查看: 2243|回复: 4
[分享] HAIDEHAHAN 80p 后处理
发表于 2012-7-10 10:07 | 显示全部楼层 |阅读模式
我有海德汉 DMH80P 机床的后处理   公司花钱做的  0 BEGIN PGM 0557-430-08-01 MM
2 x- g0 o, Z( N/ G  e1 ; ST MachMUxxP_duoBlock
) v. n5 K3 G9 Q. v- q2 BLK FORM 0.1 Z X0.0 Y0.0 Z-100.
5 ~0 O7 c" p* W1 V, L4 A" O3 BLK FORM 0.2 X100. Y100. Z0.0* Q. A# Y& x; h/ Q+ m6 m! e
4 CYCL DEF 247 DATUM SETTING ~6 M0 @& F7 i, j! u
  Q339=+1 ;DATUM NUMBER$ R1 o' g. g' K7 P) E% k: }
5 CYCL DEF 392 ATC ~9 _4 |3 B9 F2 m; K0 H
  Q240=+2 rocess Mode ~! b; J+ B: A4 {
  Q241=+2 ;Default Weight* a+ r) C& f" Z0 a" x# w
6 M129 ; TCPM OFF2 X7 T& A3 {6 y% d
7 M127 ; SHORTER PATH TRAVERSE OFF
& F# r; l7 P# K3 I9 M% P* M7 N8 L Z-1. R0 F MAX M91
: V! m, u) n' e# q9 L X110. Y-1. R0 F MAX M912 Y* {& \/ j* X
10 L B0.0 C0.0 R0 F MAX
# D' c) w0 U- M# x11 LBL 1& ~" `/ S& s  k; p" w
12 PLANE RESET STAY
8 T! `& f# P9 ~) v, y% V3 u13 CYCL DEF 7.0 DATUM SHIFT
+ v  v& l# Y6 s$ p7 ]14 CYCL DEF 7.1 X+0
+ N5 K: M0 I1 Q- _8 s" L# P15 CYCL DEF 7.2 Y+0
! i( f7 w# |* W' s16 CYCL DEF 7.3 Z+05 @- b7 H3 Q# u% Y/ K0 r
17 LBL 0
) j3 K2 f- T% ]% n7 H2 l2 C18 M55;. s3 m$ V: T- o1 m  ?
19 ; Face Milling
8 F! X) ^- Z; i4 S) a1 s20 ; FACE_MILLING; j" a$ i  V2 p: k  e
21 ; TOOL FACE_MILL_1 D80.0 X R1.0 X B0.0
  q6 V3 \6 m2 z4 x' \* V( X2 I! O22 ; E:\ZWY\0557-430-08-01\0557-430-08-01-xiemianjiagong.prt" D0 l3 b- c, i4 F/ C6 m) X
23 ; E:\ZWY\0557-430-08-01\0557-430-08-01-xiemianjiagong.h4 K* F9 N5 _9 S& S: ]- v
24 TOOL CALL  1 Z S1100# G+ A% P" Q) o  b
25 TOOL DEF  1
7 f- r* I, D7 ?% e- M26 L Z-1. R0 F MAX M919 X% y6 _% B) E) v4 S2 o
27 L X110. Y-1. R0 F MAX M91) c: m' I" }" J
28 L M126 ; SHORTER PATH TRAVERSE ON7 N% ~! S8 W0 c9 H
29 L B7.073 C357.498 R0 F MAX
1 Q9 y9 M& A' s& |& M, @  w30 L M128 F12000. ; TCPM ON
: r$ D" u- b6 W. _/ C+ k31 L X510.5225 Y55.6333 R0 F MAX M13
3 n4 W$ e% M; ^$ a+ q( m32 L Z212.0038 R0 F MAX$ T; W3 F4 o( C- w- H
33 CYCL DEF 32.0 TOLERANCE
# K* Q$ t( v. ~! h3 D% K34 CYCL DEF 32.1 T0.01
/ b* z! w6 _  D: F+ m35 CYCL DEF 32.2 HSC-MODE:0 TA0.5
% Q' a1 h! g: _. ?$ @5 A36 L X510.5225 Y55.6333 R0 F MAX: D& ^4 L4 Y! _
37 L Z212.0038 R0 F MAX
发表于 2012-7-10 15:54 | 显示全部楼层
你们花了多少钱
 楼主| 发表于 2012-7-13 12:56 | 显示全部楼层
jhw320 发表于 2012-7-10 15:54 ; G: y( T$ S3 A5 d- ~
你们花了多少钱
8 x" M, U8 a5 t( l/ r" |; o小钱  呵呵
发表于 2012-7-15 17:10 | 显示全部楼层
发出来共享一下,谢谢
发表于 2012-7-15 21:21 | 显示全部楼层
楼主  能否 传一下  后处理文件呢  我这也有台 80P
GMT+8, 2025-4-30 13:49 , Processed in 0.142246 second(s), 23 queries .
