网上找到的,供大家参考, B. ~ z! T5 S& l
solid_user 2007-12-22 20:13 / U! g( z. U4 Q
To all who have a problems with this crack!- J1 M& ~! M# R+ y' t
/ j' @, q+ a2 @" J; C8 k4 h- MThis crack needs a file "ftilicense.cfg" to be present in <BlankWowks program directory>
9 B: L. ^5 M+ S6 M8 h$ q: Q
4 z P% } X6 u' {so
" D9 I3 V8 V4 G: z/ L' m
# W5 x" ?# K8 R' u/ wFist way to Install
! f v$ @) j5 ~$ h1 W$ x8 t; f- A( R% s' j. V, [ j* M$ j
1) Run BlankWorks v3.0 Setup and select "Node locked license"6 Q+ L2 _3 ?9 j
2) Click "OK" and "Next" in any Setup windows (when aked for lisense file path jast click "OK" too!).
+ K( H' B: s( Q9 u4 {" V. w& ~3) Replace original files in <BlankWowks program directory> with cracked ones
* J: Y2 c" z0 O+ Y" R" J& SThat is all) |/ |! U3 I- K" H
: W8 ]* a+ w9 W
Second way (If you setup not Node Locked License and you have no "ftilicense.cfg" in <BlankWowks program directory>)! G: N( l3 a$ {
1 z k X1 i- g) ^1) Create an empty text-file "ftilicense.txt"
9 T8 V7 k$ @9 S- a4 f9 Q2) Rename it to "ftilicense.cfg" and put it into <BlankWowks program directory>
- ^7 [8 i! s7 C3) Replace original files in <BlankWowks program directory> with cracked ones既然选择了,就一定要做到更好!![](http://www.3dportal.cn/discuz/images/logo.gif) |
