查看: 999|回复: 0
[疑难] 开发"手动指定点导入部件"失败
发表于 2012-6-28 11:11 | 显示全部楼层 |阅读模式
  1. //------------------------------------------------------------------------------
    2 m4 l$ a6 G  Z9 {9 T' d# p. F1 K
  2. // Callback Name: apply_cb
    / a: e+ n0 E+ I7 c8 I" G
  3. // Following callback is associated with the "changeDialog" Styler item., a0 L% r; y3 a% P8 M
  4. // Input: eventObject - object of UIStyler.StylerEvent class. [/ H2 J" T2 ~, k# Y# u
  5. //------------------------------------------------------------------------------
    , ^0 A' T! ?! R3 p7 I0 ~
  6. NXOpen::UIStyler::DialogState TriNX::apply_cb(NXOpen::UIStyler::StylerEvent* eventObject)
    / Q: \* U" y6 H: x. N/ V
  7. {
    % G4 X! x: @8 b# b+ F' t
  8.         try
    ! U: C2 l7 `- o. |# H$ O
  9.         {( m- `$ c  }; V. F; ^9 D* C0 \
  10.                 // ---- Enter your callback code here -----; M( O: ~3 Z- @& z3 a* T% F( I9 o+ c
  11.                 NXString List2v = changeList2->GetSelectedString();
    ( r7 K! x; K* a
  12.                 NXString List3v = changeList3->GetSelectedString();0 W! T6 P4 y7 x2 G/ G) H
  13.                 char *cue="Select Point";
      b5 F; A# |. r. \
  14.                 UF_UI_POINT_base_method_t base_method;
    8 s+ Y1 ^1 d( y
  15.                 base_method=UF_UI_POINT_INFERRED;8 l. F7 g2 ?) e4 ^3 l
  16.                 tag_t point_tag;% B4 Z: \' W0 e0 f* z( L& K7 d$ _* H0 ^5 ]
  17.                 double  base_pt[3];
    : C! \. h1 H$ Y. _' y& _
  18.                 int response;
    ; Z7 F- w$ j, x  J
  19. 9 H) M, t$ u# b* D( Q$ Z
  20.                         UF_UI_point_construct(cue,&base_method,&point_tag,base_pt,&response);
    , N7 K$ Q% r  N& `, C1 W5 Y
  21.                         char  file_name[] = "d:\\1.prt"; //导入操作的源文件# [, f! h7 D- u% H) ~# i" c6 g
  22.                         UF_import_part_modes_t modes;1 G4 A- v# G$ `7 m! n( N4 v
  23.                         modes.layer_mode = 0;
    ! S( u( A9 l6 F6 j' |
  24.                         modes.group_mode = 1;
    ) Q+ V; d" x4 p
  25.                         modes.csys_mode  = 0;
    ! g/ _  u! x) x" C6 i3 X
  26.                         modes.plist_mode = 0;: g% C$ n# h& O
  27.                         modes.view_mode =  0;
    5 h/ ?8 J9 p% H
  28.                         modes.cam_mode = FALSE;0 L. h: i* V  c! Z7 }5 X5 I
  29.                         modes.use_search_dirs = FALSE;" E5 M) P* L1 g! |5 a
  30.                         double dest_csys[6]={1,0,0,0,1,0};+ S& }$ n2 d5 h" H- a
  31.                         tag_t group=NULL_TAG;
    * z5 B  |2 T8 o$ K  H
  32.                         int errorcode=UF_PART_import (file_name, &modes, dest_csys, base_pt, 1, &group);
    6 K7 \/ d  _/ K4 P8 b2 O; g9 c
  33.                         char msg[132];( k8 l$ x; J1 `& [$ q) ]1 L
  34.                         if(errorcode!=0)
    2 x+ e" m, |( O8 t, P. D3 @( I
  35.                         {  [+ K9 W$ m( i/ o( V
  36.                                 UF_get_fail_message(errorcode,msg);# h( V: y$ @7 k/ M9 k' S8 K! p4 `
  37.                                 uc1601(msg,1);
    / H) q' X; \) f
  38.                         }. c) W7 |) o, y: D3 B6 [8 o
  39.         }6 ]0 Y1 @, b& c1 C* _! h$ y
  40.         catch (const NXOpen::NXException& ex)- M4 H6 N" v) n; k" V5 u, L
  41.         {
    4 X) c5 N1 @& ?- J- g$ k* w* [4 Z; \
  42.                 // ---- Enter your exception handling code here -----
    % @& m9 A* L' v
  43.                 theUI->NXMessageBox()->Show("UI Styler", NXOpen::NXMessageBox::DialogTypeError, ex.Message());
    7 c+ C- |! {8 |! \; z- y
  44.         }
    6 M6 R$ a$ y7 E3 Z
  45.         // Callback acknowledged, do not terminate dialog: L1 P+ ^; _: j4 [, R' Y
  46.         // A return value of NXOpen::UIStyler::DialogStateExitDialog will not be accepted1 U) V$ ~! j  a
  47.         // for this callback type. You must respond to your apply button.. n! G& X5 c+ I7 F
  48.         return NXOpen::UIStyler::DialogStateContinueDialog;/ G5 Z1 ?* d3 e
  49. }
    + C2 O$ ?. ^: [5 x
复制代码
编译通过,但运行时不提示插入点而是直接插入到原点,并且命令无法结束,卡在了如下图提示:
9 I: X8 J2 m3 n+ ]7 h& H7 U3 T- G! B
GMT+8, 2025-1-24 16:23 , Processed in 0.051638 second(s), 23 queries .
