程序如下:* h$ Z- S2 T4 y' {4 r
// CreateBlockExt.cpp : Defines the entry point for the console application.
X5 M, d# {8 X2 J: O- i//& i, J- W. v7 |% K0 _# k; [
#include "stdafx.h"
5 h8 Y% E! k4 b4 u/ a7 j#include "stdio.h"1 D3 Y1 P9 r6 r1 Y6 S
#include <uf.h>! z* d9 [& |. I" @# O
#include <uf_ui.h>$ D0 q, i0 ^# q- P1 u
#include <uf_modl.h>
6 }( z; Q1 g1 S# n0 U |, X#include <uf_part.h>
l+ W" b: o. J2 k#include "uf_weight.h"# c X5 y) y- e# b' G+ B, M
1 ^* e2 p! j- d/ y#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
* d4 N! T W N7 Mstatic int report( char *file, int line, char *call, int irc) S% O/ a, M" ^7 E% |' o+ ?8 V
- H/ _) a' v) O8 b( q if (irc)
/ h9 y) h p* T/ ~9 Z) v* o4 d {
1 e- {1 D; W$ b2 R& C char messg[133];
3 \0 W% u0 g% ` printf("%s, line %d: %s\n", file, line, call);7 W9 `' x! f" P0 K; z7 r6 m( |
(UF_get_fail_message(irc, messg)) ?" t/ C) v; U4 j( s7 J% N% G' M
printf(" returned a %d\n", irc) :$ q* o* {+ |: E k% A
printf(" returned error %d: %s\n", irc, messg);
1 m! B( A0 S' C5 D0 q }( h( }% T7 ], T
return(irc);0 M5 }2 G2 u& R2 {! B( g/ t( _' Y
0 [& M* I# M% ^/ \
1 c+ ?$ H0 l2 {; `static void do_ugopen_api(void): }, l7 h- t# h% T& t: o
{! B" i3 G( u; n% b
int scope = 0;//只关闭当前文件,不涉及子装配! m; `* N$ k5 r* G U
int mode = 1;//
$ z1 ? f( U/ }3 N" k6 ~! J/ N char *edge_len[] = {"1.0","1.0","1.0"};//立方体各边长! s% q' s; G( n) N. q. n: |
double corner_pt[] = {0.0,0.0,0.0};//立方体原点坐标3 c i" g* G' ]- w U
tag_t block_tag;
+ `% m5 J, _( s$ V, i2 | tag_t part_tag;$ G; t( S) r% ~5 z
/* 创建一个新的prt文件 */4 \- _7 }7 m: |! i* q' M
UF_CALL(UF_PART_new("a_blank_part.prt",UF_PART_METRIC,&part_tag));& ~9 N9 M: c, b8 S2 w8 v7 ?
/* 在prt文件中创建一个立方体 */
; o% D! k# r* I) I m UF_CALL(UF_MODL_create_block1(UF_NULLSIGN,corner_pt,edge_len,&block_tag));
5 s1 F9 F! E) ^) W+ m& J UF_CALL(UF_MODL_set_body_density
+ b- ?1 H% K, [/ h9 S (
( G" U/ E! c% c( i, q& S6 W0 c block_tag,/*tag_t body, /* <I>
0 U! Y; K+ R" q" A( e solid/sheet body
3 u2 s& y+ Q1 T */0 ^0 k+ ]% S4 ?9 L' W% _) L$ T' w7 u
UF_MODL_kilograms_meters,/*UF_MODL_density_units_t units, /* <I>' ~+ s* r7 ?) i; X5 U! I1 ?
the unit of 'density'1 Z3 a* A" s* n- ]+ i+ R) g
: d: t- ?9 L. s* B! ?4 \ 0.001/*double density /* <I>
- P5 _2 h: J; Q% ]7 R P density of body
6 C4 n5 G) L8 \ */
, t" C7 m5 h( u' k, Y5 w ));
6 `* B/ u2 V8 y" k+ b2 U; ~ UF_WEIGHT_units_type_t units=UF_WEIGHT_units_km;
5 O& _; W6 c+ ]* } F) z1 R2 z UF_WEIGHT_properties_t properties;8 V7 q" Z* W* k: o
char *cset_name;5 \8 a% Q0 ~8 S+ u5 f
char text[128];8 U) |1 x) r4 V7 n
cset_name=text;
9 K% I$ m' I5 k% u* @ UF_CALL(UF_WEIGHT_estab_solid_props(2 @3 Q O- N/ C& z
block_tag,/*const tag_t solid ,/* <I>
% V. I( O2 P9 C& c4 P The solid whose properties are to be, X% H8 l# q; ^* x9 W* O
calculated. v; ^: X$ p, s3 J7 k% s. c1 @
/ a; R$ x& i8 i i8 F( H( l4 S& ] 0.9,/*const double accuracy ,/* <I>
% _" C: f6 @( R4 l% P3 Z The accuracy to which the solid's properties
~5 S' Q3 @6 K j are to be calculated.2 X# N" w( |( N
*// W! [* e, `! D6 @+ E) d
units,/*const UF_WEIGHT_units_type_t units ,/* <I>. @0 a* h* w. @5 V" ?
The units in which the properties are to be
; b! z4 D' z) R1 [! m* M' K returned.8 X. z B2 R7 @ K- R
*/: x+ f" E+ N% i; {- ?$ G/ I& a
&properties/*UF_WEIGHT_properties_t * properties /* <O>
' ?- F; J" F$ a( i8 h4 k& [ The established properties of the solid.' v2 j/ B* a1 i' l6 B) w
" T Y. a1 j: ]. A1 h ));
1 d; {$ J* v: a% x3 U! h. F% m printf("%s",cset_name);
I9 F, N$ _" F2 i( n% ]1 j8 O//UF_WEIGHT_sum_props() 1 q: B r3 e& ~- }0 \
/*保存此prt文件 */
( [# ~- `0 J% r2 G- g UF_CALL(UF_PART_save());7 m+ Z' {, Z$ n
3 C+ r( W* c' z" d" R2 n! H+ P; O
/*关闭此prt文件 */
2 {( V M1 P" e, R- | UF_CALL(UF_PART_close(part_tag,scope,mode));
8 l/ A2 {' p( Q0 \. Q- |- H2 Z}
$ }9 ^! t/ s& a0 l" I2 J7 r( x. e( D$ ]
0 B) T6 o" `" q' A
int main(int argc, char* argv[])
+ i: c$ u* z% f! u7 f{
Z& u! p2 H" \ if (!UF_CALL(UF_initialize()))
8 a! d, D9 M) q% M {8 S' {' i* V J& e
do_UGopen_api();
/ }3 Q- \* J( u3 ` UF_CALL(UF_terminate()); E. h! X' ]! E/ |
, s; q% h) E7 U8 j& k& W return 0;$ ?- X% x" g$ M' y! r+ Q6 K
}' w! Z- S, u3 d* P9 J9 ~
) z0 @: D3 E2 @, }: y% Q8 J
结果出错,错误信息是在UF_WEIGHT_estab_solid_props一句the first parameter passed in was invalid,第一个参数即block_tag,经逐句调试至少在运行这句前它是正确的指向那个正方体的,但为什么会出错呢?
' n$ J4 e6 r8 j |
