查看: 7537|回复: 6
益智拼图,聪明的你进来吧
发表于 2005-12-14 23:59 | 显示全部楼层 |阅读模式
<><a href="http://www.jigcool.com/jigonline/jigplay_sc.php?dir_no=1214051459114072010105070" target="_blank" >http://www.jigcool.com/jigonline/jigplay_sc.php?dir_no=1214051459114072010105070</A> </P>
' @  m9 n  X! T<><a href="http://www.jigcool.com/jigonline/jigplay_sc.php?dir_no=1214051652114072199606090" target="_blank" >http://www.jigcool.com/jigonline/jigplay_sc.php?dir_no=1214051652114072199606090</A> </P>
% I. h; @' J$ L  i( n' J<><a href="http://www.jigcool.com/jigonline/jigplay_sc.php?dir_no=1214051938114072253108101" target="_blank" >http://www.jigcool.com/jigonline/jigplay_sc.php?dir_no=1214051938114072253108101</A> 聪明的你别忘记告诉我拼完一张图用了多少时间哦.....如果你不能马上进入拼图,请耐心稍候一下,可能网速有些慢。</P>[em01]& D$ P) `( I* v2 Q& m) V0 f8 d! c
[此贴子已经被作者于2005-12-15 8:10:37编辑过]
6 B7 Z, i/ p8 S2 H5 x7 |
 楼主| 发表于 2005-12-15 16:11 | 显示全部楼层
<>第一张用了6分钟</P><>第二张用了8分钟</P><>第三张用了10分钟</P><>耶!!!</P>[em01]
发表于 2005-12-15 16:56 | 显示全部楼层
哇,靓女就是聪明,我怎么都......................................
发表于 2005-12-15 20:38 | 显示全部楼层
<>我只拼了第二张 </P>! {5 ^1 X6 d. i, k9 W
<>用时大概六分钟吧   </P>[em04][em04]
 楼主| 发表于 2005-12-15 21:56 | 显示全部楼层
<>比我强了一丁点嘛!我用了8分钟因为!</P>[em04]
 楼主| 发表于 2005-12-15 22:00 | 显示全部楼层
thank you!站长。2 b  _" ~  U. Y5 c. k
[此贴子已经被作者于2005-12-15 14:01:09编辑过]
2 r8 }7 e: ]% G
发表于 2008-7-8 18:57 | 显示全部楼层
GMT+8, 2025-1-11 02:56 , Processed in 0.050921 second(s), 24 queries .
