using System; ; j& k' M+ v4 d- z1 i7 p
using System.IO;
( N; @: M' c( P# ^1 Nusing System.Collections.Generic; 7 z# D) {& u. `% n
0 K0 k% p; O5 m1 N1 i1 l* Q
using NXOpen;
- r1 K9 S, N, p# s% L nusing NXOpen.Utilities; " ]1 _2 i# X& F, P3 w' F
using NXOpen.UF;
- D3 }' b3 `8 `3 [! susing NXOpenUI;
" _3 p7 U" D" I. Y5 d% g4 ~% D$ b+ B# W0 G
namespace C_sharp_select_solid
) R! E% \ l" z) q( i2 E{ 4 _5 ?5 E+ k" Y: K& B$ v/ H
public class MyClass + K0 F/ Y) u: g% E; M: R
{ & b" T$ E1 Z2 d5 g! u! r9 s7 @7 X
public static Session theSession;
8 V6 G% j6 ?$ F, `2 n$ h8 K: O public static UFSession theUFSession;
7 L* P; G% W5 T public static UI theUI; . q" `* ?5 F! O% U6 f9 v
public static ListingWindow LW; ! f9 o$ a% i& T% D
public static UFUi theUFUi; 1 d* j ^9 h! R" ~( K4 m
public static NXMessageBox MessageBox;
4 ` E1 H1 o+ T, `9 p# d8 |7 g9 c, u! {1 ?; B" h
public static int Main() // this name is essential to run at startup ( r" o( ?) t: |
{ 6 I F$ @) y+ w% P; h; a
* H* k$ t/ `1 @1 I( v. O theSession = Session.GetSession(); , T3 n* H4 e1 h
theUFSession = UFSession.GetUFSession(); 7 z. M6 `2 D7 v, Y) ^5 n( d
theUI = UI.GetUI();
, S+ i- t4 I! b$ F: @1 T- G5 T
C% ]; X# @! O. a3 p theUFUi = theUFSession.Ui;
' z6 p1 X! z' g1 j6 m5 ^9 x/ Q- j MessageBox = theUI.NXMessageBox; 2 W/ V; M! p6 [# ?( Y
5 f% x) x: W M3 a" _+ C( _( s
string cue = "I LOVE YOU SO MUCH!", title = "select solid body";
8 l. u2 u& M* ]1 N0 |6 U2 [" l$ m" W0 q9 G6 n
NXOpen.Selection.SelectionScope scope = NXOpen.Selection.SelectionScope.WorkPartAndOccurrence;
( S0 G' d" b' x$ ^( ~ NXOpen.Selection.SelectionAction saction = NXOpen.Selection.SelectionAction.ClearAndEnableSpecific; ; q2 |8 `6 r+ I& C- g3 c
NXOpen.Selection.MaskTriple [] smask = new Selection.MaskTriple[1];
# D8 _' x# L( t! L$ \' i- p0 @8 r w. Y+ H5 A$ ]
smask[0].Type = UFConstants.UF_solid_type; + h* f/ k* Y4 p- l& |0 g
smask[0].Subtype = UFConstants.UF_solid_body_subtype; , y) `: K2 m4 F0 W- @
smask[0].SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY;
, P$ W- T8 \4 a# \$ y9 x9 |0 a$ s7 m0 f* L0 ^ U7 v
NXObject sobj;
8 |% A/ [: H: N8 k NXObject[] sobjs; 5 a' S, E$ w9 j9 U# V9 I
Tag[] tagList;
# r) b9 i, a9 K- R# Y Point3d cursor; $ H7 h" m% ~9 }, S7 Q' u# [
int i = 0; , a4 ^ S2 Z2 \- N* @# x7 i
3 N v' k' [2 I$ h) n' p M
theUI.SelectionManager.SelectObjects(cue, title, scope, saction, false, false, smask, out sobjs);
' F+ }4 I7 E. t0 l, [% x& z: f2 K+ v# z. Q: d; g5 H- E
if(sobjs.Length > 0)
1 Q. w- m7 ~. | { ' ?9 p( w. q; S) h6 H
tagList = new NXOpen.Tag[sobjs.Length];
! x1 Q; t% [9 a, V* V/ m- f" R4 W
! r# b2 N" a: Q+ t& P3 W: V foreach(NXObject obj in sobjs)
/ F. C8 F x% U { & O4 `9 x! S' L# K
1 V" C7 C M9 i. o+ _; i2 m- F
tagList[i++] = obj.Tag; ; b$ Z$ n, }( L; W( U N
. F5 r- s, v) s6 f) B2 N& Y0 l //theUFUi.DisplayMessage(obj.GetType()+" "+obj.Tag.ToString() + " type = "+ type + " subtype = "+subtype,1);
. T7 x2 T a% o% z& s z } + {: L+ V0 Q7 P- {7 o! R1 J2 r" w0 `
( X8 ]0 O$ r* x' [2 _% `6 Q
string filename = "C:\\C_sharp_export_NX4.x_t"; ' y5 V( ~& Z7 N C
# \1 @5 S# r$ u# t string newStr; ! x: R. G: j G" {% P" x
string initStr = "Type your string here";
* R' V2 u& C* d string []svalue = new string[10];
0 \7 u) P% y1 |1 h8 G$ t9 W* V0 [& s, {1 [
try 6 a4 j$ ~5 p+ B/ L4 C1 N
{ % Y! y/ r- d. Y( C: N) c% A/ V
while(true) ( A8 t- d& g5 Q( M
) g/ X( @6 A( j0 T1 ] newStr = NXInputBox.GetInputString("请输入文件名(*.x_t) 【完整路径】", "请输入文件名(*.x_t)", filename); 4 F3 H0 p- N, O+ G- ?. I
" v/ i) e. N! R h5 h/ m' X+ t if(newStr.Length < 1)
' G8 N' ?: w% d return 0;
8 l4 W! x1 ]1 [" f$ b6 y! T4 C' ?. m- i: \, O$ p1 Y
if(newStr.Contains(".X_T") || newStr.Contains(".x_t"))
0 C* W+ C+ u0 c- o* |6 S0 d! H {
# F3 v4 O) l- X8 Y2 f. m1 _ filename = newStr;
7 S5 X) R0 ~% t& A/ x$ k" z }
- O1 `' i) ~( _; Z0 h6 f, d0 Z: ]& `( y" D2 w
else
& e- |) ?4 T1 C7 C: k {
: P8 G' x1 `' V) D! @ filename = newStr + ".x_t"; 1 Z/ U, U) F: T' d" }" `
' G2 s% O, R( M" n$ |8 k: S3 ]8 b
- l/ N' \& p3 c6 A4 X( O& f if(!File.Exists(filename)) ( x3 m" _9 v) d1 \ |7 N2 L' {5 S0 g
4 L5 S/ Y+ E5 \$ e( H) n0 y7 V6 a i = 1;
6 O9 O/ }7 J i" L7 ?8 p break;
+ Z& g( v7 L& Z& P9 h) d1 g0 m% T, p% L } ! p* e6 n9 f" }, ^- W, J9 f6 d
else
0 O2 v+ {- d9 b/ I! @ {
& N4 E% J$ ]0 I. a! O theUFUi.DisplayMessage(filename + " 已存在 ! 请重新输入 !", 1);
% A" P$ S5 D' l2 ?7 W q- r6 C( C! A7 w } . k1 ]/ z3 d4 T' }2 P
} + o! Z. F/ J$ q; g4 B
} $ R K$ V2 f+ q# {
catch (Exception ex) 8 S9 q+ o+ z# b
{ # L h- x. B6 I$ M0 E& M
MessageBox.Show("Oops", NXMessageBox.DialogType.Error, "No valid input...exit"); + U2 L# E2 f3 Q2 J; ` _' Z
return 0;
' y' z+ M7 V$ d- A# M) M% L0 r% J } 0 K3 c+ k# z' t8 A4 N+ p5 [
* y& h( s- u R1 t) J4 Y. K4 V' l2 } if(i == 1)
2 u2 c) V' e3 y; F' s {
: ^$ P) N0 \; T theUFSession.Ps.ExportData(tagList, filename); 0 N" I& a4 a2 s+ j5 I
theUFUi.DisplayMessage("已导出至 " + filename, 1); $ ^$ _) P. F2 G1 F5 O. w& w
% ^6 a( P5 g. ~/ L }
. G' j$ f6 [2 h% r% Q return( 0 ); 1 t5 `, F& ^% ~8 O
} 7 y' N6 C. P. S9 }7 g5 i
& l- [+ {9 d+ \; t public static int GetUnloadOption(string dummy)
1 u) J5 a# I7 {) Z; \ {
5 r' b+ Q* @4 r, v! B6 t return UFConstants.UF_UNLOAD_IMMEDIATELY;
8 [, x: a/ p0 P _6 v7 K4 x# @ } ) P6 d0 P# p: U
} . ?) P4 c. d% ]6 }# d# ?) z- i/ H- F
} * m. O9 K) n" Z# ^
7 w: j7 a, F7 p/ o7 r. \+ L3 N6 c M2 G
//可直接调试运行. x ?- w( C7 d
//仅供学习交流! ! (smthan@163.com) |
