查看: 8849|回复: 40
[疑难] 法兰克CNC工作时总是提示”Z轴超程的"
发表于 2012-5-12 22:12 | 显示全部楼层 |阅读模式
后处理器选择“MILL-3-ASIS"生成的程序传送过法兰克CNC工作时总是提示”Z轴超程的"不知问题所在,求赐教
1 g8 C7 l  f" C5 ?8 J%1 U, k5 V1 X9 s3 H
N0010 G40 G17 G90 G70
  L; ~" l% ^, q- k( i+ DN0020 G91 G28 Z0.0
7 N+ ?/ h$ h* G% H: U1 I6 v:0030 T01 M06
1 o& Q" K- u6 G. IN0040 G0 G90 X-1.8898 Y0.0 S2000 M03# g9 C4 f; f) d! S, l* G& a9 K
N0050 G43 Z.1575 H003 u. I3 d; @  a
N0060 Z.1181
* D5 N3 |, a: G7 C: GN0070 G1 Z0.0 F19.7 M08' g/ X/ K2 r; Q, q; o" ~. A  n
N0080 X-1.6929
% Z, [3 }8 `) x. o# n2 O4 G6 SN0090 Y.90551 n+ f) Y6 {) B$ w1 _; ?& X
N0100 G2 X-.9055 Y1.6929 I.7874 J0.01 S7 w7 Z) I) A* F- A1 k& ^
N0110 G1 X.9055; ^/ \9 K; a* V1 U' o5 A. ?
N0120 G2 X1.6929 Y.9055 I0.0 J-.78740 B4 ~: w& W8 y4 p' r9 o
N0130 G1 Y-.9055/ p! K8 t. f* `7 b2 ?
N0140 G2 X.9055 Y-1.6929 I-.7874 J0.03 Q$ A8 o+ Z: S; I& P$ u: N8 X
N0150 G1 X-.9055+ P" z7 m4 b% b: I* g
N0160 G2 X-1.6929 Y-.9055 I0.0 J.7874
, H7 h0 L) b; Z4 c2 Q0 |N0170 G1 Y0.0
" i8 }" W: u2 mN0180 X-1.3976
# }3 ^0 I/ q; C4 k& E( GN0190 Y.9055
# s/ Y0 _) s3 |& Z% s6 d' [N0200 G2 X-.9055 Y1.3976 I.4921 J0.0
. q: j# d' z( c4 k0 r; B% qN0210 G1 X.9055
1 V& I) Z! f8 s( ?/ [, {& AN0220 G2 X1.3976 Y.9055 I0.0 J-.4921
! n8 l. X; H9 G* ]/ z. B. {N0230 G1 Y-.9055
- L: [$ N# m! m- b: [N0240 G2 X.9055 Y-1.3976 I-.4921 J0.0
# y: R* @# x- X9 B# I5 D0 q0 z: W! eN0250 G1 X-.9055
" j) E1 M* f, b. z) A" _; \N0260 G2 X-1.3976 Y-.9055 I0.0 J.4921& a1 O. C5 n# I* K) b$ Z; {
N0270 G1 Y0.0; b3 C- y2 H0 B
N0280 X-1.1024+ e" [  ~5 Y; |4 S  E! t. D, F
N0290 Y.9055; x% u# W: q* B6 h, u" o) Z
N0300 G2 X-.9055 Y1.1024 I.1969 J0.0
) x& t. a* c/ t. |6 IN0310 G1 X.9056
4 }+ y2 r% _/ n; k4 |7 D& PN0320 G2 X1.1024 Y.9055 I-.0001 J-.1969
* d1 z  R4 P0 t: w& f8 KN0330 G1 Y-.9055/ N& k9 C  H4 I1 l# c7 [2 U
N0340 G2 X.9055 Y-1.1024 I-.1969 J0.01 t" ]+ r0 U% v0 i1 N
N0350 G1 X-.9055. m& y6 F& _6 Y7 F
N0360 G2 X-1.1024 Y-.9055 I0.0 J.1969& q3 |; m% j) b4 Z' n
N0370 G1 Y0.0' B9 X; L. r& V$ E& p* ~5 z
N0380 X-.80716 ?# X7 s* T0 g" X1 R8 X
N0390 Y.8071& B4 d6 [& b1 m0 A' b* R* _! Z
N0400 X.8071
) [' E' R. ^% l; s! x( @N0410 Y-.8071$ o* x3 N/ r4 G
N0420 X-.8071
9 Q- p! o; j9 C$ e4 a4 f7 tN0430 Y0.0
7 u5 Q; I* V$ _N0440 X-.5118
% Y8 J  Y) g* n' W2 jN0450 Y.5118$ e6 ?" ~8 s( b% {
N0460 X.5118
0 M& t* O& _% n. k& K' `1 p7 GN0470 Y-.5118( h- B2 Y" i0 \1 N. ^( }2 s1 Y2 Y6 {
N0480 X-.5118: e/ A+ z3 I3 o7 o- |
N0490 Y0.0! B( T" ]+ q# x- S5 g
N0500 X-.2165
) Y1 M& L% R% T) f: {8 JN0510 Y.2165! w! R8 W5 ^( E* q, e
N0520 X.21655 F% Y: T. F/ O5 a1 C$ Z2 E9 V
N0530 Y-.2165# y( _. W& f7 p
N0540 X-.2165
$ U7 ?2 q+ T, r- {N0550 Y0.0
) L$ y2 v7 F5 r( |; U7 HN0560 X-.0394
" j+ A- G7 ~) u; @4 G# N: LN0570 Y.0394) X% }0 B& j. i' _; W# T3 j
N0580 X.0394
6 z) F1 ^3 s& j$ c* Q( uN0590 Y-.0394
: @- j* g9 N$ ]+ O3 Q) W" fN0600 X-.0394! C& l2 G) y  q7 a
N0610 Y0.0( d7 l, s% V! W
N0620 X-.2362
; F$ Y+ z7 ?1 s6 q/ CN0630 Z.11815 Z3 v, d% |6 a
N0640 G0 Z.1575
1 o4 h9 N; C, z2 g. YN0650 M02/ K" j+ S- C6 i1 t# k+ b
部件安全距离
部件安全距离
发表于 2012-5-12 23:02 | 显示全部楼层
G54,G49没有
 楼主| 发表于 2012-5-13 08:44 | 显示全部楼层
完美有缺 发表于 2012-5-12 23:02
/ t1 G/ E* p2 y; o$ w; P8 EG54,G49没有
% b  Q4 ~9 c+ t8 ^: v; B3 B6 v谢谢你的回答。。。
 楼主| 发表于 2012-5-13 08:45 | 显示全部楼层
谢谢你的回答。。。
发表于 2012-5-13 15:48 | 显示全部楼层
還有,樓主有沒發現,您的程式碼數值有點小,UG自帶的POST是英制的,要選一下輸出的單位喔!
发表于 2012-5-13 16:14 | 显示全部楼层
& s, y# N7 G- e/ b1 U
N0010 G40 G17 G90 G70- P$ [* V8 w  W5 u0 M
不見了G49: f: r" z  R( R+ y) }
G90 X-1.8898 Y0.0 S2000 M03: T2 Y( v8 a. i4 ^' N
G90後面沒定義加工座標2 A: s- s+ t# Z
N0050 G43 Z.1575 H00/ {  M$ |; T5 w2 o) K7 u
H00要改為H01與T1M6補正不一樣
发表于 2012-5-13 17:06 | 显示全部楼层
主要问题应该是在于H00 应该是H01  刀补没加上
发表于 2012-5-13 17:24 | 显示全部楼层
你刀补使用G43了吗,还是直接在G54测量的刀补.如果后处理用G43,刀补在G54就会有超程
发表于 2012-5-13 18:21 | 显示全部楼层
刀具长度没补,G54,G49不用加,那是系统默认状况,,,原因只有一个,不加刀长,Z0位置在机械坐标系原点,超机械原点Z这个值当然报警了
发表于 2012-5-13 18:52 | 显示全部楼层
别的没有可以走,就是H00换H01就不会报警了。后处理换个就好了,你用长度补偿就要对应啊
GMT+8, 2025-2-27 11:17 , Processed in 0.056257 second(s), 24 queries .
