楼主: tqt2000
[分享] CSWP考证题二
发表于 2008-2-19 14:21 | 显示全部楼层
晕...居然还下载不了
搞什么..要怎么样才能下载?
我也下不了啊.....老大先降低下权限把...
The Frame
& i" m. i4 k* A- Y- W" j  ^Create a new part.创建一个新零件 , u  l/ j; F2 o1 x4 b# @
Using the drawing provided on illustration EX1-B, build the Frame. 使用所提供的工程图建模
4 O3 Z8 B- R3 e1 TExhibit your ability to create extruded, swept or lofted features.
! O! |2 M$ d" r  p2 k0 R使用拉伸、扫描或放样 ! }6 p' }0 p0 m+ n. J0 ?; n! I
Use mirroring to create symmetry使用镜像创建对称物体 - {+ C4 T# K& b0 c( Q& h' Q
Save the part in your folder as: “Frame”保存文件为Frame6 V7 q- F8 I: s6 \! z
# q1 }. S) a! k: Q' q4 S& uDesign Intent设计意图:
5 w8 x7 U3 J# G' U/ |  l1 ?( N·
3 q8 C" y6 E* o. B+ d8 xThe part is symmetric from left to right零件从左到右对称
1 U( c( ~& p5 v4 H9 Q·
9 I, y, R! {+ @7 X3 y1 IThe part origin is located concentric with the lower bosses零件原点与最下端圆孔同心
' q) K" Z$ v$ j  r( K4 I·0 |. v& H9 R3 j- Q
The interior machined surfaces labeled A and B are coplanar内机械加工表面标记为AB的面为同一个平面
: P( T1 O. Y& M4 P+ n·
; S" H3 ^# S, s8 s3 h; N. aThe vertical member is elliptical and always tangent to both the upper and the lower bosses. 垂直部分是椭圆形的,并且总是和上下两个圆柱孔外表面相切
- ?, {9 Y7 k; E/ O4 F$ @CAUTION:
# H0 m$ S# m& Y- t3 M- FTangency between cylinders occurs at the center plane of the cylinders only if the cylinders are of equal diameter.仅当两个圆柱孔直径相等时,相切发生在圆柱中心平面
9 i+ p9 L5 M' a* F7 ~4 N- m4 T1 ~·
5 k, U4 i( [7 H5 \6 yThe top and bottom radii of the I-shaped cross member are always tangent to the outside edge of the vertical member. I形的顶部和底部总是和垂直部分的外边线相切% ^/ K, ]+ O4 ^3 D  u- g7 K
, [, D: }! u0 |3 u5 t% \8 xThe Upper Boss must work for the value range:
" A6 R8 g# e! }! O.95 to 1.875 in.顶部圆柱外径可以从0.95到1.875英寸) f! c, E" e$ P. x8 l
% @+ U  u5 y' i, m3 e1 @The Lower Boss must work for the value range: 1.25 to 2.25 in.底部圆柱外径可以从1.25到2.25英寸
, }4 `8 g, q+ b. a# AScoring Criteria:
8 j  w  X3 E: dThe Frame评分规则& k1 C, F  j/ B
Total Value:2 S1 `  Q% q! I" S- o+ U# G% c
80 Points总分:80分
4 P! S% t6 w  R. a  _  I·
3 m) B8 H# O1 P8 j6 J/ c/ RWere the bosses created as extruded features?
( {4 T/ E/ J7 b1 _7 v! f8 G圆柱孔是否是拉伸特征?(5分)
6 U' z" B/ U- S* c. N* ]/ Y! l4 X·
( x4 t  v: S+ k, j5 k9 E- h! s/ r4 FChange the center-to-center height from 5.5 to 7.5.4 ?; {* ^, W1 e: h- T$ ]9 o4 V9 M
Does the part rebuild correctly?将两个圆柱孔中心距离从5.5改到7.5是否有重建错误?(10分)  r4 C3 S8 C7 S: `! i' Z0 k& \
( |3 }( Y, N: z& T7 t/ T, B' sWas the Vertical Member created using a loft or a sweep?垂直部分是否用放样或扫描完成?(10分)8 {! K! s' j7 t5 Y$ N
·- O. o& W- `% r
Change the lower boss diameter to 2.25 and the upper boss diameter to .95.将底部圆柱孔直径改为2.25和顶部圆柱孔直径改为0.958 U, g+ J' g& d6 B
o
1 I+ E- {  |: sDoes the part rebuild without errors and has Design Intent been maintained?零件重建是否有错误并同时保持设计要求?(10分)
# u4 q: R  c2 g* o* |3 F$ go7 b4 L+ G4 x0 w1 \+ L
Does the Cross Member remain tangent to the Vertical Member?水平交叉部分是否和垂直部分保持相切?(10分)
9 l# S( ?, s- s; G0 w7 po) [. n+ B: b" W4 k: l. P
Is the Vertical Member tangent to the Upper and Lower Bosses?
4 [5 }" j' p$ p0 ]/ F  [4 R顶部和底部圆柱孔是否和垂直部分保持相切?(10分)3 H9 ?8 ?- S" Y9 K  e
·. U! g, t- o( \$ w! K( _% \
Inspect the Upper Hole diameters to verify that they are represented accurately.检查上圆柱孔直径是否精确表达?(5分)/ R6 k+ M0 ]! a, {8 \
·' l& B9 I/ Q* C0 [) r
Inspect the Lower Hole diameters to verify that both are .625 in diameter.检查下圆柱孔直径都是0.625英寸的情况(5分)
2 x; U" r  g/ \" C& H·
* W6 I6 ?* s; M" K% ~5 _Is the keyway in only one of the Upper Holes?" _1 F8 ?4 q1 w8 [) Y8 L
是否顶部圆柱孔只有一个键槽?(5分)
: p* ?! j* l$ T: \7 d4 s·% p& ~* O- a: M& H) A" n* l6 l) t
Was the keyway created using a min arc condition dimension of .0.63?
; y  n' @. p) G. c2 j) e% l- H·
2 }' D0 C: \" H; R* A  O1 [键槽的生成是用了0.63最小圆狐的尺寸条件。
' G( }) o) T. M( e+ a0 {2 Z·  S6 b, s5 R2 Q, r1 C! T+ J7 Q. x
Change the width of the keyway." r, x6 u3 [/ [8 k* L8 N1 B
Is the feature symmetrical and has design intent been maintained?改变键槽宽度,特征是否对称,设计要求是否保持?(10分)
"myptc" 兄人真是好,同情弱者,
引用:- I. ?' y& F: P" U" v& c; u/ R! C
您无权进行当前操作,这可能因以下原因之一造成:) ^" j) {: i$ T# x
: y; H; b* v# C! B: f( @$ \8 L9 w
( l* V/ G. a( z# J9 O# o7 u
对不起,只有特定用户可以下载本论坛的附件,请返回。 ( O7 Z# J9 `. H: Y; W+ V; ^& R
您已经登录,但您的帐号或其所在的用户组无权访问当前页面。
很难得的资料,支持提供者,学习中!
谢谢啦
想问下,考CSWP有什么用呀,怎么没听周围人说起过的?
请问是那个版本的,大家好决定是否下
GMT+8, 2025-7-12 22:03 , Processed in 0.256266 second(s), 18 queries .
