悬赏10G币未解决
4 R2 {7 K; l/ ~/ `2 Z' E /*定义创建螺栓孔的参数*/ + U6 `! P2 I! u- e
tag_t placement_face,thru_face;3 x$ R# p( i5 }& M' i
uf_list_p_t face_list;" C9 F' i1 x. p# e' A
double hole_origin[3] = {0.5*PCD,0.0,0.0};
0 a6 x; j! P3 ?# @/ O# I* B; J double hole_dir[3] = {0.0,1.0,0.0};
; d. ^ f! ]) U1 G; e char *hole_dia ; - T* v; k1 Z# w
char *hole_height = "100"; ' \9 d" c; O/ p4 {# V9 u M
char *hole_angle = "0.0"; * t: l- K/ f q: `. ?% x
tag_t hole_id;
% @$ H- `: s! n! R2 A1 s
, i P- [ o, u6 p, c hole_dia = (char *) malloc(sizeof(char)*50);
" M+ [( N3 j$ n+ A m sprintf(hole_dia,"%f",REAL_14);+ H# J y4 k. O% `2 e. f% V# }, u
/ Y: Y" ]' w6 v4 p: K' M UF_MODL_ask_feat_faces(objects[0],&face_list); 8 }7 Q& c3 x" N9 ^& N
, d) ]4 p; V) v6 H" Q0 G& ^+ E: Y1 ]
$ S( t. M: s! ` UF_MODL_ask_list_item(face_list,0,&placement_face);
6 Z L0 N" b+ M% ?( [5 U; z, T UF_MODL_ask_list_item(face_list,1,&thru_face); 3 K- \ Z) @8 W$ Z
UF_MODL_delete_list(&face_list); ' {, R, y6 _8 E) X! c
7 u! j7 ^! ~. K) H2 s! p3 x UF_MODL_create_simple_hole(hole_origin,hole_dir,hole_dia, 5 t# C: O, O, [* r- |0 ?
hole_height,hole_angle,placement_face,thru_face,&hole_id);
' Z& Q f' `; G1 D: y+ R3 O" i8 G ]3 s6 J; k( H! k8 n3 w$ `# {* r
6 `/ I9 ~1 @' h4 _$ \& l+ o
/*创建螺栓孔阵列*/ : ^+ Z2 Q8 @/ E
* ^' Y9 z- N( f* l" X
; p) k2 G* X" W0 b( k8 X. | double location[3]={0.0,0.0,0.0};
4 S. S9 H6 [ { double axis[3] = {0.0,1.0,0.0};
9 C' N6 a- n' }# ^9 X char *number_str ;
+ @# v/ s4 O5 }5 R char *angle_str ;! }4 P1 s9 x3 e/ {8 o' n
number_str = (char *)malloc(sizeof(char)*256); ; r% }8 M m9 Z# j& r* I7 c
sprintf(number_str,"%d",LSNUM);5 S4 U6 P3 ^( I1 K! L
* ^; P5 R( j# x6 C
angle_str = (char *)malloc(sizeof(char)*256); , s1 ]( C: @; g6 H, B7 ?
1 G# t% z* j/ V |4 w6 u sprintf(angle_str,"%f",360.0/LSNUM);! i0 v: m( B2 {8 S8 k y8 Q/ b
+ b2 ^ {& p" G2 f h7 t) ]5 ^: V
uf_list_p_t iset_list=NULL;) A7 Q, ~+ p+ i/ G
tag_t holes_id=null_tag;# L1 d2 f5 d p- J) h3 |& u
UF_MODL_create_list(&iset_list);
5 E8 {! _& f% L$ Z$ h UF_MODL_put_list_item(iset_list,hole_id);( Y' \- c% S! ~ |/ b
* J' _6 g$ V, u: n7 N5 i0 R9 w& J
UF_MODL_create_circular_iset(0,location,axis,number_str,angle_str,iset_list,&holes_id );) t3 e5 \+ M$ H2 V9 x8 M' v
UF_MODL_delete_list(&iset_list);! w* [/ u% L' K0 l7 C5 ?4 V
注释:LSNUM是从对话框中获取的数值,程序调试后可以生成一个孔,但是环形阵列后却生成不了。求高手解答
l' C3 Y! q! t$ Q1 ?3 [6 q6 p8 G% `7 H# R% D& N W
) K: `9 k" k# o- n% V/ h2 M$ v+ _
# M% ?7 {/ ~) D0 G, w ] |
