楼主 |
发表于 2012-5-16 22:53
显示全部楼层
%_N_RPCP_RAM_SPF
/ r. H9 P% \6 z. g( j;$PATH=/_N_CUS_DIR
$ ]' M8 p I# H, ~- `' j;(PROGAM NAME-RPCP_SPEED RAM)
8 [, R9 o. `4 X;(DATE=DD-MM-YY - 12-09-10 TIME=HH:MM - 16:00)/ H5 M# W7 Z8 M( ?9 t( R
;(EDITER XU HAI)
) G; _" l6 J- R/ T: [0 T( c# iPROC RPCP_RAM (REAL AAA,REAL BBB,REAL CCC,REAL DDD,REAL EEE)
1 B0 t% i$ N; t$ s6 D, f( s;G_COMPACC=0; `: C) \/ ~% Q3 y" K- f
DEF REAL RR1
5 `, Z/ n( `0 p3 ` S. SDEF REAL RR10
- e1 [4 q3 p% B" c. jDEF REAL RR111 J2 B; p9 `( i& C3 s. M0 D* j: y' F
DEF REAL RR12
0 }' T" q3 c: x# {, M8 GDEF REAL RR25
' v7 Z9 P+ W2 A/ q4 e5 _DEF REAL RR26
2 [6 x X2 l# X2 }+ |, zDEF REAL RR28
/ m1 z" y" \' f8 g; WDEF REAL RR29
: f# O( l/ k& Q+ q& j% i+ RDEF REAL RR13
! q6 l! r4 B3 T$ P& E( g/ R2 CDEF REAL RR14* a* c) O F# [' e
DEF REAL RR15
. ~' c6 q( h* I* c4 `. {' MDEF REAL RR16
$ d' N# B' Z5 M. m8 RDEF REAL RR17
( V; N/ @0 [$ L- B( q2 mDEF REAL RR18
- s) E5 B [; D- S& E* _* BDEF REAL RR40. R7 y/ H. C# j! S0 K" e
DEF REAL RR196 r, X K# |: E) K [' J
DEF REAL RR20; W: h5 z# F) x1 {
DEF REAL RR21
c/ U4 ]' L2 K: uDEF REAL RR22& w+ `: _8 z, j
DEF REAL RR23
|! @! X& O! \DEF REAL RR24, n7 E) I" {6 h. B7 {2 P0 {
DEF REAL RR35
# c* W9 `( V# y: D9 y6 \CUT2D, {) k$ N5 ~( e( J
TRANS
4 z2 O# W% \/ c+ x5 dRR1=$P_UIFRNUM1 a% p0 A& j& R% K+ K5 H* J
RR10=$P_UIFR[RR1,X,TR]
4 Q/ q: b( \+ C8 qRR11=$P_UIFR[RR1,Y,TR]
6 {5 S7 ]6 F( h+ [) e3 _! mRR12=$P_UIFR[RR1,Z,TR] . ^! q6 N7 d* M' A1 }) S
RR25=$P_UIFR[RR1,W,TR]
6 {, M3 V# B; X% U& o9 P$ J/ |RR26=$P_UIFR[RR1,V,TR] 1 R B) d. @# W
RR28=-2100.381-3000-RR26-0.25+3.195 ;Z ROTATION POINT
- D4 O$ q* ^/ @4 qRR29=-2427.166-0.3 ;X ROTATION POINT & \/ ~6 P( `* K7 K
RR13=RR29-RR10# v# i# y) i9 M* A3 ?# o6 y- a, U
RR14=0-RR111 e+ k& v" Z% j6 q- R9 X
RR15=RR28-RR12-RR250 k! T/ E4 R" o+ [9 L9 L! Z
RR16=0-RR13( A7 l5 s7 ~+ y" S! e! ^ u# u
RR17=0-RR14
, q% `4 w! W7 N5 w1 Y4 P; jRR18=0-RR15: G. a6 T) l$ j
RR40=$AA_IW[B]
% c, B: y1 \" x9 D9 u# q9 CRR40=-RR40& ~, k `) e( h# Y
RR19=RR16*COS(RR40)+RR18*SIN(RR40)
3 u5 ]+ X# G$ d* J1 VRR20=RR17
- I; D: ~; C- Z, H7 B& q5 lRR21=-RR16*SIN(RR40)+RR18*COS(RR40)
2 `' X: m7 d( W& n% i- C' NRR22=RR19+RR13
+ P. ^8 O4 f5 G( URR23=RR20+RR14
5 y3 [3 T- k; S* kRR24=RR21+RR15
/ B3 |$ z# r9 e* O7 c, qRR35=RR24-AAA-BBB - R! [- T- O* ^( Q* j, c6 I
TRANS X=RR22 Z=RR35 W=AAA V=BBB
( d0 }1 G; h7 Y4 B0 `5 Q% D+ zATRANS X=CCC Y=DDD Z=EEE
# C6 N- m5 J) L5 ^D1: C5 P T& ]8 \6 k+ |0 o
RET3 z; i: b B9 U# C4 ^
M17
) D6 H* K/ S( _) V%_N_RTCP_TABLE_SPF
S' J$ J* w0 _+ e$ c;$PATH=/_N_CUS_DIR
1 l7 F0 X) l0 J1 T L;(PROGAM NAME-RTCP_TABLE)
# V2 x+ A7 s/ m5 R# j, N, G;(DATE=DD-MM-YY - 12-09-10 TIME=HH:MM - 16:00)
O$ A' E& r. o- e9 M;(EDITER XU HAI)
* Y+ c( ^4 T: v( {0 V! z$ zPROC RTCP_TABLE (REAL AAA,REAL CCC,REAL DDD,REAL EEE)
/ {& d( l* Z5 T- @CUT2D
$ d, w7 p+ ^! h/ j( iATRANS
) m5 G+ m( ?' Z0 a! n3 V7 n; vR35=R24-AAA , \ A6 y* N/ P0 f2 h H, y4 Q
TRANS X=CCC Y=DDD Z=R35+EEE W=AAA
/ [4 e8 a# Q. f9 D7 L% UD1
; w( T; W+ w! p. ^RET
; W0 Y1 m# [& K7 ?2 vM17
* k. l- B! f: Z# b
4 T8 J6 Z1 {3 ~1 A
: p2 M' a2 ]( i `
" \( [1 ^& e: G- D9 s%_N_RTCP_TS_SPF
( N- ^; a+ x: X7 |;$PATH=/_N_CUS_DIR
# U! u R5 [% g& h) ^0 _% l, K;(PROGAM NAME-RTCP_TS)
7 |: T2 g" c1 {;(DATE=DD-MM-YY - 12-09-10 TIME=HH:MM - 16:00)
1 s( t7 ?5 R2 ]1 R;(EDITER XU HAI)
: Q, j3 }2 A1 K* ] a5 dPROC RTCP_TS (REAL Type,REAL AAA,REAL BBB,REAL Working_plane)
7 U- H1 O! O' ]0 v7 ^' s;G_COMPACC=0
Y4 N$ U2 G- z7 x6 s5 `* C* OIF Type==35 GOTOF TS35
7 Q9 A# N( D$ j" `" z;-------------------------------------------------
. r* ^0 O5 |1 v1 m3 X WTS35:
5 ?! P- z' b/ M+ tR1=$P_UIFRNUM2 @6 [+ e2 b! h5 J0 [6 H' s) c& c
R30=$P_TOOLNO
/ X3 y) H9 d1 X% ~0 ^R31=$TC_DP3[R30,1]
! S$ h+ g2 q. Q* _R10=0
1 a( i r8 w6 M' VR25=$P_UIFR[R1,W,TR] - D" X* r0 e$ p* l
R28=304.232+R31+0.25 ;ATTCHMENT HIGH( T! q7 E! R v' Z
R29=438.739 ;ATTCHMENT LENGTH B7 `9 N/ I u4 ^# N* h; ^* I% @
R13=0-R10 , y; s9 y4 G$ k( Y) J8 c
R15=0-R28 ! J# K% Z2 m/ }6 H( `
R16=0-R13 / b/ T. ^% U$ ~$ h4 o0 k
R18=0-R15 4 D! |7 z. J: }+ J
R40=-R40;-G_AXC_REQ
8 }# }* W, P! D7 a [1 XR19=R16*COS(R40)+R18*SIN(R40)+ `% N+ {0 @2 a$ T
R21=-R16*SIN(R40)+R18*COS(R40)
5 A2 V, t$ c" ^3 h! F! O4 QR22=R19+R138 F* ?: K2 Q! ~9 i# E. P8 S
R23=R21+R15$ x P7 H7 _, _" z
ATRANS Y=R21 Z=R29+R25-R31 X=R19+0.178 T, L# O3 z9 F# p" M2 ^+ y/ O
AROT X-904 P! u0 N: E8 z8 Y2 `
AROT Y=R40;-G_AXC_REQ2 V( d. L$ ^, O6 U* c R
ATRANS X=AAA Y=BBB Z=Working_plane
6 l2 u( y/ B. k- R2 h$ HCUT2DF4 E5 C) F" y2 @3 V
;TCOFR
9 U7 z1 H0 F/ x+ D: B" TSTOPRE1 k n5 N/ | x" O% g" ~
RET
# Z/ e) f5 E+ oM17
: d9 D8 a7 a6 u, }! J. s8 D/ L
: `! d# \0 g ]1 y$ X l/ `/ M E2 _, ~: z1 A; M
9 o" E8 J; O$ C+ l
" V: @5 V8 U+ K% F! p7 A+ v' c这只是部分示例 明晚我再完整传上!谢了! |
