查看: 8755|回复: 8
UG 7.5 无法正常启动!!!
发表于 2012-4-20 13:10 | 显示全部楼层 |阅读模式
悬赏500G币未解决
我是xp的系统,去年装ug7.5,一直用得挺好。可是今天再一打开,发现报错了:nx requires a server_id feature in the license file,初步怀疑是我装了另外一个软件,那个软件破解的时候需要调用机器的网卡号,不知道这个是不是原因,反正现在用不了了,我实在是不想重装,请问有人遇到过这样的问题么?如何解决的?我试过把lotools.exe启动时改为管理员启动,还是不行,急死了!会不会是端口冲突?可是那个软件并不用flexlm呀,上班还要用UG呢,请大家帮帮我) k2 N0 q& y8 P- \# w) Z- q
 楼主| 发表于 2012-4-20 13:25 | 显示全部楼层
补充一下,系统提示
- r6 _4 o+ t+ K. t% X3 X1:13:01 (lmgrd) -----------------------------------------------
* _% W* q/ X" c% i4 W, W 1:13:01 (lmgrd)   Please Note:4 s& a' u/ h( E: z
1:13:01 (lmgrd) / `1 u; x$ |2 E6 G$ H
1:13:01 (lmgrd)   This log is intended for debug purposes only.- ^8 _/ x6 r+ E; H. ?' j; q
1:13:01 (lmgrd)   In order to capture accurate license9 a# R% {  ^; b" L( V
1:13:01 (lmgrd)   usage data into an organized repository,% z- H' n$ G- D: V
1:13:01 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s6 W0 W0 K6 {  ?7 y5 }
1:13:01 (lmgrd)   software license administration  solution,
, h2 G) g2 t0 x2 e6 ~6 k 1:13:01 (lmgrd)   FLEXnet Manager, to  readily gain visibility
. O1 ~$ ~3 z5 m4 I! ? 1:13:01 (lmgrd)   into license usage data and to create
& @0 o2 X6 z" G4 R3 x. Z 1:13:01 (lmgrd)   insightful reports on critical information like/ W8 N: M; J7 d( f
1:13:01 (lmgrd)   license availability and usage. FLEXnet Manager2 M+ G! S8 U4 R- c7 ?' _. T
1:13:01 (lmgrd)   can be fully automated to run these reports on* e7 M/ Q+ d) z; H$ ~( k
1:13:01 (lmgrd)   schedule and can be used to track license4 y5 C1 A2 [# U3 g0 V& Y- ?
1:13:01 (lmgrd)   servers and usage across a heterogeneous/ D' G. z! `3 R4 p4 [% E1 o
1:13:01 (lmgrd)   network of servers including Windows NT, Linux4 Q" w4 G& A, X' Y9 ?9 e7 N1 s
1:13:01 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
2 t. U: O8 O* y9 U 1:13:01 (lmgrd)   www.acresso.com for more details on how to
! p/ E2 @1 k2 C; g- k 1:13:01 (lmgrd)   obtain an evaluation copy of FLEXnet Manager+ ]' h6 `5 i8 q$ j  w7 u
1:13:01 (lmgrd)   for your enterprise.8 {$ y) y& b9 g( I
1:13:01 (lmgrd) . N9 N; @# o% e( g
$ R& n1 S$ N) }4 n! q 1:13:01 (lmgrd) 2 ]  \+ S% c' g2 Q, ^: e1 z
1:13:01 (lmgrd)
. u4 `$ E5 l6 O; `( j" D 1:13:01 (lmgrd) pid 5572/ a* S* M% O( ~0 E
1:13:17 (lmgrd) The TCP port number in the license, 28000, is already in use.
) B; z. Q+ |& L% I9 f$ m 1:13:17 (lmgrd) Possible causes: 4 v, e  v5 ^3 v1 L
1:13:17 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.% \( B- e$ H5 X
1:13:17 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.  o  O9 a! y9 j+ Q  {* r
1:13:17 (lmgrd)    3) Another process is using this port number (unlikely).
+ x  t4 R+ ]6 t. Q# H 1:13:17 (lmgrd) Solutions:
* ^' {( s5 S1 e0 h3 w5 M 1:13:17 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
) R( i$ [0 {, G* \& W4 u* @" ~% v  |& m8 ^ 1:13:17 (lmgrd)       license are not running.7 c1 L) K- [6 v
1:13:17 (lmgrd)    2) You may have to wait for the OS to clear this port.' m5 F( K6 r' K+ V+ @  E5 b6 W4 {
1:13:17 (lmgrd) Retrying for about 5 more minutes
& j: `" k5 {8 r: U 1:13:35 (lmgrd) Still trying...
! e) K; Y/ \$ q# x7 b) s# O 1:13:53 (lmgrd) Still trying... ( v% C/ X' R' L) s
1:14:11 (lmgrd) Still trying...
4 S: E& e5 w; }  w2 r 1:14:29 (lmgrd) Still trying... 3 ?* @+ e5 s+ Z% U# @/ O  A( S0 }
1:14:47 (lmgrd) Still trying...
8 _) G% |0 r( j- ^ 1:15:05 (lmgrd) Still trying...
9 ]: ~1 v9 G$ f+ ]& _ 1:15:23 (lmgrd) Still trying... 0 p2 I4 D" p; g0 m$ s0 p$ ?
1:15:41 (lmgrd) Still trying... 7 \$ I7 s& x& |) z; l* Z9 ^3 G% T) H+ Y
1:15:59 (lmgrd) Still trying...
( J+ C0 I  y) |+ _8 _3 z: G! ] 1:16:17 (lmgrd) Still trying...
; U/ L# E0 R( L4 ~; l1 |5 H 1:16:35 (lmgrd) Still trying...
/ D2 g0 Y$ L+ m$ T2 Y2 W4 v 1:16:50 (lmgrd) Failed to open the TCP port number in the license.& [* {& R  z4 h0 q- U2 I/ f
谁知道这样的情况该怎么办?谢谢大家
回复
 楼主| 发表于 2012-4-20 22:20 | 显示全部楼层
现在又出这个问题了:nx requires the environment variable  UGS-LICENSE-SERVER
- z5 o# {/ F% \+ n$ K  tobe configured properly. It can either be set to the value port @hostname of the NX license server
/ E+ c9 f; c- s; ~or it can be set to point directly to a license file BY default it will be of the form 28000@server Name,谁知道该怎么办呀?急死了!
回复
发表于 2012-6-26 22:08 | 显示全部楼层
我也有个问题啊,7.5打开后,在任务管理器中就是无法打开,也没用说证书错误,就是启动停滞
回复
发表于 2012-7-4 15:36 | 显示全部楼层
是不是破解的问题,我这有一个破解方法文件,可以传给你,win7和xp都适用,我自己都试过的。
回复
发表于 2012-7-5 09:30 | 显示全部楼层
楼主可以看一下这蛋疼的翻译...NX需要的环境变量配置正确的UGS公司的服务器许可证TOBE。它可以被设置值端口@ NX许可证服务器的主机名设置,也可以直接指向一个默认的许可文件,这将是形式28000@服务器名
回复
发表于 2012-7-10 14:12 | 显示全部楼层
QQ1686156477,这是我的Q号,我帮人调试过很多次了,保证UG好用.
回复
发表于 2012-7-10 15:28 | 显示全部楼层
我也是同样的问题。。。。。。。。
回复
发表于 2012-7-23 21:17 | 显示全部楼层
我也是这样的问题
回复
GMT+8, 2025-2-19 08:00 , Processed in 0.050373 second(s), 19 queries .
