这个并不是开启多核心,没用我把原文贴过来了。This variable enables Symmetric Multi-processing (SMP) on systems/ K/ I% B6 i3 X0 d' X1 O" E
# with multiple CPU's or that support hyperthreading.   erformance will t$ Q4 u9 V% L' V ]1 D
# be improved in certain Parasolid operations, such as Mass Properties,
7 O f+ V4 o* o% a) L# Booleans and silhouette generation. This option is only supported on. Q1 @# M8 b3 h* k! `4 q8 o* H
# platforms where Parasolid supports multi-threading., z k& U0 T1 E8 b$ ]. g
7 g! W/ p/ D ~3 W: u9 |) S/ f# Set to 0 to disable SMP( a! x) `- P6 l
# Set to 1 to enable SMP5 O) c! Y: F. F" f3 N8 @# x* B
# Unset will take the Parasolid default
# Z! K8 o6 g% V! x6 u5 T, Z) {# UGII_SMP_ENABLE = 1
& t2 A( s) p6 v' O& V0 W: w0 M9 U说的是多处理器。支持超线程。在某些方面加速。例如:质量属性、布尔运算。 |
