8 j0 ~+ t4 x  r& D. f! C
halt% u# H3 r) R. a7 f
# V. D& J0 \! l( I  I
发表于 2013-6-17 00:21 | 显示全部楼层
entity/guide(100),obj
) p, L! Q5 p% [l10:( z, g* G" O, ~) D
ident/'pick the guide curves',guide,cnt,num,resp; Q/ \( ~3 }8 Y% {! T
JUMP/L10:,trm:,,resp
5 u! V. g! m' m/ s. Rl20:
# A+ S7 m0 |$ p7 Bobj=soltub/guide(1..num),diamtr,5,3,toler,0.005$ a3 U9 `6 \3 w# N% j% W6 Y- _4 d) o
trm:
4 k" h% x6 o& m4 V- ^7 j' dhalt
. w$ H( o6 l1 n3 z8 k
GMT+8, 2025-6-29 07:49 , Processed in 0.055149 second(s), 25 queries .
