楼主 |
发表于 2012-10-31 15:54
显示全部楼层
4 {7 O6 f: {7 W/ y q% U2 q, u8 r% A
用“记事本”打开程序UGII文件夹下的“ugii_env_ug.dat”文件,关键字查找“JAVA”,你会阅读到这么一段话:, s7 C, E8 u8 c! \
; R& u) h: o. e5 l* ]$ e
# As of NX 8.5, NX no longer provides a JRE in the installation.
3 [% U$ I5 v9 O# T6 O9 c# UGII_JAVA_HOME should point to the base directory of the JRE Installation.. @& n% g5 X: t& a9 d+ N \
# The value below is just an example that will be different on your system. 5 ~: [, }3 @' o; @& W* C
# Changing this variable will cause all NX java based applications to use the specified JRE.
5 D% N( I$ A1 I# b6 m0 o# This is an example of how this value can be set.
- U! W3 s, |* }( C6 r. c; a#if x64wnt* ^* N$ M. }0 w6 q, X8 ~
#if FILE c:\apps\Java\jre7x64
4 G( o# v( A7 m5 LUGII_JAVA_HOME=c:\apps\Java\jre7x64
* m ?8 z, I7 N#endif
$ b) M4 F! M# {#else
. h" k& I; F1 p( y' d#if FILE c:\apps\Java\jre7
7 h; F: m1 U, j, j. h1 c: ?UGII_JAVA_HOME=c:\apps\Java\jre7
! n6 `$ f$ w# \仅阅读1楼建议即可解决转换器无法使用的问题,2楼留言提供可以阅读英语文档的nx使用者额外信息以更好理解1楼解决方法缘由。
' l- \3 U/ a4 x' Z( t9 K' m a$ k$ }% O
方便论坛搜索索引查找的关键词: UGII_JAVA_HOME,JRE,转换器,Dxf dwg转换器,CAD转档,UG 8.5导入导出autocad 2D图。; p- T- _6 P. y) e
