查看: 2887|回复: 4
[分享] 关于部份機床不支持在G02/03中同是輸出I,J,K值的解决方法
发表于 2012-5-28 13:54 | 显示全部楼层 |阅读模式
( y; A" Z& p+ }4 F9 |' G  m: u" F: u+ J2 f) _, p. W
关于部份機床不支持在G02/03中同是輸出I,J,K值的解决方法,方法在楼下,红色部分是我添加的
 楼主| 发表于 2012-5-28 13:55 | 显示全部楼层
##############################################################################' k7 K9 C, \2 \4 C" W
, r0 y, ?* ^* Q. i2 s3 R# Copyright (c) 1999/2000/2001/2002/2003/2004/2005/2006, UGS PLM Solutions.  #
; f( F9 U9 V* s( G7 Z#        #
( e! m4 R7 M4 A, e2 o##############################################################################
1 C! c/ H' p6 i% r' s- Z. g+ S#@<DEL>@ TEXT ENCLOSED WITHIN DELETE MARKERS WILL BE REMOVED UPON RELEASE.; U  E( H" R+ X; |
8 q1 G4 ^# U5 w4 b- A1 O# 08-01-2006 gsl - Corrected "switch $mom_sys_cir_vector" found by Lili.2 T3 f" b1 M/ g3 J
8 @/ W" h8 x4 `# TEXT ENCLOSED WITHIN DELETE MARKERS WILL BE REMOVED UPON RELEASE.    @<DEL>@
, S  g  L( `5 A6 m, ^9 Y9 X6 s1 @5 _0 m! U2 X
#=============================================================: ~9 D6 u/ k$ _3 M$ e
proc PB_CMD_init_helix { } {
+ X# h  ?+ W  V0 V9 q#=============================================================
. T1 B3 k+ x  z+ o# y! q: ruplevel #0 {
4 X" z" @) e0 q$ I8 q! B0 i#
# i& m+ p4 I' O% x$ f; [. I  E# This ommand will be executed automatically at the start of program and3 h4 _: |. w9 ~
# anytime it is loaded as a slave post of a linked post.2 R6 @6 L: |% {
( n% Y0 a: c# [2 ]; d# }# This procedure can be used to enable your post to output helix.* h! B( {4 R# C1 B' H' ]1 u
# You can choose from the following options to format the circle : a1 [% ]% N. S$ S( G
# block template to output the helix parameters.
7 h7 T7 K; L* H1 L, A" o) d#
* z% X/ M; i5 n, }, e9 G% |; H; ]4 x. R, h0 Q
set mom_sys_helix_pitch_type        "rise_radian"  ! t4 n0 w  n$ i5 K: N/ A- q$ l
- X0 T' ]' U% U
#8 t! }4 m# Y" D. L/ n3 l- b
# The default setting for mom_sys_helix_pitch_type is "rise_radian".5 _/ s' p" ]: H# O1 r7 @4 B4 j9 E
# This is the most common.  Other choices are:
: F1 I8 b" e1 l$ _#2 m+ k$ n, X6 q) D" I
#    "rise_radian"              Measures the rise over one radian.$ P* Y5 P0 ~" k+ ]  O5 V, W+ A
#    "rise_revolution"          Measures the rise over 360 degrees.' ?9 `' {" z" z* \( g, n7 g
#    "none"                     Will suppress the output of pitch.; V/ H0 P/ [( X3 b) i% T' K
#    "other"                    Allows you to calculate the pitch
! u; O) f; B9 q' m& v. z9 g/ [" [#                               using your own formula.7 U# N0 J- d+ t" C% L# `
# / t) O0 K& F# j* E) A+ v! g6 I
# This custom command uses the block template circular_move to output5 _- p5 M. _0 z, [3 W/ [- C' a& s4 y
# the helix block.  If your post uses a block template with a different
" q; e! ~- U- Z% S/ c/ L$ Z1 m# name, you must edit the line that outputs the helix block./ X* o) Z0 g: `8 d% a5 H8 Z/ u8 C
" W4 Z5 @' }. }6 ^/ K+ j% v; s  Z3 `
#& F6 W7 D: m2 r6 i$ Q, y* y
#  The following variable deines the output mode for helical records.+ c/ `5 D" N  ?- N; B3 a
$ k4 M, H$ L5 R, g4 t% s#  FULL_CIRCLE  -- This mode will output a helix record for each 360
5 x$ S. P5 w, d4 w#                  degrees of the helix.9 O6 H+ _- D& O, H6 t: c
#  QUADRANT  --    This mode will output a helix record for each 90 " O; Y5 v; _7 u1 D- U
( Z* j. s' y3 \1 ~, s+ W& M#  LINEAR  --      This mode will output the entire helix as linear gotos.
: F- Y7 h# }1 u. y$ T, K#  END_POINT --    This mode will assume the control can define an entire
* t- t8 x# R; {#                  helix in a single block.' o* O" d5 v& b3 Z- Y. D0 V
$ I8 S) |) X0 c; d
   set mom_kin_helical_arc_output_mode FULL_CIRCLE) [' l; W/ }! O7 m: ?+ @0 ]/ @" p. t
" K3 o2 t/ q4 I$ y& {7 y, y1 i  \   MOM_reload_kinematics- \9 ?3 [0 ~9 y
. P" x( H2 ?, E
3 M; Q- A. f  j* C
0 s$ I. t) c' [4 E" X( g  Y0 W/ |/ i
0 i% Y5 S6 j, nproc MOM_helix_move { } {3 i6 F) Y( r# k6 a! H& U: h1 S: t
#=============================================================7 N6 p* {! h+ t) \, @0 ]# A; Q; ^+ \* h
   global mom_pos_arc_plane- g$ l& p* k; X  G
   global mom_sys_cir_vector5 a& U/ @. V8 X' @# H; [! ]
   global mom_sys_helix_pitch_type
) a% v, L. G7 s0 ~$ z8 \& P' I   global mom_helix_pitch
0 y% j( l0 T$ Z7 N2 C4 z   global mom_prev_pos mom_pos_arc_center# l  ~4 d. D$ V4 o" N/ `& Q, M
   global PI" K* e3 W8 P0 w0 ?: _
# f7 l+ n. q0 X+ A; I1 s. O5 s' l
   switch $mom_pos_arc_plane {
  I$ U+ O. d' {& v      XY { MOM_suppress once K ; set cir_index 2 }- o! q! q1 K4 E* Z
      YZ { MOM_suppress once I ; set cir_index 0 }/ p1 k0 G% U; J& s. X) \
      ZX { MOM_suppress once J ; set cir_index 1 }
0 j1 e  f8 q# N6 u: p# \   }5 j$ _- k6 Z. }& V
/ y8 v- y. I0 u) K6 f   switch $mom_sys_helix_pitch_type {- D) d6 X8 X) k/ {
      none { }+ |) G6 z) d) g8 t3 |
      rise_revolution { set pitch $mom_helix_pitch }
7 G; o) R( b, j& d6 h2 S      rise_radian { set pitch [expr $mom_helix_pitch / ($PI * 2.0)]}3 G& X7 Y+ H# q; A2 c
      other {
4 j/ ?* Z2 {% g% i7 K#
$ ?7 j0 u9 p' }: f& c  h$ O" S#        Place your custom helix pitch code here
" q6 G% B2 _. R, Y' `#
6 w2 V3 g% E$ O      }
* G4 U) ^) H0 q. _& {      default { set mom_sys_helix_pitch_type "none" }
! j2 H+ S# P9 s; U! q   }
9 q4 V6 T' A0 V. A, c      N7 F) @$ C) \- d
   MOM_force once X Y Z5 R% P0 ~" Y1 v, B
3 @) m$ z/ q# M1 g3 A) y, ?: h) I7 {   if { [string compare "none" $mom_sys_helix_pitch_type] } {
5 F2 I4 L0 j+ P/ y      MOM_force once I J K
% p' O' g1 e5 E3 w1 Y+ w6 I5 A- S#<2012-5-15 yhw>
& b5 S% O% _3 r7 u, z      switch $mom_pos_arc_plane {
2 n; ?- L. g! |7 ]# Q8 F         XY { MOM_suppress once K ;}
5 z2 }2 n. {  H( w         YZ { MOM_suppress once I ;}/ ^) B9 Q& T; l& l  d! ]2 U
         ZX { MOM_suppress once J ;}
) u. W8 g. W5 t      }
  ~& m6 C5 i( P  H4 _: c#<08-01-06 gsl>
( P. k9 P( j  G. ~/ z7 a/ M, A8 c/ r& T      switch $mom_sys_cir_vector {
4 k+ S5 ~. j( s         "Vector - Arc Center to Start" {. `$ |( d* Z5 b8 P2 D" N* U$ a
            set mom_prev_pos($cir_index) $pitch
  S/ e2 t4 R/ V/ W! l9 ~  i5 M- B' K/ o            set mom_pos_arc_center($cir_index) 0.0
* r0 W8 S2 S/ z2 s, w         }' D( u  t5 I/ @% e. u8 z
         "Vector - Arc Start to Center" -
; D  I- ]! i8 p% A         "Unsigned Vector - Arc Start to Center" {8 ]) |9 C8 ^! R! X3 l
            set mom_prev_pos($cir_index) 0.0
4 K$ M- W- M. D+ M% `! t# `            set mom_pos_arc_center($cir_index) $pitch+ ]& J3 P% h3 R0 W
1 ]$ K2 X. S; t; ^  k         "Vector - Absolute Arc Center" {
- N' v1 Y8 t" }8 s8 Z# \            set mom_pos_arc_center($cir_index) $pitch$ n: J( Q# Q5 p# _' N# _" g
. j" I& l( f. t/ d3 q, b      }- K! R9 P& p4 Z$ F; B4 [& o
   }+ I, ?9 ]2 k2 C/ o& n
/ e, f4 S( t7 \3 L  \0 k
' `2 ?% S# Q9 N0 r1 p9 s
#+ g' ~! w) T7 s/ ]/ i
# You may need to edit this line if you output more than one block
7 \2 u7 S9 U: q  @/ U( \" W1 N0 E# or if you have changed the name of your circular_move block template7 }$ e1 r' [4 Y* d. n% h  u0 j
#) j$ x! W/ D( X1 m4 W# x
   MOM_do_template circular_move
% z' p- ^# _  C: v
# \/ ~; i; |  {. w. L' O1 G7 }
. L* M, F! }2 s0 H# M4 D} ;# MOM_helix_move
8 \6 @7 @# G" Q/ ~7 F- ]2 c( f7 w' [; w0 g8 U
& y6 B; Y3 g$ \# {% @* |' _: t
} ;# uplevel
+ K4 _" w) a4 d9 `}. W% G+ u$ a  k9 N$ D: r
! i! Y8 D( U2 e! U8 f; W0 P' i* D- O/ p4 [* V( ~7 A+ F
+ L- t0 q; ^! U9 u3 }" {( F
发表于 2012-5-28 14:26 | 显示全部楼层
楼主这是什么东东?
 楼主| 发表于 2012-5-28 15:25 | 显示全部楼层
Orange丶 发表于 2012-5-28 14:26
# ^  H& c0 J( A) o楼主这是什么东东?
9 a/ {! O$ i6 Z, _+ {. z
螺旋线后处理的TCL文件
发表于 2012-6-26 16:04 | 显示全部楼层
到底我们要怎么做??可以具体点吗5 b, b/ \; G/ _- @; @/ c7 r8 r  F
谢谢了
GMT+8, 2025-4-30 16:03 , Processed in 0.051587 second(s), 21 queries .
