楼主: liang.xingqing
UG后处理2.0 3.0 4.0 5.0都可以(三菱,法兰科)
发表于 2008-9-30 21:12 | 显示全部楼层
谢谢了
发表于 2008-10-2 15:12 | 显示全部楼层
谢了。。。。。。。。。
发表于 2008-10-8 15:21 | 显示全部楼层
非常感谢
发表于 2008-10-11 20:22 | 显示全部楼层
dingyixia
发表于 2008-10-13 13:54 | 显示全部楼层
5.0有问题!
下面有好几个百分号。机床走不了。大哥大姐帮帮看看0 u1 D; P6 T. W( Q- h
%% Z( o# K& e, t
O0100
) m# x# P# M1 o/ D1 XG40 G17 G49 G80# X! U7 O" f9 D6 f1 w4 u1 M
G91 G28 Z0.0
5 j- o9 R! e7 {; U9 ](Tool_Name25R5 Tool_No:0  Cavity Milling )
& r7 g, Q$ Q% X+ e, L- ]G00 G90 G54 X12.984 Y-180.039 S3000 M03
% A2 a) c2 l: C' f. DG43 Z341.501 H00
  o0 A. k& D' z9 D1 T2 S( k# \Z333.507
3 s( s$ i2 E! Q9 U* e& c, \G01 Z330.507 F255.& B5 p' q7 `3 J% x) e$ [
X12.886 Y-178.679
4 l9 [( ~" Y+ e- z( h. tX6.594 Y-167.878
/ U4 N6 v* \: P8 M$ U' dG02 X-.006 Y-154.41 I90.343 J52.625 F3000.* C1 n$ e. d1 |: a
G01 X-.004 Y-144.732- M5 ^4 v( P2 z
X-.006 Y-154.41. K. @/ [7 _% c
G02 X-6.609 Y-167.877 I-97.101 J39.253. c. T+ b5 ^# L: V! @+ G5 U: I
X-20.085 Y-166.802 I6.609 J167.8773 c! A. \1 Y( s: n
.............(省略). J6 f4 p5 D/ H( q0 H1 t
X-89.824 Y-97.579 I2.896 J-9.71
0 M; z& ]  @; E3 hX-88.705 Y-97.641 I0.0 J-10.138& I& P- l  S; F  M6 m
G00 X-76.281 Y-99.021' z  K! A  ^0 _9 Q- ]8 f( s* L
X-71.786 Y-93.186
. b; `; T- D6 o0 s- c. T& vZ333.507
1 G; N! j. i! Q& D, O  _Z341.501
' a1 y5 f& [7 k# sX-116.349 Y138.007, s' h! _$ _7 K
Z333.507* N, R& n: N* u2 h7 C
G01 Z330.507 F255.% e- J" n7 l: S( R( ^, t# e; \- R2 D
X-115.468 Y136.962
5 v  Y' q1 ]5 I7 s# x' A& SX-104.026 Y131.928. e3 K% j) r5 i. a+ u$ z- E
G02 X-90.808 Y124.949 I-42.231 J-95.992 F3000.2 a5 ~5 [6 c7 Y& m2 D7 L- h* `
G01 X-85.3 Y117.1933 O# b1 |, h  p3 O9 ^6 f
X-90.808 Y124.949
1 w2 c% w$ a& e8 h3 C( X2 [$ ZG02 X-91.272 Y127.263 %(这里有百分号走不了,下面还有。)+ G1 q  {9 R* b! d
O01002 w3 M8 A1 s+ `4 K
G40 G17 G49 G80
+ ?: i0 r  T' q$ O) }* e+ z% sG91 G28 Z0.0
  S) x( j  H) Y1 X3 M, g! _" }(Tool_Name25R5 Tool_No:0  Cavity Milling )
$ Q* f! E# W1 E8 B2 n; DG00 G90 G54 X12.984 Y-180.039 S3000 M03/ a5 V( d1 @9 m% S. t0 a/ }
G43 Z341.501 H00
* m) y0 X( E6 fZ333.5076 r$ r! {" \5 c
G01 Z330.507 F255.
* q) f) Q6 a, X! v& W! FX12.886 Y-178.679
1 Z0 W) c& z) S: V0 z3 ]. @X6.594 Y-167.878
1 y5 ?8 G; `* y' N4 b& Y" U7 CG02 X-.006 Y-154.41 I90.343 J52.625 F3000.
; M$ A# @/ ~/ M, J9 ?, q( FG01 X-.004 Y-144.732' ?' W+ p0 G8 N7 c; k4 |
X-.006 Y-154.41
0 e, x" x8 t8 z: y, |' ^G02 X-6.609 Y-167.877 I-97.101 J39.253
/ D/ a+ _1 M. X.............(省略)
! ]1 ^/ E. P1 w% V8 f; d$ uX-204.148 Y61.86
1 p+ D* \5 c4 j; kZ280.802  G/ p" ?5 Q3 i: h" f
Z341.501+ [+ k5 ~/ E, ~' N! r! M
X-201.688 Y69.463
: ^& g8 N& S1 O; y( P( JZ280.802
. p$ v1 ]( l# a8 i% D: Q+ zG01 Z277.802 F255.4 |% i6 N3 I6 q5 s% n
X-190.95 Y65.765
: s0 }; L; z& O' F' D$ c. e! nX-185.266 Y76.898: H- x0 ]1 D4 ^& L" c; d1 y
G02 X-185.121 Y77.18 I179.291 J-91.552 F3000.5 ~: }$ ?8 J! }( P) N0 r7 E6 k
X-16.214 Y199.909 I185.121 J-77.18) Q2 x$ B/ u& O; X9 c/ d1 U+ ~4 a; G
X-16.102 Y199.933 I5.502 J-25.684
1 e+ W/ {4 H. A) m: M) e; ]& I6 XG00 X-3.868 Y202.4984 n% \$ T9 \+ W
X-4.074 Y213.275
' {" O5 i: F  ]# i0 tZ280.802
6 }2 e/ y1 c! u* xZ341.501
+ k% l5 j' l1 q4 U5 B" T9 QM05: c5 f; F1 p) [& \# O
M09. A4 }- S) }( j2 p
G91 G28 Z0.0
2 H! e! B( {* l: T$ p! XM30: {- E3 P4 _7 m: J
%(同样问题)
* ~# e: G+ i( U(MAXZ = 341.501 , MINZ = 341.501)1 W' D$ b1 a* C' |+ ?# Y# C
(Total Machine Time:91.32)
3 A0 W1 K7 u; d. e# V0 d0 R7 r(www.ysug.com)' Q8 D0 A" N  M5 e6 V7 P8 I$ |
9' z# K$ |1 q8 h% n* \& W
G00 X-193.103 Y58.513# N- F4 u5 l3 v
X-204.148 Y61.868 w7 v: ]$ d9 @; F' L7 U! T
Z280.802
( Q$ {, S1 ?7 t5 yZ341.501
1 s3 K$ H! u" L  E* p# l$ a  u0 H2 fX-201.688 Y69.463" a9 ~: o& |3 U* H1 q0 r
Z280.802( D* G3 v8 F; g4 y+ K5 g, T; ~
G01 Z277.802 F255.4 i, Q8 D8 }/ w6 k" B; q
X-190.95 Y65.765& d6 s! u, J5 B2 F8 G+ n
X-185.266 Y76.898
0 {" v9 m( T8 R7 Y! oG02 X-185.121 Y77.18 I179.291 J-91.552 F3000.: j+ z  O# u( f* t8 K; h1 C1 v
2 C7 X, P" s, W/ Y& `. @, N& ]X-16.102 Y199.933 I5.502 J-25.684( C/ M7 b* d" c+ D4 a& o1 X
$ G' g6 P2 Q  K% ]" I8 eX-4.074 Y213.275
) x+ I5 {3 T5 o8 X4 e, c4 d6 iZ280.8024 r: ~% Z# n0 o$ i4 e/ d
Z341.501
( U+ x" x4 m) z7 J" G: xM058 y0 v: A+ @6 u2 m' r" j
M092 Q3 M" V1 R: y9 `- i" W1 r
G91 G28 Z0.04 Q$ T  N6 E& X2 ^) G' y4 ]
M30
) o. Z- X6 ^& a& E%. _& X! U+ }" e/ m0 d( s4 \; Z) f1 I) d
' s* Y. B" z  h- I(Total Machine Time:91.32)5 `# |; e, h3 t  r1 W+ ~
(www.ysug.com)
发表于 2008-10-13 15:04 | 显示全部楼层
回复 135楼 kAINI 的帖子
你是多条程式一起处理的吧?试试只处理一个,我没有看他这个后处理,具体也不清楚
发表于 2008-10-13 15:53 | 显示全部楼层
是单条处理的!以前也是这种情况。我现在都闲置中,就因为后处理不行。号郁闷啊!大侠你有后处理吗可以发给我吗?求跪了。4 O/ r) D. Q* W- R; _/ a2 j' G
邮箱iloveqzy@163.com
发表于 2008-10-24 09:05 | 显示全部楼层
不带刀库吗
有没有上过机床?
发表于 2008-10-24 16:33 | 显示全部楼层
看见了,下先,在此谢过
发表于 2008-10-26 21:19 | 显示全部楼层
万分感谢!!!!!!!!
GMT+8, 2025-3-11 06:39 , Processed in 0.061079 second(s), 19 queries .
