可以在后置中设置% }9 Q2 i* E8 f$ [% e" d0 r6 ]1 K% Z
% w7 R0 J2 e7 [# The following variable deines the output mode for helical records." ]( s, O( X" Z7 W2 q) B
9 E; }. v& S: X9 n3 X: s# FULL_CIRCLE -- This mode will output a helix record for each 360 5 u7 I d/ H. s& H6 N& r2 h
# degrees of the helix.! B S! D4 D9 K0 i+ |& |* b
# QUADRANT -- This mode will output a helix record for each 90 . G( [% @8 i# N# P1 V) q
5 X3 o' Q5 l1 d5 J1 A( k8 R2 E# LINEAR -- This mode will output the entire helix as linear gotos.; M* n; B0 [9 `+ ?- O8 y# h b# }
# END_POINT -- This mode will assume the control can define an entire5 u# h* A& \2 ?* z; h
# helix in a single block.. U9 c; b# u: W5 u0 R2 O
% f; s) l% d4 B& r# M5 ~; m set mom_kin_helical_arc_output_mode FULL_CIRCLE
! X; |' t: J: z- A) R' h/ i
. p; }; |( A" w8 @( C+ O MOM_reload_kinematics8 Y4 V; P) a' S" G9 ]
$ G' X3 K2 E& T( ^+ R改为LINEAR 就为直线输出了 |
