查看: 1308|回复: 8
[讨论] 为什么我后处理出来会有 {F50000} 指令的
发表于 2012-9-21 21:33 | 显示全部楼层 |阅读模式
为什么我后处理出来会有  {F50000}  指令的. 请各位大侠来指点,感谢!..........
8 m. x# C/ k  V5 w/ d
8 W7 b  R7 ]6 J+ p0 A1 bG91 G28 Z0.0
: O# b& _* t; ~# B$ s# }) B(TEL: xxxxxxxxxx. This is for ug NX7.0)
# I) u! t; G6 x9 m: k/ |; i(Program_Time: Fri Sep 14 23:20:50 2012)
+ a- _8 I! m0 E/ k' D9 u(END OF TASK: E:\My Work\bbbbbbbb.prt ): `, W6 i! h  ^1 G5 w# h' R$ N
(PROGRAM_name:bbbbbbbb)3 j  W! I) T4 L
(ToolName=D10 mm R=0.00)& r; b4 t, Z" A
(side Stock:XY=0.00mm )
! L' R9 Y7 L* ^9 W/ @' K(floor Stock:Z=0.00mm)9 y* k3 Z* |6 D5 Q8 B
T01 M060 J- ?+ @0 }7 w1 \  S
G90 G00 G54 X0 Y0
3 z8 ^% P* {3 ]* G' L4 zG00 G90 X-153.536 Y3. M03 S2000
) J7 W0 p2 P  `- IG43 H01 Z50.
8 Z# m7 v: b' r! A% C) ]" I. TZ-1.9 C+ p/ Q9 Q$ l" h8 L
G42 D03 G01 X-153.536 Y3.& H7 v$ }, Z& W, h- V- h; T
G17 Z-6. F1000.# N0 [: L$ B6 o! ~+ ]
X-156.565
) y6 z8 \/ @6 L6 CG03 X-159.565 Y0.0 I0.0 J-3.! \; v0 X2 q% }; h1 A* I9 L& m' u4 ?
I159.565 J0.0
: N: ?$ N3 Z" t+ d5 G0 GY-.1 I159.565 J0.0* R" P1 [  v1 i# e- ^# z2 d" W: \5 K0 }
G40 G01 F50000.
) |9 \$ E" x7 ~) M* G9 h9 K
G03 X-156.563 Y-3.098 I3. J.002 F3000.' M5 e3 u/ B3 S8 ~% Z: [! K/ l5 w
G01 X-156.645 Y3. F1000.
% r$ K  ]' M4 yG42 D03 G01 X-156.645 Y3.
9 |$ t0 D4 f' }  n6 _G03 X-159.645 Y0.0 I0.0 J-3.( V2 Q; b5 q2 F0 E
I159.645 J0.0
7 I* e6 P  R) ]* U% SY-.1 I159.645 J0.0
! u$ e( l8 \0 r  [" H" o9 b) z* H. OG40 G01 F50000.. t1 D! A' R) y: s
G03 X-156.643 Y-3.098 I3. J.002 F3000.
3 H1 h! e9 D: K" ^  xG01 X-156.685 Y3. F1000.
! l( ]; X' A  m* @G42 D03 G01 X-156.685 Y3.
, i( ^: b; U* `4 A; |" I6 c. _, ]/ y* rG03 X-159.685 Y0.0 I0.0 J-3.
' I# _0 R* \4 m; S9 OI159.685 J0.0! B- {1 S4 @  R; z2 m4 r
G01 Y-.18 M. b% J- E& F3 }) ^! u
G40 F50000.
- O0 w; L* o& B6 n2 A
G03 X-156.683 Y-3.098 I3. J.002 F3000.7 j8 V' N& e; ^, }6 H7 U1 j
G01 X-153.614 Y-3.096
* Z- |; |; U9 \% G. Z8 Q) @, rZ-1.: _2 |# d& J9 h' V- X
G00 Z50.1 j2 e5 K( N0 r
X-153.536 Y3.0 R9 M( E. m" q+ h0 D) ?; m% E: p, P  }
Z-5.8 R- q& D& `9 h( `% O
G42 D03 G01 X-153.536 Y3./ F" L9 h" \5 ?+ }
Z-10. F1000.( I8 X5 g8 K6 P. ?/ h* w
X-156.5650 c* g. [4 e; Z/ q
G03 X-159.565 Y0.0 I0.0 J-3., D( ?2 l6 O) k, z0 k4 j0 u
I159.565 J0.0
. `9 K4 Y8 x- B, ]Y-.1 I159.565 J0.04 L' ^. Q9 J+ J  u) J* O
G40 G01 F50000.* i  k! ]+ j& ?  y) ?, {4 Z
G03 X-156.563 Y-3.098 I3. J.002 F3000.) c! M- ]7 z; P* H( j4 G, {  m
G01 X-156.645 Y3. F1000.: S, J9 h5 [, w5 q0 P
G42 D03 G01 X-156.645 Y3.4 K' W2 t; C. }3 C
3 h- B5 x7 X/ R8 e4 e! S, P0 lI159.645 J0.0
; ?* s( P4 v- F3 XY-.1 I159.645 J0.0* L  ]+ M7 B- v: R
G40 G01 F50000.+ q! C7 R9 L, }- W* x$ F/ q
' U  O$ u" \% `G01 X-156.685 Y3. F1000.1 R5 S/ c( o% v4 B0 n
5 g' [# i6 j% Q* A/ LG03 X-159.685 Y0.0 I0.0 J-3.
9 h6 n' }& J8 GI159.685 J0.0' N, l7 w9 l$ Z1 k( _1 E7 x
G01 Y-.12 ]8 Y. @* {) X; O1 G! t
G40 F50000.0 h7 [+ F( ~4 U7 Y( _: h
G03 X-156.683 Y-3.098 I3. J.002 F3000.5 v# b/ U! V5 A& U6 n% z" u
G01 X-153.614 Y-3.096! d( |* R. H/ [3 m0 T7 `  a
Z-5.
$ p+ _7 d" x0 A3 e$ {1 `. \G00 Z50.7 m  D: }+ R  R1 V  |; w" i/ ]
M05) J6 x' [9 ^# R& J/ q0 e2 t
M09
7 y8 D+ A5 L" f# xG91 G28 Z0.07 R6 t% y4 a) l
G28 Y0
% F5 o1 {3 h0 C- tM30) {/ Q8 t1 W/ |: e* e
%$ @! u3 H3 z! j/ A
时间:6.61
发表于 2012-9-22 06:38 | 显示全部楼层
自己给的吧
发表于 2012-9-22 17:24 | 显示全部楼层
你把后处理 与你测试的文件传上来   别人才可以帮你看看
评分
参与人数 1激情 +10 G币 +10 收起 理由
cxmshh + 10 + 10 赞一个!
查看全部评分
 楼主| 发表于 2012-9-22 23:40 | 显示全部楼层
zhangyafei689 发表于 2012-9-22 17:24 / r4 S* n& N: M0 A# p* ?
2 B* \0 W% q! V
为什么我后处理出来会有 {F50000} 指令?
后处理.zip
23.21 KB, 下载次数: 7, 下载积分: G币 -1
发表于 2012-9-24 08:33 | 显示全部楼层
QQ截图20120924082946.png 7 r& J2 K. z1 w6 k
6 L+ x& d5 h/ Q; j
打开文件报错
 楼主| 发表于 2012-9-24 21:18 | 显示全部楼层
zhangyafei689 发表于 2012-9-24 08:33
6 m$ b. S/ Z6 [4 E6 i打开文件报错
, F3 L* Y* W  L/ _5 ~. j3 d' z5 V
是用UG4.0做的, 用4.0可打得开.
 楼主| 发表于 2012-9-24 21:48 | 显示全部楼层
zhangyafei689 发表于 2012-9-24 08:33 5 R" N- z! p5 f& o4 z
打开文件报错
2 d1 h& s3 C4 r$ |/ F3 A" s我把原文件发过去给你;顺便帮我看一下,为何打开切消液或开气会报警,感谢了.......
% ]$ I* j- h8 V0 Q: Y. |
后处理.rar
22.06 KB, 下载次数: 4, 下载积分: G币 -1
发表于 2012-9-25 08:39 | 显示全部楼层
你这个后处理 只能输出M08 不能输出 M07要想做到可以写一个判断语句
 楼主| 发表于 2012-9-25 21:53 | 显示全部楼层
zhangyafei689 发表于 2012-9-25 08:39 . H- ]9 j. ?/ ?  N. x6 |% Z
+ J) o) c+ U0 n, z大师真是大师,神,,,,,。那出补正的程式,为何会有(F50000)这指令出现?
GMT+8, 2025-4-30 06:12 , Processed in 0.381008 second(s), 28 queries .
