查看: 2226|回复: 1
求助
发表于 2007-11-27 13:28 | 显示全部楼层 |阅读模式
STRING/FN(100),s1(100),s2(30),s3(30),s4(30),s5(30)
8 Y- L! y4 l7 [2 {( F2 btub=60" ^% r, S# F+ a" R
$$图层个数从60开始
. N7 y! A$ P' m7 M! Y, E$$165
' l& d7 J2 ^0 K2 T/ u* ^FN='F:\gz\tc\6j1\1\1\'
( f- W5 t. p7 ~. `DOPEN/FN0 a4 A- u. V+ ?% U# ^
l1:
" L% t7 O, f, H7 SCREATE/TXT,1,'HONG.VB',iferr,m:
& _' P  ^: R( A. M& J$ b. kjump/l2:
  n* d, q: V$ e% F8 Z- km:
* k! h( _( j( ~3 c5 `3 i- [fdel/'HONG.VB'
( Q& B7 C9 U, c7 L. v' wjump/l1:3 p+ ?3 G, D# _% ]
l2:1 ~9 Z, g9 G! N
: P" `' V$ R( F5 @num=15
; ~8 [4 l0 E7 ~0 \& yi=0 $$图层从I+1开始
# {' t, H% `1 V3 k' Tj=1
1 i9 h8 H2 y2 g. W3 rfd=37( H! L$ T2 s) ^: c$ A! D( P% ]. F
S1='Option Strict Off': D- i& r" F. q6 ~
write/1,s1; B, T  V! R) K/ O
S1='Imports System'& L/ e) i4 o8 k2 z* l+ g; ~
write/1,s1% L; `9 c& _( \, K
S1='Imports NXOpen'& R# c3 O6 i- A, N3 M6 G% O, \
write/1,s1# C; a5 H: V7 j4 k
S1='Module NXJournal', }6 i0 z' Y2 @7 p+ a- _- b
write/1,s1. ~  _/ M+ v- o7 A) z+ u
S1='Sub Main'
0 p; C% ~1 }: A$ mwrite/1,s1
( g6 p7 }, ~' M! y/ W3 I( aS1='Dim theSession As Session = Session.GetSession()'& W6 q$ o( V+ F+ l4 |- q3 N$ M
write/1,s1
# j) U) D- ~& M* K2 f% |; RS1='Dim workPart As Part = theSession.Parts.Work'
: a. T+ ^! ^. [2 X# r! J8 M& `write/1,s11 J/ U& B$ ], g+ Q" u% f% P
S1='Dim displayPart As Part = theSession.Parts.Display'3 b$ s4 d( m% l% q5 a$ m7 l
write/1,s18 V8 t6 z, O' p$ S, N' b- q
S1='Dim markId1 As Session.UndoMarkId'
0 Y  e: N6 I3 U/ ewrite/1,s1' V- C; @; _9 X- o4 _3 O8 A
S1='markId1 = theSession.SetUndoMark(Session.'
$ Y& t% Q& n+ I9 ?+ ZS1=S1+'MarkVisibility.Visible, "Enter Modeling")'% y2 A9 Z9 f; _8 i, D' w
write/1,s1
- S$ @6 ]( z9 U4 A/ J- Al3:% D4 A7 ~9 ?5 H, j
ifthen/i<tub( I% A2 i3 Z9 V) e: }8 q+ \6 R
i=i+1
/ ]. v1 y" E4 Z" gj=j+1% U! r. t+ O+ y- z6 l
i=INTF(i)1 h- Y6 T/ y1 i* a
s2=istrl(i)
& C: j3 O2 l9 W! t7 w- k3 `s3=istrl(j)7 ~' `' l5 S* X1 H, n
s5=istrl(num)
6 K4 S1 I- m: R" u  s$ X- h/ uifthen/fd<10
' E* M1 g: q5 d4 g8 K7 ~; s0 ks4='0'+istrl(fd)
' ~2 n; w: g* t, \# G( a: G; jelse; v. s( n4 [* @8 s  }6 e
s4=istrl(fd)1 V6 O3 G0 }! ?% j. k+ v( ?/ A
endif
* b8 \/ \5 p0 f  Y! \ifthen/i<>1
$ Q& M* i  I8 V% s  H6 U. W' g* ts1='Dim stateArray'+s2+'1(1) As Layer.StateInfo'" ^2 Y0 b" v7 F* R
write/1,s1
  g2 e' F! p. I# V+ d- Ss1='stateArray'+s2+'1(0).Layer = '+S28 x5 R8 Y2 j- Y! p
write/1,s1
/ X+ t4 u$ E- a' ns1='stateArray'+s2+'1(0).State = Layer.State.WorkLayer'
& y  U) r1 ^  Iwrite/1,s1
" q3 D( u2 }! d. o/ E/ _4 L9 ^s1='stateArray'+s2+'1(1).Layer =1', P2 e; b- u; U, I
write/1,s1' v4 V' H3 f. q- s2 H, S$ ^- ?
s1='stateArray'+s2+'1(1).State = Layer.State.Hidden'5 T; S- V$ n8 E( Q7 ]7 h
write/1,s1+ V# q9 v; s5 ?+ q8 G
s1='workPart.Layers.ChangeStates(stateArray'+s2+'1, False)'/ o% N; @* y! Z' O( V7 x9 W
write/1,s17 n' x% C, u) p6 w3 l
ENDIF
$ {' S+ U8 t" t* Y' @9 M% Hs1='Dim layers'+s2+'(0) As Integer'0 y6 t6 d6 l* `+ c. Q2 N+ ]
write/1,s1
  ]' o5 I* j. X3 M; rs1='layers'+s2+'(0) ='+s2
7 ?/ i  z, T$ v" E( B. n7 {write/1,s1  F6 T2 l; g; i
s1='Dim category'+s2+' As Layer.Category'
& G, w3 e+ l) k; T0 Nwrite/1,s1
2 D( i- X! I- As1='category'+s2+' = workPart.LayerCategories.CreateCategory("'+s5+s4+$7 q, B" C. a* I& \/ F- z
'","", layers'+s2+')'& z1 a8 ^6 G1 ?/ G  R" n1 X
write/1,s1
4 T, n8 t( K! L& m: h  }9 Efd=fd+1/ B9 H( u0 J/ c( i& {; t
ifthen/fd>=60# W) _" }$ W3 _/ o
num=num+1
% N1 O  T" `; }; ~+ U0 vfd=fd-60; w7 e/ i! k: O! |1 _, Y) _1 p4 {) Q
endif* {" ]3 L# ?( H# R& z) ^1 G
s1='Dim markId'+s3+' As Session.UndoMarkId'
9 y+ f8 O0 x" b9 G/ iwrite/1,s1
& y, g4 g% c+ c5 `s1='markId'+s3+ \2 p0 q& Y) o: V/ D
s1=s1+'= theSession.SetUndoMark(Session.MarkVisibility.Visible,'
. |4 g- u1 U  ]; M* K* l; v- ^- ^s1=s1+'"Raster Image")'
% d3 C+ u8 N% C9 V  \" K. lwrite/1,s1
. b, e4 f# H2 L) R3 Js1='Dim origin'+s2+' As Point3d = New Point3d(0.0, 0.0, 0.0)'7 |" u1 ^5 }' Z! I2 R+ V  ~
write/1,s1
; r; u; J4 \3 O" Q& bs1='Dim matrix'+s2+' As Matrix3x3', [4 f. n) Y# K* q( ^2 q
write/1,s1
9 j# D0 x' Z2 }$ Y/ Hs1='matrix'+s2+'.Xx = 1.0'' V! y6 f  v! u- W; Z2 F# O" ]
write/1,s1* V. x! P  x6 J$ \: R+ E
s1='matrix'+s2+'.Xy = 0.0'3 N6 i; y4 o, F8 O# S
write/1,s1
+ F! X4 _8 e  a7 J0 ]; {) S  ^  N+ as1='matrix'+s2+'.Xz = 0.0'3 y1 Y; O+ _! {! l/ W3 ~; R
write/1,s1; B6 Q" q* ^3 |" X1 v
s1='matrix'+s2+'.Yx = 0.0'6 ?; W1 K2 I" A( _
write/1,s1
$ O- Y4 _9 i4 @1 g# ks1='matrix'+s2+'.Yy = 1.0', q  L: s% I+ a. p0 G
write/1,s1
: K! W  _4 l% R, j' k' As1='matrix'+s2+'.Yz = 0.0'
  c* \# Z' y7 N& I4 b. p5 F7 ywrite/1,s10 P% x5 o/ e2 o* [$ s
s1='matrix'+s2+'.Zx = 0.0'* e. E4 {- Z, i" b& b& ~
write/1,s1
/ Y9 h6 {  I/ L1 as1='matrix'+s2+'.Zy = 0.0'
. E0 f$ s7 f  ^8 ~" r9 K; p; z$ U/ nwrite/1,s1
0 {. L. o# O) K2 l* V5 l5 bs1='matrix'+s2+'.Zz = 1.0'
; S& b1 S6 d8 E9 u0 J) A, twrite/1,s1
7 {3 o" e" S9 c# q0 B) ls1='Dim rasterImage'+s2+' As Features.RasterImage'  `- d+ N" B' @& f! n7 B  l. \
write/1,s1
# V1 Y9 X% P1 |2 Ys1='rasterImage'+s2+' = workPart.Features.CreateRasterImage(origin'+S2+', _'
& H9 k- `% M, C8 Rwrite/1,s1
8 k& y) C+ y1 u' Qs1='matrix'+s2+', 280.0, 210.0, "F:\gz\tc\6j1\1\'+s5+s4+'.TIF", _'
8 F7 `  e4 c  c6 N/ ]; W- @7 lwrite/1,s1' p6 M" b6 m# _3 h0 |
s1=' 0.0, Features.RasterImage.MaxTextureSize.N512)'5 L! k1 D6 V/ t- ^1 ^6 c
write/1,s1
. |' z) W" a# L6 {2 q7 ^ifthen/i<>1; ^- g1 k1 h7 M2 O' _- U. M/ i
s1='Dim stateArray'+s2+'2(1) As Layer.StateInfo'1 Q1 q* J" `# t+ ~
write/1,s1! c4 ?2 L( v- O
s1='stateArray'+s2+'2(0).Layer =1 '
* x4 _% o  X6 W& ~8 U, ~9 ?" B% Gwrite/1,s19 l* ~0 F7 c/ Z" k. u0 ^
s1='stateArray'+s2+'2(0).State = Layer.State.WorkLayer'% H0 X6 l  V; k
write/1,s1. L" y5 b0 ]/ g7 _, r
s1='stateArray'+s2+'2(1).Layer ='+S2
0 K' j+ q6 r2 \- W: ^+ Swrite/1,s19 ^% a: j( i& |  L1 w
s1='stateArray'+s2+'2(1).State = Layer.State.Hidden'
7 j& o- C3 [+ C: F$ b2 ]write/1,s1
1 d) `9 R( q, x! ^7 N6 U- ls1='workPart.Layers.ChangeStates(stateArray'+s2+'2, False)'
+ L9 O9 N, J& g! ?3 C& Zwrite/1,s16 P4 I- d0 d. w8 f+ m  n
ENDIF( w/ ~* \# N( Y0 @! Z2 `% M
jump/l3:. O+ ]# L! D; V. V4 [
endif
$ A: _. B# t, g- B6 S0 g4 F6 e- Qs1='End Sub'
$ |$ M1 }3 L8 k4 b& U4 e* p( Uwrite/1,s1
, q! v% O) e+ p. @% js1='End Module'$ N5 ~, A* s) I1 z
write/1,s1
- I3 C& [" F7 ^4 Gfile/txt,1,fn+'HONG.VB',iferr,n:) G( Y1 v$ C' h8 N5 }' Y# c
n:
6 m+ G) z0 j; c" J5 k  rHALT
 楼主| 发表于 2007-11-27 13:42 | 显示全部楼层
这是我的二次开发程序,其中以下程序& f% t- M$ g  h" G0 e: y
. j; L2 T  ?: n8 q! e0 pwrite/1,s10 @) G  E9 ]# s8 M; ]- H, w  @  @. ]
s1='matrix'+s2+', 280.0, 210.0, "F:\gz\tc\6j1\1\'+s5+s4+'.TIF", _'6 p$ J4 O/ ]4 h' D# u  M( K& I3 i
write/1,s1/ Q  o( F. t0 [. @/ `- i
- v; q0 O# A7 \3 |$ Zwrite/1,s1# M: h1 M! R! ?6 e: S$ v: Q$ k* f
有没有办法将他们写成一行
$ r5 b7 z6 s# e, B8 y" F这是VB命令,我的思路是,用GRIP命令自动生成VB命令,再运行日记,. V2 [- d  J( H6 ~8 W% J
但这条VB命令字符太多,GRIP字符串只能处理132个字符,不得已将他分成几行7 h' P- ]9 p9 c6 m% M- r- [" ~
但WRITE命令怎么才能续写...我上面采用VB续行副,但如果以后遇到类试问题怎么办
; ^* H0 l( r& v' a$ [4 g4 y注意:GRIP字符串只能处理132个字符,但编译时不一定能找出错误,只有在UG里运行才出错
GMT+8, 2025-6-27 17:17 , Processed in 0.118369 second(s), 25 queries .
