/ P0 W* k9 o0 V* L8 [/ M8 d9 b% X7 b- g( S' q+ _: a
高级教程(热和液压).pdf
(3.2 MB, 下载次数: 166)
" V# N/ B- C8 j: A+ p* Z. ]
( x( r8 X3 U6 [6 z6 {, R* ^
高级教程.pdf
(3.89 MB, 下载次数: 170)
: p2 ~) a# H7 v
- W5 c) h8 S6 W
基础教程.pdf
(3.81 MB, 下载次数: 243)
4 M% p4 x2 b: x( m
9 Q- k. b+ _+ t3 [" ?2 r t1 _' q q9 e2 R& _) Y+ O1 R h
9 B$ T( I: z% h) S* y! o
' T) t9 J l' c) t% [7 i, q$ ?/ u3 e+ ~
0 F0 [. M7 W2 T& m5 r! k! j6 f
, @7 y8 e0 a" I) [* ]" m7 @* iE5*Z*Z*ALL*Z*SM*EAS101-NT1 MSC.EASY5™ CLASS Outline MSC.EASY5 Overview Getting Started -simple tutorial Tutorial 1 -Model Building Tutorial 2 -Linear Analyses Tutorial 3-Analysis Tools & Methodology Tutorial 4-Simulation and Integration Tutorial 5 -Data Tables and the Matrix Editor Tutorial 6 -Operating Point and Steady State Analysis MSC.EASY5 Architecture Tutorial 7 -Writing Code in MSC.EASY5 Summary • Optional Topics – User-Defined Code – Matrix Algebra Tool – Advanced Topics MSC.EASY5™ What is MSC.EASY5? • Engineering Software Tool –Used to model, simulate, analyze, and design dynamic systems. – Complete graphical-user-interface (GUI). • Model Building Tool – Models are built using pre-defined components in: hydraulic, mechanical, multiphase fluid, pneumatic, and thermal libraries, as well as simple blocks, such as summers, integrators, and filters, used to model control systems. – User-defined code also added to model. • Analysis Tool – Includes non-linear simulation, steady-state, linear analysis, control system design, data analysis, and plotting. Source code is automatically generated to support real-time requirements (ADI, Harris, etc.). • Interface Tool – Open architecture provides easy access to a broad set of software (MSC.ADAMS, ProMechanica, and others) used in computer-aided control system engineering. Customer Support – Comprehensive technical support. MSC.EASY5™ Block Diagram Modeling Approach MSC.EASY5™ Submodels Help Visualize Complex Schematics v1 V1 n# A0 G
, r- E, Z5 J5 c7 w# O# E9 q6 ^
( E4 f d$ l1 E/ t! `# t+ p |
9 S6 L1 a8 S( b9 i% }+ \$ f- q5 f
, f8 b1 a; k! n9 x% L% {
' i* {" u, Y& J+ F
“Submodels” expand to lower-level models MSC.EASY5™ Nonlinear Simulations and Linear Analyses Use Same Model Find an operating point •Simulation – “Normal” – Monitor – Interactive – Person/Hardware-in-the-loop • Linear(ized) Analysis – Linear Model – Transfer Function/ Frequency Response – Root Locus – Eigenvalue Sensitivity – Power Spectral Density MSC.EASY5™ Nominal Simulation -Transient Response Simulate transient response of dynamic system Simulation data can be view as simulation executes (using Monitor Simulation feature) Plot & Print data after simulation has completed
2 Q- q2 g7 E: m/ A5 D2 v9 Y& x/ e/ A+ N( H, G; W& V
: R5 h5 w7 q _/ _9 w1 ]! ?" T3 G9 K) n% y- G! e+ a$ g" ^
。。。。 * r' d! x0 V# R6 |2 H
2 o7 j: L9 ?! i$ D* Q |
